04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10204-Layer 3 Command Reference
17-RIPng Commands
17-RIPng Commands 97.40 KB
RIPng configuration commands
checkzero
Use checkzero to enable the zero field check on RIPng packets.
Use undo checkzero to disable the zero field check.
checkzero
undo checkzero
The zero field check is enabled.
RIPng view
Default command level
2: System level
Some fields in RIPng packet headers must be zero. These fields are called "zero fields." You can enable the zero field check on RIPng packet headers. If any such field contains a non-zero value, the RIPng packet is discarded.
# Disable the zero field check on RIPng packet headers of RIPng 100.
[Sysname] ripng 100
[Sysname-ripng-100] undo checkzero
default cost (RIPng view)
Use default cost to specify the default metric of redistributed routes.
Use undo default cost to restore the default.
default cost cost
undo default cost
The default metric of redistributed routes is 0.
RIPng view
2: System level
cost: Default metric of redistributed routes, in the range of 0 to 16.
The specified default metric applies to the routes redistributed by the import-route command with no metric specified.
# Set the default metric of redistributed routes to 2.
[Sysname] ripng 100
[Sysname-ripng-100] default cost 2
import-route
display ripng
Use display ripng to display the running status and configuration information of a RIPng process.
display ripng [ process-id ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
process-id: RIPng process ID, in the range of 1 to 65535.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
If no process-id is specified, information about all RIPng processes is displayed.
# Display the running status and configuration information of all configured RIPng processes.
<Sysname> display ripng
    RIPng process : 1
       Preference : 100
       Checkzero : Enabled
       Default Cost : 0
       Maximum number of balanced paths : 8
       Update time   :   30 sec(s)  Timeout time         :  180 sec(s)
       Suppress time :  120 sec(s)  Garbage-Collect time :  120 sec(s)
       Number of periodic updates sent : 0
       Number of trigger updates sent : 0
       IPsec policy name: policy001, SPI: 300
RIPng process
RIPng process ID.
Preference
RIPng preference.
Checkzero
Indicates whether zero field check for RIPng packet headers is enabled.
Default Cost
Default metric of redistributed routes.
Maximum number of load balanced routes.
Update time
RIPng update interval, in seconds.
Timeout time
RIPng timeout interval, in seconds.
Suppress time
RIPng suppress interval, in seconds.
RIPng garbage collection interval, in seconds.
Number of periodic updates sent.
Number of triggered updates sent.
IPsec policy name
IPsec policy applied in the process.
SPI
SPI defined in the IPsec policy.
display ripng database
Use display ripng database to display all active routes in the advertising database of the specified RIPng process, which are sent in normal RIPng update messages.
display ripng process-id database [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the active routes in the database of RIPng process 100.
<Sysname> display ripng 100 database
   2001:7B::2:2A1:5DE/64,
        cost 4, Imported
   1:13::/120,
        cost 4, Imported
   1:32::/120,
        cost 4, Imported
   1:33::/120,
        cost 4, Imported
   100::/32,
       via FE80::200:5EFF:FE04:3302, cost 2
   3FFE:C00:C18:1::/64,
       via FE80::200:5EFF:FE04:B602, cost 2
       via FE80::200:5EFF:FE04:B601, cost 2
   3FFE:C00:C18:2::/64,
   3FFE:C00:C18:3::/64,
   4000:1::/64,
   4000:2::/64,
   1111::/64,
        cost 0, RIPng-interface
IPv6 destination address/prefix length.
via
Next hop IPv6 address.
cost
Route metric value.
Imported
Route redistributed from another routing protocol.
RIPng-interface
Route learned from the interface.
display ripng interface
Use display ripng interface to display the interface information of the RIPng process.
display ripng process-id interface [ interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
If no interface is specified, information about all interfaces of the RIPng process will be displayed.
