- H3C S3600 Series Ethernet Switches Operation Manual-Release 1510(V1.04)
- 00-1Cover
- 00-2Product Overview
- 01-CLI Operation
- 02-Login Operation
- 03-Configuration File Management Operation
- 04-VLAN Operation
- 05-IP Address and Performance Configuration Operation
- 06-Management VLAN Operation
- 07-Voice VLAN Operation
- 08-GVRP Operation
- 09-Port Basic Configuration Operation
- 10-Link Aggregation Operation
- 11-Port Isolation Operation
- 12-Port Security-Port Binding Operation
- 13-DLDP Operation
- 14-MAC Address Table Operation
- 15-Auto Detect Operation
- 16-MSTP Operation
- 17-Routing Protocol Operation
- 18-Multicast Operation
- 19-802.1x Operation
- 20-AAA-RADIUS-HWTACACS-EAD Operation
- 21-VRRP Operation
- 22-Centralized MAC Address Authentication Operation
- 23-ARP Operation
- 24-DHCP Operation
- 25-ACL Operation
- 26-QoS-QoS Profile Operation
- 27-Web Cache Redirection Operation
- 28-Mirroring Operation
- 29-IRF Fabric Operation
- 30-Cluster Operation
- 31-PoE-PoE Profile Operation
- 32-UDP Helper Operation
- 33-SNMP-RMON Operation
- 34-NTP Operation
- 35-SSH Terminal Service Operation
- 36-File System Management Operation
- 37-FTP and TFTP Operation
- 38-Information Center Operation
- 39-System Maintenance and Debugging Operation
- 40-VLAN-VPN Operation
- 41-HWPing Operation
- 42-DNS Operation
- 43-Access Management Operation
- 44-Appendix
01-CLI Operation | 102 KB |
1.2 Command Level/Command View
1.2.1 Switching between User Levels.
1.2.2 Configuring a Level for a Specific Command in a Specific View
Chapter 1 CLI Configuration
1.1 Introduction to the CLI
S3600 series Ethernet switches provide a command line interface (CLI) and commands for you to configure and manage your switches. The CLI is featured by the following:
l Commands are grouped by level. This prevents unauthorized users from configuring switches with relevant commands.
l You can gain online help at any time by entering a question mark "?".
l Common diagnostic utilities (such as Tracert and Ping) are available.
l A variety of debugging information is available.
l A function similar to Doskey is provided for you to execute a history command.
l You can execute a command by entering part of the command in the CLI as long as the keywords you enter do not conflict those of other commands.
To prevent unauthorized accesses, commands are grouped by level.
Commands fall into four levels: visit, monitor, system, and manage.
l Visit level: Commands at this level are mainly used to diagnose network and switch the language mode on the user interface, and they cannot be saved in configuration files. Such commands include ping, tracert, and language-mode.
l Monitor level: Commands at this level are mainly used to maintain the system and diagnose service faults, and they cannot be saved in configuration files. Such commands include display and debugging.
l System level: Commands at this level are mainly used to configure services. Commands concerning routing and network layers are at this level. These commands can be used to provide network services directly.
l Manage level: Commands at this level are associated with the basic operation modules and support modules of the system. These commands provide supports for services. Commands concerning file system, FTP/TFTP/XModem downloading, user management, and level setting are at this level.
Users logging in to a switch also fall into four levels, which respectively correspond to the command levels. Users at a specific level can only use the commands at the same level or lower levels.
You can switch from one user level to another by executing a related command and set a password for the switching as required after logging in to a switch.
I. Setting a password for user level switching
Table 1-1 lists the operations to set a password for user level switching.
Table 1-1 Set a password for user level switching
Operation |
Command |
Enter system view |
system-view |
Set a password for switching from a lower user level to the user level specified by the level argument |
super password [ level level ] { simple | cipher } password |
Optional A password is necessary only when a user switches from a lower user level to a higher user level. |
II. Switching between user levels
Table 1-2 lists the operation to switch between user levels.
