- H3C S3600 Series Ethernet Switches Operation Manual-Release 1510(V1.04)
- 00-1Cover
- 00-2Product Overview
- 01-CLI Operation
- 02-Login Operation
- 03-Configuration File Management Operation
- 04-VLAN Operation
- 05-IP Address and Performance Configuration Operation
- 06-Management VLAN Operation
- 07-Voice VLAN Operation
- 08-GVRP Operation
- 09-Port Basic Configuration Operation
- 10-Link Aggregation Operation
- 11-Port Isolation Operation
- 12-Port Security-Port Binding Operation
- 13-DLDP Operation
- 14-MAC Address Table Operation
- 15-Auto Detect Operation
- 16-MSTP Operation
- 17-Routing Protocol Operation
- 18-Multicast Operation
- 19-802.1x Operation
- 20-AAA-RADIUS-HWTACACS-EAD Operation
- 21-VRRP Operation
- 22-Centralized MAC Address Authentication Operation
- 23-ARP Operation
- 24-DHCP Operation
- 25-ACL Operation
- 26-QoS-QoS Profile Operation
- 27-Web Cache Redirection Operation
- 28-Mirroring Operation
- 29-IRF Fabric Operation
- 30-Cluster Operation
- 31-PoE-PoE Profile Operation
- 32-UDP Helper Operation
- 33-SNMP-RMON Operation
- 34-NTP Operation
- 35-SSH Terminal Service Operation
- 36-File System Management Operation
- 37-FTP and TFTP Operation
- 38-Information Center Operation
- 39-System Maintenance and Debugging Operation
- 40-VLAN-VPN Operation
- 41-HWPing Operation
- 42-DNS Operation
- 43-Access Management Operation
- 44-Appendix
00-1Cover | 73 KB |
H3C S3600 Series Ethernet Switches |
Operation Manual |
Hangzhou H3C Technologies Co., Ltd. http://www.h3c.com
Manual Version: T2-08163G-20070724-C-1.04 Product Version: Release 1510 |
Copyright © 2006-2007, Hangzhou H3C Technologies Co., Ltd. and its licensors
All Rights Reserved
No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of Hangzhou H3C Technologies Co., Ltd.
Trademarks
H3C, , Aolynk, , H3Care, , TOP G, , IRF, NetPilot, Neocean, NeoVTL, SecPro, SecPoint, SecEngine, SecPath, Comware, Secware, Storware, NQA, VVG, V2G, VnG, PSPT, XGbus, N-Bus, TiGem, InnoVision and HUASAN are trademarks of Hangzhou H3C Technologies Co., Ltd.
All other trademarks that may be mentioned in this manual are the property of their respective owners.
Notice
The information in this document is subject to change without notice. Every effort has been made in the preparation of this document to ensure accuracy of the contents, but all statements, information, and recommendations in this document do not constitute the warranty of any kind, express or implied.
