H3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
HomeSupportSwitchesH3C S5500 Switch SeriesReference GuidesCommand ReferencesH3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
11-IP Routing-GR Overview Commands
11-IP Routing-GR Overview Commands 116 KB
Chapter 1  Routing Overview Commands
&  Note:
The term “router” in this document refers to a Layer 3 switch running routing protocols.
1.1  Routing Overview Commands
1.1.1  display ip relay-route
View
None
Use the display ip relay-route command to display the information of recursive routes.
# Display recursive route information.
<Sysname> display ip relay-route
 Total Number of Relay-route is: 1.
 Dest/Mask: 40.40.40.0/255.255.255.0
Related instance id(s): 1(1) 2(1) 3(1) 4(1)
Table 1-1 Description on the fields of the display ip relay-route command
Total number of recursive routes
Dest/Mask
Destination address/mask of the recursive route
The number in the parentheses after each instance ID indicates the number of routes that have used the recursive route in the routing table corresponding to the instance ID.
1.1.2  display ip routing-table
display ip routing-table [ verbose | | { begin | exclude | include } regular-expression ]
View
verbose: Displays detailed routing table information, including that for inactive routes. With this argument absent, the command displays only summary information about active routes.
|: Uses a regular expression to filter output information.
begin: Displays routing table entries starting from the one specified by the regular expression.
include: Displays routing table entries specified by the regular expression.
exclude: Displays routing table entries other than those specified by the regular expression.
regular-expression: Regular expression, a string of 1 to 256 characters used for specifying routing entries.
Table 1-2 Special characters for regular expressions
Character
Meaning
Remarks
_
Underscore, functions similarly as a wildcard and matches one of the following:
or a space, the beginning of a string, the end of a string.
If it is not the first character in a regular expression, it can appear as many times as the command line length permits.
If it is the first character in a regular expression, it can be followed with up to four underscores.
If it appears intermittently in a regular expression, only the first group takes effect.
Left parenthesis, represents a stack push operation in a program.
It is not recommended to use this character in a regular expression.
Full stop, a wildcard that matches any character, including a space.
Asterisk, indicates that the character(s) to its left can appear 0 or more times.
zo* matches z and zoo.
Plus, indicates that the character(s) to its left can appear one or more times.
zo+ matches zo and zoo, but not z.
Use the display ip routing-table command to display brief information about active routes in the routing table.
Use the display ip routing-table verbose command to display detailed information about all routes in the routing table.
# Display brief information about active routes in the routing table.
<Sysname> display ip routing-table
Routing Tables: Public
         Destinations : 6        Routes : 6
10.10.3.0/24        Direct 0    0            10.10.3.1       Vlan2
10.10.3.1/32        Direct 0    0            127.0.0.1       InLoop0
192.168.0.0/24      Direct 0    0            192.168.0.72    Vlan1
192.168.0.72/32     Direct 0    0            127.0.0.1       InLoop0
Table 1-3 Description on the fields of the display ip routing-table command
Destinations
Number of destination addresses
Routes
Number of routes
Destination/Mask
Destination address/mask length
Proto
Protocol that presents the route
Pre
Priority of the route
Cost
Cost of the route
Nexthop
Address of the next hop on the route
Output interface for packets to be forwarded along the route
# Display detailed information about all routes in the routing table.
<Sysname> display ip routing-table verbose
Routing Table : Public
  Destination: 10.10.3.0/24
     Protocol: Direct          Process ID: 0
   Preference: 0                     Cost: 0
      NextHop: 10.10.3.1        Interface: Vlan-interface2
  RelyNextHop: 0.0.0.0          Neighbor : 0.0.0.0
    Tunnel ID: 0x0                  Label: NULL
        State: Active Adv             Age: 1d06h37m12s
          Tag: 0
  Destination: 10.10.3.1/32
      NextHop: 127.0.0.1        Interface: InLoopBack0
        State: Active NoAdv           Age: 1d06h37m12s
          Tag: 0
  Destination: 127.0.0.0/8
        State: Active NoAdv           Age: 3d23h11m49s
          Tag: 0
  Destination: 127.0.0.1/32
        State: Active NoAdv           Age: 3d23h11m51s
          Tag: 0
  Destination: 192.168.0.0/24
      NextHop: 192.168.0.72     Interface: Vlan-interface1
        State: Active Adv             Age: 3d23h08m38s
          Tag: 0
  Destination: 192.168.0.72/32
        State: Active NoAdv           Age: 3d23h08m40s
          Tag: 0
Displayed first are statistics for the whole routing table, followed by detailed description of each route (in sequence).
