06-Security Configuration Guide
HomeSupportWirelessH3C WX3000E Series Wireless SwitchesConfigure & DeployConfiguration GuidesH3C WX3000E Series Wireless Switches Switching Engine Configuration Guides(R3507P26)-6W10206-Security Configuration Guide
05-Port Security Configuration
05-Port Security Configuration 198.66 KB
Port security configuration
This chapter includes these sections:
·          Port security overview
·          Port security configuration task list
·          Displaying and maintaining port security
·          Port security configuration examples
·          Troubleshooting port security
·      The term "switch" or "device" in this chapter refers to the switching engine on a WX3000E wireless switch.
·      The WX3000E series comprises WX3024E and WX3010E wireless switches.
·      The port numbers in this chapter are for illustration only.
Port security provides MAC-based network access control. It prevents unauthorized access to the network by checking the source MAC address of inbound traffic and prevents access to unauthorized devices by checking the destination MAC address of outbound traffic.
Port security enables you to control MAC address learning and authentication on ports. The feature ensures that a port learns only legal source MAC addresses.
A frame is illegal, if its source MAC address cannot be learned in a port security mode or it is from a client that has failed 802.1X or MAC authentication.
The port security feature can automatically take a pre-defined action on illegal frames. This automatic mechanism enhances network security and reduces human intervention.
The security modes of the port security feature provide extended and combined use of 802.1X authentication and MAC authentication. They apply to scenarios that require both 802.1X authentication and MAC authentication. For scenarios that require only 802.1X authentication or MAC authentication, H3C recommends you configure 802.1X authentication or MAC authentication rather than port security. For more information about 802.1X and MAC authentication, see the chapters “802.1X configuration” and “MAC authentication configuration.
Port security features
NTK
The need to know (NTK) feature prevents traffic interception by checking the destination MAC address in the outbound frames. The feature ensures that frames are sent only to hosts that have passed authentication or whose MAC addresses have been learned or configured on the access device.
Intrusion protection
The intrusion protection feature checks the source MAC address in inbound frames for illegal frames and takes a pre-defined action on each detected illegal frame. The action can be disabling the port temporarily, disabling the port permanently, or blocking frames from the illegal MAC address for three minutes (not user configurable).
Port security traps
You can configure the port security module to send traps for port security events such as login, logoff, and MAC authentication. These traps help you monitor user behaviors.
Port security modes
Port security supports the following categories of security modes:
·          MAC learning controlIncludes two modes, autoLearn and secure. MAC address learning is permitted on a port in autoLearn mode and disabled in secure mode.
·          AuthenticationSecurity modes in this category implement MAC authentication, 802.1X authentication, or a combination of these two authentication methods.
Upon receiving a frame, the port in a security mode searches the MAC address table for the source MAC address. If a match is found, the port forwards the frame. If no match is found, the port learns the MAC address or performs authentication, depending on the security mode. If the frame is illegal, the port takes the pre-defined NTK, intrusion protection, or trapping action.
Table 1 describes the port security modes and the security features.
Table 1 Port security modes
Purpose
Security mode
Features that can be triggered
Turning off the port security feature
noRestrictions (the default mode)
In this mode, port security is disabled on the port and access to the port is not restricted.
Controlling MAC address learning
autoLearn
NTK/intrusion protection
secure
Performing 802.1X authentication
userLogin
userLoginSecure
userLoginSecureExt
userLoginWithOUI
Performing MAC authentication
macAddressWithRadius
Performing a combination of MAC authentication and 802.1X authentication
Or
macAddressOrUserLoginSecure
macAddressOrUserLoginSecureExt
Else
macAddressElseUserLoginSecure
macAddressElseUserLoginSecureExt
TIP TIP:
·      userLogin specifies 802.1X authentication and port-based access control.
·      macAddress specifies MAC authentication.
·      Else specifies that the authentication method before Else is applied first. If the authentication fails, whether to turn to the authentication method following Else depends on the protocol type of the authentication request.
