H3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
HomeSupportSwitchesH3C S5500 Switch SeriesReference GuidesCommand ReferencesH3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
42-Appendix
42-Appendix 112 KB
Appendix A  Command Index
The command index includes all the commands in the Command Manual, which are arranged alphabetically.
A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
A
abr-summary
IPv4 Routing Commands
3-1
abr-summary
IPv6 Routing Commands
3-1
access-limit
AAA RADIUS HWTACACS Commands
1-1
accounting
QoS Commands
2-6
accounting default
1-2
accounting lan-access
1-3
accounting login
1-4
accounting optional
1-5
accounting-on enable
1-30
accounting-on enable interval
1-30
accounting-on enable send
1-31
acl
Login Commands
2-1
acl
ACL Commands
1-5
acl copy
ACL Commands
1-7
acl ipv6
ACL Commands
1-20
acl ipv6 copy
ACL Commands
1-22
acl ipv6 name
ACL Commands
1-23
acl name
ACL Commands
1-8
activation-key
Login Commands
1-1
active region-configuration
MSTP Commands
1-1
add-member
Cluster Management Commands
1-16
administrator-address
1-17
aggregate
5-1
aggregation-group
IPv6 Commands
3-1
apply as-path
6-1
apply comm-list delete
6-2
apply community
6-3
apply cost
6-4
apply cost-type
6-4
apply extcommunity
6-5
apply ip-address next-hop
6-23
apply ipv6 next-hop
6-1
apply isis
6-6
apply local-preference
6-7
apply origin
6-7
apply poe-profile
PoE Commands
1-1
apply poe-profile interface
PoE Commands
1-2
apply preference
6-8
apply preferred-value
6-9
apply tag
6-10
area
3-2
area
3-2
area-authentication-mode
4-1
arp check enable
ARP Commands
1-1
arp max-learning-num
ARP Commands
1-1
arp static
ARP Commands
1-2
arp timer aging
ARP Commands
1-3
asbr-summary
3-3
ascii
File System Management Commands
2-5
attribute
1-6
attribute
PKI Commands
1-1
authentication default
1-7
authentication lan-access
1-8
authentication login
1-9
authentication-mode
Login Commands
1-2
authentication-mode
3-4
authorization command
1-10
authorization default
1-11
authorization lan-access
1-12
authorization login
1-13
auto cost enable
4-2
auto-build
1-18
auto-execute command
Login Commands
1-3
auto-rp enable
Multicast Commands
6-1
B
backup startup-configuration
1-11
balance
5-3
balance
5-1
bandwidth-reference
3-5
bandwidth-reference
4-3
bestroute as-path-neglect
5-3
5-1
bestroute compare-med
5-4
5-2
bestroute med-confederation
5-5
5-3
bgp
5-5
bims-server
DHCP Commands
1-1
binary
2-5
black-list add-mac
1-19
black-list delete-mac
1-20
bootfile-name
DHCP Commands
1-2
boot-loader
System Maintaining and Debugging Commands
3-1
bootrom
3-2
bootrom-update security-check enable
3-2
bpdu-tunnel dot1q enable
BPDU Tunneling Commands
2-2
bpdu-tunnel dot1q stp
2-1
bpdu-tunnel tunnel-dmac
2-3
broadcast-suppression
Port Correlation Configuration Commands
1-1
bsr-policy
Multicast Commands
6-2
build
1-20
bye
2-6
bye
SSH Commands
1-32
C
ca identifier
PKI Commands
1-2
cache-sa-enable
Multicast Commands
7-1
car
QoS Commands
2-6
c-bsr
Multicast Commands
6-2
c-bsr admin-scope
Multicast Commands
6-3
c-bsr global
Multicast Commands
6-4
c-bsr group
Multicast Commands
6-5
c-bsr hash-length
Multicast Commands
6-6
c-bsr holdtime
Multicast Commands
6-6
c-bsr interval
Multicast Commands
6-7
c-bsr priority
Multicast Commands
6-8
cd
1-1
cd
2-6
cd
SSH Commands
1-33
cdup
2-7
cdup
SSH Commands
1-33
certificate request entity
PKI Commands
1-3
certificate request from
PKI Commands
1-3
certificate request mode
PKI Commands
1-4
certificate request polling
PKI Commands
1-5
certificate request url
PKI Commands
1-6
check region-configuration
MSTP Commands
1-1
checkzero
2-1
checkzero
2-1
ciphersuite
HTTPS Commands
1-1
circuit-cost
4-4
classifier behavior
QoS Commands
2-18
client-verify enable
HTTPS Commands
1-2
clock datetime
1-1
clock summer-time one-off
1-2
clock summer-time repeating
1-3
clock timezone
1-4
close
2-7
close-mode wait
HTTPS Commands
1-2
cluster
1-21
cluster enable
1-22
cluster switch-to
1-22
command-privilege
1-5
common-name
PKI Commands
1-6
compare-different-as-med
5-6
5-4
confederation id
5-7
confederation nonstandard
5-8
confederation peer-as
5-8
control-vlan
RRPP Commands
1-1
copy
1-2
cost-style
4-5
country
PKI Commands
1-7
crl check
PKI Commands
1-8
crl update-period
PKI Commands
1-8
crl url
PKI Commands
1-9
c-rp
Multicast Commands
6-9
c-rp advertisement-interval
Multicast Commands
6-10
c-rp holdtime
Multicast Commands
6-11
crp-policy
Multicast Commands
6-11
cut connection
1-14
D
dampening
5-9
dampening
5-4
databits
Login Commands
1-4
data-fill
NQA Commands
1-1
data-flow-format
1-32
data-flow-format
1-59
data-size
NQA Commands
1-2
debugging
2-8
debugging
2-7
default
3-5
default cost
2-2
default cost
2-2
default cost
3-2
default ipv4-unicast
5-10
default local-preference
5-11
5-5
default med
5-12
default med
5-6
default-cost
3-6
default-cost
3-3
default-route imported
5-12
5-7
default-route originate
2-2
default-route-advertise
3-7
4-6
delete
1-2
delete
2-9
delete
SSH Commands
1-34
delete ipv6 static-routes all
1-1
delete static-routes all
1-1
delete-member
1-24
description
VLAN Commands
1-1
description
1-2
description
3-8
description
NQA Commands
1-2
description (for IPv4)
ACL Commands
1-8
description (for IPv6)
ACL Commands
1-23
destination
IPv6 Commands
3-2
destination ip
NQA Commands
1-3
destination port
NQA Commands
1-4
dhcp enable
DHCP Commands
1-2
dhcp enable
DHCP Commands
2-1
dhcp relay address-check
DHCP Commands
2-2
dhcp relay information enable
DHCP Commands
2-2
dhcp relay information format
DHCP Commands
2-3
dhcp relay information strategy
DHCP Commands
2-4
dhcp relay release
DHCP Commands
2-5
dhcp relay security static
DHCP Commands
2-5
dhcp relay security tracker
DHCP Commands
2-6
dhcp relay server-detect
DHCP Commands
2-7
dhcp relay server-group
DHCP Commands
2-8
dhcp relay server-select
DHCP Commands
2-9
dhcp select relay
DHCP Commands
2-9
dhcp select server global-pool
DHCP Commands
1-3
dhcp server detect
DHCP Commands
1-4
dhcp server forbidden-ip
DHCP Commands
1-4
dhcp server ip-pool
DHCP Commands
1-5
dhcp server ping packets
DHCP Commands
1-6
dhcp server ping timeout
DHCP Commands
1-7
dhcp server relay information enable
DHCP Commands
1-7
dhcp-snooping
DHCP Commands
4-1
dhcp-snooping information enable
DHCP Commands
4-2
dhcp-snooping information format
DHCP Commands
4-2
dhcp-snooping information strategy
DHCP Commands
4-3
dhcp-snooping trust
DHCP Commands
4-4
dir
1-3
dir
2-10
dir
SSH Commands
1-34
disconnect
2-11
display acl
ACL Commands
1-9
display acl ipv6
ACL Commands
1-24
display acl resource
ACL Commands
1-1
