- H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
- 01-CLI Command
- 02-Login Command
- 03-Configuration File Management Command
- 04-VLAN Command
- 05-Auto Detect Command
- 06-Voice VLAN Command
- 07-GVRP Command
- 08-Basic Port Configuration Command
- 09-Link Aggregation Command
- 10-Port Isolation Command
- 11-Port Security-Port Binding Command
- 12-DLDP Command
- 13-MAC Address Table Management Command
- 14-MSTP Command
- 15-802.1x and System Guard Command
- 16-AAA Command
- 17-MAC Address Authentication Command
- 18-IP Address and Performance Command
- 19-DHCP Command
- 20-ACL Command
- 21-QoS-QoS Profile Command
- 22-Mirroring Command
- 23-ARP Command
- 24-SNMP-RMON Command
- 25-Multicast Command
- 26-NTP Command
- 27-SSH Command
- 28-File System Management Command
- 29-FTP-SFTP-TFTP Command
- 30-Information Center Command
- 31-System Maintenance and Debugging Command
- 32-VLAN-VPN Command
- 33-HWPing Command
- 34-DNS Command
- 35-Smart Link-Monitor Link Command
- 36-PoE-PoE Profile Command
- 37-Routing Protocol Command
- 38-UDP Helper Command
- 39-Index
15-802.1x and System Guard Command | 149.55 KB |
Table of Contents
1 802.1x Configuration Commands
2 Quick EAD Deployment Configuration Commands
3 System-Guard Configuration Commands
display system-guard attack-record
display dot1x
display dot1x [ sessions | statistics ] [ interface interface-list ]
View
sessions: Displays the information about 802.1x sessions.
statistics: Displays the statistics on 802.1x.
interface: Display the 802.1x-related information about a specified port.
interface-list: Ethernet port list, in the form of interface-list= { interface-type interface-number [ to interface-type interface-number ] } &<1-10>, in which interface-type specifies the type of an Ethernet port and interface-number is the number of the port. The string “&<1-10>” means that up to 10 port lists can be provided.
Use the display dot1x command to display 802.1x-related information, such as configuration information, operation information (session information), and statistics.
When the interface-list argument is not provided, this command displays all the 802.1x-related information of the device. The output information can be used to verify 802.1 x-related configurations and to troubleshoot.
Related commands: reset dot1x statistics, dot1x, dot1x retry, dot1x max-user, dot1x port-control, dot1x port-method, and dot1x timer.
# Display 802.1x-related information.
<device> display dot1x
Global 802.1X protocol is enabled
CHAP authentication is enabled
DHCP-launch is disabled
Handshake is enabled
Proxy trap checker is disabled
Proxy logoff checker is disabled
EAD Quick Deploy is enabled
Configuration: Transmit Period 30 s, Handshake Period 15 s
ReAuth Period 3600 s, ReAuth MaxTimes 2
Quiet Period 60 s, Quiet Period Timer is disabled
Supp Timeout 30 s, Server Timeout 100 s
Interval between version requests is 30s
Maximal request times for version information is 3
The maximal retransmitting times 2
EAD Quick Deploy configuration:
url http://192.168.19.23
free-ip 192.168.19.0 255.255.255.0
acl-timeout 30m
Total maximum 802.1x user resource number is 1024
Total current used 802.1x resource number is 1
GigabitEthernet1/0/1 is link-down
802.1X protocol is disabled
Version-Check is disabled
The port is an authenticator
Authentication Mode is Auto
Port Control Type is Mac-based
ReAuthenticate is disabled
Max number of on-line users is 256
Authentication Success: 0, Failed: 0
EAPOL Packets: Tx 0, Rx 0
Sent EAP Request/Identity Packets : 0
EAP Request/Challenge Packets: 0
Received EAPOL Start Packets : 0
EAPOL LogOff Packets: 0
EAP Response/Identity Packets : 0
EAP Response/Challenge Packets: 0
Error Packets: 0
Controlled User(s) amount to 0
GigabitEthernet1/0/2 is link-down
Error Packets: 0
GigabitEthernet1/0/3
Table 1-1 display dot1x command output description
Global 802.1X protocol is enabled |
Whether 802.1x is enabled on the device globally. |
CHAP authentication is enabled |
802.1x authentication mode used, which can be CHAP, EAP, or PAP. |
DHCP-launch is disabled |