·      Typically, in a security mode with Or, which authentication method is to be used depends on the protocol type of the authentication request.
·      userLogin with Secure specifies 802.1X authentication and MAC-based access control.
·      Ext indicates allowing multiple 802.1X users to be authenticated and serviced at the same time. A security mode without Ext allows only one user to pass 802.1X authentication.
1.        autoLearn
A port in this mode can learn MAC addresses, and allows frames from learned or configured MAC addresses to pass. The automatically learned MAC addresses are secure MAC addresses. You can also configure secure MAC addresses by using the port-security mac-address security command. A secure MAC address never ages out by default.
When the number of secure MAC addresses reaches the upper limit, the port transitions to secure mode.
The dynamic MAC address learning function in MAC address management is disabled on ports operating in autoLearn mode, but you can configure MAC addresses by using the mac-address dynamic and mac-address static commands.
2.        secure
MAC address learning is disabled on a port in secure mode. You configure MAC addresses by using the mac-address static and mac-address dynamic commands.
A port in secure mode allows only frames sourced from secure MAC addresses and manually configured MAC addresses to pass.
1.        userLogin
A port in this mode performs 802.1X authentication and implements port-based access control. The port can service multiple 802.1X users. If one 802.1X user passes authentication, all the other 802.1X users of the port can access the network without authentication.
2.        userLoginSecure
A port in this mode performs 802.1X authentication and implements MAC-based access control. The port services only one user passing 802.1X authentication.
3.        userLoginSecureExt
This mode is similar to the userLoginSecure mode except that this mode supports multiple online 802.1X users.
4.        userLoginWithOUI
This mode is similar to the userLoginSecure mode. The difference is that a port in this mode also permits frames from one user whose MAC address contains a specified organizationally unique identifier (OUI).
For wired users, the port performs 802.1X authentication upon receiving 802.1X frames, and performs OUI check upon receiving non-802.1X frames.
macAddressWithRadius: A port in this mode performs MAC authentication and services multiple users.
1.        macAddressOrUserLoginSecure
This mode is the combination of the macAddressWithRadius and userLoginSecure modes.
For wired users, the port performs MAC authentication upon receiving non-802.1X frames and performs 802.1X authentication upon receiving 802.1X frames.
2.        macAddressOrUserLoginSecureExt
This mode is similar to the macAddressOrUserLoginSecure mode except that a port in this mode supports multiple 802.1X and MAC authentication users.
3.        macAddressElseUserLoginSecure
This mode is the combination of the macAddressWithRadius and userLoginSecure modes, with MAC authentication having a higher priority as the Else keyword implies.
For non-802.1X frames, a port in this mode performs only MAC authentication. For 802.1X frames, it performs MAC authentication and then, if the authentication fails, 802.1X authentication.
4.        macAddressElseUserLoginSecureExt
This mode is similar to the macAddressElseUserLoginSecure mode except that a port in this mode supports multiple 802.1X and MAC authentication users as the keyword Ext implies.
·      The maximum number of users a port supports equals the maximum number of MAC addresses that port security allows or the maximum number of concurrent users the authentication mode in use allows, whichever is smaller. For example, if 802.1X allows less concurrent users than port security’s limit on the number of MAC addresses on the port in userLoginSecureExt mode, port security’s limit takes effect.
·      For more information about configuring MAC address table entries, see the Layer 2 Configuration Guide.
Support for guest VLAN and Auth-Fail VLAN
An 802.1X guest VLAN is the VLAN that a user is in before initiating authentication. An 802.1X Auth-Fail VLAN or a MAC authentication guest VLAN is the VLAN that a user is in after failing authentication. Support for the guest VLAN and Auth-Fail VLAN features varies with security modes.
·          You can use the 802.1X guest VLAN and 802.1X Auth-Fail VLAN features together with port security modes that support 802.1X authentication. For more information about the 802.1X guest VLAN and Auth-Fail VLAN on a port that performs MAC-based access control, see the chapter “802.1X configuration.
