06-三层技术-IP业务配置指导
09-UDP Helper配置
本章节下载 09-UDP Helper配置  (137.78 KB)
09-UDP Helper配置
  录
1 UDP Helper···································································································································· 1-1
1.1 UDP Helper简介····················································································································· 1-1
1.2 配置UDP Helper····················································································································· 1-1
1.3 UDP Helper显示和维护············································································································ 1-2
1.4 UDP Helper典型配置举例········································································································ 1-2
1.4.1 UDP Helper配置举例····································································································· 1-2
1 UDP Helper
1.1  UDP Helper简介
网络中的主机有时需要通过发送广播报文,来获得网络配置或查询网络中其他设备的名称。但是,当主机与服务器或待查询的设备不在同一个广播域时,主机就无法获得所需要的信息。
为解决上述问题,设备提供了UDP Helper功能。通过该功能可以实现对指定UDP端口的IP广播报文进行中继转发,即将指定UDP端口的广播报文转换为单播报文发送给指定的目的服务器,起到中继的作用。
使能UDP Helper功能后,如果设备接收到广播报文,将根据报文的UDP目的端口号来判断是否要对其中继转发,并进行相应的处理:
·     如果报文的UDP目的端口号与配置的需要中继转发的UDP端口号匹配,则修改IP报文头的目的IP地址,将报文发给指定的目的服务器;
·     如果报文的UDP目的端口号与配置的需要中继转发的UDP端口号不匹配,则直接将报文送给上层协议处理。
1.2  配置UDP Helper
表1-1 配置UDP Helper
使能UDP Helper功能
udp-helper enable
缺省情况下,UDP Helper功能处于关闭状态
配置需要中继转发的UDP端口
缺省情况下,没有配置中继转发的UDP端口
进入接口视图
配置中继转发的目的服务器
udp-helper server [ vpn-instance vpn-instance-name ] ip-address
缺省情况下,没有配置中继转发的目的服务器
·     UDP Helper功能不能中继转发DHCP广播报文,即中继转发的UDP端口不能配置为67和68。
·     需要中继转发的UDP端口有两种配置方法:指定端口号配置和指定参数配置。例如:udp-helper port 53和udp-helper port dns的效果是一样的。
·     关闭UDP Helper功能后,所有已配置的UDP端口都被取消。
·     设备上最多可以配置256个需要中继转发的UDP端口。
·     一个接口上最多可以配置20个中继转发的目的服务器。
1.3  UDP Helper显示和维护
在完成上述配置后,在任意视图下执行display命令可以显示配置后UDP中继转发的目的服务器信息以及中继转发到目的服务器的报文数目,通过查看显示信息验证配置的效果。
在用户视图下,执行reset命令可以清除UDP中继转发的报文统计数目。
表1-2 UDP Helper显示和维护
显示UDP中继转发的相关信息
display udp-helper server [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
清除UDP中继转发的报文统计数目
reset udp-helper packet
缺省情况下,以太网接口、VLAN接口及聚合接口处于DOWN状态。如果要对这些接口进行配置,请先使用undo shutdown命令使接口状态处于UP状态。
Switch A的VLAN接口1的IP地址为10.110.1.1/16,连接到网段10.110.0.0/16。配置将目的UDP端口号为55、目的IP地址为255.255.255.255和此网段子网广播地址10.110.255.255的广播报文,中继转发到目的服务器10.2.1.1/16。
图1-1 UDP Helper配置举例组网图
用户需保证Switch A到网段10.2.0.0/16路由可达。
# 使能UDP Helper功能。
[SwitchA] udp-helper enable
# 配置将目的UDP端口号为55的广播报文进行中继转发。
[SwitchA] udp-helper port 55
# 配置中继转发的目的服务器为公网中的10.2.1.1。
[SwitchA-Vlan-interface1] ip address 10.110.1.1 16
[SwitchA-Vlan-interface1] udp-helper server 10.2.1.1
