04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10204-Layer 3 Command Reference
12-Basic IP Routing Commands
12-Basic IP Routing Commands 105.50 KB
Basic IP routing commands
display ip routing-table
Use display ip routing-table to display brief information about active routes in the routing table.
Use display ip routing-table verbose to display detailed information about all routes in the routing table.
display ip routing-table [ verbose ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
verbose: Displays detailed information about all routes, including both active and inactive routes. Without this keyword, the command displays only brief information about active routes.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
The display ip routing-table command displays brief information about a routing table, with a routing entry contained in one line. The information displayed includes destination IP address/mask length, protocol, priority, cost, next hop and output interface. The display ip routing-table command displays only the optimal routes in use.
The display ip routing-table verbose command displays detailed information about all active and inactive routes, including the statistics of the entire routing table and information for each route.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
Routing Tables: Public
         Destinations : 7       Routes : 7
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
1.1.2.0/24          Direct 0    0            1.1.2.1         Vlan1
1.1.2.1/32          Direct 0    0            127.0.0.1       InLoop0
2.2.2.0/24          OSPF   10   2            1.1.2.2         InLoop0
192.168.0.0/24      Direct 0    0            192.168.0.1     VT1
192.168.0.1/32      Direct 0    0            127.0.0.1       InLoop0
Destinations
Number of destination addresses.
Routes
Number of routes.
Destination/Mask
Destination address/mask length.
Proto
Protocol that installed the route.
Pre
Preference of the route.
Cost
Cost of the route.
NextHop
Next hop address of the route.
Output interface for packets to be forwarded along the route.
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
         Destinations : 6       Routes : 6
  Destination: 1.1.2.0/24
     Protocol: Direct          Process ID: 0
   Preference: 0                     Cost: 0
 IpPrecedence:                    QosLcId:
      NextHop: 1.1.2.1          Interface: Vlan-interface1
    BkNextHop: 0.0.0.0        BkInterface:
  RelyNextHop: 0.0.0.0          Neighbor : 0.0.0.0
    Tunnel ID: 0x0                  Label: NULL
  BKTunnel ID: 0x0                BKLabel: NULL
        State: Active Adv             Age: 06h46m22s
          Tag: 0
  Destination: 1.1.2.1/32
      NextHop: 127.0.0.1        Interface: InLoopBack0
        State: Active NoAdv           Age: 06h46m22s
          Tag: 0
  Destination: 127.0.0.0/8
        State: Active NoAdv           Age: 06h46m36s
          Tag: 0
  Destination: 127.0.0.1/32
        State: Active NoAdv           Age: 06h46m37s
          Tag: 0
  Destination: 192.168.0.0/24
      NextHop: 192.168.0.1      Interface: Virtual-Template1
        State: Active Adv             Age: 06h46m35s
          Tag: 0
  Destination: 192.168.0.1/32
        State: Active NoAdv           Age: 06h46m35s
          Tag: 0
Statistics for the entire routing table are displayed first, followed by detailed description of each route (in sequence).
Destination
Protocol
Preference
Cost
Cost of the route.
IpPrecedence
IP precedence.
QosLcId
Local QoS ID.
NextHop
BkNextHop
Backup next hop.
BkInterface
Backup output interface.
RelyNextHop
Next hop address obtained through routing recursion.
Neighbor
Neighboring address determined by the routing protocol.
BKTunnel ID
Backup tunnel ID.
BKLabel
Backup label.
Route status:
·     Active—This is an active unicast route.
·     Adv—This route can be advertised.
·     Delete—This route is deleted.
·     Gateway—This is an indirect route.
·     Holddown—Number of holddown routes. Holddown is a route advertisement policy used in some routing protocols, such as RIP, to avoid the propagation of incorrect routes. It distributes a Holddown route during a period regardless of whether a new route to the same destination is found. For more information, refer to relevant routing protocols.
·     Int—The route was discovered by an Interior Gateway Protocol (IGP).
·     NoAdv—The route is not advertised when the router advertises routes based on policies.
·     NotInstallThe route with the highest priority among the routes to a destination is installed into the core routing table and advertised. A NotInstall route cannot be installed into the core routing table but can be advertised.
·     Reject—The packets matching a Reject route are dropped. The router sends ICMP unreachable messages to the sources of the dropped packets. The Reject routes are typically used for network testing.