·          You can use the MAC authentication VLAN feature together with security modes that support MAC authentication. For more information about the MAC authentication guest VLAN, see the chapter “MAC authentication configuration.
If you configure both an 802.1X Auth-Fail VLAN and a MAC authentication guest VLAN on a port that performs MAC-based access control, the 802.1X Auth-Fail VLAN has a higher priority.
Complete the following tasks to configure port security:
Remarks
Enabling port security
Required
Setting port security’s limit on the number of MAC addresses on a port
Optional
Setting the port security mode
Required
Configuring port security features
Configuring NTK
Optional
Configure one or more features as required.
Configuring intrusion protection
Enabling port security traps
Configuring secure MAC addresses
Optional
Ignoring authorization information from the server
Optional
Configuration prerequisites
Disable 802.1X and MAC authentication globally.
Configuration procedure
Follow these steps to enable port security:
To do…
Use the command…
Remarks
Enter system view
Enable port security
port-security enable
Required
The port security is disabled by default .
Enabling or disabling port security resets the following security settings to the default:
·          802.1X access control mode is MAC-based, and the port authorization state is auto.
·          Port security mode is noRestrictions.
When port security is enabled, you cannot manually enable 802.1X or MAC authentication, or change the access control mode or port authorization state. The port security automatically modifies these settings in different security modes.
You cannot disable port security when online users are present.
·      For more information about 802.1X configuration, see the chapter “802.1X configuration.
·      For more information about MAC authentication configuration, see the chapter “MAC authentication configuration.
You can set the maximum number of MAC addresses that port security allows on a port for the following purposes:
·          Controlling the number of concurrent users on the port. The maximum number of concurrent users on the port equals this limit or the limit of the authentication mode (802.1X for example) in use, whichever is smaller.
·          Controlling the number of secure MAC addresses on the port in autoLearn mode.
Follow these steps to set the maximum number of secure MAC addresses allowed on a port:
To do…
Use the command…
Remarks
Enter system view
Enter interface view
Set the limit of port security on the number of MAC addresses
port-security max-mac-count count-value
Required
Not limited by default
The port security’s limit on the number of MAC addresses on a port is independent of the MAC learning limit described in MAC address table configuration in the Layer 2—LAN Switching Configuration Guide.
Before you set a port security mode for a port, complete the following tasks:
·          Disable 802.1X and MAC authentication.
·          Check that the port does not belong to any aggregation group.
·          If you are configuring the autoLearn mode, set port security’s limit on the number of MAC addresses. You cannot change the setting when the port is operating in autoLearn mode.
·      You can specify a port security mode when port security is disabled, but your configuration cannot take effect.
·      You cannot change the port security mode of a port when online users are present.
Follow these steps to enable a port security mode:
To do…
Use the command…
Remarks
Enter system view
Set an OUI value for user authentication
port-security oui oui-value index index-value
Optional
Not configured by default.
The command is required for the userlogin-withoui mode.
Set the port security mode
port-security port-mode { autolearn | mac-authentication | mac-else-userlogin-secure | mac-else-userlogin-secure-ext | secure | userlogin | userlogin-secure | userlogin-secure-or-mac | userlogin-secure-or-mac-ext | userlogin-withoui }
Required
By default, a port operates in noRestrictions mode.
·      An OUI, as defined by the Institute of Electrical and Electronics Engineers (IEEE), is the first 24 bits of the MAC address, which uniquely identifies a device vendor.
·      A port in userLoginWithOUI mode allows only one 802.1X user and one user whose MAC address contains any specified OUI to pass authentication concurrently.
·      After enabling port security, you can change the port security mode of a port only when the port is operating in noRestrictions (the default) mode. To change the port security mode for a port in any other mode, use the undo port-security port-mode command to restore the default port security mode first.
Configuring NTK
The NTK feature checks the destination MAC addresses in outbound frames to make sure that frames are forwarded only to authenticated devices. Any unicast frame with an unknown destination MAC address is discarded.
