05-Comware 9 CLI-based configuration examples (AC+fit AP deployment)
HomeSupportDoc SetsDoc PackagesH3C Wireless Products All-in-One-6W10105-Comware 9 CLI-based configuration examples (AC+fit AP deployment)
Table of Contents
Related Documents
86-Mesh Link Establishment Between a Fit AP and a Fat AP Configuration Examples
H3C Access Controllers
Mesh Link Establishment Between Fit AP and Fat AP
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
Introduction
The following information provides an example of configuring a mesh link between a fit AP and a fat AP.
The following information applies to Comware-based access controllers and access points. Procedures and information in the examples might be slightly different depending on the software or hardware version of the access controllers and access points.
The following information is provided based on the assumption that you have basic knowledge of WLAN mesh.
Example: Configuring a mesh link between a fit AP and a fat AP
As shown in Figure 1, in centralized forwarding mode, the AC in LAN 1 is connected to Switch 1, and Switch 1 assigns an IP address to the AP and client in LAN 1 as a DHCP server. Switch 2 assigns an IP address to the client in LAN 2 as a DHCP server. Configure the devices to meet the following requirements:
·     AP 1 obtains an IP address from the address pool on VLAN 10 configured on Switch 1 and comes online from the AC.
·     The clients in LAN 1 and LAN 2 are assigned to different VLANs and are reachable to each other at Layer 3.
Figure 1 Network diagram
·     Use the actual serial ID of an AP to uniquely identify that AP.
·     Configure GE 1/0/4 that connects Switch 1 to the AP as a trunk port, and remove the port from VLAN 1.
Procedures
Configuring Switch 1
1.     Configure interfaces on Switch 1:
# Create VLAN 10 and VLAN-interface 10, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
<Switch1> system-view
[Switch1] vlan 10
[Switch1-vlan10] quit
[Switch1] interface vlan-interface 10
[Switch1-Vlan-interface10] ip address 172.16.1.1 255.255.255.0
[Switch1-Vlan-interface10] quit
# Create VLAN 20 and VLAN-interface 20, and assign an IP address to the VLAN interface. This VLAN will use be used as the gateway for the clients.
[Switch1] vlan 20
[Switch1-vlan20] quit
[Switch1] interface vlan-interface 20
[Switch1-Vlan-interface20] ip address 192.168.10.1 255.255.255.0
[Switch1-Vlan-interface20] quit
# Create VLAN 30 and VLAN-interface 30, and assign an IP address to the VLAN interface. The switch will use this VLAN to communicate with the AP.
[Switch1] vlan 30
[Switch1-vlan30] quit
[Switch1] interface vlan-interface 30
[Switch1-Vlan-interface30] ip address 10.12.12.1 255.255.255.0
[Switch1-Vlan-interface30] quit
# Configure GigabitEthernet 1/0/1 that connects Switch 1 to the AC as a trunk port, and assign the port to all VLANs.
[Switch1] interface gigabitEthernet 1/0/1
[Switch1-GigabitEthernet1/0/1] port link-type trunk
[Switch1-GigabitEthernet1/0/1] port trunk permit vlan all
[Switch1-GigabitEthernet1/0/1] quit
# Configure GigabitEthernet 1/0/4 that connects Switch 1 to AP 1 as a trunk port, remove the port from VLAN 1, and assign the port to all the other VLANs.
[Switch1] interface gigabitEthernet 1/0/4
[Switch1-GigabitEthernet1/0/4] port link-type trunk
[Switch1-GigabitEthernet1/0/4] port trunk permit vlan all
[Switch1-GigabitEthernet1/0/4] undo port trunk permit vlan 1
# Set the PVID of GigabitEthernet 1/0/4 to VLAN 10.
[Switch1-GigabitEthernet1/0/4] port trunk pvid vlan 10
[Switch1-GigabitEthernet1/0/4] quit
# Assign GigabitEthernet 1/0/2 that connects Switch 1 to Client 1 to VLAN 20.
[Switch1] interface gigabitEthernet 1/0/2
[Switch1-GigabitEthernet1/0/2] port access vlan 20
[Switch1-GigabitEthernet1/0/2] quit
[Switch1] quit
2.     Configure the DHCP server:
# Enable DHCP.
[Switch1] dhcp enable
# Specify 172.16.1.0/24 as the address range for dynamic allocation in DHCP address pool 1, and specify 172.16.1.1 as the gateway address.