Whether the DHCP-triggered 802.1x authentication is enabled. Possible values include enabled and disabled. The value of enabled means that the device will perform 802.1x authentication for a user when the user runs DHCP to apply for an IP address. |
Proxy trap checker is disabled |
Whether to send Trap packets when detecting a supplicant system logs in through a proxy. l Disabled means the device does not send Trap packets when it detects that a supplicant system logs in through a proxy. l Enabled means the device sends Trap packets when it detects that a supplicant system logs in through a proxy. |
Proxy logoff checker is disabled |
Whether to disconnect a supplicant system when detecting it logs in through a proxy. l Disabled means the device does not disconnect a supplicant system when it detects that the latter logs in through a proxy. l Enabled means the device disconnects a supplicant system when it detects that the latter logs in through a proxy. |
EAD Quick Deploy is enabled |
Whether the quick EAD deployment is enabled. |
Transmit Period |
Setting of the Transmission period timer (the tx-period) |
Handshake Period |
Setting of the handshake period timer (the handshake-period) |
ReAuth Period |
Re-authentication interval |
ReAuth MaxTimes |
Maximum times of re-authentications |
Quiet Period |
Setting of the quiet period timer (the quiet-period) |
Quiet Period Timer is disabled |
Whether the quiet period timer is enabled. |
Supp Timeout |
Setting of the supplicant timeout timer (supp-timeout) |
Server Timeout |
Setting of the server-timeout timer (server-timeout) |
The maximal retransmitting times |
The maximum number of times that the device can send authentication request packets to a supplicant system |
free-ip |
Free IP range that users can access before passing authentication |
acl-timeout |
ACL timeout period |
url |
URL for HTTP redirection |
Total maximum 802.1x user resource number |
The maximum number of 802.1x users that the device can accommodate |
Total current used 802.1x resource number |
The number of online supplicant systems |
GigabitEthernet1/0/1 is link-down |
GigabitEthernet 1/0/1 port is down. |
802.1X protocol is disabled |
Whether 802.1x is enabled on the port. |
Whether to send Trap packets when detecting a supplicant system in logging in through a proxy. l Disabled means the device does not send Trap packets when it detects that a supplicant system logs in through a proxy. l Enabled means the device sends Trap packets when it detects that a supplicant system logs in through a proxy. |
Whether to disconnect a supplicant system when detecting it in logging in through a proxy. l Disabled means the device does not disconnect a supplicant system when it detects that the latter logs in through a proxy. l Enabled means the device disconnects a supplicant system when it detects that the latter logs in through a proxy. |
Version-Check is disabled |
Whether the client version checking function is enabled: l Disabled means the device does not checks client version. l Enabled means the device checks client version. |
The port is an authenticator |
The port acts as an authenticator system. |
Authentication Mode is Auto |
The port authorization mode, which can be auto, authorized-force, or unauthorized-force. For description of the three modes, refer to parameter description of the dot1x port-control command. |
Port Control Type is Mac-based |
The access control method of the port, which can be: l MAC-based: Controls user access based on MAC address. l Port-based: Controls user access based on the port |
ReAuthenticate is disabled |
Whether 802.1x re-authentication is enabled. |
Max number of on-line users |
The maximum number of online users that the port can accommodate |
Information omitted here |
dot1x
dot1x [ interface interface-list ]
undo dot1x [ interface interface-list ]
View
System view, Ethernet port view
Use the dot1x command to enable 802.1x globally or for specified Ethernet ports.
Use the undo dot1x command to disable 802.1x globally or for specified Ethernet ports.
By default, 802.1x is disabled globally and also on all ports.
