07-System
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath M9000 Comware 7 Web configuration guide(R9153P38 R9724P38 R9001P38 E9153P38)-6W40107-System
15-Bandwidth alarm logs
15-Bandwidth alarm logs 13.06 KB
Introduction
This feature monitors the total incoming traffic on the device. The device examines the total incoming traffic rate every 5 seconds and uses the average traffic rate during the 5 seconds to compare with the threshold. A log message is generated if the total incoming traffic rate on the device has reached or exceeded the threshold for the specified duration. After that, a log message is generated if the average traffic rate during a 5-second period reaches or exceeds the threshold. A log message is also generated when the average traffic rate falls below the threshold for the first time. Bandwidth alarm logs can only be output as system logs.
