04-Layer 3 Command Reference
HomeSupportReference GuidesCommand ReferencesH3C Access Controllers Command References(E3703P61 R2509P61 R3709P61 R2609P61 R3509P61)-6W10204-Layer 3 Command Reference
04-DHCPv6 Commands
04-DHCPv6 Commands 192.98 KB
DHCPv6 configuration commands· 1
DHCPv6 common configuration commands· 1
display ipv6 dhcp duid· 1
display ipv6 dhcp option-group· 1
DHCPv6 server configuration commands· 3
address range· 3
display ipv6 dhcp pool 4
display ipv6 dhcp prefix-pool 6
display ipv6 dhcp server 8
display ipv6 dhcp server conflict 9
display ipv6 dhcp server expired· 10
display ipv6 dhcp server ip-in-use· 11
display ipv6 dhcp server pd-in-use· 12
display ipv6 dhcp server statistics· 14
dns-server 16
domain-name· 16
ds-lite address· 17
network· 17
ipv6 dhcp option-group· 19
ipv6 dhcp pool 20
ipv6 dhcp prefix-pool 20
ipv6 dhcp server 21
ipv6 dhcp server enable· 22
ipv6 nd ra separate-delegation dhcp-pool 23
option· 23
option-group· 24
prefix-pool 25
reset ipv6 dhcp server conflict 26
reset ipv6 dhcp server expired· 26
reset ipv6 dhcp server ip-in-use· 27
reset ipv6 dhcp server pd-in-use· 27
reset ipv6 dhcp server statistics· 28
sip-server 28
static-bind address· 29
static-bind prefix· 30
temporary address range· 31
DHCPv6 relay agent configuration commands· 32
display ipv6 dhcp relay server-address· 32
display ipv6 dhcp relay statistics· 33
ipv6 dhcp relay server-address· 35
reset ipv6 dhcp relay statistics· 36
DHCPv6 client configuration commands· 36
display ipv6 dhcp client 36
display ipv6 dhcp client statistics· 37
ipv6 address dhcp-alloc· 39
ipv6 dhcp client pd· 39
reset ipv6 dhcp client statistics· 40
DHCPv6 snooping configuration commands· 41
display ipv6 dhcp snooping trust 41
display ipv6 dhcp snooping user-binding· 41
ipv6 dhcp snooping enable· 42
ipv6 dhcp snooping max-learning-num·· 43
ipv6 dhcp snooping trust 43
ipv6 dhcp snooping vlan enable· 44
reset ipv6 dhcp snooping user-binding· 44
Support for DHCPv6 commands depends on the device model. For more information, see About the H3C Access Controllers Command References.
Use display ipv6 dhcp duid to display the DHCP unique identifier (DUID) of the local device.
display ipv6 dhcp duid [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display the DUID of the device.
<Sysname> display ipv6 dhcp duid
The DUID of this device: 0003-0001-00e0-fc00-5552
Use display ipv6 dhcp option-group to display information about DHCPv6 option groups, including static and dynamic option groups.
display ipv6 dhcp option-group [ option-group-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
option-group-number: Specifies a DHCPv6 option group by its ID in the range of 1 to 100. If you do not specify any option group, the command displays information about all DHCPv6 option groups.
DHCPv6 option groups can be static or dynamic:
·     A static DHCPv6 option group is created by the ipv6 dhcp option-group command.
·     A dynamic group is automatically created by a DHCPv6 client when the client obtains and IPv6 address/prefix and network parameters. Dynamic option groups cannot be manually modified or removed.
# Display information about all DHCPv6 option groups.
<Sysname> display ipv6 dhcp option-group
DHCPv6 option group: 1
  Type: Static
  DNS server addresses:
    1::1
  Domain names:
    aaa.com
  SIP server addresses:
    2::1
  SIP server domain names:
    bbb.com
  DS-Lite addresses:
    2::3
  Options:
    Code: 23
      Length: 2 bytes
      Hex: ABCD
    Code: 33
      Length: 2 bytes
      Hex: DEFA
DHCPv6 option group
DHCPv6 option group number.
DHCPv6 option group type, Static or Dynamic.
IP address of the DNS server.
Domain names
Domain name suffix.
IP address of the SIP server.
Domain name of the SIP server.
DS-Lite addresses
IP address of the Address Family Transition Router (AFTR).
Options
User-defined options.
Code
Code of the self-defined option.
Length
Self-defined option string length in bytes.
Hex
Self-defined option content represented by a hexadecimal string.
·     ipv6 address dhcp-alloc
·     ipv6 dhcp client pd
address range
Use address range to specify a non-temporary IPv6 address range in a DHCPv6 address pool for dynamic allocation.
Use undo address range to remove the non-temporary IPv6 address range in the address pool.
address range start-ipv6-address end-ipv6-address [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ]
undo address range
No non-temporary IPv6 address range is configured.
DHCPv6 address pool view
2: System level
start-ipv6-address: Specifies the start IPv6 address.
end-ipv6-address: Specifies the end IPv6 address.
preferred-lifetime preferred-lifetime: Specifies the preferred lifetime for the non-temporary IPv6 addresses. The value ranges from 60 to 4294967295 seconds and defaults to 604800 seconds (7 days).
valid-lifetime valid-lifetime: Specifies the valid lifetime for the non-temporary IPv6 addresses. The value ranges from 60 to 4294967295 seconds and defaults to 2592000 seconds (30 days). The valid lifetime cannot be shorter than the preferred lifetime.
When no non-temporary IPv6 address range is specified, all unicast addresses on the subnet specified by the network command in address pool view are assignable. If a non-temporary IPv6 address range is specified, only the IPv6 addresses in the IPv6 address range are assignable.
You can specify only one non-temporary IPv6 address range in an address pool. If you execute the address range command multiple times, the most recent configuration takes effect.
The non-temporary IPv6 address range specified by the address range command must be on the subnet specified by the network command.
The non-temporary and temporary IPv6 address ranges cannot overlap.
# Configure a non-temporary IPv6 address range from 3ffe:501:ffff:100::10 through 3ffe:501:ffff:100::31 in address pool 1.
[Sysname] ipv6 dhcp pool 1
[Sysname-dhcp6-pool-1] network 3ffe:501:ffff:100::/64
[Sysname-dhcp6-pool-1] address range 3ffe:501:ffff:100::10 3ffe:501:ffff:100::31
·     display ipv6 dhcp pool
·     network
·     temporary address range
Use display ipv6 dhcp pool to display DHCPv6 address pool information.
display ipv6 dhcp pool [ pool-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
pool-number: Displays information about the DHCPv6 address pool specified by the pool number. The value range for the pool number varies by device model. For more information, see About the H3C Access Controllers Command References. If you do not specify any pool number, this command displays all DHCPv6 address pool information.
# Display all DHCPv6 address pool information.
<Sysname> display ipv6 dhcp pool 1
Pool: 1
  Network: 3FFE:501:FFFF:100::/64
    Preferred lifetime 604800 sec, valid lifetime 2592000 sec
  Static bindings:
    Prefix: 3FFE:501:FFFF:100::/64
      DUID: 0003000100E0FC000001
      IAID: 0x3F
    Address: 3FFE:501:FFFF:100::2345/64
      DUID: 0003000100E0FC000002
      IAID: 0x30
  Prefix pool: 1
    Preferred lifetime 201600 sec, valid lifetime 864000 sec
  Address range:
    From 3FFE:501:FFFF:100::10
    To 3FFE:501:FFFF:100::20
    Preferred lifetime 3600 sec, valid lifetime 7200 sec
    Total: 17
    Available: 17
    In-use: 0
  Temporary address range:
    From 3FFE:501:FFFF:100::21
    To 3FFE:501:FFFF:100::30
    Total: 16
    Available: 16
    In-use: 0
    2::2
    2::3
  Domain names:
    aaa.com
    5::1
    bbb.com
  DS-Lite addresses:
    6::6
  Options:
    Code: 88
      Length: 4 bytes
      Hex: AABBCCDD
  Option group: 1
Pool
DHCPv6 address pool number.