·     Static—A static route is not lost when you perform the save operation and then restart the router. Routes configured manually are marked as static.
·     Unicast—Unicast routes.
·     Inactive—Inactive routes.
·     Invalid—Invalid routes.
·     WaitQ—The route is the WaitQ during route recursion.
·     TunE—Tunnel.
·     GotQ—The route is in the GotQ during route recursion.
Age
Time for which the route has been in the routing table, in the sequence of hour, minute, and second from left to right.
Tag
Route tag.
display ip routing-table ip-address
Use display ip routing-table ip-address to display information about routes to a specific destination address.
Use display ip routing-table ip-address1 { mask-length | mask } ip-address2 { mask-length | mask } to display information about active routes whose destinations and masks fall into the specified address range.
display ip routing-table ip-address [ mask | mask-length ] [ longer-match ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
display ip routing-table ip-address1 { mask | mask-length } ip-address2 { mask | mask-length } [ verbose ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
ip-address: Specifies a destination IP address, in dotted decimal notation.
mask: Specifies the mask length, in dotted decimal notation.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
longer-match: Displays the route with the longest mask.
verbose: Displays detailed information about all routes. Without this argument, the command displays only brief information about active routes.
Executing the command with different parameters yields the following results:
·     display ip routing-table ip-address:
¡     The system ANDs the input destination IP address with the subnet mask in each route entry.
¡     The system ANDs the destination IP address in each route entry with its own subnet mask.
If the two operations yield the same result for an entry and this entry is active, the entry is displayed.
·     display ip routing-table ip-address mask:
¡     The system ANDs the input destination IP address with the input subnet mask.
¡     The system ANDs the destination IP address in each route entry with the input subnet mask.
If the two operations yield the same result for an entry and the entry is active with a subnet mask less than or equal to the input subnet mask, the entry is displayed.
·     display ip routing-table ip-address longer-match:
If the two operations yield the same result for multiple entries that are active, the entry with the longest mask length is displayed.
·     display ip routing-table ip-address mask longer-match:
If the two operations yield the same result for multiple entries with a mask less than or equal to the input subnet mask, the entry that is active with the longest mask length is displayed.
# Display brief information about the routes with destination IP address 11.0.0.1.
<Sysname> display ip routing-table 11.0.0.1
Routing Table : Public
Summary Count : 3
11.0.0.0/8          Static 60   0            0.0.0.0         NULL0
11.0.0.0/16         Static 60   0            0.0.0.0         NULL0
11.0.0.0/24         Static 60   0            0.0.0.0         NULL0
# Display brief information about the routes with destination IP address 11.0.0.1 and mask length 20.
<Sysname> display ip routing-table 11.0.0.1 20
Summary Count : 3
11.1.0.0/16         Static 60   0            0.0.0.0         NULL0
# Display brief information about the routes with destination IP address 11.0.0.1 and the longest mask length.
<Sysname> display ip routing-table 11.0.0.1 longer-match
Summary Count : 1
# Display brief information about the routes with destination IP address 11.0.0.1, mask length 20, and the longest mask length.
<Sysname> display ip routing-table 11.0.0.1 20 longer-match
Summary Count : 1
# Display brief information about the routes with destination addresses in the range of 1.1.1.0 to 5.5.5.0.
<Sysname> display ip routing-table 1.1.1.0 24 5.5.5.0 24
1.1.1.0/24          Direct 0    0            1.1.1.1       Vlan1
1.1.1.1/32          Direct 0    0            127.0.0.1     InLoop0
2.2.2.0/24          Direct 0    0            2.2.2.1       Vlan2
3.3.3.0/24          Direct 0    0            3.3.3.1       Vlan3
3.3.3.1/32          Direct 0    0            127.0.0.1     InLoop0
4.4.4.0/24          Direct 0    0            4.4.4.1       Vlan4
4.4.4.1/32          Direct 0    0            127.0.0.1     InLoop0
For command output, see Table 1.
display ip routing-table protocol
Use display ip routing-table protocol to display information about routes installed by a routing protocol.
display ip routing-table protocol protocol [ inactive | verbose ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
protocol: Specifies a routing protocol. It can be direct or static.
inactive: Displays information about only inactive routes. Without this argument, the command displays information about all routes.
verbose: Displays detailed routing table information. Without this argument, the command displays brief routing table information.
