- 07-System
- 01-High availability group
- 02-VRRP
- 03-Track
- 04-BFD
- 05-NQA
- 06-Basic log settings
- 07-Session log settings
- 08-NAT log settings
- 09-AFT log settings
- 10-Threat log settings
- 11-Application audit log settings
- 12-NetShare log settings
- 13-URL filtering log settings
- 14-Attack defense log settings
- 15-Bandwidth alarm logs
- 16-Configuration log settings
- 17-Security policy log
- 18-Heartbeat log settings
- 19-IP access logs
- 20-WAF log settings
- 21-Bandwidth management logs
- 22-Context rate limit logging
- 23-Report settings
- 24--Session settings
- 25-MAC authentication online users
- 26-Signature upgrade
- 27-Software upgrade
- 28-License management
- 29-IRF
- 30-IRF advanced settings
- 31-Contexts
- 32-Administrators
- 33-Date and time
- 34-MAC address learning through a Layer 3 device
- 35-SNMP
- 36-Configuration management
- 37-About
- 38-Reboot
- 39-Ping
- 40-Tracert
- 41-Packet capture
- 42-Webpage Diagnosis
- 43-Diagnostic Info
- 44-Packet trace
- 45-Load balancing test
- 46-IPsec diagnosis
- 47-Fast Internet Access
- 48-IP reputation log settings
- 49-Load balancing logging
42-Webpage Diagnosis | 27.01 KB |
This help contains the following topics:
Introduction
This feature outputs easy-to-read diagnosis results to help you quickly troubleshoot webpage access failures of internal users. With this feature, you do not need to manually ping servers or display log messages.
· This feature supports only IPv4.
· This feature supports only HTTP webpages.
· Before starting a webpage diagnosis, you must configure security policies to ensure connectivity between the following security zones:
¡ Security zone where the user resides.
¡ Security zone where the Web server resides.
¡ Security zone Local.
Perform a webpage diagnosis
1. Select System > Diagnosis Center > Webpage Diagnosis.
2. Configure webpage diagnosis parameters.
Table 1 Webpage diagnosis configuration items
Item |
User IP |
IP address of the user. |
User VRF |
VPN instance to which the user belongs. |
Webpage URL |
URL that the user accessed, for example, http://www.example.com. |
Webpage VRF |
VPN instance to which the webpage belongs. |
3. Click Diagnose.
4. View the webpage diagnosis result to analyze the failure and resolve the issue.
5. (Optional.) Click Export to export the webpage diagnosis result to a .xml file.
