- 04-Layer 3 Command Reference
- 01-ARP Commands
- 02-IP Addressing Commands
- 03-DHCP Commands
- 04-DHCPv6 Commands
- 05-DNS Commands
- 06-IPv6 DNS Commands
- 07-NAT Commands
- 08-Adjacency Table Commands
- 09-Flow Classification Commands
- 10-IPv6 Basics Commands
- 11-IP Performance Optimization Commands
- 12-Basic IP Routing Commands
- 13-Static Routing Commands
- 14-IPv6 Static Routing Commands
- 15-GRE Commands
- 16-RIP Commands
- 17-RIPng Commands
- 18-Policy-Based Routing Commands
18-Policy-Based Routing Commands | 71.30 KB |
Policy-based routing configuration commands
apply default output-interface
apply ip-address default next-hop
apply output-interface ip-address next-hop
display ip policy-based-route setup
display ip policy-based-route statistics
reset policy-based-route statistics
Use apply default output-interface to set a default output interface.
Use undo apply default output-interface to remove the configuration.
apply default output-interface interface-type interface-number [ track track-entry-number ] [ interface-type interface-number [ track track-entry-number ] ]
undo apply default output-interface [ interface-type interface-number [ interface-type interface-number ] ]
Policy node view
Default command level
2: System level
track track-entry-number: Specifies a track entry by its number, in the range of 1 to 1024.
You can specify up to two default output interfaces by performing this command once or twice.
A specified default output interface must be P2P type. Using a non-P2P output interface (broadcast and NBMA interfaces such as Ethernet and virtual-template interfaces) can result in forwarding failures when the interface has multiple next hops.
With an interface specified, the undo apply default output-interface command removes the specified default output interface.
Without any interface specified, the undo apply default output-interface command removes all default output interfaces.
# Set GigabitEthernet 1/0/5 as the default output interface.
[Sysname] policy-based-route aa permit node 11
[Sysname-pbr-aa-11] apply default output-interface gigabitethernet1/0/5
Use apply ip-address default next-hop to set the default next hops.
Use undo apply ip-address default next-hop to remove the configuration.
apply ip-address default next-hop ip-address [ track track-entry-number ] [ ip-address [ track track-entry-number ] ]
undo apply ip-address default next-hop [ ip-address [ ip-address ] ]
Policy node view
2: System level
ip-address: Specifies the default next hop IP address.
You can specify up to two default next hops by performing this command once or twice.
With a next hop specified, the undo apply ip-address default next-hop command removes the specified default next hop.
Without any next hop specified, the undo apply ip-address default next-hop command removes all default next hops.
# Set the default next hop of 1.1.1.1.
[Sysname-pbr-aa-11] apply ip-address default next-hop 1.1.1.1
apply ip-address next-hop
Use apply ip-address next-hop to set the next hops for packets.
Use undo apply ip-address next-hop to remove the configuration.
apply ip-address next-hop ip-address [ direct ] [ track track-entry-number ] [ ip-address [ direct ] [ track track-entry-number ] ]
undo apply ip-address next-hop [ ip-address [ ip-address ] ]
Policy node view
2: System level
ip-address: Specifies the next hop IP address.
direct: Specifies that the next hop must be directly connected to take effect.
You can specify up to two next hops by performing this command once or twice.
With a next hop specified, the undo apply ip-address next-hop command removes the specified next hop.
Without any next hop specified, the undo apply ip-address next-hop command removes all next hops.
# Set a directly-connected next hop of 1.1.1.1.
[Sysname-pbr-aa-11] apply ip-address next-hop 1.1.1.1 direct
apply ip-df zero
Use apply ip-df zero to set the Don’t Fragment (DF) bit in the IP header of matching packets to 0, which means the packet can be fragmented.
Use undo apply ip-df to remove the configuration.
apply ip-df zero
undo apply ip-df
Policy node view
2: System level
# Set the DF bit in the IP header of matching packets to 0.
[Sysname-pbr-aa-11] apply ip-df zero
apply ip-precedence
Use apply ip-precedence to set a precedence for packets.
Use undo apply ip-precedence to remove the configuration.
apply ip-precedence value
Policy node view
2: System level
value: Sets the precedence for IP packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IP packets.