# Display brief information about direct routes.
<Sysname> display ip routing-table protocol direct
Public Routing Table : Direct
Summary Count : 6
Direct Routing Table Status : <Active>
Summary Count : 6
2.2.2.2/32          Direct 0    0          127.0.0.1       InLoop0
192.168.80.0/24     Direct 0    0          192.168.80.10   Vlan3
192.168.80.10/32    Direct 0    0          127.0.0.1       InLoop0
Direct Routing Table Status : <Inactive>
Summary Count : 0
# Display brief information about static routes.
<Sysname> display ip routing-table protocol static
Public Routing Table : Static
Summary Count : 2
Static Routing Table Status : <Active>
Summary Count : 0
Static Routing Table Status : <Inactive>
Summary Count : 2
1.2.3.0/24          Static  60   0          1.2.4.5      Vlan10
3.0.0.0/8           Static  60   0          2.2.2.2      Vlan3
display ip routing-table statistics
Use display ip routing-table statistics to display IPv4 route statistics.
display ip routing-table statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display IPv4 route statistics for the public network.
<Sysname> display ip routing-table statistics
Proto      route       active      added       deleted     freed
DIRECT     4           4           6           2           2
STATIC     1           0           1           0           0
Total      5           4           7           2           2
Proto
Routing protocol that installed the route.
route
Number of routes installed by the protocol.
active
Number of active routes.
added
Number of routes added into the routing table since the router started up or the routing table was most recently cleared.
deleted
Number of routes marked as deleted, which will be cleared after a period.
freed
Number of routes that were permanently removed.
Total
Total number of routes.
display ipv6 routing-table
Use display ipv6 routing-table to display brief IPv6 routing table information, including destination IP address and prefix, protocol type, priority, metric, next hop and output interface.
Use display ipv6 routing-table verbose to display detailed information about all IPv6 routes, including both active and inactive routes.
display ipv6 routing-table [ verbose ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
verbose: Displays detailed information about all IPv6 routes, including both active and inactive routes. Without this keyword, the command displays only brief information about active routes.
The display ipv6 routing-table command displays brief information about only active routes.
The display ipv6 routing-table verbose command displays statistics about the entire routing table, and detailed information about each route.
# Display brief routing table information.
<Sysname> display ipv6 routing-table
        Destinations : 1        Routes : 1
Destination: ::1/128                           Protocol  : Direct
NextHop    : ::1                               Preference: 0
Interface  : InLoop0                           Cost      : 0
Destination
IPv6 address of the destination network/host.
NextHop
Preference
Output interface.
Protocol
Cost
Cost of the route.
# Display detailed routing table information.
<Sysname> display ipv6 routing-table verbose
 Destination  : ::1                                     PrefixLength : 128
 NextHop      : ::1                                     Preference   : 0
 IpPrecedence :                                         QosLcId      :
 RelayNextHop : ::                                      Tag          : 0H
 Neighbor     : ::                                      ProcessID    : 0
 Interface    : InLoopBack0                             Protocol     : Direct
 State        : Active NoAdv                            Cost         : 0
 Tunnel ID    : 0x0                                     Label        : NULL
 Age          : 22161sec
Table 5 Command output
Destination
PrefixLength
Prefix length of the address.
NextHop
Preference
IpPrecedence
IP precedence.
QosLcId
Local QoS ID.
RelayNextHop
Recursive next hop.
Tag
Tag of the route.
Neighbor
Address of the neighbor determined by the routing protocol.
Output interface.
Protocol
Routing protocol.
State of the route:
·     Active.
·     Inactive.
·     Adv (advertised).
·     NoAdv (not advertised).
Cost
Cost of the route.
Age
Time that has elapsed since the route was generated.
display ipv6 routing-table ipv6-address
Use display ipv6 routing-table ipv6-address to display information about routes to an IPv6 destination  address.
Use display ipv6 routing-table ipv6-address1 ipv6-address2 to display information about routes to a range of IPv6 destination addresses.
display ipv6 routing-table ipv6-address [ prefix-length ] [ longer-match ] [ verbose ] [ | { begin | exclude | include } regular-expression ]
display ipv6 routing-table ipv6-address1 prefix-length1 ipv6-address2 prefix-length2 [ verbose ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
ipv6-address: Specifies an IPv6 destination  address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
longer-match: Displays the matched route entry with the longest prefix length.
ipv6-address1/ipv6-address2: Specifies an IPv6 destination address range.
prefix-length1/prefix-length2: Specifies the prefix length in the range of 0 to 128.
verbose: Displays detailed information about all routes. Without this keyword, the command displays only brief information about active routes.
