H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
HomeSupportWirelessH3C WX3000 Series Unified SwitchesReference GuidesCommand ReferencesH3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
04-VLAN Command
04-VLAN Command 85.07 KB
VLAN Configuration Commands
description
View
VLAN view, VLAN interface view
text: Case sensitive character string to describe the current VLAN or VLAN interface. Special characters and spaces are allowed.
It has:
l          1 to 32 characters for a VLAN description.
l          1 to 80 characters for a VLAN interface description.
Use the description command to assign a description string to the current VLAN or VLAN interface.
Use the undo description command to restore the default description string.
By default, the description string of the current VLAN is its VLAN ID, such as “VLAN 0001”; the description string of the current VLAN interface is its name, such as “Vlan-interface 1 Interface”.
Related commands: display vlan, and display interface Vlan-interface.
# Specify the description string of VLAN 1 as “RESEARCH”.
<device> system-view
[device] vlan 1
[device-vlan1] description RESEARCH
display interface vlan-interface
display interface vlan-interface [ vlan-id ]
View
vlan-id: ID of the specific VLAN interface.
Use the display interface Vlan-interface command to display the information about the VLAN interface.
If the vlan-id argument is specified, the information about the specified VLAN interface is displayed; if the vlan-id argument is not specified, the information about all the created VLAN interfaces is displayed.
Related commands: interface Vlan-interface.
# Display the information about VLAN-interface1.
<device> display interface Vlan-interface 1
Vlan-interface1 current state : DOWN
Line protocol current state : DOWN
IP Sending Frames' Format is PKTFMT_ETHNT_2, Hardware address is 000f-e207-4101
Internet Address is 10.1.1.1/24 Primary
Description : Vlan-interface1 Interface
The Maximum Transmit Unit is 1500
Table 1-1 display interface Vlan-interface command output description
Current state of the VLAN interface
Current state of the link protocol
Format of the frames that IP sends
Hardware address
MAC address corresponding to the VLAN interface
Internet Address
IP address corresponding to the VLAN interface
Description string of the VLAN interface
Maximum transmission unit (MTU)
display vlan
display vlan [ vlan-id [ to vlan-id ] | all | dynamic | static ]
View
vlan-id: VLAN ID, in the range of 1 to 4094.
to: Specifies multiple contiguous VLAN IDs. The VLAN ID after to cannot be less than that before to.
all: Displays the information about all the VLANs.
dynamic: Displays information about the dynamic VLANs (which are registered through GVRP protocol).
static: Displays information about the static VLANs (which are created through manual configuration).
Use the display vlan command to display the information about the specified VLANs or all VLANs.
l          If the vlan-id argument is specified, information about the specified VLAN will be displayed.
l          If the vlan-id argument is not specified, the VLAN IDs of all the existing VLANs will be displayed.
l          If the dynamic or static keyword is specified, this command displays the amount and VLAN IDs of the dynamic or static VLANs.
Related commands: vlan.
# Display the information about VLAN 1.
<device> display vlan 1
 VLAN ID: 1
 VLAN Type: static
 Route Interface: configured
 IP Address: 192.168.0.50
 Subnet Mask: 255.255.255.0
 Description: VLAN 0001
 Tagged   Ports: none
 Untagged Ports:
  GigabitEthernet1/0/1         GigabitEthernet1/0/2         GigabitEthernet1/0/3
  GigabitEthernet1/0/4         GigabitEthernet1/0/5         GigabitEthernet1/0/6
  GigabitEthernet1/0/7         GigabitEthernet1/0/8         GigabitEthernet1/0/9
  GigabitEthernet1/0/10        GigabitEthernet1/0/11        GigabitEthernet1/0/12
  GigabitEthernet1/0/13        GigabitEthernet1/0/14        GigabitEthernet1/0/15
  GigabitEthernet1/0/16        GigabitEthernet1/0/17        GigabitEthernet1/0/18
  GigabitEthernet1/0/19        GigabitEthernet1/0/20        GigabitEthernet1/0/21
  GigabitEthernet1/0/22        GigabitEthernet1/0/23        GigabitEthernet1/0/24
  GigabitEthernet1/0/29
Table 1-2 display vlan command output description
VLAN ID
VLAN ID
VLAN Type
VLAN type (dynamic or static)
Route Interface
Whether the VLAN interface of the VLAN is configured as a route forwarding interface (Whether an IP address is assigned to the VLAN interface)
IP Address
Primary IP address of the VLAN interface
Subnet Mask
Subnet mask of the IP address of the VLAN interface
Name
VLAN name
Tagged Ports
Ports through which packets are sent with VLAN tag kept.
