04-组播路由与转发命令
本章节下载: 04-组播路由与转发命令 (389.44 KB)
1.1.1 delete ip rpf-route-static
1.1.3 display multicast boundary
1.1.4 display multicast fast-forwarding cache
1.1.5 display multicast flow-statistic
1.1.6 display multicast forwarding event
1.1.7 display multicast forwarding-table
1.1.8 display multicast global statistics
1.1.9 display multicast routing-table
1.1.10 display multicast routing-table static
1.1.11 display multicast rpf-info
1.1.13 load-splitting (MRIB view)
1.1.14 longest-match (MRIB view)
1.1.16 multicast forwarding-table cache-unknown per-entry
1.1.17 multicast forwarding-table cache-unknown total
1.1.19 multicast frr monitor cycle
1.1.23 multicast rpf-fail-pkt flooding
1.1.24 multicast rpf-fail-pkt trap-to-cpu
1.1.25 reset multicast fast-forwarding cache
1.1.26 reset multicast forwarding event
1.1.27 reset multicast forwarding-table
1.1.28 reset multicast routing-table
1.1.29 snmp-agent trap enable mrib
delete ip rpf-route-static命令用来删除所有组播静态路由。
vpn-instance vpn-instance-name:指定VPN实例,vpn-instance-name表示MPLS L3VPN的VPN实例名称,为1~31个字符的字符串,区分大小写。如果未指定本参数,则表示指定公网。
本命令用来删除所有的组播静态路由,而undo ip rpf-route-static命令则用来删除指定的组播静态路由。
# 删除公网中的所有组播静态路由。
[Sysname] delete ip rpf-route-static
This will erase all multicast static routes and their configurations, you must reconfigure all static routes.
Are you sure?[Y/N]:y
· ip rpf-route-static
display mrib interface命令用来显示MRIB(Multicast Routing Information Base,组播路由信息库)维护的接口信息。
interface-type interface-number:显示指定接口上MRIB维护的接口信息。如果未指定本参数,将显示所有接口上MRIB维护的接口信息。
# 显示公网接口上MRIB维护的接口信息。
<Sysname> display mrib interface
Interface: Ten-GigabitEthernet3/1/1
Index: 0x00004444
Current state: up
MTU: 1500
Type: BROADCAST
Protocol: PIM-DM
PIM protocol state: Enabled
Address list:
1. Local address : 8.12.0.2/16
Remote address: 0.0.0.0
Reference : 1
State : NORMAL
Interface: Multicast-UA0
Index: 0xd0000001
Current state: up
MTU: 0
Type: MUA
Protocol: IGMP
PIM protocol state: Disabled
User ID: 0x1
VLAN ID: 100
Second VLAN ID: 10
Access type: IPoE
Access interface: Ten-GigabitEthernet3/1/1.1
Address list:
1. Local address : 127.1.1.11/32
Reference : 3
State : NORMAL
表1-1 display mrib interface命令显示信息描述表
接口的名称 |
Index |
接口的索引号 |
Current state |
接口的状态,包括up和down |
MTU |
MTU(Maximum Transmission Unit,最大传输单元)值 |
Type |
接口的类型,包括: · BROADCAST:表示广播链路接口 · P2P:表示P2P接口 · LOOP:表示LoopBack接口 · REGISTER:表示注册接口 · NBMA:表示NBMA接口 · MTUNNEL:表示组播隧道接口 · MUA:表示Multicast-UA接口 如果接口为NULL0接口,则该字段显示为为空 |
Protocol |
接口的协议类型标记,包括PIM-DM、PIM-SM、IGMP、PROXY和MD |
PIM protocol state |
PIM协议的使能状态,包括: · Enabled:表示使能 · Disabled:表示关闭 |
User ID |
用户ID |
VLAN ID |
用户带VLAN Tag接入时所携带的外层(或唯一一层)VLAN编号。如果不带VLAN Tag接入,则不显示本字段 |
Second VLAN ID |
用户带VLAN Tag接入时所携带的内层VLAN编号。如果不带VLAN Tag接入,则不显示本字段 |
Access type |
用户接入的方式: · IPoE:表示IPoE方式 · PPP:表示PPP方式 |
Access interface |
用户接入的实际接口 |
Address list |
接口地址列表 |
Local address |
本端的地址 |
Remote address |
远端的地址(仅Vlink类型接口有效) |
Reference |
地址被引用的次数 |
State |
接口地址的状态,包括NORMAL和DEL |
display multicast boundary命令用来显示组播边界的信息。
group-address:显示指定组播组的组播边界信息,取值范围为224.0.0.0~239.255.255.255。如果未指定本参数,将显示所有组播组的组播边界信息。
mask-length:指定组播组地址的掩码长度,取值范围为4~32,缺省值为32。
mask:指定组播组地址的掩码,缺省值为255.255.255.255。
