09-Configuration Examples
HomeSupportConfigure & DeployH3C Firewall Products Comware 7 Web Configuration Guide-6W60009-Configuration Examples
Table of Contents
Related Documents
17-User identification configuration examples
17-User identification configuration examples 2.00 MB
·     Introduction
·     Prerequisites
·     General restrictions and guidelines
·     Example: Configuring user identification for portal users that pass RADIUS authentication (RADIUS single sign-on)
·     Example: Configuring user identification for portal users that pass RADIUS authentication (non-RADIUS single sign-on)
·     Example: Configuring user identification for users obtained from a Dr.Com server (Dr.Com server single sign-on)
The following information provides user identification configuration examples.
The user identification feature identifies users by IP addresses. This feature works with other security features to control network access on a per-user basis.
The feature enables the device to perform the following tasks:
·     Implements security policies on a per-user basis to improve the policy usability.
·     Collects statistics and analysis for network attack behaviors and traffic flow on a per-user basis to track the user network access behaviors in real time.
·     Implements policy control regardless of changes to the user IP addresses.
The RADIUS single sign-on service enables a RADIUS server to synchronize user identity information (for example, the username and IP address) to a security device (for example, a firewall) so the users can access the network without having to authenticate with the device after they pass authentication with the RADIUS server.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of the portal, AAA, user identification, and security policy features.
When you configure security policies and packet filtering policies, make sure they can take effect as you expected. Security policies process packets prior to packet filtering policies. Packet filtering policies will not process the packets that have matched security policies.
As shown in Figure 1:
·     Users user10001, user10002, and user10003 use static IP addresses, and they must pass portal authentication to access the network.
·     The router acts as a NAS for the users to access the network. The NAS uses the RADIUS server to authenticate the users.
·     The RADIUS server is installed with IMC components. For portal authentication, the server acts as both the portal authentication server and portal Web server.
·     The RESTful server stores user account information. The server can synchronize user identity information to Device.
·     Device is a firewall. The users can access the network without having to authenticate with the firewall after they pass authentication with the RADIUS server.
·     The firewall performs the following identity-based access control on the users that have passed portal authentication:
¡     User user10001 cannot access the FTP server or Internet.
¡     User user10002 can access the FTP server but cannot access the Internet.
¡     User user10003 can access the Internet but cannot access the FTP server.
¡     Users from the Internet cannot access the hosts in the Trust and DMZ security zones.
Figure 1 Network diagram
Analysis
Figure 2 Analysis diagram
Software versions used
This configuration example was created and verified on the following software versions:
·     R8860 of the F1000-AI-55 device.
·     Version 7.1.064, ESS 0701 of the MSR26-30 router.
The RADIUS and portal server is installed with IMC PLAT 7.3 (E0606), IMC UAM 7.3 (E0503), IMC CAMS 7.3 (E0501), and IMC EIA 7.3 (E0512).
An IMC server logs off an online user only after it receives an accounting-stop request for that user. For the NAS to send accounting-stop requests to the server, you need to configure accounting settings in the authentication domain of the user on the NAS. However, you do not need to configure accounting parameters on the IMC server since accounting is not required.
Configuring the router
Configuring IP addresses for interfaces and a default route to ensure the network connectivity of the router
# Assign IP address 20.2.1.1 to GigabitEthernet 0/0.
<Router> system-view
[Router] interface gigabitethernet 0/0
[Router-GigabitEthernet0/0] ip address 20.2.1.1 255.255.255.0
[Router-GigabitEthernet0/0] quit
# Assign IP address 192.168.100.90 to GigabitEthernet 0/1.
[Router] interface gigabitethernet 0/1
[Router-GigabitEthernet0/1] ip address 192.168.100.90 255.255.255.0
[Router-GigabitEthernet0/1] quit
# Configure a default route to ensure that the router can reach the FTP server and the Internet.
[Router] ip route-static 0.0.0.0 0.0.0.0 192.168.100.88
Configuring SNMP for the IMC server to monitor and manage the router
# Enable the SNMP agent.
[Router] snmp-agent
# Enable all SNMP versions, and create the read-only community public and the read and write community private.
[Router] snmp-agent sys-info version all
[Router] snmp-agent community read public
[Router] snmp-agent community write private
Configuring a RADIUS scheme
# Create a RADIUS scheme named rs1 and enter its view.
[Router] radius scheme rs1
# Specify the server at 192.168.100.244 as the primary authentication server and the primary accounting server, and set the authentication shared key to admin in plaintext form for secure RADIUS communication.
[Router-radius-rs1] primary authentication 192.168.100.244
[Router-radius-rs1] primary accounting 192.168.100.244
[Router-radius-rs1] key authentication simple admin
# Exclude domain names from the usernames sent to the RADIUS server.
[Router-radius-rs1] user-name-format without-domain
[Router-radius-rs1] quit
Configuring an authentication domain
# Create an ISP domain named dm1 and enter its view.
[Router] domain dm1
# Configure the ISP domain to use RADIUS scheme rs1 for the authentication, authorization, and accounting of portal users.