Untagged Ports
Port through which packets are sent with VLAN tag stripped.
interface vlan-interface vlan-id
undo interface vlan-interface vlan-id
View
vlan-id: ID of the VLAN interface, in the range of 1 to 4,094.
Use the interface vlan-interface command to create a VLAN interface and enter VLAN interface view.
Use the undo interface vlan-interface command to delete the VLAN interface.
Related commands: display interface vlan-interface.
l          Before you can create a VLAN interface, you must create the corresponding VLAN.
l          You can configure a maximum number of eight VLAN interfaces on the device.
# Enter VLAN-interface1 view
[device] interface Vlan-interface 1
[device-Vlan-interface1]
name
name text
undo name
View
VLAN view
text: VLAN name, in the range of 1 character to 32 characters. It can contain special characters and spaces.
Use the name command to assign a name to the current VLAN.
Use the undo name command to restore to the default VLAN name.
By default, the name of a VLAN is its VLAN ID, such as “VLAN 0001”.
# Specify the name of VLAN 2 as ”test vlan”.
[device] vlan 2
[device-vlan2] name test vlan
shutdown
shutdown
View
VLAN interface view
None
Use the shutdown command to disable the VLAN interface.
Use the undo shutdown command to enable the VLAN interface.
By default, the VLAN interface is enabled. In this case, the physical status of the VLAN interface is affected by that of the ports in the VLAN.
l          When all the Ethernet ports in the VLAN are down, the VLAN interface of the VLAN is down, that is, the VLAN interface is disabled.
l          When one or more Ethernet ports in the VLAN are up, the VLAN interface of the VLAN is up, that is, the VLAN interface is enabled.
If you disable the VLAN interface, the status of the VLAN interface will always be down, regardless of the status of the ports in the VLAN.
You can use the undo shutdown command to enable a VLAN interface when its related parameters and protocols are configured. When a VLAN interface fails, you can use the shutdown command to disable the interface, and then use the undo shutdown command to enable this interface again, which may restore the interface.
The operation of enabling/disabling a VLAN interface does not influence the status of the Ethernet ports belonging to this VLAN.
# Disable the VLAN-interface2.
[device] interface Vlan-interface 2
[device-Vlan-interface2] shutdown
vlan
vlan vlan-id
undo vlan vlan-id
View
vlan-id: ID of the VLAN which you want to create and whose view you want to enter. This argument ranges from 1 to 4,094.
Use the vlan command to enter VLAN view. If the VLAN identified by the vlan-id argument does not exist, this command creates the VLAN and then enters VLAN view.
Use the undo vlan command to remove the specified VLAN.
l          VLAN 1 is the default VLAN and cannot be removed.
l          When you use the undo vlan command to remove a VLAN which is the default VLAN of a trunk port or a hybrid port on the device, the configuration of the default VLAN of the trunk port or hybrid port does not change after the undo vlan command is executed, that is, the trunk port or the hybrid port will use the removed VLAN (the already non-existing VLAN) as its default VLAN.
l          The VLANs kept by protocol , voice VLAN, management VLAN and the probe VLAN for remote mirroring cannot be removed using the undo vlan command.
# Enter VLAN 1 view.
[device] vlan 1
[device-vlan1]
# Remove VLAN 5.
[device] undo vlan 5
vlan to
vlan { vlan-id1 to vlan-id2 | all }
undo vlan { vlan-id1 to vlan-id2 | all }
View
vlan-id1: ID of the initial VLAN to be created, in the range of 1 to 4,094.
to: Specifies the VLAN range.
vlan-id2: ID of the terminal VLAN to be created, in the range of 1 to 4,094. The value of the argument is no smaller than that of the vlan-id1 argument
all: If the all keyword in the vlan to command is specified, all VLANs (VLAN 1 to 4094) will be created at a time. If the all keyword in the undo vlan to command is specified, all existing VLANs will be removed.
Use the vlan to command to create VLANs in bulk.
Use the undo vlan to command to remove VLANs in bulk.
The undo vlan to command or the undo vlan all command cannot be used to remove the VLANs kept by protocol, the voice VLAN, the default VLAN (VLAN 1), the management VLAN and the probe VLAN for remote mirroring.