[Switch1] dhcp server ip-pool 1
[Switch1-dhcp-pool-1] network 172.16.1.0 mask 255.255.255.0
[Switch1-dhcp-pool-1] gateway-list 172.16.1.1
# Exclude 172.16.1.2 from dynamic allocation.
[Switch1-dhcp-pool-1] forbidden-ip 172.16.1.2
[Switch1-dhcp-pool-1] quit
# Configure DHCP address pool 2. In the address pool, specify 192.168.10.1 as the gateway IP address, 192.168.10.0/24 as the subnet for dynamic allocation, and 192.168.10.1 as the DNS server address.
[Switch1] dhcp server ip-pool 2
[Switch1-dhcp-pool-2] network 192.168.10.0 mask 255.255.255.0
[Switch1-dhcp-pool-2] gateway-list 192.168.10.1
[Switch1-dhcp-pool-2] dns-list 192.168.10.1
[Switch1-dhcp-pool-2] quit
3.     # Configure a route to the network where Client 2 resides.
[Switch1] ip route-static 192.168.20.0 255.255.255.0 10.12.12.2
Configuring the AC
1.     Configure interfaces on the AC:
# Create VLAN 10 and VLAN-interface 100, and assign an IP address to the VLAN interface. The AC will use this IP address to establish a CAPWAP tunnel with the AP.
[AC] vlan 10
[AC-vlan10] quit
[AC] interface vlan-interface 10
[AC-Vlan-interface10] ip address 172.16.1.2 255.255.255.0
[AC-Vlan-interface10] quit
# Configure GigabitEthernet 1/0/1 that connects the AC to Switch 1 as a trunk port, and assign the port to all VLANs.
[AC-GigabitEthernet1/0/1] port trunk permit vlan all
2.     Configure a fit AP:
In a large-scale network, configure AP settings in AP group view instead of AP view as a best practice.