Table 1-4 display ip routing-table verbose command output description
Destination
Protocol
Process ID
Process ID
Preference
Cost
Cost of the route
NextHop
Outbound interface for packets to be forwarded along the route
RelyNextHop
The next hop address obtained through routing stack.
Neighbour
Neighboring address determined by Routing Protocol
Tunnel ID
Tunnel ID
Label
Label
Route status:
Active
This is an active unicast route.
Adv
This route can be advertised.
Delete
This route is deleted.
Gateway
This is an indirect route.
Holddown
Number of holddown routes. Holddown is a route advertisement policy used in some distance vector (D-V) routing protocols, such as RIP, to avoid the propagation of some incorrect routes. It distributes a Holddown route during a period regardless of whether a new route to the same destination is found. For details, refer to corresponding routing protocols.
Int
The route was discovered by an Internal Gateway Protocol (IGP).
NoAdv
The route is not advertised when the router advertises routes based on policies.
NotInstall
Normally, among routes to a destination, the route with the highest preference is installed into the core routing table and advertised, while a NotInstall route cannot be installed into the core routing table but may be advertised.
Reject
The packets matching a Reject route will be dropped. Besides, the router sends ICMP unreachable messages to the sources of the dropped packets. The Reject routes are usually used for network testing.
Static
A static route is not lost when you perform the save operation and then restart the router. Routes configured manually are marked as static.
Unicast
Unicast routes
Inactive
Inactive routes
Invalid
Invalid routes
WaitQ
The route is the WaitQ during route recursion.
TunE
Tunnel
GotQ
The route is in the GotQ during route recursion.
Age
Time for which the route has been in the routing table, in the sequence of hour, minute, and second from left to right.
Tag
Route tag
1.1.3  display ip routing-table acl
display ip routing-table acl acl-number [ verbose ]
View
acl-number: Basic ACL number, in the range of 2000 to 2999.
verbose: Displays detailed routing table information, including that for inactive routes. With this argument absent, the command displays only brief information about active routes.
Use the display ip routing-table acl command to display information about routes permitted by a specified basic ACL.
This command is intended for the follow-up display of routing policies.
For more information about routing policy, refer to IPv4 Routing Configuration.
&  Note:
If the specified ACL does not exist or it has no rules configured, the entire routing table is displayed.
# Define basic ACL 2000 and set the route filtering rules.
<Sysname > system-view
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 192.168.0.0 0.0.255.255
[Sysname-acl-basic-2000] rule deny source any
# Display brief information about active routes permitted by basic ACL 2000.
[Sysname-acl-basic-2000] display ip routing-table acl 2000
Routes Matched by Access list : 2000
Summary Count : 2
192.168.0.0/24      Direct 0    0            192.168.0.136   Vlan1
192.168.0.136/32    Direct 0    0            127.0.0.1       InLoop0
For detailed description of the above output, see Table 1-3.
# Display detailed information about both active and inactive routes permitted by basic ACL 2000.
<Sysname> display ip routing-table acl 2000 verbose
Summary Count : 2
      NextHop: 192.168.0.136    Interface: Vlan-interface1
        State: Active Adv             Age: 1d04h26m42s
          Tag: 0
  Destination: 192.168.0.136/32
        State: Active NoAdv           Age: 1d04h26m42s
          Tag: 0
For the description of the command output above, seeTable 1-4.