# Display the interface information of RIPng process 1.
<Sysname> display ripng 1 interface
Interface-name: GigabitEthernet1/0/5
          Link Local Address: FE80::20F:E2FF:FE30:C16C
          Split-horizon: on                Poison-reverse: off
          MetricIn: 0                      MetricOut: 1
          Default route: off
          Summary address:
                 3:: 64
                 3:: 16
Interface-name
Name of an interface running RIPng.
Link Local Address
Link-local address of an interface running RIPng.
Split-horizon
Indicates whether the split horizon function is enabled:
·     on—Enabled.
·     off—Disabled.
Poison-reverse
Indicates whether the poison reverse function is enabled:
·     on—Enabled.
·     off—Disabled.
MetricIn/MetricOut
Additional metric to incoming and outgoing routes.
Default route
·     Only/OriginateOnly means that the interface advertises only the default route. Originate means that the default route and other RIPng routes are advertised.
·     Off—Indicates that no default route is advertised or the garbage-collect time expires after the default route advertisement was disabled.
·     In garbage-collect status—With default route advertisement disabled, the interface advertises the default route with metric 16 during the garbage-collect time.
Summary address
Summarized IPv6 prefix and summary IPv6 prefix on the interface.
IPsec policy name
IPsec policy applied on the interface.
SPI
display ripng route
Use display ripng route to display all RIPng routes and timers associated with each route of a RIPng process.
display ripng process-id route [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the routing information of RIPng process 100.
<Sysname> display ripng 100 route
   Route Flags: A - Aging, S - Suppressed, G - Garbage-collect
 Peer FE80::200:5EFF:FE04:B602  on GigabitEthernet1/0/1
 Dest 3FFE:C00:C18:1::/64,
     via FE80::200:5EFF:FE04:B602, cost  2, tag 0, A, 34 Sec
 Dest 3FFE:C00:C18:2::/64,
 Peer FE80::200:5EFF:FE04:B601  on GigabitEthernet1/0/2
     via FE80::200:5EFF:FE04:B601, cost  2, tag 0, A, 13 Sec
 Dest 3FFE:C00:C18:3::/64,
 Peer FE80::200:5EFF:FE04:3302  on GigabitEthernet1/0/3
 Dest 100::/32,
     via FE80::200:5EFF:FE04:3302, cost  2, tag 0, A, 6 Sec
 Dest 4000:1::/64,
 Dest 4000:2::/64,
 Dest 4000:3::/64,
 Dest 4000:4::/64,
Peer
Neighbor connected to the interface.
Dest
IPv6 destination address.
via
cost
Routing metric value.
tag
Route tag.
Sec
Time that a route entry stays in a particular state.
"A"
The route is in aging state.
"S"
The route is in suppressed state.
"G"
The route is in Garbage-collect state.
enable ipsec-policy (RIPng view)
Use enable ipsec-policy to apply an IPsec policy in a RIPng process.
Use undo enable ipsec-policy to remove the IPsec policy from the RIPng process.
enable ipsec-policy policy-name
No IPsec policy is configured for the RIPng process.
RIPng view
2: System level
policy-name: IPsec policy name, a string of 1 to 15 characters.
The IPsec policy to be applied must have been configured.
# Apply IPsec policy policy001 to RIPng process 1.
[Sysname] ripng 1
[Sysname-ripng-1] enable ipsec-policy policy001
filter-policy export (RIPng view)
Use filter-policy export to define an outbound route filtering policy. Only routes passing the filter can be advertised in the update messages.
Use undo filter-policy export to disable the outbound route filtering.
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ protocol [ process-id ] ]
RIPng does not filter any outbound routing information.
RIPng view
2: System level
acl6-number: Specifies the number of an ACL to filter advertised routing information, in the range of 2000 to 3999.
ipv6-prefix ipv6-prefix-name: Specifies the name of an IPv6 prefix list used to filter routing information, a string of 1 to 19 characters.
protocol: Filters routes redistributed from a routing protocol, including direct, ripng, and static.
process-id: Process number of the specified routing protocol, in the range of 1 to 65535. This argument is available only when the routing protocol is ripng.
