04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10204-Layer 3 Command Reference
07-NAT Commands
07-NAT Commands 131.02 KB
NAT configuration commands
Support for NAT commands depends on the device model. For more information, see About the H3C Access Controllers Command References.
display nat address-group
Use display nat address-group to display NAT address pool information.
display nat address-group [ group-number ] [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
group-number: Specifies a NAT address pool by its number in the range of 0 to 7. The value range for this argument varies by device model. For more information, see About the H3C Access Controllers Command References. If you do not specify this argument, this command displays information about all NAT address pools.
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display NAT address pool information.
<Sysname> display nat address-group
NAT address-group information:
  There are currently 2 nat address-group(s)
  1     : from         202.110.10.10     to 202.110.10.15
  2     : from         202.110.10.20     to 202.110.10.25
# Display information about NAT address group 1.
<Sysname> display nat address-group 1
The range of IP addresses in address pool 1 is from 202.110.10.10 to 202.110.10.15.
nat address-group
display nat aging-time
Use display nat aging-time to display the NAT aging time settings for various protocols.
display nat aging-time [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display the NAT aging time settings for various protocols.
<Sysname> display nat aging-time
NAT aging-time value information:
       tcp ---- aging-time value is    300 (seconds)
       udp ---- aging-time value is    240 (seconds)
      icmp ---- aging-time value is     10 (seconds)
      pptp ---- aging-time value is    300 (seconds)
       dns ---- aging-time value is     10 (seconds)
   tcp-fin ---- aging-time value is     10 (seconds)
   tcp-syn ---- aging-time value is     10 (seconds)
  ftp-ctrl ---- aging-time value is    300 (seconds)
  ftp-data ---- aging-time value is    300 (seconds)
    no-pat ---- aging-time value is    240 (seconds)
tcp
NAT aging time for TCP.
udp
NAT aging time for UDP.
icmp
NAT aging time for ICMP.
pptp
NAT aging time for PPTP.
dns
NAT aging time for DNS.
tcp-fin
NAT aging time for TCP FIN and RST connections.
tcp-syn
NAT aging time for TCP SYN connection.
ftp-ctrl
NAT aging time for FTP control link.
ftp-data
NAT aging time for FTP data link.
no-pat
NAT aging time in NO-PAT mode.
nat aging-time
display nat all
Use display nat all to display all NAT configuration information.
display nat all [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display all NAT configuration information.
<Sysname> display nat all
  There are currently 1 nat address-group(s)
NAT bound information:
  There are currently 1 nat bound rule(s)
  Interface: Vlan-interface1
    Direction: outbound  ACL: 2009  Address-group: 1    NO-PAT: N
NAT server-group information:
  There are currently 2 NAT server-group(s)
  Server-group  Inside-IP        Port   Weight Connections
  1             10.1.1.1         21     101    0
  1             10.110.10.20     30     100    0
  2             ---              ---    ---    ---
NAT server in private network information:
  There are currently 1 internal server(s)
  Interface: Vlan-interface2, Protocol: 6(tcp)
    Global:         5.5.5.5 : 80(www)
    Local :       192.1.1.1 : 80(www)
NAT static information:
  There are currently 1 NAT static configuration(s)
  single static:
    Local-IP        : 1.1.1.1
    Global-IP       : 2.2.2.2
    Local-VPN       : ---
NAT static enabled information:
  Interface                                      Direction
  Vlan-interface3                                out-static
NAT log information:
  log enable  :  enable
  flow-begin  :  enable
See the display nat address-group command for descriptions on the specific fields.
Configuration information about internal address to external address translation. See the display nat bound command for descriptions on the specific fields.
Internal server group information. See the display nat server-group command for descriptions on the specific fields.
Internal server information. See the display nat server command for descriptions on the specific fields.
Information about static NAT. See the display nat static command for descriptions on the specific fields.
Information about static NAT entries and interfaces with static NAT enabled. See the display nat static command for descriptions on the specific fields.
