H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
HomeSupportWirelessH3C WX3000 Series Unified SwitchesReference GuidesCommand ReferencesH3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
37-Routing Protocol Command
37-Routing Protocol Command 202.11 KB
Table of Contents
1 IP Routing Table Commands· 1-1
display ip routing-table· 1-1
display ip routing-table acl 1-3
display ip routing-table ip-address· 1-5
display ip routing-table ip-address1 ip-address2· 1-6
display ip routing-table protocol 1-7
display ip routing-table radix· 1-7
display ip routing-table statistics· 1-8
display ip routing-table verbose· 1-9
reset ip routing-table statistics protocol 1-10
2 Static Route Configuration Commands· 2-1
delete static-routes all 2-1
ip route-static· 2-1
3 RIP Configuration Commands· 3-1
checkzero· 3-1
default cost 3-1
display rip· 3-2
display rip interface· 3-3
display rip routing· 3-4
filter-policy export 3-5
filter-policy import 3-5
host-route· 3-6
import-route· 3-7
network· 3-7
peer 3-8
preference· 3-9
reset 3-9
rip· 3-10
rip authentication-mode· 3-10
rip input 3-11
rip metricin· 3-12
rip metricout 3-12
rip output 3-13
rip split-horizon· 3-14
rip version· 3-14
rip work· 3-15
summary· 3-16
timers· 3-16
4 IP Routing Policy Configuration Commands· 4-1
apply cost 4-1
display route-policy· 4-1
if-match acl 4-2
if-match cost 4-3
if-match interface· 4-3
if-match ip next-hop· 4-4
route-policy· 4-4
The term router in this chapter refers to a router in a generic sense or a WX3000 series device running a routing protocol.
display ip routing-table [ | { begin | exclude | include } regular-expression ]
View
regular-expression: Regular expression, a string of 1 to 256 case-sensitive characters used for specifying routing entries.
|: Uses the regular expression to match the output routing information.
begin: Displays the routing information from the route entry containing the specified character string.
include: Displays all routing information containing the specified character string.
exclude: Displays all routing information without the specified character string.
For details about regular expressions, refer to Configuration File Management in.H3C WX3000 Series Unified Switches Switching Engine Configuration Guide.
Use the display ip routing-table command to display the routing table summary.
This command displays the summary of the routing table. Each line represents one route, containing destination address/mask length, protocol, preference, cost, next hop, and output interface.
This command displays only the currently used routes, that is, the optimal routes.
# Display the summary of the current routing table.
<Sysname> display ip routing-table
Routing Table: public net
Destination/Mask   Protocol   Pre Cost    Nexthop     Interface
1.1.1.0/24         DIRECT     0   0       1.1.1.1     Vlan-interface1
1.1.1.1/32         DIRECT     0   0       127.0.0.1   InLoopBack0
2.2.2.0/24         DIRECT     0   0       2.2.2.1     Vlan-interface2
2.2.2.1/32         DIRECT     0   0       127.0.0.1   InLoopBack0
3.3.3.0/24         DIRECT     0   0       3.3.3.1     Vlan-interface3
3.3.3.1/32         DIRECT     0   0       127.0.0.1   InLoopBack0
4.4.4.0/24         DIRECT     0   0       4.4.4.1     Vlan-interface4
4.4.4.1/32         DIRECT     0   0       127.0.0.1   InLoopBack0
127.0.0.0/8        DIRECT     0   0       127.0.0.1   InLoopBack0
127.0.0.1/32       DIRECT    0   0       127.0.0.1   InLoopBack0
# Display the routing information from the entry containing the character string interface4 in the current routing table.
<Sysname> display ip routing-table | begin interface4
# Display the routing information containing the character string interface4 in the current routing table.
<Sysname> display ip routing-table | include interface4
# Display the routing information without the character string interface4 in the current routing table.
<Sysname> display ip routing-table | exclude interface4
Table 1-1 display ip routing-table command output description
Destination/Mask
Destination address/mask length
Protocol
Routing protocol
Pre
Route preference
Cost
Route cost
Nexthop
Next hop address
Output interface, through which the data packets destined for the destination network segment are sent
display ip routing-table acl acl-number [ verbose ]
View
acl-number: Basic access control list number, in the range of 2000 to 2999.
verbose: With this keyword specified, detailed information of routes in the active or inactive state that match the ACL is displayed. With this keyword not specified, brief information of only the routes in the active state that match the ACL is displayed.
Use the display ip routing-table acl command to display the information of routes that match the specified ACL.
# Display the information of ACL 2100.
<Sysname> display acl 2100
Basic ACL  2100, 1 rule
Acl's step is 1
rule 0 permit source 192.168.1.0 0.0.0.255
For details about the display acl command, refer to ACL Command.
# Display the information of routes that match ACL 2100.
<Sysname> display ip routing-table acl 2100
Routes matched by access-list 2100:
  Summary count: 2
192.168.1.0/24     DIRECT    0    0         192.168.1.2     Vlan-interface2
192.168.1.2/32     DIRECT    0    0         127.0.0.1       InLoopBack0
For descriptions of the above fields, refer to Table 1-1.
