H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
HomeSupportWirelessH3C WX3000 Series Unified SwitchesReference GuidesCommand ReferencesH3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
21-QoS-QoS Profile Command
21-QoS-QoS Profile Command 219.52 KB
Table of Contents
1 QoS Commands· 1-1
QoS Commands· 1-1
burst-mode enable· 1-1
display protocol-priority· 1-1
display qos cos-drop-precedence-map· 1-2
display qos cos-dscp-map· 1-2
display qos cos-local-precedence-map· 1-3
display qos dscp-cos-map· 1-3
display qos dscp-drop-precedence-map· 1-5
display qos dscp-dscp-map· 1-6
display qos dscp-local-precedence-map· 1-8
display qos-global 1-10
display qos-interface all 1-10
display qos-interface mirrored-to· 1-12
display qos-interface priority-trust 1-12
display qos-interface traffic-limit 1-13
display qos-interface traffic-priority· 1-14
display qos-interface traffic-redirect 1-15
display qos-interface traffic-remark-vlanid· 1-15
display qos-interface traffic-shape· 1-16
display qos-interface traffic-statistic· 1-17
display qos-port-group· 1-18
display qos-vlan· 1-19
display queue-scheduler 1-19
mirrored-to· 1-20
mirrored-to vlan· 1-21
monitor-port 1-22
priority· 1-22
priority-trust 1-23
protocol-priority protocol-type· 1-24
qos cos-drop-precedence-map· 1-25
qos cos-dscp-map· 1-27
qos cos-local-precedence-map· 1-28
qos dscp-cos-map· 1-29
qos dscp-drop-precedence-map· 1-31
qos dscp-dscp-map· 1-32
qos dscp-local-precedence-map· 1-33
queue-scheduler 1-35
reset traffic-limit 1-36
reset traffic-limit vlan· 1-37
reset traffic-statistic· 1-37
reset traffic-statistic vlan· 1-38
traffic-limit 1-38
traffic-limit vlan· 1-40
traffic-priority· 1-41
traffic-priority vlan· 1-42
traffic-redirect 1-42
traffic-redirect vlan· 1-43
traffic-remark-vlanid· 1-44
traffic-shape· 1-45
traffic-statistic· 1-45
traffic-statistic vlan· 1-46
2 QoS Profile Configuration Commands· 2-1
apply qos-profile· 2-1
display qos-profile· 2-1
packet-filter 2-2
qos-profile· 2-3
qos-profile port-based· 2-3
traffic-limit 2-4
traffic-priority· 2-5
QoS Commands
burst-mode enable
burst-mode enable
undo burst-mode enable
View
None
Use the burst-mode enable command to enable the burst function.
Use the undo burst-mode enable command to disable the burst function.
By default, the burst function is disabled.
# Enable the burst function on the current device.
<device> system-view
[device] burst-mode enable
View
None
Use the display protocol-priority command to display the priority of the protocol packets.
Related commands: protocol-priority.
# Display the priority of the protocol packet.
<device> display protocol-priority
Protocol: telnet
  DSCP: be(0)
View
None
Use the display qos cos-drop-precedence-map command to display the CoS-precedence-to-drop-precedence mapping table.
Related commands: qos cos-drop-precedence-map.
# Display the CoS-precedence-to-drop-precedence mapping table on the current device.
<device> display qos cos-drop-precedence-map
cos-drop-precedence-map:
              cos :       0     1     2     3     4     5     6     7
  drop-precedence :       0     0     0     0     0     0     0     0
View
None
Use the display qos cos-dscp-map command to display the CoS-precedence-to-DSCP-precedence mapping table.
Related commands: qos cos-dscp-map.
# Display the CoS-precedence-to-DSCP-precedence mapping table.
<device> display qos cos-dscp-map
cos-dscp-map:
            dscp :     16     0     8    24    32    40    48    56
View
None
Use the display qos cos-local-precedence-map command to display the CoS-precedence-to-local-precedence mapping table.
Related commands: qos cos-local-precedence-map.
# Display the CoS-precedence-to-local-precedence mapping table on the current device.
<device> display qos cos-local-precedence-map
 cos-local-precedence-map:
               cos(802.1p) :     0     1     2     3     4     5     6     7
   local precedence(queue) :     2     0     1     3     4     5     6     7
View
None
Use the display qos dscp-cos-map command to display the DSCP-precedence-to-CoS-precedence mapping table.
Related commands: qos dscp-cos-map.
# Display the DSCP-precedence-to-CoS-precedence mapping table.
<device> display qos dscp-cos-map
 dscp-cos-map:
             dscp :          cos
                0 :            1
                1 :            1
                2 :            1
                3 :            1
                4 :            1
                5 :            1
                6 :            1
                7 :            1
                8 :            2
                9 :            2
               10 :            2
               11 :            2
               12 :            2
               13 :            2
               14 :            2
               15 :            2
               16 :            0
               17 :            0
               18 :            0
               19 :            0
               20 :            0
               21 :            0
               22 :            0
               23 :            0
               24 :            3
               25 :            3
               26 :            3
               27 :            3
               28 :            3
               29 :            3
               30 :            3
               31 :            3
               32 :            4
               33 :            4
               34 :            4
               35 :            4
               36 :            4
               37 :            4
               38 :            4
               39 :            4
               40 :            5
               41 :            5
               42 :            5
               43 :            5
               44 :            5
               45 :            5
               46 :            5
               47 :            5
               48 :            6
               49 :            6
               50 :            6
               51 :            6
               52 :            6
               53 :            6
               54 :            6
               55 :            6
               56 :            7
               57 :            7
               58 :            7
               59 :            7
               60 :            7
               61 :            7
               62 :            7
               63 :            7
View
None
Use the display qos dscp-drop-precedence-map command to display the DSCP-precedence-to-drop-precedence mapping table.
Related commands: qos dscp-drop-precedence-map.
# Display the DSCP-precedence-to-drop-precedence mapping table on the current device.
<device> display qos dscp-drop-precedence-map
 dscp-drop-precedence-map:
             dscp : drop-precedence
                0 :            1
                1 :            1
                2 :            1
                3 :            1
                4 :            1
                5 :            1
                6 :            1
                7 :            1
                8 :            1
                9 :            1
               10 :            1
               11 :            1
               12 :            1
               13 :            1
               14 :            1
               15 :            1
               16 :            1
               17 :            1
               18 :            1
               19 :            1
               20 :            1
               21 :            1
               22 :            1
               23 :            1
               24 :            1
               25 :            1
               26 :            1
               27 :            1
               28 :            1
               29 :            1
               30 :            1
               31 :            1
               32 :            0
               33 :            0
               34 :            0
               35 :            0
               36 :            0
               37 :            0
               38 :            0
               39 :            0
               40 :            0
               41 :            0
               42 :            0
               43 :            0
               44 :            0
               45 :            0
               46 :            0
               47 :            0
               48 :            0
               49 :            0
               50 :            0
               51 :            0
               52 :            0
               53 :            0
               54 :            0
               55 :            0
               56 :            0
               57 :            0
               58 :            0
               59 :            0
               60 :            0
               61 :            0
               62 :            0
               63 :            0
View
None
Use the display qos dscp-dscp-map command to display the DSCP-precedence-to-DSCP-precedence mapping table.
Related commands: qos dscp-dscp-map.