# Create a manual AP named ap1, and specify the AP model and serial ID.
[AC] wlan ap ap1 model WA6330
[AC-wlan-ap-ap1] serial-id 219801A23V8192E00021
[AC-wlan-ap-ap1] quit
# Create AP group group1, and configure a grouping rule by AP name to add AP ap1 to the group.
[AC] wlan ap-group group1
[AC-wlan-ap-group-group1] ap ap1
[AC-wlan-ap-group-group1] ap-model WA6330
[AC-wlan-ap-group-group1-ap-model-WA6330] radio 1
# Enter the view of radio 1, specify the radio type as dot11an, and specify the channel as 36.
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] radio 1
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] type dot11an
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] channel 36
# Enable radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] radio enable
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] quit
[AC-wlan-ap-group-group1] quit
3.     Configure a mesh profile:
# Create mesh profile 1.
[AC] wlan mesh-profile 1
# Set the mesh ID to 1.
[AC-wlan-mesh-profile-1] mesh-id 1
# Set the authentication and key management (AKM) mode to sae.
[AC-wlan-mesh-profile-1] akm mode sae
# Configure simple character string meshlink as the PSK.
[AC-wlan-mesh-profile-1] preshared-key pass-phrase simple meshlink
# Enable the mesh profile.
[AC-wlan-mesh-profile-1] mesh-profile enable
[AC-wlan-mesh-profile-1] quit
# Bind radio 1 to the mesh profile.
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] mesh-profile 1
4.     Add the MAC address of AP 2 to the mesh peer whitelist for AP ap1.
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] mesh peer-mac-address 90e7-1066-e060
[AC-wlan-ap-group-group1-ap-model-WA6330] quit
5.     Configure a WLAN-mesh interface:
# Create a WLAN-mesh interface.
[AC-wlan-ap-group-group1] interface wlan-mesh 1
# Configure WLAN-mesh interface 1 as a trunk port, and assign the port to all VLANs.
[AC-wlan-ap-group-group1-wlan-mesh-1] mesh-port link-type trunk
[AC-wlan-ap-group-group1-wlan-mesh-1] mesh-port trunk permit vlan all
[AC-wlan-ap-group-group1-wlan-mesh-1] quit
# Bind WLAN-mesh interface 1 to radio 1.
[AC-wlan-ap-group-group1-ap-model-WA6330-radio-1] mesh-interface 1
6.     Editing the AP’s configuration file
# Edit the AP’s configuration file, name it map.txt.
vlan 30
7.     Upload the configuration file to the AC.
[AC-wlan-ap-group-group1-ap-model-WA6330] map-configuration map.txt
Configuring Switch 2
1.     Configure interfaces on Switch 2:
# Create VLAN 40 and VLAN-interface 40, and assign an IP address to the VLAN interface. This VLAN will be used for client access.
<Switch2> system-view
[Switch2] vlan 40
[Switch2-vlan40] quit
[Switch2] interface vlan-interface 40
[Switch2-Vlan-interface40] ip address 192.168.20.2 255.255.255.0
[Switch2-Vlan-interface40] quit
# Configure GigabitEthernet 1/0/1 that connects Switch 2 to the AC as a trunk port, and assign the port to all VLANs.
[Switch2] interface gigabitEthernet 1/0/1
[Switch2-GigabitEthernet1/0/1] port link-type trunk
[Switch2-GigabitEthernet1/0/1] port trunk permit vlan all
[Switch2-GigabitEthernet1/0/1] quit
# Assign GigabitEthernet1/0/2 that connects Switch 2 to Client 2 to VLAN 40.
[Switch2] interface gigabitEthernet 1/0/2
[Switch2-GigabitEthernet1/0/2] port access vlan 40
[Switch2-GigabitEthernet1/0/2] quit
# Enable DHCP.
[Switch2] dhcp enable
# Specify 192.168.20.0/24 as the address range for dynamic allocation in DHCP address pool 1, and specify 192.168.20.1 as the gateway address.
[Switch2] dhcp server ip-pool 1
[Switch2-dhcp-pool-1] network 192.168.20.0 mask 255.255.255.0
[Switch2-dhcp-pool-1] gateway-list 192.168.20.1
# Exclude 192.168.20.1 from dynamic allocation.
[Switch2-dhcp-pool-1] forbidden-ip 192.168.20.1
[Switch2-dhcp-pool-1] quit
Configuring AP 2
1.     Configure interfaces on AP 2:
# Create VLAN 30 and VLAN-interface 30, and assign an IP address to the VLAN interface. The AP will use this VLAN to communicate with Switch 1.
<AP2> system-view
[AP2] vlan 30
[AP2-vlan30] quit
[AP2] interface vlan-interface 30
[AP2-Vlan-interface30] ip address 10.12.12.2 255.255.255.0
[AP2-Vlan-interface30] quit
# Create VLAN 40 and VLAN-interface 20, and assign an IP address to the VLAN interface. This VLAN will be used as the gateway for the clients.