Information about NAT aging time. See the display nat aging-time command for descriptions on the specific fields.
NAT log information
Information about NAT logging configuration. See the display nat log command for descriptions on the specific fields.
display nat bound
Use display nat bound to display NAT configuration information.
display nat bound [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display NAT configuration information.
<Sysname> display nat bound
  There are currently 3 nat bound rule(s)
  Interface:Vlan-interface10
    Direction: outbound  ACL: 2000  Address-group: 319  NO-PAT: Y
    Direction: outbound  ACL: 3000  Address-group: 300  NO-PAT: N
  Interface:Vlan-interface20
    Direction: outbound  ACL: 2001  Address-group: ---  NO-PAT: N
Display configured NAT address translation information.
Interface associated with a NAT address pool.
Direction
Address translation direction.
ACL
ACL number.
Address-group
Address group number. The field is blank in Easy IP mode.
NO-PAT
Identifies whether NO-PAT mode is supported.
nat outbound
display nat dns-map
Use display nat dns-map to display NAT DNS mapping configuration information.
display nat dns-map [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display NAT DNS mapping configuration information.
<Sysname> display nat dns-map
NAT DNS mapping information:
  There are currently 2 NAT DNS mapping(s)
  Domain-name: www.server.com
  Global-IP  : 202.113.16.117
  Global-port: 80(www)
  Protocol   : 6(tcp)
  Domain-name: ftp.server.com
  Global-IP  : 202.113.16.100
  Global-port: 21(ftp)
  Protocol   : 6(tcp)
Table 5 Command output
Domain-name
Domain name of the internal server.
Global-IP
External IP address of the internal server.
Global-port
Public port number of the internal server.
Protocol
Protocol type of the internal server.
nat dns-map
display nat log
Use display nat log to view the NAT logging configuration information.
display nat log [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# View the NAT logging configuration information.
<Sysname> display nat log
  log enable  :  enable acl 2000
  flow-begin  :  enable
  flow-active :  10(minutes)
Table 6 Command output
NAT log information :
Logging data flows matching ACL 2000.
flow-begin  :  enable
Logging newly established sessions.
Interval in logging active flows (10 minutes)
display nat server
Use display nat server to display information about internal servers.
display nat server [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display information about internal servers.
<Sysname> display nat server
  There are currently 2 internal server(s)
  Interface: Vlan-interface10, Protocol: 6(tcp)
    Global: 100.100.120.120 : 21(ftp)
    Local : 192.168.100.100 : 21(ftp)
  Interface: Vlan-interface11, Protocol: 6(tcp)
    Global: 100.100.100.121 : 80(www)
    Local : 192.168.100.101 : 80(www)
Table 7 Command output
Server in private network information
Information about internal servers.
Internal server interface.
Protocol
Protocol type.
Global
External IP address and port number of a server.
Local
Internal network information about a server.
nat server
Use display nat server-group to display configuration information about internal server groups.
display nat server-group [ group-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
group-number: Internal server group number. The value range is 0 to 19. If this argument is not specified, information of all internal server groups is displayed.
# Display configuration information about all internal server groups.
<Sysname> display nat server-group
  There are currently 1 NAT server-group(s)
  1             2.2.2.2          21     245    3
  1             2.2.2.5          21     100    1
Table 8 Command output
Server-group
Inside-IP
IP address of an internal server.
Port
Port number of an internal server.
Weight
Weight of an internal server.
Connections
Number of current connections of an internal server.
If multiple members exist in an internal server group, this field displays the total number of member connections.
nat server-group
display nat session
Use display nat session to display dynamic NAT entries.
Centralized devices:
display nat session [ source { global global-address | inside inside-address } ] [ destination dst-address ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
source global global-address: Displays NAT entries for the specified external source IP address.
source inside inside-address: Displays NAT entries for the specified internal source IP address.
destination dst-address: Displays NAT entries for the specified destination IP address.