# Display the DSCP-precedence-to-DSCP-precedence mapping table.
<device> display qos dscp-dscp-map
 dscp-dscp-map:
             dscp :         dscp
                0 :            0
                1 :            1
                2 :            2
                3 :            3
                4 :            4
                5 :            5
                6 :            6
                7 :            7
                8 :            8
                9 :            9
               10 :           10
               11 :           11
               12 :           12
               13 :           13
               14 :           14
               15 :           15
               16 :           16
               17 :           17
               18 :           18
               19 :           19
               20 :           20
               21 :           21
               22 :           22
               23 :           23
               24 :           24
               25 :           25
               26 :           26
               27 :           27
               28 :           28
               29 :           29
               30 :           30
               31 :           31
               32 :           32
               33 :           33
               34 :           34
               35 :           35
               36 :           36
               37 :           37
               38 :           38
               39 :           39
               40 :           40
               41 :           41
               42 :           42
               43 :           43
               44 :           44
               45 :           45
               46 :           46
               47 :           47
               48 :           48
               49 :           49
               50 :           50
               51 :           51
               52 :           52
               53 :           53
               54 :           54
               55 :           55
               56 :           56
               57 :           57
               58 :           58
               59 :           59
               60 :           60
               61 :           61
               62 :           62
               63 :           63
View
None
Use the display qos dscp-local-precedence-map command to display the DSCP-precedence-to-local-precedence mapping table.
Related commands: qos dscp-local-precedence-map.
# Display the DSCP-precedence-to-local-precedence mapping table on the current device.
<device> display qos dscp-local-precedence-map
 dscp-local-precedence-map:
             dscp : local-precedence(queue)
                0 :            0
                1 :            0
                2 :            0
                3 :            0
                4 :            0
                5 :            0
                6 :            0
                7 :            0
                8 :            1
                9 :            1
               10 :            1
               11 :            1
               12 :            1
               13 :            1
               14 :            1
               15 :            1
               16 :            2
               17 :            2
               18 :            2
               19 :            2
               20 :            2
               21 :            2
               22 :            2
               23 :            2
               24 :            3
               25 :            3
               26 :            3
               27 :            3
               28 :            3
               29 :            3
               30 :            3
               31 :            3
               32 :            4
               33 :            4
               34 :            4
               35 :            4
               36 :            4
               37 :            4
               38 :            4
               39 :            4
               40 :            5
               41 :            5
               42 :            5
               43 :            5
               44 :            5
               45 :            5
               46 :            5
               47 :            5
               48 :            6
               49 :            6
               50 :            6
               51 :            6
               52 :            6
               53 :            6
               54 :            6
               55 :            6
               56 :            7
               57 :            7
               58 :            7
               59 :            7
               60 :            7
               61 :            7
               62 :            7
               63 :            7
display qos-global
display qos-global { all | mirrored-to | traffic-limit | traffic-priority | traffic-redirect | traffic-statistic }
View
all: Displays all the QoS-related configuration.
traffic-limit: Displays the global traffic policing configuration.
traffic-priority: Displays the global priority marking configuration.
traffic-redirect: Displays the global traffic redirecting configuration.
traffic-statistics: Displays the global traffic accounting configuration.
Use the display qos-global command to display the QoS-related configuration performed for all the packets.
# Display all the QoS configurations performed for all the packets.
<device> display qos-global all
 global: traffic-limit inbound:
   Matches: Acl 3001 rule 0  running
     Target rate: 128 Kbps
     Exceed action: drop
   meter-statistic not running
display qos-interface { interface-type interface-number | unit-id } all
View
interface-type interface-number: Port type and port number.
unit-id: Unit ID, which is fixed to 1. With this argument specified, the QoS-related configuration of all the ports on the device is displayed.
Use the display qos-interface all command to display the QoS-related configuration of a port or all the ports on the device.
For a device, the following information is displayed in the following order depending on the configuration:
l          Traffic policing configurations
l          Priority marking configurations
l          Redirect configurations
l          Traffic accounting configurations
l          Traffic mirroring configurations
l          Priority trust mode configurations
l          Traffic shaping configurations
l          VLAN Mapping configurations
# Display the QoS-related configuration of GigabitEthernet 1/0/1.
<device> display qos-interface GigabitEthernet 1/0/1 all
GigabitEthernet1/0/1: traffic-limit
 Inbound:
   Matches: Acl 2000 rule 0  running
 GigabitEthernet1/0/1: priority-trust port
 GigabitEthernet1/0/1 Port Shaping: Disable
 0 kbps, 0 burst
 QID:    status    max-rate(kbps)   burst-size(byte)
  0 :   Disable           0                  0
  1 :   Disable           0                  0
  2 :   Disable           0                  0
  3 :   Disable           0                  0
  4 :   Disable           0                  0
  5 :   Disable           0                  0
  6 :   Disable           0                  0
  7 :   Disable           0                  0
display qos-interface { interface-type interface-number | unit-id } mirrored-to
View
unit-id: Unit ID, which is fixed to 1. With this argument specified, the traffic mirroring configuration of all the ports on the device is displayed.
Use the display qos-interface mirrored-to command to display the traffic mirroring configuration of a port or all the ports on the device.
Related commands: mirrored-to.
# Display the traffic mirroring configuration of GigabitEthernet 1/0/1.
<device> display qos-interface GigabitEthernet 1/0/1 mirrored-to
GigabitEthernet1/0/1: mirrored-to
 Inbound:
     Mirrored to: monitor interface
Table 1-1 display qos-interface mirrored-to command output description
Port with traffic mirroring configured
Inbound
Inbound direction. That is, traffic mirroring is performed to the inbound packets.
Matches
Match rule used for traffic classification
Mirrored to
Destination mirroring port
display qos-interface { interface-type interface-number | unit-id } priority-trust
View
unit-id: Unit ID, which is fixed to 1. With this argument specified, the priority trust mode configuration of all the ports on the device is displayed.
Use the display qos-interface priority-trust command to display the priority trust mode configuration of a port or all the ports on the device.
Related commands: priority-trust.
# Display the priority trust mode configuration of Gigabitethernet 1/0/1.
<device> display qos-interface Gigabitethernet 1/0/1 priority-trust
Table 1-2 display qos-interface priority-trust command output description
Port with priority trust mode configured
priority-trust port
Port priority is trusted.
l      priority-trust cos indicates that packet CoS precedence is trusted.
l      priority-trust dscp indicates that packet DSCP precedence is trusted.
display qos-interface { interface-type interface-number | unit-id } traffic-limit
View
unit-id: Unit ID, which is fixed to 1. With this argument specified, the traffic policing configuration of all the ports on the device is displayed.
Use the display qos-interface traffic-limit command to display the traffic policing configuration of a port or all the ports on the device. This command also displays the traffic policing statistics.
Related commands: traffic-limit.
# Display the traffic policing configuration and the corresponding statistics on GigabitEthernet 1/0/1.
<device> display qos-interface GigabitEthernet 1/0/1 traffic-limit
 Inbound:
   Matches: Acl 2001 rule 0  running
     Conform action: remark-cos video
     Exceed action: drop
   meter-statistic running
     62284 byte outprofile
     82521 byte inprofile
Table 1-3 display qos-interface traffic-limit command output description
Port with traffic policing configured
Inbound
Packet direction
Matches
ACL rules for traffic classifying
Target rate
Traffic policing target rate
Conform action
Action conducted to packet conforming to the traffic specification
Exceed action
Action conducted to packets exceeding the traffic specification
The function of collecting traffic policing statistics information is enabled (meter-statistic not running indicates that the function is not enabled)
Size of the packets exceeding the traffic specification (in bytes)
Size of the packets conforming to the traffic specification (in bytes)
display qos-interface { interface-type interface-number | unit-idtraffic-priority
View
unit-id: Unit ID, which is fixed to 1. With this argument specified, the priority marking configuration of all the ports on the device is displayed.
Use the display qos-interface traffic-priority command to display the priority marking configuration of a port or all the ports on the device.
Related commands: traffic-priority.
# Display the priority marking configuration of GigabitEthernet 1/0/1.
<device> display qos-interface GigabitEthernet 1/0/1 traffic-priority
GigabitEthernet1/0/1: traffic-priority
 Inbound:
     Priority action: cos controlled-load
Table 1-4 display qos-interface traffic-priority command output description
Port with priority marking configured
Inbound
Packet direction
Matches
Priority action
Priority marking action
l      cos indicates that the CoS precedence of packets is marked
l      dscp indicates that the DSCP precedence of packets is marked
display qos-interface { interface-type interface-number | unit-idtraffic-redirect
View
unit-id: Unit ID, which is fixed to 1. With this argument specified, the traffic redirecting configuration of all the ports on the device is displayed.