display arp
ARP Commands
1-3
display arp ip-address
ARP Commands
1-5
display arp timer aging
ARP Commands
1-6
display bgp group
5-13
display bgp ipv6 group
5-8
display bgp ipv6 network
5-9
display bgp ipv6 paths
5-10
display bgp ipv6 peer
5-11
display bgp ipv6 routing-table
5-12
display bgp ipv6 routing-table as-path-acl
5-14
display bgp ipv6 routing-table community
5-15
display bgp ipv6 routing-table community-list
5-16
display bgp ipv6 routing-table dampened
5-17
display bgp ipv6 routing-table dampening parameter
5-18
display bgp ipv6 routing-table different-origin-as
5-19
display bgp ipv6 routing-table flap-info
5-19
display bgp ipv6 routing-table peer
5-21
display bgp ipv6 routing-table regular-expression
5-22
display bgp ipv6 routing-table statistic
5-22
display bgp network
5-15
display bgp paths
5-16
display bgp peer
5-17
display bgp routing-table
5-19
display bgp routing-table as-path-acl
5-21
display bgp routing-table cidr
5-22
display bgp routing-table community
5-22
display bgp routing-table community-list
5-23
display bgp routing-table dampened
5-24
display bgp routing-table dampening parameter
5-25
display bgp routing-table different-origin-as
5-26
display bgp routing-table flap-info
5-26
display bgp routing-table peer
5-28
display bgp routing-table regular-expression
5-29
display bgp routing-table statistic
5-29
display boot-loader
3-5
display bootp client
DHCP Commands
5-1
display brief interface
1-3
display channel
Information Center Commands
1-1
display clipboard
1-6
display clock
1-7
display cluster
1-24
display cluster base-topology
1-26
display cluster black-list
1-27
display cluster candidates
1-28
display cluster current-topology
1-30
display cluster members
1-32
display connection
1-15
display cpu-usage
3-3
display current-configuration
1-8
display debugging
2-8
display device
3-6
display device manuinfo
3-7
display dhcp client
DHCP Commands
3-1
display dhcp relay
DHCP Commands
2-10
display dhcp relay security
DHCP Commands
2-11
display dhcp relay security statistics
DHCP Commands
2-12
display dhcp relay security tracker
DHCP Commands
2-12
display dhcp relay server-group
DHCP Commands
2-13
display dhcp relay statistics
DHCP Commands
2-14
display dhcp server conflict
DHCP Commands
1-8
display dhcp server expired
DHCP Commands
1-9
display dhcp server forbidden-ip
DHCP Commands
1-10
display dhcp server free-ip
DHCP Commands
1-10
display dhcp server ip-in-use
DHCP Commands
1-11
display dhcp server statistics
DHCP Commands
1-12
display dhcp server tree
DHCP Commands
1-14
display dhcp-snooping
DHCP Commands
4-5
display dhcp-snooping trust
DHCP Commands
4-6
display diagnostic-information
1-10
display dldp
DLDP Commands
1-1
display dldp statistics
DLDP Commands
1-3
display dns domain
DNS Commands
1-1
display dns dynamic-host
DNS Commands
1-2
display dns ipv6 dynamic-host
IPv6 Commands
1-1
display dns ipv6 server
IPv6 Commands
1-2
display dns proxy table
DNS Commands
1-3
display dns server
DNS Commands
1-4
display domain
1-16
display dot1x
MAC Authentication Commands
1-1
display environment
3-8
display fan
3-8
display fib
IP Addressing and IP Performance Commands
2-1
display fib ip-address
2-3
display fib statistics
2-4
display ftp client configuration
2-11
display ftp-server
2-1
display ftp-user
2-1
display garp statistics
VLAN Commands
3-1
display garp timer
VLAN Commands
3-2
display gvrp local-vlan interface
VLAN Commands
3-5
display gvrp state
VLAN Commands
3-6
display gvrp statistics
VLAN Commands
3-6
display gvrp status
VLAN Commands
3-8
display gvrp vlan-operation interface
VLAN Commands
3-8
display habp
3-1
display habp table
3-1
display habp traffic
3-2
display history-command
1-10
display hotkey
1-11
display hwtacacs
1-60
display icmp statistics
2-5
display igmp group
Multicast Commands
5-1
display igmp group port-info
Multicast Commands
5-3
display igmp interface
Multicast Commands
5-4
display igmp routing-table
Multicast Commands
5-6
display igmp-snooping group
Multicast Commands
1-1
display igmp-snooping statistics
Multicast Commands
1-2
display info-center
1-2
display interface
1-5
display interface tunnel
IPv6 Commands
3-3
display interface Vlan-interface
VLAN Commands
1-2
display ip as-path
6-10
display ip check source
IP Source Guard Commands
1-1
display ip community-list
6-11
display ip extcommunity-list
6-12
display ip host
DNS Commands
1-5
display ip https
HTTPS Commands
2-1
display ip interface
1-1
display ip interface brief
1-3
display ip ip-prefix
6-24
display ip ipv6-prefix
6-2
display ip relay-route
GR Overview Commands
1-1
display ip routing-table
1-2
display ip routing-table acl
1-8
display ip routing-table ip-address
1-9
display ip routing-table ip-prefix
1-12
display ip routing-table protocol
1-13
display ip routing-table statistics
1-15
display ip socket
2-6
display ip statistics
2-9
display ip-subnet-vlan interface
VLAN Commands
1-25
display ip-subnet-vlan vlan
VLAN Commands
1-26
display ipv6 fib
IPv6 Commands
1-3
display ipv6 host
IPv6 Commands
1-4
display ipv6 interface
IPv6 Commands
1-5
display ipv6 interface tunnel
IPv6 Commands
3-4
display ipv6 neighbors
IPv6 Commands
1-7
display ipv6 neighbors count
IPv6 Commands
1-9
display ipv6 pathmtu
IPv6 Commands
1-9
display ipv6 relay-route
1-16
display ipv6 routing-table
1-17
display ipv6 routing-table acl
1-18
display ipv6 routing-table ipv6-address
1-18
display ipv6 routing-table ipv6-address1 ipv6-address2
1-20
display ipv6 routing-table ipv6-prefix
1-21
display ipv6 routing-table protocol
1-22
display ipv6 routing-table statistics
1-22
display ipv6 routing-table verbose
1-23
display ipv6 socket
IPv6 Commands
1-10
display ipv6 statistics
IPv6 Commands
1-12
display isis brief
4-7
display isis graceful-restart status
4-8
display isis interface
4-10
display isis license
4-12
display isis lsdb
4-14
display isis mesh-group
4-15
display isis name-table
4-16
display isis peer
4-17
display isis route
4-19
display isis route ipv6
4-1
display isis spf-log
4-20
display isis statistics
4-22
display lacp system-id
Link Aggregation Commands
1-1
display link-aggregation interface
1-1
display link-aggregation service-type
1-3
display link-aggregation summary
1-4
display link-aggregation verbose
1-6
display lldp local-information
LLDP Commands
1-1
display lldp neighbor-information
LLDP Commands
1-6
display lldp statistics
LLDP Commands
1-12
display lldp status
LLDP Commands
1-13
display lldp tlv-config
LLDP Commands
1-15
display local-proxy-arp
ARP Commands
2-1
display local-user
1-18
display logbuffer
1-4
display logbuffer summary