interface interface-type interface-number:显示指定接口上的组播边界信息,interface-type interface-number表示接口类型和接口编号。如果未指定本参数,将显示所有接口上的组播边界信息。
# 显示公网所有接口上所有组播组的组播边界信息。
<Sysname> display multicast boundary
Boundary Interface
224.1.1.0/24 XGE3/1/1
239.2.2.0/24 XGE3/1/2
表1-2 display multicast boundary命令显示信息描述表
Boundary |
表示组播边界对应的组播组 |
表示组播边界对应的接口 |
· multicast boundary
display multicast fast-forwarding cache命令用来显示组播快速转发表信息。
(独立运行模式)
display multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache [ source-address | group-address ] * [ slot slot-number ]
display multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache [ source-address | group-address ] * [ chassis chassis-number slot slot-number ]
source-address:组播源地址,显示包含指定组播源的组播快速转发项。
group-address:组播组地址,显示指定组播组的组播快速转发项,取值范围为224.0.1.0~239.255.255.255。
slot slot-number:指定单板。slot-number为单板所在的槽位号。如果不指定本参数,则表示指定主用主控板。(独立运行模式)
chassis chassis-number slot slot-number:指定单板。chassis-number表示设备在IRF中的成员编号,slot-number表示单板所在的槽位号。如果不指定本参数,则表示指定Master设备主用主控板。(IRF模式)
# 显示公网组播快转表项的信息。
<Sysname> display multicast fast-forwarding cache
Total 1 entries, 1 matched
(60.1.1.200, 225.0.0.2)
Status : Enabled
Source port: 2001 Destination port: 2002
Protocol : 2 Flag : 0x2
Incoming interface: Ten-GigabitEthernet3/1/3
List of 1 outgoing interfaces:
Ten-GigabitEthernet3/1/2
Status: Enabled Flag: 0x14
表1-3 display multicast fast-forwarding cache命令显示信息描述表
Total 1 entries, 1 matched |
组播快速转发表中(S,G)表项的总数和匹配数 |
(60.1.1.200, 225.0.0.2) |
表示组播转发表的(S,G)表项 |
Source port |
源端口号 |
Destination port |
目的端口号 |
Protocol |
协议号 |
Flag |
(S,G)表项的状态,通过将不同的比特位置位来表示不同的状态: · 0x1:表示由板间透传的报文触发创建的表项 · 0x2:表示组播转发流程添加的表项 (S,G)表项出接口状态,通过将不同的比特位置位来表示不同的状态: · 0x1:表示由板间透传的报文触发创建的出接口 · 0x2:表示向已存在的快转表项增添的出接口 · 0x4:表示需要设置MAC地址 · 0x8:表示入VLAN口或者入Super VLAN口对应的出接口 · 0x10:表示出接口已经与会话建立关联关系 · 0x20:表示待删除的出接口 · 其他取值:由上述取值组合相加,比如0x14是由0x4与0x10组合相加,表示该接口需要设置MAC地址且出接口已经与会话建立关联关系 |
Status |
组播快转表项入cache和出cache的状态,包括Enabled和Disabled |
Incoming interface |
表示(S,G)表项的入接口 |
List of 1 outgoing interfaces |
表示(S,G)表项的出接口列表 |
· reset multicast fast-forwarding cache
display multicast flow-statistic命令用来显示组播流量统计结果。
display multicast flow-statistic source source-address group group-address interface interface-type interface-number [ s-vlan svlan-id [ c-vlan cvlan-id ] ] { inbound | outbound }
source source-address:指定组播源的地址。
group group-address:指定组播组地址,取值范围为224.0.1.0~239.255.255.255。
interface interface-type interface-number:接口类型和接口编号,显示指定接口上组播流量统计结果。
s-vlan svlan-id:指定封装的外层VLAN Tag,svlan-id的取值范围为1~4094。
c-vlan cvlan-id:指定封装的内层VLAN Tag,cvlan-id的取值范围为1~4094。
inbound:显示入方向的组播流量统计结果。
outbound:显示出方向的组播流量统计结果。
执行本命令时,若同时未指定s-vlan和c-vlan参数,将显示所有VLAN的组播流量统计信息。
在组播流量转发路径上的各台设备上执行本命令,可以查看每台设备上的组播流量统计信息,以便根据统计信息定位转发故障发生的节点。例如,在IPTV业务中,组播报文丢失会严重影响用户视频体验,此时可以利用本命令的显示结果快速定位故障节点的位置。
若需显示指定聚合接口上组播流量统计结果,则interface interface-type interface-number应指定该聚合接口。若interface interface-type interface-number指定聚合组内的成员端口,则无法获取统计信息。
# 显示接口Ten-GigabitEthernet3/1/1接收到的来自组播源110.11.0.2、发往组播组225.0.0.1的组播流量。
<Sysname> display multicast flow-statistic source 110.11.0.2 group 225.0.0.1 interface ten-gigabitethernet 3/1/1 inbound
Matched 512 packets in 2 seconds, 128 packets/sec.
Matched 20480 bytes in 2 seconds, 10240 bytes/sec.
