09-Configuration Examples
HomeSupportConfigure & DeployH3C Firewall Products Comware 7 Web Configuration Guide-6W60009-Configuration Examples
Table of Contents
Related Documents
37-NAT Flow Logging Configuration Examples
37-NAT Flow Logging Configuration Examples 111.09 KB
NAT flow logging configuration examples
·     Introduction
·     Prerequisites
·     Example: Configuring NAT flow logging
The following information provides NAT flow logging configuration examples.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of flow logging, NAT logging, and NAT.
As shown in Figure 1, configure NAT flow logging on the device to enable it to send NAT session information to the log server for user tracing and analysis. The following log information is recorded when the internal host accesses the server on the public network: Source IP address, source port number, destination IP address, and destination port number before and after NAT translation.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R8860 of the F1000-AI-55 device.
·     To record IP address and port number after translation, use log version 3.0.
·     For the NAT flow logging to take effect, you must enable NAT logging.
·     Logs cannot be sent to the log host and the information center at the same time. By default, logs are sent to the log host. If the information center is specified as the log output destination, logs will not be sent to the log host.
Configuring the device
1.     Assign IP addresses to interfaces and add the interfaces to security zones.
# On the top navigation bar, click Network.
# From the navigation pane, select Interface Configuration > Interfaces.
# Click the Edit icon for GE 1/0/0.
# In the dialog box that opens, configure the interface:
a.     Select the DMZ security zone.
b.     On the IPv4 Address tab, enter the IP address and mask of the interface. In this example, enter 192.168.100.200/24.
c.     Click OK.
# Add GE 1/0/1 to the Trust security zone and set its IP address to 172.16.1.254/24 in the same way you configure GE 1/0/0.
# Add GE 1/0/2 to the Untrust security zone and set its IP address to 202.2.2.1/24 in the same way you configure GE 1/0/0.
2.     Create security policy SecPolicy1.
# On the top navigation bar, click Policies.
# From the navigation pane, select Security Policies > Security Policies.
# Click Create and click Create a policy.
# In the dialog box that opens, configure a security policy:
¡     Enter policy name SecPolicy1.
¡     Select source zone Trust.
¡     Select destination zone Untrust.
¡     Select IPv4 as the type.
¡     Select action Permit.
¡     Specify 172.16.1.0/24 as the source address.
¡     Specify 202.2.2.0/24 as the destination address.
# Click OK.
3.     Create security policy SecPolicy2.
# Click Create.
¡     Enter policy name SecPolicy2.
¡     Select source zone Local.
¡     Select destination zone DMZ.
¡     Specify 192.168.100.0/24 as the destination address.
# Click OK.
4.     Configure a policy-based NAT rule.
# From the navigation pane, select Policy-based NAT.
# Click Create.
# Create a policy-based NAT rule, as shown in Figure 1.
Figure 2 Creating a policy-based NAT rule
# Click OK.
5.     Configure flow logging.
# On the top navigation bar, click System.
# From the navigation pane, select Log Settings > Basic Settings.
# On the Flow Log tab, configure flow logging, as shown in Figure 3.
Figure 3 Configure flow logging
6.     Configure NAT logging.
# From the navigation pane, select Log Settings > NAT Log Settings.
# Configure NAT logging, as shown in Figure 3.
Figure 4 Configure NAT logging
# Click Apply.
Configuring the log server
# Configure the log server. (Details not shown.)
Verify that a NAT session log is generated on the log server when the host accesses the server on the public network. The log information includes source IP address, source port number, destination IP address, and destination port number before and after translation.