# Display the detailed information of routes that match ACL 2100.
<Sysname> display ip routing-table acl 2100 verbose
  + = Active Route, - = Last Active, # = Both    * = Next hop in use
  Summary count: 3
**Destination: 192.168.1.0       Mask: 255.255.255.0
         Protocol: #DIRECT       Preference: 0
         *NextHop: 192.168.1.2      Interface: 192.168.1.2(Vlan-interface2)
         State: <Int ActiveU Retain Unicast>
         Age: 21:34:13            Cost: 0/0
**Destination: 192.168.1.2       Mask: 255.255.255.255
         *NextHop: 127.0.0.1        Interface: 127.0.0.1(InLoopBack0)
         State: <NoAdvise Int ActiveU Retain Gateway Unicast>
Table 1-2 display ip routing-table command output description
Destination
Destination address
Mask
Subnet mask
Protocol
Protocol that discovers the route
Preference
Route preference
Nexthop
Next hop to the destination
Outbound interface through which data packets are forwarded to the destination network segment.
Description of route state:
ActiveU
An active unicast route, where “U” represents unicast.
Blackhole
A blackhole route is similar to a reject route, but no ICMP unreachable message is sent to the source.
Delete
A route is to be deleted.
Gateway
An indirect route.
Hidden
An existing route that is temporarily unavailable for some reason (for example, suppressed by a routing policy or down interface). However, deletion is not expected. It is therefore hidden so that it can recover later.
Holddown
Number of routes that are held down. Holddown is a route advertisement policy that some D-V based routing protocols (for example, RIP) use to avoid the spread of wrong routes but speed up the correct spread of ICMP unreachable messages. A certain route is advertised at intervals, no matter whether the currently discovered route to the same destination changes. For details, refer to the specific routing protocols.
Int
A route discovered by IGP.
NoAdvise
A routing protocol does not advertise any NoAdvise route when advertising routes in accordance with a routing policy.
NotInstall
A NotInstall route cannot be added to the core routing table, but may be advertised. A route with the highest priority is generally selected from the routing table, added to the core routing table, and then advertised.
Reject
The routes marked with reject do not guide the router to forward packets as a normal route does. The router discards the packets matching reject routes and sends an ICMP unreachable message to the source.
Reject routes are usually used for network tests.
Retain
The routes marked with retain will not be deleted when you delete routes in the core routing table. You can mark static routes with retain to make them stay in the core routing table.
Static
The routes marked with static will not be deleted from the routing table after you perform a save operation and restart the router. The routes manually configured on a router are marked with static.
Unicast
A unicast route.
Age
Lifetime of a route in the routing table, in the format of HH:MM:SS.
Cost
Cost of a route.
display ip routing-table ip-address [ mask | mask-length ] [ longer-match ] [ verbose ]
View
ip-address: Destination IP address, in dotted decimal notation.
mask: Subnet mask, in dotted decimal notation.
mask-length: Length of a subnet mask, in the range of 0 to 32.
longer-match: Specifies all the routes that lead to the destination address and match the specified mask. If you do not specify the mask argument, those that match the natural mask are specified.
verbose: Displays the detailed information of routes.
Use the display ip routing-table ip-address command to display the routing information of the specified destination address.
With different arguments provided, the command output is different. The following is the command output with different arguments provided:
l          display ip routing-table ip-address
If the destination address ip-address corresponds to a route in the natural mask range, this command displays the route that is the longest match of the destination address ip-address and is active.
l          display ip routing-table ip-address mask
This command only displays the routes exactly matching the specified destination address and mask.
l          display ip routing-table ip-address longer-match
This command displays all destination address routes matching the specified destination address in the natural mask range.
l          display ip routing-table ip-address mask longer-match
This command displays all destination address routes matching the specified destination address in the specified mask range.
# Display the brief information of routes with a natural mask.
<Sysname> display ip routing-table 169.0.0.0
169.0.0.0/16          Static  60  0       2.1.1.1     LoopBack1
For descriptions of the above fields, see Table 1-1.
# Display the detailed information of routes with a natural mask.
<Sysname> display ip routing-table 169.253.0.0 verbose
Routing Tables:
  Summary count:1
**Destination: 169.0.0.0       Mask: 255.0.0.0
         Protocol: #Static     Preference: -60
         *NextHop: 2.1.1.1        Interface: 2.1.1.1(LoopBack1)
         State: <Int ActiveU Static Unicast>
         Age: 3:47             Cost: 0/0
For descriptions of the above fields, see Table 1-2.
display ip routing-table ip-address1 { mask1 | mask-length1 } ip-address2 { mask2 | mask-length2 } [ verbose ]
View
ip-address1, ip-address2: Destination IP address in dotted decimal notation. ip-address1 {mask1 | mask-length1} and ip-address2 {mask2 | mask-length2} determine one address range together. ip-address1 ANDed with {mask1 | mask-length1} specifies the start of the range, while ip-address2 ANDed with {mask2 | mask-length2} specifies the end. This command displays the route in this address range.
mask1, mask2: Subnet mask, in dotted decimal notation.
mask-length1, mask-length2: Mask length, in the ranges of 0 to 32.
verbose: With the verbose argument provided, this command displays the verbose information of both active and inactive routes. Without this argument provided, this command displays the summary of active routes only.
Use the display ip routing-table ip-address1 ip-address2 command to display the route information in the specified destination address range.