The NTK feature supports the following modes:
·          ntkonlyForwards only unicast frames with authenticated destination MAC addresses.
·          ntk-withbroadcastsForwards only broadcast frames and unicast frames with authenticated destination MAC addresses.
·          ntk-withmulticastsForwards only broadcast frames, multicast frames, and unicast frames with authenticated destination MAC addresses.
Follow these steps to configure the NTK feature:
To do…
Use the command…
Remarks
Enter system view
Configure the NTK feature
port-security ntk-mode { ntk-withbroadcasts | ntk-withmulticasts | ntkonly }
Required
By default, NTK is disabled on a port and all frames are allowed to be sent.
The device supports only the ntk-withmulticast mode.
Whether the NTK feature can be triggered depends on the port security mode. For more information, see Table 1.
The intrusion protection enables a device to take one of the following actions in response to illegal frames:
·          blockmacAdds the source MAC addresses of illegal frames to the blocked MAC addresses list and discards the frames. All subsequent frames sourced from a blocked MAC address will be dropped. A blocked MAC address is restored to normal state after being blocked for three minutes. The interval is fixed and cannot be changed.
·          disableport—Disables the port until you bring it up manually.
·          disableport-temporarily—Disables the port for a specified period of time. The period can be configured with the port-security timer disableport command.
Follow these steps to configure the intrusion protection feature:
To do…
Use the command…
Remarks
Enter system view
Configure the intrusion protection feature
port-security intrusion-mode { blockmac | disableport | disableport-temporarily }
Required
By default, intrusion protection is disabled.
Return to system view
Set the silence timeout period during which a port remains disabled
port-security timer disableport time-value
Optional
20 seconds by default
On a port operating in either the macAddressElseUserLoginSecure mode or the macAddressElseUserLoginSecureExt mode, intrusion protection is triggered only after both MAC authentication and 802.1X authentication for the same frame fail.
You can configure the port security module to send traps for the following categories of events:
·          addresslearned—Learning of new MAC addresses.
·          dot1xlogfailure/dot1xlogon/dot1xlogoff—802.1X authentication failure, success, and 802.1X user logoff.
·          ralmlogfailure/ralmlogon/ralmlogoffMAC authentication failure, MAC authentication user logon, and MAC authentication user logoff.
·          intrusion—Detection of illegal frames.
Follow these steps to enable port security traps:
To do…
Use the command…
Remarks
Enter system view
Enable port security traps
port-security trap { addresslearned | dot1xlogfailure | dot1xlogoff | dot1xlogon | intrusion | ralmlogfailure | ralmlogoff | ralmlogon }
Required
By default, port security traps are disabled.
Secure MAC addresses are MAC addresses configured or learned in autoLearn mode. They can survive link down/up events, and once saved, can survive a device reboot. You can bind a MAC address to only one port in a VLAN.
Static secure MAC addresses are manually configured at the command line or in the MIB in autoLearn mode. No aging mechanism is available for this type of MAC address. They never age out unless you manually remove them, change the port security mode, or disable the port security feature.
When the maximum number of secure MAC address entries is reached, the port changes to secure mode, and no more secure MAC addresses can be added or learned. The port allows only frames sourced from a secure MAC address or a MAC address configured with the mac-address dynamic or mac-address static command to pass through.
·          Enable port security.
·          Set port security’s limit on the number of MAC addresses on the port. Perform this task before you enable autoLearn mode.
·          Set the port security mode to autoLearn.
Follow these steps to configure a secure MAC address:
To do…
Use the command…
Remarks
Enter system view
Configure a secure MAC address
In system view
port-security mac-address security mac-address interface interface-type interface-number vlan vlan-id
Required
Use either approach
No secure MAC address is configured by default.
In interface view
port-security mac-address security mac-address vlan vlan-id
The authorization information is delivered by the RADIUS server to the device after an 802.1X user or MAC authenticated user passes RADIUS authentication. You can configure a port to ignore the authorization information from the RADIUS server.
