09-Configuration Examples
HomeSupportConfigure & DeployH3C Firewall Products Comware 7 Web Configuration Guide-6W60009-Configuration Examples
Table of Contents
Related Documents
15-APR-Based Security Policy Configuration Examples
APR-based security policy configuration examples
·     Introduction
·     Prerequisites
·     Restrictions and guidelines
·     Example: Configuring APR-based, strict security policies
·     Example: Configuring APR-based, loose security policies
The following information provides APR-based security policy configuration examples.
A security policy defines a set of rules for forwarding control and Deep Packet Inspection (DPI). It matches packets against the rules and takes the action stated in the rules on the matched packets.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of the APR and security policy features.
Packet filtering, if configured, is performed only on packets that do not match any security policy rule. As a best practice, make sure security policies have stricter filtering criteria than packet filtering, so the unmatched packets can still be filtered by packet filtering.
For security purposes, configure APR-based, strict security policies.
As shown in Figure 1, configure security policies to achieve the following goals:
·     The president office can access all network resources at any time.
·     The financial office can access only its own resources.
·     The marketing office can access some resources on the Internet from 8:00 to 18:00 on workdays.
¡     Cannot access gaming, streaming media, P2P, or network community resources, but can access YouKu.
¡     Can only access WeChat and cannot access any other IM applications.
¡     Can access MSN, DingTalk, and security forum resources.
¡     Can access any resources except the listed resources that cannot be accessed.
·     The financial office cannot be accessed by anyone, and the financial office and the marketing office cannot access each other.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on R8860 of the F1000-AI-55 device.
When you configure a security policy, follow these restrictions and guidelines:
·     Update the APR signature library to the latest version.
·     For the applications in a security policy to be identified, you must allow the dependent protocols of the applications to pass through.
Analysis
·     Configure security policy president_permit to allow the employees in the president office to freely access any network resources.
·     Configure security policy finance_permit to allow the employees in the financial office to communicate with one another.
·     Configure security policy market_permit1 to allow the employees in the marketing office to use WeChat, MSN, DingTalk, YouKu, and security forum resources. By default, a security policy does not allow use of IM applications.
·     Configure security policy market_deny1 to deny network community and streaming media applications for the marketing office from 8:00 to 18:00 on workdays. This security policy prevents employees in the marketing office from playing games, watching video, and accessing network community sites from 8:00 to 18:00 on workdays. To permit WeChat, MSN, DingTalk, YouKu, and security forum applications, you must configure security policy market_permit1 before market_deny1.
·     Configure security policy market_permit2 to allow the employees in the marketing office to use some OA, email, and protocol applications that are not easy to identify. To deny such an application, remove it from the application group or configure another security policy to deny it.
·     Configure security policy market_permit3 to allow common protocols for APR to identify applications correctly. Common protocols include TCP, UDP, DNS, HTTP, HTTPS, SMTP, IMAP, and POP3. The security policy market_permit2 might permit these protocols. As a best practice for APR to identify applications correctly when security policy market_permit2 changes, configure security policy market_permit3 to allow these protocols.
·     Configure the security policies in the following order:
a.     president_permit
b.     finance_permit
c.     market_permit1
d.     market_deny1
e.     market_permit2
f.     market_permit3
1.     Configure security zones.
# On the top navigation bar, click Network.
# From the navigation pane, click Security Zones.
# Click the Edit icon for security zone Untrust.
# In the dialog box that opens, add GE 1/0/1 to the security zone.
# Create a security zone named president, and add GE 1/0/2 to the security zone.
# Create a security zone named finance, and add GE 1/0/3 to the security zone.
# Create a security zone named market, and add GE 1/0/4 to the security zone.
2.     Assign IP addresses to interfaces.
# From the navigation pane, select Interface Configuration > Interfaces.
# Click the Edit icon for GE 1/0/1.
# In the dialog box that opens, configure the interface:
a.     On the IPv4 Address tab, enter the IP address and mask of the interface. In this example, enter 2.2.2.1/24.
b.     Click OK.
# Configure the IP addresses of GE 1/0/2, GE 1/0/3, and GE 1/0/4 as 10.0.12.1/24, 10.0.11.1/24, and 10.0.10.1/24, respectively, in the same way you configure GE 1/0/1.
3.     Configure a time range.
# On the top navigation bar, click Objects.
# From the navigation pane, select Object Groups > Time Ranges.
# Click Create.
# In the dialog box that opens, configure the time range:
a.     Enter a time range name. In this example, enter work.
b.     Create a periodic time range from 8:00 to 18:00 on workdays, and click OK.
c.     Click OK.
4.     Configure application groups.
# From the navigation pane, select APPSecurity > APP Recognition > Application Groups.
# Click Create.
# In the dialog box that opens, configure an application group named game-group:
¡     Enter group name game-group.
¡     Add all applications in the Game category to the Selected Applications pane.