# Display the routing information of destination addresses ranging from 1.1.1.0 to 2.2.2.0.
<Sysname>display ip routing-table 1.1.1.0 24 2.2.2.0 24
Routing tables:
  Summary count: 3
display ip routing-table protocol protocol [ inactive | verbose ]
View
protocol: You can provide one of the following values for this argument.
l          direct: Displays direct-connect route information
l          rip: Displays RIP route information.
l          static: Displays static route information.
inactive: With this argument provided, this command displays the inactive route information. Without this argument provided, this command displays both active and inactive route information.
verbose: With this keyword specified, detailed information of routes in the active or inactive state is displayed. With this keyword not specified, brief information of only the routes in the active state is displayed.
Use the display ip routing-table protocol command to display the route information of a specific protocol.
# Display the summary of all direct-connect routes.
<Sysname> display ip routing-table protocol direct
DIRECT Routing tables:
Summary count: 4
DIRECT Routing tables status:<active>:
Summary count: 3
20.1.1.1/32           DIRECT          0   0       127.0.0.1   InLoopBack0
DIRECT Routing tables status:<inactive>:
Summary count: 1
210.0.0.1/32          DIRECT      0       0       127.0.0.1   InLoopBack0
For detailed description of the output information, see Table 1-1.
View
None
Use the display ip routing-table radix command to display the route information in a tree structure.
<Sysname> display ip routing-table radix
Radix tree for INET (2) inodes 7 routes 5:
              +-32+--{210.0.0.1
          +--0+
           | | +--8+--{127.0.0.0
           | | | +-32+--{127.0.0.1
           | +--1+
           | +--8+--{20.0.0.0
           | +-32+--{20.1.1.1
Table 1-3 display ip routing-table radix command output description
INET
Address suite
Inodes
Number of nodes
Routes
Number of routes
View
None
Use the display ip routing-table statistics command to display the integrated routing information.
The integrated routing information includes the total number of routes, the number of active routes, the number of routes added by protocols, and the number of routes deleted.
# Display the integrated route information.
<Sysname> display ip routing-table statistics
Routing tables:
Proto      route       active      added       deleted
DIRECT     24          4           25          1
STATIC     4           1           4           0
RIP        0           0           0           0
Total      28          5           29          1
Table 1-4 display ip routing-table statistics command output description
Proto
Routing protocol type
Route
Total number of routes
Active
Number of active routes
Added
Number of routes added after the router is rebooted or the routing table is cleared last time.
Deleted
Number of routes deleted (Such routes will be freed in a period of time)
Total
Total number of the different kinds of routes
View
None
Use the display ip routing-table verbose command to display the detailed information of a routing table, including inactive routes and null routes. The information displayed includes route state descriptor, statistics of the routing table, and detailed information of each route.
# Display the verbose routing table information.
<Sysname> display ip routing-table verbose
Routing Tables:
  Destinations: 3       Routes: 3
  Holddown: 0    Delete: 62      Hidden: 0
**Destination: 1.1.1.0           Mask: 255.255.255.0
         *NextHop: 1.1.1.1        Interface: 1.1.1.1(Vlan-interface1)
         Age: 20:17:41          Cost: 0/0
**Destination: 1.1.1.1           Mask: 255.255.255.255
         Age: 20:17:42          Cost: 0/0
**Destination: 2.2.2.0           Mask: 255.255.255.0
         *NextHop: 2.2.2.1          Interface: 2.2.2.1(Vlan-interface2)
         Age: 20:08:05              Cost: 0/0
For descriptions of route states, see Table 1-2.
Table 1-5 lists the statistics of the routing table.
Table 1-5 display ip routing-table verbose command output description
Holddown
Number of suppressed routes
Delete
Number of deleted routes
Hidden
Number of hidden routes
reset ip routing-table statistics protocol { all | protocol }
View
all: Specifies all protocols.
protocol: Specifies a protocol, which can be direct, rip, or static.
Use the reset ip routing-table statistics protocol command to clear the statistics of routes in a routing table.
# Before executing the reset ip routing-table statistics protocol command, use the display ip routing-table statistics command to display the routing statistics:
Routing tables:
DIRECT     4           4           12          8
STATIC     0           0           0           0
RIP        0           0           0           0
Total      4           4           12          8
# Clear the routing statistics of all protocols from the IP routing table.
<Sysname> reset ip routing-table statistics protocol all
# Display the routing statistics in the IP routing table.
Routing tables:
DIRECT     4           4           0           0
STATIC     0           0           0           0
RIP        0           0           0           0
Total      4           4           0           0
The above information shows that the routing statistics in the IP routing table is cleared.
View
None
Use the delete static-routes all command to delete all static routes.
The system will request your confirmation before it deletes all the configured static routes.
Related commands: ip route-static, display ip routing-table.