1-7
display loopback-detection
1-8
display mac-address
MAC Address Table Management Commands
1-1
display mac-address aging-time
1-2
display mac-authentication
4-1
display mac-vlan
VLAN Commands
1-15
display mac-vlan interface
VLAN Commands
1-15
display memory
3-9
display mirroring-group
Port Mirroring Commands
1-1
display mld-snooping group
Multicast Commands
2-1
display mld-snooping statistics
Multicast Commands
2-2
display msdp brief
Multicast Commands
7-2
display msdp peer-status
Multicast Commands
7-3
display msdp sa-cache
Multicast Commands
7-5
display msdp sa-count
Multicast Commands
7-7
display multicast boundary
Multicast Commands
8-1
display multicast forwarding-table
Multicast Commands
8-2
display multicast routing-table
Multicast Commands
8-4
display multicast routing-table static
Multicast Commands
8-6
display multicast rpf-info
Multicast Commands
8-7
display multicast-vlan
Multicast Commands
3-1
display multicast-vlan ipv6
Multicast Commands
4-1
display ndp
1-1
display nqa
NQA Commands
1-4
display nqa server status
NQA Commands
1-29
display ntdp
1-7
display ntdp device-list
1-8
display ntdp single-device mac-address
1-10
display ntp-service sessions
NTP Commands
1-1
display ntp-service status
NTP Commands
1-3
display ntp-service trace
NTP Commands
1-4
display ospf abr-asbr
3-9
display ospf asbr-summary
3-10
display ospf brief
3-11
display ospf cumulative
3-14
display ospf error
3-16
display ospf interface
3-18
display ospf lsdb
3-19
display ospf nexthop
3-21
display ospf peer
3-22
display ospf peer statistics
3-25
display ospf request-queue
3-26
display ospf retrans-queue
3-27
display ospf routing
3-29
display ospf vlink
3-30
display ospfv3
3-4
display ospfv3 interface
3-6
display ospfv3 lsdb
3-7
display ospfv3 lsdb statistic
3-10
display ospfv3 next-hop
3-11
display ospfv3 peer
3-12
display ospfv3 peer statistic
3-14
display ospfv3 request-list
3-15
display ospfv3 retrans-list
3-17
display ospfv3 routing
3-19
display ospfv3 statistic
3-20
display ospfv3 topology
3-21
display ospfv3 vlink
3-22
display pim bsr-info
Multicast Commands
6-12
display pim claimed-route
Multicast Commands
6-14
display pim control-message counters
Multicast Commands
6-15
display pim grafts
Multicast Commands
6-17
display pim interface
Multicast Commands
6-18
display pim join-prune
Multicast Commands
6-20
display pim neighbor
Multicast Commands
6-21
display pim routing-table
Multicast Commands
6-23
display pim rp-info
Multicast Commands
6-26
display pki certificate
PKI Commands
1-10
display pki certificate access-control-policy
PKI Commands
1-11
display pki certificate attribute-group
PKI Commands
1-12
display pki crl domain
PKI Commands
1-13
display poe device
PoE Commands
1-3
display poe interface
PoE Commands
1-3
display poe interface power
PoE Commands
1-7
display poe pse
PoE Commands
1-9
display poe-profile
PoE Commands
1-11
display poe-profile interface
PoE Commands
1-13
display port combo
1-9
display port-group manual
1-10
display port-isolate group
2-1
display port-security
Port Security Commands
1-1
display port-security mac-address block
1-3
display port-security mac-address security
1-4
display power
3-10
display protocol-vlan interface
VLAN Commands
1-19
display protocol-vlan vlan
VLAN Commands
1-20
display proxy-arp
ARP Commands
2-1
display public-key local
SSH Commands
1-1
display public-key peer
SSH Commands
1-3
display qos lr interface
QoS Commands
1-1
display qos map-table
QoS Commands
4-1
display qos policy
QoS Commands
2-19
display qos policy interface
QoS Commands
2-20
display qos sp interface
QoS Commands
3-1
display qos trust interface
QoS Commands
4-4
display qos vlan-policy
QoS Commands
5-1
display qos wrr interface
QoS Commands
3-1
display radius scheme
1-33
display radius statistics
1-35
display reboot-type
3-10
display rip
2-3
display rip database
2-5
display rip interface
2-6
display rip route
2-7
display ripng
2-2
display ripng database
2-4
display ripng interface
2-5
display ripng route
2-6
display rmon alarm
RMON Commands
2-1
display rmon event
RMON Commands
2-2
display rmon eventlog
RMON Commands
2-3
display rmon history
RMON Commands
2-4
display rmon prialarm
RMON Commands
2-6
display rmon statistics
RMON Commands
2-7
display route-policy
6-12
display rrpp brief
RRPP Commands
1-1
display rrpp statistics
RRPP Commands
1-3
display rrpp verbose
RRPP Commands
1-6
display saved-configuration
1-12
display schedule reboot
3-11
display sflow
sFlow Commands
1-1
display sftp client source
SSH Commands
1-4
display snmp-agent community
RMON Commands
1-1
display snmp-agent group
RMON Commands
1-2
display snmp-agent local-engineid
RMON Commands
1-1
display snmp-agent mib-view
RMON Commands
1-3
display snmp-agent statistics
RMON Commands
1-5
display snmp-agent sys-info
RMON Commands
1-7
display snmp-agent trap-list
RMON Commands
1-8
display snmp-agent usm-user
RMON Commands
1-9
display ssh client source
SSH Commands
1-5
display ssh server
SSH Commands
1-5
display ssh server-info
SSH Commands
1-7
display ssh user-information
SSH Commands
1-8
display ssl client-policy
HTTPS Commands
1-3
display ssl server-policy
HTTPS Commands
1-4
display startup
1-17
display stop-accounting-buffer
1-38
1-62
display storm-constrain
1-11
display stp
MSTP Commands
1-3
display stp abnormal-port
MSTP Commands
1-5
display stp down-port
MSTP Commands
1-6
display stp history
MSTP Commands
1-7
display stp region-configuration
MSTP Commands
1-8
display stp root
MSTP Commands
1-9
display stp tc
MSTP Commands
1-10
display tcp ipv6 statistics
IPv6 Commands
1-16
display tcp ipv6 status
IPv6 Commands
1-19
display tcp statistics
2-10
display tcp status
2-13
display telnet client configuration
Login Commands
1-5
display tftp client configuration
3-1
display this
1-13
display time-range
ACL Commands
1-2
display track
Track Commands
1-1
display traffic behavior
QoS Commands
2-8
display traffic classifier
QoS Commands
2-1
display transceiver alarm interface
3-11
display transceiver diagnosis interface
3-14
display transceiver interface
3-16
display transceiver manuinfo interface
3-17
display trapbuffer
1-8
display udp ipv6 statistics
IPv6 Commands
1-20
display udp statistics
2-14
display udp-helper server
UDP Helper Commands
1-1
display user-bind
1-2
display user-interface
Login Commands
1-6
display users
Login Commands
1-7
display version
1-13
display vlan
VLAN Commands
1-3
display voice vlan oui
VLAN Commands
2-1
display voice vlan state
VLAN Commands
2-2
display vrrp
VRRP Commands
1-1
display vrrp ipv6
VRRP Commands
1-15
