H3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
HomeSupportWirelessH3C WX3000 Series Unified SwitchesReference GuidesCommand ReferencesH3C WX3000 Series Unified Switches Switching Engine Command Reference-6W103
22-Mirroring Command
22-Mirroring Command 54.66 KB
Mirroring Commands
display mirroring-group
display mirroring-group { group-id | all | local | remote-destination | remote-source }
View
group-id: Number of a port mirroring group, in the range of 1 to 20.
all: Specifies to display the parameter settings of all mirroring groups.
local: Specifies to display the parameter settings of local port mirroring groups.
remote-destination: Specifies to display the parameter settings of the destination groups for remote mirroring.
remote-source: Specifies to display the parameter settings of the source groups for remote mirroring.
Use the display mirroring-group command to display the information of a mirroring group.
Related commands: mirroring-group mirroring-port, mirroring-group monitor-port.
# Display the configuration information about port mirroring group 1.
<device> display mirroring-group 1
mirroring-group 1:
    type: local
    status: active
    mirroring port:
        GigabitEthernet1/0/1  both
    mirroring mac:
    mirroring vlan:
    monitor port: GigabitEthernet1/0/2
Table 1-1 display mirroring-group command output description
type
A mirroring group’s type, including local, remote-source and remote-destination.
status
A mirroring group’s status. “active” for already effective, and “inactive” for not effective yet.
mirroring port
Mirroring source port
both
The direction of packets to be mirrored:
l      both: mirrors the packets received on and sent by the port.
l      inbound: mirrors the packets received on the port.
l      outbound: mirrors the packets sent by the port.
mirroring mac
The specified MAC address and VLAN ID for MAC-based mirroring
mirroring vlan
The specified VLAN ID for VLAN-based mirroring
monitor port
Mirroring destination port
mirroring-group
mirroring-group group-id { local | remote-destination | remote-source }
undo mirroring-group { group-id | all | local | remote-destination | remote-source }
View
group-id: Number of a port mirroring group, in the range 1 to 20.
all: Specifies to remove all mirroring groups.
local: Specifies the mirroring group as a local port mirroring group.
remote-destination: Specifies the mirroring group as the destination mirroring group for remote port mirroring.
remote-source: Specifies the mirroring group as the source mirroring group for remote port mirroring.
Use the mirroring-group command to configure a port mirroring group.
Use the undo mirroring-group command to remove a port mirroring group.
Related commands: display mirroring-group.
# Configure a port mirroring group on the local device.
<device> system-view
[device] mirroring-group 1 local
mirroring-group mirroring-mac
mirroring-group group-id mirroring-mac mac vlan vlan-id
undo mirroring-group group-id mirroring-mac [ [ mac ] vlan vlan-id ]
View
mac: Specified MAC address, in the format of H-H-H. The MAC address must be a static one existing in the MAC address table.
vlan vlan-id: Specifies the VLAN to which the static MAC address belongs.
Use the mirroring-group mirroring-mac command to configure the MAC-based mirroring for a local or remote source mirroring group.
Use the undo mirroring-group mirroring-mac command to remove the configuration.
# Configure MAC-based mirroring to mirror packets whose source/destination MAC addresses match 000f-e20f-0101 to port GigabitEthernet 1/0/2 on the local device.
[device] mac-address static 000f-e20f-0101 interface Gigabitethernet 1/0/1 vlan 2
[device] mirroring-group 1 mirroring-mac 000f-e20f-0101 vlan 2
[device] mirroring-group 1 monitor-port GigabitEthernet 1/0/2
mirroring-group group-id mirroring-port mirroring-port-list { both | inbound | outbound }
undo mirroring-group group-id mirroring-port mirroring-port-list
View
System view/Ethernet port view
mirroring-port mirroring-port-list: Specifies a list of source ports. mirroring-port-list is available in system view only, and there is no such argument in Ethernet port view. mirroring-port-list is provided in the format of mirroring-port-list = { interface-type interface-number [ to interface-type interface-number ] }&<1-8>, where interface-type is the port type, and interface-number is the port number, and &<1-8> means that you can specify up to 8 ports or port lists.
both: Specifies to mirror the packets received on and sent from the port.
inbound: Specifies to mirror the packets received on the port.
outbound: Specifies to mirror the packets sent from the port.
Use the mirroring-group mirroring-port command to configure the source ports for a local mirroring group or a remote source mirroring group.
Use the undo mirroring-group mirroring-port command to remove the source ports of a local mirroring group or a remote source mirroring group.
Note that you cannot configure a member port of an existing mirroring group as a source port for port mirroring.
# Configure GigabitEthernet 1/0/1 as the source port of local mirroring group 1, and mirror all packets received on this port.
[device] mirroring-group 1 mirroring-port GigabitEthernet 1/0/1 inbound
mirroring-group mirroring-vlan
mirroring-group group-id mirroring-vlan vlan-id inbound
undo mirroring-group group-id mirroring-vlan [ vlan-id inbound ]
View
mirroring-vlan vlan-id: Specifies a VLAN. The vlan-id argument ranges from 1 to 4094. The specified VLAN must be an existing VLAN on the device.
inbound: Specifies to mirror packets received on all ports of the VLAN.