# Delete all the static routes in the router.
System View: return to User View with Ctrl+Z
[Sysname] delete static-routes all
Are you sure to delete all the unicast static routes?[Y/N]y
ip route-static
ip route-static ip-address { mask | mask-length } { interface-type interface-number | next-hop } [ preference preference-value ] [ reject | blackhole ] [ detect-group group number ] [ description text ]
undo ip route-static ip-address { mask | mask-length } [ interface-type interface-number | next-hop ] [ preference preference-value ]
View
mask-length: Mask length, in the range of 0 to 32.
interface-type interface-number: Next-hop outbound interface.
next-hop: Next hop IP address of the route, in dotted decimal notation.
preference preference-value: Preference level of a static route, in the range of 1 to 255. The default preference is 60.
reject: Indicates the destination is unreachable. If a static route to a destination is marked with reject, all IP packets destined for this destination will be discarded, and the source host will be informed that the destination is unreachable.
blackhole: Indicates a blackhole route. If a static route to a destination is marked with blackhole, the outbound interface of this route is the Null 0 interface regardless of the next hop address, and all the IP packet addresses destined for this destination are dropped without the source host being notified.
description text: Provides a description for the current route, which is a string of 1 to 60 characters.
detect-group group number: Specifies a detect group number, which ranges from 1 to 25.
l          If you specify the next-hop outgoing interface when configuring a static route, the type of outgoing interface can be Null only.
l          The packets sent to a Null interface, which is a virtual interface, will be discarded immediately. This can decrease the system load.
l          For automatic detection information, refer to Auto Detect in.H3C WX3000 Series Unified Switches Switching Engine Configuration Guide.
Use the ip route-static command to configure a static route.
Use the undo ip route-static command to delete a static route.
By default, the system can obtain the subnet route directly connected to the router. When you configure a static route, if no preference is specified for the route, the preference defaults to 60, and if the route is not specified as reject or blackhole, the route will be reachable by default.
When configuring a static route, note the following points:
l          If the destination IP address and the mask are both 0.0.0.0, what you are configuring is a default route. All the packets that fail to find a routing entry will be forwarded through this default route.
l          You cannot configure an interface address of the local device as the next hop address of a static route.
l          You can configure a different preference to implement flexible route management policy.
Related commands: display ip routing-table.
# Configure the next hop of the default route as 129.102.0.2.
[Sysname] ip route-static 0.0.0.0 0.0.0.0 129.102.0.2
checkzero
checkzero
undo checkzero
View
RIP view
None
Use the checkzero command to enable the must be zero field check for RIP-1 packets.
Use the undo checkzero command to disable the must be zero field check for RIP-1 packets.
By default, RIP-1 performs the must be zero field check.
According to the protocol (RFC 1058) specifications, some fields in RIP-1 packets must be zero and these fields are called zero fields. You can use the checkzero command to enable/disable the must be zero field check for RIP-1 packets. When the must be zero field check is enabled, if the must be zero field in an incoming RIP-1 packet is non-zero, the packet will be rejected.
# Disable the must be zero field check for RIP-1 packets.
[Sysname] rip
[Sysname-rip] undo checkzero
default cost
default cost value
undo default cost
View
RIP view
value: Default cost, in the range of 1 to 16.
Use the default cost command to set the default cost for redistributed routes.
Use the undo default cost command to restore the default.
By default, the default cost of a redistributed route is 1.
If no cost is specified when you use the import-route command to redistribute routes from another routing protocol, the routes will be redistributed with the default cost specified with the default cost command.
Related commands: import-route.
# Redistribute static routes and set the default cost of the redistributed routes to 3.
[Sysname] rip
[Sysname-rip] import-route static
[Sysname-rip] default cost 3
display rip
display rip
View
None
Use the display rip command to display the current RIP operation state and RIP configuration.
# Display the current RIP operation state and configuration.
<Sysname> display rip
RIP is running
    Checkzero is on         Default cost : 1
    Summary is on           Preference : 100
    Traffic-share-across-interface is off
Period update timer : 30
    Timeout timer : 180
    Garbage-collection timer : 120
    No peer router
    Network :
    202.38.168.0
Table 3-1 display rip command output description
RIP is running
RIP is active.
Checkzero
State of the must be zero field check for RIP-1 packets
l      on: Enabled
l      off: Disabled
Default cost
Default cost for redistributed routes
Summary
State of the automatic route summarization function:
l      on: Enabled
l      off: Disabled
Preference
RIP preference
Period update timer
Length of the period update timer in seconds
Timeout timer
Length of the timeout timer in seconds
Length of the garbage-collection timer in seconds
No peer router
No destination address of a transmission is specified
Network
Network segment on which RIP is enabled
State of load sharing among interfaces:
l      on: Enabled
l      off: Disabled
View
None
Use the display rip interface command to display RIP interface information.
# Display RIP interface information.
<Sysname> display rip interface
                        RIP Interface: public net
Address  Interface          Ver  MetrIn/Out Input Output  Split-horizon
1.0.0.1  Vlan-interface100  2    0/1        on    on     on
Table 3-2 display rip interface command output description
Address
IP address of the interface running RIP (You need to use the network command to enable the network segment on which the address resides.)
Name of the interface running RIP. The IP address of the interface corresponds to that in the Address field.
Ver
Version of RIP running on the interface
MetrIn/Out
Additional metric added when a route is received/sent
Input
Indicates whether to allow the interface to receive RIP packets (on means yes; off means no).
Output
Indicates whether to allow the interface to send RIP packets (on means yes; off means no).
Split-horizon
Indicates whether split horizon is enabled (on means yes; off means no)
display rip routing
display rip routing
View
None
Use the display rip routing command to display RIP routing information.