表1-4 display multicast flow-statistic命令显示信息描述表
Matched 512 packets in 2 seconds, 128 packets/sec. |
2秒内收到的包数和包速率 |
Matched 20480 bytes in 2 seconds, 10240 bytes/sec. |
2秒内收到的字节数和字节速率 |
display multicast forwarding event命令用来显示组播转发的事件统计信息。
(独立运行模式)
display multicast [ vpn-instance vpn-instance-name ] forwarding event [ slot slot-number ]
display multicast [ vpn-instance vpn-instance-name ] forwarding event [ chassis chassis-number slot slot-number ]
# 显示公网组播转发的事件统计信息。
<Sysname> display multicast forwarding event
Total active events sent: 0
Total inactive events sent: 0
Total NoCache events sent: 2
Total NoCache events dropped: 0
Total WrongIF events sent: 0
Total WrongIF events dropped: 0
Total SPT switch events sent: 0
NoCache rate limit: 1024 packets/s
WrongIF rate limit: 1 packets/10s
Total timer of register suppress timeout: 0
表1-5 display multicast forwarding event命令显示信息描述表
Total active events sent |
表项活跃事件的发送次数 |
Total inactive events sent |
表项不活跃事件的发送次数 |
Total NoCache events sent |
NoCache事件的发送次数 |
Total NoCache events dropped |
NoCache事件的丢弃次数 |
Total WrongIF events sent |
WrongIF事件的发送次数 |
Total WrongIF events dropped |
WrongIF事件的丢弃次数 |
Total SPT switch events sent |
SPT切换事件的发送次数 |
NoCache rate limit |
NoCache事件的发送限速,单位为报文/秒 |
WrongIF rate limit |
WrongIF事件的发送限速,单位为报文/10秒 |
Total timer of register suppress timeout |
注册抑制超时的总次数 |
· reset multicast forwarding event
display multicast forwarding-table命令用来显示组播转发表的信息。
(独立运行模式)
display multicast [ vpn-instance vpn-instance-name ] forwarding-table [ source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number | chassis chassis-number slot slot-number | statistics ] *
source-address:组播源地址,显示包含指定组播源的组播转发项。
group-address:组播组地址,显示指定组播组的组播转发项,取值范围为224.0.0.0~239.255.255.255。
mask-length:指定组播组或组播源地址的掩码长度。对于组播组地址,其取值范围为4~32,缺省值为32;对于组播源地址,其取值范围为0~32,缺省值为32。
mask:指定组播组或组播源地址的掩码,缺省值为255.255.255.255。
incoming-interface:显示指定入接口的组播转发项。
interface-type interface-number:显示指定接口类型和接口编号的入接口的组播转发项。
outgoing-interface:显示指定出接口的组播转发项。
exclude:显示出接口列表中不包含指定接口的组播转发项。
include:显示出接口列表中包含指定接口的组播转发项。
match:显示出接口列表中包含且仅包含指定接口的组播转发项。
statistics:显示组播转发表的统计信息。
# 显示公网组播转发表的信息。
<Sysname> display multicast forwarding-table
00001. (172.168.0.2, 227.0.0.1)
Flags: 0x0
Incoming interface: Ten-GigabitEthernet3/1/1
Backup incoming interface: Ten-GigabitEthernet3/1/3
List of 1 outgoing interface:
1: Ten-GigabitEthernet3/1/2 (inactive)
Matched 19648 packets(20512512 bytes), Wrong If 0 packet
Forwarded 0 packets(0 bytes)
表1-6 display multicast forwarding-table命令显示信息描述表
组播转发表中(S,G)表项的总数和匹配数 |
00001 |
表示(S,G)表项的序号 |
(172.168.0.2,227.0.0.1) |
表示组播转发表的(S,G)表项 |
Flags |
(S,G)表项的状态,通过将不同的比特位置位来表示不同的状态: · 0x0:表示正常表项 · 0x1:表示表项处于Inactive状态 · 0x2:表示空转发表项 · 0x4:表示表项下刷失败 · 0x8:表示有出接口下刷失败 · 0x10:表示下刷Data-Group失败 · 0x20:表示表项有注册出接口 · 0x40:表示表项即将被删除 · 0x80:表示表项处于注册抑制状态 · 0x100:表示表项正在被删除 · 0x200:表示表项处于平滑状态 · 0x800:表示表项中存在到组播源地址的ARP表项 · 0x4000000:表示表项由IGMP代理下发创建 |