# Display dynamic NAT entries.
<Sysname> display nat session
There are currently 1 NAT session:
Pro    GlobalAddr:Port        LocalAddr:Port         DestAddr:Port
TCP    100.1.1.1:23           63.1.1.1:23            51.1.1.2:1781
       GlobalVPN: vpn3        LocalVPN: vpn1
       Status:11              TTL:00:00:10           Left:00:00:02
Table 9 Command output
Pro
Protocol type.
GlobalAddr:Port
External IP address and port number after translation.
InsideAddr:Port
Internal IP address and port number before translation.
DestAddr:Port
Destination IP address and port number.
status
NAT session status.
TTL
NAT session lifetime in the format of hh:mm:ss.
Left
NAT session remaining lifetime, in the format of hh:mm:ss.
display nat static
Use display nat static to display static NAT entries and interfaces with static NAT enabled.
display nat static [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display static NAT entries and interfaces with static NAT enabled.
<Sysname> display nat static
  single static:
    Local-IP        : 4.4.4.4
    Global-IP       : 5.5.5.5
    Local-VPN       : ---
Interface                         Direction
Vlan-interface11                  out-static
Table 10 Command output
Configuration information about static NAT.
single static
One-to-one static NAT.
Local-IP
Internal IP address.
Global-IP
External IP address.
Local-VPN
VPN to which the internal IP address belongs.
Information about static NAT enabled on the interfaces.
Interface on which static NAT is configured.
Direction
Direction of packets to be translated.
·     nat static
·     nat outbound static
display nat statistics
Use display nat statistics to display NAT statistics.
display nat statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display NAT statistics.
<Sysname> display nat statistics
  total PAT session table count: 1
  total NO-PAT session table count: 0
  total SERVER session table count: 0
  total STATIC session table count: 0
Table 11 Command output
Number of PAT session entries.
Number of NO-PAT session entries.
Number of SERVER session entries.
Number of STATIC session entries.
display userlog export
Use display userlog export to view the configuration and statistics of logs output to the log server.
display userlog export [ | { begin | exclude | include } regular-expression ]
1: Monitor level
This command can display all types of logs output to the log server, but it only displays NAT logs in this document.
reset userlog nat export
# View the configuration and statistics of NAT logs.
<Sysname> display userlog export
nat:
   Export Version 1 logs to log server : enabled
   Address of log server             : 100.1.1.100 (port: 5000)
   Total Logs/UDP packets exported   : 0/0
   Logs in buffer                    : 0
 flow:
   No userlog export is enabled
Table 12 Command output
nat
NAT log information to be displayed.
flow
Flow log information to be displayed.
NAT logs cannot be exported. The reason may be:
·     The NAT log function is not enabled.
·     The NAT log function is enabled, but NAT logs are configured to be exported to the information center.
·     The NAT log function is enabled, but the IP address and the UDP port number of the log server are not configured.
NAT logs of version 1 are exported to the log server.
Log server address, including the IP address and port number.
Total number of the logs sent and that of the UDP packets carrying NAT logs. (The term "UDP packets" refers to the UDP packets carrying NAT logs. A UDP packet can carry multiple pieces of NAT logs.)
Logs in buffer
Total number of flow or NAT logs buffered.
nat address-group
Use nat address-group to configure a NAT address pool. When the start and end IP addresses are specified, this command specifies an address pool. Without the start and end IP addresses specified, the command places you into the address group view.
Use undo nat address-group to remove an address pool or address group.
nat address-group group-number [ start-address end-address [ level level ] ]
undo nat address-group group-number [ start-address end-address [ level level ] ]
2: System level
group-number: Assigns an index to the address pool. The value range for this argument varies by device model. For more information, see About the H3C Access Controllers Command References.
start-address: Specifies the start IP address of the address pool.
end-address: Specifies the end IP address of the address pool. The end-address cannot be lower than the start-address. If they are the same, the address pool has only one IP address. The maximum number of IP addresses that an address pool can include varies by device model. For more information, see About the H3C Access Controllers Command References.
level level: Specifies the level of port numbers assigned in NAPT translation for this address pool. It is the value of either 1 or 0. 0 represents a lower level, and the value range for the assignable port numbers is 35000 to 65535. 1 represents a higher level, and the value range for the assignable port numbers is 1024 to 34999 for devices in stateful failover state, and 1024 to 65535 for devices not in stateful failover state. The default value is 1. In the asymmetric stateful failover network scenario, configure different port assignment levels for the address pools on the two stateful failover devices.