# Create VLAN 4 through VLAN 100.
[device] vlan 4 to 100
Please wait............. Done.
# Remove VLAN 2 through VLAN 9 in bulk, in which VLAN 5 is the voice VLAN.
[device] undo vlan 2 to 9
 Note:The VLAN kept by protocol, the voice VLAN,  the default VLAN, the management VLAN and the remote probe VLAN will not be deleted!
 Please wait... Done.
[device] display vlan
The following VLANs exist:
  1(default), 5
The above output information indicates that among VLAN 2 through VLAN 9, VLAN 5 (the voice VLAN) cannot be removed by the undo vlan command, while other VLANs are removed by the command successfully.
Port-Based VLAN Configuration Commands
port
port interface-list
undo port interface-list
View
VLAN view
interface-list: List of Ethernet ports to be added to or removed from a VLAN. You need to provide this argument in the form of interface-list = { interface-type interface-number [ to interface-type interface-number ] } &<1-10>, where:
l          interface-type is port type and interface-number is port number.
l          The port number to the right of the to keyword must be larger than or equal to the one to the left of the keyword.
l          &<1-10> means that you can provide up to 10 ports or ports lists.
Use the port command to add a port or multiple ports to a VLAN.
Use the undo port command to remove a port or multiple ports from a VLAN.
The port command is only applicable to access ports. To add trunk ports and hybrid ports to a VLAN, you can use the port trunk permit vlan and port hybrid vlan commands in Ethernet port view. For related commands, refer to the Basic Port Configuration in H3C WX3000 Series Unified Switches Switching Engine Configuration Guide.
Related commands: display vlan.
# Add GigabitEthernet 1/0/2 through GigabitEthernet 1/0/4 to VLAN 2.
[device] vlan 2
[device-vlan2] port GigabitEthernet 1/0/2 to GigabitEthernet 1/0/4
Protocol-Based VLAN Configuration Commands
display protocol-vlan interface
display protocol-vlan interface { interface-type interface-number [ to interface-type interface-number ] | all }
View
interface-type interface-number [ to interface-type interface-number ]: Specifies the port on which protocol-based VLAN configuration information is displayed. If you do not use the to keyword, only one port is specified. If you use the to keyword, a range of ports are specified. The port number after to must be greater than or equal to that before to. The interface-type argument refers to the port type and the interface-number argument refers to the port number.
all: Displays the protocol-related information about all ports.
Use the display protocol-vlan interface command to display the protocol information and protocol indexes configured for specified ports.
# Display protocol information and protocol index configured for GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2.
<device> display protocol-vlan interface GigabitEthernet 1/0/1 to GigabitEthernet 1/0/2
     VLAN ID  Protocol-Index     Protocol-type
        50          0                ip
        80          1                ip
        100         0                ip
        100         1                ipx ethernetii
        50          1                ipx raw
        80          2                at
        100         3                snap etype 0x0abc
        100         4                llc dsap 0xac ssap 0xbd
display protocol-vlan vlan
display protocol-vlan vlan { vlan-id [ to vlan-id ] | all }
View
vlan-id: VLAN ID in the range of 1 to 4094.
to: Specifies a VLAN ID range. Make sure the vlan-id argument to the right of this keyword is larger than or equal to the argument to the left of this keyword.
all: Specifies to display information about all configured protocol-based VLANs.
Use the display protocol-vlan vlan command to display the protocol information and protocol indexes configured for specified VLANs.
# Display the protocol information and protocol indexes configured for VLAN 10 through VLAN 20.
<device> display protocol-vlan vlan 10 to 20
 VLAN ID: 10
 VLAN Type: Protocol-based VLAN
      Protocol-Index          Protocol-Type
             0                    ip
             1                    ip
             2                    ipx ethernetii
             3                    at
 VLAN ID: 15
             0                    ip
             1                    snap etype 0x0abcd
port hybrid protocol-vlan vlan
port hybrid protocol-vlan vlan vlan-id { protocol-index [ to protocol-index-end ] | all }
undo port hybrid protocol-vlan vlan vlan-id { protocol-index [ to protocol-index-end ] | all }
View
Ethernet port view
protocol-index: Beginning protocol index in the range of 0 to 7.
to: Specifies multiple contiguous protocol indexes.
protocol-index-end: End protocol index in the range of 0 to 7. Note that this argument must be larger than or equal to the protocol-index argument.
all: Specifies all protocol indexes. If the all keyword in the port hybrid protocol-vlan vlan command is specified, this command associates the port with all the protocol indexes of the specified protocol-based VLAN; if the all keyword in the undo port hybrid protocol-vlan vlan command is specified, the command removes the associations between the port and all the protocol indexes of the specified protocol-based VLAN.