Network
IPv6 subnet for dynamic IPv6 address assignment.
If the subnet is not valid, Not-available is displayed.
Preferred lifetime
Preferred lifetime in seconds.
valid lifetime
Valid lifetime in seconds.
Static bindings
Static IPv6 address or prefix information configured in the address pool. If no static prefix is configured, this field is not displayed.
Prefix
IPv6 address prefix in the binding.
Address
IPv6 address in the binding.
DUID
Client DUID.
IAID
Client IAID. If no IAID is configured, this field displays Not configured.
Prefix pool
Prefix pool referenced by the address pool. If no referenced prefix pool is specified, this field displays Not configured.
Address range
Non-temporary address ranges for dynamic allocation.
If no non-temporary address range is configured, this field is not displayed.
Temporary address range for dynamic allocation.
If no temporary address range is configured, this field is not displayed.
From
Start IPv6 address of the address range.
To
End IPv6 address of the address range.
Total
Total number of assignable addresses.
Available
Number of idle addresses.
In-use
Number of assigned addresses.
DNS server address. If no DNS server address is configured, this field is not displayed.
Domain names
Domain name suffix. If no domain name suffix is configured, this field is not displayed.
SIP server address. If no SIP server address is configured, this field is not displayed.
Domain name of the SIP server. If no domain name of the SIP server is configured, this field is not displayed.
DS-Lite address
AFTR address. If no AFTR address is configured, this field is not displayed.
Options
Self-defined option. If no self-defined option is configured, this field is not displayed.
Code
Self-defined option code.
Length
Self-defined option length in bytes.
Hex
Self-defined option content, represented by a hexadecimal string.
Option group
Option group ID. If no option group is configured, this field is not displayed.
Use display ipv6 dhcp prefix-pool to display prefix pool information.
display ipv6 dhcp prefix-pool [ prefix-pool-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
prefix-pool-number: Displays details about the prefix pool specified by the prefix pool number. The value range for the prefix-pool-number varies by device model. For more information, see About the H3C Access Controllers Command References. If you do not specify any prefix pool number, this command displays brief information about all prefix pools.
This command does not display information about the prefix pools that are not applied to any address pool.
# Display brief information about all prefix pools.
<Sysname> display ipv6 dhcp prefix-pool
Prefix-pool Prefix                                      Available In-use Static
1           5::/64                                      64        0      0
# Display details about prefix pool 1.
<Sysname> display ipv6 dhcp prefix-pool 1
Prefix: 5::/64
Assigned length: 70
Total prefix number: 64
Available: 64
In-use: 0
Static: 0
Prefix-pool
Prefix pool number.
Prefix
Prefix contained in the prefix pool.
If the prefix pool is not valid, Not-available is displayed.
Available
Number of idle prefixes.
In-use
Number of assigned prefixes.
Static
Number of static prefixes.
Assigned length
Length of prefixes to be assigned.
Total prefix number
Total number of prefixes.
Use display ipv6 dhcp server to display DHCPv6 server information.
display ipv6 dhcp server [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
interface interface-type interface-number: Displays the DHCPv6 server information about the interface specified by interface type and number. If you do not specify any interface, this command displays DHCPv6 server information about all interfaces.
# Display DHCPv6 server information about all interfaces.
<Sysname> display ipv6 dhcp server
DHCPv6 server status: Enabled
Interface             Pool
Vlan-interface2       1
Vlan-interface3       2
# Display DHCPv6 server information about the specified interface.
<Sysname> display ipv6 dhcp server interface vlan-interface 2
Using pool: 1
Preference value: 0
Allow-hint: Enabled
Rapid-commit: Disabled
DHCPv6 server status, Enabled or Disabled.
Interface on which the DHCPv6 server is enabled.
Pool
Address pool applied to the interface.
Global indicates that no address pool is applied to the interface. The DHCPv6 server searches all address pools and selects one address pool to assign a prefix or an address to the client.
Using pool
Address pool applied to the interface. If no address pool is applied, Global is  displayed.
Preference value
Server priority in the DHCPv6 Advertise message. The value ranges from 0 to 255. The higher the value is, the higher priority the server has.
Allow-hint
Whether desired address/prefix assignment is enabled.
Rapid-commit
Whether rapid address/prefix assignment is enabled.
Use display ipv6 dhcp server conflict to display IPv6 address conflict information.
display ipv6 dhcp server conflict [ address ipv6-address | pool pool-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
address ipv6-address: Displays conflict information about a specific IPv6 address.
pool pool-number: Displays IPv6 address conflict information about the DHCPv6 address pool specified by the pool number. The value range for the pool number varies by device model. For more information, see About the H3C Access Controllers Command References.
# Display all IPv6 address conflict information.
<Sysname> display ipv6 dhcp server conflict
Total number: 4
Address                                         Detect time
1:2::1                                          Nov 23 2010 16:37:08
1:2::2                                          Nov 23 2010 16:37:08
1:2::3                                          Nov 23 2010 16:37:08
1:2::4                                          Nov 23 2010 16:37:08
 --- total 4 entries ---
Table 5 Command output
Total number
Total number of conflicted addresses.
Address
IPv6 address that conflicted with another IPv6 address.
Detect time
Time when the conflict was detected.
Use display ipv6 dhcp server expired to display information about expired IPv6 addresses.
display ipv6 dhcp server expired [ address ipv6-address | pool pool-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
address ipv6-address: Displays information about an expired IPv6 address.
pool pool-number: Displays information about expired IPv6 addresses in the address pool specified by the pool number. The value range for the pool number varies by device model. For more information, see About the H3C Access Controllers Command References.
# Display information about all expired IPv6 addresses.
<Sysname> display ipv6 dhcp server expired
Total number: 4
Address                                  DUID              Expiration time
1:2::4                                   00010006498D332   Nov 23 2010 16:12:43
                                         2000102030405
1:2::3                                   00010006498D332   Nov 23 2010 16:12:43
                                         2000102030405
1:2::2                                   00010006498D332   Nov 23 2010 16:12:43
                                         2000102030405
1:2::1                                   00010006498D332   Nov 23 2010 16:12:43
                                         2000102030405
Table 6 Command output
Total number
Total number of expired addresses.
Address
Expired IPv6 address.
DUID
Client DUID bound to the expired IPv6 address.
Expiration time
Time when the lease expired.
Use display ipv6 dhcp server ip-in-use to display IPv6 address binding information.
display ipv6 dhcp server ip-in-use [ address ipv6-address | pool pool-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
address ipv6-address: Displays binding information about a specific IPv6 address.
pool pool-number: Displays IPv6 address binding information about the address pool specified by the pool number. The value range for the pool number varies by device model. For more information, see About the H3C Access Controllers Command References.
# Display all IPv6 address binding information.
<Sysname> display ipv6 dhcp server ip-in-use
Total number: 4
Address                                     Type      Pool Expiration time
2:1::1                                      Auto(O)   1    Jul 10 2011 19:45:01
3:1::2                                      Static(C) 1    Jan  1 2011 11:11:11
1:1::2                                      Static(F) 2    Not-available
1:2::1f1                                    Static(O) 3    Oct  9 2011 09:23:31
# Display IPv6 address binding information about address pool 1.
<Sysname> display ipv6 dhcp server ip-in-use pool 1
Total number: 2
2:1::1                                      Auto(O)   1    Jul 10 2011 22:22:22
# Display binding information about IPv6 address 2:1::1.
<Sysname> display ipv6 dhcp server ip-in-use address 2:1::1
Pool: 1
Client: FE80::C800:CFF0:FE18:0
Type: Auto(O)
DUID: 00030001CA000C180000
IAID: 0x30001
Address: 2:1::1
  Preferred lifetime 400 sec, valid lifetime 500 sec
  Will expire at Jul 10 2008 09:45:01 (288 seconds left)
Table 7 Command output
Total number
Total number of IPv6 address bindings.
