H3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
HomeSupportSwitchesH3C S5500 Switch SeriesReference GuidesCommand ReferencesH3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
03-IP Addressing and IP Performance Commands
Chapter 1  IP Addressing Configuration Commands
1.1  IP Addressing Configuration Commands
1.1.1  display ip interface
display ip interface [ interface-type interface-number ]
View
Use the display ip interface command to display information about a specified or all Layer 3 interfaces.
# Display information about interface VLAN-interface 1.
<Sysname> display ip interface vlan-interface 1
Vlan-interface1 current state : DOWN
Line protocol current state : DOWN
Internet Address is 1.1.1.1/8 Primary
Broadcast address : 1.255.255.255
The Maximum Transmit Unit : 1500 bytes
input packets : 0, bytes : 0, multicasts : 0
output packets : 0, bytes : 0, multicasts : 0
ARP packet input number:           0
  Request packet:                  0
  Reply packet:                    0
  Unknown packet:                  0
TTL invalid packet number:         0
ICMP packet input number:          0
  Echo reply:                      0
  Unreachable:                     0
  Source quench:                   0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                     0
  IP header bad:                   0
  Timestamp request:               0
  Timestamp reply:                 0
  Information request:             0
  Information reply:               0
  Netmask request:                 0
  Netmask reply:                   0
  Unknown type:                    0
DHCP packet deal mode:  global
Table 1-1 Description on fields of the display ip interface command
current state
Current physical state of an interface
Current state of the network layer protocol
Internet Address
IP address of an interface followed by:
l      Primary: Identifies a primary IP address, or
l      Sub: Identifies a secondary IP address.
Broadcast address
Broadcast address of the subnet attached to an interface
Maximum transmission units on an interface
Unicast packets, bytes, and multicast packets received on an interface
Unicast packets, bytes, and multicast packets sent on an interface
  Request packet:                  0
  Reply packet:                      0
  Unknown packet:                0
Total number of ARP packets received on an interface, including
l      ARP request packets
l      ARP reply packets
l      Unknown packets
Number of TTL-invalid packets received on an interface
  Echo reply:                               0
  Unreachable:                            0
  Source quench:                        0
  Routing redirect:                       0
  Echo request:                           0
  Router advert:                           0
  Router solicit:                           0
  Time exceed:                            0
  IP header bad:                          0
  Timestamp reply:                      0
  Netmask request:                            0
  Netmask reply:                         0
  Unknown type:                          0
Total number of ICMP packets received on an interface, including the following packets:
l      Echo reply packet
l      Unreachable packets
l      Source quench packets
l      Routing redirect packets
l      Echo request packets
l      Router advertisement packets
l      Router solicitation packets
l      Time exceeded packets
l      IP header bad packets
l      Timestamp request packets
l      Timestamp reply packets
l      Information request packets
l      Information reply packets
l      Netmask request packets
l      Netmask reply packets
l      Unknown type packets
DHCP packet processing mode. This field appears on a DHCP-supporting device and can be one of the following values:
l      global: The DHCP server with the global address pool is enabled on the interface.
l      relay: The DHCP relay agent is enabled on the interface.
1.1.2  display ip interface brief
display ip interface brief [ interface-type [ interface-number ] ]
View
interface-type: Interface type.
interface-number: Interface number.
Use the display ip interface brief command to display brief information about a specified or all layer 3 interfaces.
Without the interface type and interface number specified, the information about all layer 3 interfaces is displayed; with only the interface type specified, the information about all layer 3 interfaces of the specified type is displayed; with both the interface type and interface number specified, only the information about the specified interface is displayed.
Related commands: display ip interface.
# Display brief information about VLAN-interface 1.
<Sysname> display ip interface brief vlan-interface 1
*down: administratively down
(s): spoofing
Interface            Physical        Protocol        IP Address
Vlan-interface1     up           up     1.1.1.1
Table 1-2 Description on fields of the display ip interface brief command
*down
The interface is administratively shut down with the shutdown command.
(s)
Spoofing attribute of the interface. It indicates that an interface whose network layer protocol is displayed up may have no link present or the link is set up only on demand.
Interface name
Physical
Physical state of interface
Protocol
Network layer protocol state of interface
IP Address
IP address of interface (If no IP address is configured, “unassigned” is displayed.)
1.1.3  ip address
undo ip address [ ip-address { mask | mask-length } [ sub ] ]
View
Interface view
ip-address: IP address of interface, in dotted decimal notation.
mask: Subnet mask in dotted decimal notation.
mask-length: Subnet mask length, the number of consecutive ones in the mask.
sub: Secondary IP address for the interface.
Use the ip address command to assign an IP address and mask to the interface.