# Display the information of the RIP routing table.
<Sysname> display rip routing
                     RIP routing table: public net
A = Active     I = Inactive     G = Garbage collection
C = Change     T = Trigger RIP
Destination/Mask    Cost  NextHop           Age    SourceGateway     Att
192.168.110.0/24    1     31.31.31.8        7s     31.31.31.8        A
200.1.1.0/24        1     31.31.31.8        7s     31.31.31.8        A
130.1.0.0/16        1     31.31.31.8        7s     31.31.31.8        A
Table 3-3 display rip routing command output description
Destination/Mask
Destination address/Mask
Cost
Cost
NextHop
Net hop address
Age
Time elapsed after the route is advertised
SourceGateway
Gateway originating the route
Att
Attributes of a route:
l      A: Active route
l      I: Inactive route
l      G: Working state of the garbage collection timer
l      C: Change state
l      T: Triggered RIP
filter-policy acl-number export [ protocol]
undo filter-policy  acl-number export [ protocol]
filter-policy route-policy route-policy-name export
undo filter-policy route-policy route-policy-name export
View
RIP view
acl-number: Number of the basic or advanced ACL used to filter routing information by destination address, in the range of 2000 to 3999.
route-policy-name: Name of the route-policy used to filter routing information, a string of 1 to 19 characters.
protocol: Filters routing protocol redistributed from the protocol. Currently, this argument can be direct or static.
Use the filter-policy export command to enable RIP to filter the outgoing routing information.
Use the undo filter-policy export command to disable RIP from filtering the outgoing routing information.
Note that, if protocol is specified, RIP filters only the outgoing routes redistributed from the specified routing protocol. Otherwise, RIP filters all routes to be advertised.
By default, RIP does not filter advertised routing information.
Related commands: acl, filter-policy import.
For details about ACL, refer to ACL in.H3C WX3000 Series Unified Switches Switching Engine Configuration Guide.
# Apply ACL 2000 to filter the outgoing routing information.
[Sysname] rip
[Sysname-rip] filter-policy 2000 export
filter-policy { acl-number| route-policy route-policy-name } import
undo filter-policy { acl-number  | route-policy route-policy-name } import
View
RIP view
acl-number: Number of the ACL used to filter routing information by destination address, in the range of 2000 to 3999.
Use the filter-policy import command to enable RIP to filter the incoming routing information.
Use the undo filter-policy import command to disable RIP from filtering the incoming routing information.
By default, RIP does not filter the received routing information.
Related commands: acl, filter-policy export.
For details about ACL, refer to ACL in.H3C WX3000 Series Unified Switches Switching Engine Configuration Guide..
# Apply ACL 2000 to filter the incoming routing information.
<Sysname>system-view
[Sysname] rip
[Sysname-rip] filter-policy 2000 import
host-route
host-route
undo host-route
View
RIP view
None
Use the host-route command to enable RIP to receive host routes.
Use the undo host-route command to disable RIP from receiving host routes.
By default, RIP is enabled to receive host routes.
In some special cases, RIP receives a great number of host routes from the same network segment. These routes are of little help to addressing but occupy a lot of resources. In this case, the undo host-route command can be used to disable RIP from receiving host routes to save network resources.
# Disable RIP from receiving host routes.
[Sysname] rip
[Sysname-rip] undo host-route
import-route
import-route protocol [process-id ] [ cost value | route-policy route-policy-name ]*
undo import-route protocol [ process-id ]
View
RIP view
protocol: Source routing protocol from which routes are redistributed by RIP. At present, RIP can redistribute routes from protocols: direct and static.
value: Cost for redistributed routes, in the range of 0 16. If no cost is specified when redistributing routes, the default cost defined by the default cost command will be used.
route-policy-name: Name of a routing policy, a string of 1 to 19 characters.
Use the import-route command to enable RIP to redistribute routes from other protocols.
Use the undo import-route command to disable RIP from redistributing routes from other protocols.
By default, RIP does not redistribute routes from other protocols.
If the value is not specified, routes will be redistributed with the default cost defined by the default cost command. If the cost of a redistributed route is 16, RIP does not stop advertising the route to other routers until the Garbage Collection timer expires (the timer length defaults to 120 seconds).
Related commands: default cost.
# Redistribute static routes with the cost of 4.
[Sysname] rip
[Sysname-rip] import-route static cost 4
# Set the default cost and redistribute OSPF routes with the default cost.
[Sysname] rip
[Sysname-rip] import-route ospf
network
network network-address
undo network network-address
View
RIP view
network-address: Network/IP address of an interface, in dotted decimal notation.
Use the network command to enable RIP on an interface attached to the specified network segment.
Use the undo network command to disable RIP on the interface attached to the specified network segment.
RIP runs only on the interface attached to the specified network. For an interface not on the specified network, RIP neither receives/sends routes on it nor forwards interface route through it. Therefore, you need to specify the network after enabling RIP to validate RIP on a specific interface.
By default, RIP is disabled on all interfaces.
The differences between the network and rip work commands are as follows:
l          The network command enables RIP on an interface attached to the specified network segment.
l          The rip work command enables an interface to receive and send RIP packets.
Related commands: rip work.
# Enable RIP on the interface with the network address 129.102.0.0.
[Sysname] rip
[Sysname-rip] network 129.102.0.0
peer
peer ip-address
undo peer ip-address
View
RIP view
ip-address: IP address of the interface receiving RIP packets in the unicast mode on the neighbor router, in dotted decimal notation.
