09-Configuration Examples
HomeSupportConfigure & DeployH3C Firewall Products Comware 7 Web Configuration Guide-6W60009-Configuration Examples
Table of Contents
Related Documents
18-Attack defense configuration examples
18-Attack defense configuration examples 164.15 KB
·     Introduction
·     Prerequisites
·     Example: Configuring scanning attack defense
·     Example: Configuring flood attack defense
Introduction
The following information describes attack defense configuration examples.
The following attack defense features are supported:
Scanning attack defense
Scanning attack detection inspects the incoming packet rate of connections to the target system. Apply a scanning attack defense policy to the security zone that is connected to the external network.
Global flood attack defense
Apply a flood attack defense policy to the security zone that is connected to the external network to protect internal servers. Flood attack detection monitors the rate at which connections are initiated to the internal servers.
IP-specific flood attack defense
You can configure flood attack detection and defense for specific IP addresses. For non-specific IP addresses, the device uses the global flood attack defense settings.
Well-known single-packet attack defense
Single-packet attack detection inspects incoming packets based on the packet signature. Apply the single-packet attack defense policy to the security zone that is connected to the external network.
User-defined single-packet attack defense
The device supports detecting attack packets with user-defined signatures.
Exemption list
The attack defense policy uses an ACL to identify exempted packets. The policy does not check the packets permitted by the ACL.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of attack detection and defense.
As shown in Figure 1, configure middle-level scanning attack detection and defense on the Untrust security zone where GigabitEthernet 1/0/1 resides to protect internal hosts from scanning attacks. The defense actions are logging and dropping attack packets.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R8860 of the F1000-AI-55 device.
1.     Assign IP addresses to interfaces and add the interfaces to security zones.
# On the top navigation bar, click Network.
# From the navigation pane, select Interface Configuration > Interfaces.
# Click the Edit icon for GE 1/0/1.
# In the dialog box that opens, configure the interface:
a.     Select the Untrust security zone.
b.     On the IPv4 Address tab, enter the IP address and mask of the interface. In this example, enter 20.1.1.1/24.
c.     Click OK.
# Add GE 1/0/3 to the Trust security zone and set its IP address to 30.1.1.1/24 in the same way you configure GE 1/0/1.
2.     Create a security policy from zone Untrust to zone Trust.
# On the top navigation bar, click Policies.
# From the navigation pane, select Security Policies > Security Policies.
# Click Create.
# In the dialog box that opens, configure a security policy:
¡     Enter policy name Secpolicy.
¡     Select source zone Untrust.
¡     Select destination zone Trust.
¡     Select type IPv4.
¡     Set the action to Permit.
¡     Specify 20.1.1.0/24 as the source IPv4 address.
¡     Specify 30.1.1.0/24 as the destination IPv4 address.
¡     Use the default settings for other parameters.
# Click OK.
3.     Configure a scanning attack defense policy.
# From the navigation pane, select Attack Defense > Attack Defense Policies.
# Click Create.
# Create a scanning attack defense policy, as shown in Figure 2.
Figure 2 Creating a scanning attack defense policy
# Click OK.
The attack defense policy is displayed on the attack defense policy list, as shown in Figure 3.
Figure 3 Attack defense policy list
1.     On the host at 20.1.1.2, simulate an attack to send a large number of SYN packets with different destination port numbers to destination address 30.1.1.2.
2.     On the firewall, view the attack defense log information.
# On the top navigation bar, click Monitor.
# From the navigation pane, select Security Logs > Scanning Attack Logs.
Figure 4 Scanning attack log list
3.     Double-click the attack log to view its details.
Figure 5 Detailed information about the scanning attack log
4.     Verify that no sessions are created for SYN packets because these packets have been dropped.
# From the navigation pane, select Sessions.
As shown in Figure 6, configure SYN flood attack detection and defense on the security zone where GigabitEthernet 1/0/1 resides to protect internal network hosts from SYN flood attacks. When the firewall detects that the number of packets sent by the attacker reaches or exceeds 10000 per second, the firewall outputs logs and drops attack packets.
Figure 6 Network diagram
c.     Click OK.
# Click Create.
¡     Select type IPv4.
# Click OK.
3.     Configuring flood attack defense global settings.
# Click Create.
# In the dialog box that opens, create an attack defense policy, as shown in Figure 7.
Figure 7 Creating an attack defense policy
# Click OK.
The attack defense policy is displayed on the attack defense policy list, as shown in Figure 8.
Figure 8 Attack defense policy list
1.     On the host at 20.1.1.2, simulate a SYN flood attack by sending a large number of SYN packets with different source port numbers to destination address 30.1.1.2.
2.     On the firewall, view the flood attack log information.
# From the navigation pane, select Security Logs > Flood Attack Logs.
Figure 9 Flood attack log list
3.     Double-click the flood attack log to view its details.
Figure 10 Flood attack log details
4.     Verify that no session is created for SYN packets because these packets have been dropped.
# From the navigation pane, select Device Logs > Traffic Logs.