In system view:
l If you do not provide the interface-list argument, the dot1x command enables 802.1x globally.
l If you specify the interface-list argument, the dot1x command enables 802.1x for the specified Ethernet ports.
In Ethernet port view, the interface-list argument is not available and the command enables 802.1x for only the current Ethernet port.
You can perform 802.1x-related configurations (globally or on specified ports) before or after 802.1x is enabled. If you do not previously perform other 802.1x-related configurations when enabling 802.1x globally, the device adopts the default 802.1x settings.
802.1x-related configurations take effect on a port only after 802.1x is enabled both globally and on the port.
l Configurations of 8021.x and the maximum number of MAX addresses that can be learnt are mutually exclusive. That is, when 802.1x is enabled for a port, it cannot also have the maximum number of MAX addresses to be learned configured at the same time. Conversely, if you configure the maximum number of MAX addresses that can be learnt for a port, 802.1x is unavailable to it.
l If you enable 802.1x for a port, it is not available to add the port to an aggregation group. Meanwhile, if a port has been added to an aggregation group, it is prohibited to enable 802.1x for the port.
Related commands: display dot1x.
# Enable 802.1x for GigabitEthernet1/0/1 port.
<device> system-view
[device] dot1x interface GigabitEthernet 1/0/1
# Enable 802.1x globally.
[device] dot1x
dot1x authentication-method
dot1x authentication-method { chap | pap | eap }
undo dot1x authentication-method
View
chap: Authenticates using challenge handshake authentication protocol (CHAP).
pap: Authenticates using password authentication protocol (PAP).
eap: Authenticates using extensible authentication protocol (EAP).
Use the dot1x authentication-method command to set the 802.1x authentication method.
Use the undo dot1x authentication-method command to revert to the default 802.1x authentication method.
The default 802.1x authentication method is CHAP.
PAP applies a two-way handshaking procedure. In this method, passwords are transmitted in plain text.
CHAP applies a three-way handshaking procedure. In this method, user names are transmitted rather than passwords. Therefore this method is safer.
In EAP authentication, the device authenticates supplicant systems by encapsulating 802.1x authentication information in EAP packets and sending the packets to the RADIUS server, instead of converting the packets into RADIUS packets before forwarding to the RADIUS server. You can use EAP authentication in one of the four sub-methods: PEAP, EAP-TLS, EAP-TTLS and EAP-MD5.
When the current device operates as the authentication server, EAP authentication is unavailable.
# Specify the authentication method to be PAP.
[device] dot1x authentication-method pap
dot1x dhcp-launch
dot1x dhcp-launch
undo dot1x dhcp-launch
View
None
Use the dot1x dhcp-launch command to specify the device to launch the 802.1x to authenticate a supplicant system once the supplicant system applies for a dynamic IP address through DHCP.
Use the undo dot1x dhcp-launch command to disable the 802.1x-enabled device from authenticating a supplicant system when the supplicant system applies for a dynamic IP address through DHCP.
By default, the device does not launch an 802.1x authentication for a supplicant system when the supplicant system applies for a dynamic IP address through DHCP.
# Configure to authenticate a supplicant system when it applies for a dynamic IP address through DHCP.
[device] dot1x dhcp-launch
dot1x guest-vlan
dot1x guest-vlan vlan-id [ interface interface-list ]
undo dot1x guest-vlan [ interface interface-list ]
View
vlan-id: VLAN ID of a Guest VLAN, in the range 1 to 4094.
Use the dot1x guest-vlan command to enable the Guest VLAN function for ports.
Use the undo dot1x guest-vlan command to disable the Guest VLAN function for ports.
In system view,
l If you do not provide the interface-list argument, these two commands apply to all the ports of the device.
l If you specify the interface-list argument, these two commands apply to the specified ports.
In Ethernet port view, the interface-list argument is not available and these two commands apply to only the current Ethernet port.
l The Guest VLAN function is available only when the device operates in the port-based authentication mode.
l Only one Guest VLAN can be configured on one device.
l The Guest VLAN function is unavailable when the dot1x dhcp-launch command is executed on the device, because the device does not send authentication request packets in this case.