Uptime |
表示(S,G)表项已存在时间 |
Timeout in |
表示(S,G)表项的超时剩余时间 |
表示(S,G)表项的入接口,当存在(S,G)表项的备入接口时,此字段表示主入接口 |
Backup incoming interface |
(S,G)表项的备入接口,当(S,G)表项的主入接口发生故障时,从备入接口到达的组播数据才会转发给接收者 |
表示(S,G)表项的出接口列表,如果某个出接口不参与组播数据转发,则会在该接口后面显示(inactive) |
Matched 19648 packets (20512512 bytes), Wrong If 0 packet |
(S,G)表项匹配的报文数量(字节数),发生入接口错误的报文个数 |
Forwarded 19648 packets (20512512 bytes) |
(S,G)表项已转发的组播报文数量(字节数) |
· reset multicast forwarding-table
display multicast global statistics命令用来显示全局PIM表项限制配置和统计信息。
display multicast global pim sm statistics
pim sm:显示PIM-SM模式下的全局PIM表项限制配置和统计信息。
# 显示PIM-SM模式下的全局PIM表项限制配置和统计信息。
<Sysname> display multicast global pim sm statistics
PIM-SM Number Limit Threshold(Upper Lower)
(*, G) 4 2000 80 50
(S, G) 0 1000 80 70
表1-7 display multicast global statistics命令显示信息描述表
PIM-SM |
PIM-SM模式下的全局PIM表项限制配置和统计信息,包括(*, G)和(S, G)表项 |
Number |
当前已创建的PIM表项数目 |
Limit |
配置的全局PIM表项数目的最大值,未配置显示为“--” |
Threshold(Upper Lower) |
全局PIM表项数目预警上限/下限阈值,未配置显示为“--” |
· multicast global limit
display multicast routing-table命令用来显示组播路由表的信息。
source-address:组播源地址,显示包含指定组播源的组播路由项。
group-address:组播组地址,显示指定组播组的组播路由项,取值范围为224.0.0.0~239.255.255.255。
incoming-interface:显示指定入接口的组播路由项。
interface-type interface-number:显示指定接口类型和接口编号的入接口的组播路由项。
outgoing-interface:显示指定出接口的组播路由项。
exclude:显示出接口列表中不包含指定接口的组播路由项。
include:显示出接口列表中包含指定接口的组播路由项。
match:显示出接口列表中包含且仅包含指定接口的组播路由项。
组播路由表是进行组播数据转发的基础,通过查看该表可以了解(S,G)表项等的建立情况。
# 显示公网组播路由表的信息。
<Sysname> display multicast routing-table
Total 1 entries
Uptime: 00:00:28
Upstream Interface: Ten-GigabitEthernet3/1/1
Backup Upstream Interface: Ten-GigabitEthernet3/1/4
List of 2 downstream interfaces
2: Ten-GigabitEthernet3/1/3
表1-8 display multicast routing-table命令显示信息描述表
Total 1 entries |
组播路由表中(S,G)表项的总数 |
00001 |
表示(S,G)表项的序号 |
(172.168.0.2, 227.0.0.1) |
表示组播路由表的(S,G)表项 |
Uptime |
表示(S,G)表项已经存在的时间 |
Upstream Interface |
表示(S,G)表项的上游接口,表示组播数据应该从此接口到达;当(S,G)表项存在上游备接口时,此字段表示上游主接口 |
Backup Upstream Interface |
(S,G)表项的上游备接口,当(S,G)表项的上游主接口发生故障时,从上游备入接口到达的组播数据才会转发给接收者 |
List of 2 downstream interfaces |
下游接口列表,表示哪些接口需要进行组播转发 |
· reset multicast routing-table
display multicast routing-table static命令用来显示组播静态路由表的信息。
source-address:显示指定组播源的组播静态路由信息。
mask-length:指定组播源地址的掩码长度,取值范围为0~32。
mask:指定组播源地址的掩码。
本命令只显示已生效的组播静态路由信息。
# 显示公网组播静态路由表的信息。
<Sysname> display multicast routing-table static
Destinations: 3 Routes: 4
Destination/Mask Pre RPF neighbor Interface
1.1.0.0/16 10 7.12.0.1 XGE3/1/1
7.11.0.1 XGE3/1/2
2.2.2.0/24 20 7.11.0.1 XGE3/1/3
3.3.3.3/32 50 7.12.0.1 XGE3/1/4
表1-9 display multicast routing-table static命令显示信息描述表
Destinations |
目的地址个数 |
Routes |
路由条数 |
Destination/Mask |
目的地址和掩码长度 |
Pre |
路由优先级 |
RPF neighbor |
可达目的地址的RPF邻居IP地址 |
可达目的地址的出接口 |
display multicast rpf-info命令用来显示组播源的RPF信息。
source-address:显示指定组播源的RPF信息。
group-address:显示指定组播组的RPF信息,取值范围为224.0.1.0~239.255.255.255。
# 显示公网组播源192.168.1.55的全部RPF信息。
<Sysname> display multicast rpf-info 192.168.1.55