Address
Assigned IPv6 address.
Type of an IPv6 address binding:
·     Static(F)—Free static binding, indicating the static address has not been assigned to the client.
·     Static(O)—Offered static binding. If the server replies with an Advertise message to the client during the four-step message exchange, the server sets the type of the static binding configured for the client to Static(O).
·     Static(C)—Committed static binding, indicating the static IPv6 address has been assigned to the client in a Reply message.
·     Auto(O)—Offered dynamic binding. If the server selects a dynamic IPv6 address and replies with an Advertise message to the client during the four-step message exchange, the server sets the type of the dynamic IPv6 address binding to Auto(O).
·     Auto(C)—Committed dynamic binding, indicating the dynamic IPv6 address has been assigned to the client in a Reply message.
Pool
Address pool to which the binding belongs.
Expiration time
Time when the lease of an IPv6 address expires. If the lease expires after the year 2100, this field displays after 2100. For a free static binding, this field displays Not-available.
Client
Link-local address of a DHCPv6 client. For a free static binding, this field is blank.
DUID
Client DUID.
IAID
Client IAID. For a free static binding without IAID specified, this field is blank.
Will expire at
Time when the lease of an IPv6 address will expire. If the lease expires after the year 2100, this field displays Will expire after 2100.
Use display ipv6 dhcp server pd-in-use to display IPv6 prefix binding information.
display ipv6 dhcp server pd-in-use [ pool pool-number | prefix prefix/prefix-len | prefix-pool prefix-pool-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
pool pool-number: Displays prefix binding information about the DHCPv6 address pool specified by the pool number. The value range for the pool number varies by device model. For more information, see About the H3C Access Controllers Command References.
prefix prefix/prefix-len: Displays binding information about the specified prefix. The prefix/prefix-len indicates the IPv6 prefix and prefix length. The value range for the prefix length is 1 to 128.
prefix-pool prefix-pool-number: Displays prefix binding information about the prefix pool specified by the prefix pool number. The value range for the prefix pool number varies by device model. For more information, see About the H3C Access Controllers Command References.
The binding information generated for static prefixes is not displayed when you display the prefix binding information about a specific prefix pool.
# Display all IPv6 prefix binding information.
<Sysname> display ipv6 dhcp server pd-in-use
Total number: 3
Prefix                                      Type      Pool Expiration time
2:1::/24                                    Auto(O)   1    Jul 10 2011 19:45:01
1:1::/64                                    Static(F) 2    Not-available
1:2::/64                                    Static(O) 3    Oct  9 2011 09:23:31
# Display prefix binding information about the specified DHCPv6 address pool.
<Sysname> display ipv6 dhcp server pd-in-use pool 1
Total number: 2
2:1::/24                                    Auto(O)   1    Jul 10 2011 22:22:22
3:1::/64                                    Static(C) 1    Jan  1 2011 11:11:11
# Display prefix binding information about the specified prefix pool.
<Sysname> display ipv6 dhcp server pd-in-use prefix-pool 1
Total number: 1
2:1:1:2::/64                                Auto(C)   2    Jan  1 2011 14:45:56
# Display prefix binding information about the specified prefix.
<Sysname> display ipv6 dhcp server pd-in-use prefix 2:1::3/24
Pool: 1
Prefix pool: 1
Client: FE80::C800:CFF:FE18:0
Type: Auto(O)
IAID: 0x30001
Prefix: 2:1::/24
Table 8 Command output
Total number
Total number of prefix bindings.
Prefix
Assigned IPv6 prefix.
Type of a prefix binding:
·     Static(F)—Free static binding, indicating the static prefix has not been assigned to the client.
·     Static(C)—Committed static binding, indicating the static IPv6 prefix has been assigned to the client in a Reply message.
·     Auto(O)—Offered dynamic binding. If the server selects a dynamic IPv6 prefix and replies with an Advertise message to the client during the four-step message exchange, the server sets the type of the dynamic IPv6 prefix binding to Auto(O).
·     Auto(C)—Committed dynamic binding, indicating the dynamic IPv6 prefix has been assigned to the client in a Reply message.
Pool
Address pool to which the prefix binding belongs.
Expiration time
Time when the prefix lease expires. If the lease expires after the year 2100, this field displays after 2100. For a free static binding, this field displays Not-available.
Prefix Pool
Prefix pool to which the prefix binding belongs. For a free static binding, this field is blank.
Client
IPv6 address of the DHCPv6 client. For a free static binding, this field is blank.
DUID
Client DUID.
IAID
Client IAID. For a free static binding without IAID configured, this field is blank.
Preferred lifetime
Preferred lifetime of the prefix, in seconds.
valid lifetime
Valid lifetime of the prefix, in seconds.
Will expire at
Time when the prefix lease will expire. If the lease expires after the year 2100, this field displays Will expire after 2100.
Use display ipv6 dhcp server statistics to display packet statistics on the DHCPv6 server.
display ipv6 dhcp server statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display packet statistics on the DHCPv6 server.
<Sysname> display ipv6 dhcp server statistics
Packets received     :  0
  SOLICIT            :  0
  REQUEST            :  0
  CONFIRM            :  0
  RENEW              :  0
  REBIND             :  0
  RELEASE            :  0
  DECLINE            :  0
  INFORMATION-REQUEST:  0
  RELAY-FORWARD      :  0
Packets dropped      :  0
Packets sent         :  0
  ADVERTISE          :  0
  RECONFIGURE        :  0
  REPLY              :  0
  RELAY-REPLY        :  0
Table 9 Command output
Packets received
Number of messages received by the DHCPv6 server. The message types include:
·     SOLICIT.
·     REQUEST.
·     CONFIRM.
·     RENEW.
·     REBIND.
·     RELEASE.
·     DECLINE.
·     INFORMATION-REQUEST.
·     RELAY-FORWARD.
Packets dropped
Number of packets discarded.
Packets sent
Number of messages sent out from the DHCPv6 server. The message types include:
·     ADVERTISE.
·     RECONFIGURE.
·     REPLY.
·     RELAY-REPLY.
dns-server
Use dns-server to specify a DNS server for the client.
Use undo dns-server to remove the specified DNS server.
dns-server ipv6-address
undo dns-server ipv6-address
No DNS server address is specified.
DHCPv6 address pool view, DHCPv6 option group view
2: System level
ipv6-address: IPv6 address of a DNS server.
You can configure multiple DNS server addresses.
You can configure up to eight DNS servers in an address pool.
The precedence of the specified DNS servers depends on the configuration sequence. The formerly specified DNS server takes precedence over the latter one.
# Specify the DNS server address to be assigned to the client as 2:2::3.
[Sysname-dhcp6-pool-1] dns-server 2:2::3
domain-name
Use domain-name to configure the domain name suffix for the client.
Use undo domain-name to remove the configuration.
domain-name domain-name
undo domain-name
No domain name suffix is configured for the client.
2: System level
domain-name: Domain name suffix, a string of 1 to 50 characters.
You can configure only one domain name suffix in an address pool.
If you use the domain-name command multiple times, the most recent configuration takes effect.
# Configure the domain name suffix to be assigned to the client as aaa.com.
[Sysname-dhcp6-pool-1] domain-name aaa.com
ds-lite address
Use ds-lite address to specify the address of the AFTR.
Use undo ds-lite address to delete the address of the AFTR.
ds-lite address ipv6-address
The address of the AFTR is not specified.
2: System level
ipv6-address: IPv6 address of the AFTR.