Table 1-2 Switch between user levels
Operation |
Command |
Switch from the current user level to the user level specified by the level argument |
super [ level ] |
Required Execute this command in user view. If you have set a password for user level switching by using the super password command and you want to switch from a lower user level to a higher user level, you need to enter the correct password. Otherwise, you will remain at the original user level. |
& Note:
l By default, you switch from the current user level to level 3.
l For the purpose of security, you cannot see the password you enter on the screen. You will remain at the original user level if you fail to enter the correct password after you have tried more than three times.
You can configure a level for a specific command in a specific view. Commands fall into four levels: visit, monitor, system, and manage, which are identified as 0, 1, 2, and 3 respectively. The administrator can change the command level according to the requirements..
Table 1-3 lists the operations to configure a level for a specific command.
Table 1-3 Configure a level for a specific command in a specific view
Operation |
Command |
Enter system view |
system-view |
Configure a level for a specific command in a specific view |
command-privilege level level view view command |
Required It is forbidden to change the command level at will. Doing so may bring inconvenience to maintenance and operation. |
1.2.3 CLI Views
CLI views are designed for different configuration tasks. They are related but distinguished. You will enter user view once you log in to a switch successfully, where you can view operation status and statistics information. After executing the system-view command, you can enter system view, where you can go into other views by entering corresponding commands.
The following CLI views are provided:
l User view
l System view
l Ethernet interface view
l VLAN view
l VLAN interface view
l Loopback interface view
l Local user view
l User interface view
l FTP client view
l SFTP client view
l MST region view
l Cluster view
l Public key view
l Public key code view
l DHCP address pool view
l PIM view
l RIP view
l OSPF view
l OSPF area view
l Routing policy view
l Basic ACL view
l Advanced ACL view
l Layer 2 ACL view
l User-defined ACL view
l QoS profile view
l RADIUS scheme view
l ISP domain view
l HWPing view
l HWTACACS view
l MSDP view
l PoE profile view
Table 1-4 lists operations you can perform in these CLI views and details about commands used to enter these CLI views.
Table 1-4 Operations in CLI views
View |
Available operation |
Prompt |
Enter method |
Quit method |
User view |
Display operation status and statistical information |
<H3C> |
Enter user view once logging in to the switch. |
Execute the quit command in user view to log out of the switch. |
System view |
Configure system parameters |
[H3C] |
Execute the system-view command in user view. |
Execute the quit or return command to return to user view. |
Ethernet interface view |
Configure Ethernet interface parameters |
100M Ethernet interface view Execute the interface ethernet 1/0/1 command in system view. |
Execute the quit command to return to system view. Execute the return command to return to user view. |
[H3C-GigabitEthernet1/1/1] |
Gigabit Ethernet interface view Execute the interface gigabitethernet 1/1/1 command in system view. |
VLAN view |
Configure VLAN parameters |
[H3C-vlan1] |
Execute the vlan 1 command in system view. |
VLAN interface view |
Configure IP interface parameters for VLANs and aggregated VLANs |
[H3C-Vlan-interface1] |
Execute the interface vlan-interface 1 command in system view. |
Loopback interface view |
Configure loopback interface parameters |
[H3C-LoopBack0] |
Execute the interface loopback 0 command in system view |
Local user view |
Configure local user parameters |
[H3C-luser-user1] |
Execute the local-user user1 command in system view. |
User interface view |
Configure user interface parameters |
[H3C-ui0] |
Execute the user-interface 0 command in system view. |
FTP client view |
Configure FTP client parameters |
[ftp] |
Execute the ftp command in user view. |
Execute the quit command to return to user view. |
SFTP client view |
Configure SFTP client parameters |
sftp-client> |
Execute the sftp 10.1.1.1 command in system view. |
MST region view |
Configure MST region parameters |