RPF information about source 192.168.1.55:
RPF interface: Ten-GigabitEthernet3/1/1, RPF neighbor: 10.1.1.1
Backup RPF interface: Ten-GigabitEthernet3/1/2, backup RPF neighbor: 2.2.2.2
Referenced route/mask: 192.168.1.0/24
Referenced route type: igp
Load splitting rule: disable
Source AS: 0
C-multicast route target: 0x0000000000000000
表1-10 display multicast rpf-info命令显示信息描述表
RPF information about source 192.168.1.55 |
到组播源192.168.1.55的RPF路径信息 |
RPF interface |
表示RPF接口名称,当存在备RPF接口时,此字段表示主RPF接口 |
Backup RPF interface |
备RPF接口名称 |
RPF neighbor |
表示RPF邻居,当存在备份RPF邻居时,此字段表示主RPF邻居 |
backup RPF neighbor |
备份RPF邻居 |
Referenced route/mask |
表示引用的路由及其掩码长度 |
Referenced route type |
表示引用的路由类型,可以是下列类型之一: · igp:单播路由(内部网关协议) · egp:单播路由(外部网关协议) · unicast (direct):单播路由(直连) · unicast:其它单播路由(如单播静态路由等) · multicast static:组播静态路由 · mbgp:MBGP路由 |
Route selection rule |
RPF路由选择规则,可以是根据路由协议的路由优先级进行选择,或者是按照目的地址对路由表进行最长匹配 |
Load splitting rule |
是否使能了负载分担规则 |
Source AS |
组播源所在PE的AS号 |
C-multicast route target |
C-multicast路由扩展团体属性 |
· display multicast forwarding-table
· display multicast routing-table
ip rpf-route-static命令用来配置组播静态路由。
undo ip rpf-route-static命令用来删除指定的组播静态路由。
ip rpf-route-static [ vpn-instance vpn-instance-name ] source-address { mask-length | mask } { rpf-nbr-address | interface-type interface-number } [ preference preference ] [ description text ]
undo ip rpf-route-static [ vpn-instance vpn-instance-name ] source-address { mask-length | mask } { rpf-nbr-address | interface-type interface-number }
不存在组播静态路由。
source-address:指定组播源地址。
mask:指定组播源地址的掩码。
rpf-nbr-address:指定RPF邻居的IP地址。
interface-type interface-number:指定与RPF邻居相连接口的接口类型和接口编号。
preference:指定路由优先级,取值范围为1~255,缺省值为1。
text:配置组播静态路由描述信息,取值范围为1~60个字符,区分大小写。除“?”外,可以包含空格等特殊字符。
只有点到点类型的接口才能使用指定接口的方式来指定RPF邻居,非点到点类型的接口(包括三层以太网接口、三层聚合接口、Loopback接口或VLAN接口等)不能使用此方式,只能使用指定地址的方式。
配置的组播静态路由并不一定会生效,因为可能出现指定的RPF邻居无法迭代出接口、指定的RPF接口不属于本实例、指定的RPF接口不是点到点类型或处于down状态等情况。此外,若在相同组播源地址范围下有多条配置,只有路由优先级最高的那条才能被激活。因此,配置完成后建议使用display multicast routing-table static命令显示该组播静态路由是否已生效。
undo ip rpf-route-static命令用来删除指定的组播静态路由,而delete ip rpf-route-static命令则用来删除所有的组播静态路由。
# 在公网中配置到组播源10.1.1.0/24的组播静态路由,其RPF邻居的地址是192.168.1.23。
[Sysname] ip rpf-route-static 10.1.1.0 24 192.168.1.23
· delete ip rpf-route-static
· display multicast routing-table static
load-splitting命令用来配置对组播流量进行负载分担。
undo load-splitting命令用来恢复缺省情况。
load-splitting { balance-ecmp | balance-ucmp | ecmp | source | source-group | ucmp }
undo load-splitting
不对组播流量进行负载分担。
MRIB视图
balance-ecmp:根据等价路由均匀地对组播流量进行负载分担。
balance-ucmp:根据链路带宽均匀地对组播流量进行负载分担。
ecmp:根据等价路由对组播流量进行负载分担。
source:仅根据组播源地址对组播流量进行负载分担。
source-group:根据组播源地址和组播组地址对组播流量进行负载分担。
ucmp:根据链路带宽对组播流量进行负载分担。
balance-ecmp、ecmp、source和source-group用于在等价链路环境中实现组播流量的负载分担;balance-ucmp、ucmp方式用于在非等价链路环境中实现组播流量的负载分担。
· 配置ecmp方式后网络中等价链路的增删对组播流量的影响较大。
· 配置source和source-group方式后网络中链路增删对组播流量的影响较小,适合等价链路不稳定的情况。