When you configure a DS-lite tunnel, the Customer Premises Equipment (CPE) sends a DHCPv6 request to obtain the address of the AFTR. Upon receiving the request, the DHCPv6 server sends the address of the AFTR to the CPE.
You can specify only one AFTR address for an address pool. The latest setting overrides the previous one.
# Specify the AFTR address as 2::1.
[Sysname-dhcp6-pool-1] ds-lite address 2::1
network
Use network to specify an IPv6 subnet in a DHCPv6 address pool for dynamic address assignment.
Use undo network to remove an IPv6 subnet from a DHCPv6 address pool.
network { network-address/prefix-length | prefix prefix-number [ sub-prefix/sub-prefix-length ] } [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ]
undo network
No IPv6 subnet is configured for dynamic address assignment.
2: System level
network-address/prefix-length: IPv6 subnet for dynamic assignment. The network-address argument is the IPv6 address and the prefix-length argument is the prefix length. The prefix length ranges from 1 to 128.
prefix: Specifies a prefix for dynamic prefix assignment.
prefix-number: Specifies the ID of an IPv6 prefix, in the range of 1 to 1024.
sub-prefix/sub-prefix-length: Specifies the IPv6 sub-prefix and sub-prefix length. The value for sub-prefix-length ranges from 1 to 128. If the ipv6 prefix command specifies a prefix longer than the sub-prefix, the prefix is used for prefix assignment.
preferred-lifetime preferred-lifetime: Specifies the preferred lifetime for IPv6 addresses assigned from the subnet. The value ranges from 60 to 4294967295 seconds and defaults to 604800 seconds (7 days).
valid-lifetime valid-lifetime: Specifies the valid lifetime for IPv6 addresses assigned from the subnet. The value ranges from 60 to 4294967295 seconds and defaults to 2592000 seconds (30 days). The valid lifetime cannot be shorter than the preferred lifetime.
Only one subnet can be specified in an address pool. You cannot execute the network command multiple times in the same address pool.
The network command cannot be used to specify a subnet where all addresses are link-local or multicast addresses. The network command can be used to specify a subnet where some of the addresses are link-local or multicast addresses, but these addresses are not assignable.
You cannot use the network network-address/prefix-length command to configure the same subnet in different address pools, or cannot use the network prefix command in to specify the same prefix in different address pools.
You can specify a non-existing IPv6 prefix for the network prefix command, but the command takes effect only after you create the IPv6 prefix.
If the prefix used by the network prefix command changes, the assignable network changes, and information about assigned prefix and addresses is removed.
# Specify IPv6 subnet 3ffe:501:ffff:100::/64 in DHCPv6 address pool 1.
# Create an IPv6 prefix 88:99::/32 with the ID 3. Specify the IPv6 prefix in address pool 1 for prefix assignment.
[Sysname] ipv6 prefix 3 88:99::/32
[Sysname-dhcp6-pool-1] network prefix 3
# Create an IPv6 prefix 88:99::/32 with the ID 3. Specify the IPv6 prefix in address pool 1 and specify the sub-prefix and sub-prefix length as 3ffe:501:ffff:100::/64. The DHCPv6 server assigns addresses in the subnet 88:99:ffff:100::/64 with the prefix length 64. The first 32-bit prefix is determined by the prefix 3 and the last 2-bit prefix is determined by the sub-prefix.
[Sysname-dhcp6-pool-1] network prefix 3 3ffe:501:ffff:100::/64
·     ipv6 prefix
Use ipv6 dhcp option-group to create a static DHCPv6 option group, and enter its view.
Use undo ipv6 dhcp option-group to delete the specified static DHCPv6 option group.
ipv6 dhcp option-group option-group-number
undo ipv6 dhcp option-group option-group-number
No DHCPv6 option group is configured on the device.
2: System level
option-group-number: Assign an ID to the static option group, in the range of 1 to 100.
The DHCPv6 option group ID must be globally unique on the device. Do not assign the ID of a dynamic DHCPv6 option group to a static option group.
# Create a static DHCPv6 option group 1, and enter its view.
[Sysname] ipv6 dhcp option-group 1
[Sysname-dhcp6-option-group1]
ipv6 dhcp pool
Use ipv6 dhcp pool to create a DHCPv6 address pool and enter DHCPv6 address pool view, or enter DHCPv6 address pool view if the specified address pool already exists.
Use undo ipv6 dhcp pool to remove the address pool.
ipv6 dhcp pool pool-number
undo ipv6 dhcp pool pool-number
No DHCPv6 address pool is configured.
2: System level
pool-number: Assigns a number to the address pool. The value range for the this argument varies by device model. For more information, see About the H3C Access Controllers Command References.
# Create DHCPv6 address pool 1 and enter its view.
Use ipv6 dhcp prefix-pool to create a prefix pool and specify the prefix and the length of the prefix assigned.
Use undo ipv6 dhcp prefix-pool to remove the prefix pool.
ipv6 dhcp prefix-pool prefix-pool-number prefix { prefix-number | prefix/prefix-len } assign-len assign-len
undo ipv6 dhcp prefix-pool prefix-pool-number
No prefix pool is configured.
2: System level
prefix-pool-number: Assigns a number to the prefix pool. The value range for this argument varies by device model. For more information, see About the H3C Access Controllers Command References.
prefix: Specifies a prefix by specifying its ID or the prefix.
prefix-number: Specifies the ID of the IPv6 prefix, in the range of 1 to 1024.
prefix/prefix-len: Specifies the IPv6 prefix and prefix length. The value range for the prefix-len argument is 1 to 128.
assign-len assign-len: Specifies the length of the prefix assigned. The value ranges from 1 to 128. The assign-len must be higher than or equal to the prefix-len, and the difference between them must be less than or equal to 16.
The prefix ranges of the prefix pools cannot overlap. Otherwise, the prefix pools configured later does not take effect.
You cannot modify an existing prefix pool.
Removing a prefix pool clears all bindings of prefixes assigned from the prefix pool.
You can specify a non-existing IPv6 prefix for the ipv6 dhcp prefix-pool command, but the command takes effect only after you create the IPv6 prefix.
You cannot specify the same IPv6 prefix for different prefix pools.
When the IPv6 prefix used by the ipv6 dhcp prefix-pool command changes, the assignable prefix range changes accordingly.
# Create prefix pool 1 that contains the prefix 2001:0410::/32 and specify the length of prefixes to be assigned as 42. Prefix pool 1 can assign 1024 prefixes in the range of 2001:0410::/42 to 2001:0410:FFC0::/42.
[Sysname] ipv6 dhcp prefix-pool 1 prefix 2001:0410::/32 assign-len 42
# Create IPv6 prefix with the ID 3. Create prefix pool 2, and specify the prefix 3 and the length of the prefixes to be assigned as 42. Prefix pool 2 can assign 1024 prefixes in the range of 88:99::/42 to 88:99:FFC0::/42.
[Sysname] ipv6 dhcp prefix-pool 2 prefix 3 assign-len 42
ipv6 dhcp server
Use ipv6 dhcp server to enable the DHCPv6 server on the interface.
Use undo ipv6 dhcp server to remove the configuration.
ipv6 dhcp server [ allow-hint | apply pool pool-number | preference preference-value | rapid-commit ] *
The DHCPv6 server is not enabled on an interface.
Interface view
2: System level
allow-hint: Enables desired address and prefix assignment.
apply pool pool-number: Applies an address pool to the interface. The value range for the pool number varies by device model. For more information, see About the H3C Access Controllers Command References. If this option is specified, the DHCPv6 server assigns an IPv6 address or prefix from the address pool applied on the interface to the client. If not, the server searches all DHCPv6 address pools to assign an appropriate one to the client.
preference preference-value: Specifies the server priority in Advertise messages, in the range of 0 to 255. The default value is 0. A higher value indicates a higher priority.
rapid-commit: Enables rapid address and prefix assignment.
