H3C WX Series Access Controllers Web-Based Configuration Guide(R3308 R2308)-6W107
HomeSupportConfigure & DeployUser ManualsH3C WX Series Access Controllers Web-Based Configuration Guide(R3308 R2308)-6W107
01-About the WX Series Access Controllers Web Configuration Guide
Models of WX series access controllers
H3C WX series access controllers include the WX3000E series wireless switches, and WX5000 and WX6000 series access controllers. Table 1 shows the models of WX series.
Table 1 Models of WX series access controllers
Product
Model
WX3024E wireless switch
WX5000 series access controllers
·       WX5002V2 access controller
·       WX5004 access controller
·       LSWM1WCM10 access controller module
·       LSWM1WCM20 access controller module
·       WX6103 access controller
·       LSQM1WCMB0 access controller module
·       LSQM1WCMD0 access controller module
·       LSBM1WCM2A0 access controller module
·       LSRM1WCM2A1 access controller module
·       LSRM1WCM3A1 access controller module
The WX6103 access controller supports EWPX1WCMB0 and EWPX1WCMD0 main control boards.
Access controller network scenario
As shown in Figure 1, the AC connects to a Layer 2 or Layer 3 switch through GE1/0/1, the switch is connected to APs directly or over an IP network, and clients access the network through the APs.
Figure 1 AC networking
Access controller module network scenario
As shown in Figure 2, the AC is installed on a Layer 2 or Layer 3 switch, the switch is connected to APs directly or over an IP network, and clients access the network through the APs.
Figure 2 Access controller module networking
Wireless switch network scenario
As shown in Figure 3, the wireless switch that has both AC and switch functions is connected to APs directly or over an IP network, and clients access the network through the APs.
Figure 3 Unified switch networking diagram
In this document, Yes means a feature is supported, and No means not supported.
Feature matrix for the WX5000 series
The LSWM1WCM10 and LSWM1WCM20 access controller modules of the WX5000 series adopt the OAP architecture. They work as OAP cards to exchange data and status and control information with the switch through their internal interfaces. Do not configure services such as QoS rate limiting and 802.1X authentication on XGE 1/0/1 of the LSWM1WCM10, and the logical aggregate interface BAGG1 formed by GE 1/0/1 and GE 1/0/2 of the LSWM1WCM20.
Table 2 Feature matrix for the WX5000 series
Module
Feature
WX5002V2
WX5004
LSWM1WCM10
LSWM1WCM20
Device
License management
Supports 32 concurrent APs by default, and can be extended to support 64 concurrent APs.
Supports 64 concurrent APs by default, and can be extended to support 256 concurrent APs.
Supports 32 concurrent APs by default, and can be extended to support 128 concurrent APs.
File management
CF Yes
CF Yes
CF Yes
Flash Yes
Port mirroring
Yes
Yes
No
No
Loopback test
Yes on GE interfaces
Internal loopback testing Yes on XGE interfaces only
Internal loopback testing Yes on GE interfaces only
Network
IGMP Snooping
The maximum number of multicast groups ranges from 1 to 256 and defaults to 256.
AP
AP group (Licenses must be fully configured to reach the maximum number of group IDs)
The number of group IDs ranges from 1 to 64.
The number of group IDs ranges from 1 to 256.
The number of group IDs ranges from 1 to 128.
Wireless Service
Access service
The maximum number of associated users per SSID is 124 and defaults to 64.
Advanced settings
AC hot backup
Yes
Yes
Yes
No
Fast backup (Hello interval)
Yes (The hello interval ranges from 100 to 2000 and defaults to 2000.)
No
1+1 AC backup
Yes
Yes
Yes
No
1+1 fast backup
Yes
Yes
Yes
No
High availability
Stateful failover
Yes
Yes
Yes
No
Feature matrix for the WX6000 series
·       The switch interface board of the WX6103 adopts OAP architecture and is installed on the slot with purple paint at slot sides. The WX6103 supports EWPX1WCMB0 and EWPX1WCMD0 main control boards. The switch interface board exchanges data, and state and control information with the main control board through internal interfaces. Do not configure services such as QoS rate limiting and 802.1X authentication on the internal interfaces.
·       For configuration information about the switch interface board of the WX6103, see the H3C WX6103 Access Controller Switch Interface Board Configuration Guide and H3C WX6103 Access Controller Switch Interface Board Command Reference.
·       The LSQM1WCMB0/LSQM1WCMD0/LSBM1WCM2A0/LSRM1WCM2A1/LSRM1WCM3A1 of the WX6000 series are OAP cards. Each OAP card is installed on the expansion slot of the switch and exchanges data and status and control information with the switch through internal interfaces. Do not configure services such as QoS rate limiting and 802.1X authentication on the internal interfaces.
Table 3 Feature matrix for the WX6000 series
Module
Feature
WX6103
LSQM1WCMB0
LSQM1WCMD0
LSBM1WCM2A0
LSRM1WCM2A1
LSRM1WCM3A1
Device
License management
EWPX1WCMB0 supports 128 concurrent APs by default, and can be extended to support 640 concurrent APs. EWPX1WCMD0 supports 128 concurrent APs by default, and can be extended to support 1024 concurrent APs.
Supports 128 concurrent APs by default, and can be extended to support 640 concurrent APs.
Supports 128 concurrent APs by default, and can be extended to support 1024 concurrent APs.
File management
CF and USB supported
Port mirroring
No
No
No
No
No
No
Loopback test
Internal loopback testing supported on XGE interfaces only
Network
IGMP Snooping
AP
On EWPX1WCMB0, the number of group IDs ranges from 1 to 640. On EWPX1WCMD0, the number of group IDs ranges from 1 to 1024.
The number of group IDs ranges from 1 to 640.
The number of group IDs ranges from 1 to 1024.
Wireless Service
Access service
Advanced settings
AC backup
Yes
Yes
Yes
Yes
Yes
Yes
Yes (The hello interval ranges from 30 to 2000 and defaults to 2000.)
1+1 AC backup
Yes
Yes
Yes
Yes
Yes
Yes
High availability
Stateful failover
Yes
Yes
Yes
Yes
Yes
Yes
Feature matrix for the WX3024E
·       The access controller engine and switching engine of the WX3024E adopt the OAP architecture. The switching engine is integrated on the access controller engine and adopts OAP architecture. You actually log in to the access controller engine when you log in to the switch by default. The GE 1/0/1 and GE 1/0/2 interfaces of the access controller engine form a logical interface BAGG1, and the GE1/0/29 and GE1/0/30 interfaces of the switching engine form a logical interface BAGG1. The two BAGG1 interfaces exchange data, status, and control information. Do not configure services such as QoS rate limiting and 802.1X authentication on these internal interfaces.
·       For configuration information about the switching engine of the WX3024E, see the H3C WX3024E Wireless Switch Switching Engine Configuration Guide and H3C WX3024E Wireless Switch Switching Engine Command Reference.
Table 4 Feature matrix for the WX3024E
Module
Feature
WX3024E
Device
License management
Supports 24 concurrent APs by default, and can be extended to support 60 concurrent APs.
File management
Flash supported
Port mirroring
No
Loopback test
Internal loopback testing supported on GE interfaces only
Network
IGMP Snooping
The maximum number of multicast groups ranges from 1 to 64 and defaults to 64.
AP
The number of group IDs ranges from 1 to 60.
Wireless Service
Access service
The maximum number of associated users per SSID is 124, and defaults to 64.
Advanced settings
AC backup
No
No
1+1 AC backup
No
High availability
Stateful failover
No