To obtain the latest information, please access:
http://www. h3c.com
Technical Support
http://www. h3c.com
About This Manual
Related Documentation
In addition to this manual, each H3C S3600 Series Ethernet Switches-Release 1510 documentation set includes the following:
Manual |
H3C S3600 Series Ethernet Switches Command Manual-Release 1510 |
It is used for assisting the users in using various commands. |
H3C S3600 Series Ethernet Switches Installation Manual |
It provides information for the system installation. |
Organization
H3C S3600 Series Ethernet Switches Operation Manual-Release 1510 is organized as follows:
Part |
Contents |
0 Product Overview |
Introduces the characteristics and implementations of the Ethernet switch. |
1 CLI |
Introduces the command hierarchy, command view and CLI features of the Ethernet switch. |
2 Login |
Introduces the ways to log into an Ethernet switch. |
3 Configuration File Management |
Introduces the ways to manage configuration files. |
4 VLAN |
Introduces VLAN fundamental and the related configuration. |
5 IP Address and Performance Configuration |
Introduces IP address and IP performance fundamental and the related configuration. |
6 Management VLAN |
Introduces the management VLAN configuration. |
7 Voice VLAN |
Introduces voice VLAN fundamental and the related configuration. |
8 GVRP |
Introduces GVRP and the related configuration. |
9 Port Basic Configuration |
Introduces basic port configuration. |
10 Link Aggregation |
Introduces link aggregation and the related configuration. |
11 Port Isolation |
Introduces port isolation and the related configuration. |
12 Port Security-Port Binding |
Introduces port security, port binding, and the related configuration. |
13 DLDP |
Introduces DLDP and the related configuration. |
14 MAC Address Table |
Introduces MAC address forwarding table and the related configuration. |
15 Auto Detect |
Introduces auto detect and the related configuration. |
16 MSTP |
Introduces STP and the related configuration. |
17 Routing Protocol |
Introduces the routing protocol-related configurations, including static route configuration, RIP configuration, OSPF configuration, IS-IS configuration, BGP configuration, and routing policy configuration. |
18 Multicast |
Introduces the configuration of GMRP, IGMP Snooping, IGMP, PIM-DM, PIM-SM, and MSDP. |
19 802.1x |
Introduces 802.1x and the related configuration. |
20 AAA-RADIUS-HWTACACS-EAD |
Introduces AAA, RADIUS, HWTACACS, EAD, and the related configurations. |
21 VRRP |
Introduces VRRP and the related configuration. |
22 Centralized MAC Address Authentication |
Introduces centralized MAC address authentication and the related configuration. |
23 ARP |
Introduces ARP and the related configuration. |
24 DHCP |
Introduces DHCP server, DHCP relay, DHCP-Snooping, and the related configurations. |
25 ACL |
Introduces ACL and the related configuration. |
26 QoS-QoS Profile |
Introduces QoS, QoS profile and the related configuration. |
27 Web Cache Redirection |
Introduces Web cache redirection and the related configuration. |
28 Mirroring |
Introduces port mirroring and the related configuration. |
29 IRF Fabric |
Introduces IRF fabric-related configuration. |
30 Cluster |
Introduces the configuration to form clusters using HGMP V2. |
31 PoE-PoE Profile |
Introduces PoE, PoE profile and the related configuration. |
32 UDP Helper |
Introduces UDP Helper and the related configuration. |
33 SNMP-RMON |
Introduces the configuration to manage network devices through SNMP and RMON. |
34 NTP |
Introduces NTP and the related configuration. |
35 SSH Terminal Service |
Introduces SSH2.0 and the related configuration. |
36 File System Management |
Introduces basic configuration for file system management. |
37 FTP and TFTP |
Introduces basic configuration for FTP and TFTP, and the applications. |
38 Information Center |
Introduces the configuration to analyze and diagnose networks using the information center. |
39 System Maintenance and Debugging |
Introduces daily system maintenance and debugging. |
40 VLAN-VPN |
Introduces VLAN VPN and the related configuration. |
41 HWPing |
Introduces HWPing and the related configuration. |
42 DNS |
Introduces DNS and the related configuration. |
43 Access Management |
Introduces Access Management and the related configuration. |
44 Appendix |
Lists the acronyms used in this manual. |
Conventions
The manual uses the following conventions:
I. Command conventions
Convention |
Boldface |
The keywords of a command line are in Boldface. |
italic |
Command arguments are in italic. |
Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } |
Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] |
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * |
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * |
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
A line starting with the # sign is comments. |
II. GUI conventions
Convention |
Button names are inside angle brackets. For example, click <OK>. |
Window names, menu items, data table and field names are inside square brackets. For example, pop up the [New User] window. |
Multi-level menus are separated by forward slashes. For example, [File/Create/Folder]. |
III. Symbols
Convention |
Warning |
Means reader be extremely careful. Improper operation may cause bodily injury. |
Caution |
Means reader be careful. Improper operation may cause data loss or damage to equipment. |
& Note |
Means a complementary description. |