·     display ipv6 routing-table ipv6-address:
¡     The system ANDs the input destination IPv6 address with the prefix length in each route entry.
¡     The system ANDs the destination IPv6 address in each route entry with the prefix length in each entry.
·     display ipv6 routing-table ipv6-address prefix-length:
¡     The system ANDs the input destination IPv6 address with the input prefix length.
¡     The system ANDs the destination IPv6 address in each route entry with the input prefix length.
If the two operations yield the same result for an entry and the entry is active with a prefix length less than or equal to the input prefix length, the entry is displayed.
Only route entries that exactly match the input destination address and prefix length are displayed.
·     display ipv6 routing-table ipv6-address longer-match:
If the two operations yield the same result for multiple entries, the entry that is active with the longest prefix length is displayed.
·     display ipv6 routing-table ipv6-address prefix-length longer-match:
If the two operations yield the same result for multiple entries with a prefix length less than or equal to the input prefix length, the entry that is active with the longest prefix length is displayed.
# Display brief information about the routes with destination IPv6 address 10::1.
<Sysname> display ipv6 routing-table 10::1
Routing Table: Public
Summary Count: 3
Destination: 10::/64                                     Protocol  : Static
NextHop    : ::                                          Preference: 60
Interface  : NULL0                                       Cost      : 0
Destination: 10::/68                                     Protocol  : Static
Destination: 10::/120                                     Protocol  : Static
# Display brief information about the routes with destination IPv6 address 10::1 and prefix length 100.
<Sysname> display ipv6 routing-table 10::1 100
Summary Count: 2
# Display brief information about the routes with destination IPv6 address 10::1 and the longest prefix length.
<Sysname> display ipv6 routing-table 10::1 longer-match
Summary Count : 1
# Display brief information about the routes with destination IPv6 address 10::1, prefix length 100, and the longest prefix length.
<Sysname> display ipv6 routing-table 10::1 100 longer-match
Summary Count: 1
# Display brief information about the routes with destination IPv6 addresses in the range of 100::/64 to 300::/64.
<Sysname> display ipv6 routing-table 100:: 64 300:: 64
Summary Count : 3
Destination: 100::/64                                    Protocol  : Static
Destination: 200::/64                                    Protocol  : Static
Destination: 300::/64                                    Protocol  : Static
         Cost      : 0
For command output, see Table 4.
display ipv6 routing-table protocol
Use display ipv6 routing-table protocol to display IPv6 routes installed by a routing protocol.
display ipv6 routing-table protocol protocol [ inactive | verbose ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
protocol:  Specifies a routing protocol. The protocol can be direct or static.
inactive: Displays information about inactive routes. Without the keyword, the command displays information about all routes.
# Display brief information about all direct routes.
<Sysname> display ipv6 routing-table protocol direct
Summary Count : 1
Summary Count : 1
Summary Count : 0
display ipv6 routing-table statistics
Use display ipv6 routing-table statistics to display IPv6 route statistics.
display ipv6 routing-table statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display IPv6 route statistics for the public network.
<Sysname> display ipv6 routing-table statistics
Protocol   route       active      added       deleted     freed
DIRECT     1           1           1           0           0
STATIC     0           0           0           0           0
Total      1           1           1           0           0
Table 6 Command output
Protocol
route
active
added
Number of routes added to the routing table after the router started up or the routing table was most recently cleared.
deleted
freed
Total
reset ip routing-table statistics protocol
Use reset ip routing-table statistics protocol to clear IPv4 route statistics.
reset ip routing-table statistics protocol { protocol | all }
2: System level
protocol: Clears route statistics for the IPv4 routing protocol. It can be direct or static.
all: Clears route statistics for all IPv4 routing protocols.
# Clear route statistics for all routing protocols.
<Sysname> reset ip routing-table statistics protocol all
reset ipv6 routing-table statistics
Use reset ipv6 routing-table statistics to clear IPv6 route statistics.
reset ipv6 routing-table statistics protocol { protocol | all }
2: System level
protocol: Clears route statistics for an IPv6 routing protocol. It can be direct or static.
all: Clears route statistics for all IPv6 routing protocols.
# Clear route statistics for the public network.
<Sysname> reset ipv6 routing-table statistics protocol all
