14-IPv6基础典型配置举例
本章节下载: 14-IPv6基础典型配置举例 (100.18 KB)
本章介绍了使用IPv6地址实现IPv6设备间通信的典型配置案例。
如图1所示,Switch作为网关设备,在2001::/64网段内发布地址前缀信息,该网段内的主机根据获取的前缀信息自动配置IPv6地址,生成指向Switch A的缺省路由,实现与外部网络的通信。
图1 IPv6基础配置组网图
# 使能交换机的IPv6转发功能。
<Switch> system-view
[Switch] ipv6
# 配置VLAN接口1采用EUI-64格式的IPv6地址,并允许其发布RA消息。(缺省情况下,所有的接口不会发布RA消息)
[Switch] interface vlan-interface 1
[Switch-Vlan-interface1] ipv6 address 2001::/64 eui-64
[Switch-Vlan-interface1] undo ipv6 nd ra halt
[Switch-Vlan-interface1] quit
# 配置VLAN接口2的全球单播地址。
[Switch] vlan 2
[Switch-vlan2] port GigabitEthernet 1/0/2
[Switch-vlan2] quit
[Switch-Vlan-interface2] ipv6 address 3001::1 64
[Switch-Vlan-interface2] quit
进入Host的cmd命令窗口,安装IPv6协议栈。
C:\Documents and Settings\aa>ipv6 install
# 在Host上查看IPv6地址,发现生成以2001::/64为前缀的IPv6地址,网关指定为Switch。
# 在Switch上显示接口信息,可以看到接口配置的IPv6地址。
<Switch> display ipv6 interface
Vlan-interface1 current state :UP
Line protocol current state :UP
IPv6 is enabled, link-local address is FE80::223:89FF:FE5F:958C
Global unicast address(es):
2001::223:89FF:FE5F:958C, subnet is 2001::/64
Joined group address(es):
FF02::1:FF00:0
FF02::1:FF00:1
FF02::1:FF5F:958C
FF02::2
FF02::1
MTU is 1500 bytes
IPv6 Packet statistics:
InReceives: 67
InTooShorts: 0
InTruncatedPkts: 0
InHopLimitExceeds: 0
InBadHeaders: 0
InBadOptions: 0
ReasmReqds: 0
ReasmOKs: 0
InFragDrops: 0
InFragTimeouts: 0
OutFragFails: 0
InUnknownProtos: 0
InDelivers: 26
OutRequests: 36
OutForwDatagrams: 0
InNoRoutes: 0
InTooBigErrors: 0
OutFragOKs: 0
OutFragCreates: 0
InMcastPkts: 22
InMcastNotMembers: 41
OutMcastPkts: 21
InAddrErrors: 0
InDiscards: 0
OutDiscards: 0
Vlan-interface2 current state :UP
3001::1, subnet is 3001::/64
FF02::1:FF00:0
FF02::1:FF00:1
FF02::1:FF5F:958C
FF02::2
FF02::1
MTU is 1500 bytes
InReceives: 8
InTooShorts: 0
InTruncatedPkts: 0
InBadHeaders: 0
InBadOptions: 0
ReasmReqds: 0
ReasmOKs: 0
InFragDrops: 0
InFragTimeouts: 0
OutFragFails: 0
InUnknownProtos: 0
InDelivers: 6
OutRequests: 8
OutForwDatagrams: 0
InNoRoutes: 0
InTooBigErrors: 0
OutFragOKs: 0
OutFragCreates: 0
InMcastPkts: 3
InMcastNotMembers: 2
OutMcastPkts: 4
InAddrErrors: 0
InDiscards: 0
OutDiscards: 0
ipv6
vlan 1 to 2
interface Vlan-interface1
interface Vlan-interface2
ipv6 address 3001::1/64
port access vlan 2