Table 1 IP precedences and the corresponding types
Precedence value |
Precedence type |
0 |
routine |
1 |
priority |
2 |
immediate |
3 |
flash |
4 |
flash-override |
5 |
critical |
6 |
internet |
7 |
network |
# Set the precedence to 5 (critical) for packets.
[Sysname-pbr-aa-11] apply ip-precedence critical
Use apply output-interface to set output interfaces for packets.
Use undo apply output-interface to remove the configuration.
apply output-interface interface-type interface-number [ track track-entry-number ] [ interface-type interface-number [ track track-entry-number ] ]
undo apply output-interface [ interface-type interface-number [ interface-type interface-number ] ]
Policy node view
2: System level
You can specify up to two output interfaces by performing this command once or twice.
A specified output interface must be P2P type. Using a non-P2P output interface (broadcast and NBMA interfaces such as Ethernet and virtual-template interfaces) can result in forwarding failures when the interface has multiple next hops.
With an interface specified, the undo apply output-interface command removes the specified output interface.
Without any interface specified, the undo apply output-interface command removes all output interfaces.
Non-broadcast multi-access (NBMA) networks adopt the unicast mode to send packets.
# Specify tunnel 3 as the output interface for IP packets.
[Sysname-pbr-aa-11] apply output-interface tunnel 3
Use apply output-interface ip-address next-hop dhcpc to specify the output interface and next hop. The next hop is the gateway address learned through DHCP.
apply output-interface interface-type interface-number ip-address next-hop dhcpc
Policy node view
2: System level
interface-type interface-number: Specifies an output interface by its type and number.
ip-address next-hop dhcpc: Specifies the gateway address learned through DHCP as the next hop.
# Specify the management subinterface GigabitEthernet 1/0/5.1 as the output interface. (Because GigabitEthernet 1/0/5.1 obtains its IP address through DHCP and the next hop address is unknown, you need to specify the gateway address learned through DHCP as the next hop address.)
[Sysname] policy-based-route management permit node 1
[Sysname-pbr-management-1] apply output-interface gigabitethernet1/0/5.1 ip-address next-hop dhcpc
Use display ip policy-based-route to display information about local PBR and interface PBR.
display ip policy-based-route [ | { begin | exclude | include } regular-expression ]
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display information about local PBR and interface PBR.
<Sysname> display ip policy-based-route
Policy Name interface
pr02 local
pr02 Virtual-Template0
pr01 GigabitEthernet1/0/5
Policy Name |
Policy name. |
interface |
PBR type. This field displays local for a local PBR or a specific interface (such as GigabitEthernet 1/0/5) to which the policy has been applied to implement interface PBR. |
Use display ip policy-based-route setup to display PBR configuration.
display ip policy-based-route setup { policy-name | interface interface-type interface-number | local } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
policy-name: Displays the PBR configuration of the specified policy by its name, a string of 1 to 19 characters.
interface interface-type interface-number: Displays the PBR configuration on the specified interface.
local: Displays the local PBR information.
# Display PBR configuration for policy pr01.
<Sysname> display ip policy-based-route setup pr01
policy Name interface
# Display PBR configuration on GigabitEthernet 1/0/5.
<Sysname> display ip policy-based-route setup interface GigabitEthernet1/0/5
Interface GigabitEthernet1/0/5 policy based routing configuration information:
policy-based-route: pr01
permit node 1:
if-match acl 3101
apply next-hop 1.1.1.1
# Display local PBR configuration.
<Sysname> display ip policy-based-route setup local
Local policy based routing configuration information:
permit node 1:
if-match acl 3101
policy Name |
Policy name. |
interface |
Interface where the policy is applied. Local means the policy is applied locally. |
Interface GigabitEthernet 1/0/5 policy based routing configuration information |
PBR configuration on GigabitEthernet 1/0/5. |
Local policy based routing configuration information |
Local PBR information. |
policy-based-route |
Policy name. |
permit node |
The match mode is permit. |
if-match acl |
Match packets against ACL. |
apply output-interface Serial2/0 |
Specify the output interface. |
Use display ip policy-based-route statistics to display PBR statistics.
display ip policy-based-route statistics { interface interface-type interface-number | local } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
interface interface-type interface-number: Displays the statistics of PBR on the specified interface.
local: Displays the statistics of local PBR.
Packets matching a deny-mode node are forwarded according to the routing table. Therefore, no statistics are available for such packets.