Follow these steps to configure a port to ignore the authorization information from the RADIUS server:
To do…
Use the command…
Remarks
Enter system view
Ignore the authorization information from the RADIUS server
port-security authorization ignore
Required
By default, a port uses the authorization information from the RADIUS server.
To do…
Use the command…
Remarks
Display port security configuration information, operation information, and statistics about one or more ports or all ports
display port-security [ interface interface-list ] [ | { begin | exclude | include } regular-expression ]
Available in any view
Display information about secure MAC addresses
display port-security mac-address security [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ] [ | { begin | exclude | include } regular-expression ]
Display information about blocked MAC addresses
display port-security mac-address block [ interface interface-type interface-number ] [ vlan vlan-id ] [ count ] [ | { begin | exclude | include } regular-expression ]
Configuring the autoLearn mode
Network requirements
See Figure 1. Configure port GigabitEthernet 1/0/1 on the Switch, as follows:
·          Accept up to 64 users on the port without authentication.
·          Permit the port to learn and add MAC addresses as MAC addresses, and set the MAC aging timer to 30 minutes.
·          After the number of secure MAC addresses reaches 64, the port stops learning MAC addresses. If any frame with an unknown MAC address arrives, intrusion protection starts, and the port shuts down and stays silent for 30 seconds.
Figure 1 Network diagram for configuring the autoLearn mode
1.        Configure port security
# Enable port security.
<Switch> system-view
[Switch] port-security enable
# Enable intrusion protection traps on port GigabitEthernet 1/0/1.
[Switch] port-security trap intrusion
# Set the port security mode to autoLearn.
[Switch-GigabitEthernet1/0/1] port-security port-mode autolearn
# Configure the port to be silent for 30 seconds after the intrusion protection feature is triggered.
[Switch-GigabitEthernet1/0/1] port-security intrusion-mode disableport-temporarily
[Switch] port-security timer disableport 30
2.        Verify the configuration
After completing the configurations, you can use the following command to view the port security configuration information:
<Switch> display port-security interface gigabitethernet 1/0/1
 Equipment port-security is enabled
 Intrusion trap is enabled
Disableport Timeout: 30s
 OUI value:
GigabitEthernet1/0/1 is link-up
   Port mode is autoLearn
   NeedToKnow mode is disabled
   Intrusion Protection mode is DisablePortTemporarily
   Max MAC address number is 64
   Stored MAC address number is 0
   Authorization is permitted
The output shows that the port security's limit on the number of secure MAC addresses on the port is 64, the port security mode is autoLearn, intrusion protection traps are enabled, and the intrusion protection action is disabling the port (DisablePortTemporarily) for 30 seconds.
You can also use the command repeatedly to track the number of MAC addresses learned by the port, or use the display this command in interface view to display the secure MAC addresses learned:
[Switch-GigabitEthernet1/0/1] display this
 port-security max-mac-count 64
 port-security mac-address security 0002-0000-0015 vlan 1
 port-security mac-address security 0002-0000-0014 vlan 1
 port-security mac-address security 0002-0000-0013 vlan 1
 port-security mac-address security 0002-0000-0012 vlan 1
 port-security mac-address security 0002-0000-0011 vlan 1
Issuing the display port-security interface command after the number of MAC addresses learned by the port reaches 64, you will see that the port security mode has changed to secure. When any frame with a new MAC address arrives, intrusion protection is triggered and you will see the following traps:
#Jul 14 10:39:47:135 2009 Switch PORTSEC/4/VIOLATION:Traph3cSecureViolation
 An intrusion occurs!
 IfIndex: 9437185
 Port: 9437185
 MAC Addr: 00:02:00:00:00:32
 VLAN ID: 1
 IfAdminStatus: 1
In addition, you will see that the port security feature has disabled the port if you issue the following command:
[Switch-GigabitEthernet1/0/1] display interface gigabitethernet 1/0/1
 GigabitEthernet1/0/1 current state:  Port Security Disabled
 IP Packet Frame Type: PKTFMT_ETHNT_2, Hardware Address: 000f-cb00-5558
 Description: GigabitEthernet1/0/1 Interface
The port should be re-enabled 30 seconds later.