Upon receiving a request, the interface enabled with the DHCPv6 server selects an IPv6 address or a prefix from the address pool and assigns it to the client.
With the allow-hint keyword specified, the server assigns the desired address or prefix to the requesting client. If the desired address or prefix is not included in the assignable address pool of the interface, or is already assigned to another client, the server ignores the desired address or prefix and assigns the client an address or a prefix from the free addresses or prefixes.
An interface cannot serve as a DHCPv6 server and DHCPv6 relay agent at the same time. H3C recommends not enabling the DHCPv6 server and DHCPv6 client on the same interface.
Only one address pool can be applied to an interface.
You can apply a non-existing address pool to an interface. However, the server cannot assign any address, prefix, or other configuration information from the address pool until the address pool is created.
If you execute the command multiple times on the same interface, the most recent configuration takes effect.
# Enable DHCPv6 server on interface VLAN-interface 2, apply prefix pool 1 to VLAN-interface 2, configure the server to support desired address and prefix assignment, and rapid address and prefix assignment, and set the highest priority of 255.
[Sysname-Vlan-interface2] ipv6 dhcp server apply pool 1 allow-hint preference 255 rapid-commit
Use ipv6 dhcp server enable to enable the DHCPv6 server.
Use undo ipv6 dhcp server enable to disable the DHCPv6 server.
The DHCPv6 server is disabled.
2: System level
Other DHCPv6 server related configuration is effective only when the DHCPv6 server is enabled.
# Enable the DHCPv6 server.
[Sysname] ipv6 dhcp server enable
Use ipv6 nd ra separate-delegation dhcp-pool to configure the DHCPv6 server to assign IPv6 prefixes to clients for stateless address autoconfiguration.
Use undo ipv6 nd ra separate-delegation dhcp-pool to restore the default.
ipv6 nd ra separate-delegation dhcp-pool prefix-pool-number
The DHCPv6 server does not assign IPv6 prefixes to clients for stateless address autoconfiguration.
Interface view
2: System level
prefix-pool-number: Specifies a DHCPv6 prefix pool by its number. The value range for this argument varies by device model. For more information, see About the H3C Access Controllers Command References.
When receiving an RS message from a client , the DHCPv6 server sends back an IPv6 prefix in an RA message to the client for stateless address autoconfiguration.
# Configure the DHCPv6 server to assign prefixes from IPv6 prefix pool 1 to clients for stateless address autoconfiguration.
[Sysname] interface vlan 1
[Sysname-Vlan-interface1] ipv6 nd ra separate-delegation dhcp-pool 1
option
Use option to configure a self-defined DHCPv6 option.
Use to undo option delete a self-defined DHCPv6 option.
option code hex hex-string
undo option code
No self-defined DHCPv6 option is configured.
2: System level
code: Self-defined option code in the range of 21 to 65535, excluding 25, 26, 37 to 40, and 43 to 48.
hex hex-string: Specifies a hexadecimal string. The number of hexadecimal digits must be an even number in the range of 2 to 256.
If you use the option command multiple times with the same code, the most recent configuration takes effect.
You can configure a maximum of 256 self-defined options.
Use the option command to specify a hexadecimal string for the padding content of the option with the code argument so that the server can assigns the option to clients.
Some DHCPv6 options can be specified by the option command or other dedicated commands. For example, to specify the DNS server address, you can use the dns-server command or the option 23 command. If both commands are configured, the dns-server command takes precedence.
# Configure the hexadecimal string 020202 for the self-defined DHCP Option 23 in DHCPv6 address pool 1. The DHCPv6 server assigns the DNS server address 2.2.2.2 to clients.
[Sysname-dhcp6-pool-1] option 23 hex 02020202
option-group
Use option-group to apply a DHCPv6 option group to the address pool so that the DHCPv6 server assigns parameters in the option group to DHCP6 clients.
Use undo option-group to remove the DHCPv6 option group application.
undo option-group
No DHCPv6 option group is configured.
2: System level
Only one DHCPv6 option group can be applied to one DHCPv6 address pool. You cannot execute the command multiple times in the same address pool.
Configuration parameters in the address pool take precedence over these in the DHCPv6 option group.
# Apply DHCPv6 option group 1 to DHCPv6 address pool 1.
[Sysname-dhcp6-pool-1] option-group 1
prefix-pool
Use prefix-pool to apply a prefix pool to the DHCPv6 address pool, so that the DHCPv6 server can dynamically select a prefix from the prefix pool and assign it to the client.
Use undo prefix-pool to remove the configuration.
prefix-pool prefix-pool-number [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ]
undo prefix-pool
No prefix pool is referenced by an address pool.
2: System level
prefix-pool-number: Specifies a prefix pool by its number. The value range for this argument varies by device model. For more information, see About the H3C Access Controllers Command References.
preferred-lifetime preferred-lifetime: Specifies the preferred lifetime of prefixes to be assigned. The value ranges from 60 to 4294967295, in seconds. The default value is 604800 seconds (7 days).
valid-lifetime valid-lifetime: Specifies the valid lifetime of the prefixes to be assigned. The value ranges from 60 to 4294967295 seconds and defaults to 2592000 seconds (30 days). The valid lifetime cannot be shorter than the preferred lifetime.
Only one prefix pool can be referenced by an address pool.
A non-existing prefix pool can be referenced by an address pool. However, no prefix is available in the prefix pool for dynamic prefix assignment until the prefix pool is created.
You cannot modify the prefix pool referenced by an address pool, or the preferred lifetime or valid lifetime by using the prefix-pool command. You need to remove the configuration before you can have another prefix pool referenced by the address pool, or modify the preferred lifetime and valid lifetime.
# Apply prefix pool 1 to address pool 1, and use the default preferred lifetime and valid lifetime.
[Sysname-dhcp6-pool-1] prefix-pool 1
# Apply prefix pool 1 to address pool 1, and set the valid lifetime to three days, the preferred lifetime to one day.
[Sysname-dhcp6-pool-1] prefix-pool 1 preferred-lifetime 86400 valid-lifetime 259200
Use reset ipv6 dhcp server conflict to clear IPv6 address conflict information.
reset ipv6 dhcp server conflict [ address ipv6-address | pool pool-number ] ]
2: System level
address ipv6-address: Clears conflict information about a specific IPv6 address.
pool pool-number: Clears IPv6 address conflict information about the address pool specified by the pool number. The value range for the pool number varies by device model. For more information, see About the H3C Access Controllers Command References.
# Clear all IPv6 address conflict information.
<Sysname> reset ipv6 dhcp server conflict
Use reset ipv6 dhcp server expired to clear binding information about lease-expired IPv6 addresses.
reset ipv6 dhcp server expired [ address ipv6-address | pool pool-number ] ]
2: System level
address ipv6-address: Clears binding information about the specified lease-expired IPv6 address.
pool pool-number: Clears binding information about lease-expired IPv6 addresses in the address pool specified by its number. The value range for the pool number varies by device model. For more information, see About the H3C Access Controllers Command References.
# Clears binding information about lease-expired IPv6 addresses in address pool 1.
<Sysname> reset ipv6 dhcp server expired pool 1
Use reset ipv6 dhcp server ip-in-use to clear IPv6 address binding information.
reset ipv6 dhcp server ip-in-use [ address ipv6-address | pool pool-number ]
2: System level
address ipv6-address: Clears binding information about a specific IPv6 address.
pool pool-number: Clears IPv6 address binding information about the address pool specified by the pool number. The value range for the pool number varies by device model. For more information, see About the H3C Access Controllers Command References.
This command only clears offered and committed static bindings but not free static bindings.
This command changes offered and committed static bindings to free static bindings.