· balance-ecmp和balance-ucmp方式采用轮询机制分担,相比于ecmp和ucmp方式网络的稳定性及均衡性更好。
# 在公网中配置仅根据组播源地址对组播流量进行负载分担。
[Sysname] multicast routing
[Sysname-mrib] load-splitting source
longest-match命令用来配置按照最长匹配来选择RPF路由,即选择掩码最长的路由作为RPF路由。
undo longest-match命令用来恢复缺省情况。
longest-match
undo longest-match
选择路由优先级最高的路由作为RPF路由。
MRIB视图
# 在公网中配置按照最长匹配原则选择RPF路由。
[Sysname-mrib] longest-match
multicast boundary命令用来配置组播转发边界。
undo multicast boundary命令用来删除组播转发边界。
undo multicast boundary { group-address { mask-length | mask } | all }
未在接口上配置组播转发边界。
group-address:指定组播组地址,取值范围为224.0.0.0~239.255.255.255。
mask-length:指定组播组地址的掩码长度,取值范围为4~32。
mask:指定组播组地址的掩码。
all:删除该接口上配置的所有组播转发边界。
组播转发边界为指定地址范围的组播组划定了边界条件,如果组播报文的目的地址与边界条件匹配,就停止转发。
一个接口可以作为不同地址范围的组播组的转发边界,即允许在同一接口上多次执行本命令为不同地址范围的组播组设定转发边界。
执行本命令不需要使能IP组播路由。
假设A和B为不同地址范围的组播组的集合,且B是A的真子集:如果接口先配置为A的转发边界,再配置为B的转发边界,则该接口仍然为A的转发边界;如果接口先配置为B的转发边界,再配置为A的转发边界,则该接口将变为A的转发边界。
在接口上线的可控组播用户不受该接口下配置的组播转发边界的限制,仍可以加入组播转发边界指定地址范围的组播组。
# 将接口Ten-GigabitEthernet3/1/1配置为地址范围为239.2.0.0/16的组播组的转发边界。
[Sysname] interface ten-gigabitethernet 3/1/1
[Sysname-Ten-GigabitEthernet3/1/1] multicast boundary 239.2.0.0 16
· display multicast boundary
multicast forwarding-table cache-unknown per-entry命令用来设置对于同一个(S,G)表项,可缓存的最大未知组播数据报文数目。
undo multicast forwarding-table cache-unknown per-entry命令用来恢复缺省情况。
multicast forwarding-table cache-unknown per-entry per-entry-limit
对于同一个(S,G)表项,可缓存的最大未知组播数据报文数目为1。
per-entry-limit:设置对于同一个(S,G)表项,可缓存的最大未知组播数据报文数目,取值范围为0~256。当取值为0时,代表不可缓存未知组播数据报文。
# 设置对于同一个(S,G)表项,可缓存的最大未知组播数据报文数目为20。
[Sysname] multicast forwarding-table cache-unknown per-entry 20
· multicast forwarding-table cache-unknown total
multicast forwarding-table cache-unknown total命令用来设置内存中缓存的未知组播数据报文的总数量。
undo multicast forwarding-table cache-unknown total命令用来恢复缺省情况。
multicast forwarding-table cache-unknown total total-limit
内存中缓存的未知组播数据报文的总数量为1024。
total-limit:设置内存中缓存的未知组播数据报文的总数量,取值范围为0~65535。当取值为0时,代表不可缓存未知组播数据报文。
建议本命令配置的值要远远大于multicast forwarding-table cache-unknown per-entry命令配置的值。
# 设置内存中缓存的未知组播数据报文的总数量为10000。
[Sysname] multicast forwarding-table cache-unknown total 10000
· multicast forwarding-table cache-unknown per-entry
multicast frr mode命令用来配置组播FRR的工作模式。
undo multicast frr mode命令用来恢复缺省情况。
multicast frr mode [ by-entry | by-iif ]
组播FRR的工作模式为按表项检测模式。
by-entry:按表项检测模式。在此模式下,当开启了组播FRR功能后,设备将周期性的针对每条表项进行主备入接口流量的检测。
by-iif:按入接口检测模式。在此模式下,当开启了组播FRR功能后,设备会将主备入接口均相同的组播表项划分为一组,然后周期性对这组表项进行主备入接口流量的检测。
当设备上开启组播FRR(Fast Reroute,快速重路由)功能后,同一个(S,G)表项将会存在主备入接口,同时将会周期性检测主备入接口的组播流量。当检测到组播流量未从主入接口到达,表示主入接口存在故障,此时会将该表项的入接口切换到备份入接口。
当设备上的组播表项较多,且这些表项中的大部分表项的主备入接口均相同,此时推荐将组播FRR的工作模式配置为按入接口检测模式。
目前只有PIM支持组播FRR,有关PIM FRR的详细介绍,请参见“IP组播配置指导”中的“PIM”。
# 配置组播FRR的工作模式为按入接口检测模式。
[Sysname] multicast frr mode by-iif
· rpf-frr enable(IP组播命令参考/PIM)
multicast frr monitor cycle命令用来配置组播FRR监测主备链路状态的周期。
undo multicast frr monitor cycle命令用来恢复缺省情况。
multicast frr monitor cycle monitor-time
组播FRR监测主备链路状态的周期为200毫秒。