Use the display qos-interface traffic-redirect command to display the traffic redirecting configuration of a port or all the ports on the device.
Related commands: traffic-redirect.
# Display the traffic redirecting configuration of GigabitEthernet 1/0/1.
<device> display qos-interface GigabitEthernet 1/0/1 traffic-redirect
GigabitEthernet1/0/1: traffic-redirect
 Inbound:
     Redirected to: interface GigabitEthernet1/0/2
Table 1-5 display qos-interface traffic-redirect command output description
Port with traffic redirecting configured
Inbound
Packet direction
Matches
ACL rules for traffic classification
Redirected to
Destination port
display qos-interface { interface-type interface-number | unit-id } traffic-remark-vlanid
View
unit-id: Unit ID, which is fixed to 1. With this argument specified, the VLAN mapping configuration of all the ports on the device is displayed.
Use the display qos-interface traffic-remark-vlanid command to display the VLAN mapping configuration of a port or all the ports on the device.
Related commands: traffic-remark-vlanid.
# Display the VLAN mapping configuration of GigabitEthernet 1/0/1.
<device> display qos-interface GigabitEthernet 1/0/1 traffic-remark-vlanid
GigabitEthernet1/0/1: traffic-remark-vlanid
 Inbound:
     Remark vlan: 2
     Packet type: untagged-packet
Table 1-6 display qos-interface traffic-remark-vlanid command output description
Port with VLAN mapping configured
Inbound
Packet direction
Matches
Remark vlan
Destination VLAN ID of the VLAN mapping function
Packet type
Packet type after VLAN mapping is performed
display qos-interface { interface-type interface-number | unit-idtraffic-shape
View
unit-id: Unit ID, which is fixed to 1. With this argument specified, the traffic shaping configuration of all the ports is displayed.
Use the display qos-interface traffic-shape command to display the traffic shaping configuration of a port or all the ports on the device.
Related commands: traffic-shape.
# Display the traffic shaping configuration of GigabitEthernet 1/0/1.
<device> display qos-interface Gigabitethernet1/0/1 traffic-shape
 GigabitEthernet1/0/1 Port Shaping: Enable
 2000 kbps, 160 burst
  0 :   Disable           0                  0
  1 :   Disable           0                  0
  2 :   Disable           0                  0
  3 :   Disable           0                  0
  4 :   Disable           0                  0
  5 :   Disable           0                  0
  6 :   Disable           0                  0
  7 :   Disable           0                  0
Table 1-7 display qos-interface traffic-shape command output description
Port with traffic shaping configured
2000 kbps
Maximum traffic rate
160 burst
Burst size
QID
Queue ID
status
Traffic shaping status of a queue
max-rate(kbps)
Maximum traffic rate of a queue
burst-size(byte)
Burst size of a queue
display qos-interface { interface-type interface-number | unit-id } traffic-statistic
View
unit-id: Unit ID, which is fixed to 1. With this argument specified, the traffic accounting configuration of all the ports on the device is displayed.
Use the display qos-interface traffic-statistic command to display the traffic accounting configuration of a port or all the ports on the device. This command also displays traffic statistics.
Related commands: traffic-statistic.
# Display the traffic accounting configuration information and traffic statistics on GigabitEthernet 1/0/1.
<device> display qos-interface GigabitEthernet 1/0/1 traffic-statistic
GigabitEthernet1/0/1: traffic-statistic
 Inbound:
     8251 packet
Table 1-8 display qos-interface traffic-statistic command output description
Port with the traffic accounting function configured
Inbound
Packet direction
Matches
8251 packet
Statistics on matched packets
display qos-port-group [ group-id ] { all | mirrored-to | traffic-limit | traffic-priority | traffic-redirect | traffic-statistic }
View
group-id: Port group ID, in the range 1 to 100. If this argument is not specified, the QoS information of all the port groups is displayed.
all: Displays all the QoS-related configurations of a port group.
traffic-limit: Displays the traffic policing configuration of a port group.
traffic-priority: Displays the priority marking configuration of a port group.
traffic-redirect: Displays the traffic redirecting configuration of a port group.
traffic-statistics: Displays the traffic accounting configuration of a port group.
Use the display qos-port-group command to display specific QoS-related configuration of a port group.
# Display all the QoS-related configurations of port group 1.
<device> display qos-port-group 1 all
Port-group 1 traffic-limit
 Inbound:
     Exceed action: drop
display qos-vlan
display qos-vlan [ vlan-id ] { all | mirrored-to | traffic-limit | traffic-priority | traffic-redirect | traffic-statistic }
View
vlan-id: VLAN ID, in the range 1 to 4094. If this argument is not specified, the QoS configuration performed for all the VLANs is displayed.
all: Displays all the QoS-related configurations performed for packets of a VLAN.
traffic-limit: Displays the traffic policing configuration performed for packets of a VLAN.
traffic-priority: Displays the priority marking configuration performed for packets of a VLAN.
traffic-redirect: Displays the traffic redirecting configuration performed for packets of a VLAN.
traffic-statistics: Displays the traffic accounting configuration performed for packets of a VLAN.
Use the display qos-vlan command to display the QoS-related configuration performed for a VLAN.
# Display all the QoS-related configuration performed for VLAN 1.
<device> display qos-vlan 1 all
Vlan 1 traffic-limit
 Inbound:
     Exceed action: drop
View
None
Use the display queue-scheduler command to display the queue scheduling mode and corresponding configuration.
Related commands: queue-scheduler.
# Display the queue scheduling mode and corresponding configuration.
<device> display queue-scheduler
QID:   scheduling-group     weight
  0 :   sp                      0
  1 :   sp                      0
  2 :   sp                      0
  3 :   sp                      0
  4 :   sp                      0
  5 :   sp                      0
  6 :   sp                      0
  7 :   sp                      0
mirrored-to
mirrored-to inbound acl-rule monitor-interface
undo mirrored-to inbound acl-rule
View
System view, Port group, Ethernet port view
inbound: Duplicates inbound packets.
acl-rule: ACL rules to be applied. This argument can be the combination of multiple ACLs. For more information about this argument, refer to Table 1-9 and Table 1-10. Note that the ACL rules referenced must be those defined with the permit keyword specified.
Table 1-9 Ways of applying combined ACL rules
ACL combination
Form of the acl-rule argument
Apply a basic or advanced Layer 3 ACL
ip-group  acl-number
Apply a rule in an Layer 3 ACL
ip-group acl-number rule rule-id
Apply all the rules in a Layer 2 ACL
link-group acl-number
Apply a rule in a Layer 2 ACL
link-group acl-number rule rule-id
Apply a rule in an Layer 3 ACL and a rule in a Layer 2 ACL
ip-group acl-number rule rule-id link-group acl-number rule rule-id
Table 1-10 Description on the parameters used in Table 1-9
ip-group acl-number
Specifies the number of a basic or advanced ACL, in the range 2000 to 3999.
Specifies the number of a Layer 2 ACL, in the range 4000 to 4999.
rule-id
ACL rule number, in the range 0 to 65534. If this argument is not provided, all the rules in the ACL are specified.
monitor-interface: Duplicates the packets to the destination mirroring port.
Use the mirrored-to command to reference ACLs globally or to a port group or a port for identifying traffics and perform traffic mirroring for packets that match.
Use the undo mirrored-to command to remove traffic mirroring configuration globally or for a port group or a port.
Related commands: display qos-interface mirrored-to.