display vrrp ipv6 statistics
VRRP Commands
1-17
display vrrp statistics
VRRP Commands
1-3
display web users
Login Commands
1-9
dldp authentication-mode
DLDP Commands
1-4
dldp delaydown-timer
DLDP Commands
1-5
dldp enable
DLDP Commands
1-6
dldp interval
DLDP Commands
1-7
dldp reset
DLDP Commands
1-8
dldp unidirectional-shutdown
DLDP Commands
1-9
dldp work-mode
DLDP Commands
1-9
dns domain
DNS Commands
1-5
dns proxy enable
DNS Commands
1-6
dns resolve
DNS Commands
1-7
dns server
DNS Commands
1-7
dns server ipv6
IPv6 Commands
1-21
dns-list
DHCP Commands
1-15
domain
1-19
domain default
1-20
domain-authentication-mode
4-23
domain-name
DHCP Commands
1-16
dot1x
1-4
dot1x authentication-method
1-5
dot1x free-ip
2-1
dot1x guest-vlan
1-6
dot1x handshake
1-8
dot1x max-user
1-9
dot1x multicast-trigger
1-10
dot1x port-control
1-10
dot1x port-method
1-12
dot1x quiet-period
1-13
dot1x retry
1-13
dot1x timer
1-14
dot1x timer ead-timeout
2-2
dot1x url
2-2
duplex
1-12
E
ebgp-interface-sensitive
5-30
enable link-local-signaling
3-31
enable log
3-32
enable out-of-band-resynchronization
3-32
enable snmp trap updown
RMON Commands
1-10
encap-data-enable
Multicast Commands
7-8
escape-key
Login Commands
1-9
execute
1-4
exit
SSH Commands
1-35
expired
DHCP Commands
1-17
F
fast-leave
Multicast Commands
1-3
fast-leave
Multicast Commands
2-3
fast-leave
Multicast Commands
5-7
file prompt
1-5
filename
NQA Commands
1-8
filter
3-33
filter
QoS Commands
2-9
filter-policy export
2-10
3-34
4-24
5-31
2-7
3-24
5-23
filter-policy import
2-11
3-35
4-26
5-32
2-8
3-25
5-24
fixdisk
1-5
flash-flood
4-26
flow-control
Login Commands
1-11
flow-control
1-13
flow-interval
1-14
format
1-6
fqdn
PKI Commands
1-15
free ftp user
2-2
free user-interface
Login Commands
1-11
free web-users
Login Commands
2-2
frequency
NQA Commands
1-9
ftp
2-12
ftp client source
2-13
ftp ipv6
2-14
ftp server enable
2-3
ftp timeout
2-3
ftp update
2-4
ftp-server
1-34
G
garp timer
VLAN Commands
3-2
garp timer leaveall
VLAN Commands
3-4
gateway-list
DHCP Commands
1-17
get
2-16
get
SSH Commands
1-36
graceful-restart
3-36
graceful-restart
4-27
graceful-restart
5-32
graceful-restart help
3-37
graceful-restart interval
3-37
4-28
graceful-restart suppress-sa
4-28
graceful-restart timer restart
5-33
graceful-restart timer wait-for-rib
5-33
gratuitous-arp-learning enable
ARP Commands
1-7
gratuitous-arp-sending enable
ARP Commands
1-7
group
5-34
group
5-25
group-member
1-14
group-policy
Multicast Commands
1-4
group-policy
Multicast Commands
2-4
gvrp
VLAN Commands
3-9
gvrp registration
VLAN Commands
3-10
H
habp enable
3-3
habp server vlan
3-4
habp timer
3-4
handshake timeout
HTTPS Commands
1-5
header
1-14
hello-option dr-priority
Multicast Commands
6-27
hello-option holdtime
Multicast Commands
6-28
hello-option lan-delay
Multicast Commands
6-28
hello-option neighbor-tracking
Multicast Commands
6-29
hello-option override-interval
Multicast Commands
6-30
help
SSH Commands
1-36
history-command max-size
Login Commands
1-12
history-records
NQA Commands
1-10
holdtime
1-35
holdtime assert
Multicast Commands
6-30
holdtime join-prune
Multicast Commands
6-31
host-advertise
3-38
host-aging-time
Multicast Commands
1-5
host-aging-time
Multicast Commands
2-5
host-route
2-11
hotkey
1-16
http-version
NQA Commands
1-11
hwtacacs nas-ip
1-62
hwtacacs scheme
1-63
I
idle-cut
1-21
idle-timeout
Login Commands
1-13
if-match
QoS Commands
2-2
if-match acl
6-25
if-match as-path
6-13
if-match community
6-14
if-match cost
6-15
if-match extcommunity
6-16
if-match interface
6-16
if-match ip
6-26
if-match ip-prefix
6-26
if-match ipv6
6-3
if-match route-type
6-17
if-match tag
6-18
igmp
Multicast Commands
5-8
igmp enable
Multicast Commands
5-9
igmp fast-leave
Multicast Commands
5-9
igmp group-policy
Multicast Commands
5-10
igmp last-member-query-interval
Multicast Commands
5-12
igmp max-response-time
Multicast Commands
5-12
igmp require-router-alert
Multicast Commands
5-13
igmp robust-count
Multicast Commands
5-14
igmp send-router-alert
Multicast Commands
5-14
igmp static-group
Multicast Commands
5-15
igmp timer other-querier-present
Multicast Commands
5-16
igmp timer query
Multicast Commands
5-17
igmp version
Multicast Commands
5-18
igmp-snooping
Multicast Commands
1-6
igmp-snooping drop-unknown
Multicast Commands
1-7
igmp-snooping enable
Multicast Commands
1-7
igmp-snooping fast-leave
Multicast Commands
1-8
igmp-snooping general-query source-ip
Multicast Commands
1-9
igmp-snooping group-limit
Multicast Commands
1-10
igmp-snooping group-policy
Multicast Commands
1-11
igmp-snooping host-aging-time
Multicast Commands
1-12
igmp-snooping host-join
Multicast Commands
1-13
igmp-snooping last-member-query-interval
Multicast Commands
1-14
igmp-snooping max-response-time
Multicast Commands
1-15
igmp-snooping overflow-replace
Multicast Commands
1-16
igmp-snooping querier
Multicast Commands
1-17
igmp-snooping query-interval
Multicast Commands
1-18
igmp-snooping router-aging-time
Multicast Commands
1-18
igmp-snooping source-deny
Multicast Commands
1-19
igmp-snooping special-query source-ip
Multicast Commands
1-20
igmp-snooping static-group
Multicast Commands
1-21
igmp-snooping static-router-port
Multicast Commands
1-22
igmp-snooping version
Multicast Commands
1-23
import
QoS Commands
4-3
import-route
2-12
import-route
3-39
import-route
4-29
import-route
5-35
import-route
2-9
import-route
3-26
import-route
5-25
import-route isis level-2 into level-1
4-31
import-source
Multicast Commands
7-9
info-center channel name
1-9
info-center console channel
1-10
info-center enable
1-11
info-center logbuffer
1-11
info-center loghost
1-12
info-center loghost source
1-13
info-center monitor channel
1-14
info-center snmp channel
1-15
info-center source
1-16
info-center synchronous
1-18
info-center timestamp
1-19
info-center timestamp loghost
1-20
info-center trapbuffer
1-21
instance
MSTP Commands
1-11
interface
1-15
interface tunnel
IPv6 Commands
3-6
VLAN Commands
1-4
ip
PKI Commands
1-15
ip address
VLAN Commands
1-5
ip address
1-4
ip address bootp-alloc
DHCP Commands
5-2
ip address dhcp-alloc
DHCP Commands
3-3
ip as-path
6-19
ip check source
1-3
ip community-list
6-20
6-21
ip forward-broadcast (interface view)
2-15
ip forward-broadcast (system view)
2-16
ip host
DNS Commands
1-8
ip http acl
Login Commands
2-2
ip http enable
Login Commands
1-14
ip https acl
HTTPS Commands
2-2
ip https certificate access-control-policy
HTTPS Commands
2-2
ip https enable
HTTPS Commands
2-3
ip https ssl-server-policy
HTTPS Commands
2-4
ip ip-prefix
6-27
ip ipv6-prefix
6-3