[H3C-mst-region] |
Execute the stp region-configuration command in system view. |
Cluster view |
Configure cluster parameters |
[H3C-cluster] |
Execute the cluster command in system view. |
Public key view |
Configure RSA public keys for SSH users |
[H3C-rsa-public-key] |
Execute the rsa peer-public-key a003 command in system view. |
Execute the peer-public-key end command to return to system view. |
Public key code view |
Edit RSA public key for SSH users |
[H3C-rsa-key-code] |
Execute the public-key-code begin command in public key code view |
Execute the public-key-code end command to return to public key view |
DHCP address pool view |
Configure DHCP address pool parameters |
[H3C-dhcp-pool-a123] |
Execute the dhcp server ip-pool a123 command in system view |
PIM view |
Configure PIM parameters |
[H3C-pim] |
Execute the pim command in system view |
RIP view |
Configure RIP parameters |
[H3C-rip] |
Execute the rip command in system view |
OSPF view |
Configure OSPF protocol parameters |
[H3C-ospf-1] |
Execute the ospf command in system view |
OSPF area view |
Configure OSPF area parameters |
[H3C-ospf-1-area-0.0.0.1] |
Execute the area 1 command in OSPF view |
Execute the quit command to return to OSPF view. Execute the return command to return to user view. |
Routing policy view |
Configure routing policies |
[H3C-route-policy] |
Execute the route-policy policy1 permit node 10 command in system view |
Basic ACL view |
Define sub-rules for a basic ACL (with ID ranging from 2000 to 2999) |
[H3C-acl- basic-2000] |
Execute the acl number 2000 command in system view. |
Advanced ACL view |
Define sub-rules for an advanced ACL (with ID ranging from 3000 to 3999) |
[H3C-acl- adv-3000] |
Execute the acl number 3000 command in system view. |
Layer 2 ACL view |
Define sub-rules for an layer 2 ACL (with ID ranging from 4000 to 4999) |
[H3C-acl-ethernetframe-4000] |
Execute the acl number 4000 command in system view. |
User-defined ACL view |
Define sub-rules for a user-defined ACL (with ID ranging from 5000 to 5999) |
[H3C-acl-user-5000] |
Execute the acl number 5000 command in system view |
QoS profile view |
Define QoS profile |
[H3C-qos-profile-a123] |
Execute the qos-profile a123 command in system view |
RADIUS scheme view |
Configure RADIUS parameters |
[H3C-radius-1] |
Execute the radius scheme 1 command in system view. |
ISP domain view |
Configure ISP domain parameters |
[H3C-isp-aaa163.net] |
Execute the domain aaa163.net command in system view. |
HWPing view |
Configure HWPing parameters |
[H3C-hwping-a123-a123] |
Execute the hwping a123 a123 command in system view |
HWTACACS view |
Configure HWTACACS parameters |
[H3C-hwtacacs-a123] |
Execute the hwtacacs scheme a123 command in system view |
MSDP view |
Configure MSDP parameters |
[H3C-msdp] |
Execute the msdp command in system view |
PoE profile view |
Configure PoE profile parameters |
[H3C-poe-profile-a123] |
Execute the poe-profile a123 command in system view |
& Note:
The <Ctrl + Z> keys function as the return command does.
1.3 CLI Features
1.3.1 Online Help
CLI provides two types of online help: complete online help and partial online help. You can obtain help information necessary for the switch configuration.
I. Complete online help
Enter a "?" character in any view on your terminal to display all the commands available in the view and their brief descriptions. The following takes user view as an example.
<H3C> ?
User view commands:
backup Backup current configuration
boot Set boot option
cd Change current directory
clock Specify the system clock
cluster Run cluster command
copy Copy from one file to another
debugging Enable system debugging functions
delete Delete a file
dir List files on a file system
display Display current system information
<omitted>
Enter a command, a space, and a "?" character. If a keyword is in the “?” position of the command, all available keywords and their brief descriptions will be displayed on your terminal. The following takes the clock command as an example.
<H3C> clock ?
datetime Specify the time and date
summer-time Configure summer time
timezone Configure time zone
Enter a command, a space, and a "?" character. If an argument is in the “?” position of the command, all available arguments and their brief descriptions will be displayed on your terminal. The following takes the interface vlan command as an example.