# Mirror packets that match ACL 2000 on port GigabitEthernet 1/0/1 to GigabitEthernet 1/0/4 through traffic mirroring.
[device] interface GigabitEthernet 1/0/4
[device- GigabitEthernet1/0/4] monitor-port
[device- GigabitEthernet1/0/4] quit
[device] interface GigabitEthernet 1/0/1
[device-GigabitEthernet1/0/1] mirrored-to inbound ip-group 2000 monitor-interface
mirrored-to vlan
mirrored-to vlan vlan-id inbound acl-rule monitor-interface
View
vlan-id: VLAN ID, in the range of 1 to 4,094.
inbound: Mirrors the inbound packets.
Use the mirrored-to vlan command to reference ACLs to a VLAN for identifying traffics and perform traffic mirroring for packets that match.
Use the undo mirrored-to vlan command to remove traffic mirroring configuration for a VLAN.
# Mirror packets that match ACL 2000 on VLAN 1 to GigabitEthernet 1/0/2 through traffic mirroring.
[device] interface GigabitEthernet1/0/2
[device-GigabitEthernet1/0/2] monitor-port
[device-GigabitEthernet1/0/2] quit
[device] mirrored-to vlan 1 inbound ip-group 2000 monitor-interface
monitor-port
monitor-port
undo monitor-port
View
Ethernet port view
None
Use the monitor-port command to configure a port as a destination mirroring port.
Use the undo monitor-port command to cancel the configuration.
Note that the member ports of an aggregation link group, LACP-enabled ports, and STP-enabled ports cannot operate as destination mirroring ports.
When you configure mirroring destination port on an Ethernet port, if local mirroring group 1 does not exist, the device creates the group and adds the port to the group; if local mirroring group 1 already exists, but is not a local mirroring group, your configuration of the destination port will fail.
# Configure GigabitEthernet1/0/4 as the destination port.
[device-GigabitEthernet1/0/4] monitor-port
priority
priority priority-level
undo priority
View
Ethernet port view
priority-level: Port priority, ranging from 0 to 7.
Use the priority command to configure the priority of an Ethernet port.
Use the undo priority command to restore the default port priority.
By default, the priority of an Ethernet port is 0.
With the priority command configured on a port, the device uses the configured port priority of the receiving port as the 802.1p precedence of the packet and then looks up the CoS-precedence-to-other-precedence mapping table for the corresponding precedence.
# Set the priority of GigabitEthernet 1/0/1 to 6.
[device-GigabitEthernet1/0/1] priority 6
priority-trust
priority-trust { cos [ automap ] | dscp [ automap | remap ] }
undo priority-trust
View
Ethernet port view
cos [ automap ]: The mapping is performed based on 802.1p precedence and the mapping modes are as follows:
l          If automap is not input, it is the default mode in which the device does not replace the priority carried in the packet with the mapped priority.
l          If automap is input, it is the automap mode in which the device replaces the priority carried in the packet with the mapped priority.
dscp [ automap | remap]: The mapping is performed based on DSCP precedence, and the mapping modes are as follows:
l          If keywords are not input after DSCP, it is the default mode in which the device does not replace the priority carried in the packet with the mapped priority.
l          If remap is input, it is the remap mode. In this mode, the device firstly gets new DSCP precedence by the DSCP-precedence-to-DSCP-precedence mapping relationship, and then searches DSCP-precedence-to-other precedence mapping relationship through the new DSCP precedence, and replaces the precedence carried in the packet with the mapped precedence.
Use the priority-trust command to configure the precedence mapping mode on the port of the device.
Use the undo priority-trust command to restore its default value.
The device trusts the port priority by default.
Related commands: display qos-interface priority-trust.
# Configure to trust packet 802.1p precedence on GigabitEthernet 1/0/1 and adopt the default priority mapping table for priority mapping.
[device-GigabitEthernet1/0/1] priority-trust cos
protocol-priority protocol-type protocol-type { ip-precedence ip-precedence | dscp dscp-value }
undo protocol-priority protocol-type protocol-type
View
protocol-type protocol-type: Specifies the protocol type, which could be Telnet, SNMP, or ICMP.
ip-precedence ip-precedence: Specifies the IP precedence, in the range 0 to 7. You can also enter the keywords listed in Table 1-11 as the IP precedence.
Table 1-11 IP precedence keywords and the corresponding decimal/binary values
Keyword
IP precedence value (decimal)
IP precedence value (binary)
routine
0
000
priority
1
001
immediate
2
010
flash
3
011
flash-override
4
100
critical
5
101
internet
6
110
network
7
111
dscp dscp-value: Specifies the DSCP precedence, in the range of 0 to 63. You can also enter a keyword listed in Table 1-12 as the DSCP precedence.
Table 1-12 DSCP precedence keywords and the corresponding decimal/binary values
Keyword
DSCP value (decimal)
DSCP value (binary)
af11
10
001010
af12
12
001100
af13
14
001110
af21
18
010010
af22
20
010100
af23
22
010110
af31
26
011010
af32
28
011100
af33
30
011110
af41
34
100010
af42
36
100100
af43
38
100110
be (the default)
0
000000
cs1
8
001000
cs2
16
010000
cs3
24
011000
cs4
32
100000
cs5
40
101000
cs6
48
110000
cs7
56
111000
ef
46
101110
Use the protocol-priority command to set the global IP precedence or DSCP precedence for packets of a specific protocol type.
Use the undo protocol-priority command to cancel the global IP precedence or DSCP precedence set for packets of a specific protocol type.
Related commands: display protocol-priority.
# Set the IP precedence to 3 for SNMP protocol packets.
[device] protocol-priority protocol-type snmp ip-precedence 3
qos cos-drop-precedence-map cos0-map-drop-prec cos1-map-drop-prec cos2-map-drop-prec cos3-map-drop-prec cos4-map-drop-prec cos5-map-drop-prec cos6-map-drop-prec cos7-map-drop-prec
undo qos cos-drop-precedence-map
View
cos0-map-drop-prec: Drop precedence to which CoS 0 is to be mapped, in the range 0 to 1.
cos1-map-drop-prec: Drop precedence to which CoS 1 is to be mapped, in the range 0 to 1.
cos2-map-drop-prec: Drop precedence to which CoS 2 is to be mapped, in the range 0 to 1.
cos3-map-drop-prec: Drop precedence to which CoS 3 is to be mapped, in the range 0 to 1.
cos4-map-drop-prec: Drop precedence to which CoS 4 is to be mapped, in the range 0 to 1.
cos5-map-drop-prec: Drop precedence to which CoS 5 is to be mapped, in the range 0 to 1.
cos6-map-drop-prec: Drop precedence to which CoS 6 is to be mapped, in the range 0 to 1.
cos7-map-drop-prec: Drop precedence to which CoS 7 is to be mapped, in the range 0 to 1.
Use the qos cos-drop-precedence-map command to modify the CoS-precedence-to-drop-precedence mapping table.
Use the undo qos cos-drop-precedence-map command to restore the default CoS-precedence-to-drop-precedence mapping table.
Table 1-13 shows the default CoS-precedence-to-drop-precedence mapping table.
Table 1-13 The default CoS-precedence-to-drop-precedence mapping relationship
CoS value
Drop precedence
0
0
1
0
2
0
3
0
4
0
5
0
6
0
7
0
Related commands: display qos cos-drop-precedence-map.