An address pool consists of a set of consecutive IP addresses. An address group consists of multiple group members, each of which specifies an address pool with the address command. The address pools of group members may not be consecutive.
·     You cannot remove an address pool or address group that has been associated with an ACL.
·     Different address pools must not overlap.
·     The address pools of group members must not overlap with each other or with other address pools.
·     An address pool or address group is not needed in the case of Easy IP where the interface's public IP address is used as the translated IP address.
# Configure an address pool numbered 1 that contains addresses 202.110.10.10 to 202.110.10.15.
[Sysname] nat address-group 1 202.110.10.10 202.110.10.15
nat aging-time
Use nat aging-time to set NAT aging time.
Use undo nat aging-time to restore the default.
nat aging-time { dns | ftp-ctrl | ftp-data | icmp | no-pat | pptp | tcp | tcp-fin | tcp-syn | udp } seconds
undo nat aging-time { dns | ftp-ctrl | ftp-data | icmp | no-pat | pptp | tcp | tcp-fin | tcp-syn | udp } [ seconds ]
The default NAT aging times of various protocols are as follows:
·     10 seconds for DNS.
·     300 seconds for FTP control link.
·     300 seconds for FTP data link.
·     10 seconds for ICMP.
·     240 seconds in NO-PAT mode.
·     300 seconds for PPTP.
·     300 seconds for TCP.
·     10 seconds for TCP FIN and RST connections.
·     10 seconds for TCP SYN connections.
·     240 seconds for UDP.
2: System level
dns: Specifies the NAT aging time for DNS.
ftp-ctrl: Specifies the NAT aging time for FTP control link.
ftp-data: Specifies the NAT aging time for FTP data link.
icmp: Specifies the NAT aging time for ICMP.
no-pat: Specifies the NAT aging time in No-PAT mode.
pptp: Specifies the NAT aging time for PPTP.
tcp: Specifies the NAT aging time for TCP.
tcp-fin: Specifies the NAT aging time for TCP FIN or RST connection.
tcp-syn: Specifies the NAT aging time for TCP SYN connection.
udp: Specifies the NAT aging time for UDP.
seconds: NAT aging time, in the range of 10 to 86400 seconds.
A NAT entry is not permanent. You can use this command to configure NAT aging time for TCP, UDP, ICMP, and other protocols. If a NAT entry is not used within the configured time, it will be aged out. For example, when a user with IP address 10.110.10.10 and port number 2000 establishes an external TCP connection, NAT assigns an IP address and a port number for the user. If, within a preconfigured aging time, the TCP connection is not used, the system removes it.
In NO-PAT mode, if the private network is big and the users frequently go online and offline, you can set a smaller aging time to speed up the release of addresses.
# Set the NAT aging time for TCP to 240 seconds.
[Sysname] nat aging-time tcp 240
nat alg
Use nat alg to enable NAT application layer gateway for one or more protocols.
Use undo nat alg to disable NAT application layer gateway.
nat alg { all | dns | ftp | ils | nbt | pptp }
undo nat alg { all | dns | ftp | ils | nbt | pptp }
NAT application layer gateway is enabled.
2: System level
all: Supports all special protocols.
dns: Supports DNS.
ftp: Supports FTP.
ils: Supports ILS.
nbt: Supports NBT.
pptp: Supports PPTP.
# Enable NAT application layer gateway for FTP.
[Sysname] nat alg ftp
nat dns-map
Use nat dns-map to map the domain name to the public network information about an internal server.