Use the peer command to specify the IP address of a neighbor, where routing updates destined for the peer are unicast, rather than multicast or broadcast.
Use the undo peer command to remove the IP address of a neighbor.
By default, no neighbor is specified.
This command is used for non-broadcast networks where the broadcast mode is not suitable. Generally you are not recommended to use this command.
# Send RIP packets in the unicast mode to the destination 202.38.165.1.
[Sysname] rip
[Sysname-rip] peer 202.38.165.1
preference
preference value
undo preference
View
RIP view
value: Preference level, in the range of 1 to 255.
Use the preference command to configure the preference of RIP routes.
Use the undo preference command to restore the default.
By default, the preference of RIP routes is 100.
Every routing protocol has its own preference. Its default value is determined by the specific routing policy. The preferences of routing protocols will finally determine which routing algorithm's routes will be selected as the optimal routes in the IP routing table. You can use the preference command to modify the preference of RIP routes manually.
# Specify the RIP preference as 20.
[Sysname] rip
[Sysname-rip] preference 20
reset
reset
View
RIP view
None
Use the reset command to reset the system configuration parameters of RIP.
When you need to re-configure the parameters of RIP, you can use this command to restore the default.
# Reset the RIP system configuration.
[Sysname] rip
[Sysname-rip] reset
% Reset RIP's configuration and restart RIP? [Y/N]y
rip
rip
undo rip
View
None
Use the rip command to enable RIP or enter RIP view.
Use the undo rip command to disable RIP.
By default, the system does not run RIP.
You must enable RIP and enter RIP view before configuring RIP global parameters. You can, however, configure the interface-related parameters no matter whether RIP is enabled.
Note that the interface-related parameters configured previously would be invalid after RIP is disabled.
# Enable RIP and enter RIP view.
[Sysname] rip
[Sysname-rip]
rip authentication-mode { simple password | md5 { rfc2082 key-string key-id | rfc2453 key-string } }
undo rip authentication-mode
View
Interface view
simple: Specifies to use plain text authentication mode.
password: Plain text authentication key, containing 1 to 16 characters.
md5: Specifies to use MD5 cipher text authentication mode.
rfc2082: Specifies that MD5 cipher text authentication packets will use the packet format stipulated by RFC2082.
rfc2453: Specifies that MD5 cipher text authentication packets will use the packet format stipulated by RFC2453.
key-string: MD5 cipher text authentication key. If it is typed in the plain text mode, the length does not exceed 16 characters. If it is typed in the cipher text mode, the length is 24 characters. The system will display the MD5 cipher text authentication key with a length of 24 characters in the cipher text mode when you execute the display current-configuration command.
key-id: MD5 cipher text authentication identifier, ranging from 1 to 255.
Use the rip authentication-mode command to configure RIP-2 authentication mode and its parameters.
Use the undo rip authentication-mode command to remove authentication.
Only one authentication key is supported each time authentication is performed. An authentication key newly input overwrites an old one.
Related commands: rip version.
You can configure RIPv1 authentication mode in interface view, but the configuration will not take effect because RIPv1 does not support authentication.
# Specify the interface VLAN-interface 10 to use the simple authentication with the authentication key of aaa.
[Sysname] interface Vlan-interface 10
[Sysname-Vlan-interface10] rip authentication-mode simple aaa
# Specify VLAN-interface 10 to use the MD5 cipher text authentication, with the authentication key of aaa and the packet format of rfc2453.
[Sysname-Vlan-interface10] rip authentication-mode md5 rfc2453 aaa
rip input
rip input
undo rip input
View
Interface view
None
Use the rip input command to enable an interface to receive RIP packets.
Use the undo rip input command to disable an interface from receiving RIP packets.
By default, all interfaces, except loopback interfaces, can receive RIP packets.
# Disable the interface VLAN-interface 10 from receiving RIP packets.
[Sysname]interface Vlan-interface 10
[Sysname-Vlan-interface10] undo rip input
rip metricin
rip metricin value
undo rip metricin
View
Interface view
value: Additional metric of RIP routes received on an interface, in the range of 0 to 16.
Use the rip metricin command to configure an additional metric for RIP routes received on an interface.
Use the undo rip metricin command to restore the default.
By default, the additional metric of RIP routes received on an interface is 0.
Before a valid RIP route received on an interface is added to the routing table, the additional metric will be added to the route. Therefore, if you increase the additional metric, the metric of RIP routes received on the interface will increase accordingly. If the sum of the additional metric and the original metric is greater than 16, the metric of the route will be 16.
Related commands: rip metricout.
# Set the additional metric of RIP routes received on the interface VLAN-interface 10 to 2.
[Sysname-Vlan-interface10] rip metricin 2
rip metricout
rip metricout value
undo rip metricout
View
Interface view
value: Additional metric of RIP routes sent out of an interface, in the range of 1 to 16.
Use the rip metricout command to configure an additional metric for RIP routes sent out of an interface.
Use the undo rip metricout command to restore the default.
By default, the additional metric of RIP routes sent out of an interface is 1.
With the command configured on an interface, the metric of RIP routes sent on the interface will be increased.
Related commands: rip metricin.
# Set the additional metric of RIP routes sent out of the interface VLAN-interface 10 to 2.
[Sysname-Vlan-interface10] rip metricout 2
rip output
rip output
undo rip output
View
Interface view
None
Use the rip output command to enable an interface to transmit RIP packets.
