07-System
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath M9000 Comware 7 Web configuration guide(R9153P38 R9724P38 R9001P38 E9153P38)-6W40107-System
07-Session log settings
07-Session log settings 25.07 KB
This help contains the following topics:
·     Introduction
·     Configure session log setting
Introduction
Session logs provide information about user access, IP address translation, and network traffic for security auditing. They can be output in flow log or fast log output format.
The device supports time-based or traffic-based logging:
·     Time-based logging—The device outputs session logs regularly.
·     Traffic-based logging—The device outputs a session log when the traffic amount of a session reaches a threshold.
If you set both time-based and traffic-based logging, the device outputs a session log when whichever is reached. After outputting a session log, the device resets the traffic counter and restarts the interval for the session.
Session logs can be generated only when session logging is enabled on interfaces.
Configure session log settings
1.     Click the System tab.
2.     Select Log Settings > Session Log Settings.
3.     Configure session logging.
Table 1 Session logging configuration items
Item
Log type
Select a log type. By default, flow log is used.
Session creation logging
This feature enables the device to output a session log when a session entry is created.
Session deletion logging
This feature enables the device to output a session log when a session entry is removed.
Set either the byte-based threshold or the packet-based threshold.
The device outputs a session log when the traffic amount of a session reaches the set threshold.
Time-based logging
Set the time-based threshold for the device to output session logs.
4.     Click Apply.
5.     Click Add interface to enable session logging on the specified interface.
Table 2 Configuration items for enabling session logging on an interface
Item
IP version
Select an IP version, IPv4 or IPv6.
Port
Select a port.
You can also enable session logging on the specified directions of the port.
ACL
Select an ACL to filter IPv4 or IPv6 sessions that can trigger session logging on the interface.
If no ACL is specified, the device outputs session logs for all IPv4 or IPv6 sessions on the interface.
6.     Click OK.
7.     Verify the configuration on the Session Logging page.