Use undo nat dns-map to remove a DNS mapping.
nat dns-map domain domain-name protocol pro-type ip global-ip port global-port
undo nat dns-map domain domain-name
2: System level
domain domain-name: Specifies the domain name of an internal server. A domain name is a string containing no more than 255 case-insensitive characters. It consists of several labels separated by dots (.). Each label has no more than 63 characters that must begin and end with letters or digits. Dashes (-) can also be included.
protocol pro-type: Specifies the protocol type used by the internal server, tcp or udp.
ip global-ip: Specifies the public IP address used by the internal server to provide services to the external network.
port global-port: Specifies the port number used by the internal server to provide services to the external network. The value range for the global-port argument is 1 to 65535.
A device can support a maximum of 16 DNS mappings.
# A company provides Web service to external users. The domain name of the internal server is www.server.com, and the public IP address is 202.112.0.1. Configure a DNS mapping, so that internal users can access the Web server using its domain name.
[Sysname] nat dns-map domain www.server.com protocol tcp ip 202.112.0.1 port www
display nat dns-map
nat link-down reset-session enable
Use nat link-down reset-session enable to enable aging out NAT entries upon master link failure.
Use undo nat link-down reset-session enable to restore the default.
This feature is disabled.
2: System level
# Enable aging out NAT entries upon master link failure.
[Sysname] nat link-down reset-session enable
nat log enable
Use nat log enable to enable the NAT logging function for all data flows outbound from the internal network or outbound data flows matching a specific ACL.
Use undo nat log enable to disable NAT logging.
nat log enable [ acl acl-number ]
undo nat log enable [ acl acl-number ]
The NAT logging function is disabled.
2: System level
acl acl-number: Specifies an ACL by its number, in the range of 2000 to 3999.
# Enable NAT logging.
[Sysname] nat log enable acl 2001
nat log flow-active
Use nat log flow-active to enable logging for active NAT sessions and set the logging interval.
Use undo nat log flow-active to disable this function.
nat log flow-active minutes
undo nat log flow-active [ minutes ]
This function is disabled.
2: System level
minutes: Interval for logging active NAT sessions, in the range of 10 to 120 minutes.
This function helps in tracking active flows by logging them regularly. Without this function, logs are generated only when a session is established or deleted and no logs are available for tracking a session that lasts for a long period.
# Enable logging for active NAT sessions and set the logging interval to 10 minutes.
[Sysname] nat log flow-active 10
nat log flow-begin
Use nat log flow-begin to enable logging of NAT session establishment events.
Use undo nat log flow-begin to restore the default.
nat log flow-begin
No log is generated when a session is established.
2: System level
# Enable logging of NAT session establishment events.
[Sysname] nat log flow-begin
nat outbound
Use nat outbound to enable outbound NAT on an interface.
Use undo nat outbound to disable outbound NAT.
nat outbound [ acl-number ] [ address-group group-number [ no-pat ] ] [ track vrrp virtual-router-id ]
undo nat outbound [ acl-number ] [ address-group group-number [ no-pat ] ] [ track vrrp virtual-router-id ]
Interface view
2: System level
acl-number: Specifies an ACL number in the range of 2000 to 3999. A packet matching a permit rule in the ACL is translated by NAT. If you do not specify any ACL, a packet that is not sourced from the outbound interface is translated by NAT.
address-group group-number: Specifies an address pool for NAT. The value range for the group-number argument varies by device model. For more information, see About the H3C Access Controllers Command References. If you do not specify any address pool, the IP address of the interface is used as the translated IP address. That is, Easy IP is enabled.
no-pat: Specifies not to use the TCP/UDP port number for many-to-many NAT. If this keyword is not specified, the TCP/UDP port number is used for many-to-one NAT.
track vrrp virtual-router-id: Associates address translation on a specific outbound interface with a VRRP group. The virtual-router-id argument indicates the number of the VRRP group, in the range of 1 to 255. Without this argument specified, no VRRP group is associated.