[Router-isp-dm1] authentication portal radius-scheme rs1
[Router-isp-dm1] authorization portal radius-scheme rs1
[Router-isp-dm1] accounting portal radius-scheme rs1
[Router-isp-dm1] quit
Configuring portal authentication
# Configure the portal authentication server.
[Router] portal server newpt
[Router-portal-server-newpt] ip 192.168.100.244 key simple admin
[Router-portal-server-newpt] port 50100
[Router-portal-server-newpt] quit
# Configure the portal Web server.
[Router] portal web-server newpt
[Router-portal-websvr-newpt] url http://192.168.100.244:8080/portal
[Router-portal-websvr-newpt] quit
# Enable direct portal authentication on GigabitEthernet 0/0.
[Router–GigabitEthernet0/0] portal enable method direct
# Specify portal Web server newpt on GigabitEthernet 0/0.
[Router–GigabitEthernet0/0] portal apply web-server newpt
# Specify domain dm1 as the portal authentication domain on GigabitEthernet 0/0.
[Router–GigabitEthernet0/0] portal domain dm1
[Router–GigabitEthernet0/0] quit
Configuring Device (the firewall)
Configuring SNMP for the IMC server to monitor and manage the firewall
[Device] snmp-agent
[Device] snmp-agent sys-info version all
[Device] snmp-agent community read public
[Device] snmp-agent community write private
Configuring NETCONF over SOAP for the IMC server to issue configuration to the firewall
# Enable NETCONF over SOAP over HTTP.
[Device] netconf soap http enable
# Enable NETCONF over SOAP over HTTPS.
[Device] netconf soap https enable
Enabling RESTful for the firewall to communicate with the IMC RESTful server
# Enable RESTful over HTTP.
[Device] restful http enable
# Enable RESTful over HTTPS.
[Device] restful https enable
Assigning IP addresses to interfaces and adding the interfaces to security zones
# On the top navigation bar, click Network.
# From the navigation pane, select Interface Configuration > Interfaces.
# Click the Edit icon for GE 1/0/1.
# In the dialog box that opens, configure the interface:
1.     Select the Trust security zone.
2.     Click the IPv4 Address tab, and then enter the IP address and mask of the interface. In this example, enter 192.168.100.88/24.
3.     Use the default settings for other parameters.
4.     Click OK.
# Add GE 1/0/2 to the DMZ security zone and set its IP address to 11.1.1.1/24 in the same way you configure GE 1/0/1.
# Add GE 1/0/3 to the Untrust security zone and set its IP address to 12.1.1.1/24 in the same way you configure GE 1/0/1.
Configuring routing
1.     Configure routes to ensure that the firewall and users can reach each other.
This step uses static routing as an example. To use dynamic routing, configure a dynamic routing protocol.
# From the navigation pane, select Routing > Static Routing.
# On the IPv4 Static Routing tab, click Create.
# In the dialog box that opens, configure the IPv4 static route:
¡     Enter 20.2.1.0 in the Destination address field.
¡     Enter 24 in the Mask length field.
¡     Enter 192.168.100.90 as the next hop address in the Next hop field.
¡     Use the default settings for other parameters.
# Click OK.
2.     Configure a default route to ensure that the firewall can reach the Internet.
¡     Enter 0.0.0.0 in the Destination address field.
¡     Enter 0 in the Mask length field.
¡     Enter 12.1.1.2 as the next hop address in the Next hop field.
# Click OK.
Assigning the HTTP service to administrator admin
# On the top navigation bar, click System.
# From the navigation pane, select Administrators > Administrators.
# Click the Edit icon for administrator admin.
# In the dialog box that opens, select the HTTP service as shown in Figure 3.
Figure 3 Modifying administrator information
# Click OK.
1.     Enable user identification:
# On the top navigation bar, click Objects.
# From the navigation pane, select User > User Management > Online Users.
# On the Online Users tab, click Enable user identification.
Figure 4 Enabling user identification
2.     Create RESTful server rest1:
# From the navigation pane, select User > Authentication > RESTful Server.
# Click Create.
# Configure the following parameters for the RESTful server:
¡     Set the server name to rest1, the username to admin, and the password to admin.
¡     Set the Get-user-account URI to http://192.168.100.244:8080/imcrs/uam/acmUser/acmUserList.
¡     Set the Get-online-user URI to http://192.168.100.244:8080/imcrs/uam/online.
¡     Set the Get-user-group URI to http://192.168.100.244:8080/imcrs/uam/acmUser/userGroup.
For an IMC RESTful server, URIs are in a fixed format. You cannot modify any parameters in the above URIs except for the IP address.
Figure 5 Creating a RESTful server
# Click OK.
3.     Create user import policy imc:
# From the navigation pane, select User > User Management > User Import Policies.
# Click Create.
# Configure parameters for the user import policy, as shown in Figure 6.
Figure 6 Creating a user import policy
# Click OK.
# After the firewall and the IMC server can communicate with each other, enter the User Import Policies page and select imc from the policy list. Then, click the Manually import identity users and Manually import online users icons to import the user accounts and online users on the IMC server to the firewall.