ip redirects enable
2-16
ip route-static
1-2
ip route-static default-preference
1-3
ip rpf-route-static
Multicast Commands
8-9
ip ttl-expires enable
2-17
ip unreachables enable
2-18
ip-pool
1-36
ip-subnet-vlan
VLAN Commands
1-27
ipv6
IPv6 Commands
1-22
ipv6
IPv6 Commands
2-1
ipv6 address
IPv6 Commands
1-22
ipv6 address
IPv6 Commands
2-1
ipv6 address auto link-local
IPv6 Commands
1-23
IPv6 Commands
2-2
ipv6 address eui-64
IPv6 Commands
1-24
ipv6 address eui-64
IPv6 Commands
2-3
ipv6 address link-local
IPv6 Commands
1-24
IPv6 Commands
2-3
ipv6 default-route-advertise
4-3
ipv6 enable
4-4
ipv6 filter-policy export
4-5
ipv6 filter-policy import
4-6
ipv6 host
IPv6 Commands
1-25
ipv6 icmp-error
IPv6 Commands
1-26
IPv6 Commands
1-26
ipv6 import-route
4-7
ipv6 import-route isisv6 level-2 into level-1
4-8
ipv6 maximum load-balancing
4-9
IPv6 Commands
1-27
ipv6 nd autoconfig other-flag
IPv6 Commands
1-28
ipv6 nd dad attempts
IPv6 Commands
1-28
ipv6 nd hop-limit
IPv6 Commands
1-29
ipv6 nd ns retrans-timer
IPv6 Commands
1-30
ipv6 nd nud reachable-time
IPv6 Commands
1-30
ipv6 nd ra halt
IPv6 Commands
1-31
ipv6 nd ra interval
IPv6 Commands
1-32
ipv6 nd ra prefix
IPv6 Commands
1-32
ipv6 nd ra router-lifetime
IPv6 Commands
1-33
ipv6 neighbor
IPv6 Commands
1-34
ipv6 neighbors max-learning-num
IPv6 Commands
1-35
ipv6 pathmtu
IPv6 Commands
1-36
ipv6 pathmtu age
IPv6 Commands
1-36
ipv6 preference
4-10
ipv6 route-static
1-2
ipv6 summary
4-11
ipv6-family
5-26
isis
4-32
isis authentication-mode
4-33
isis circuit-level
4-34
isis circuit-type
4-35
isis cost
4-36
isis dis-name
4-36
isis dis-priority
4-37
isis enable
4-38
isis ipv6 enable
4-12
isis mesh-group
4-39
isis silent
4-40
isis small-hello
4-41
isis timer csnp
4-41
isis timer hello
4-42
isis timer holding-multiplier
4-43
isis timer lsp
4-45
isis timer retransmit
4-45
is-level
4-46
is-name
4-47
is-name map
4-48
is-snmp-traps enable
4-48
J
jp-pkt-size
Multicast Commands
6-32
jp-queue-size
Multicast Commands
6-32
jumboframe enable
1-16
K
key
1-39
key
1-64
L
lacp port-priority
1-8
lacp system-priority
1-8
last-listener-query-interval
Multicast Commands
2-6
Multicast Commands
1-23
Multicast Commands
5-18
lcd
2-16
ldap-server
PKI Commands
1-16
level
1-22
link-aggregation group description
1-9
link-aggregation group mode
1-9
link-aggregation group service-type
1-10
link-delay
1-16
lldp admin-status
LLDP Commands
1-17
lldp check-change-interval
LLDP Commands
1-18
lldp enable
LLDP Commands
1-19
lldp fast-count
LLDP Commands
1-20
lldp hold-multiplier
LLDP Commands
1-20
lldp management-address-tlv
LLDP Commands
1-21
lldp notification remote-change enable
LLDP Commands
1-22
lldp timer notification-interval
LLDP Commands
1-22
lldp timer reinit-delay
LLDP Commands
1-23
lldp timer tx-delay
LLDP Commands
1-23
lldp timer tx-interval
LLDP Commands
1-24
lldp tlv-enable
LLDP Commands
1-25
locality
PKI Commands
1-16
local-proxy-arp enable
ARP Commands
2-2
local-user
1-23
local-user password-display-mode
1-24
lock
Login Commands
1-14
logging-host
1-37
log-peer-change
3-40
log-peer-change
4-49
log-peer-change
5-36
log-peer-change
3-27
loopback
1-17
loopback-detection control enable
1-18
loopback-detection enable
1-19
loopback-detection interval-time
1-20
loopback-detection per-vlan enable
1-21
ls
2-17
ls
SSH Commands
1-37
lsa-arrival-interval
3-41
lsa-generation-interval
3-42
lsdb-overflow-limit
3-42
lsp-fragments-extend
4-50
lsp-length originate
4-51
lsp-length receive
4-51
M
mac-address (Ethernet port view)
1-3
mac-address (System view)
1-4
mac-address max-mac-count
1-5
mac-address timer
1-6
mac-authentication
4-3
mac-authentication domain
4-4
mac-authentication timer
4-5
mac-authentication user-name-format
4-6
mac-vlan enable
VLAN Commands
1-18
mac-vlan mac-address
VLAN Commands
1-17
management-vlan
1-38
2-14
3-43
4-52
2-10
3-28
maximum-routes
3-44
max-response-time
Multicast Commands
1-24
max-response-time
Multicast Commands
2-6
max-response-time
Multicast Commands
5-19
mdi
1-21
mirroring-group
1-2
mirroring-group mirroring-port
1-3
mirroring-group monitor-egress
1-4
mirroring-group monitor-port
1-5
mirroring-group remote-probe vlan
1-6
mirroring-port
1-7
mirror-to
QoS Commands
6-1
mkdir
1-7
mkdir
2-18
mkdir
SSH Commands
1-38
mld-snooping
Multicast Commands
2-7
mld-snooping drop-unknown
Multicast Commands
2-8
mld-snooping enable
Multicast Commands
2-8
mld-snooping fast-leave
Multicast Commands
2-9
mld-snooping general-query source-ip
Multicast Commands
2-10
mld-snooping group-limit
Multicast Commands
2-11
mld-snooping group-policy
Multicast Commands
2-12
mld-snooping host-aging-time
Multicast Commands
2-13
mld-snooping host-join
Multicast Commands
2-14
mld-snooping last-listener-query-interval
Multicast Commands
2-15
mld-snooping max-response-time
Multicast Commands
2-16
mld-snooping overflow-replace
Multicast Commands
2-17
mld-snooping querier
Multicast Commands
2-18
mld-snooping query-interval
Multicast Commands
2-18
mld-snooping router-aging-time
Multicast Commands
2-19
mld-snooping source-deny
Multicast Commands
2-20
mld-snooping special-query source-ip
Multicast Commands
2-20
mld-snooping static-group
Multicast Commands
2-21
mld-snooping static-router-port
Multicast Commands
2-23
mld-snooping version
Multicast Commands
2-23
monitor-port
1-8
more
1-7
move
1-8
msdp
Multicast Commands
7-10
mtracert
Multicast Commands
8-10
mtu (tunnel interface view)
IPv6 Commands
3-6
multicast boundary
Multicast Commands
8-12
multicast forwarding-table downstream-limit
Multicast Commands
8-13
multicast forwarding-table route-limit
Multicast Commands
8-14
multicast load-splitting
Multicast Commands
8-15
multicast longest-match
Multicast Commands
8-15
multicast routing-enable
Multicast Commands
8-16
multicast-suppression
1-22
multicast-vlan enable
Multicast Commands
3-1
multicast-vlan ipv6 enable
Multicast Commands
4-1
multicast-vlan ipv6 subvlan
Multicast Commands
4-2
multicast-vlan subvlan
Multicast Commands
3-2
N
nas-ip
1-40
nas-ip
1-65
nbns-list
DHCP Commands
1-18
ndp enable
1-4
ndp timer aging
1-5
ndp timer hello
1-6
nest
QoS Commands
2-10
netbios-type
DHCP Commands
1-19
network
2-14
network
3-44
network
5-37
network
5-27
network
DHCP Commands
1-20
network-entity
4-53
next-hop
NQA Commands
1-11
nm-interface vlan-interface
1-39
nqa
NQA Commands
1-12
nqa agent enable
NQA Commands
1-13
nqa agent max-concurrent
NQA Commands
1-13
nqa schedule
NQA Commands
1-14
nqa server enable
NQA Commands
1-30
nqa server tcp-connect
NQA Commands
1-31
nqa server udp-echo
NQA Commands
1-32
nssa
3-45
ntdp enable
1-11
ntdp explore