Use the undo rip output command to disable an interface from transmitting RIP packets.
By default, all interfaces except loopback interfaces are enabled to transmit RIP packets.
Related commands: rip input, rip work.
# Disable the interface VLAN-interface 10 from transmitting RIP packets.
[Sysname-Vlan-interface10] undo rip output
rip split-horizon
rip split-horizon
undo rip split-horizon
View
Interface view
None
Use the rip split-horizon command to enable the split horizon function.
Use the undo rip split-horizon command to disable the split horizon function.
By default, the split horizon function is enabled.
The split horizon function disables an interface from sending routes received from the interface to prevent routing loops between adjacent routers. Therefore, normally, split horizon is necessary for avoiding routing loops. Only in some special cases the split horizon function needs to be disabled to ensure the correct execution of the protocol. So, disable the split horizon function only when necessary.
# Disable the split horizon function on the interface VLAN-interface 10.
[Sysname-Vlan-interface10] undo rip split-horizon
rip version
rip version { 1 | 2 [ broadcast | multicast ] }
undo rip version
View
Interface view
1: Specifies the version of RIP running on an interface as RIP-1.
2: Specifies the version of RIP running on an interface as RIP-2.
broadcast: Sends RIP-2 packets in the broadcast mode.
multicast: Sends RIP-2 packets in the multicast mode.
Use the rip version command to specify the version of RIP running on an interface.
Use the undo rip version command to restore the default.
By default, the version of RIP running on an interface is RIP-1 and RIP-1 packets are sent in the broadcast mode.
If RIP-2 runs on an interface, RIP packets are sent in the multicast mode by default, which reduces resource consumption.
Table 3-4 Receive mode of RIP packets
RIP version
RIP-1 broadcast packet
RIP-2 broadcast packet
RIP-2 multicast packet
RIP-1
RIP-2 broadcast mode
RIP-2 multicast mode
Table 3-5 Send mode of RIP packets
RIP version
RIP-1
# Run RIP-2 on the interface VLAN-interface 10 and send RIP packets in the broadcast mode.
[Sysname-Vlan-interface10] rip version 2 broadcast
rip work
rip work
undo rip work
View
Interface view
None
Use the rip work command to enable the interface to receive and send RIP packets.
Use the undo rip work command to disable the interface from neither receiving nor sending RIP packets.
By default, all interfaces except loopback interfaces are enabled to receive and send RIP packets.
The differences between the rip work, rip input, and rip output commands are as follows:
l          The rip work command controls the receiving and sending of RIP packets on an interface.
l          The rip input command controls only the receiving of RIP packets on an interface.
l          The rip output command controls only the sending of RIP packets on an interface.
Related commands: rip input, rip output.
# Disable the interface VLAN-interface 10 from receiving or sending RIP packets.
[Sysname-Vlan-interface10] undo rip work
summary
summary
undo summary
View
RIP view
None
Use the summary command to enable RIP-2 automatic route summarization.
Use the undo summary command to disable RIP-2 automatic route summarization.
By default, RIP-2 automatic route summarization is enabled.
Route summarization can be used to reduce the routing traffic on the network as well as to reduce the size of the routing table. The summary routes contain the natural masks when advertised.
If RIP-2 is used, route summarization can be disabled with the undo summary command when it is necessary to broadcast subnet routes.
RIP-1 always uses automatic route summarization, but the undo summary command is invalid for RIP-1.
# Set RIP version on the interface VLAN-interface 10 as RIP-2 and disable route summarization.
[Sysname-Vlan-interface10] quit
[Sysname] rip
[Sysname-rip] undo summary
timers
timers { update update-timer | timeout timeout-timer } *
undo timers { update | timeout } *
View
RIP view
update-timer: Length of the Period Update timer in seconds, in the range of 1 to 3600.
timeout-timer: Length of the Timeout timer in seconds, in the range of 1 to 3600.
Use the timers command to modify the lengths of the three RIP timers: Period Update, Timeout, and Garbage-collection (which is usually set to a length four times that of the Period Update timer).
Use the undo timers command to restore the default settings.
By default, the lengths of the Period Update, Timeout, and Garbage-collection timers are 30 seconds, 180 seconds, and 120 seconds, respectively.
Generally, it is regarded that the value of the Garbage-collection timer is fixed at four times that of the Period Update timer. Adjusting the Period Update timer will affect the Garbage-collection timer.
The modification of RIP timers is validated immediately.
As specified in RFC 1058, RIP is controlled by the above three timers:
l          The update timer defines the interval between routing updates.
l          The timeout timer defines the route aging time. If no routing update related to a route is received within the aging time, the metric of the route is set to 16 in the routing table.
l          The garbage-collect timer defines the interval from when the metric of a route becomes 16 to when it is deleted from the routing table. During the Garbage-Collect timer length, RIP advertises the route with the routing metric set to 16. If no routing update is announced for that route after the Garbage-Collect timer expires, the route will be deleted from the routing table.
Related commands: display rip.
# Set the values of the Period Update timer and the Timeout timer of RIP to 10 seconds and 30 seconds respectively.
[Sysname] rip
[Sysname-rip] timers update 10 timeout 30
apply cost
apply cost value
undo apply cost
View
Route policy view
value: Cost for matched routes, in the range of 0 to 4294967295.