 GigabitEthernet1/0/1 current state: UP
If you manually delete several secure MAC addresses, the port security mode of the port will be restored to autoLearn, and the port will be able to learn MAC addresses again.
Configuring the userLoginWithOUI mode
As shown in Figure 2, a client is connected to the Switch through port GigabitEthernet 1/0/1. The Switch authenticates the client with a RADIUS server. If the authentication succeeds, the client is authorized to access the Internet.
·          The RADIUS server at 192.168.1.2 functions as the primary authentication server and the secondary accounting server, and the RADIUS server at 192.168.1.3 functions as the secondary authentication server and the primary accounting server. The shared key for authentication is name, and that for accounting is money.
·          All users use the default authentication, authorization, and accounting methods of ISP domain sun, which can accommodate up to 30 users.
·          The RADIUS server response timeout time is five seconds and the maximum number of RADIUS packet retransmission attempts is five. The Switch sends real-time accounting packets to the RADIUS server at an interval of 15 minutes, and sends user names without domain names to the RADIUS server.
Configure port GigabitEthernet 1/0/1 of the Switch to:
·          Allow only one 802.1X user to be authenticated.
·          Allow up to 16 OUI values to be configured and allow one terminal that uses any of the OUI values to access the port in addition to an 802.1X user.
Figure 2 Network diagram for configuring the userLoginWithOUI mode
·      The following configuration steps cover some AAA/RADIUS configuration commands. For more information about the commands, see the chapter “AAA configuration.
·      Configurations on the host and RADIUS servers are omitted.
1.        Configure the RADIUS protocol
# Configure a RADIUS scheme named radsun.
[Switch] radius scheme radsun
[Switch-radius-radsun] primary authentication 192.168.1.2
[Switch-radius-radsun] primary accounting 192.168.1.3
[Switch-radius-radsun] secondary authentication 192.168.1.3
[Switch-radius-radsun] secondary accounting 192.168.1.2
[Switch-radius-radsun] key authentication name
[Switch-radius-radsun] key accounting money
[Switch-radius-radsun] timer response-timeout 5
[Switch-radius-radsun] retry 5
[Switch-radius-radsun] timer realtime-accounting 15
[Switch-radius-radsun] user-name-format without-domain
[Switch-radius-radsun] quit
# Configure ISP domain sun to use RADIUS scheme radsun for authentication, authorization, and accounting of all types of users. Specify that the ISP domain can contain up to 30 users.
[Switch] domain sun
[Switch-isp-sun] authentication default radius-scheme radsun
[Switch-isp-sun] authorization default radius-scheme radsun
[Switch-isp-sun] accounting default radius-scheme radsun
[Switch-isp-sun] access-limit enable 30
[Switch-isp-sun] quit
2.        Configure 802.1X
# Set the 802.1X authentication method to CHAP. (This configuration is optional. By default, the authentication method is CHAP for 802.1X.)
