H3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
HomeSupportSwitchesH3C S5500 Switch SeriesReference GuidesCommand ReferencesH3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
18-ARP Commands
18-ARP Commands 53 KB
Chapter 1  ARP Configuration Commands
1.1  ARP Configuration Commands
1.1.1  arp check enable
arp check enable
undo arp check enable
View
None
Use the arp check enable command to enable ARP entry check. With this function enabled, the device cannot learn any ARP entry with a multicast MAC address. Configuring such a static ARP entry is not allowed either; otherwise, the system prompts error information.
Use the undo arp check enable command to disable the function. After the ARP entry check is disabled, the device can learn the ARP entry with a multicast MAC address, and you can also configure such a static ARP entry on the device.
By default, ARP entry check is enabled.
# Enable the ARP entry check function on the switch.
[Sysname] arp check enable
1.1.2  arp max-learning-num
arp max-learning-num number
undo arp max-learning-num
View
VLAN interface view
number: Maximum number of dynamic ARP entries that a VLAN interface can learn, in the range 1 to 8192.
Use the arp max-learning-num command to set the maximum number of dynamic ARP entries that a VLAN interface can learn.
Use the undo arp max-learning-num command to restore the default.
By default, a VLAN interface can learn up to 8,192 dynamic ARP entries.
# Specify VLAN-interface 40 to learn up to 500 dynamic ARP entries.
[Sysname] interface vlan-interface 40
[Sysname-Vlan-interface40] arp max-learning-num 500
1.1.3  arp static
arp static ip-address mac-address [ vlan-id interface-type interface-number ]
undo arp ip-address
View
ip-address: IP address in an ARP entry.
mac-address: MAC address in an ARP entry, in the format H-H-H.
vlan-id: ID of a VLAN to which a static ARP entry belongs to, in the range 1 to 4094.
interface-type interface-number: Port type and port number.
Use the arp static command to configure a static ARP entry in the ARP mapping table.
Use the undo arp command to remove an ARP entry.
Note that:
l           A static ARP entry is effective when the device works normally. However, when the VLAN or VLAN interface to which an ARP entry corresponds is deleted, the entry, if permanent, will be deleted, and if non-permanent and resolved, will become unresolved.
l           The vlan-id argument is used to specify the corresponding VLAN of an ARP entry and must be the ID of an existing VLAN. In addition, the Ethernet port following the argument must belong to that VLAN. The VLAN interface of the VLAN must have been created.
Related commands: reset arp, display arp.
# Configure a static ARP entry, with the IP address being 202.38.10.2, the MAC address being 000f-e201-0000, and the outbound port being GigabitEthernet 1/0/10 of VLAN 10.
[Sysname] arp static 202.38.10.2 000f-e201-0000 10 gigabitethernet 1/0/10
1.1.4  arp timer aging
arp timer aging aging-time
undo arp timer aging
View
aging-time: Aging time for dynamic ARP entries in minutes, in the range 1 to 1,440.
Use the arp timer aging command to set aging time for dynamic ARP entries.
Use the undo arp timer aging command to restore the default.
By default, the aging time for dynamic ARP entries is 20 minutes.
Related commands: display arp timer aging.
# Set aging time for dynamic ARP entries to 10 minutes.
[Sysname] arp timer aging 10
1.1.5  display arp
display arp { { all | dynamic | static } | vlan vlan-id | interface interface-type interface-number } [ | { begin | exclude | include } string | count ]
View
all: Displays all ARP entries.
dynamic: Displays dynamic ARP entries.
static: Displays static ARP entries.
vlan vlan-id: Displays the ARP entries of the specified VLAN. The VLAN ID ranges from 1 to 4,094.
interface interface-type interface-number: Displays the ARP entries of the port specified by the argument interface-type interface-number.
|: Uses a regular expression to specify the ARP entries to be displayed. For detailed information about regular expression, refer to the part discussing CLI display in System Maintaining and Debugging Configuration.
begin: Displays ARP entries from the first one containing the specified string.
exclude: Displays the ARP entries that do not contain the specified string.
include: Displays the ARP entries containing the specified string.
string: A case-sensitive string for matching, consisting of 1 to 256 characters.
count: Displays the number of ARP entries.
Use the display arp command to display ARP entries in the ARP mapping table.
Related commands: arp static, reset arp.
# Display the information of all ARP entries.
<Sysname> display arp all
                Type: S-Static    D-Dynamic
IP Address       MAC Address     VLAN ID  Interface              Aging Type
20.1.1.1         00e0-fc00-0001  N/A      N/A                    N/A   S
193.1.1.70       00e0-fe50-6503  100      GE1/0/1                14    D
192.168.0.115    000d-88f7-9f7d  1        GE1/0/2                18    D
192.168.0.39     0012-a990-2241  1        GE1/0/3                20    D
Table 1-1 Description on the fields of the display arp command
IP Address
MAC Address
VLAN ID
VLAN ID contained a static ARP entry
Outbound port in an ARP entry
Aging
Aging time for a dynamic ARP entry in minutes
ARP entry type: D stands for dynamic and S for static.