1.1.4  display ip routing-table ip-address
display ip routing-table ip-address [ mask-length | mask ] [ longer-match ] [ verbose ]
display ip routing-table ip-address1 { mask-length | mask } ip-address2 { mask-length | mask } [ verbose ]
View
ip-address: Destination IP address, in dotted decimal format.
mask-length: IP address mask length in the range 0 to 32.
mask: IP address mask in dotted decimal format.
longer-match: Displays the route with the longest mask.
Use the display ip routing-table ip-address command to display information about routes to a specified destination address.
Executing the command with different parameters yields different output:
l           display ip routing-table ip-address
The system ANDs the input destination IP address with the subnet mask in each route entry; and ANDs the destination IP address in each route entry with its corresponding subnet mask.
If the two operations yield the same result for an entry and this entry is active, it is displayed.
l           display ip routing-table ip-address mask
The system ANDs the input destination IP address with the input subnet mask; and ANDs the destination IP address in each route entry with the input subnet mask.
If the two operations yield the same result for an entry and the entry is active with a subnet mask less than or equal to the input subnet mask, the entry is displayed.
Only route entries that exactly match the input destination address and mask are displayed.
l           display ip routing-table ip-address longer-match
If the two operations yield the same result for multiple entries that are active, the one with longest mask length is displayed.
l           display ip routing-table ip-address mask longer-match
If the two operations yield the same result for multiple entries with a mask less than or equal to the input subnet mask, the one that is active with longest mask length is displayed.
Use the display ip routing-table ip-address1 { mask-length | mask } ip-address2 { mask-length | mask } command to display route entries with destination addresses within a specified range.
# Display route entries for the destination IP address 11.1.1.1.
<Sysname> display ip routing-table  11.1.1.1
Summary Count : 4
0.0.0.0/0           Static 60   0            0.0.0.0         NULL0
11.0.0.0/8          Static 60   0            0.0.0.0         NULL0
11.1.0.0/16         Static 60   0            0.0.0.0         NULL0
11.1.1.0/24         Static 60   0            0.0.0.0         NULL0
# Display route entries by specifying a destination IP address and the longer-match keyword.
<Sysname> display ip routing-table 11.1.1.1 longer-match
Summary Count : 1
# Display route entries by specifying a destination IP address and mask.
<Sysname> display ip routing-table  11.1.1.1 24
Summary Count : 3
# Display route entries by specifying a destination IP address and mask and the longer-match keyword.
<Sysname> display ip routing-table 11.1.1.1 24 longer-match
Summary Count : 1
Destination/Mask    Proto  Pre  Cost         NextHop         Interface
# Display route entries for destination addresses in the range 1.1.1.0 to 5.5.5.0.
<Sysname> display ip routing-table 1.1.1.0 24 5.5.5.0 24
1.1.1.0/24          Direct 0    0            1.1.1.1       Vlan1
1.1.1.1/32          Direct 0    0            127.0.0.1     InLoop0
2.2.2.0/24          Direct 0    0            2.2.2.1       Vlan2
For the description of the command output above, seeTable 1-3.
1.1.5  display ip routing-table ip-prefix
display ip routing-table ip-prefix ip-prefix-name [ verbose ]
View
ip-prefix-name: IP Prefix list name, a string of 1 to 19 characters.
Use the display ip routing-table ip-prefix command to display information about routes permitted by a specified prefix list.
This command is intended for the follow-up display of routing policies. If the specified prefix list is not configured, detailed information about all routes (with the verbose keyword) or brief information about all active routes (without the verbose keyword) is displayed.
# Configure a prefix list named test, permitting routes with a prefix of 2.2.2.0 and a mask length between 24 and 32.
[Sysname] ip ip-prefix test permit 2.2.2.0 24 less-equal 32
# Display brief information about active routes permitted by the prefix list test.
[Sysname] display ip routing-table ip-prefix test
Routes Matched by Prefix list : test
Summary Count : 2
2.2.2.1/32         Direct  0    0          127.0.0.1       InLoop0
# Display detailed information about both active and inactive routes permitted by IP prefix list test.
[Sysname] display ip routing-table ip-prefix test verbose
Routes Matched by Prefix list  test :
Summary Count : 2
Destination: 2.2.2.0/24
      NextHop: 2.2.2.1                  Interface: Vlan2
  RelyNextHop: 0.0.0.0                  Neighbour: 0.0.0.0
        State: Active Adv                     Age: Od00h20m52s
          Tag: 0
Destination: 2.2.2.1/32
      NextHop: 127.0.0.1                Interface: InLoop0
        State: Active NoAdv                   Age: Od00h20m52s
          Tag: 0
For detailed description of the above output, see Table 1-4.