# Modify the CoS-precedence-to-drop-precedence mapping table according to Table 1-14.
Table 1-14 A CoS-precedence-to-drop-precedence mapping table
CoS value
Drop precedence
0
1
1
1
2
1
3
1
4
1
5
0
6
0
7
0
The configuration procedure is as follows:
[device] qos cos-drop-precedence-map 1 1 1 1 1 0 0 0
qos cos-dscp-map
qos cos-dscp-map cos0-map-dscp cos1-map-dscp cos2-map-dscp cos3-map-dscp cos4-map-dscp cos5-map-dscp cos6-map-dscp cos7-map-dscp
undo qos cos- dscp-map
View
cos0-map-dscp: DSCP precedence to which CoS 0 is to be mapped, in the range 0 to 63.
cos1-map-dscp: DSCP precedence to which CoS 1 is to be mapped, in the range 0 to 63.
cos2-map-dscp: DSCP precedence to which CoS 2 is to be mapped, in the range 0 to 63.
cos3-map-dscp: DSCP precedence to which CoS 3 is to be mapped, in the range 0 to 63.
cos4-map-dscp: DSCP precedence to which CoS 4 is to be mapped, in the range 0 to 63.
cos5-map-dscp: DSCP precedence to which CoS 5 is to be mapped, in the range 0 to 63.
cos6-map-dscp: DSCP precedence to which CoS 6 is to be mapped, in the range 0 to 63.
cos7-map-dscp: DSCP precedence to which CoS 7 is to be mapped, in the range 0 to 63.
Use the qos cos-dscp-map command to modify the CoS-precedence-to-DSCP-precedence mapping table.
Use the undo qos cos-dscp-map command to restore the default CoS-precedence-to-DSCP-precedence mapping table.
Table 1-15 shows the default CoS-precedence-to-DSCP-precedence mapping table.
Table 1-15 The default CoS-precedence-to-DSCP-precedence mapping table
CoS value
DSCP
0
16
1
0
2
8
3
24
4
32
5
40
6
48
7
56
Related commands: display qos cos-dscp-map.
# Modify the CoS-precedence-to-DSCP-precedence mapping table according to Table 1-16.
Table 1-16 A CoS-precedence-to-DSCP-precedence mapping table
CoS value
DSCP
0
0
1
1
2
2
3
3
4
4
5
5
6
6
7
7
[device] qos cos-dscp-map 0 1 2 3 4 5 6 7
qos cos-local-precedence-map cos0-map-local-prec cos1-map-local-prec cos2-map-local-prec cos3-map-local-prec cos4-map-local-prec cos5-map-local-prec cos6-map-local-prec cos7-map-local-prec
undo qos cos-local-precedence-map
View
cos0-map-local-prec: Local precedence to which CoS 0 is to be mapped, in the range 0 to 7.
cos1-map-local-prec: Local precedence to which CoS 1 is to be mapped, in the range 0 to 7.
cos2-map-local-prec: Local precedence to which CoS 2 is to be mapped, in the range 0 to 7.
cos3-map-local-prec: Local precedence to which CoS 3 is to be mapped, in the range 0 to 7.
cos4-map-local-prec: Local precedence to which CoS 4 is to be mapped, in the range 0 to 7.
cos5-map-local-prec: Local precedence to which CoS 5 is to be mapped, in the range 0 to 7.
cos6-map-local-prec: Local precedence to which CoS 6 is to be mapped, in the range 0 to 7.
cos7-map-local-prec: Local precedence to which CoS 7 is to be mapped, in the range 0 to 7.
Use the qos cos-local-precedence-map command to modify the CoS-precedence-to-local-precedence mapping table.
Use the undo qos cos-local-precedence-map command to restore the default CoS-precedence-to-local-precedence mapping table.
A port on a device can accommodate up to eight output queues. Table 1-17 shows the default CoS-precedence-to-local-precedence mapping table.
Table 1-17 The default CoS-precedence-to-local-precedence mapping table on the device
CoS value
Local precedence
0
2
1
0
2
1
3
3
4
4
5
5
6
6
7
7
Related commands: display qos cos-local-precedence-map.
# Modify the CoS-precedence-to-local-precedence mapping table on the device according to Table 1-18.
Table 1-18 A CoS-precedence-to-local-precedence mapping table
CoS value
Local precedence
0
0
1
1
2
2
3
3
4
4
5
5
6
6
7
7
[device] qos cos-local-precedence-map 0 1 2 3 4 5 6 7
qos dscp-cos-map
qos dscp-cos-map dscp-list : cos-value
undo qos dscp-cos-map [ dscp-list ]
View
dscp-list: List of DSCP values. It can include only one DSCP value or many DSCP values. DSCP values are separated by space. dscp-list is connected with cos-value by the “:” after it to indicate the mapping relationship between them. The range of dscp-list is from 0 to 63.
cos-value: 802.1p precedence, in the range of 0 to 7.
Use the qos dscp-cos-map command to modify the DSCP-precedence-to-CoS-precedence mapping table.
Use the undo qos dscp-cos-map command to restore the default DSCP-precedence-to-CoS-precedence mapping table.
Table 1-19 shows the default DSCP-precedence-to-CoS-precedence mapping table.
Table 1-19 The default DSCP-precedence-to-CoS-precedence mapping table
DSCP
CoS value
0 to 7
1
8 to 15
2
16 to 23
0
24 to 31
3
32 to 39
4
40 to 47
5
48 to 55
6
56 to 63
7
Related commands: display qos dscp-cos-map.
# Modify the DSCP-precedence-to-CoS-precedence mapping table according to Table 1-20.
Table 1-20 A DSCP-precedence-to-CoS-precedence mapping relationship
DSCP
CoS value
0 to 7
0
8 to 15
1
16 to 23
2
24 to 31
3
32 to 39
4
40 to 47
5
48 to 55
6
56 to 63
7
[device] qos dscp-cos-map 0 1 2 3 4 5 6 7 : 0
[device] qos dscp-cos-map 8 9 10 11 12 13 14 15 : 1
[device] qos dscp-cos-map 16 17 18 19 20 21 22 23 : 2
[device] qos dscp-cos-map 24 25 26 27 28 29 30 31 : 3
[device] qos dscp-cos-map 32 33 34 35 36 37 38 39 : 4
[device] qos dscp-cos-map 40 41 42 43 44 45 46 47 : 5
[device] qos dscp-cos-map 48 49 50 51 52 53 54 55 : 6
[device] qos dscp-cos-map 56 57 58 59 60 61 62 63 : 7
qos dscp-drop-precedence-map dscp-list : drop-precedence
undo qos dscp-drop-precedence-map [dscp-list ]
View
drop-precedence: Drop precedence. The range of drop-precedence is from 0 to 1.
Use the qos dscp-drop-precedence-map command to modify the DSCP-precedence-to-drop-precedence mapping table.
Use the undo qos dscp-drop-precedence-map command to restore the default DSCP-precedence-to-drop-precedence mapping table.
Table 1-21 shows the default DSCP-precedence-to-drop-precedence mapping table.
Table 1-21 The default DSCP-precedence-to-drop-precedence mapping table
DSCP
Drop precedence
0 to 7
1
8 to 15
1
16 to 23
1
24 to 31
1
32 to 39
0
40 to 47
0
48 to 55
0
56 to 63
0
Related commands: display qos dscp-drop-precedence-map.
# Modify the DSCP-precedence-to-drop-precedence mapping table according to Table 1-22.
Table 1-22 A DSCP-precedence-to-drop-precedence mapping table
DSCP
Drop precedence
0 to 7
0
8 to 15
1
16 to 23
1
24 to 31
1
32 to 39
0
40 to 47
0
48 to 55
0
56 to 63
0
[device] qos dscp-drop-precedence-map 0 1 2 3 4 5 6 7 : 0
qos dscp-dscp-map
qos dscp-dscp-map dscp-list : dscp-value
undo qos dscp-dscp-map [dscp-list ]
View
dscp-list: List of DSCP values. It can include only one DSCP value or many DSCP values. DSCP values are separated by space. dscp-list is connected with dscp-value by the “:” after it to indicate the mapping relationship between them. The range of dscp-list is from 0 to 63.
dscp-value: DSCP precedence. The range of dscp-value is from 0 to 63.
Use the qos dscp-dscp-map command to modify the DSCP-precedence-to-DSCP-precedence mapping table.
Use the undo qos dscp-dscp-map command to restore the default DSCP-precedence-to-DSCP-precedence mapping table.
Table 1-23 shows the default DSCP-precedence-to-DSCP-precedence mapping table.