Use the mirroring-group mirroring-vlan command to configure the VLAN-based mirroring for a local or remote source mirroring group.
Use the undo mirroring-group mirroring-vlan command to remove the configuration.
You can monitor packets of multiple VLANs by executing the mirroring-group mirroring-vlan command for several times.
# Configure VLAN-based mirroring to mirror packets received on all ports in VLAN 2 to port GigabitEthernet 1/0/2 on the local device.
[device] mirroring-group 1 mirroring-vlan 2 inbound
mirroring-group group-id monitor-port monitor-port
undo mirroring-group group-id monitor-port monitor-port
View
monitor-port monitor-port: Specifies the destination port for port mirroring. monitor-port is available in system view only, and there is no such argument in Ethernet port view.
Use the mirroring-group monitor-port command to configure the destination port for a local mirroring group or a remote destination mirroring group.
Use the undo mirroring-group monitor-port to remove the destination port of a local mirroring group or a remote destination mirroring group.
Note that you cannot configure a member port of an existing mirroring group, a member port of an aggregation group, or a port enabled with LACP or STP as the destination port.
# Configure GigabitEthernet 1/0/4 as the destination port of local mirroring group 1.
[device] mirroring-group 1 monitor-port GigabitEthernet 1/0/4
mirroring-group reflector-port
mirroring-group group-id reflector-port reflector-port
undo mirroring-group group-id reflector-port reflector-port
View
reflector-port reflector-port: Specifies the reflector port. reflector-port is available in system view only, and there is no such argument in Ethernet port view.
Use the mirroring-group reflector-port command to specify the reflector port for a remote source mirroring group.
Use the undo mirroring-group reflector-port command to remove the reflector port of a remote source mirroring group.
Note the following when you configure the reflector port:
l          The reflector port cannot be a member port of an existing mirroring group, a member port of an aggregation group, or a port enabled with LACP or STP. It must be an access port and cannot be configured with the functions like VLAN-VPN, port loopback detection, QoS, port security, and so on.
l          You cannot modify the duplex mode, port rate, and MDI attribute of a reflector port.
# Configure GigabitEthernet 1/0/2 as the reflector port of remote source mirroring group 1.
[device] mirroring-group 1 remote-source
[device] mirroring-group 1 reflector-port GigabitEthernet 1/0/2
mirroring-group remote-probe vlan
mirroring-group group-id remote-probe vlan remote-probe-vlan-id
undo mirroring-group group-id remote-probe vlan remote-probe-vlan-id
View
remote-probe vlan remote-probe-vlan-id: Specifies the remote-probe VLAN for the mirroring group.
Use the mirroring-group remote-probe vlan command to specify the remote-probe VLAN for a remote source/destination mirroring group.
Use the undo mirroring-group remote-probe vlan command to remove the configuration of remote-probe VLAN for a remote source/destination mirroring group.
# Configure VLAN 100 as the remote-probe VLAN of remote source mirroring group 1.
[device] mirroring-group 1 remote-probe vlan 100
mirroring-port
mirroring-port { both | inbound | outbound }
undo mirroring-port
View
Ethernet port view
both: Specifies to mirror all packets received on and sent from the port.
Use the mirroring-port command to configure the source port.
Use the undo mirroring-port command to remove the configuration of the source port.
When you configure mirroring source port on an Ethernet port, if local mirroring group 1 does not exist, the device creates the group and adds the port to the group; if local mirroring group 1 already exists, but is not a local mirroring group, your configuration of the source port will fail.
# Configure GigabitEthernet 1/0/1 as the source port, and mirror all packets received on and sent from this port.
[device] interface GigabitEthernet 1/0/1
[device-GigabitEthernet1/0/1] mirroring-port both
monitor-port
monitor-port
undo monitor-port
View
Ethernet port view
None
Use the monitor-port command to configure the destination port.
Use the undo monitor-port command to remove the configuration of the destination port.
Note that you cannot configure a member port of an aggregation group, a member port of an aggregation group, or a port enabled with LACP and STP as the mirroring destination port.
When you configure mirroring destination port on an Ethernet port, if local mirroring group 1 does not exist, the device creates the group and adds the port to the group; if local mirroring group 1 already exists, but is not a local mirroring group, your configuration of the destination port will fail.
# Configure GigabitEthernet 1/0/4 as the destination port.
[device] interface GigabitEthernet 1/0/4
[device-GigabitEthernet1/0/4] monitor-port
remote-probe vlan
remote-probe vlan enable
undo remote-probe vlan enable
View
VLAN view
None
Use the remote-probe vlan enable command to configure the current VLAN as the remote-probe VLAN.
Use the undo remote-probe vlan enable command to restore the remote-probe VLAN to a normal VLAN.
Note that you cannot configure a default VLAN, a management VLAN, or a dynamic VLAN as the remote-probe VLAN.
# Configure VLAN 5 as the remote-probe VLAN.
[device] vlan 5
[device-vlan5] remote-probe vlan enable