# Configure the device to operate in the port-based access control mode.
[device] dot1x port-method portbased
# Enable the Guest VLAN function for all the ports.
[device] dot1x guest-vlan 1
dot1x handshake
dot1x handshake enable
undo dot1x handshake enable
View
None
Use the dot1x handshake enable command to enable the online user handshaking function.
Use the undo dot1x handshake enable command to disable the online user handshaking function.
By default, the online user handshaking function is enabled.
l To enable the proxy detecting function, you need to enable the online user handshaking function first.
l Handshaking packets are used to test whether a user is online or not. Users need to run the client that supports the handshaking function to respond to the handshaking packets.
l If a user runs a client that does not support the online user handshaking function, the device cannot receive handshaking acknowledgement packets from the client in handshaking periods. To prevent the user being falsely considered offline, you need to disable the online user handshaking function in this case.
# Enable the online user handshaking function.
[device] dot1x handshake enable
dot1x handshake secure
undo dot1x handshake secure
View
Ethernet port view
None
Use the dot1x handshake secure command to enable the handshaking packet secure function, preventing the device from attacks resulted from simulating clients.
Use the undo dot1x handshake secure command to disable the handshaking packet secure function.
By default, the handshaking packet secure function is disabled.
For the handshaking packet secure function to take effect, the clients that enable the function need to cooperate with the authentication server. If either the clients or the authentication server does not support the function, disabling the handshaking packet secure function is needed.
# Enable the handshaking packet secure function.
[device] interface GigabitEthernet 1/0/1
[device-GigabitEthernet1/0/1] dot1x handshake secure
dot1x max-user
dot1x max-user user-number [ interface interface-list ]
undo dot1x max-user [ interface interface-list ]
View
user-number: Maximum number of users a port can accommodate, in the range 1 to 256.
Use the dot1x max-user command to set the maximum number of users an Ethernet port can accommodate.
Use the undo dot1x max-user command to revert to the default maximum user number.
By default, a port can accommodate up to 256 users.
In system view:
In Ethernet port view, the interface-list argument is not available and the commands apply to only the current port.
# Configure the maximum number of users that GigabitEthernet1/01 port can accommodate to be 32.
[device] dot1x max-user 32 interface GigabitEthernet 1/0/1
dot1x port-control
dot1x port-control { auto | authorized-force | unauthorized-force } [ interface interface-list ]
undo dot1x port-control [ interface interface-list ]
View
auto: Specifies to operate in auto authorization mode. When a port operates in this mode, it is in the unauthorized state initially. In this case, only EAPoL packets can be exchanged between the device and the hosts, which are not allowed to access the network before they pass the authentication. After the hosts pass the authentication, the port changes to the authorized state and allows the hosts to access the network resources. Normally, a port operates in this mode.
authorized-force: Specifies to operate in the authorized-force authorization mode. When a port operates in this mode, the port is always in authorized state, so that all the hosts connected to it can access the network resources without being authenticated.
unauthorized-force: Specifies to operate in the unauthorized-force authorization mode. When a port operates in this mode, the port is always in unauthorized mode. Therefore the hosts connected to it cannot access the network resources.
Use the dot1x port-control command to specify the 802.1x’s authorization mode for the specified ports.
Use the undo dot1x port-control command to revert to the default port authorization mode.
The default port authorization mode is auto.
In system view:
l If you specify the interface-list argument, these commands apply to the specified ports.
In Ethernet port view, the interface-list argument is not available and the commands apply to only the current Ethernet port.
# Specify GigabitEthernet 1/0/1 port to operate in unauthorized-force mode.
[device] dot1x port-control unauthorized-force interface GigabitEthernet 1/0/1
dot1x port-method
dot1x port-method { macbased | portbased } [ interface interface-list ]
undo dot1x port-method [ interface interface-list ]
View
macbased: Performs MAC address-based access control for users..
portbased: Performs port-based access control for users..
Use the dot1x port-method command to specify the 802.1x’s access control method on the specified ports.