1-12
ntdp hop
1-13
ntdp timer
1-14
ntdp timer hop-delay
1-14
ntdp timer port-delay
1-15
ntp-service access
NTP Commands
1-5
ntp-service authentication enable
NTP Commands
1-6
ntp-service authentication-keyid
NTP Commands
1-7
ntp-service broadcast-client
NTP Commands
1-8
ntp-service broadcast-server
NTP Commands
1-9
ntp-service in-interface disable
NTP Commands
1-9
ntp-service max-dynamic-sessions
NTP Commands
1-10
ntp-service multicast-client
NTP Commands
1-11
ntp-service multicast-server
NTP Commands
1-11
ntp-service reliable authentication-keyid
NTP Commands
1-12
ntp-service source-interface
NTP Commands
1-13
ntp-service unicast-peer
NTP Commands
1-14
ntp-service unicast-server
NTP Commands
1-15
O
opaque-capability enable
3-46
open
2-19
open ipv6
2-19
operation (FTP test type view)
NQA Commands
1-15
operation (HTTP test type view)
NQA Commands
1-15
operation interface
NQA Commands
1-16
option
DHCP Commands
1-21
organization
PKI Commands
1-17
organizational-unit
PKI Commands
1-18
originating-rp
Multicast Commands
7-11
ospf
3-47
ospf authentication-mode
3-47
ospf cost
3-49
ospf dr-priority
3-50
ospf mib-binding
3-50
ospf mtu-enable
3-51
ospf network-type
3-52
ospf timer dead
3-53
ospf timer hello
3-54
ospf timer poll
3-54
ospf timer retransmit
3-55
ospf trans-delay
3-56
ospfv3
3-29
ospfv3 area
3-29
ospfv3 cost
3-30
ospfv3 dr-priority
3-31
ospfv3 mtu-ignore
3-31
ospfv3 timer dead
3-32
ospfv3 timer hello
3-33
ospfv3 timer retransmit
3-34
ospfv3 trans-delay
3-34
overflow-replace
Multicast Commands
1-25
overflow-replace
Multicast Commands
2-24
P
parity
Login Commands
1-15
passive
2-20
password
1-24
password
NQA Commands
1-17
peer
2-15
peer
3-57
peer advertise-community
5-38
5-28
peer advertise-ext-community
5-38
5-28
peer allow-as-loop
5-39
peer allow-as-loop
5-29
peer as-number
5-40
peer as-number
5-30
peer as-path-acl
5-40
peer as-path-acl
5-30
peer capability-advertise conventional
5-41
peer capability-advertise route-refresh
5-42
5-31
peer connect-interface
5-43
5-32
Multicast Commands
7-11
peer default-route-advertise
5-43
5-33
peer description
5-44
peer description
5-34
peer description
Multicast Commands
7-12
peer ebgp-max-hop
5-45
peer ebgp-max-hop
5-34
peer enable
5-46
peer fake-as
5-46
peer fake-as
5-35
peer filter-policy
5-47
peer filter-policy
5-36
peer group
5-48
peer group
5-37
peer ignore
5-49
peer ignore
5-37
peer ip-prefix
5-49
peer ipv6-prefix
5-38
peer keep-all-routes
5-50
5-39
peer log-change
5-51
peer log-change
5-40
peer mesh-group
Multicast Commands
7-13
peer minimum-ttl
Multicast Commands
7-13
peer next-hop-local
5-51
peer next-hop-local
5-40
peer password
5-52
peer preferred-value
5-53
5-41
peer public-as-only
5-54
peer public-as-only
5-42
peer reflect-client
5-55
peer reflect-client
5-43
peer request-sa-enable
Multicast Commands
7-14
peer route-limit
5-55
peer route-limit
5-43
peer route-policy
5-56
peer route-policy
5-44
peer route-update-interval
5-57
5-45
peer sa-cache-maximum
Multicast Commands
7-15
peer sa-policy
Multicast Commands
7-16
peer sa-request-policy
Multicast Commands
7-17
peer substitute-as
5-58
peer substitute-as
5-46
peer timer
5-58
peer timer
5-47
peer-public-key end
SSH Commands
1-8
pim
Multicast Commands
6-33
pim bsr-boundary
Multicast Commands
6-34
pim dm
Multicast Commands
6-35
pim hello-option dr-priority
Multicast Commands
6-35
pim hello-option holdtime
Multicast Commands
6-36
pim hello-option lan-delay
Multicast Commands
6-37
pim hello-option neighbor-tracking
Multicast Commands
6-37
pim hello-option override-interval
Multicast Commands
6-38
pim holdtime assert
Multicast Commands
6-39
pim holdtime join-prune
Multicast Commands
6-39
pim require-genid
Multicast Commands
6-40
pim sm
Multicast Commands
6-41
pim state-refresh-capable
Multicast Commands
6-41
pim timer graft-retry
Multicast Commands
6-42
pim timer hello
Multicast Commands
6-42
pim timer join-prune
Multicast Commands
6-43
pim triggered-hello-delay
Multicast Commands
6-44
ping
2-1
ping ipv6
2-3
PKI Commands
1-18
PKI Commands
1-19
pki delete-certificate
PKI Commands
1-20
pki domain
PKI Commands
1-20
pki entity
PKI Commands
1-21
pki import-certificate
PKI Commands
1-22
pki request-certificate domain
PKI Commands
1-22
pki retrieval-certificate
PKI Commands
1-23
pki retrieval-crl domain
PKI Commands
1-24
pki validate-certificate
PKI Commands
1-24
pki-domain
HTTPS Commands
1-6
poe disconnect
PoE Commands
1-14
poe enable
PoE Commands
1-15
poe legacy enable
PoE Commands
1-16
poe max-power
PoE Commands
1-16
poe mode
PoE Commands
1-17
poe pd-description
PoE Commands
1-18
poe pd-policy priority
PoE Commands
1-19
poe priority
PoE Commands
1-19
poe update
PoE Commands
1-21
poe utilization-threshold
PoE Commands
1-21
poe-profile
PoE Commands
1-22
port
VLAN Commands
1-8
port access vlan
VLAN Commands
1-9
port hybrid ip-subnet-vlan vlan
VLAN Commands
1-28
port hybrid protocol-vlan
VLAN Commands
1-21
port hybrid pvid vlan
VLAN Commands
1-10
port hybrid vlan
VLAN Commands
1-11
port link-aggregation group
1-11
port link-type
VLAN Commands
1-12
port trunk permit vlan
VLAN Commands
1-13
port trunk pvid vlan
VLAN Commands
1-14
port-group
1-24
port-group aggregation
1-12
port-isolate enable
2-2
port-security authorization ignore
1-6
port-security enable
1-7
port-security intrusion-mode
1-8
1-9
port-security max-mac-count
1-10
port-security ntk-mode
1-11
port-security oui
1-11
port-security port-mode
1-12
port-security timer disableport
1-14
port-security trap
1-14
prefer-cipher
HTTPS Commands
1-6
preference
2-16
preference
3-57
preference
4-54
preference
5-59
preference
2-10
preference
3-35
preference
5-48
primary accounting
1-41
primary accounting
1-66
primary authentication
1-42
1-67
primary authorization
1-67
probe count
NQA Commands
1-17
probe packet-interval
NQA Commands
1-18
probe packet-number
NQA Commands
1-19
probe packet-timeout
NQA Commands
1-19
probe timeout
NQA Commands
1-20
probe-interval
Multicast Commands
6-44
protocol inbound
Login Commands
1-16
protocol-vlan
VLAN Commands
1-22
proxy-arp enable
ARP Commands
2-2
public-key local create
SSH Commands
1-11
public-key local destroy
SSH Commands
1-12
public-key local export dsa
SSH Commands
1-14
public-key local export rsa
SSH Commands
1-13
public-key peer
SSH Commands
1-15
public-key peer import sshkey
SSH Commands
1-16
public-key-code begin
SSH Commands
1-9
public-key-code end
SSH Commands
1-10
put
2-21
put
SSH Commands
1-38
pwd
1-8
pwd
2-21
pwd
SSH Commands
1-39
Q
qinq enable
1-2
qinq ethernet-type
1-2
qinq vid
1-3
qos apply policy
QoS Commands
2-21