Figure 7 Importing user accounts and online users
Configuring security policies to ensure the network connectivity between the firewall and the IMC server
Perform the tasks in this section to ensure that the firewall can import identity user information from the IMC server.
.# On the top navigation bar, click Policies.
# From the navigation pane, select Security Policies > Security Policies.
# Click Create > Create a policy.
# Configure security policy trust-local to permit traffic from zone Trust to zone Local:
·     Enter security policy name trust-local.
·     Select source security zone Trust.
·     Select destination security zone Local.
·     Select type IPv4.
·     Select action Permit.
·     Use the default settings for other parameters.
# Click OK.
# Configure security policy local-trust in the same way you configure security policy trust-local to permit traffic from zone Local to zone Trust:
·     Enter security policy name local-trust.
·     Select source security zone Local.
·     Select destination security zone Trust.
·     Select type IPv4.
# Configure security policy user10002 in the same way you configure security policy trust-local to permit user user10002 to access the FTP server and deny other users from accessing the FTP server:
·     Enter security policy name user10002.
·     Select source security zones Trust and DMZ.
·     Select destination security zones Trust and DMZ.
·     Select type IPv4.
·     Select user user10002.
# Configure security policy user10003 in the same way you configure security policy trust-local to permit user user10003 to access the Internet but denies users from the Internet from accessing the internal network:
·     Enter security policy name user10003.
·     Select destination security zone Untrust.
·     Select type IPv4.
·     Select user user10003.
Adding managed devices to IMC
Add the router and firewall to IMC so that IMC can monitor and manage the devices.
1.     Log in to IMC:
# Enter the IMC URL in the address bar of the Web browser. In this example, the URL is http://192.168.100.244:8080/imc/.
# Enter username admin and password admin.
2.     Add the firewall to IMC:
# Click the Resource tab.
# From the navigation tree, select Resource Management > Add Device.
# On the page that opens, configure the parameters as shown in Figure 8:
¡     In the Telnet Settings area, set the username and password to admin.
¡     Use the default values for other parameters.
By default, the read-only SNMP community string is public and the read and write SNMP community string is private.
Figure 8 Adding the firewall to IMC
# Click OK.
# Add the router (192.168.100.90) to IMC in the same way you add the firewall to IMC.
3.     Modify NETCONF settings:
# From the navigation tree, select View Management > Device View.
# Click the link in the Device Label column for the target device.
Figure 9 Device list
# In the right pane, click Configure > Modify NETCONF Settings.
# In the dialog box that opens, click the plus sign (+) to add a protocol as shown in Figure 10. In this example, set the username and password to admin.
Figure 10 Modifying NETCONF settings
# Click OK.
Configuring security services (IMC)
1.     Synchronize security services from the firewall to the IMC server to ensure that the configuration and user information is consistent between the firewall and IMC server.
# Click the Service tab.
# From the navigation tree, select Security Service Manager > Device Management.
# On the Devices tab, the firewall is displayed in the device list, as shown in Figure 11.
Figure 11 Page for security device management (not synchronized)
# Select the firewall in the device list and click Synchronize. You can view the synchronization status from the Sync Status column, as shown in Figure 12 and Figure 13.
The synchronization process might take a long time. Please wait.
Figure 12 Page for security device management (synchronizing)
Figure 13 Page for security device management (synchronization succeeded)
2.     Configure user authentication system parameters and user notification parameters to ensure that the IMC server synchronizes user online and offline information to the firewall in real time.
# From the navigation tree, select Security Service Manager > Global Parameters.
# Configure the user authentication system parameters, as shown in Figure 14.
Select a protocol depending on the protocol of the portal authentication server. Make sure the username and password is the same as that used to log in to the IMC server.
Figure 14 Configuring user authentication system parameters
# Click OK.
# Click the User tab.
# From the navigation tree, select User Access Policy > Service Parameters > System Settings.
# Click the Configure icon for User Notification Parameters.
# On the page that opens, click Add.
# On the Add User Notification page, configure the parameters as shown in Figure 15. In this example, you can enter a shared key randomly.
Figure 15 Configuring user notification parameters
# Click OK.
Configuring the RADIUS server (IMC)
1.     Add the router to the server as an access device:
# From the navigation tree, select User Access Policy > Access Device Management > Access Device.
# Click Add.
# Set the shared key to admin, as shown in Figure 16.
# In the Device List area, click Select or Add Manually to add the device at 192.168.100.90 as an access device.
You must specify the source IP address of outgoing RADIUS packets on the router as the IP address of the access device on the server.
On the router, the source IP address is configured by using the nas-ip or radius nas-ip command. The IP address configured by using the nas-ip command has a higher priority than the IP address configured by using the radius nas-ip command. If no IP address is specified as the source IP address, the IP address of the packet outbound interface is used as the source IP address. In this example, the IP address of the packet outbound interface is used, which is 192.168.100.90.