With the protocol argument specified, only routing information redistributed from the specified routing protocol will be filtered. Otherwise, all outgoing routing information will be filtered.
To reference an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL in one of the following ways:
·     To deny/permit a route with the specified destination, use rule [ rule-id ] { deny | permit } ipv6 source sour sour-prefix.
·     To deny/permit a route with the specified destination and prefix, use rule [ rule-id ] { deny | permit } ipv6 source sour sour-prefix destination dest dest-prefix.
The source keyword specifies the destination address of a route, and the destination keyword specifies the prefix of the route. (The prefix must be valid; otherwise, the configuration is ineffective.)
# Use IPv6 prefix list Filter 2 to filter advertised RIPng updates.
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy ipv6-prefix Filter2 export
# Configure ACL6 3000 to permit only route 2001::1/128 to pass, and reference ACL6 3000 to filter advertised RIPng updates.
[Sysname-acl6-adv-3000] rule 10 permit ipv6 source 2001::1 128 destination ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff 128
[Sysname-acl6-adv-3000] rule 100 deny ipv6
[Sysname-acl6-adv-3000] quit
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy 3000 export
filter-policy import (RIPng view)
Use filter-policy import to define an inbound route filtering policy. Only routes that match the filtering policy can be received.
Use undo filter-policy import to disable inbound route filtering.
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } import
RIPng does not filter incoming routing information.
RIPng view
2: System level
acl6-number: Specifies the number of an ACL to filter incoming routing information, in the range of 2000 to 3999.
ipv6-prefix ipv6-prefix-name: Specifies the name of an IPv6 prefix list to filter incoming routes, in the range of 1 to 19 characters.
# Reference IPv6 prefix list Filter1 to filter incoming RIPng updates.
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy ipv6-prefix Filter1 import
# Configure ACL6 3000 to permit only route 2001::1/128 to pass, and reference ACL6 3000 to filter incoming RIPng updates.
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy 3000 import
import-route
Use import-route to redistribute routes from another routing protocol.
Use undo import-route to disable redistributing routes from another routing protocol.
import-route protocol [ process-id ] [ cost cost ] *
undo import-route protocol [ process-id ]
RIPng does not redistribute routes from other routing protocols.
RIPng view
2: System level
protocol: Specifies a routing protocol from which to redistribute routes. It can be direct, ripng, or static.
process-id: Process ID, in the range of 1 to 65535. The default is 1. This argument is available only when the protocol is ripng.
cost: Routing metric of redistributed routes, in the range of 0 to 16. If cost value is not specified, the metric is the default metric specified by the default cost command.
# Redistribute RIPng routes (process 7) and specify the metric as 7.
[Sysname] ripng 100
[Sysname-ripng-100] import-route ripng 7 cost 7
default cost
maximum load-balancing (RIPng view)
Use maximum load-balancing to specify the maximum number of equal-cost multi-path (ECMP) routes for load balancing.
Use undo maximum load-balancing to restore the default.
maximum load-balancing number
The maximum number of ECMP routes is 4.
RIPng view
2: System level
number: Maximum number of ECMP routes. The value range is 1 to 4.
Configure the maximum number of ECMP routes according to the memory size.
# Set the maximum number of ECMP routes to 2.
[Sysname] ripng 100
[Sysname-ripng-100] maximum load-balancing 2
preference
Use preference to specify the preference for RIPng routes.
Use undo preference to restore the default.
preference preference
undo preference
The preference of RIPng routes is 100.
RIPng view
2: System level
preference: Preference for RIPng routes, in the range of 1 to 255.
# Set the RIPng route preference to 120.
[Sysname] ripng 100
[Sysname-ripng-100] preference 120
# Restore the default RIPng route preference.
[Sysname-ripng-100] undo preference
reset ripng process
Use reset ripng process to reset the specified RIPng process.
reset ripng process-id process
2: System level
After executing the command, you are prompted whether you want to reset the RIPng process.