You can configure multiple associations or use the undo command to remove an association from an interface that serves as the egress of an internal network to the external network.
When the undo nat outbound command is executed to remove an association, the NAT entries depending on the association are not deleted. They are aged out automatically after 5 to 10 minutes. During this period, the involved users cannot access the external network whereas all the other users are not affected.
When an ACL rule is not operative, no new NAT session entry depending on the rule can be created. However, existing connections are still available for communication.
You can bind an ACL to only one address pool on an interface. An address pool can be bound to multiple ACLs.
In stateful failover networking, make sure you associate each address pool configured on an interface with one VRRP group only. Otherwise, the system associates the address pool with the VRRP group having the highest group ID.
For some devices, the ACL rules referenced by the same interface cannot conflict. That is, the source IP address, destination IP address, and VPN instance information in two ACL rules cannot be the same. For basic ACLs (numbered from 2000 to 2999), if the source IP address and VPN instance information in two ACL rules are the same, a conflict occurs.
# Configure NAT for hosts on subnet 10.110.10.0/24. The NAT address pool contains addresses 202.110.10.10 through 202.110.10.12. Assume that interface VLAN-interface 1 is connected to the Internet.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 10.110.10.0 0.0.0.255
[Sysname-acl-basic-2001] rule deny
[Sysname-acl-basic-2001] quit
# Configure address pool 1.
[Sysname] nat address-group 1 202.110.10.10 202.110.10.12
# Use addresses in address pool 1 as translated addresses and TCP/UDP port information.
[Sysname] interface Vlan-interface 1
[Sysname-Vlan-interface1] nat outbound 2001 address-group 1
# Use addresses in address pool 1 as translated addresses without using TCP/UDP port information.
[Sysname-Vlan-interface1] nat outbound 2001 address-group 1 no-pat
# Use the IP address of interface VLAN-interface 1 as translated address.
nat outbound static
Use nat outbound static to enable static NAT on an interface, making the configured static NAT mappings take effect.
Use undo nat outbound static to disable static NAT on the interface.
nat outbound static [ track vrrp virtual-router-id ]
undo nat outbound static [ track vrrp virtual-router-id ]
Interface view
2: System level
track vrrp virtual-router-id: Associates static NAT with a VRRP group. The virtual-router-id argument indicates the number of the VRRP group, in the range of 1 to 255. If you do not specify this option, no VRRP group is associated.
# Configure a one-to-one NAT mapping and enable static NAT on interface VLAN-interface 1.
[Sysname] nat static 192.168.1.1 2.2.2.2
[Sysname-Vlan-interface1] nat outbound static
display nat static
nat server (for normal NAT server)
Use nat server to configure a load sharing internal server.
Use undo nat server to remove the configuration.
nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 inside local-address1 local-address2 local-port [ track vrrp virtual-router-id ]
undo nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } global-port1 global-port2 inside local-address1 local-address2 local-port [ track vrrp virtual-router-id ]
nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } [ global-port ] inside local-address [ local-port ] [ track vrrp virtual-router-id ]
undo nat server protocol pro-type global { global-address | current-interface | interface interface-type interface-number } [ global-port ] inside local-address [ local-port ] [ track vrrp virtual-router-id ]
Interface view
2: System level
protocol pro-type: Specifies a protocol type. pro-type supports TCP, UDP, and ICMP. If ICMP is specified, do not specify port number for the internal server.
global-address: Specifies the public IP address for the internal server.
current-interface: Uses the current interface address as the external IP address for the internal server.
interface: Uses the IP address of an interface as the external IP address for the internal server to enable Easy IP.
interface-type interface-number: Specifies the interface type and interface number. Only loopback interfaces are supported and must be configured. Otherwise, the configuration is considered illegal.
global-port1, global-port2: Specifies a range of ports that have a one-to-one correspondence with the IP addresses of the internal hosts. The global-port2 argument must be greater than global-port1.
local-address1, local-address2: Defines a consecutive range of addresses that have a one-to-one correspondence with the range of ports. The local-address2 argument must be greater than local-address1 and that the number of addresses must match that of the specified ports.
local-port: Specifies the port number provided by the internal server, in the range of 0 to 65535, excluding FTP port number 20.