Table 1-23 The default DSCP-precedence-to-DSCP-precedence mapping table
DSCP
Target DSCP
0
0
1
1
2
2
61
61
62
62
63
63
Related commands: display qos dscp-dscp-map.
# Modify the DSCP-precedence-to-DSCP-precedence mapping table according to Table 1-24.
Table 1-24 A DSCP-precedence-to-DSCP-precedence mapping table
DSCP
Target DSCP
0
1
1
1
2
1
3
1
4
1
5
1
6
1
7
1
8
8
9
9
10
10
61
61
62
62
63
63
[device] qos dscp-dscp-map 0 1 2 3 4 5 6 7 : 1
qos dscp-local-precedence-map dscp-list : local-precedence
undo qos dscp-local-precedence-map [dscp-list ]
View
dscp-list: List of DSCP values. It can include only one DSCP value or many DSCP values. DSCP values are separated by space. dscp-list is connected with local-precedence by the “:” after it to indicate the mapping relationship between them. The range of dscp-list is from 0 to 63.
local-precedence: Local precedence. This argument is in the range of 0 to 7.
Use the qos dscp-local-precedence-map command to modify the DSCP-precedence-to-local-precedence mapping table.
Use the undo qos dscp-local-precedence-map command to restore the default DSCP-precedence-to-local-precedence mapping table.
A port of a device can accommodate up to eight output queues. Table 1-25 shows the default DSCP-precedence-to-local-precedence mapping tables on a device.
Table 1-25 The default DSCP-precedence-to-local-precedence mapping table
DSCP
Local precedence
0 to 7
0
8 to 15
1
16 to 23
2
24 to 31
3
32 to 39
4
40 to 47
5
48 to 55
6
56 to 63
7
Related commands: display qos dscp-local-precedence-map.
# Modify the DSCP-precedence-to-local-precedence mapping table according to Table 1-26.
Table 1-26 A DSCP-precedence-to-local-precedence mapping table
DSCP
Local precedence
0 to 7
1
8 to 15
1
16 to 23
2
24 to 31
3
32 to 39
4
40 to 47
5
48 to 55
6
56 to 63
7
[device] qos dscp-local-precedence-map 0 1 2 3 4 5 6 7 : 1
queue-scheduler
queue-scheduler wrr { group1 { queue-id queue-weight } &<1-8> | group2 { queue-id queue-weight } &<1-8> }*
undo queue-scheduler [ queue-id ] &<1-8>
View
wrr: Specifies the shaped deficit weighted round robin (SDWRR) queue scheduling algorithm.
group1: Specifies WRR scheduling group 1.
group2: Specifies WRR scheduling group 2.
queue-id: Queue ID, in the range 0 to 7.
queue-weight: Weight assigned to a queue, in the range 1 to 255.
&<1-8>: Indicates that the queue-id argument and the queue-weight argument can be entered for up to eight times.
Use the queue-scheduler command to configure a queue scheduling algorithm and the related parameters for specific queues.
Use the undo queue-scheduler command to restore the default.
By default, the SP queue scheduling algorithm is adopted.
A port on a device can accommodate up to eight output queues. You can configure to use SP queue scheduling algorithm, SDWRR queue scheduling algorithm, or both of the two algorithms as required for queue scheduling.
l          With SDWRR queue scheduling algorithm adopted, the output queues of a port can be assigned to group 1 and group 2. The two groups are scheduled using SP algorithm. For example, you can assign queue 0, queue 1, queue 2, and queue 3 to group 1, and assign queue 4, queue 5, queue 6, and queue 7 to group 2. The queues in group 2 are scheduled preferentially using WRR queue scheduling algorithm. Queues in group 1 are scheduled using WRR queue scheduling algorithm only when all the queues in group 2 are empty.
l          With both SP and SDWRR queue scheduling algorithms adopted, groups are scheduled using SP algorithm. Assume that queue 0 and queue 1 are scheduled using SP algorithm; queue 2, queue 3, and queue 4 are assigned to group 1; and queue 5, queue 6, and queue 7 are assigned to group 2. The queues in group 2 are scheduled preferentially using WRR queue scheduling algorithm. When all the queues in group 2 are empty, queues in group 1 are scheduled using WRR queue scheduling algorithm. Then, queue 1 is scheduled, and then queue 0.
When using SDWRR or SP-SDWRR combination for queue scheduling, you are recommended to assign queues with successive queue numbers to the same scheduling group.
Related commands: display queue-scheduler.
# Adopt both SP and SDWRR for queue scheduling, assigning queue 3, queue 4, and queue 5 to WRR scheduling group 1, with the weigh of 20, 20 and 30; assigning queue 0, queue 1, and queue 2 to WRR scheduling group 2, with the weight 20, 20, and 40; and scheduling queue 6 and queue 7 using the SP algorithm.
[device] queue-scheduler wrr group1 3 20 4 20 5 30 group2 0 20 1 20 2 40
[device] display queue-scheduler
  0 :   wrr , group2           20
  1 :   wrr , group2           20
  2 :   wrr , group2           40
  3 :   wrr , group1           20
  4 :   wrr , group1           20
  5 :   wrr , group1           30
  6 :   sp                      0
  7 :   sp                      0
reset traffic-limit
reset traffic-limit inbound acl-rule
View
System view, Ethernet port view, Port group view
inbound: Specifies to clear the statistics about the inbound packets.
Use the reset traffic-limit command to clear the traffic policing statistics about all the packets matching specific ACL rules, or packets that match specific ACL rules and are of a port group or pass a port.
# Clear the traffic policing statistics about packets matching ACL 2000 and passing GigabitEthernet 1/0/1.
[device] interface GigabitEthernet1/0/1
[device-GigabitEthernet1/0/1] reset traffic-limit inbound ip-group 2000
reset traffic-limit vlan vlan-id inbound acl-rule
View
Use the reset traffic-limit vlan command to clear the statistics about packets of a VLAN.
Related commands: traffic-limit vlan.
# Clear the statistics about packets that match ACL 2000 and are of VLAN 1.
[device] reset traffic-limit vlan 1 inbound ip-group 2000
reset traffic-statistic inbound acl-rule
View
Use the reset traffic-statistics command to clear the statistics about all the packets matching specific ACL rules, or the packets that match specific ACL rules and are of a port group or pass a port.
# Clear the statistics about packets matching ACL 2000 and passing GigabitEthernet 1/0/1.
[device-GigabitEthernet1/0/1] reset traffic-statistic inbound ip-group 2000
reset traffic-statistic vlan vlan-id inbound acl-rule
View
Use the reset traffic-statistics vlan command to clear the statistics about packets that are of a VLAN and match specific ACL rules.
Related commands: traffic-statistic vlan.
[device] reset traffic-statistic vlan 1 inbound ip-group 2000
traffic-limit
traffic-limit inbound acl-rule target-rate [ conform con-action ] [ exceed exceed-action ] [ meter-statistic ]
undo traffic-limit inbound acl-rule [ meter-statistic ]
View
inbound: Performs traffic policing on the inbound packets.
target-rate: Target traffic rate of traffic policing ( in kbps). This argument is in the range of 1 to 44000000 in system view and port group view. In Ethernet port view, the range of this argument varies by port type as follows:
l          Gigabit port: In the rang 1 to 1000000
l          10G port: In the rang 1 to 10000000
conform con-action: Sets the actions of the device on the packets except forwarding when the packet traffic is within the specified traffic. The con-action argument can be:
l          remark-dscp dscp-value: Sets the DSCP precedence for the packets. The dscp-value argument is in the range of 0 to 63. You can also enter a keyword listed in Table 1-12 for this argument.
l          remark-cos cos-value : Sets the 802.1p precedence for the packets. The cos-value argument is in the range of 0 to 7. You can also enter a keyword listed in Table 1-27 for this argument.