¡     Click OK.
Figure 2 Creating an application group
# Create an application group named p2p-group, and add all applications in the P2P category to the application group.
# Create an application group named streaming-media-group, and add all applications in the Streaming_Media category to the application group.
# Create an application group named network-community-group, and add all applications in the Network-Community category to the application group.
# Create an application group named permit-others, and add some applications in the E-Mail, OA, and Protocol categories that are not easy to identify to the application group.
# Create an application group named protocol-permit, and add common protocols (such as TCP, UDP, DNS, HTTP, HTTPS, SMTP, IMAP, and POP3) to the application group.
5.     Configure a security policy named president_permit.
# On the top navigation bar, click Policies.
# From the navigation pane, select Security Policies > Security Policies.
# Click Create.
# In the dialog box that appears, configure the security policy:
¡     Enter policy name president_permit.
¡     Select source zone president.
¡     Select destination zones Untrust, finance, and market.
¡     Select policy type IPv4.
¡     Select action Permit.
¡     Select source IP address president.
# Click OK.
Figure 3 Creating security policy president_permit
6.     Configure a security policy named finance_permit.
# Click Create.
¡     Enter policy name finance_permit.
¡     Select source zone finance.
¡     Select destination zone finance.
# Click OK.
Figure 4 Creating security policy finance_permit
7.     Configure a security policy named market_permit1.
# Click Create.
¡     Enter policy name market_permit1.
¡     Select source zone market.
¡     Select destination zone Untrust.
¡     Select source IP address market.
¡     Select applications WeChat, MSN, AnFang Forum (security forum), and YouKu.
¡     Select time range work.
# Click OK.
Figure 5 Creating security policy market_permit1
8.     Configure a security policy named market_deny1.
# Click Create.
¡     Enter policy name market_deny1.
¡     Select application groups p2p-group, streaming-media-group, network-community-group, and game-group.
# Click OK.
Figure 6 Creating security policy market_deny1
9.     Configure a security policy named market_permit2.
# Click Create.
¡     Enter policy name market_permit2.
¡     Select application group permit-others.
# Click OK.
Figure 7 Creating security policy market_permit2
10.     Configure a security policy named market_permit3.
# Click Create.
¡     Enter policy name market_permit3.
¡     Select application group protocol-permit.
# Click OK.
Figure 8 Creating security policy market_permit3
# Verify that the employees in the president office can freely access any network resources.
# Verify that the employees in the financial office can communicate with one another.
# Verify that the marketing office can access some resources on the Internet from 8:00 to 18:00 on workdays.
·     Cannot access gaming, streaming media, P2P, or network community resources, but can access YouKu.
·     Can only access WeChat and cannot access any other IM applications.
·     Can access MSN, DingTalk, and security forum resources.
·     Can access any resources except the listed resources that cannot be accessed.
# Verify that the financial office cannot be accessed by anyone, and the financial office and the marketing office cannot access each other.
# Verify that security polices can be hit correctly by selecting Monitor > Security Logs > Security Policy Logs. The following are examples of security policy hitting:
Figure 9 Denying Xunleikankan
Figure 10 Permitting YouKu
Figure 11 Permitting WeChat
Figure 12 Denying QQ
As shown in Figure 13, configure security policies to achieve the following goals:
·     The marketing office can access all network resources except video and game applications from 8:00 to 18:00 on workdays and can play games and watch video during non-working hours.
Figure 13 Network diagram
Analysis
·     Configure security policy market_deny1 to deny game and streaming video applications for the marketing office from 8:00 to 18:00 on workdays. This security policy prevents employees in the marketing office from playing games and watching video from 8:00 to 18:00 on workdays.
·     Configure security policy president_market_permit to allow packets from the president office and the marketing office to pass through. This security policy can meet the following requirements:
¡     The president office can access all network resources at any time.
¡     The marketing office can access all network resources except video and game applications from 8:00 to 18:00 on workdays and can play games and watch video during non-working hours.
a.     finance_permit
b.     market_deny1
c.     president_market_permit
b.     Click OK.
# Click Create.
c.     Click OK.
# Click Create.
¡     Click OK.
Figure 14 Creating application group game-group
5.     Configure a security policy named finance_permit.
# Click Create.
# Click OK.
Figure 15 Creating security policy finance_permit
6.     Configure a security policy named market_deny1.
# Click Create.
¡     Select action Deny.
# Click OK.
Figure 16 Creating security policy market_deny1
7.     Configure a security policy named president_market_permit.
# Click Create.
¡     Enter policy name president_market_permit.
# Click OK.
Figure 17 Creating security policy president_market_permit
# Verify that the marketing office can access all network resources except video and game applications from 8:00 to 18:00 on workdays and can play games and watch video during non-working hours.
Figure 18 Denying Xunleikankan
Figure 19 Permitting WeChat