Figure 16 Adding an access device
# Click OK.
2.     Add an access policy:
# From the navigation tree, select User Access Policy > Access Policy.
# Click Add.
# Set the access policy name to Portal, as shown in Figure 17.
Figure 17 Adding an access policy
# Click OK.
3.     Add an access service:
# Select the User tab.
# From the navigation tree, select User Access Policy > Access Service.
# Click Add.
# On the Add Access Service page, configure the following parameters:
¡     Enter service name to Portal.
¡     Select Portal from the Default Access Policy list.
Figure 18 Adding an access service
# Click OK.
4.     Add an access user:
# From the navigation tree, select Access User > All Access Users.
# Click Add.
# On the Add Access User page, configure parameters as shown in Figure 19.
¡     Enter user in the User Name field.
¡     Enter user10001 in the Account Name field.
¡     Enter admin in the Password and Confirm Password fields.
¡     Select Portal in the Access Service area.
Figure 19 Adding an access user
# Click OK.
# Add user accounts user10002 and user10003 in the same way you add user account user10001.
Configuring the portal server (IMC)
1.     Configure the portal server:
# From the navigation tree, select User Access Policy > Portal Service > Server.
# Configure the parameters in Figure 20 depending on the network conditions. In this example, the default values are used.
Figure 20 Configuring the portal server
# Click OK.
2.     Add an IP group:
# From the navigation tree, select User Access Policy > Portal Service > IP Group.
# Click Add.
# Configure parameters as shown in Figure 21.
Figure 21 Adding an IP group
# Click OK.
3.     Add a portal device:
# From the navigation tree, select User Access Policy > Portal Service > Device.
# Click Add.
# Set the shared key to admin and configure other parameters as shown in Figure 22.
Figure 22 Adding a portal device
# Click OK.
4.     Associate the portal device with the IP group:
# Click the Port Group icon in the Operation column for the router.
Figure 23 Device list
# On the page that opens, configure a port group as shown in Figure 24.
Figure 24 Adding a port group
# Click OK.
Configuring the hosts
# Configure the IP address, network mask, and default gateway settings on each host. Make sure the hosts can communicate with the devices in the network. (Details not shown.)
1.     On the hosts, verify that the users can pass portal authentication.
# Enter the URL of the portal Web server in the address bar of the Web browser to log in to the portal authentication page. In this example, the URL is http://192.168.100.244:8080/portal.
# Enter the username and password.
# Click Log In.
# Verify that the user has passed portal authentication.
Figure 25 Portal authentication success page
2.     On the IMC server, verify that users user10001, user10002, and user10003 are in the online user list after they pass portal authentication. To view the online user list, click the User tab and select Access User > Online Users from the navigation tree.
3.     On the firewall, display identity user information.
# Display information about all identity users.
[Device] display user-identity all user
  User ID     Username
  0x2         user10001
  0x3         user10002
  0x4         user10003
# Display information about online identity user user10001.
[Device] display user-identity online-user null-domain name user10001
User name: user10001
  IP  : 20.2.1.11
  MAC : 0011-95e4-4aa9
  Type: Dynamic
Total 1 records matched.
# Display information about online identity user user10002.
[Device] display user-identity online-user null-domain name user10002
User name: user10002
  IP  : 20.2.1.12
  MAC : 0011-95e4-4aa3
  Type: Dynamic
# Display information about online identity user user10003.
[Device] display user-identity online-user null-domain name user10003
User name: user10003
  IP  : 20.2.1.13
  MAC : 0011-95e4-4aa2
  Type: Dynamic
4.     Verify that the firewall can perform identity-based access control on the users:
# Verify that user user10001 cannot ping the FTP server.
C:\>ping 11.1.1.2
Pinging 11.1.1.2 with 32 bytes of data:
Request time out.
Request time out.
Request time out.
Request time out.
Ping statistics for 11.1.1.2:
    Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
# Verify that user user10002 can ping the FTP server.
C:\>ping 11.1.1.2
Reply from 11.1.1.2: bytes=32 time=36ms TTL=253
Reply from 11.1.1.2: bytes=32 time<1ms TTL=253
    Minimum = 0ms, Maximum = 36ms, Average = 9ms
# When user user10002 pings the FTP server, verify that the firewall generates a message.
# Verify that user user10003 can ping hosts in the Internet. In this example, the user pings the host at 12.1.1.2.
C:\>ping 12.1.1.2
Pinging 12.1.1.2 with 32 bytes of data:
Reply from 12.1.1.2: bytes=32 time=37ms TTL=253
Reply from 12.1.1.2: bytes=32 time<1ms TTL=253
Ping statistics for 12.1.1.2:
# When user user10003 pings the host in the Internet, verify that the firewall generates a message.
Configuration files
Router
[Router] display current-configuration
interface GigabitEthernet0/0
 port link-mode route
 portal domain dm1
interface GigabitEthernet0/1
interface GigabitEthernet3/0
 combo enable copper
 ip route-static 0.0.0.0 0 192.168.100.88
 snmp-agent
 snmp-agent local-engineid 800063A28074258A37B5F500000001
radius scheme rs1
 key authentication cipher $c$3$hhbEbD5Ycvw7VWqljAoMoU7hQRgcUjtg
domain dm1
domain system
 domain default enable system
local-user admin class manage
 password hash $h$6$UbIhNnPevyKUwfpm$LqR3+yg1IjNct39MkOR0H0iQXLkYB3jMqM4vbAeoXOh
babIIFnjJPEGR00YiYA1Sz4LiY3FmEdru2fOLMb1shQ==
 service-type telnet http
portal server newpt
 ip 192.168.100.244 key cipher $c$3$+UmaGOco7eHsjOqlrp8lI4eYe0A8NpYU
return
Device
[Device] display current-configuration
 ip address 192.168.100.88 255.255.255.0
 ip address 11.1.1.1 255.255.255.0
 ip address 12.1.1.1 255.255.255.0
security-zone name Trust
 import interface GigabitEthernet1/0/1
security-zone name DMZ
 import interface GigabitEthernet1/0/2
security-zone name Untrust
 import interface GigabitEthernet1/0/3
line vty 0 63
 authentication-mode scheme
 ip route-static 0.0.0.0 0 12.1.1.2
 ip route-static 20.2.1.0 24 192.168.100.90
 snmp-agent
 snmp-agent local-engineid 800063A280487ADA9593B700000001
 snmp-agent target-host trap address udp-domain 192.168.100.244 params securityn
ame public v2c
 service-type ssh telnet terminal http https
 authorization-attribute user-role level-3
 restful http enable
 user-identity enable
 user-identity user-account auto-import policy imc
user-identity restful-server rest1
 login-name admin password cipher $c$3$phGy00HA6OP6pIpGI0KOKZEOPuLVbtt/
 uri get-user-database http://192.168.100.244:8080/imcrs/uam/acmUser/acmUserList
 uri get-user-group-database http://192.168.100.244:8080/imcrs/uam/acmUser/userGroup
 uri get-online-user http://192.168.100.244:8080/imcrs/uam/online
user-identity user-import-policy imc
 account-update-interval 1
security-policy ip
 rule 0 name trust-local
  action pass
  source-zone trust
  destination-zone local
 rule 1 name local-trust
  action pass
  source-zone local
  destination-zone trust
 rule 2 name user10002
  action pass
  logging enable
  source-zone trust
  source-zone dmz
  destination-zone dmz
  user user10002
 rule 3 name user10003
  action pass
  logging enable
  source-zone trust
  destination-zone untrust
  user user10003
return
As shown in Figure 26:
·     Device is a firewall and acts as a NAS for the users to access the network. The NAS uses the RADIUS server to authenticate the users.
·     The RESTful server stores user account information. The server can synchronize user identity information to Device (the firewall).
¡     Users user10001 and user10002 cannot access the Internet.
¡     User user10003 can access the Internet.
Figure 26 Network diagram
Analysis
Figure 27 Analysis diagram
Perform the tasks in this section to ensure the network connectivity of the router.
# Assign IP address 20.2.2.1 to GigabitEthernet 0/1.
[Router-GigabitEthernet0/1] ip address 20.2.2.1 255.255.255.0
# Configure a default route to ensure that the router can reach the Internet.
[Router] ip route-static 0.0.0.0 0.0.0.0 20.2.2.2
[Device] snmp-agent
# Enable all SNMP versions, create the read-only community public and the read and write community private.
1.     Select the DMZ security zone.
4.     Click OK.
# Add GE 1/0/2 to the Trust security zone and set its IP address to 20.2.2.2/24 in the same way you configure GE 1/0/1.
Configuring routing
1.     Configure a route to ensure that the firewall and the users can reach each other.
¡     Enter 20.2.2.1 as the next hop address in the Next hop field.
# Click OK.
Specify the IP address of the device that connects to the firewall in the Internet as the next hop address. In this example, the next hop address is 12.1.1.2.
# Click OK.
# In the dialog box that opens, select the HTTP service as shown in Figure 28.
Figure 28 Modifying administrator information
# Click OK.
# Configure security policy dmz-local to permit traffic from zone DMZ to zone Local:
·     Enter security policy name dmz-local.
·     Select source security zone DMZ.
·     Select type IPv4.
# Click OK.
# Configure security policy local-dmz in the same way you configure security policy dmz-local to permit traffic from zone Local to zone DMZ:
·     Enter security policy name local-dmz.
·     Select destination security zone DMZ.
·     Select type IPv4.
# Configure security policy trust-dmz in the same way you configure security policy dmz-local to permit traffic between zone Trust and zone DMZ. This task allows the NAS to send and receive AAA and portal authentication packets for the users and IMC server.
·     Enter security policy name trust-dmz.
·     Select type IPv4.
Configuring RADIUS scheme rs1
# From the navigation pane, select User > Authentication > RADIUS.
# Click Create.
# In the dialog box that opens, create a RADIUS authentication server and a RADIUS accounting server and configure advanced settings, as shown in Figure 29, Figure 30, and Figure 31.