qos lr outbound
QoS Commands
1-2
qos map-table
QoS Commands
4-2
qos policy
QoS Commands
2-22
qos priority
QoS Commands
4-3
qos sp
QoS Commands
3-3
qos trust
QoS Commands
4-5
qos vlan-policy
QoS Commands
5-2
qos wrr
QoS Commands
3-3
2-22
1-18
SSH Commands
1-39
R
radius client
1-43
radius nas-ip
1-43
radius scheme
1-44
radius trap
1-45
raw-vlan-id inbound
1-1
reaction
NQA Commands
1-21
reaction trap
NQA Commands
1-22
reboot
3-18
reboot member
1-39
redirect
QoS Commands
2-11
reflect between-clients
5-60
5-48
reflector cluster-id
5-61
5-49
refresh bgp
5-61
refresh bgp ipv6
5-50
region-name
MSTP Commands
1-12
register-policy
Multicast Commands
6-45
register-suppression-timeout
Multicast Commands
6-46
register-whole-checksum
Multicast Commands
6-46
remark customer-vlan-id
QoS Commands
2-12
remark dot1p
QoS Commands
2-12
remark drop-precedence
QoS Commands
2-13
remark dscp
QoS Commands
2-14
remark ip-precedence
QoS Commands
2-15
remark local-precedence
QoS Commands
2-16
remark service-vlan-id
QoS Commands
2-16
remotehelp
2-22
remove
SSH Commands
1-40
rename
1-9
rename
SSH Commands
1-41
report-aggregation
Multicast Commands
1-26
report-aggregation
Multicast Commands
2-25
Multicast Commands
5-20
reset acl counter
ACL Commands
1-10
reset acl ipv6 counter
ACL Commands
1-25
reset arp
ARP Commands
1-6
reset bgp
5-62
reset bgp dampening
5-63
reset bgp flap-info
5-63
reset bgp ipv4 all
5-64
reset bgp ipv6
5-51
reset bgp ipv6 dampening
5-51
reset bgp ipv6 flap-info
5-52
reset counters interface
1-24
reset dhcp relay statistics
DHCP Commands
2-15
reset dhcp server conflict
DHCP Commands
1-21
reset dhcp server ip-in-use
DHCP Commands
1-22
reset dhcp server statistics
DHCP Commands
1-23
reset dhcp-snooping
DHCP Commands
4-7
reset dldp statistics
DLDP Commands
1-10
reset dns dynamic-host
DNS Commands
1-9
reset dns ipv6 dynamic-host
IPv6 Commands
1-37
reset dot1x statistics
1-16
reset garp statistics
VLAN Commands
3-5
reset hwtacacs statistics
1-68
reset igmp group
Multicast Commands
5-20
reset igmp group port-info
Multicast Commands
5-22
reset igmp-snooping group
Multicast Commands
1-26
reset igmp-snooping statistics
Multicast Commands
1-27
reset ip ip-prefix
6-29
reset ip ipv6-prefix
6-5
reset ip routing-table statistics protocol
1-25
reset ip statistics
2-18
reset ipv6 neighbors
IPv6 Commands
1-38
reset ipv6 pathmtu
IPv6 Commands
1-38
reset ipv6 routing-table statistics
1-25
reset ipv6 statistics
IPv6 Commands
1-39
reset isis all
4-54
reset isis peer
4-55
reset lacp statistics
1-12
reset logbuffer
1-22
reset mac-authentication statistics
4-7
reset mld-snooping group
Multicast Commands
2-26
reset mld-snooping statistics
Multicast Commands
2-26
reset msdp peer
Multicast Commands
7-17
reset msdp sa-cache
Multicast Commands
7-18
reset msdp statistics
Multicast Commands
7-19
reset multicast forwarding-table
Multicast Commands
8-17
reset multicast routing-table
Multicast Commands
8-18
reset ndp statistics
1-6
reset ospf counters
3-58
reset ospf process
3-59
reset ospf redistribution
3-60
reset pim control-message counters
Multicast Commands
6-47
reset qos vlan-policy
QoS Commands
5-3
reset radius statistics
1-46
reset recycle-bin
1-10
reset rip statistics
2-16
reset rrpp statistics
RRPP Commands
1-8
reset saved-configuration
1-17
reset stop-accounting-buffer
1-47
1-69
reset stp
MSTP Commands
1-12
reset tcp ipv6 statistics
IPv6 Commands
1-39
reset tcp statistics
2-19
reset trapbuffer
1-22
reset udp ipv6 statistics
IPv6 Commands
1-40
reset udp statistics
2-19
reset udp-helper packet
UDP Helper Commands
1-1
reset unused porttag
3-19
reset vrrp ipv6 statistics
VRRP Commands
1-19
reset vrrp statistics
VRRP Commands
1-5
restore startup-configuration
1-18
retry
1-47
retry realtime-accounting
1-48
retry stop-accounting
1-49
1-69
return
1-18
revision-level
MSTP Commands
1-13
rfc1583 compatible
3-60
ring
RRPP Commands
1-9
ring enable
RRPP Commands
1-12
rip
2-17
rip authentication-mode
2-18
rip input
2-19
rip metricin
2-19
rip metricout
2-20
rip output
2-21
rip poison-reverse
2-22
rip split-horizon
2-23
rip summary-address
2-23
rip version
2-24
ripng
2-11
ripng default-route
2-12
ripng enable
2-13
ripng metricin
2-13
ripng metricout
2-14
ripng poison-reverse
2-15
ripng split-horizon
2-15
ripng summary-address
2-16
rmdir
1-10
rmdir
2-25
rmdir
SSH Commands
1-41
rmon alarm
RMON Commands
2-9
rmon event
RMON Commands
2-11
rmon history
RMON Commands
2-13
rmon prialarm
RMON Commands
2-14
rmon statistics
RMON Commands
2-16
robust-count
Multicast Commands
5-22
root-certificate fingerprint
PKI Commands
1-25
route-option bypass-route
NQA Commands
1-23
route-policy
6-22
router-aging-time
Multicast Commands
1-28
router-aging-time
Multicast Commands
2-27
router-id
5-65
router-id
3-36
router-id
5-53
rrpp domain
RRPP Commands
1-13
rrpp enable
RRPP Commands
1-13
rule
PKI Commands
1-26
rule (in advanced IPv4 ACL view)
ACL Commands
1-12
rule (in advanced IPv6 ACL view)
ACL Commands
1-27
rule (in basic IPv4 ACL view)
ACL Commands
1-11
rule (in basic IPv6 ACL view)
ACL Commands
1-26
rule (in Ethernet frame header ACL view)
ACL Commands
1-17
rule comment (for IPv4)
ACL Commands
1-18
rule comment (for IPv6)
ACL Commands
1-31
S
save
1-19
schedule reboot at
3-20
schedule reboot delay
3-22
screen-length
Login Commands
1-17
secondary accounting
1-50
1-70
secondary authentication
1-51
1-71
secondary authorization
1-72
security-policy-server
1-52
self-service-url
1-25
send
Login Commands
1-18
send-router-alert
Multicast Commands
5-23
server-type
1-53
service-type
Login Commands
1-19
service-type
1-27
service-type ftp
1-27
session
HTTPS Commands
1-7
set authentication password
Login Commands
1-20
set-overload
4-56
sflow agent ip
sFlow Commands
1-2
sflow collector ip
sFlow Commands
1-3
sflow enable
sFlow Commands
1-3
sflow interval
sFlow Commands
1-4
sflow sampling-mode
sFlow Commands
1-5
sflow sampling-rate
sFlow Commands
1-6
sftp
SSH Commands
1-17
sftp client ipv6 source
SSH Commands
1-18
sftp client source
SSH Commands
1-18
sftp ipv6
SSH Commands
1-19
sftp server enable
SSH Commands
1-20
sftp server idle-timeout
SSH Commands
1-21
shell
Login Commands
1-21
shutdown
VLAN Commands
1-6
shutdown
1-25
shutdown
Multicast Commands
7-19
silent-interface
2-25
silent-interface
3-61
silent-interface
3-37
snmp-agent
RMON Commands
1-10
snmp-agent calculate-password
RMON Commands
1-11
Login Commands
2-3
RMON Commands
1-12
snmp-agent group
Login Commands
2-4
snmp-agent group
RMON Commands
1-13
RMON Commands
1-14
snmp-agent log
RMON Commands
1-15
snmp-agent mib-view
RMON Commands