# Clear all IPv6 address binding information.
<Sysname> reset ipv6 dhcp server ip-in-use
# Clear IPv6 address binding information about address pool 1.
<Sysname> reset ipv6 dhcp server ip-in-use pool 1
# Clear the binding information about IPv6 address 2001:0:0:1::1.
<Sysname> reset ipv6 dhcp server ip-in-use address 2001:0:0:1::1
Use reset ipv6 dhcp server pd-in-use to clear IPv6 prefix binding information.
reset ipv6 dhcp server pd-in-use [ pool pool-number | prefix prefix/prefix-len | prefix-pool prefix-pool-number ]
2: System level
pool pool-number: Clears IPv6 prefix binding information about the address pool specified by the pool number. The value range for the pool number varies by device model. For more information, see About the H3C Access Controllers Command References.
prefix prefix/prefix-len: Clears binding information about the specified IPv6 prefix. The prefix/prefix-len indicates the IPv6 prefix and prefix length. The value range for the prefix length is 1 to 128.
prefix-pool prefix-pool-number: Clears prefix binding information about the prefix pool specified by its prefix pool number. The value range for the prefix pool number varies by device model. For more information, see About the H3C Access Controllers Command References.
# Clear IPv6 prefix binding information about address pool 1.
<Sysname> reset ipv6 dhcp server pd-in-use pool 1
# Clear binding information about IPv6 prefix 2001:0:0:1::/64.
<Sysname> reset ipv6 dhcp server pd-in-use prefix 2001:0:0:1::/64
Use reset ipv6 dhcp server statistics to clear packet statistics on the DHCPv6 server.
1: Monitor level
# Clear packet statistics on the DHCPv6 server.
<Sysname> reset ipv6 dhcp server statistics
sip-server
Use sip-server to configure the IPv6 address or domain name of a SIP server for the client.
Use undo sip-server to remove the configuration.
sip-server { address ipv6-address | domain-name domain-name }
undo sip-server { address ipv6-address | domain-name domain-name }
No SIP server address or domain name is specified.
2: System level
address ipv6-address: Specifies the IPv6 address of a SIP server.
domain-name domain-name: Specifies the domain name of a SIP server. The domain name is a string of 1 to 50 characters.
You can configure up to eight SIP server addresses and eight SIP server domain names in an address pool. The priorities of the specified SIP servers depend on the configuration sequence. The formerly specified SIP server takes precedence over the latter one.
If you use the sip-server command multiple times, the latest configuration does not overwrite the previous one.
# Specify the SIP server address as 2:2::4 for the client.
[Sysname-dhcp6-pool-1] sip-server address 2:2::4
# Specify the domain name of the SIP server as bbb.com for the client.
[Sysname-dhcp6-pool-1] sip-server domain-name bbb.com
static-bind address
Use static-bind address to configure a static IPv6 address binding in an address pool.
Use undo static-bind address to remove a static IPv6 address binding.
static-bind address ipv6-address/addr-prefix-length duid duid [ iaid iaid ] [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ]
undo static-bind address ipv6-address/addr-prefix-length
No static IPv6 address binding is configured in an address pool.
2: System level
ipv6-address/addr-prefix-length: Static IPv6 address and prefix length. The prefix length ranges from 1 to 128.
duid duid: Specifies a client DUID. The value is an even hexadecimal number in the range of 2 to 256.
iaid iaid: Specifies a client IAID. The value is a hexadecimal number in the range of 0 to FFFFFFFF. If no IAID is specified, the server does not match against the client IAID during address assignment.
preferred-lifetime preferred-lifetime: Specifies the preferred lifetime of the static IPv6 address. The value ranges from 60 to 4294967295 seconds and defaults to 604,800 seconds (7 days).
valid-lifetime valid-lifetime: Specifies the valid lifetime of the static IPv6 address. The value ranges from 60 to 4294967295 seconds and defaults to 2592000 seconds (30 days). The valid lifetime cannot be shorter than the preferred lifetime.
You can configure multiple static IPv6 address bindings.
An IPv6 address can be bound to only one DHCPv6 client. You cannot use the static-bind address command to modify the DUID, IAID, preferred lifetime and valid lifetime of a static IPv6 address binding. To do so, remove the static binding first.
# In address pool 1, bind static address 2001:0410::2/35 to the client with DUID 00030001CA0006A400 and IAID A1A1A1A1, and use the default settings of the preferred lifetime and valid lifetime.
[Sysname-dhcp6-pool-1] static-bind address 2001:0410::2/35 duid 00030001CA0006A400 iaid A1A1A1A1
static-bind prefix
Use static-bind prefix to configure a static prefix.
Use undo static-bind prefix to remove a static prefix.
static-bind prefix prefix/prefix-len duid duid [ iaid iaid ] [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ]
undo static-bind prefix prefix/prefix-len
No static prefix is configured.
2: System level
prefix/prefix-len: Static prefix and prefix length. The prefix length ranges from 1 to 128.
iaid iaid: Specifies a client IAID. The value is a hexadecimal number in the range of 0 to FFFFFFFF. If you do not specify an IAID, the server does not match against the client IAID for prefix assignment.
preferred-lifetime preferred-lifetime: Specifies the preferred lifetime of the prefix to be assigned. The value ranges from 60 to 4294967295, in seconds. The default value is 604800 seconds, that is, 7 days.
valid-lifetime valid-lifetime: Specifies the valid lifetime of the prefix to be assigned. The value ranges from 60 to 4294967295 seconds and defaults to 2592000 seconds, that is, 30 days. The valid lifetime cannot be shorter than the preferred lifetime.
An IPv6 prefix can be bound to only one DHCPv6 client. You cannot use the static-bind prefix command to modify the DUID, IAID, preferred lifetime, and valid lifetime of an existing static IPv6 prefix binding. To do so, remove the static IPv6 prefix binding first.
# In address pool 1, bind static prefix 2001:0410::/35 to the client with DUID 00030001CA0006A400 and IAID A1A1A1A1, and set the preferred lifetime to one day, and the valid lifetime to three days.
[Sysname-dhcp6-pool-1] static-bind prefix 2001:0410::/35 duid 00030001CA0006A400 iaid A1A1A1A1 preferred-lifetime 86400 valid-lifetime 259200
Use temporary address range to configure a temporary IPv6 address range in a DHCPv6 address pool for dynamic allocation.
Use undo temporary address range to remove the temporary IPv6 address range from the address pool.
temporary address range start-ipv6-address end-ipv6-address [ preferred-lifetime preferred-lifetime valid-lifetime valid-lifetime ]
No temporary IPv6 address range is configured in an address pool.
2: System level
preferred-lifetime preferred-lifetime: Specifies the preferred lifetime. The value ranges from 60 to 4294967295 seconds and defaults to 604800 seconds (7 days).
valid-lifetime valid-lifetime: Specifies the valid lifetime. The value ranges from 60 to 4294967295 seconds, and defaults to 2592000 seconds (30 days). The valid lifetime cannot be shorter than the preferred lifetime.
If you do not execute the temporary address range command, the DHCPv6 server does not support temporary address assignment.
You can configure only one temporary IPv6 address range in an address pool. If you execute the command multiple times, the most recent configuration takes effect.
The temporary IPv6 address range specified by the temporary address range command must be on the subnet specified by the network command.
# In DHCPv6 address pool 1, configure a temporary IPv6 address range from 3ffe:501:ffff:100::50 to 3ffe:501:ffff:100::60.
[Sysname-dhcp6-pool-1] temporary address range 3ffe:501:ffff:100::50 3ffe:501:ffff:100::60
·     network
·     address range
Use display ipv6 dhcp relay server-address to display information about DHCPv6 server addresses specified on the DHCPv6 relay agent.
display ipv6 dhcp relay server-address { all | interface interface-type interface-number } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
all: Displays all DHCPv6 server address information.
interface interface-type interface-number: Displays DHCPv6 server address information about the specified interface.