Use the undo dot1x port-method command to restore the default access control method.
By default, the access control method is macbased.
This command specifies the way in which the specified ports control the access of users.
l When a port works the MAC-based control mode, all users connected to the port are authenticated separately. And if a user logs off, others are not affected.
l When a port works in the port-based control mode, all the users connected to the port are able to access the network without being authenticated after a user among them passes the authentication. When the user logs off, the network is inaccessible to all other users either.
l Changing the access control method on a port by the dot1x port-method command will forcibly log off the online 802.1x users on the port.
In system view:
# Specify the access control method for users on GigabitEthernet1/0/1 as port-based.
[device] dot1x port-method portbased interface GigabitEthernet 1/0/1
dot1x quiet-period
dot1x quiet-period
undo dot1x quiet-period
View
None
Use the dot1x quiet-period command to enable the quiet-period timer.
Use the undo dot1x quiet-period command to disable the quiet-period timer.
When a user fails to pass the authentication, the authenticator system will stay quiet for a period (determined by the quiet-period timer) before it performs another authentication. During the quiet period, the authenticator system performs no 802.1x authentication of the user.
By default, the quiet-period timer is disabled.
Related commands: display dot1x, dot1x timer.
# Enable the quiet-period timer.
[device] dot1x quiet-period
dot1x retry
dot1x retry max-retry-value
undo dot1x retry
View
max-retry-value: Maximum number of times that the device sends authentication request packets to a user. This argument ranges from 1 to 10.
Use the dot1x retry command to specify the maximum number of times that the device sends authentication request packets to a user.
Use the undo dot1x retry command to revert to the default value.
By default, the device sends authentication request packets to a user for up to 2 times.
After the device sends an authentication request packet to a user, it sends another authentication request packet if it does not receive response from the user after a specific period of time. If the device still receives no response when the configured maximum number of authentication request transmission attempts is reached, it no longer sends an authentication request packet to the user. This command applies to all ports.
# Specify the maximum number of times that the device sends authentication request packets to be 9.
[device] dot1x retry 9
dot1x retry-version-max
dot1x retry-version-max max-retry-version-value
undo dot1x retry-version-max
View
max-retry-version-value: Maximum number of times that the device sends version request packets to a user. This argument ranges from 1 to 10.
Use the dot1x retry-version-max command to set the maximum number of times that the device sends version request packets to a user.
Use the undo dot1x retry-version-max command to revert to the default value.
By default, the device sends version request packets to a user for up to 3 times.
After the device sends a version request packet to a user, it sends another version request packet if it does receive response from the user after a specific period of time (as determined by the client version request timer). When the number set by this command has reached and there is still no response from the user, the device continues the following authentication procedures without sending version requests. This command applies to all the ports with the version checking function enabled.
# Configure the maximum number of times that the device sends version request packets to be 6.
[device] dot1x retry-version-max 6
dot1x re-authenticate
dot1x re-authenticate [ interface interface-list ]
undo dot1x re-authenticate [ interface interface-list ]
View
System view/Ethernet port view
Use the dot1x re-authenticate command to enable 802.1x re-authentication on specific ports or on all ports of the device.
Use the undo dot1x re-authenticate command to disable 802.1x re-authentication on specific ports or on all ports of the device.
By default, 802.1x re-authentication is disabled on all ports.
In system view:
l If you do not specify the interface-list argument, this command will enable 802.1x re-authentication on all ports.
l If you specify the interface-list argument, the command will enable 802.1x on the specified ports.
In Ethernet port view, the interface-list argument is not available and 8021.x re-authentication is enabled on the current port only.
802.1x must be enabled globally and on the current port before 802.1x re-authentication can be configured on a port.
# Enable 802.1x re-authentication on port GigabitEthernet 1/0/1.
[device] dot1x
802.1X is enabled globally.
802.1X is enabled on port GigabitEthernet1/0/1 already.
