09-Configuration Examples
HomeSupportConfigure & DeployH3C Firewall Products Comware 7 Web Configuration Guide-6W60009-Configuration Examples
Table of Contents
Related Documents
44-IRF configuration examples
44-IRF configuration examples 88.67 KB
·     Introduction
·     Prerequisites
·     Example: Setting up an IRF fabric
The following information provides IRF configuration examples.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of the IRF feature.
As shown in Figure 1, use Device A and Device B to set up an IRF fabric. Assign Device A a higher priority than Device B so Device A can be the master device.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R8860 of the F1000-AI-55 device.
Configuring Device A
# On the top navigation bar, click System.
# From the navigation pane, select Virtualization Advanced Settings > IRF.
# Click the Settings icon for IRF-port 2.
# In the dialog box that opens, configure IRF parameters as shown in Figure 2.
Figure 2 Configuring IRF on Device A
# Click OK.
Configuring Device B
# Click the Settings icon for IRF-port 1.
# In the dialog box that opens, configure IRF parameters as shown in Figure 3.
Figure 3 Configuring IRF on Device B
# Click OK.
Device B automatically reboots. The member ID and physical interface numbers of Device B change after the reboot. The device forms an IRF fabric with Device A.
# Use the management address of the master (Device A) to log in to the Web interface of the IRF fabric.
# Verify that Device A and Device B are IRF member devices and their IRF ports are up.
Figure 4 IRF information