# Display the statistics of PBR on GigabitEthernet 1/0/5.
<Sysname> display ip policy-based-route statistic interface GigabitEthernet1/0/5
Interface GigabitEthernet1/0/5 policy based routing statistics information:
policy-based-route: aaa
permit node 5
if-match acl 3101
matched: 0
Total matched: 0
Interface GigabitEthernet 1/0/5 policy based routing statistics information |
PBR statistics on GigabitEthernet 1/0/5. |
policy-based-route: aaa |
Policy name. |
permit node |
The match mode of node is permit. |
if-match acl |
apply output-interface |
Output interface. |
matched |
Matching packets on the node. |
Total matched |
Total matching packets on all nodes. |
display policy-based-route
Use display policy-based-route to display PBR policy information.
display policy-based-route [ policy-name ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
policy-name: Displays information about the specified policy. A policy name is a string of 1 to 19 characters.
If no policy name is specified, this command displays information about all policies.
If a policy is specified, this command displays information about the specified policy.
# Display the PBR policy information.
<Sysname> display policy-based-route
Policy based routing configuration information:
policy-based-route : aaa
Node 1 permit :
Table 5 Command output
Policy name. |
Node 1 permit |
The match mode of Node 1 is permit. |
if-match acl
Use if-match acl to configure an ACL match criterion.
Use undo if-match acl to remove the ACL match criterion.
if-match acl acl-number
undo if-match acl
Policy node view
2: System level
acl-number: Specifies the ACL number, in the range of 2000 to 3999. The number of a basic ACL ranges from 2000 to 2999 and that of an advanced ACL ranges from 3000 to 3999.
# Permit the packets matching ACL 2010.
[Sysname-pbr-aa-11] if-match acl 2010
if-match packet-length
Use if-match packet-length to define a packet length match criterion.
Use undo if-match packet-length to remove the match criterion.
if-match packet-length min-len max-len
Policy node view
2: System level
min-len: Specifies the minimum IP packet length in bytes, in the range of 0 to 65535.
max-len: Specifies the maximum IP packet length in bytes, in the range of 1 to 65535. The value of max-len must be no less than that of min-len.
# Match the packets with a length from 100 to 200 bytes.
[Sysname-pbr-aa-11] if-match packet-length 100 200
ip local policy-based-route
Use ip local policy-based-route to configure local PBR based on a specified policy.
Use undo ip local policy-based-route to remove the configuration.
ip local policy-based-route policy-name
undo ip local policy-based-route policy-name
No policy is referenced for local PBR.
2: System level
policy-name: Policy name, a string of 1 to 19 characters.
You can configure only one policy for local PBR. If you perform this command multiple times, only the last specified policy takes effect.
Local PBR is used to route locally generated packets. Do not configure local PBR unless required.
# Configure local PBR based on policy aaa.
[Sysname] ip local policy-based-route aaa
Use ip policy-based-route to configure PBR by applying a policy on the interface.
Use undo ip policy-based-route to remove the configuration.
ip policy-based-route policy-name
undo ip policy-based-route policy-name
No policy is applied on an interface.
Interface view
2: System level
policy-name: Specifies a policy by its name, a string of 1 to 19 characters.
You can apply only one policy on an interface PBR. If you perform this command multiple times, only the last specified policy takes effect.
# Apply policy aaa on GigabitEthernet 1/0/5.
[Sysname] interface GigabitEthernet 1/0/5
[Sysname-GigabitEthernet1/0/5] ip policy-based-route aaa
policy-based-route
Use policy-based-route to create a policy node, and enter policy node view. If the specified policy node already exists, the command directly places you into policy node view.
Use undo policy-based-route to remove a created policy or policy node.
undo policy-based-route policy-name [ deny | node node-number | permit ]
2: System level
policy-name: Specifies a policy name, a string of 1 to 19 characters.
deny: Specifies the match mode of the policy node as deny.
permit: Specifies the match mode of the policy node as permit.
node node-number: Specifies the number of a policy node, in the range of 0 to 65535. A smaller number has a higher priority.
# Create permit-mode of Node 10 for policy 1, and enter policy node view.
[Sysname] policy-based-route policy1 permit node 10
[Sysname-pbr-policy1-10]
Use reset policy-based-route statistics to clear PBR statistics.
reset policy-based-route statistics [ policy-name ]
1: Monitor level
If no policy is specified, this command clears all the PBR statistics.
# Clear all PBR statistics.
<Sysname> reset policy-based-route statistics