1-16
snmp-agent packet max-size
RMON Commands
1-17
snmp-agent sys-info
RMON Commands
1-17
snmp-agent target-host
RMON Commands
1-18
snmp-agent trap enable
RMON Commands
1-20
snmp-agent trap enable ospf
3-61
snmp-agent trap if-mib link extended
RMON Commands
1-21
snmp-agent trap life
RMON Commands
1-22
snmp-agent trap queue-size
RMON Commands
1-22
snmp-agent trap source
RMON Commands
1-23
snmp-agent usm-user
Login Commands
2-5
snmp-agent usm-user { v1 | v2c }
RMON Commands
1-24
snmp-agent usm-user v3
RMON Commands
1-25
snmp-host
1-40
source
IPv6 Commands
3-7
source interface
NQA Commands
1-23
source ip
NQA Commands
1-24
source port
NQA Commands
1-25
source-deny
Multicast Commands
1-28
source-deny
Multicast Commands
2-27
source-lifetime
Multicast Commands
6-48
source-policy
Multicast Commands
6-48
speed
Login Commands
1-22
speed
1-26
spf timers
3-37
spf-schedule-interval
3-63
spf-slice-size
4-57
spt-switch-threshold
Multicast Commands
6-49
ssh client authentication server
SSH Commands
1-21
ssh client first-time enable
SSH Commands
1-22
ssh client ipv6 source
SSH Commands
1-23
ssh client source
SSH Commands
1-24
ssh server authentication-retries
SSH Commands
1-24
ssh server authentication-timeout
SSH Commands
1-25
ssh server compatible-ssh1x enable
SSH Commands
1-26
ssh server enable
SSH Commands
1-26
ssh server rekey-interval
SSH Commands
1-27
ssh user
SSH Commands
1-28
ssh2
SSH Commands
1-29
ssh2 ipv6
SSH Commands
1-31
ssl client-policy
HTTPS Commands
1-8
ssl server-policy
HTTPS Commands
1-9
ssm-policy
Multicast Commands
6-50
startup saved-configuration
1-20
state
1-28
state
1-54
state
PKI Commands
1-26
state-refresh-interval
Multicast Commands
6-51
state-refresh-rate-limit
Multicast Commands
6-52
state-refresh-ttl
Multicast Commands
6-52
static-bind client-identifier
DHCP Commands
1-23
static-bind ip-address
DHCP Commands
1-24
static-bind mac-address
DHCP Commands
1-25
static-rp
Multicast Commands
6-53
static-rpf-peer
Multicast Commands
7-20
step (for IPv4)
ACL Commands
1-19
step (for IPv6)
ACL Commands
1-32
stop-accounting-buffer enable
1-55
1-73
stopbits
Login Commands
1-23
storm-constrain
1-27
storm-constrain control
1-28
storm-constrain enable log
1-29
storm-constrain enable trap
1-29
storm-constrain interval
1-30
stp
MSTP Commands
1-14
stp bpdu-protection
MSTP Commands
1-15
stp bridge-diameter
MSTP Commands
1-16
stp compliance
MSTP Commands
1-16
stp config-digest-snooping
MSTP Commands
1-18
stp cost
MSTP Commands
1-18
stp edged-port
MSTP Commands
1-19
stp loop-protection
MSTP Commands
1-20
stp max-hops
MSTP Commands
1-21
stp mcheck
MSTP Commands
1-22
stp mode
MSTP Commands
1-23
stp no-agreement-check
MSTP Commands
1-23
stp pathcost-standard
MSTP Commands
1-24
stp point-to-point
MSTP Commands
1-26
stp port priority
MSTP Commands
1-27
stp port-log
MSTP Commands
1-27
stp priority
MSTP Commands
1-28
MSTP Commands
1-29
stp root primary
MSTP Commands
1-30
stp root secondary
MSTP Commands
1-31
stp root-protection
MSTP Commands
1-32
stp tc-protection
MSTP Commands
1-32
stp tc-protection threshold
MSTP Commands
1-33
stp timer forward-delay
MSTP Commands
1-34
stp timer hello
MSTP Commands
1-35
stp timer max-age
MSTP Commands
1-36
stp timer-factor
MSTP Commands
1-37
stp transmit-limit
MSTP Commands
1-37
stub
3-64
stub
3-38
stub-router
3-64
summary
2-26
summary
4-58
summary automatic
5-65
super
1-19
super password
1-20
synchronization
5-66
synchronization
5-53
sysname
1-21
1-22
T
tcp ipv6 timer fin-timeout
IPv6 Commands
1-40
tcp ipv6 timer syn-timeout
IPv6 Commands
1-41
tcp ipv6 window
IPv6 Commands
1-41
tcp timer fin-timeout
2-20
tcp timer syn-timeout
2-20
tcp window
2-21
telnet
Login Commands
1-24
telnet client source
Login Commands
1-25
telnet ipv6
Login Commands
1-25
telnet server enable
Login Commands
1-26
terminal debugging
1-23
terminal logging
1-23
terminal monitor
1-24
terminal trapping
1-25
terminal type
Login Commands
1-27
tftp
3-2
tftp client source
3-4
tftp ipv6
3-5
tftp-server
1-41
tftp-server acl
3-1
tftp-server domain-name
DHCP Commands
1-26
tftp-server ip-address
DHCP Commands
1-27
timer
5-67
timer
5-54
timer
1-41
timer
RRPP Commands
1-14
timer hello
Multicast Commands
6-54
timer isp-generation
4-59
timer join-prune
Multicast Commands
6-55
timer lsp-max-age
4-60
timer lsp-refresh
4-61
Multicast Commands
5-24
timer query
Multicast Commands
5-25
timer quiet
1-56
timer quiet
1-73
timer realtime-accounting
1-56
1-74
timer response-timeout
1-57
1-75
timer retry
Multicast Commands
7-21
timer spf
4-62
time-range
ACL Commands
1-3
timers
2-27
timers
2-17
topology accept
1-42
topology restore-from
1-43
topology save-to
1-44
tos
NQA Commands
1-26
tracert
2-4
tracert ipv6
2-6
track nqa
Track Commands
1-2
traffic behavior
QoS Commands
2-17
traffic classifier
QoS Commands
2-5
ttl
NQA Commands
1-26
tunnel-protocol
IPv6 Commands
3-8
type
NQA Commands
1-27
U
udp-helper enable
UDP Helper Commands
1-2
udp-helper port
UDP Helper Commands
1-2
udp-helper server
UDP Helper Commands
1-3
undelete
1-11
unicast-suppression
1-31
url
NQA Commands
1-28
user
2-25
user privilege level
Login Commands
1-28
user-bind
1-4
user-interface
Login Commands
1-28
username
NQA Commands
1-29
user-name-format
1-58
user-name-format
1-76
V
validate-source-address
2-28
verbose
2-26
version
2-29
version
Multicast Commands
5-25
version
HTTPS Commands
1-9
virtual-cable-test
1-32
virtual-system
4-63
vlan
VLAN Commands
1-7
vlan precedence
VLAN Commands
1-19
vlan-mapping modulo
MSTP Commands
1-38
vlink-peer
3-65
vlink-peer
3-39
voice vlan
VLAN Commands
2-3
voice vlan aging
VLAN Commands
2-4
voice vlan enable
VLAN Commands
2-4
voice vlan mac-address
VLAN Commands
2-5
voice vlan mode auto
VLAN Commands
2-7
voice vlan security enable
VLAN Commands
2-8
voice-config
DHCP Commands
1-27
vrrp ipv6 method
VRRP Commands
1-21
vrrp ipv6 ping-enable
VRRP Commands
1-22
vrrp ipv6 vrid authentication-mode
VRRP Commands
1-20
vrrp ipv6 vrid preempt-mode
VRRP Commands
1-22
vrrp ipv6 vrid priority
VRRP Commands
1-23
vrrp ipv6 vrid timer advertise
VRRP Commands
1-24
vrrp ipv6 vrid track
VRRP Commands
1-25
vrrp ipv6 vrid virtual-ip
VRRP Commands
1-26
vrrp method
VRRP Commands
1-7
vrrp ping-enable
VRRP Commands
1-8
vrrp un-check ttl
VRRP Commands
1-8
vrrp vrid authentication-mode
VRRP Commands
1-6
vrrp vrid preempt-mode
VRRP Commands
1-9
vrrp vrid priority
VRRP Commands
1-10
vrrp vrid timer advertise
VRRP Commands
1-11
vrrp vrid track
VRRP Commands
1-12
vrrp vrid track interface
VRRP Commands
1-13
vrrp vrid virtual-ip
VRRP Commands
1-14
W
work-directory
1-29
X
Y
Z
