09-AP胖瘦切换
04-V7 FIT模式切换为V5 FAT模式操作指导
本章节下载 04-V7 FIT模式切换为V5 FAT模式操作指导  (190.36 KB)
Copyright © 2021 新华三技术有限公司 版权所有,保留一切权利。
本文档中的信息可能变动,恕不另行通知。
1 V7的Fit AP切换到V5的Fat AP
1.1  V7的Fit AP切换到V5的Fat AP(无AC,有console)
1.1.1  上传V5 Fat AP的版本文件并降级BootWare版本
(1)     重启设备,当出现“Press Ctrl+B to enter extended boot menu...”,键入<Ctrl+B>,系统进入BootWare主菜单:
System is starting...
Press Ctrl+D to access BASIC-BOOTWARE MENU
Booting Normal Extend BootWare
The Extend BootWare is self-decompressing.............................Done!
*                   H3C WAP712C BootWare, Version 7.15                     *
Copyright (c) 2004-2019 New H3C Technologies Co., Ltd.
Compiled Date       : Mar  1 2019
CPU Type            : ATHEROS AR9563
CPU L1 Cache        : 32KB
CPU Clock Speed     : 775MHz
Memory Type         : SDRAM
Memory Size         : 128MB
Memory Speed        : 560MHz
BootWare Size       : 512KB
Flash Size          : 16MB
PCB Version         : Ver.A
BootWare Validating...
Press Ctrl+B to access EXTENDED-BOOTWARE MENU...
(2)     在BootWare主菜单下键入<Ctrl+F>,并输入“Y”格式化存储介质:
==========================<EXTENDED-BOOTWARE MENU>==========================
|<1> Boot System                                                           |
|<2> Enter Serial SubMenu                                                  |
|<3> Enter Ethernet SubMenu                                                |
|<4> File Control                                                          |
|<5> Restore to Factory Default Configuration                              |
|<6> Skip Current System Configuration                                     |
|<7> BootWare Operation Menu                                               |
|<8> Skip Authentication for Console Login                                 |
|<9> Storage Device Operation                                              |
|<0> Reboot        |
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format File System
Ctrl+C: Display Copyright
Ctrl+Y: Change AP Mode
Enter your choice(0-9):
Warning:All files on flash will be lost! Are you sure to format? [Y/N]Y.....
Format success.
(3)     在BootWare主菜单,选择<3>,进入以太网操作子菜单:
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 3
(4)     在以太网操作子菜单,选择<5>,设置以太网参数:
==========================<Enter Ethernet SubMenu>==========================
|Note:the operating device is flash                                        |
|<1> Download Image Program To SDRAM And Run                               |
|<2> Update Main Image File                                                |
|<3> Update Backup Image File                                              |
|<4> Download Files(*.*)                                                   |
|<5> Modify Ethernet Parameter                                             |
|<0> Exit To Main Menu                                                     |
|<Ensure The Parameter Be Modified Before Downloading!>                    |
Enter your choice(0-5): 5
(5)     在以太网参数设置菜单,根据实际配置设置正确的以太网参数:
==========================<ETHERNET PARAMETER SET>==========================
|Note:       '.' = Clear field.                                            |
|            '-' = Go to previous field.                                   |
|         Ctrl+D = Quit.                                                   |
Protocol (FTP or TFTP) :ftp
Load File Name         :wa4300s.ipe
                       : wa4300s_fat.bin
Target File Name       :wa4300s.ipe
                       : wa4300s_fat.bin
Server IP Address      :192.168.0.10
Local IP Address       :192.168.0.50
Subnet Mask            :255.255.255.0
Gateway IP Address     :0.0.0.0
FTP User Name          :user
FTP User Password      :******
(6)     选择<1>,降级BootWare版本:
Enter your choice(0-5): 1
Loading.....................................................................
............Done.
11293696 bytes downloaded!
(7)     选择“Y”,更新BootWare版本:
Extended BootWare Version is not equal,updating? [Y/N]Y
Updating Extended BootWare..........Done.
BootWare updated,System is rebooting now.