1.1.6  display ip routing-table protocol
display ip routing-table protocol protocol [ inactive | verbose ]
View
protocol: Routing protocol. It can be BGP, DIRECT, ISIS, OSPF, RIP, or STATIC.
inactive: Displays information about only inactive routes. With this argument absent, the command displays information about both active and inactive routes.
verbose: Displays detailed routing table information. With this argument absent, the command displays brief routing table information.
Use the display ip routing-table protocol command to display routing information of a specified routing protocol.
# Display brief information about direct routes.
<Sysname> display ip routing-table protocol direct
Public Routing Table : Direct
Summary Count : 5
Direct Routing table Status : < Active>
Summary Count :  5
2.2.2.2/32          Direct 0    0          127.0.0.1       InLoop0
192.168.80.10/32    Direct 0    0          127.0.0.1       InLoop0
Direct Routing table Status : < Inactive>
Summary Count : 0
# Display summary information about static routes.
<Sysname> display ip routing-table protocol static
Public Routing Table : Static
Summary Count : 1
Static Routing table Status : < Active>
Summary Count :  0
Static Routing table Status : < Inactive>
Summary Count : 1
1.2.3.0/24          Static  60   0          1.2.4.5      Vlan10
1.1.7  display ip routing-table statistics
View
None
Use the display ip routing-table statistics command to display statistics about the public network routing table.
# Display statistics about the routes in the routing table.
<Sysname> display ip routing-table statistics
Proto      route       active      added       deleted       freed
DIRECT     24          4           25          1             0
STATIC     4           1           4           0             0
RIP        0           0           0           0             0
OSPF       0           0           0           0             0
IS-IS      0           0           0           0             0
BGP        0           0           0           0             0
Total      28          5           29          1             0
Table 1-5 Description on the fields of display ip routing-table statistics
Proto
Origin of the routes. Possible values include O_ASE for OSPF_ASE routes, O_NSSA for OSPF NSSA, and AGGRE for aggregated routes.
route
Number of routes from the origin
active
Number of active routes from the origin
added
Number of routes added into the routing table since the router starts up or the last routing table reset operation
deleted
Number of routes marked as deleted, which will be freed after a period.
freed
Number of routes that got freed, that is, got removed permanently
Total
Sums for the numerical items above
1.1.8  display ipv6 relay-route
View
None
Use the display ipv6 relay-route command to display IPv6 recursive route information.
# Display IPv6 recursive route information.
<Sysname> display ipv6 relay-route
 Total Number of relay-route is: 1
 Dest/Mask: 192::1/64
      Related instance id(always 0): 0(1)
Table 1-6 Description on the fields of the display ipv6 relay-route command
Dest/Mask
IPv6 supports public networks only. Therefore, the instance ID can be 0 only.
The number in the parentheses after the instance ID indicates the number of routes that have used the recursive route in the routing table.
1.1.9  display ipv6 routing-table
View
None
Use the display ipv6 routing-table command to display brief routing table information, including destination IP address and prefix, protocol type, priority, metric, next hop and outbound interface.
The command displays only active routes, namely, the brief information about the current optimal routes.
# Display brief routing table information
<Sysname> display ipv6 routing-table
Routing Table :
        Destinations : 1        Routes : 1
Destination : ::1/128                           Protocol     : Direct
NextHop     : ::1                               Preference   : 0
Interface   : InLoop0                           Cost         : 0
Table 1-7 Description on the fields of the display ipv6 routing-table command
Destination
Destination IPv6 address
NextHop
Next hop
Preference
Routing preference
Outbound interface
Protocol
Routing protocol of the route
Cost
Routing cost
1.1.10  display ipv6 routing-table acl
display ipv6 routing-table acl acl6-number [ verbose ]
View
acl6-number: Basic IPv6 ACL number, in the range 2000 to 2999.
verbose: Displays both active and inactive verbose routing information permitted by the ACL. Without this keyword, only brief active routing information is displayed.