[AP2] vlan 40
[AP2-vlan40] quit
[AP2] interface vlan-interface 40
[AP2-Vlan-interface40] ip address 192.168.20.1 255.255.255.0
[AP2-Vlan-interface40] quit
2.     Configure a radio interface:
# Enter the view of WLAN-Radio 1/0/1, specify the radio type as dot11an, and specify the channel as 36.
[AP2] interface wlan-radio 1/0/1
[AP2-WLAN-Radio1/0/1] type dot11an
[AP2-WLAN-Radio1/0/1] channel 36
[AP2-WLAN-Radio1/0/1] quit
[AP2] wlan mesh-profile 1
[AP2-wlan-mesh-profile-1] mesh-id 1
[AP2-wlan-mesh-profile-1] akm mode sae
[AP2-wlan-mesh-profile-1] preshared-key pass-phrase simple meshlink
[AP2-wlan-mesh-profile-1] mesh-profile enable
[AP2-wlan-mesh-profile-1] quit
# Bind WLAN-Radio 1/0/1 to the mesh profile.
[AP2-WLAN-Radio1/0/1] mesh-profile 1
4.     Add the MAC address of AP 1 to the mesh peer whitelist for the fat AP.
[AP2-WLAN-Radio1/0/1] mesh peer-mac-address 542b-dea7-a8c0
[AP2] interface wlan-mesh 1
[AP2-WLAN-Mesh1] port link-type trunk
[AP2-WLAN-Mesh1] port trunk permit vlan all
[AP2-WLAN-Mesh1] quit
# Bind WLAN-mesh interface 1 to WLAN-Radio 1/0/1.
[AP2-WLAN-Radio1/0/1] mesh-interface 1
6.     Configure a route to the network where Client 1 resides.
[AP2] ip route-static 192.168.10.0 255.255.255.0 10.12.12.1
1.     Verify that AP 1 has been associated with the AC. If the AP is in R/M state, the AP has been associated with the AC.
<AC> display wlan ap name ap1
                                  AP information
 State : I = Idle,      J  = Join,       JA = JoinAck,    IL = ImageLoad
         C = Config,    DC = DataCheck,  R  = Run,   M = Master,  B = Backup
AP name                        APID  State Model           Serial ID
ap1                            1     R/M   WA6330          219801A23V8192E00021
2.     Display mesh link information on the fat AP:
<AP2> display wlan mesh-link
Peer MAC       RSSI BSSID          Interface         Link state       Online time
542b-dea7-a8c0 81   d461-fe59-4d20 WLAN-MeshLink2    Active(an)       20h 00m 49s
3.     Ping Client 2 from Client 1 to verify that they are reachable to each other.
C:\Users\system32> ping 192.168.20.3
Pinging 192.168.20.3 with 32 bytes of data:
Reply from 192.168.20.3: bytes=32 time<1ms TTL=255
Ping statistics for 192.168.20.3:
    Minimum = 0ms, Maximum = 0ms, Average = 0ms
Configuration files
·     Switch 1:
 dhcp enable
vlan 10
vlan 20
vlan 30
interface Vlan-interface10
interface Vlan-interface20
interface Vlan-interface30
 port access vlan 20
interface GigabitEthernet1/0/4
 port trunk permit vlan 2 to 4094
·     AC:
wlan mesh-profile 1
 mesh-id 1
 akm mode sae
 preshared-key pass-phrase cipher $c$3$qVXx1KuNn4FeEi3nMUkQ7A8jcIMrN8JH2AOv
 mesh-profile enable
vlan 10
 map-configuration flash:/map.txt
 vlan 1
 ap ap1
 ap-model WA6330
  radio 1
   type dot11an
   channel 36
   radio enable
   mesh-interface 1
   mesh-profile 1
·     Switch 2:
 dhcp enable
vlan 40
interface Vlan-interface40
 port access vlan 40
·     AP 2:
wlan mesh-profile 1
 mesh-id 1
 akm mode sae
 mesh-profile enable
vlan 30
vlan 40
interface WLAN-Radio1/0/1
 mesh-profile 1
 mesh-interface 1
 type dot11an
 channel 36
interface WLAN-Mesh1
Related documentation
·     AP Management Command Reference in H3C Access Controllers Command References
·     AP Management Configuration Guide in H3C Access Controllers Configuration Guides
·     WLAN Mesh Command Reference in H3C Access Controllers Command References
·     WLAN Mesh Configuration Guide in H3C Access Controllers Configuration Guides