*                   H3C WAP712C BootWare, Version 1.06                     *
Copyright (c) 2004-2017 New H3C Technologies Co., Ltd.
Compiled Date       : Mar 27 2017
CPU L1 Cache        : 32KB
Memory Type         : SDRAM
Memory Size         : 128MB
Flash Size          : 16MB
PCB Version         : Ver.A
1.1.2  切换AP模式
(1)     当出现“Press Ctrl+B to enter extended boot menu...”,键入<Ctrl+B>,系统进入BootWare主菜单后,键入<Ctrl+Y>,切换AP模式:
===========================<EXTEND-BOOTWARE MENU>===========================
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<8> Clear Super Password                                                  |
|<0> Reboot        |
(2)     选择<1>,将AP由Fit模式切换成Fat模式:
Please select the new mode
Current mode is Fit
|NO.  Mode        |
|1    Fat Mode                                                             |
|2    Fit Mode                                                             |
|0    Exit        |
Enter your choice(0-2):1
Changed to fat mode successfully!
(4)切换AP模式之后键入<Ctrl+F>格式化设备。
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Format success.
1.1.3  上传V5 Fat AP的版本文件并更新AP的版本
(1)     在BootWare主菜单,选择<3>,进入以太网操作子菜单:
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
(2)     在以太网操作子菜单,选择<3>,设置以太网参数:
|<1> Download Application Program To SDRAM And Run                         |
|<2> Update Main Application File                                          |
|<3> Modify Ethernet Parameter                                             |
Enter your choice(0-3): 3
(3)     在以太网参数设置菜单,根据实际配置设置正确的以太网参数:
|          Ctrl+D = Quit.                                                  |
Load File Name         :wa4300s_fat.bin
Target File Name       :wa4300s_fat.bin
Server IP Address      :192.168.1.1 192.168.0.10
Local IP Address       :192.168.1.50 192.168.0.50
FTP User Name          :admin user
FTP User Password      :password 123456
(4)     在以太网操作子菜单,选择<2>,更新AP版本:
Enter your choice(0-3): 2
............Done!
Updating File flash:/wa4300s_fat.bin........................................
...........................................................Done!
(5)     选择<0>,返回BootWare主菜单:
Enter your choice(0-3): 0
(6)     在BootWare主菜单,选择<0>,AP重启后就可以发现AP已经由V7的Fit AP切换成V5的Fat AP。
|<1> Boot System                                                           |
|<4> File Control                                                          |
|<0> Reboot        |
Enter your choice(0-9): 0
1.2  V7的Fit AP切换到V5的Fat AP(有AC,有console)
(1)     在有V5的AC配合下,若是有多个V7的Fit AP需要降级,可以通过V5的AC先将其降级成V5的Fit AP。在V5的AC上配置AP模板,并将AP对应的V5版本导入AC设备,然后在AC的隐藏视图下开启CAPWAP功能,保证其可以上线。
a.     进入隐藏视图下开启FPL-DIAG。
[AC]_h
Now you enter a hidden command view for developer's testing, some commands may
affect operation by wrong use, please carefully use it with our engineer's
direction.
[AC-hidecmd]fpl-diag enable
Are you sure you want to enable FPL-DIAG? [Y/N] y
% FPL-DIAG has been enabled.
b.     开启CAPWAP功能。
[AC-hidecmd]fpl-diag drv_capwap_set 1
(2)     开启CAPWAP功能后,保存配置并重启设备生效。等待AP下载V5版本,并刷新为低版本的V5 Bootware后再关闭V5平台AC的CAPWAP功能。
a.     在隐藏视图下开启FPL-DIAG。
b.     关闭CAPWAP功能,保存配置并重启设备生效。
[AC-hidecmd]fpl-diag drv_capwap_set 0
(3)     当AP在V5的AC上线后,已经切换为V5 Fit版本。此时需要通过Console口登录到AP上,将V5 Fit模式切换成V5 Fat模式,同时传入Fat版本。详细操作步骤可参考1.1.2  切换AP模式1.1.3  上传V5 Fat AP的版本文件并更新AP的版本