Use the apply cost command to apply a cost to routes satisfying matching rules.
Use the undo apply cost command to remove the configuration.
By default, no cost is applied to routes satisfying matching rules.
The apply clause is one that sets a cost for the routes satisfying matching rules in a routing policy.
Related commands: if-match interface, if-match acl, if-match ip next-hop, if-match cost, if-match tag, route-policy.
# Create a routing policy named policy and node 1 with the matching mode being permit. Apply the cost 120 to routes matching ACL 2000.
[Sysname] route-policy policy permit node 1
  %New sequence of this list
[Sysname-route-policy] if-match acl 2000
[Sysname-route-policy] apply cost 120
display route-policy [ route-policy-name ]
View
route-policy-name: Name of a routing policy, a string of up to 19 characters.
Use the display route-policy command to display information about routing policies.
If you do not specify a route policy name, this command displays all route-policies configured.
Related commands: route-policy.
# Display information about routing policy named policy1.
<Sysname> display route-policy policy1
Route-policy : policy1
  Permit 10 : if-match acl 2000
              apply cost 100
Table 4-1 display route-policy command output description
Route-policy
Permit 10
Information about the routing policy with the matching mode configured as permit and the node as 10.
if-match acl 2000
Matching conditions
apply cost 100
Apply the cost 100 to the routes satisfying the matching conditions.
if-match acl
if-match acl acl-number
undo if-match acl
View
Route policy view
acl-number: Number of the ACL used for filtering, in the range of 2000 to 3999.
Use the if-match acl command to match routes permitted by an ACL or IP prefix list.
Use the undo if-match acl command to remove the configuration.
By default, the if-match clause is not configured.
Related commands: if-match interface, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply cost.
# Define an if-match clause to match routing information permitted by ACL 2000.
if-match cost
if-match cost value
undo if-match cost
View
Route policy view
value: Route cost, in the range of 0 to 4294967295.
Use the if-match cost command to configure a cost matching rule for routing information.
Use the undo if-match cost command to remove the configuration.
By default, no cost matching rule is defined.
Related commands: if-match interface, if-match acl, if-match ip next-hop, if-match tag, route-policy, apply cost.
# Define an if-match clause to match routes with the cost of 8.
[Sysname-route-policy] if-match cost 8
if-match interface
if-match interface interface-type interface-number
undo if-match interface
View
Route policy view
interface-type interface-number: Specifies the interface type and interface number.
Use the if-match interface command to match routes having the specified outgoing interface.
Use the undo if-match interface command to remove the match rule.
By default, no such a matching rule is configured.
This command matches routes having next hops pass through the specified interface.
Related commands: if-match acl, if-match ip next-hop, if-match cost, if-match tag, route-policy, apply cost.
# Define an if-match clause to match routes with the outbound interface VLAN-interface 1.
[Sysname-route-policy] if-match interface Vlan-interface 1
if-match ip next-hop acl acl-number
undo if-match ip next-hop
View
Route policy view
acl acl-number: Number of a basic ACL used for filtering, in the range of 2000 to 2999.
Use the if-match ip next-hop command to match routes with next hops specified in an ACL or IP prefix list.
Use the undo if-match ip next-hop command to remove the matching rule with an ACL.
By default, no next hop matching rule is defined.
Related commands: if-match interface, if-match acl, if-match cost, if-match tag, route-policy, apply cost.
# Define an if-match clause to match routes with next hops permitted by ACL 2000.
[Sysname-route-policy] if-match ip next-hop acl 2000
route-policy
route-policy route-policy-name { permit | deny } node node-number
undo route-policy route-policy-name [ permit | deny | node node-number ]
View
route-policy-name: Name of a routing policy, a string of 19 characters. This argument identifies a routing policy uniquely.
permit: Specifies the match mode of the defined routing policy node as permit. When a route entry meets all the if-match clauses of the node, the entry is permitted to filter through the node and the apply clause of the node will be performed. If a route entry does not meet the if-match clause of the node, the next node of the route-policy will be tested.
deny: Specifies the match mode of the defined Route-policy node as deny mode. When a route entry meets all the if-match clauses of the node, the entry is prohibited from filtering through the node and the next node will not be tested.
node: Specifies a node index in a routing policy.
node-number: Index of the node in a routing policy, in the range 0 to 1023. When this routing policy is used, the node with smaller node-number will be matched first.
Use the route-policy command to create a routing policy or enter the Route-policy view.
Use the undo route-policy command to delete the created Route-policy.
By default, no Route-policy is defined.
Route-policy is used for route information filter. A Route-policy comprises some nodes and each node comprises some if-match clauses and apply clauses.
An if-match clause defines the match rules of this node. An apply clause defines the actions after filtering through this node. The filtering relationship between the if-match clauses of the node is AND. That is, all if-match clauses of the node must be met.
The filtering relation between Route-policy nodes is OR. That is, filtering through one node means filtering through this Route-policy. If the information does not filter through any node, it cannot filter through this Route-policy.
Related commands: if-match interface, if-match acl, if-match ip next-hop, if-match cost, if-match tag, apply cost.
# Configure Route-policy policy1, with the node number of 10 and the match mode of permit, and enter Route policy view.