# Display all DHCPv6 server address information.
<Sysname> display ipv6 dhcp relay server-address all
Interface: Vlan2
Server address(es)                             Output Interface
1::1
FF02::1:2                                      Vlan4
Interface: Vlan3
1::1
FF02::1:2                                      Vlan4
# Display DHCPv6 server addresses on VLAN-interface 2.
<Sysname> display ipv6 dhcp relay server-address interface vlan-interface 2
Interface: Vlan2
1::1
FF02::1:2                                      Vlan4
Table 10 Command output
Interface that serves as the DHCPv6 relay agent.
Server address(es)
DHCPv6 server addresses specified on the interface.
Output Interface
Outgoing interface of DHCPv6 packets.
Use display ipv6 dhcp relay statistics to display packet statistics on the DHCPv6 relay agent.
display ipv6 dhcp relay statistics [ | { begin | exclude | include } regular-expression ]
1: Monitor level
# Display packet statistics on the DHCPv6 relay agent.
<Sysname> display ipv6 dhcp relay statistics
Packets dropped               :  4
    Error                     :  4
    Excess of rate limit      :  0
Packets received              :  14
    SOLICIT                   :  0
    REQUEST                   :  0
    CONFIRM                   :  0
    RENEW                     :  0
    REBIND                    :  0
    RELEASE                   :  0
    DECLINE                   :  0
    INFORMATION-REQUEST       :  7
    RELAY-FORWARD             :  0
    RELAY-REPLY               :  7
Packets sent                  :  14
    ADVERTISE                 :  0
    RECONFIGURE               :  0
    REPLY                     :  7
    RELAY-FORWARD             :  7
    RELAY-REPLY               :  0
Table 11 Command output
Packets dropped
Number of discarded packets.
Error
Number of discarded error packets.
Number of packets discarded due to excess of rate limit.
Packets received
Number of received packets.
SOLICIT
Number of received solicit packets.
REQUEST
Number of received request packets.
CONFIRM
Number of received confirm packets.
RENEW
Number of received renew packets.
REBIND
Number of received rebind packets.
RELEASE
Number of received release packets.
DECLINE
Number of received decline packets.
INFORMATION-REQUEST
Number of received information request packets.
RELAY-FORWARD
Number of received relay-forward packets.
RELAY-REPLY
Number of received relay-reply packets.
Packets sent
Number of sent packets.
ADVERTISE
Number of sent advertise packets.
RECONFIGURE
Number of sent reconfigure packets.
REPLY
Number of sent reply packets.
RELAY-FORWARD
Number of sent Relay-forward packets.
RELAY-REPLY
Number of sent Relay-reply packets.
Use ipv6 dhcp relay server-address to enable DHCPv6 relay agent on the interface and specify a DHCPv6 server.
Use undo ipv6 dhcp relay server-address to remove the DHCPv6 server from the interface.
ipv6 dhcp relay server-address ipv6-address [ interface interface-type interface-number ]
undo ipv6 dhcp relay server-address ipv6-address [ interface interface-type interface-number ]
DHCPv6 relay agent is disabled and no DHCPv6 server is specified on the interface.
Interface view
2: System level
ipv6-address: IPv6 address of the DHCPv6 server.
interface interface-type interface-number: Specifies an outgoing interface for DHCPv6 packets.
Upon receiving a request from a DHCPv6 client, the interface that operates as a DHCPv6 relay agent encapsulates the request into a Relay-forward message and forwards the message to the specified DHCPv6 server, which then assigns an IPv6 address and other configuration parameters to the DHCPv6 client.
You can specify up to eight DHCP servers for an interface. After receiving requests from DHCPv6 clients, the DHCPv6 relay agent forwards the requests to all the specified DHCPv6 servers.
If the DHCPv6 server address is a link-local address or link-scoped multicast address on the local link, specify an outgoing interface. If no outgoing interface is specified, DHCPv6 packets may fail to be forwarded to the DHCPv6 server.
After you remove all the specified DHCPv6 servers from an interface with the undo ipv6 dhcp relay server-address command, DHCPv6 relay agent is disabled on the interface.
An interface cannot serve as a DHCPv6 client and DHCPv6 relay agent at the same time.
# Enable DHCPv6 relay agent on VLAN-interface 2, and specify the DHCPv6 server address as 2001:1::3.
[Sysname-Vlan-interface2] ipv6 dhcp relay server-address 2001:1::3
Use reset ipv6 dhcp relay statistics to clear packets statistics on the DHCPv6 relay agent.
1: Monitor level
After this command is executed, the packets statistics are displayed as 0 for the output from the display ipv6 dhcp relay statistics command.
# Clear packet statistics on the DHCPv6 relay agent.
<Sysname> reset ipv6 dhcp relay statistics
Use display ipv6 dhcp client to display DHCPv6 client information.
display ipv6 dhcp client [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
interface interface-type interface-number: Displays DHCPv6 client information about a specific interface.
If you do not specify any parameters, the command displays DHCPv6 client information about all interfaces.
# Display the DHCPv6 client information about VLAN-interface 2.
<Sysname> display ipv6 dhcp client interface vlan-interface 2
Vlan-interface2 is in stateless DHCPv6 client mode
State is OPEN
Preferred Server:
    Reachable via address    :  FE80::213:7FFF:FEF6:C818
    DUID                     :  0003000100137ff6c818
    DNS servers              :  1:2:3::5
                                1:2:4::7
    Domain names             :  abc.com
Table 12 Command output
The client is in the stateless DHCPv6 configuration mode.
State is OPEN
Current state of the DHCPv6 client:
·     INIT—After enabled, the DHCPv6 client enters INIT state.
·     IDLE—After receiving an RA message with the "M" flag set to 0 and "O" flag set to 1 and enabled with stateless DHCPv6, the DHCPv6 client enters IDLE state.
·     INFO-REQUESTING—The DHCPv6 client is requesting configuration information.
·     OPEN—The DHCPv6 client successfully obtained configuration parameters and completed stateless configuration based on the obtained parameters.
Preferred Server
Information about the DHCPv6 server selected by the DHCPv6 client.
Reachable address, which is the link local address of the DHCPv6 server or relay agent.
DUID
DUID of the DHCPv6 server.
DNS servers
DNS server address sent by the DHCPv6 server.
Domain names
Domain name information sent by the DHCPv6 server.
Use display ipv6 dhcp client statistics to display DHCPv6 client statistics.
display ipv6 dhcp client statistics [ interface interface-type interface-number ] [ | { begin | exclude | include } regular-expression ]
1: Monitor level
interface interface-type interface-number: Displays the DHCPv6 client statistics of a specific interface.
If you do not specify any parameters, the command displays DHCPv6 client statistics of all interfaces.
# Display DHCPv6 client statistics of VLAN-interface 2.
<Sysname> display ipv6 dhcp client statistics interface vlan-interface 2
Interface                    :  Vlan-interface2
Packets Received             :  1
         Reply               :  1
         Advertise           :  0
         Reconfigure         :  0
         Invalid             :  0
Packets Sent                 :  5
         Solicit             :  0
         Request             :  0
         Confirm             :  0
         Renew               :  0
         Rebind              :  0
         Information-request :  5
         Release             :  0
         Decline             :  0
Table 13 Command output
Interface that serves as the DHCPv6 client.
Packets Received
Reply
Number of received reply packets.
Advertise
Number of received advertise packets.
Reconfigure
Number of received reconfigure packets.
Invalid
Number of invalid packets.
Packets Sent
Solicit
Number of sent solicit packets.
Request
Number of sent request packets.
Confirm
Number of sent confirm packets.
Renew
Number of sent renew packets.
Rebind
Number of sent rebind packets.
Information-request
Number of sent information request packets.
Release
Number of sent release packets.
Decline
Number of sent decline packets.
Use the ipv6 address dhcp-alloc command to configure an interface to use DHCPv6 for IP address acquisition.