Table 1-27 802.1p precedence keywords and the corresponding decimal/binary values
Keyword
802.1p precedence (decimal)
802.1p precedence (binary)
best-effort
0
000
background
1
001
Spare
2
010
excellent-effort
3
011
controlled-load
4
100
Video
5
101
Voice
6
110
Network-management
7
111
exceed exceed-action: Sets the actions on the part of the packets exceeding the specified traffic when the packet traffic exceeds the specified traffic. The actions include:
l          drop: Drops the packets.
l          forward: Forwards the packets.
l          remark-dscp dscp-value: Resets the DSCP precedence of the packets and forwards them at the same time. The DSCP value is in the range of 0 to 63. You can also enter a keyword listed in Table 1-12 for this argument.
l          remark-cos cos-value: Resets the 802.1p precedence of the packets and forwards them at the same time. The cos-value argument is in the range of 0 to 7. You can also enter a keyword listed in Table 1-27 for this argument.
meter-statistic: Performs the traffic accounting function on traffic policing. It can meter the bytes of the packets within the limited rate and the bytes of the packets beyond the limited rate.
Use the traffic-limit command to perform traffic policing for all the packets matching specific ACL rules, or for packets that match specific ACL rules and are of a port group or pass a port.
Use the undo traffic-limit command to cancel the configuration.
The granularity of traffic policing is described in the following table:
Table 1-28 The granularity of traffic policing
The rang of total rate
Granularity (bps)
0 to 1 Mbps
1K
0 to 10 Mbps
10K
0 to 100 Mbps
100K
0 to 1 Gbps
1M
0 to 10 Gbps
10M
# Perform traffic policing for packets matching ACL 4000 on GigabitEthernet 1/0/1. Limit the rate within 128 kbps and drop the packets exceeding the traffic limit.
[device-GigabitEthernet1/0/1] traffic-limit inbound link-group 4000 128 exceed drop
traffic-limit vlan
traffic-limit vlan vlan-id inbound acl-rule target-rate [ conform con-action ] [ exceed exceed-action ] [ meter-statistic ]
undo traffic-limit vlan vlan-id inbound acl-rule [ meter-statistic ]
View
target-rate: Target traffic rate of traffic policing (in kbps). This argument is in the range 1 to 44000000.
conform con-action: Sets the actions of the device on the packets except forwarding when the packet traffic is within the specified traffic. The actions are as follows:
l          remark-dscp dscp-value: Sets the DSCP precedence of the packets to the specified value. The dscp-value argument is in the range of 0 to 63. You can also enter a keyword listed in Table 1-12 for this argument.
l          remark-cos cos-value : Sets the 802.1p precedence of the packets to the specified value. The cos-value argument is in the range of 0 to 7. You can also enter a keyword listed in Table 1-27 for this argument.
l          remark-dscp dscp-value: Resets the DSCP precedence of the packets and forwards them at the same time. The dscp-value argument is in the range of 0 to 63. You can also enter a keyword listed in Table 1-12 for this argument.
Use the traffic-limit vlan command to use ACL rules in traffic identifying and traffic policing for the packet matching with the ACL rules and to set traffic policing parameters and different actions for packets within the traffic limit and packets beyond the traffic limit on a VLAN.
Use the undo traffic-limit vlan command to disable traffic policing on a VLAN.
Refer to Table 1-28 for the granularity of traffic policing.
# Perform traffic policing for packets matching ACL 4000 on VLAN 1. Limit the rate within 128 kbps and drop the packets exceeding the traffic limit on VLAN 1.
[device] traffic-limit vlan 1 inbound link-group 4000 128 exceed drop
traffic-priority
traffic-priority inbound acl-rule { dscp dscp-value | cos cos-value }
undo traffic-priority inbound acl-rule
View
inbound: Marks the priority for inbound packets.
dscp dscp-value: Sets the DSCP precedence, in the range 0 to 63. You can also enter a keyword listed in Table 1-12 for the dscp-value argument.
cos cos-value: Sets the 802.1p precedence, in the range 0 to 7. You can also enter a keyword listed in Table 1-27 for the cos-value argument.
Use the traffic-priority command to use ACL rules in traffic identifying and specify a new priority for all the packets matching the specific ACL rules, or packets that match specific ACL rules and are of a port group, or pass a port.
Use the undo traffic-priority to disable the priority marking function for all the packets matching specific the ACL rules, or packets that match specific ACL rules and are of a port group, or pass a port.
# Set the 802.1p precedence to 1 for packets matching ACL 4000 and passing GigabitEthernet 1/0/1.
[device-GigabitEthernet1/0/1] traffic-priority inbound link-group 4000 cos 1
traffic-priority vlan vlan-id inbound acl-rule { dscp dscp-value | cos cos-value }
undo traffic-priority vlan vlan-id inbound acl-rule
View
inbound: Performs priority marking for the inbound packets.
dscp dscp-value: Sets the DSCP precedence, in the range of 0 to 63. You can also enter a keyword listed in Table 1-12 for the dscp-value argument.
cos cos-value: Sets the 802.1p precedence, in the range of 0 to 7. You can also enter a keyword listed in Table 1-27 for the cos-value argument.
Use the traffic-priority vlan command to mark the priority for packets that match specific ACL rules and are of a VLAN.
Use the undo traffic-priority vlan to disable the priority marking for packets that match specific ACL rules and are of a VLAN.
# Set the 802.1p precedence to 1 for packets that match ACL 4000 and are of VLAN 1.
[device] traffic-priority vlan 1 inbound link-group 4000 cos 1
traffic-redirect
traffic-redirect inbound acl-rule interface interface-type interface-number
undo traffic-redirect inbound  acl-rule
View
inbound: Redirects inbound packets.
interface interface-type interface-number: Redirects the packets to the specified Ethernet port. interface-type indicates the type of the interface and interface-number indicates the interface number.
Use the traffic-redirect command to redirect all the packets that match specific ACL rules, or the packets that match specific ACL rules and are of a port group or pass a port.
Use the undo traffic-redirect command to disable traffic redirecting for all the packets that match specific ACL rules, or the packets that match specific ACL rules and are of a port group or pass a port
If the traffic is redirected to a Combo port in down state, the system automatically redirects the traffic to the port corresponding to the Combo port in up state. Refer to Port Basic Configuration in H3C WX3000 Series Unified Switches Switching Engine Configuration Guide for information about Combo ports.
# Redirect the packets that match ACL 2000 and pass GigabitEthernet 1/0/1 to GigabitEthernet 1/0/7.
[device-GigabitEthernet1/0/1] traffic-redirect inbound ip-group 2000 interface GigabitEthernet1/0/7
traffic-redirect vlan vlan-id inbound acl-rule interface interface-type interface-number
undo traffic-redirect vlan vlan-id inbound acl-rule
View
Use the traffic-redirect vlan command to redirect packets that match specific ACL rules and are of a specific VLAN to a specified port.
Use the undo traffic-redirect vlan command to cancel the configuration.
# Redirect the packets that match ACL 2000 rules and are of VLAN 1 to GigabitEthernet 1/0/7.
[device] traffic-redirect vlan 1 inbound ip-group 2000 interface GigabitEthernet1/0/7
traffic-remark-vlanid inbound acl-rule remark-vlan vlan-id untagged-packet
undo traffic-remark-vlanid inbound acl-rule
View
Ethernet port view
inbound: Indicates that VLAN tag remark is performed on the packets received on the port.
remark-vlan vlan-id: Indicates the VLAN ID used in remark.
untagged-packet: Performs the VLAN tag remark operation on the packets matching with ACL rules without VLAN tags.
Use the traffic-remark-vlanid command to enable VLAN mapping and set the target VLAN ID for packets matching specific ACL rules.
Use the undo traffic-remark-vlanid command to disable VLAN mapping for packets matching specific ACL rules.