·     You can use the service names to represent those well-known port numbers. For example, you can use www to represent port number 80, ftp to represent port number 21, and so on.
·     You can use the keyword any to represent port number 0, which means all types of services are supported. This has the same effect as a static translation between the global-address and local-address.
global-port: Specifies the global port number for the internal server, in the range of 0 to 65535.
local-address: Specifies the internal IP address of the internal server.
track vrrp virtual-router-id: Associates the internal server with a VRRP group. The virtual-router-id argument indicates the number of the VRRP group to be associated, in the range of 1 to 255. Without this option specified, no VRRP group is associated.
Using the address and port defined by the global-address and global-port parameters, external users can access the internal server with an IP address of local-address and a port of local-port.
If one of the two arguments global-port and local-port is set to any, the other must also be any or remain undefined.
Using this command, you can configure internal servers (such as Web, FTP, Telnet, POP3, and DNS servers) to provide services for external users. An internal server can reside in an internal network.
The maximum number of internal server configuration commands that can be configured on an interface depends on the device model. The number of internal servers that each command can define equals the difference between global-port2 and global-port1. Up to 4096 internal servers can be configured on an interface. The system allows up to 1024 internal server configuration commands.
In general, this command is configured on an interface that serves as the egress of an internal network and connects to the external network.
The device supports using an interface address as the external IP address of an internal server, which is Easy IP. If you specify the current-interface keyword, the internal server uses the current primary IP address of the current interface. If you use interface { interface-type interface-number } to specify an interface, the interface must be an existing loopback interface, and the current primary IP address of the loopback interface is used.
H3C recommends that if an internal server using Easy IP is configured on the current interface, the IP address of this interface should not be configured as the external address of another internal server and vice versa. This is because that the interface address that is referenced by the internal server using Easy IP serves as the external address of the internal server.
In stateful failover networking, make sure you associate the public address of an internal server on an interface with one VRRP group only. Otherwise, the system associates the public address with the VRRP group having the highest group ID.
When the protocol type is not udp (with a protocol number of 17) or tcp (with a protocol number of 6), you can configure one-to-one NAT between an internal IP address and an external IP address only, but cannot specify port numbers.
# Allow external hosts to ping the host with an IP address of 10.110.10.12 by using the ping 202.110.10.11 command.
[Sysname-Vlan-interface1] nat server protocol icmp global 202.110.10.11 inside 10.110.10.12
# Allow external hosts to access the Telnet services of internal servers 10.110.10.1 to 10.110.10.100 through the public address of 202.110.10.10 and port numbers from 1001 to 1100. As a result, a user can Telnet to 202.110.10.10:1001 to access 10.110.10.1, Telnet to 202.110.10.10:1002 to access 10.110.10.2, and so on.
[Sysname-Vlan-interface1] nat server protocol tcp global 202.110.10.10 1001 1100 inside 10.110.10.1 10.110.10.100 telnet
# Remove the Web server.
[Sysname-Vlan-interface1] undo nat server protocol tcp global 202.110.10.10 8080 inside 10.110.10.10 www
# Remove the FTP server.
[Sysname-Vlan-interface1] undo nat server protocol tcp global 202.110.10.11 21 inside 10.110.10.11 ftp
display nat server
nat server-group
Use nat server-group to configure an internal server group.
Use undo nat server-group to remove the specified internal server group.
nat server-group group-number
undo nat server-group group-number
2: System level
An interval server group referenced by the nat server command on an interface cannot be removed.
# Configure internal server group 1.
[Sysname] nat server-group 1
nat server
nat static
Use nat static to configure a one-to-one static NAT mapping.