# Display the number of all ARP entries
<Sysname> display arp all count
Total Entry(ies): 4
1.1.6  display arp ip-address
display arp ip-address [ | { begin | exclude | include } string ]
View
ip-address: Displays the ARP entry for the specified IP address.
begin: Displays the ARP entries from the first one containing the specified string.
include: Displays the ARP entries that contain the specified string.
Use the display arp ip-address command to display the ARP entry for a specified IP address.
# Display the corresponding ARP entry for the IP address 20.1.1.1.
<Sysname> display arp 20.1.1.1
1.1.7  display arp timer aging
View
None
Use the display arp timer aging command to display the aging time for dynamic ARP entries.
Related commands: arp timer aging.
# Display the aging time for dynamic ARP entries.
[Sysname] display arp timer aging
Current ARP aging time is 10 minute(s)
1.1.8  reset arp
reset arp { all | dynamic | static | interface interface-type interface-number }
View
all: Clears all ARP entries.
dynamic: Clears all dynamic ARP entries.
static: Clears all static ARP entries.
interface interface-type interface-number: Clears the ARP entries for the port specified by the argument interface-type interface-number.
Use the reset arp command to clear ARP entries from the ARP mapping table.
With interface interface-type interface-number specified, the command clears only dynamic ARP entries of the port.
Related commands: arp static, display arp.
# Clear all static ARP entries.
<Sysname> reset arp static
1.2  Gratuitous ARP Configuration Commands
1.2.1  gratuitous-arp-learning enable
undo gratuitous-arp-learning enable
View
None
Use the gratuitous-arp-learning enable command to enable the gratuitous ARP packet learning function.
Use the undo gratuitous-arp-learning enable command to disable the function.
By default, the function is enabled.
# Disable the gratuitous ARP packet learning function.
[Sysname] undo gratuitous-arp-learning enable
1.2.2  gratuitous-arp-sending enable
undo gratuitous-arp-sending enable
View
None
Use the gratuitous-arp-sending enable command to enable a device to send gratuitous ARP packets when receiving ARP requests from another network segment.
Use the undo gratuitous-arp-sending enable command to restore the default.
By default, a device cannot send gratuitous ARP packets when receiving ARP requests from another network segment.
# Disable a device from sending gratuitous ARP packets.
[Sysname] undo gratuitous-arp-sending enable
Chapter 2  Proxy ARP Configuration Commands
2.1  Proxy ARP Configuration Commands
2.1.1  display local-proxy-arp
display local-proxy-arp [ interface Vlan-interface vlan-id ]
View
interface vlan-interface vlan-id: Displays the local proxy ARP status of the VLAN interface specified by the argument vlan-id.
Use the display local-proxy-arp command to display the status of the local proxy ARP.
Related commands: local-proxy-arp enable.
# Display the status of the local proxy ARP on VLAN-interface 2.
<Sysname> display local-proxy-arp interface vlan-interface 2
Interface Vlan-interface2
 Local Proxy ARP status: enabled
2.1.2  display proxy-arp
display proxy-arp [ interface Vlan-interface vlan-id ]
View
interface Vlan-interface vlan-id: Displays the proxy ARP status of the VLAN interface specified by the argument vlan-id.
Use the display proxy-arp command to display the proxy ARP status.
Related commands: proxy-arp enable.
# Display the proxy ARP status on VLAN-interface 1.
<Sysname> display proxy-arp interface vlan-interface 1
Interface Vlan-interface1
 Proxy ARP status: disabled
2.1.3  local-proxy-arp enable
undo local-proxy-arp enable
View
VLAN interface view
None
Use the local-proxy-arp enable command to enable local proxy ARP.
Use the undo local-proxy-arp enable command to disable local proxy ARP.
By default, local proxy ARP is disabled.
Related commands: display local-proxy-arp.
# Enable local proxy ARP on VLAN-interface 2.
[Sysname] interface Vlan-interface 2
[Sysname-Vlan-interface2] local-proxy-arp enable
2.1.4  proxy-arp enable
proxy-arp enable
undo proxy-arp enable
View
VLAN interface view
None
Use the proxy-arp enable command to enable proxy ARP.
Use the undo proxy-arp enable command to disable proxy ARP.
By default, proxy ARP is disabled.
Related commands: display proxy-arp.
# Enable proxy ARP on VLAN-interface 2.
[Sysname-Vlan-interface2] proxy-arp enable
