- H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
- 01-CLI Command
- 02-Login Command
- 03-Configuration File Management Command
- 04-VLAN Command
- 05-Auto Detect Command
- 06-Voice VLAN Command
- 07-GVRP Command
- 08-Basic Port Configuration Command
- 09-Link Aggregation Command
- 10-Port Isolation Command
- 11-Port Security-Port Binding Command
- 12-DLDP Command
- 13-MAC Address Table Management Command
- 14-MSTP Command
- 15-802.1x and System Guard Command
- 16-AAA Command
- 17-MAC Address Authentication Command
- 18-IP Address and Performance Command
- 19-DHCP Command
- 20-ACL Command
- 21-QoS-QoS Profile Command
- 22-Mirroring Command
- 23-ARP Command
- 24-SNMP-RMON Command
- 25-Multicast Command
- 26-NTP Command
- 27-SSH Command
- 28-File System Management Command
- 29-FTP-SFTP-TFTP Command
- 30-Information Center Command
- 31-System Maintenance and Debugging Command
- 32-VLAN-VPN Command
- 33-HWPing Command
- 34-DNS Command
- 35-Smart Link-Monitor Link Command
- 36-PoE-PoE Profile Command
- 37-Routing Protocol Command
- 38-UDP Helper Command
- 39-Index
09-Link Aggregation Command | 43.26 KB |
Table of Contents
1 Link Aggregation Configuration Commands
display link-aggregation interface
display link-aggregation summary
display link-aggregation verbose
link-aggregation group description
display link-aggregation interface interface-type interface-number [ to interface-type interface-number ]
View
interface-type: Port type.
interface-number: Port number.
to: Specifies a port index range, with the two interface-type interface-number argument pairs around it as the two ends.
Use the display link-aggregation interface command to display the link aggregation details about a specified port or port range.
Note that as ports in a manual link aggregation groups do not acquire the information about their peers automatically, so the entries in the information about the peer ports displayed are all 0 instead of the actual values.
# Display the link aggregation details on GigabitEthernet 1/0/1.
<device> display link-aggregation interface GigabitEthernet 1/0/1
GigabitEthernet1/0/1:
Selected AggID: 1
Local:
Port-Priority: 32768, Oper key: 2, Flag: 0x45
Remote:
System ID: 0x8000, 0000-0000-0000
Port Number: 0, Port-Priority: 32768 , Oper-key: 0, Flag: 0x38
Received LACP Packets: 0 packet(s), Illegal: 0 packet(s)
Sent LACP Packets: 0 packet(s)
Table 1-1 display link-aggregation interface command output description
Selected AggID |
ID of the aggregation group to which the specified port belongs |
Local |
Information about the local end |
Port-Priority |
Port priority |
Oper key |
Operation key |
Flag |
Protocol status flag |
Remote |
Information about the remote end |
System ID |
Remote device ID |
Port number |
Port number |
Received LACP Packets: 0 packet(s), Illegal: 0 packet(s) Sent LACP Packets: 0 packet(s) |
Statistics about LACP packets |
View
None
Use the display link-aggregation summary command to display summary information of all aggregation groups.
# Display summary information of all aggregation groups.
<device> display link-aggregation summary
Aggregation Group Type:D -- Dynamic, S -- Static , M -- Manual
Actor ID: 0x8000, 000f-e20f-5104
AL AL Partner ID Select Unselect Share Master
ID Type Ports Ports Type Port
1 S 0x8000,0000-0000-0000 0 1 NonS GigabitEthernet1/0/2
2 M none 0 1 NonS GigabitEthernet1/0/3
Table 1-2 display link-aggregation summary command output description
Aggregation Group Type |
Aggregation group type: D for dynamic, S for static, and M for manual |
Loadsharing Type |
Load sharing type: Shar for load sharing and NonS for non-load sharing |
Actor ID |
Local device ID |
AL ID |
Aggregation group ID |
AL Type |
Aggregation group type: D (dynamic), S (static), or M (manual) |
Partner ID |
ID of the remote device, including the system priority and system MAC address of the remote device (in the dynamic or static aggregation group, if the LACP protocol is disabled on the remote port of the logical master port, the partner ID displays 0x8000,0000-0000-0000 ) |
Select Ports |
Number of the selected ports |
Unselect Ports |
Number of the unselected ports |
Share Type |
Load sharing type: Shar (load-sharing), or NonS (non-load-sharing) |
Master Port |
the smallest port number in an aggregation group |
display link-aggregation verbose [ agg-id ]
View
agg-id: Aggregation group ID to be displayed, which ranges from 1 to 12 and must be the ID of an existing aggregation group.
Use the display link-aggregation verbose command to display the details about a specified aggregation group or all aggregation groups.