# Configure VLAN mapping on GigabitEthernet 1/0/1 to map the VLAN IDs of inbound packets matching ACL 4001 to 1001.
[device-GigabitEthernet1/0/1] traffic-remark-vlanid inbound link-group 4001 remark-vlan 1001
traffic-shape
traffic-shape [ queue queue-id ] max-rate burst-size
undo traffic-shape [ queue queue-id ]
View
Ethernet port view
queue queue-id: Specifies the ID of a queue, in the range of 0 to 7.
max-rate: Maximum traffic rate on a port, in kbps.
burst-size: Burst size (in KB), in the range 16 to 16000. This argument must be a multiple of 4.
Use the traffic-shape command to enable traffic shaping and send the packets out at an even rate. Use the undo traffic-shape command to disable traffic shaping.
The device supports two forms of traffic shaping:
l          Traffic shaping for all the traffic of a port. The function can be implemented when queue queue-id in the traffic-shape command is not specified.
l          Traffic shaping for the specified output queues. The function can be implemented when queue queue-id in the traffic-shape command is specified.
Table 1-29 The granularity of traffic shaping
Port type
The set traffic shaping value
Granularity (bps)
GE ports
0 to 80 Mbps
20 Kbps
GE ports
80 Mbps to 1 Gbps
260 Kbps
10GE ports
0 to 10 Gbps
2500 Kbps
# Configure traffic shaping on GigabitEthernet 1/0/1, with the maximum rate being 640 kbps and the burst size being 16 KB.
[device-GigabitEthernet1/0/1] traffic-shape 640 16
traffic-statistic
undo traffic-statistic inbound acl-rule
View
inbound: Collects statistics about inbound packets.
Use the traffic-statistic command to collect statistics about all the packets matching specific ACL rules, or about packets that match specific ACL rules and are of a port group, or pass a port.
Use the undo traffic-statistic command to disable collecting statistics about all the packets matching specific ACL rules, or about packets that match specific ACL rules and are of a port group, or pass a port.
# Collect statistics about the packets that match ACL 2000 and pass GigabitEthernet 1/0/1.
[device-GigabitEthernet1/0/1] traffic-statistic inbound ip-group 2000
undo traffic-statistic vlan vlan-id inbound acl-rule
View
Use the traffic-statistic vlan command to collect statistics about packets that match specific ACL rules and are of a specific VLAN.
Use the undo traffic-statistic vlan command to cancel the configuration.
# Collect statistics about packets that match ACL 2000 and are of VLAN 1.
[device] traffic-statistic vlan 1 inbound ip-group 2000
apply qos-profile
In system view
apply qos-profile profile-name interface interface-list
undo apply qos-profile profile-name interface interface-list
View
profile-name: QoS profile name, a string of 1 to 32 characters and starting with English letters [a-z, A-Z].
interface-list: List of Ethernet ports. You can specify multiple Ethernet ports by providing this argument in the form of interface-type interface-number [ to interface-type interface-number ].
Use the apply qos-profile command to apply a QoS profile to a port or multiple ports.
Use the undo apply qos-profile command to remove a QoS profile from a port or multiple ports.
# Apply the QoS profile named “a123” to GigabitEthernet 1/0/1.
[device-GigabitEthernet1/0/1] apply qos-profile a123
# Apply the QoS profile named “a123” to GigabitEthernet 1/0/1 through GigabitEthernet 1/0/4.
[device] apply qos-profile a123 interface GigabitEthernet 1/0/1 to GigabitEthernet 1/0/4
display qos-profile
display qos-profile { all | name profile-name | interface interface-type interface-number | user user-name }
View
all: Specifies all the QoS profiles.
name profile-name: Specifies a QoS profile name, a string of 1 to 32 characters and starting with English letters [a-z, A-Z].
interface interface-type interface-number: Specifies the port type and port number.
user user-name: Specifies a user name, a string of 1 to 80 characters.
Use the display qos-profile command to display the configuration of a QoS profile or all the QoS profiles.
# Display the configuration of all the QoS profiles.
<device> display qos-profile all
qos-profile: test, 0 action
packet-filter
packet-filter inbound acl-rule
undo packet-filter inbound acl-rule
View
QoS profile view
inbound: Filters the inbound packets.
Use the packet-filter command to add the packet filtering action to a QoS profile.
Use the undo packet-filter command to remove the packet filtering action from a QoS profile.
Refer to ACL in H3C WX3000 Series Unified Switches Switching Engine Configuration Guide for the detailed information about packet filtering.
# Add the packet filtering action to the QoS profile named “a123” to filter the inbound packets matching ACL 4000.
[device] qos-profile a123
[device-qos-profile-a123] packet-filter inbound link-group 4000
qos-profile
undo qos-profile profile-name
View
profile-name: QoS profile name, a string of 1 to 32 characters and  starting with English letters [a-z, A-Z]. Note that a QoS profile name cannot be “all”, “interface”, “user”, “undo”, or “name”.
Use the qos-profile command to create a QoS profile and enter QoS profile view. If the QoS profile already exists, this command leads you to the corresponding QoS profile view.
Use the undo qos-profile command to remove a QoS profile.
A QoS profile currently applied to a port cannot be removed.
# Create a QoS profile named “a123”.
undo qos-profile port-based
View
Ethernet port view
None
Use the qos-profile port-based command to configure the QoS profile application mode on a port to be port-based.
Use the undo qos-profile port-based command to restore the default.
By default, the application mode of a QoS profile is user-based.
Note that:
l          If the 802.1x authentication is MAC-based, you need to configure the QoS profile application mode to be user-based.
l          If the 802.1x authentication is port-based, you need to configure the QoS profile application mode to be port-based.
# Configure the QoS profile application mode on GigabitEthernet 1/0/1 to be port-based.
[device-GigabitEthernet1/0/1] qos-profile port-based
traffic-limit
View
QoS profile view
target-rate: Target traffic rate of traffic policing. This argument is in the range 1 to 10000000.
l          remark-dscp dscp-value: Sets the DSCP precedence for the packets. The dscp-value argument is in the range 0 to 63. You can also enter a keyword listed in Table 1-12 for this argument.
l          remark-cos cos-value : Sets the 802.1p precedence of the packets. The cos-value argument is in the range 0 to 7. You can also enter a keyword listed in Table 1-27 for this argument.
l          remark-dscp dscp-value: Resets the DSCP precedence for the packets and forwards them at the same time. The dscp-value argument is in the range 0 to 63. You can also enter a keyword listed in Table 1-12 for this argument.
l          remark-cos cos-value: Resets the 802.1p precedence for the packets and forwards them at the same time. The cos-value argument is in the range 0 to 7. You can also enter a keyword listed in Table 1-27 for this argument.
Use the traffic-limit command to add the traffic policing action to a QoS profile.
Use the undo traffic-limit command to remove the traffic policing action from a QoS profile.
The traffic policing action of a QoS profile currently applied to a port cannot be removed.
# Add traffic policing action to the QoS profile named “a123” to limit the rate of the inbound packets matching ACL 2000 to 128 kbps and drop the packets exceeding 128 kbps.
[device-qos-profile-a123] traffic-limit inbound  ip-group 2000 128 exceed drop
traffic-priority
View
QoS profile view
inbound: Performs priority marking on the inbound packets.
dscp dscp-value: Sets the DSCP precedence. The dscp-value argument is in the range 0 to 63. You can also enter a keyword listed in Table 1-12 for this argument.
cos cos-value: Sets the 802.1p precedence. The cos-value argument is in the range 0 to 7. You can also enter a keyword listed in Table 1-27 for this argument.
Use the traffic-priority command to add a priority marking action to a QoS profile.
Use the undo traffic-priority command to remove a priority marking action from a QoS profile.
The priority marking action of a QoS profile currently applied to a port cannot be removed.
# Add the priority marking action to the QoS profile named “a123” to set the 802.1p precedence of the inbound packets matching ACL 4000 to 1.
[device-qos-profile-a123] traffic-priority inbound link-group 4000 cos 1
