- 07-System
- 01-High availability group
- 02-VRRP
- 03-Track
- 04-BFD
- 05-NQA
- 06-Basic log settings
- 07-Session log settings
- 08-NAT log settings
- 09-AFT log settings
- 10-Threat log settings
- 11-Application audit log settings
- 12-NetShare log settings
- 13-URL filtering log settings
- 14-Attack defense log settings
- 15-Bandwidth alarm logs
- 16-Configuration log settings
- 17-Security policy log
- 18-Heartbeat log settings
- 19-IP access logs
- 20-WAF log settings
- 21-Bandwidth management logs
- 22-Context rate limit logging
- 23-Report settings
- 24--Session settings
- 25-MAC authentication online users
- 26-Signature upgrade
- 27-Software upgrade
- 28-License management
- 29-IRF
- 30-IRF advanced settings
- 31-Contexts
- 32-Administrators
- 33-Date and time
- 34-MAC address learning through a Layer 3 device
- 35-SNMP
- 36-Configuration management
- 37-About
- 38-Reboot
- 39-Ping
- 40-Tracert
- 41-Packet capture
- 42-Webpage Diagnosis
- 43-Diagnostic Info
- 44-Packet trace
- 45-Load balancing test
- 46-IPsec diagnosis
- 47-Fast Internet Access
- 48-IP reputation log settings
- 49-Load balancing logging
09-AFT log settings | 24.70 KB |
AFT log settings
This help contains the following topics:
Introduction
AFT session log settings
For security auditing, you can configure AFT logging to record AFT session information. AFT sessions refer to the sessions whose source and destination addresses have been translated by AFT.
AFT session logs can be output only in flow logs. AFT can log the creation and deletion events of AFT sessions.
Port block log settings
If a port block size is specified for a dynamic translation policy in PAT mode, AFT generates a port block log when a port block is allocated, deleted, or the resources in a port block are exhausted.
Port block logs can be output in system logs or fast logs. By default, port block logs are output in system logs.