# Reset RIPng process 100.
<Sysname> reset ripng 100 process
Warning : Reset RIPng process? [Y/N]:Y
reset ripng statistics
Use reset ripng statistics to clear the statistics of the specified RIPng process.
reset ripng process-id statistics
1: Monitor level
# Clear the statistics of RIPng process 100.
<Sysname> reset ripng 100 statistics
ripng
Use ripng to create a RIPng process and enter RIPng view.
Use undo ripng to disable a RIPng process.
undo ripng [ process-id ]
No RIPng process is enabled.
2: System level
process-id: RIPng process ID, in the range of 1 to 65535. The default value is 1.
Before configuring global RIPng parameters, you must create a RIPng process. This requirement does not apply to interface RIPng parameter configuration.
After you disable a RIPng process, the RIPng parameters on interface running the process also become ineffective.
# Create RIPng process 100 and enter its view.
[Sysname] ripng 100
[Sysname-ripng-100]
# Disable RIPng process 100.
[Sysname] undo ripng 100
ripng default-route
Use ripng default-route to advertise a default route with the specified routing metric to a RIPng neighbor.
Use undo ripng default-route to stop advertising or forwarding the default route.
ripng default-route { only | originate } [ cost cost ]
A RIP process does not advertise any default route.
Interface view
2: System level
only: Indicates that only the IPv6 default route (::/0) is advertised through the interface.
originate: Indicates that the IPv6 default route (::/0) is advertised without suppressing other routes.
cost: Metric of the advertised default route, in the range of 1 to 15, with a default value of 1.
After you execute this command, the generated RIPng default route is advertised in a route update over the specified interface. This IPv6 default route is advertised without considering whether it already exists in the local IPv6 routing table.
# Advertise only the default route through GigabitEthernet 1/0/5.
[Sysname] interface gigabitethernet1/0/5
[Sysname-GigabitEthernet1/0/5] ripng default-route only
# Advertise the default route together with other routes through GigabitEthernet 1/0/5.
[Sysname-GigabitEthernet1/0/5] ripng default-route originate
ripng enable
Use ripng enable to enable RIPng on the specified interface.
Use undo ripng enable to disable RIPng on the specified interface.
ripng process-id enable
undo ripng [ process-id ] enable
RIPng is disabled on an interface.
Interface view
2: System level
# Enable RIPng100 on GigabitEthernet 1/0/5.
[Sysname-GigabitEthernet1/0/5] ripng 100 enable
ripng ipsec-policy
Use ripng ipsec-policy to apply an IPsec policy on a RIPng interface.
Use undo ripng ipsec-policy to remove the IPsec policy from the RIPng interface.
ripng ipsec-policy policy-name
No IPsec policy is configured for the RIPng interface.
Interface view
2: System level
# Apply IPsec policy policy001 to interface GigabitEthernet 1/0/5.
[Sysname-GigabitEthernet1/0/5] ripng ipsec-policy policy001
ripng metricin
Use ripng metricin to specify an additional metric for received RIPng routes.
Use undo ripng metricin to restore the default.
ripng metricin value
undo ripng metricin
The additional metric to received routes is 0.
Interface view
2: System level
value: Additional metric for received routes, in the range of 0 to 16.
# Specify the additional routing metric as 12 for RIPng routes received by GigabitEthernet 1/0/5.
[Sysname-GigabitEthernet1/0/5] ripng metricin 12
ripng metricout
ripng metricout
Use ripng metricout to configure an additional metric for RIPng routes advertised by an interface.
Use undo rip metricout to restore the default.
ripng metricout value
undo ripng metricout
The default additional routing metric is 1.
Interface view
2: System level
value: Additional metric to advertised routes, in the range of 1 to 16.
# Set the additional metric to 12 for routes advertised by GigabitEthernet 1/0/5.
[Sysname-GigabitEthernet1/0/5] ripng metricout 12
ripng metricin
ripng poison-reverse
Use ripng poison-reverse to enable the poison reverse function.