Figure 29 Creating a RADIUS scheme (authentication servers)
Figure 30 Creating a RADIUS scheme (accounting servers)
Figure 31 Creating a RADIUS scheme (advanced settings)
# Click OK.
Configuring authentication domain dm1
# From the navigation pane, select User > Authentication > ISP Domains.
# Click Create.
# In the dialog box that opens, configure the access types and the AAA methods for portal users, as shown in Figure 32 and Figure 33.
Figure 32 Adding ISP domain dm1 (access types)
Figure 33 Adding ISP domain dm1 (AAA methods for portal users)
# Click OK.
1.     Configuring the portal authentication server:
# From the navigation pane, select User > Access Control > Portal.
# On the Portal Authentication Servers tab, click Create.
# In the dialog box that opens, configure the portal authentication server:
¡     Enter server name newpt.
¡     Set the IP address to 192.168.100.244.
¡     Enter key admin.
¡     Set the port to 50100.
Figure 34 Creating a portal authentication server
# Click OK.
2.     Configure the portal Web server:
# Click the Portal Web Servers tab.
# Click Create.
# In the dialog box that opens, configure the server name and URL, as shown in Figure 35. In this example, the URL is http://192.168.100.244:8080/portal.
Figure 35 Creating a portal Web server
# Click OK.
3.     Configure an interface portal policy and enable IPv4 portal on GE 1/0/2:
# Click the Interface Portal Policies tab.
# Click Create.
# In the dialog box that opens, configure the interface portal policy, as shown in Figure 36.
Figure 36 Creating an interface portal policy
# Click OK.
Figure 37 Enabling user identification
# Click Create.
# In the dialog box that opens, configure the following parameters for the RESTful server:
¡     Enter server name rest1.
¡     Enter username admin.
¡     Enter password admin.
Figure 38 Creating the RESTful server
# Click OK.
# Click Create.
# In the dialog box that opens, configure parameters for the user import policy, as shown in Figure 39.
Figure 39 Creating user import policy imc
# Click OK.
# After the firewall and the IMC server can communicate with each other, enter the User Import Policies page and click the Manually import identity users icon for policy imc to import the user accounts on the IMC server to the firewall.
Figure 40 Importing user accounts
Configuring a security policy to permit user user10003 to access the Internet
Perform this task to create a security policy to permit user user10003 to access the Internet and deny users from the Internet from accessing the internal network.
# In the dialog box that opens, configure the security policy:
·     Select type IPv4.
# Click OK.
# Add the firewall to IMC for IMC to monitor and manage the firewall.
1.     Log in to IMC:
# On the page that opens, configure parameters as shown in Figure 41:
¡     Set the username and password to admin in the Telnet Settings area.
Figure 41 Adding the firewall to IMC
# Click OK.
Figure 42 Device list
# In the dialog box that opens, click the plus sign (+) to add a protocol as shown in Figure 43.
Figure 43 Modifying NETCONF settings
# Click OK.
# On the Devices tab, the firewall is displayed in the device list, as shown in Figure 44.
Figure 44 Page for security device management (not synchronized)
# Select the firewall in the device list and click Synchronize. You can view the synchronization status from the Sync Status column, as shown in Figure 45 and Figure 46.
Figure 45 Page for security device management (synchronizing)
Figure 46 Page for security device management (synchronization succeeded)
# Configure the user authentication system parameters, as shown in Figure 47.
Figure 47 Configuring user authentication system parameters
# Click OK.
# On the Add User Notification page, configure the parameters as shown in Figure 48. In this example, you can enter a shared key randomly.
Figure 48 Configuring user notification parameters
# Click OK.
1.     Add the firewall to the IMC server as an access device:
# Click Add.
# In the Access Configuration area, set the shared key to admin, as shown in Figure 49.
# In the Device List area, click Select or Add Manually to add the device at 192.168.100.88 as an access device.
You must specify the source IP address of outgoing RADIUS packets on the firewall as the IP address of the access device on the server.
On the firewall, the source IP address is configured by using the nas-ip or radius nas-ip command. The IP address configured by using the nas-ip command has a higher priority than the IP address configured by using the radius nas-ip command. If no IP address is specified as the source IP address, the IP address of the packet outbound interface is used as the source IP address. In this example, the IP address of the packet outbound interface is used, which is 192.168.100.88.
Figure 49 Adding an access device
# Click OK.
# Click Add.
# On the Add Access Policy page, set the access policy name to Portal, as shown in Figure 50.
Figure 50 Adding an access policy
# Click OK.
# Click Add.
# On the Add Access Service page, set the service name to Portal and select Portal from the Default Access Policy list.
Figure 51 Adding an access service
# Click OK.
# Click Add.
# On the Add Access User page, configure parameters as shown in Figure 52.
Figure 52 Adding an access user
# Click OK.
# Configure the parameters in Figure 53 depending on the network conditions. In this example, the default values are used.