[device-GigabitEthernet1/0/1] dot1x re-authenticate
Re-authentication is enabled on port GigabitEthernet1/0/1
dot1x supp-proxy-check
dot1x supp-proxy-check { logoff | trap } [ interface interface-list ]
undo dot1x supp-proxy-check { logoff | trap } [ interface interface-list ]
View
logoff: Disconnects a user upon detecting it logging in through a proxy or through multiple network adapters.
trap: Sends Trap packets upon detecting a user logging in through a proxy or through multiple network adapters.
Use the dot1x supp-proxy-check command to enable 802.1x proxy checking for specified ports.
Use the undo dot1x supp-proxy-check command to disable 802.1x proxy checking for specified ports.
By default, 802.1x proxy checking is disabled on all Ethernet ports.
In system view:
l If you do not specify the interface-list argument, the configurations performed by these two commands are global.
l If you specify the interface-list argument, these two commands apply to the specified Ethernet ports.
The proxy checking function takes effect on a port only when the function is enabled both globally and on the port.
802.1x proxy checking checks for:
l Users logging in through proxies
l Users logging in through IE proxies
l Whether or not a user logs in through multiple network adapters (that is, when the user attempts to log in, it contains more than one active network adapters.)
The device can optionally take the following actions in response to any of the above three cases:
l Only disconnects the user but sends no Trap packets, which can be achieved by using the dot1x supp-proxy-check logoff command.
l Sends Trap packets without disconnecting the user, which can be achieved by using the dot1x supp-proxy-check trap command.
This function needs the cooperation of 802.1x clients and the CAMS server:
l Multiple network adapter checking, proxy checking, and IE proxy checking are enabled on the 802.1x client.
l The CAMS server is configured to disable the use of multiple network adapters, proxies, and IE proxy.
By default, proxy checking is disabled on 802.1x client. In this case, if you configure the CAMS server to disable the use of multiple network adapters, proxies, and IE proxy, it sends messages to the 802.1x client to ask the latter to disable the use of multiple network adapters, proxies, and IE proxy after the user passes the authentication.
l The 802.1x proxy checking function needs the cooperation of an 802.1x client program.
l The proxy checking function takes effect only after the client version checking function is enabled on the device (using the dot1x version-check command).
# Configure to disconnect the users connected to GigabitEthernet 1/0/1 through GigabitEthernet 1/0/8 ports if they are detected logging in through proxies.
[device] dot1x supp-proxy-check logoff
[device] dot1x supp-proxy-check logoff interface GigabitEthernet 1/0/1 to GigabitEthernet 1/0/8
# Configure the device to send Trap packets if the users connected to GigabitEthernet 1/0/9 port is detected logging in through proxies.
[device] dot1x supp-proxy-check trap
[device] dot1x supp-proxy-check trap interface GigabitEthernet 1/0/9
dot1x timer
dot1x timer { handshake-period handshake-period-value | quiet-period quiet-period-value | server-timeout server-timeout-value | supp-timeout supp-timeout-value | tx-period tx-period-value | ver-period ver-period-value }
undo dot1x timer { handshake-period | quiet-period | server-timeout | supp-timeout | tx-period | ver-period }
View
handshake-period handshake-period-value: Sets the handshake timer. This timer sets the handshake-period and is triggered after a supplicant system passes the authentication. It sets the interval for the device to send handshake request packets to online users. If you set the number of retries to N by using the dot1x retry command, an online user is considered offline when the device does not receive response packets from it in a period N times of the handshake-period.
The handshake-period-value argument ranges from 5 to 1,024 (in seconds). By default, the handshake timer is set to 15 seconds.
quiet-period quiet-period-value: Sets the quiet-period timer. This timer sets the quiet-period. When a supplicant system fails to pass the authentication, the device quiets for the set period (set by the quiet-period timer) before it processes another authentication request re-initiated by the supplicant system. During this quiet period, the device does not perform any 802.1x authentication-related actions for the supplicant system.
The quiet-period-value argument ranges from 10 to 120 (in seconds). By default, the quiet-period timer is set to 60 seconds.
server-timeout server-timeout-value: Sets the RADIUS server timer. This timer sets the server-timeout period. After sending an authentication request packet to the RADIUS server, the device sends another authentication request packet if it does not receive the response from the RADIUS server when this timer times out.
