- 09-Configuration Examples
- 01-Web Login Configuration Examples
- 02-Internet Access Through a Static IP Address Configuration Examples
- 03-Internet access through PPPoE configuration examples
- 04-License Configuration Examples
- 05-Signature Library Upgrade Configuration Examples
- 06-Software Upgrade Examples
- 06-Software Upgrade Examples (only for F50X0-D and F5000-AK5X5 firewalls)
- 07-Routing deployment configuration examples
- 08-Transparent deployment configuration examples
- 09-Static routing configuration examples
- 10-RIP configuration examples
- 11-OSPF configuration examples
- 12-BGP configuration examples
- 13-Policy-based routing configuration examples
- 14-Security Policy Configuration Examples
- 15-APR-Based Security Policy Configuration Examples
- 16-Object Group Configuration Examples
- 17-User identification configuration examples
- 18-Attack defense configuration examples
- 19-IPCAR Configuration Examples
- 20-IPS Configuration Examples
- 21-URL Filtering Configuration Examples
- 22-Anti-Virus Configuration Examples
- 23-File Filtering Configuration Examples
- 24-Data Filtering Configuration Examples
- 25-WAF Configuration Examples
- 26-IP Reputation Configuration Examples
- 27-APT Defense Configuration Examples
- 28-NetShare Control Configuration Examples
- 29-Bandwidth Management Configuration Examples
- 30-IPsec configuration examples
- 31-SSL VPN IP access configuration examples
- 31-SSL VPN TCP access configuration examples
- 31-SSL VPN Web access configuration examples
- 32-L2TP Configuration Examples
- 33-NAT configuration examples
- 34-NPTv6 Configuration Examples
- 35-Policy-based NAT configuration examples
- 36-NAT hairpin configuration examples
- 37-NAT Flow Logging Configuration Examples
- 38-Inbound Link Load Balancing Configuration Examples
- 39-Outbound Link Load Balancing Configuration Examples
- 40-Server Load Balancing Configuration Examples
- 41-Transparent DNS Proxy Configuration Examples
- 42-High Availability Group Configuration Examples
- 43-Context Configuration Examples
- 43-Context Configuration Examples(only for F50X0-D and F5000-AK5X5 firewalls)
- 44-IRF configuration examples
- 44-IRF configuration examples(only for F50X0-D and F5000-AK5X5 firewalls)
- 45-DHCP configuration examples
- 46-DNS configuration examples
- 47-Server Connection Detection Configuration Examples
- 48-Connection Limit Configuration Examples
- 49-Public key management configuration examples
- 50-SSL Decryption Configuration Examples
- 51-MAC Address Learning Through a Layer 3 Device Configuration Examples
- 52-4G Configuration Examples
- 53-WLAN Configuration Examples
07-Routing deployment configuration examples | 83.48 KB |
· Example: Configuring routing deployment
Routing deployment enables the device to operate at Layer 3 (both the uplink and downlink service interfaces of the device operate at Layer 3) in the network, implementing security inspection and control for network traffic.
Routing deployment requires changing the existing network address plan, and enables the device to support various routing and security features.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of interface configuration and security policies.
As shown in Figure 1, an enterprise deploys a device as a security protection device at the network border. The device can connect the internal network and the Internet, perform security inspection and control for network traffic, and support routing and various security features.
Software versions used
This configuration example was created and verified on R8860 of the F1000-AI-55 device.
Configuring the device
1. Assign IP addresses to interfaces and add the interfaces to security zones.
# On the top navigation bar, click Network.
# From the navigation pane, select Interface Configuration > Interfaces.
# Click the Edit icon for GE 1/0/1.
# In the dialog box that opens, configure the IP address and security zone settings as shown in Figure 2.
a. Select the Trust security zone.
b. Enter the IP address and mask of the interface. In this example, enter 10.1.1.1/24.
c. Use default settings for other parameters.
d. Click OK.
Figure 2 Configuring interface information
# Configure the IP address and security zone settings for GE 1/0/2 in the same way you configure GE 1/0/1.
2. Configure a static route:
You can configure a dynamic routing protocol based on network requirements. This example uses a static route as an example. Assume the next hop IP address that the device connects to the external network is 20.1.1.2.
# From the navigation pane, select Routing > Static Routing.
# On the IPv4 Static Routing tab, click Create.
# In the dialog box that opens, configure the following parameters:
a. Enter the destination IP address 0.0.0.0.
b. Specify the mask length as 0.
c. Specify the next hop IP address as 20.1.1.2.
d. Use default settings for other parameters.
# Click OK.
3. Create a security policy to enable the host to access the external network.
# On the top navigation bar, click Policies.
# From the navigation pane, select Security Policies > Security Policies.
# Select Create > Create a policy.
# In the dialog box that opens, configure the security policy as shown in Figure 3.
Figure 3 Creating a security policy
# Use default settings for other parameters, and then click OK.
Configuring the host
# Configure the IPv4 address of the default gateway as 10.1.1.1 for the host.
# Verify that only the host with IP address 10.1.1.2 in the internal network can access the external network. Other hosts cannot access the external network.