Use undo nat static to remove a one-to-one static NAT mapping.
nat static [ acl-number ] local-ip global-ip
undo nat static [ acl-number ] local-ip global-ip
2: System level
acl-number: Specifies an ACL number in the range of 2000 to 3999. You can use an ACL to specify the destination addresses that internal hosts can access.
local-ip: Specifies the internal IP address.
global-ip: Specifies the external IP address.
# Configure static NAT mapping between internal IP address 192.168.1.1 and external IP address 2.2.2.2.
# Configure static NAT to allow the internal host 192.168.1.1 to access only the external network 3.3.3.0/24 by using the external IP address 2.2.2.2.
[Sysname] acl number 3001
[Sysname-acl-adv-3001] rule permit ip destination 3.3.3.0 0.0.0.255
[Sysname-acl-adv-3001] quit
[Sysname] nat static 3001 192.168.1.1 2.2.2.2
display nat static
reset nat session
Use reset nat session to clear the address translation table and release the memory dynamically assigned for storing the table.
reset nat session
2: System level
# Clear the address translation table.
<Sysname> reset nat session
Use reset userlog nat export to clear NAT log statistics.
2: System level
Once the NAT log function is enabled, the system takes statistics for NAT logs periodically.
# Clear the NAT log information.
<Sysname> reset userlog nat export
reset userlog nat logbuffer
Use reset userlog nat logbuffer to clear the NAT log buffer.
2: System level
Clearing the NAT log buffer causes NAT logs loss. H3C recommends you not to use this command in normal situations.
# Clear the NAT log buffer.
<Sysname> reset userlog nat logbuffer
userlog nat export host
Use userlog nat export host to specify the IP address and UDP port number of the NAT log server that receives NAT logs.
Use undo userlog nat export host to restore the default.
userlog nat export host { ipv4-address | ipv6 ipv6-address } udp-port
undo userlog nat export host { ipv4-address | ipv6 ipv6-address }
No NAT log server IP address or UDP port number is configured.
2: System level
ipv4-address: IPv4 address of the NAT log server. It must be a valid unicast IPv4 address and cannot be a loopback address.
ipv6 ipv6-address: IPv6 address of the NAT log server. It must be a valid unicast IPv6 address.
udp-port: UDP port number of the NAT log server, ranging from 0 to 65535.
Specify the NAT log server to successfully export NAT logs in UDP packets.
Use a UDP port number greater than 1024 to avoid conflicting with common UDP port numbers.
# Export NAT logs to NAT log server with IP address 169.254.1.1 and port number 2000.
[Sysname] userlog nat export host 169.254.1.1 2000
userlog nat export source-ip
Use userlog nat export source-ip to configure the source IP address for the UDP packets that carry NAT logs.
Use undo userlog nat export source-ip to restore the default.
userlog nat export source-ip ip-address
The source IP address of the UDP packets that carry NAT logs is the IP address of the interface that sends the UDP packets.
2: System level
ip-address: Source IP address for the UDP packets.
# Use 169.254.1.2 as the source IP address of the UDP packets that carry NAT logs.
[Sysname] userlog nat export source-ip 169.254.1.2
userlog nat export version
Use userlog nat export version to set the version number of the NAT log packets.
Use undo userlog nat export version to restore the default.
userlog nat export version version-number
The version number of NAT log packets is 1.
2: System level
version-number: Version number for the NAT log packets. The system supports only version 1.
# Set the version number of NAT log packets to 1.
[Sysname] userlog nat export version 1
userlog nat syslog
Use userlog nat syslog to configure the device to export NAT logs to the information center.
Use undo userlog nat syslog to restore the default.
userlog nat syslog
NAT logs are exported to the NAT log server.
2: System level
As NAT logs may consume a large volume of memory, H3C recommends that you not export large amounts of NAT logs to the information center.
# Export NAT logs to the information center.
[Sysname] userlog nat syslog