[H3C] interface vlan-interface ?
<1-4094> VLAN interface number
[H3C] interface vlan-interface 1 ?
<cr>
The <cr> string means that no argument is available in the “?” position. You can directly execute the command by pressing <Enter>.
II. Partial online help
Enter a character string followed by a "?" character on your terminal to display all the commands beginning with the string. For example:
<H3C> pi?
ping
Enter a command, a space, and a character string followed by a "?" character on your terminal to display all the keywords that belong to the command and begin with the string (if available). For example:
<H3C> display ver?
version
Enter the first several characters of a keyword in a command and then press <Tab>, the complete keyword will be displayed on the terminal screen if the input characters uniquely identify a keyword; all the keywords that match the input characters will be displayed on the terminal screen if the input characters match more than one keyword.
You can use the language-mode command to display the help information in English.
1.3.2 Terminal Display
CLI provides the following display features:
l The prompt information and help information can be displayed in Chinese or English.
l Display suspension. That is, the display of output information can be paused when the screen is full and you can then perform one of the three operations listed in Table 1-5 as needed.
Table 1-5 Display-related operations
Operation |
Function |
Press <Ctrl+C> |
Suspend the display and execution of a command. |
Press the space key |
Scroll the output information up by one page. |
Press <Enter> |
Scroll the output information up by one line. |
1.3.3 History Commands
The CLI provides a function similar to Doskey to store the history commands automatically. You can recall and execute these history commands at any time. By default, the CLI can store 10 history commands for each user. Table 1-6 lists history command-related operations.
Table 1-6 Access history commands
Operation |
Operation |
Display history commands |
Execute the display history-command command |
This command displays valid history commands. |
Recall the previous history command |
Press the up-arrow key or <Ctrl+P> |
This operation recalls the previous history command (if available). |
Recall the next history command |
Pressing the down-arrow key or <Ctrl+N> |
This operation recalls the next history command (if available). |
& Note:
l The Up and Down arrow keys can be used to recall history commands only in terminals running on Windows 3.x or Telnet running on Windows 3.x. You can press <Ctrl + P> or <Ctrl + N> in terminals running on Windows 9x to achieve the same purpose.
l If you enter and execute the same command for multiple times, the command is buffered when it is entered for the first time.
1.3.4 Error Messages
If the command you enter passes the syntax check, it will be successfully executed; otherwise an error message will appear. Table 1-7 lists the common error messages.
Table 1-7 Common error messages
Error message |
Unrecognized command |
The command does not exist. |
The keyword does not exist. |
The parameter type is wrong. |
The parameter value is out of range. |
Incomplete command |
The command entered is incomplete. |
Too many parameters |
You have entered too many parameters. |
Ambiguous command |
The parameters entered are ambiguous. |
Wrong parameter found at '^' position. |
The parameter at the '^' position is incorrect. |
1.3.5 Command Edit
The CLI provides basic command edit functions and supports multi-line editing. The maximum number of characters a command can contain is 254. Table 1-8 lists the CLI edit operations.
Table 1-8 Edit operations
Press… |
To… |
Common key |
Insert the character the key represents at the cursor and move the cursor one character to the right if the edit buffer is not full. |
Backspace key |
Delete the character on the left of the cursor and move the cursor one character to the left. |
Left arrow key or <Ctrl+B> |
Move the cursor one character to the left. |
Right arrow key or <Ctrl+F> |
Move the cursor one character to the right. |
Up arrow key or <Ctrl+P> Down arrow key or <Ctrl+N> |
Display history commands. |
Tab key |
Utilize the partial online help. That is, when you enter an incomplete keyword and press the Tab key, if the input keyword uniquely identifies an existing keyword, the system substitutes the complete key word for the incomplete keyword; if the input keyword matches more than one keyword, all the keywords are displayed on the terminal screen, with each keyword on a line; if the input arguments matches no keyword, the system displays your original input on a new line without any change. |