# Display the details about aggregation group 1.
<device> display link-aggregation verbose 1
Flags: A -- LACP_Activity, B -- LACP_timeout, C -- Aggregation,
G -- Defaulted, H -- Expired
Aggregation ID: 1, AggregationType: Static, Loadsharing Type: NonS
Aggregation Description: abc
System ID: 0x16, 0012-a990-2240
Port Status: S -- Selected, U -- Unselected
Local:
Port Status Priority Key Flag
GigabitEthernet1/0/4 S 32768 2 {ACDEFG}
GigabitEthernet1/0/5 U 32768 2 {ACG}
Remote:
Actor Partner Priority Key SystemID Flag
GigabitEthernet1/0/4 0 32768 0 0x8000,0000-0000-0000 {DEF}
GigabitEthernet1/0/5 0 32768 0 0x8000,0000-0000-0000 {DEF}
Table 1-3 display link-aggregation verbose command output description
Loadsharing Type |
Loadsharing type, including Loadsharing and Non-Loadsharing |
Flags |
Flag types of LACP |
Aggregation ID |
Aggregation Description |
Aggregation group description string |
AggregationType |
Aggregation group type |
System ID |
Device ID |
Port Status |
Port status, including selected and unselected |
display lacp system-id
View
None
Use the display lacp system-id command to display the device ID of the local system, including the system priority and the MAC address.
Related commands: link-aggregation.
# Display the device ID of the local system.
<device> display lacp system-id
Actor System ID: 0x8000, 000f-e20f-0100
The Actor System ID field is the device ID (consisting of the system priority and the system MAC address) of the local system.
lacp enable
lacp enable
undo lacp enable
View
Ethernet port view
None
Use the lacp enable command to enable LACP on the current port.
Use the undo lacp enable command to disable LACP.
By default, LACP is disabled on a port.
# Enable the LACP protocol on GigabitEthernet 1/0/1.
<device> system-view
[device] interface GigabitEthernet 1/0/1
[device-GigabitEthernet1/0/1] lacp enable
lacp port-priority
lacp port-priority port-priority
undo lacp port-priority
View
Ethernet port view
port-priority: Port priority, ranging from 0 to 65,535.
Use the lacp port-priority command to set the priority of the current port.
Use the undo lacp port-priority command to restore the default port priority.
By default, the port priority is 32,768.
Related commands: display link-aggregation verbose, and display link-aggregation interface.
# Set the priority of GigabitEthernet 1/0/1 to 64.
[device-GigabitEthernet1/0/1] lacp port-priority 64
lacp system-priority
lacp system-priority system-priority
undo lacp system-priority
View
system-priority: System priority, ranging from 0 to 65,535.
Use the lacp system-priority command to set the system priority.
Use the undo lacp system-priority command to restore the default system priority.
By default, the system priority is 32,768.
# Set the system priority to 64.
[device] lacp system-priority 64
link-aggregation group agg-id description agg-name
undo link-aggregation group agg-id description
View
agg-id: Aggregation group ID, in the range of 1 to 12.
agg-name: Aggregation group name, a string of 1 to 32 characters.
Use the link-aggregation group description command to set a description for an aggregation group.
Use the undo link-aggregation group description command to remove the description of an aggregation group.
If you have saved the current configuration with the save command, after system reboot, the configuration concerning manual and static aggregation groups and their descriptions still exists, but that of the dynamic aggregation groups and their descriptions gets lost.
Related commands: display link-aggregation verbose.
# Set the description "abc" for aggregation group 1.
[device] link-aggregation group 1 description abc
link-aggregation group mode
link-aggregation group agg-id mode { manual | static }
View
manual: Creates a manual aggregation group.
static: Creates a static aggregation group.
Use the link-aggregation group mode command to create a manual or static aggregation group.
Use the undo link-aggregation group command to remove an aggregation group.
Related commands: display link-aggregation summary.
# Create manual aggregation group 22
[device] link-aggregation group 22 mode manual
port link-aggregation group
port link-aggregation group agg-id
undo port link-aggregation group
View
Ethernet port view
Use the port link-aggregation group command to add the current Ethernet port to a manual or static aggregation group.
Use the undo port link-aggregation group command to remove the current Ethernet port from the aggregation group.
# Add GigabitEthernet 1/0/1 to aggregation group 22.
[device-GigabitEthernet1/0/1] port link-aggregation group 22
reset lacp statistics
reset lacp statistics [ interface interface-type interface-number [ to interface-type interface-number ] ]
View
Use the reset lacp statistics command to clear LACP statistics on specified port(s), or on all ports if no port is specified.
Related commands: display link-aggregation interface.
# Clear LACP statistics on all Ethernet ports.
<device> reset lacp statistics