[Switch] dot1x authentication-method chap
3.        Configure port security
# Add five OUI values.
[Switch] port-security oui 1234-0100-1111 index 1
[Switch] port-security oui 1234-0200-1111 index 2
[Switch] port-security oui 1234-0300-1111 index 3
[Switch] port-security oui 1234-0400-1111 index 4
[Switch] port-security oui 1234-0500-1111 index 5
# Set the port security mode to userLoginWithOUI.
[Switch-GigabitEthernet1/0/1] port-security port-mode userlogin-withoui
4.        Verify the configuration
After completing the configurations, you can use the following command to view the configuration information of the RADIUS scheme named radsun:
<Switch> display radius scheme radsun
SchemeName  : radsun
  Index : 1                            Type : standard
  Primary Auth Server:
    IP: 192.168.1.2                              Port: 1812   State: active
    Encryption Key : N/A
  Primary Acct Server:
    IP: 192.168.1.3                              Port: 1813   State: active
  Second Auth Server:
    IP: 192.168.1.3                              Port: 1812   State: active
  Second Acct Server:
    IP: 192.168.1.2                              Port: 1813   State: active
  Auth Server Encryption Key : name
  Acct Server Encryption Key : money
  Accounting-On packet disable, send times : 5 , interval : 3s
  Interval for timeout(second)                            : 5
  Retransmission times for timeout                        : 5
  Interval for realtime accounting(minute)                : 15
  Retransmission times of realtime-accounting packet      : 5
  Retransmission times of stop-accounting packet          : 500
  Quiet-interval(min)                                     : 5
  Username format                                         : without-domain
  Data flow unit                                          : Byte
  Packet unit                                             : one
Use the following command to view the configuration information of the ISP domain named sun:
<Switch> display domain sun
   Domain : sun
   State : Active
   Access-limit : 30
   Accounting method : Required
   Default authentication scheme      : radius:radsun
   Default authorization scheme       : radius:radsun
   Default accounting scheme          : radius:radsun
   Domain User Template:
   Idle-cut : Disabled
   Self-service : Disabled
   Authorization attributes:
Use the following command to view the port security configuration information:
 Trap is disabled
 Disableport Timeout: 20s
 OUI value:
   Index is 1,  OUI value is 123401
   Index is 2,  OUI value is 123402
   Index is 3,  OUI value is 123403
   Index is 4,  OUI value is 123404
   Index is 5,  OUI value is 123405
   Port mode is userLoginWithOUI
   Intrusion Protection mode is NoAction
   Max MAC address number is not configured
After an 802.1X user gets online, you can see that the number of secure MAC addresses stored is 1. You can also use the following command to view information about 802.1X:
<Switch> display dot1x interface gigabitethernet 1/0/1
 Equipment 802.1X protocol is enabled
 CHAP authentication is enabled
EAD quick deploy is disabled
  Configuration: Transmit Period   30 s,  Handshake Period       15 s
                  Quiet Period      60 s,  Quiet Period Timer is disabled
                  Supp Timeout      30 s,  Server Timeout        100 s
                  Reauth Period   3600 s
                  The maximal retransmitting times    2
  EAD quick deploy configuration:
                EAD timeout:    30m
 The maximum 802.1X user resource number is 1024 per slot
 Total current used 802.1X resource number is 1
   Handshake is enabled
   Handshake secure is disabled
   802.1X unicast-trigger is enabled
   Periodic reauthentication is disabled
   The port is an authenticator
   Authentication Mode is Auto
   Port Control Type is Mac-based
   802.1X Multicast-trigger is enabled
   Mandatory authentication domain: NOT configured
   Guest VLAN: NOT configured
   Auth-Fail VLAN: NOT configured
   Max number of on-line users is 256
   EAPOL Packet: Tx 16331, Rx 102
   Sent EAP Request/Identity Packets : 16316
        EAP Request/Challenge Packets: 6
        EAP Success Packets: 4, Fail Packets: 5
   Received EAPOL Start Packets : 6
            EAPOL LogOff Packets: 2
            EAP Response/Identity Packets : 80
            EAP Response/Challenge Packets: 6
            Error Packets: 0
 1. Authenticated user : MAC address: 0002-0000-0011
   Controlled User(s) amount to 1
In addition, the port allows an additional user whose MAC address has an OUI among the specified OUIs to access the port. You can use the following command to view the related information:
<Switch> display mac-address interface gigabitethernet 1/0/1
MAC ADDR        VLAN ID   STATE          PORT INDEX               AGING TIME(s)
1234-0300-0011  1         Learned        GigabitEthernet1/0/1       AGING
  ---  1 mac address(es) found  ---
Configuring the macAddressElseUserLoginSecure mode
As shown in Figure 2, a client is connected to the Switch through GigabitEthernet 1/0/1. The Switch authenticates the client by a RADIUS server. If the authentication succeeds, the client is authorized to access the Internet.