Figure 53 Portal server configuration
# Click OK.
2.     Add an IP group:
# Click Add.
# On the Add IP Group page, configure the IP group parameters as shown in Figure 54.
Figure 54 Adding an IP group
# Click OK.
# Click Add.
# On the Add Device page, set the key to admin and configure other parameters as shown in Figure 55.
Figure 55 Adding portal device configuration
# Click OK.
# Click the Port Group icon in the Operation column for the firewall
Figure 56 Device list
# On the page that opens, configure a port group as shown in Figure 57.
Figure 57 Adding a port group
# Click OK.
# Configure the IP address, network mask, and default gateway settings for each host. Make sure the hosts can communicate with the devices in the network. (Details not shown.)
# Click Log In.
Figure 58 Portal authentication success page
3.     On the firewall, display information about all portal users.
[Device] display portal user all
Total portal users: 3
Username: user10001
  Portal server: newpt
  State: Online
  VPN instance: N/A
  MAC             IP                    VLAN    Interface
  0011-95e4-4aa9  20.2.1.13             --      GigabitEthernet1/0/2
  Authorization information:
    DHCP IP pool: N/A
    User profile: N/A
    Session group profile: N/A
    ACL number: N/A
    Inbound CAR: N/A
Outbound CAR: N/A
Username: user10002
  State: Online
  VPN instance: N/A
  0011-95e4-4aa3  20.2.1.13             --      GigabitEthernet1/0/2
    DHCP IP pool: N/A
    User profile: N/A
    ACL number: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
Username: user10003
  State: Online
  VPN instance: N/A
  0011-95e4-4aa2  20.2.1.13             --      GigabitEthernet1/0/2
    DHCP IP pool: N/A
    User profile: N/A
    ACL number: N/A
    Inbound CAR: N/A
    Outbound CAR: N/A
4.     On the firewall, display identity user information.
  User ID     Username
  0x2         user10001
  0x3         user10002
  0x4         user10003
  IP  : 20.2.1.11
  Type: Dynamic
  IP  : 20.2.1.12
  Type: Dynamic
  IP  : 20.2.1.13
  Type: Dynamic
5.     Verify that the firewall can perform identity-based access control on the users:
# Verify that user user10001 cannot ping any host in the Internet. In this example, the user pings the host at 12.1.1.2.
C:\>ping 12.1.1.2
Request time out.
Request time out.
Request time out.
Request time out.
C:\>ping 12.1.1.2
Reply from 12.1.1.2: bytes=32 time=36ms TTL=253
# When user user10003 pings the host in the Internet, the firewall generates a message.
Configuration files
Router
 combo enable copper
 ip route-static 0.0.0.0 0 20.2.2.2
 snmp-agent
return
Device
 ip address 20.2.2.2 255.255.255.0
 portal domain dm1
line vty 0 63
 ip route-static 20.2.1.0 24 20.2.2.1
 snmp-agent
ame public v2c
radius scheme rs1
domain dm1
domain system
portal server newpt
 restful http enable
security-policy ip
 rule 0 name dmz-local
  action pass
  source-zone dmz
 rule 1 name local-dmz
  action pass
  source-zone local
 rule 2 name trust-dmz
  action pass
  source-zone trust
  source-zone dmz
  action pass
  logging enable
  source-zone trust
  user user10003
return
As shown in Figure 59:
·     A Dr.Com server is deployed for user authentication, authorization, and accounting in the campus network.
·     Device (firewall) acts as a gateway to control access between the campus network and the Internet.
·     Device obtains all user accounts, online users, and user online and offline messages from the server.
·     Device performs the following identity-based access control on online users based on the information synchronized from the server:
○          User user10001 cannot access the FTP server or Internet.
○          User user10002 can access the FTP server but cannot access the Internet.
○          User user10003 can access the Internet but cannot access the FTP server.
○          Users from the Internet cannot access the hosts in the Trust and DMZ security zones.
·     The Dr.Com server has two IP addresses:
¡     One IP address is 184.79.0.12 for communication with users, user identity authentication, and authorization.
¡     The other IP address is 184.79.0.11 for communication with Device and user information synchronization.
Figure 59 Network diagram
This configuration example was created and verified on R8860 of the F1000-AI-55 device.
Create the users on the Dr.Com server.
Configure access authentication settings on the network access devices to ensure that the users can pass authentication on the Dr.Com server and obtain authorization information from the server.
Configuring the Dr.Com server
1.     Add the IP address and port number of Device to the server:
# Use SSH to access 184.79.0.11/24 and enter the username and password to log in to the CLI of the DR.Com server.
# Change the work directory to /usr/local/drcom/dronline/ac0.
# Configure the following parameters under the action title in the dronline.ini file:
¡     Set the value for the ip1 parameter to 184.69.0.161 (IP address of Device).
¡     Set the value for the port1 parameter to 61440.