monitor-time:组播FRR监测主备链路状态的周期,取值范围为10、20、40、100、200和500,单位为毫秒。
在配置本功能前,请先通过rpf-frr enable或c-multicast frr命令开启公网或私网的组播FRR功能。
当连接组播源的设备发生故障时,为了加快组播业务收敛速度,可以在连接接收者的设备上开启组播FRR功能。设备上开启组播FRR功能后,设备将为同一个(S,G)表项保存主备两个入接口,并周期性检测主备入接口的组播流量。如果检测到组播流量未从主入接口到达,则表示主链路存在故障,此时连接接收者的设备将选择接收从备份链路发来的组播流量。通过本命令,可以配置组播FRR监测主备链路状态的周期。
组播转发表项较多时,建议将监测主备链路状态的周期调大,避免在短时间内监测过多的组播表项对应的组播流量,导致CPU负载过重;当组播流量速率比较小时,也建议将监测主备链路状态的周期调大,避免监测周期过短监测过于频繁,造成链路故障的误判。
# 配置组播FRR监测主备链路状态的周期为20毫秒。
[Sysname] multicast frr monitor cycle 20
· c-multicast frr(IP组播命令参考/组播VPN)
· rpf-frr enable (PIM view)
multicast frr wtr命令用来配置组播FRR中组播流量从备份链路回切到主链路功能。
undo multicast frr wtr命令用来恢复缺省情况。
multicast frr wtr { wtr-time | disable }
组播FRR中组播流量从备份链路回切到主链路功能处于开启状态,回切的等待时间为600秒。
wtr-time:组播FRR中组播流量从备份链路回切到主链路的等待时间,取值范围为60~1800,单位为秒。
disable:组播FRR中组播流量不从备份链路回切到主链路。
建议配置的组播FRR中组播流量从备份链路回切到主链路的等待时间不要过短,以免在主链路完成组播表项建立前,将组播流量回切到主链路,导致组播流量转发失败。
组播流量回切过程中,可能会导致部分组播业务出现多包或者丢包。在组播业务可靠性要求较高的场景下,建议配置为不回切。
# 配置组播FRR中组播流量从备份链路回切到主链路的等待时间为800秒。
[Sysname] multicast frr wtr 800
multicast global limit命令用来开启全局PIM表项数目限制功能。
undo multicast global limit命令用来关闭全局PIM表项数目限制功能。
multicast global limit pim sm { source-group-number | star-group-number } limit-count [ alarm-threshold upper-limit upper-limit lower-limit lower-limit ]
undo multicast global limit pim sm { source-group-number | star-group-number }
全局PIM表项数目限制功能处于关闭状态。
pim sm:配置PIM-SM模式下的全局PIM表项数目限制功能。
star-group-number:指定PIM表项中(*,G)表项数目的限制功能。
source-group-number:指定PIM表项中(S,G)表项数目的限制功能。
limit-count:指定全局PIM表项数目的最大值,取值范围为1~16384。
alarm-threshold upper-limit upper-limit:指定PIM表项数目预警上限阈值,当系统中的PIM表项数目与设置的PIM表项数目最大值的百分比达到上限阈值时,设备将生成对应的日志。upper-limit取值范围为1~100,单位为百分比,缺省值为80,建议取值不要大于95。
alarm-threshold lower-limit lower-limit:指定PIM表项数目预警下限阈值,当系统中的PIM表项数目与设置的PIM表项数目最大值的百分比低于下限阈值时,设备将生成对应的日志。upper-limit取值范围为1~100,单位为百分比,缺省值为70。lower-limit的取值必须小于upper-limit的取值,建议lower-limit至少比upper-limit小10,以避免路由震荡时频繁生成日志。
非法用户利用组播数据或组播IGMP/PIM协议报文对网络进行攻击时,可能会在设备上生成过多的组播路由表项,从而导致设备内存占用过多或CPU使用率过高。通过本命令可以对PIM表项数量进行限制,从而确保组播业务的正常运行。
当全局PIM表项数目达到的最大值以后,新的PIM表项将无法创建,同时将会生成对应的日志。
静态创建的(*,G)、(S,G)表项和MDT模式MVPN创建的ASM Default-Group表项不受本功能的限制。
设备生成的日志信息会交给信息中心模块处理,信息中心模块的配置将决定日志信息的发送规则和发送方向。关于信息中心的详细描述请参见“网络管理和监控配置指导”中的“信息中心”。
# 配置PIM-SM模式下,(S,G)表项数目的最大值为1000。
[sysname] multicast global limit pim sm source-group-number 1000
# 配置PIM-SM模式下,(*,G)表项数目的最大值为2000,PIM表项数目预警上限为80%,下限为70%。
<sysname> system-view
[sysname] multicast global limit pim sm star-group-number 2000 alarm-threshold upper-limit 80 lower-limit 70
· display multicast global statistics
multicast routing命令用来使能IP组播路由,并进入MRIB视图。
undo multicast routing命令用来关闭IP组播路由。
undo multicast routing [ vpn-instance vpn-instance-name ]
IP组播路由处于关闭状态。
只有在公网或VPN实例中使能了IP组播路由,该实例中的其它三层组播功能才能生效;没有使能IP组播路由前,设备不转发任何组播报文。
# 使能公网中的IP组播路由,并进入公网的MRIB视图。
[Sysname-mrib]
# 使能VPN实例mvpn中的IP组播路由,并进入该VPN实例的MRIB视图。
[Sysname-mrib-mvpn]
multicast rpf-fail-pkt flooding命令用来配置在所有VLAN内泛洪RPF检查失败的组播数据报文。