Restrict port GigabitEthernet 1/0/1 of the Switch:
·          Allow more than one MAC authenticated user to log on.
·          For 802.1X users, perform MAC authentication first and then, if MAC authentication fails, 802.1X authentication. Allow only one 802.1X user to log on.
·          Set fixed username and password for MAC authentication. Set the total number of MAC authenticated users and 802.1X authenticated users to 64.
·          Enable NTK to prevent frames from being sent to unknown MAC addresses.
Configure the RADIUS authentication/accounting and ISP domain settings the same as in Configuring the userLoginWithOUI mode.
2.        Configure port security
# Configure a MAC authentication user, setting the username and password to aaa and 123456 respectively.
[Switch] mac-authentication user-name-format fixed account aaa password simple 123456
# Specify ISP domain sun for MAC authentication.
[Switch] mac-authentication domain sun
# Set port security’s limit on the number of MAC addresses to 64 on the port.
[Switch-GigabitEthernet1/0/1] port-security max-mac-count 64
# Set the port security mode to macAddressElseUserLoginSecure.
[Switch-GigabitEthernet1/0/1] port-security port-mode mac-else-userlogin-secure
# Set the NTK mode of the port to ntkonly.
[Switch-GigabitEthernet1/0/1] port-security ntk-mode ntkonly
3.        Verify the configuration
 Trap is disabled
 OUI value:
   Port mode is macAddressElseUserLoginSecure
   NeedToKnow mode is NeedToKnowOnly
Use the following command to view MAC authentication information:
<Switch> display mac-authentication interface gigabitethernet 1/0/1
MAC address authentication is enabled.
 User name format is fixed account
 Fixed username:aaa
 Fixed password:123456
          Offline detect period is 60s
          Quiet period is 5s
          Server response timeout value is 100s
          The max allowed user number is 1024 per slot
          Current user number amounts to 3
          Current domain is mac
Silent MAC User info:
          MAC Addr         From Port                    Port Index
  Authenticate success: 3, failed: 7
  Current online user number is 3
    MAC ADDR         Authenticate state           Auth Index
    1234-0300-0011   MAC_AUTHENTICATOR_SUCCESS     13
    1234-0300-0012   MAC_AUTHENTICATOR_SUCCESS     14
    1234-0300-0013   MAC_AUTHENTICATOR_SUCCESS     15
Use the following command to view 802.1X authentication information:
                EAD timeout:    30m
 Total maximum 802.1X user resource number is 1024 per slot
            Error Packets: 0
In addition, as NTK is enabled, frames with unknown destination MAC addresses, multicast addresses, and broadcast addresses should be discarded.
Cannot set the port security mode
Symptom
Cannot set the port security mode.
 Error:When we change port-mode, we should first change it to noRestrictions, then change it to the other.
Analysis
For a port operating in a port security mode other than noRestrictions, you cannot change the port security mode by using the port-security port-mode command directly.
Solution
Set the port security mode to noRestrictions first.
[Switch-GigabitEthernet1/0/1] undo port-security port-mode
Cannot configure secure MAC addresses
Symptom
Cannot configure secure MAC addresses.
[Switch-GigabitEthernet1/0/1] port-security mac-address security 1-1-2 vlan 1
Error: Security MAC address configuration failed.
Error:Can not operate security MAC address for current port mode is not autoLearn!
Analysis
No secure MAC address can be configured on a port operating in a port security mode other than autoLearn.
Solution
Cannot change port security mode when a user is online
Symptom
Port security mode cannot be changed when an 802.1X authenticated or MAC authenticated user is online.
[SwitchGigabitEthernet1/0/1] undo port-security port-mode
 Error:Cannot configure port-security for there is 802.1X user(s) on line on port GigabitEthernet1/0/1.
Analysis
Changing port security mode is not allowed when an 802.1X authenticated or MAC authenticated user is online.
Solution
Use the cut command to forcibly disconnect the user from the port before changing the port security mode.
[Switch] cut connection interface gigabitethernet 1/0/1