Use the display ipv6 routing-table acl command to display routing information permitted by the IPv6 ACL.
If the specified IPv6 ACL is not available, all routing information is displayed.
# Display brief routing information permitted by ACL 2000.
<Sysname> display ipv6 routing-table acl 2000
Routes Matched by Access list  2000  :
Summary Count : 2
Destination : 1:1::/64                          Protocol   : Static
NextHop     : ::                                Preference : 60
Interface   : NULL0                             Cost       : 0
Refer to Table 1-7 for description about the above output.
1.1.11  display ipv6 routing-table ipv6-address
display ipv6 routing-table ipv6-address prefix-length [ longer-match ] [ verbose ]
View
ipv6-address: Destination IPv6 address.
prefix-length: Prefix length, in the range 0 to 128.
longer-match: Displays the matched route having the longest prefix length.
verbose: Displays both active and inactive verbose routing information. Without this keyword, only brief active routing information is displayed.
Use the display ipv6 routing-table ipv6-address command to display routing information about the specified destination IPv6 address.
l           display ipv6 routing-table ipv6-address prefix-length
The system ANDs the input destination IPv6 address with the input prefix length, and ANDs the destination IPv6 address in each route entry with the input prefix length.
If the two operations yield the same result for an entry and the entry is active with a prefix length less than or equal to the input prefix length, the entry is displayed.
Only route entries that exactly match the input destination address and prefix length are displayed.
l           display ipv6 routing-table ipv6-address prefix-length longer-match
The system ANDs the input destination IPv6 address with the input prefix length; and ANDs the destination IPv6 address in each route entry with the input prefix length.
If the two operations yield the same result for multiple entries with a prefix length less than or equal to the input prefix length, the one that is active with the longest prefix length is displayed.
# Display brief information about the route matching the specified destination IPv6 address.
<Sysname> display ipv6 routing-table 10::1 127
Routing Table:
Summary Count: 3
Destination: 10::/64                                    Protocol  : Static
NextHop    : ::                                         Preference: 60
Destination: 10::/68                                    Protocol  : Static
Destination: 10::/120                                    Protocol  : Static
# Display brief information about the matched route with the longest prefix length.
<Sysname> display ipv6 routing-table 10:: 127 longer-match
Routing Tables:
Summary Count : 1
1.1.12  display ipv6 routing-table ipv6-address1 ipv6-address2
display ipv6 routing-table ipv6-address1 prefix-length1 ipv6-address2 prefix-length2 [ verbose ]
View
ipv6-address1/ipv6-address2: An IPv6 address range from IPv6 address1 to IPv6 address2.
prefix-length1/prefix-length2: Prefix length, in the range 0 to 128.
Use the display ipv6 routing-table ipv6-address1 ipv6-address2 command to display routes with destinations falling into the specified IPv6 address range.
# Display routes with destinations falling into the IPv6 address range.
<Sysname> display ipv6 routing-table 100:: 64 400:: 64
Routing Table :
Summary Count : 3
Destination: 100::/64                                    Protocol  : Static
NextHop    : 1::2                                        Preference: 60
Interface  : Vlan1                                       Cost      : 0
Destination: 200::/64                                    Protocol  : Static
Destination: 300::/64                                    Protocol  : Static
1.1.13  display ipv6 routing-table ipv6-prefix
display ipv6 routing-table ipv6-prefix ipv6-prefix-name [ verbose ]
View
ipv6-prefix-name: Name of the IPv6 prefix list, in the range 1 to 19 characters.
Use the display ipv6 routing-table ipv6-prefix command to display routes permitted by the IPv6 prefix list.