Figure 60 Adding the IP address and port number of Device
2.     Enable UDP interface process and get interface process on the server:
# Enable UDP interface process for pushing user online and offline messages.
cd /usr/local/drcom/dronline/ac0
./dronline
# Enable get interface process for responding to the requests from Device for importing user accounts and online users in bulk.
cd /usr/local/drcom/DrcomSup
java -jar DrcomSup.jar --server.port=8003
# Verify that the server can push user online and offline messages to Device and respond to the requests from Device. (Details not shown.)
1.     Assign IP addresses to interfaces and add the interfaces to security zones:
a.     Select the Trust security zone.
b.     Click the IPv4 Address tab, and then enter the IP address and mask of the interface. In this example, enter 184.69.0.161/24.
c.     Use the default settings for other parameters.
d.     Click OK.
# Add GE 1/0/2 to the DMZ security zone and set its IP address to 184.69.2.1/24 in the same way you configure GE 1/0/1.
# Add GE 1/0/3 to the Untrust security zone and set its IP address to 184.69.1.1/24 in the same way you configure GE 1/0/1.
2.     Configure routing:
¡     Enter 184.79.0.0 in the Destination address field.
¡     Enter 184.69.0.1 as the next hop address in the Next hop field.
# Click OK.
# Configure a static route destined for 10.1.1.0/24 in the same way the static route destined for 184.79.0.0/24 is configured.
# Configure a static route destined for the Internet in the same way the static route destined for 184.79.0.0/24 is configured.
3.     Configure security policies to permit traffic between the Dr.Com server and Device:
# Configure the following parameters in the security policy for Device to import user information from the Dr.Com server:
¡     Set the name to trust-local.
¡     Select Trust as the source security zone.
¡     Select Local as the destination security zone.
¡     Set the type to IPv4.
¡     Select action Permit.
¡     Specify 184.79.0.0/24 as the source IPv4 address.
# Click OK.
# Configure security policy local-trust for Device to send traffic to the Dr.Com server in the same way security policy trust-local is configured. Configure the following parameters for security policy local-trust:
¡     Set the name to local-trust.
¡     Select Local as the source security zone.
¡     Select Trust as the destination security zone.
¡     Specify 184.79.0.0/24 as the destination IPv4 address.
# Click OK.
4.     Enable user identification:
Figure 61 Enabling user identification
5.     Configure a RESTful server for synchronizing user accounts and online users from the Dr.Com server:
# Click Create.
¡     Set the name to drcom.
¡     Set the username to the username used to access the Dr.Com server.
¡     Set the password to the password used to access the Dr.Com server.
¡     Set the Get-user-account URI to http://184.79.0.11:8003/DrcomSup/accessUser.
¡     Set the Get-online-user URI to http://184.79.0.11:8003/DrcomSup/onlineUser.
¡     Enable server detection.
Figure 62 Configuring a RESTful server
# Click OK.
6.     Configure a security management server set to receive user online and offline messages pushed from the Dr.Com server:
# From the navigation pane, select User > Authentication > Sec Mgt Server Set.
# Click Create.
# Configure the following parameters for the security management server set:
¡     Set the name to drcom1.
¡     Set the server address to 184.79.0.11.
¡     Set the listening port to 61440.
Figure 63 Configuring a security management server set
# Click OK.
7.     Configure a user import policy:
# Click Create.
# Configure the following parameters for the user import policy:
¡     Select RESTful server drcom.
¡     Select User and user group as the import type.
¡     Enable auto import.
Figure 64 Configuring a user import policy
# Click OK.
8.     Manually import user accounts and online users:
# On the User Import Policies page, select drcom from the policy list.
# Click the Manually import identity users and Manually import online users icons for the policy to import the user accounts and online users on the Dr.Com server to the firewall.
9.     Configure security policies to control user traffic:
# Configure the following parameters in the security policy to permit only user user10002 to access the FTP server:
¡     Set the name to user10002.
¡     Select DMZ as the destination security zone.
¡     Specify user user10002.
# Click OK.
# Create security policy user10003 to permit only user user10003 to access the Internet and prevent Internet users from accessing the internal network.
¡     Set the name to user10003.
¡     Select Untrust as the destination security zone.
¡     Specify user user10003.
# Click OK.
1.     On the top navigation bar, click Objects. From the navigation pane, select User > User Management > Static Identity Users. On the page that opens, verify that you can view user information imported from the Dr.Com server.
2.     On the top navigation bar, click Objects. From the navigation pane, select User > User Management > Online Users. On the page that opens, verify that you can view online user information pushed from the Dr.Com server.
3.     Verify that user user10001 cannot ping the FTP server.
C:\>ping 184.69.2.2
Pinging 184.69.2.2 with 32 bytes of data:
Request time out.
Request time out.
Request time out.
Request time out.
Ping statistics for 184.69.2.2:
4.     Verify that user user10002 can ping the FTP server.
C:\>ping 184.69.2.2
Reply from 184.69.2.2: bytes=32 time=36ms TTL=253
Reply from 184.69.2.2: bytes=32 time<1ms TTL=253
5.     Verify that user user10003 can ping a host on the Internet. In this example, the user pings the host at 12.1.1.2.
C:\>ping 12.1.1.2