Use undo ripng poison-reverse to disable the poison reverse function.
The poison reverse function is disabled.
Interface view
2: System level
# Enable the poison reverse function for RIPng update messages on GigabitEthernet 1/0/5.
[Sysname-GigabitEthernet1/0/5] ripng poison-reverse
ripng split-horizon
Use ripng split-horizon to enable the split horizon function.
Use undo ripng split-horizon to disable the split horizon function.
ripng split-horizon
The split horizon function is enabled.
Interface view
2: System level
The split horizon function is necessary for preventing routing loops. Do not disable it unless you make sure that it is necessary.
If both the poison reverse and split horizon functions are enabled, only the poison reverse function takes effect.
On frame relay, X.25, and other non-broadcast multi-access (NBMA) links, split horizon should be disabled if multiple VCs are configured on the primary interface and secondary interfaces to ensure route advertisement.
# Enable the split horizon function on GigabitEthernet 1/0/5.
[Sysname-GigabitEthernet1/0/5] ripng split-horizon
ripng summary-address
Use ripng summary-address to configure a summary network to be advertised through the interface.
Use undo ripng summary-address to remove the summary.
ripng summary-address ipv6-address prefix-length
undo ripng summary-address ipv6-address prefix-length
Interface view
2: System level
ipv6-address: Destination IPv6 address of the summary route.
prefix-length: Prefix length of the destination IPv6 address of the summary route, in the range of 0 to 128. It indicates the number of consecutive 1s of the prefix, which defines the network ID.
Networks falling into the summary network will not be advertised. The cost of the summary route is the lowest cost among summarized routes.
# Assign an IPv6 address with the 64-bit prefix to GigabitEthernet 1/0/5 and configure a summary with the 35-bit prefix.
[Sysname-GigabitEthernet1/0/5] ipv6 address 2001:200::3EFF:FE11:6770/64
[Sysname-GigabitEthernet1/0/5] ripng summary-address 2001:200:: 35
timers
Use timers to configure RIPng timers.
Use undo timers to restore the default.
undo timers { garbage-collect | suppress | timeout | update } *
The garbage-collect timer is 120 seconds, the suppress timer 120 seconds, the timeout timer 180 seconds, and the update timer 30 seconds.
RIPng view
2: System level
garbage-collect-value: Interval of the garbage-collect timer in seconds, in the range of 1 to 86400.
suppress-value: Interval of the suppress timer in seconds, in the range of 0 to 86400.
timeout-value: Interval  of the timeout timer in seconds, in the range of 1 to 86400.
update-value: Interval of the update timer in seconds, in the range of 1 to 86400.
RIPng is controlled by the following timers:
·     Update timer—Defines the interval between update messages.
·     Timeout timer—Defines the route aging time. If no update message related to a route is received within the aging time, the metric of the route is set to 16 in the routing table.
·     Suppress timer—Defines for how long a RIPng route stays in suppressed state. When the metric of a route is 16, the route enters the suppressed state. In suppressed state, only routes which come from the same neighbor and whose metric is less than 16 will be received by the router to replace unreachable routes.
·     Garbage-collect timer—Defines the interval from when the metric of a route becomes 16 to when it is deleted from the routing table. During the garbage-collect timer length, RIPng advertises the route with the routing metric set to 16. If no update message is announced for that route before the garbage-collect timer expires, the route will be completely deleted from the routing table.
H3C does not recommend changing the default values of these timers under normal circumstances.
The lengths of these timers must be kept consistent on all routers in the network.
# Configure the update, timeout, suppress, and garbage-collect timers as 5s, 15s, 15s and 30s.
[Sysname] ripng 100
[Sysname-ripng-100] timers update 5
[Sysname-ripng-100] timers timeout 15
[Sysname-ripng-100] timers suppress 15
[Sysname-ripng-100] timers garbage-collect 30