# Display brief active routing information permitted by the IPv6 prefix list test2.
<Sysname> display ipv6 routing-table ipv6-prefix test2
Routes Matched by Prefix list  test2  :
Summary Count : 1
1.1.14  display ipv6 routing-table protocol
display ipv6 routing-table protocol protocol [ inactive | verbose ]
View
protocol: Displays routes of a routing protocol, which can be bgp4+, direct, isisv6, ospfv3, ripng and static.
inactive: Displays only inactive routes. Without the keyword, all active and inactive routes are displayed.
Use the display ipv6 routing-table protocol command to display routes of a specified routing protocol.
# Display brief information about all direct routes.
<Sysname> display ipv6 routing-table protocol direct
Direct Routing Table :
Summary Count : 1
Direct Routing Table's Status : < Active >
Summary Count : 1
Destination: ::1/128                                     Protocol  : Direct
NextHop    : ::1                                         Preference: 0
Direct Routing Table's Status : < Inactive >
Summary Count : 0
1.1.15  display ipv6 routing-table statistics
View
None
Use the display ipv6 routing-table statistics command to display routing statistics, including total route number, added route number and deleted route number.
# Display routing statistics.
<Sysname> display ipv6 routing-table statistics
Protocol   route      active     added      deleted     freed
DIRECT     1          1          1          0           0
STATIC     3          0          3          0           0
RIPng      0          0          0          0           0
OSPFv3     0          0          0          0           0
IS-ISv6    0          0          0          0           0
BGP4+      0          0          0          0           0
Total      4          1          4          0           0
Table 1-8 Description on the fields of the display ipv6 routing-table statistics command
Protocol
Routing protocol
route
Route number of the protocol
active
Active route number
added
Routes added after the last startup of the router
deleted
Deleted routes, which will be released after a specified time
freed
Released (totally removed from the routing table) route number
Total
Total route number
1.1.16  display ipv6 routing-table verbose
View
None
Use the display ipv6 routing-table verbose command to display detailed information about all active and inactive routes, including the statistics of the entire routing table and information for each route.
# Display detailed information about all active and inactive routes.
<Sysname> display ipv6 routing-table verbose
Routing Table :
 Destination  : ::1                                     PrefixLength : 128
 RelayNextHop : ::                                      Tag          : 0H
 Neighbour    : ::                                      ProcessID    : 0
 Interface    : InLoopBack0                             Protocol     : Direct
 State        : Active NoAdv                            Cost         : 0
 Tunnel ID    : 0x0                                     Label        : NULL
 Age          : 22161sec
Table 1-9 Description on the fields of the display ipv6 routing-table verbose command
Destination
PrefixLength
Prefix length of the address
Nexthop
Next hop
Preference
Routing preference
RelayNextHop
Relay next hop
Tag
Tag of the route
Neighbour
Neighbor address
ProcessID
Process ID
Outbound interface
Protocol
Routing protocol
State of the route, Active, Inactive, Adv (advertised), or NoAdv (not advertised)
Cost
Cost of the route
Tunnel ID
Tunnel ID
Label
Label
Age
Time that has elapsed since the route was generated
1.1.17  reset ip routing-table statistics protocol
reset ip routing-table statistics protocol { all | protocol }
View
all: Clears statistics for all routing protocols.
protocol: Clears statistics for the routing protocol, which can be bgp, direct, is-is, ospf, rip, or static.
Use the reset ip routing-table statistics protocol command to clear the routing statistics of the routing table.
# Clear the routing statistics of the routing table.
<Sysname> reset ip routing-table statistics protocol all
1.1.18  reset ipv6 routing-table statistics
reset ipv6 routing-table statistics protocol { all | protocol }
View
protocol: Clears statistics for the routing protocol, which can be bgp4+, direct, isisv6, ospfv3, ripng, or static.
Use the reset ipv6 routing-table statistics command to clear the route statistics of the routing table.
# Clear statistics for all routing protocols.
<Sysname> reset ipv6 routing-table statistics protocol all
Chapter 2  GR Overview Commands
2.1  GR Overview Commands
GR overview involves no commands. For GR-related commands, refer to BGP Configuration Commands, OSPF Configuration Commands, and IS-IS Configuration Commands in IPv4 Routing Commands.
