04-Layer 3 Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10204-Layer 3 Configuration Guide
13-Static Routing Configuration
13-Static Routing Configuration 59.49 KB
Configuring static routing
Static routes are manually configured. If a network's topology is simple, you only need to configure static routes for the network to work correctly.
Static routes cannot adapt to network topology changes. If a fault or a topological change occurs in the network, the network administrator must modify the static routes manually.
Configuring a static route
Before you configure a static route, complete the following tasks:
·     Configure physical parameters for related interfaces.
·     Configure link-layer attributes for related interfaces.
·     Configure IP addresses for related interfaces.
Follow these guidelines when you configure a static route:
·     The next hop address of a static route cannot be the IP address of a local interface. Otherwise, the static route does not take effect.
·     You can associate a track entry with a static route to monitor the reachability of the next hops. For more information about track, see High Availability Configuration Guide.
To configure a static route:
Step
Remarks
N/A
2.     Configure a static route.
ip route-static dest-address { mask | mask-length } { next-hop-address [ track track-entry-number ] | interface-type interface-number [ next-hop-address ] [ preference preference-value ] [ permanent ] [ description description-text ]
By default, no static route is configured.
3.     Configure the default preference for static routes.
ip route-static default-preference default-preference-value
Optional.
60 by default.
4.     Delete all static routes, including the default route.
delete static-routes all
Optional.
To delete one static route, use the undo ip route-static command.
Displaying and maintaining static routes
Remarks
Display static route information.
display ip routing-table protocol static [ inactive | verbose ] [ | { begin | exclude | include } regular-expression ]
Available in any view.
Static route configuration example
Network requirements
The IP addresses and masks of the AC, AP, switches and hosts are shown in Figure 1. Configure static routes on the routers so that the hosts, switches, and AC can communicate with each other.
Figure 1 Network diagram
Configuration procedure
1.     Configure IP addresses for interfaces. (Details not shown.)
2.     Configure AC basic functions. (For more information, see WLAN Configuration Guide.)
3.     Configure static routes:
# Configure a default route on Switch A.
[SwitchA] ip route-static 0.0.0.0 0.0.0.0 1.1.4.2
# Configure two static routes on Switch B.
[SwitchB] ip route-static 1.1.2.0 255.255.255.0 1.1.4.1
[SwitchB] ip route-static 1.1.3.0 255.255.255.0 1.1.5.6
# Configure a default route on AC.
<AC> system-view
[AC] ip route-static 0.0.0.0 0.0.0.0 1.1.5.5
4.     Configure the default gateways of Host A, Host B, and Host C as 1.1.2.3, 1.1.6.1, and 1.1.3.1. (Details not shown.)
5.     Verify the configuration:
# Display the IP routing table on Switch A.
Routing Tables: Public
         Destinations : 7       Routes : 7
0.0.0.0/0           Static 60   0            1.1.4.2         Vlan500
1.1.2.0/24          Direct 0    0            1.1.2.3         Vlan300
1.1.2.3/32          Direct 0    0            127.0.0.1       InLoop0
1.1.4.0/30          Direct 0    0            1.1.4.1         Vlan500
1.1.4.1/32          Direct 0    0            127.0.0.1       InLoop0
127.0.0.0/8         Direct 0    0            127.0.0.1       InLoop0
# Display the IP routing table on Switch B.
[SwitchB] display ip routing-table
         Destinations : 10       Routes : 10
1.1.2.0/24          Static 60   0            1.1.4.1         Vlan500
1.1.3.0/24          Static 60   0            1.1.5.6         Vlan600
1.1.4.0/30          Direct 0    0            1.1.4.2         Vlan500
1.1.4.2/32          Direct 0    0            127.0.0.1       InLoop0
1.1.5.4/30          Direct 0    0            1.1.5.5         Vlan600
1.1.5.5/32          Direct 0    0            127.0.0.1       InLoop0
1.1.6.0/24          Direct 0    0            192.168.1.47    Vlan100
1.1.6.1/32          Direct 0    0            127.0.0.1       InLoop0
# Use the ping command on Host B to test reachability of Host A (assuming Windows XP runs on the two hosts).
C:\Documents and Settings\Administrator>ping 1.1.2.2
Pinging 1.1.2.2 with 32 bytes of data:
Reply from 1.1.2.2: bytes=32 time=1ms TTL=255
Ping statistics for 1.1.2.2:
# Use the tracert command on Host B to test reachability of Host A.
[HostB] tracert 1.1.2.2
Tracing route to 1.1.2.2 over a maximum of 30 hops
  1    <1 ms    <1 ms    <1 ms  1.1.6.1
  2    <1 ms    <1 ms    <1 ms  1.1.4.1
  3     1 ms    <1 ms    <1 ms  1.1.2.2
Trace complete.