Use the undo ipv6 address dhcp-alloc command to cancel an interface from using DHCPv6.
ipv6 address dhcp-alloc [ option-group group-number | rapid-commit ] *
An interface does not use DHCPv6 for IP address acquisition.
Interface view
2: System level
option-group option-group-number: Enables the DHCPv6 client to create a dynamic DHCPv6 option group for saving the network parameters, and assigns an ID to the dynamic DHCPv6 option group in the range of 1 to 100. If you do not specify any option group ID, the DHCPv6 client does not create any dynamic DHCPv6 option group.
# Configure VLAN-interface 10 to use DHCPv6 for address acquisition, enable rapid address assignment, and specify the ID for the DHCPv6 option group as 1. When the client obtains network parameters, it creates an option group and saves the parameters in the group.
[Sysname-Vlan-interface10] ipv6 address dhcp-alloc rapid-commit option-group 1
ipv6 dhcp client pd
Use ipv6 dhcp client pd to configure an interface to use DHCPv6 for IPv6 prefix acquisition.
Use undo ipv6 dhcp client pd to cancel an interface from using DHCPv6.
ipv6 dhcp client pd prefix-number [ option-group group-number | rapid-commit ] *
An interface does not use DHCPv6 for IPv6 prefix acquisition.
Interface view
2: System level
prefix-number: Specifies an IPv6 prefix ID in the range of 1 to 1024. The client, after obtaining an IPv6 prefix, automatically assigns it the specified ID.
option-group option-group-number: Enables the DHCPv6 client to create a dynamic DHCPv6 option group for saving the network parameters, and assigns an ID to the dynamic DHCPv6 option group in the range of 1 to 100. If no option group ID is specified, the DHCPv6 client does not create any dynamic DHCPv6 option group.
# Configure VLAN-interface10 to use DHCPv6 for IPv6 prefix acquisition. Specify the prefix ID as 1, enable the DHCPv6 client to create a dynamic DHCPv6 option group with the ID 1, and enable rapid address and prefix assignment.
[Sysname-Vlan-interface10] ipv6 dhcp client pd 1 rapid-commit option-group 1
Use reset ipv6 dhcp client statistics to clear DHCPv6 client statistics.
reset ipv6 dhcp client statistics [ interface interface-type interface-number ]
1: Monitor level
interface interface-type interface-number: Clears DHCPv6 client statistics of a specific interface.
If you do not specify any parameters, the command clears DHCPv6 client statistics of all interfaces.
After this command is executed, the packets statistics are displayed as 0 for the display ipv6 dhcp client statistics command output.
# Clear DHCPv6 client statistics of all interfaces.
<Sysname> reset ipv6 dhcp client statistics
DHCPv6 snooping configuration commands
display ipv6 dhcp snooping trust
Use display ipv6 dhcp snooping trust to display DHCPv6 snooping trusted ports.
display ipv6 dhcp snooping trust [ | { begin | exclude | include } regular-expression ]
Default command level
1: Monitor level
|: Filters command output by specifying a regular expression. For more information about regular expressions, see Fundamentals Configuration Guide.
begin: Displays the first line that matches the specified regular expression and all lines that follow.
exclude: Displays all lines that do not match the specified regular expression.
include: Displays all lines that match the specified regular expression.
regular-expression: Specifies a regular expression, a case-sensitive string of 1 to 256 characters.
# Display DHCPv6 snooping trusted ports.
<Sysname> display ipv6 dhcp snooping trust
 Trusted ports include:
 Ten-GigabitEthernet1/0/1
 Ten-GigabitEthernet1/0/2
display ipv6 dhcp snooping user-binding
Use display ipv6 dhcp snooping user-binding to display DHCPv6 snooping entries.
display ipv6 dhcp snooping user-binding { ipv6-address | dynamic } [ | { begin | exclude | include } regular-expression ]
1: Monitor level
ipv6-address: Displays DHCPv6 snooping entries of the specified IPv6 address.
dynamic: Displays all DHCPv6 snooping entries.
# Display all DHCPv6 snooping entries.
<Sysname> display ipv6 dhcp snooping user-binding dynamic
IPv6 Address                   MAC Address    Lease      VLAN Interface
2::1                           00e0-fc00-0006 286        1    Ten-GigabitEthernet1/0/1
---   1 DHCPv6 snooping item(s) found   ---
Table 14 Command output
IPv6 Address
IPv6 address in the DHCPv6 snooping entry.
MAC Address
MAC address in the DHCPv6 snooping entry.
Lease
Remaining lease of the DHCPv6 snooping entry, in seconds.
VLAN
VLAN to which the interface belongs.
Interface through which the DHCPv6 client is connected.
ipv6 dhcp snooping enable
Use ipv6 dhcp snooping enable to enable DHCPv6 snooping globally.
Use undo ipv6 dhcp snooping enable to disable DHCPv6 snooping globally.
Global DHCPv6 snooping is disabled.
2: System level
After DHCPv6 snooping is enabled in system view, the DHCPv6 snooping device discards DHCPv6 reply messages received by an untrusted port if any, and does not record these DHCPv6 snooping entries.
# Enable DHCPv6 snooping globally.
[Sysname] ipv6 dhcp snooping enable
ipv6 dhcp snooping max-learning-num
Use ipv6 dhcp snooping max-learning-num to configure the maximum number of DHCPv6 snooping entries an interface can learn.
Use undo ipv6 dhcp snooping max-learning-num to restore the default.
ipv6 dhcp snooping max-learning-num number
The number of DHCPv6 snooping entries learned by an interface is not limited.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
2: System level
number: Maximum number of DHCPv6 snooping entries an interface can learn, in the range of 0 to 4096.
# Set the maximum number of DHCPv6 snooping entries Layer 2 Ethernet interface GigabitEthernet 1/0/1 can learn to 1000.
[Sysname-GigabitEthernet1/0/1] ipv6 dhcp snooping max-learning-num 1000
Use ipv6 dhcp snooping trust to configure a DHCPv6 trusted port.
Use undo ipv6 dhcp snooping trust to restore the default.
All interfaces of a device with DHCPv6 snooping enabled globally are untrusted ports.
2: System level
After DHCPv6 snooping is enabled, to make sure DHCPv6 clients can obtain IPv6 addresses from an authorized DHCPv6 server, you must configure the port that connects to the authorized DHCPv6 server as a trusted port.
# Configure Ethernet interface GigabitEthernet 1/0/1 as a trusted port.
[Sysname-GigabitEthernet1/0/1] ipv6 dhcp snooping trust
ipv6 dhcp snooping vlan enable
Use ipv6 dhcp snooping vlan enable to enable DHCPv6 snooping for a specific VLAN.
Use undo ipv6 dhcp snooping vlan enable to disable DHCPv6 snooping for a specific VLAN.
DHCPv6 snooping is disabled for a VLAN.
VLAN view
2: System level
After DHCPv6 snooping is enabled globally and then enabled for a VLAN, the DHCPv6 snooping device records DHCPv6 snooping entries according to the DHCPv6 packets received in the VLAN. Meanwhile, upon receiving a DHCPv6 request from a client in the VLAN, the device forwards the packet through trusted ports rather than any untrusted port in the VLAN, thus reducing network traffic.
# Enable DHCPv6 snooping for VLAN 1.
[Sysname] vlan 1
[Sysname-vlan1] ipv6 dhcp snooping vlan enable
reset ipv6 dhcp snooping user-binding
Use reset ipv6 dhcp snooping user-binding to clear DHCPv6 snooping entries.
reset ipv6 dhcp snooping user-binding { ipv6-address | dynamic }
2: System level
ipv6-address: Clears DHCPv6 snooping entries of the specified IPv6 address.
dynamic: Clears all DHCPv6 snooping entries.
# Clear all DHCPv6 snooping entries.
<Sysname> reset ipv6 dhcp snooping user-binding dynamic