The server-timeout-value argument ranges from 100 to 300 (in seconds). By default, the RADIUS server timer is set to 100 seconds.
supp-timeout supp-timeout-value: Sets the supplicant system timer. This timer sets the supp-timeout period and is triggered by the device after the device sends a request/challenge packet to a supplicant system (The packet is used to request the supplicant system for the MD5 encrypted string.) The device sends another request/challenge packet to the supplicant system if the device does not receive the response from the supplicant system when this timer times out..
The supp-timeout-value argument ranges from 10 to 120 (in seconds). By default, the supplicant system timer is set to 30 seconds.
tx-period tx-period-value: Sets the transmission timer. This timer sets the tx-period and is triggered in two cases. The first case is when the client requests for authentication. The device sends a unicast request/identity packet to a supplicant system and then triggers the transmission timer. The device sends another request/identity packet to the supplicant system if it does not receive the reply packet from the supplicant system when this timer times out. The second case is when the device authenticates the 802.1x client who cannot request for authentication actively. The device sends multicast request/identity packets periodically through the port enabled with 802.1x function. In this case, this timer sets the interval to send the multicast request/identity packets.
The tx-period-value argument ranges from 10 to 120 (in seconds). By default, the transmission timer is set to 30 seconds.
ver-period ver-period-value: Sets the client version request timer. This timer sets the version period and is triggered after the device sends a version request packet. The device sends another version request packet if it does receive version response packets from the supplicant system when the timer expires.
The ver-period-value argument ranges from 1 to 30 (in seconds). By default, the client version request timer is set to 30 seconds.
Use the dot1x timer command to set a specified 802.1x timer.
Use the undo dot1x timer command to restore a specified 802.1x timer to the default setting.
During an 802.1x authentication process, multiple timers are triggered to ensure that the supplicant systems, the authenticator systems, and the Authentication servers interact with each other in an orderly way. To make authentications being processed in the desired way, you can use the dot1x timer command to set the timers as needed. This may be necessary in some special situations or in tough network environments. Normally, the defaults are recommended. (Note that some timers cannot be adjusted.)
# Set the RADIUS server timer to 150 seconds.
[device] dot1x timer server-timeout 150
dot1x timer reauth-period
undo dot1x timer reauth-period
View
reauth-period reauth-period-value: Specifies re-authentication interval, in seconds. After this timer expires, the device initiates 802.1x re-authentication. The value of the reauth-period-value argument ranges from 60 to 7,200.
Use the dot1x timer reauth-period command to configure the interval for 802.1x re-authentication.
Use the undo dot1x timer reauth-period command to restore the default 802.1x re-authentication interval.
By default, the 802.1x re-authentication interval is 3,600 seconds.
# Set the 802.1x re-authentication interval to 150 seconds.
[device] dot1x timer reauth-period 150
dot1x version-check
dot1x version-check [ interface interface-list ]
undo dot1x version-check [ interface interface-list ]
View
Use the dot1x version-check command to enable 802.1x client version checking for specified Ethernet ports.
Use the undo dot1x version-check command to disable 802.1x client version checking for specified Ethernet ports.
By default, 802.1x client version checking is disabled on all the Ethernet ports.
In system view:
# Configure GigabitEthernet 1/0/1 port to check the version of the 802.1x client upon receiving authentication packets.
[device-GigabitEthernet1/0/1] dot1x version-check
reset dot1x statistics [ interface interface-list ]
View
Use the reset dot1x statistics command to clear 802.1x-related statistics.
To retrieve the latest 802.1x-related statistics, you can use this command to clear the existing 802.1x-related statistics first.
When you execute this command,
If the interface-list argument is not specified, this command clears the global 802.1x statistics and the 802.1x statistics on all the ports.
If the interface-list argument is specified, this command clears the 802.1x statistics on the specified ports.