Use the port hybrid protocol-vlan vlan command to associate the port with the specified protocol-based VLAN.
Use the undo port hybrid protocol-vlan vlan command to remove the association between the specified protocol-based VLAN and the port.
l          The port hybrid protocol-vlan vlan command can be executed on hybrid ports only.
l          Before you associate a port with the protocol-based VLAN, make sure the port belongs to the protocol-based VLAN.
l          When the undo port hybrid protocol-vlan vlan command is being executed, the device will prompt operation failure if the index of the specified protocol to be removed does not exist. If a part of the specified protocol indexes to be removed do not exist, the device will remove the existing indexes when it prompts errors.
Related commands: display protocol-vlan interface.
# Associate GigabitEthernet 1/0/1 with the protocols indexed from 0 to 4 of VLAN 3 (assuming that VLAN 3 is a protocol-based VLAN).
[device] interface GigabitEthernet 1/0/1
[device-GigabitEthernet1/0/1] port hybrid protocol-vlan vlan 3 0 to 4
protocol-vlan
protocol-vlan [ protocol-index ] { at | ip | ipx { ethernetii | llc | raw | snap } | mode { ethernetii etype etype-id | llc dsap dsap-id ssap ssap-id | snap etype etype-id } }
undo protocol-vlan { protocol-index [ to protocol-index-end ] | all }
View
VLAN view
at: Specifies the VLAN to be an AppleTalk-based VLAN.
ip: Specifies the VLAN to be an IP-based VLAN.
ipx: Specifies the VLAN to be an IPX-based VLAN. The ethernetii, llc, raw and snap keywords specify the four IPX encapsulation types.
mode: Configures user-defined protocol templates.
ethernetii etype-id: Matches the Ethernet II encapsulation format and the corresponding protocol type value of the packet. The etype-id argument ranges from 0x0600 to 0xFFFF.
llc: Matches LLC encapsulation format.
dsap-id: Destination service access point. This argument ranges 0x0000 to 0x00FF.
ssap-id: Source service access point. This argument ranges from 0x0000 to 0x00FF.
snap etype-id: Matches SNAP encapsulation format and the corresponding protocol type value of the packet. The etype-id argument ranges from 0x0600 to 0xFFFF.
protocol-index: Beginning protocol index ranging from 0 to 7. Note that this argument must be less than or equal to the protocol-end argument. If you do not specify this argument, the beginning protocol index will be determined by the system.
protocol-index-end: End protocol index ranging from 0 to 7. Note that this argument must be larger than or equal to the protocol-index argument.
all: Specifies all the protocol indexes.
When you use the mode keyword to configure a user-defined protocol template, if you set the etype-id argument for Ethernet II or SNAP packets to 0x0800, 0x089B, or 0x8137, the matching packets have the same format as that of IP, IPX, and AppleTalk packets respectively. To prevent two commands from processing packets of the same protocol type in different ways, the device will prompt that you cannot set the etype-id argument for Ethernet II or SNAP packets to 0x0800, 0x089B, or 0x8137.
Use the protocol-vlan command to configure the protocol template used for classifying protocol-based VLANs.
Use the undo protocol-vlan command to disable the configuration.
Related commands: display protocol-vlan vlan.
# Configure VLAN 3 as a protocol-based VLAN and assign IP packets to VLAN 3 for transmission.
[device] vlan 3
[device-vlan3] protocol-vlan ip
Because the IP protocol is closely associated with the ARP protocol, you are recommended to configure the ARP protocol type when configuring the IP protocol type and associate the two protocol types with the same port, in case that ARP packets and IP packets are not assigned to the same VLAN, which will cause IP address resolution failure.
# Configure an ARP protocol template. The code for the ARP protocol is 0x0806.
l          Perform the following command when Ethernet encapsulation is used.
[device-vlan3] protocol-vlan mode ethernetii etype 0806
l          Perform the following configuration when 802.3 encapsulation format is used.
[device-vlan3] protocol-vlan mode snap etype 0806