undo multicast rpf-fail-pkt flooding命令用来恢复缺省情况。
不在VLAN内泛洪RPF检查失败的组播数据报文。
执行本命令不需要使能IP组播路由。
执行本命令后必须清除组播转发表中的所有转发项,否则本命令将不能生效。
利用reset multicast forwarding-table来清除组播转发表中的转发项。
# 配置在所有VLAN内泛洪RPF检查失败的组播数据报文。
[Sysname] multicast rpf-fail-pkt flooding
multicast rpf-fail-pkt trap-to-cpu命令用来配置把RPF检查失败的组播数据报文上送CPU处理。
undo multicast rpf-fail-pkt trap-to-cpu命令用来恢复缺省情况。
不把RPF检查失败的组播数据报文上送CPU处理。
执行本命令不需要使能IP组播路由。
# 配置把RPF检查失败的组播数据报文上送CPU处理。
[Sysname] multicast rpf-fail-pkt trap-to-cpu
reset multicast fast-forwarding cache命令用来清除组播快速转发表中的转发项。
(独立运行模式)
reset multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache { { source-address | group-address } * | all } [ slot slot-number ]
reset multicast [ vpn-instance vpn-instance-name ] fast-forwarding cache { { source-address | group-address } * | all } [ chassis chassis-number slot slot-number ]
source-address:组播源地址,清除包含指定组播源的组播转发项。
group-address:组播组地址,清除指定组播组的组播转发项,取值范围为224.0.0.0~239.255.255.255。
all:清除组播快速转发表中的所有组播转发项。
# 从公网组播快速转发表中清除所有组播转发表项。
<Sysname> reset multicast fast-forwarding cache all
# 从公网组播快快速转发表中清除组播源组为(20.0.0.2 ,225.0.0.2)的转发表项。
<Sysname> reset multicast fast-forwarding cache 20.0.0.2 225.0.0.2
· display multicast fast-forwarding cache
reset multicast forwarding event命令用来清除组播转发的事件统计信息。
# 清除公网组播转发的事件统计信息。
<Sysname> reset multicast forwarding event
· display multicast forwarding event
reset multicast forwarding-table命令用来清除组播转发表中的转发项。
incoming-interface:清除指定入接口的组播转发项。
interface-type interface-number:清除指定接口类型和接口编号的入接口的组播转发项。
all:清除组播转发表中的所有组播转发项。
清除组播转发表中的转发项后,组播路由表中的相应表项也将随之被删除。
# 从公网组播转发表中清除组播组225.5.4.3的相关转发表项。
<Sysname> reset multicast forwarding-table 225.5.4.3
reset multicast routing-table命令用来清除组播路由表中的路由项。
reset multicast [ vpn-instance vpn-instance-name ] routing-table { { source-address [ mask { mask-length | mask } ] | group-address [ mask { mask | mask-length } ] | incoming-interface interface-type interface-number } * | all }
source-address:组播源地址,清除包含指定组播源的组播路由项。
group-address:组播组地址,清除指定组播组的组播路由项,取值范围为224.0.0.0~239.255.255.255。
incoming-interface:清除指定入接口的组播路由项。
interface-type interface-number:清除指定接口类型和接口编号的入接口的组播路由项。
all:清除组播路由表中的所有组播路由项。
清除组播路由表中的路由项后,组播转发表中的相应表项也将被随之删除。
# 从公网组播路由表中清除组播组225.5.4.3的相关路由项。
<Sysname> reset multicast routing-table 225.5.4.3
snmp-agent trap enable mrib命令用来开启组播路由与转发的告警功能。
undo snmp-agent trap enable mrib命令用来关闭组播路由与转发的告警功能。
snmp-agent trap enable mrib [ entry-exceed | entry-exceed-clear ]*
undo snmp-agent trap enable mrib [ entry-exceed | entry-exceed-clear ]*
组播路由与转发的告警功能处于开启状态。
entry-exceed:表示组播路由表项数量超过允许的最大值的告警信息。
entry-exceed-clear:表示组播路由表项数量降低到允许的最大值以下的告警信息。
执行本命令时,如果未指定任何参数,则表示开启或关闭组播路由与转发的所有告警功能。
组播路由表项数量的最大值由multicast global limit命令中的limit-count参数值以及各产品支持的组播路由表项数量规格共同决定,最大值取两者中较小的值。
开启了组播路由与转发的告警功能后,该模块会生成告警信息,用于报告该模块的重要事件。生成的告警信息将发送到设备的SNMP模块,通过设置SNMP中告警信息的发送参数,来决定告警信息输出的相关属性。有关告警信息的详细介绍,请参见“网络管理和监控配置指导”中的“SNMP”。
# 关闭组播路由与转发的所有告警功能。
[Sysname] undo snmp-agent trap enable mrib