# Clear 802.1x statistics on GigabitEthernet 1/0/1 port.
<device> reset dot1x statistics interface GigabitEthernet 1/0/1
dot1x free-ip
dot1x free-ip ip-address { mask-address | mask-length }
undo dot1x free-ip [ ip-address { mask-address | mask-length } ]
View
ip-address: Free IP address, in dotted decimal notation.
mask-address: Subnet mask of the free IP address, in dotted decimal notation.
mask-length: Length of the subnet mask of the free IP address, in the range 0 to 32.
Use the dot1x free-ip command to configure a free IP range. A free IP range is an IP range that users can access before passing 802.1x authentication.
Use the undo dot1x free-ip command to remove a specified free IP range or all free IP ranges.
By default, no free IP range is configured.
l You must configure the URL for HTTP redirection before configuring a free IP range.
l A device supports up to two free IP ranges.
# Configure a free IP range for users to access before passing authentication.
[device] dot1x free-ip 192.168.19.23 24
dot1x timer acl-timeout
dot1x timer acl-timeout acl-timeout-value
undo dot1x timer acl-timeout
View
acl-timeout-value: ACL timeout period (in minutes), in the range of 1 to 1440.
Use the dot1x timer acl-timeout command to configure the ACL timeout period.
Use the undo dot1x timer acl-timeout command to restore the default.
By default, the ACL timeout period is 30 minutes.
Related commands: dot1x configuration commands.
# Set the ACL timeout period to 40 minutes.
[device] dot1x timer acl-timeout 40
dot1x url
dot1x url url-string
undo dot1x url
View
url-string: URL for HTTP redirection, in the format of http://x.x.x.x.
Use the dot1x url command to configure the URL for HTTP redirection.
Use the undo dot1x url command to remove the configuration.
By default, no URL is configured for HTTP redirection.
# Configure the URL for HTTP redirection.
[device] dot1x url http://192.168.19.23
View
None
Use the display system-guard attack-record command to display the record of detected attacks.
# Display the record of detected attacks.
<device> display system-guard attack-record
Not found attack
display system-guard state
View
None
Use the display system-guard state command to display the state of the system-guard feature.
Related commands: system-guard enable, system-guard detect-threshold, and system-guard timer-interval.
# Display the state of the system-guard feature.
<device> display system-guard state
System-guard Status: Enabled
Detect Threshold: 201
Isolated Time: 20
Attack Number: 0
Table 3-1 display system-guard state command output description
System-guard Status |
The enable/disable status of the system-guard feature |
Detect Threshold |
The threshold for the number of packets when an attack is detected |
Isolated Time |
The length of the isolation after an attack is detected |
Attack Number |
The times of detected attacks |
system-guard detect-threshold threshold-value
undo system-guard detect-threshold
View
threshold-value: Threshold for the number of packets when an attack is detected, in the range of 200 to 1,000.
Use the system-guard detect-threshold command to set the threshold for the number of packets when an attack is detected. When the number of inbound packets of the same type exceeds the threshold, one attack is detected and recorded.
Use the undo system-guard detect-threshold command to restore the threshold to the default value.
By default, the threshold is 200.
Related commands: display system-guard state.
# Set the threshold for the number of packets when an attack is detected to 300.
[device]system-guard detect-threshold 300
system-guard enable
system-guard enable
undo system-guard enable
View
None
Use the system-guard enable command to enable the system-guard feature.
Use the undo system-guard enable command to disable the system-guard feature.
By default, the system-guard feature is disabled.
# Enable the system-guard feature.
[device]system-guard enable
System-guard is enabled
system-guard timer-interval isolate-timer
undo system-guard timer-interval
View
isolate-timer: Length of the isolation after an attack is detected, in the range of 1 to 10,000 in minutes.
Use the system-guard timer-interval command to set the length of the isolation after an attack is detected.
Use the undo system-guard timer-interval command to restore the length of the isolation to the default value.
By default, the length of the isolation after an attack is detected is 10 minutes.
# Set the length of the isolation after an attack is detected to 20 minutes.
[device]system-guard timer-interval 20