Use the undo ip address command to remove all IP addresses.
Use the undo ip address ip-address { mask | mask-length } command to remove the primary IP address.
Use the undo ip address ip-address { mask | mask-length } sub command to remove a secondary IP address.
By default, no IP address is assigned to any interface.
When assigning IP addresses to an interface, consider the following:
l           You can assign only one primary IP address to an interface.
l           The primary and secondary IP addresses can be located in the same network segment.
l           Before removing the primary IP address, remove all secondary IP addresses.
l           You cannot assign a secondary IP address to the interface that has been configured to obtain an IP address through BOOTP or DHCP.
# Assign VLAN-interface 1 a primary IP address and a secondary IP address, with subnet masks being 255.255.255.0.
[Sysname-Vlan-interface1] ip address 129.12.0.1 255.255.255.0
[Sysname-Vlan-interface1] ip address 202.38.160.1 255.255.255.0 sub
Chapter 2  IP Performance Configuration Commands
2.1  IP Performance Configuration Commands
2.1.1  display fib
display fib [ | { begin | include | exclude } string | acl acl-number | ip-prefix ip-prefix-name ]
View
| { begin | include | exclude } string: Displays FIB information in the buffer related to the specified string according to a regular expression.
l           The begin keyword specifies to display from the first FIB entry that contains the specified string.
l           The include keyword specifies to display only the FIB entries that include the specified string.
l           The exclude keyword specifies to display only the FIB entries that do not include the specified string.
l           The string argument is a case-sensitive string, containing 1 to 256 characters.
acl acl-number: Displays FIB information matching a specified ACL numbered from 2000 to 2999.
ip-prefix ip-prefix-name: Displays FIB information matching a specified IP prefix list, a string of 1 to 19 characters.
Use the display fib command to display FIB forward information. If no parameters are specified, all FIB information will be displayed.
# Display all FIB information.
<Sysname> display fib
FIB Table:
Total number of Routes : 4
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Reject   L:Generated by ARP or ESIS
Destination/Mask Nexthop     Flag    TimeStamp      Interface   Token
10.2.0.0/16      0.0.0.0     U  t[1150900568]  Vlan1       invalid
10.2.1.1/32      127.0.0.1   HU t[1150900568]  InLoop0     invalid
127.0.0.0/8      127.0.0.1   U  t[1150623094]  InLoop0     invalid
127.0.0.1/32     127.0.0.1   HU t[1150623094]  InLoop0     invalid
Table 2-1 Description on the fields of the display fib command
Total number of routes in the FIB table
Destination/Mask
Destination address/length of mask
Nexthop
Address of next hop
Flag
Flags of routes:
l      “U”—Usable route
l      “G”—Gateway route
l      “H”—Host route
l      “B”—Blackhole route
l      “D”—Dynamic route
l      “S”—Static route
l      “R”—Refused route
l      “L”—Route generated by ARP or ESIS
TimeStamp
Time stamp
Forward interface
Token
LSP index number
# Display FIB information passing ACL 2000
[Sysname] acl number 2000
[Sysname-acl-basic-2000] rule permit source 10.2.0.0 0.0.255.255
[Sysname-acl-basic-2000] display fib acl 2000
Route entry matched by access-list 2000:
 Summary counts: 2
 Flag:
# Display all entries that contain the string 127 and start from the first one.
<Sysname> display fib | begin 127
 Flag:
# Display FIB information passing the IP prefix list abc0
[Sysname] ip ip-prefix abc0 permit 10.2.0.0 16
[Sysname] display fib ip-prefix abc0
Route Entry matched by prefix-list abc0:
 Summary count: 1
 Flag:
2.1.2  display fib ip-address
display fib ip-address1 [ { mask1 | mask-length1 } [ ip-address2 { mask2 | mask-length2 } | longer ] | longer ]
View
ip-address1, ip-address2: Destination IP address, in dotted decimal notation. ip-address1 and ip-address2 together determine an address range for the FIB entries to be displayed.
mask1, mask2: IP address mask.
mask-length1, mask-length2: Length of IP address mask.
longer: Displays FIB entries that match the specified address/mask and have masks longer than or equal to the mask that a user enters. If no masks are specified, FIB entries that match the natural network address and have the masks longer than or equal to the natural mask will be displayed.
Use the display fib ip-address command to display FIB entries that match the specified destination IP address.
# Display the FIB entries that match the natural network of 10.1.0.0 and have the masks longer than or equal to the natural mask.
<Sysname> display fib 10.1.0.0 longer
  Route Entry Count: 2
 Flag:
10.0.0.0/8       0.0.0.0     U   t[1141140133]  Vlan1       invalid
10.1.1.1/32      127.0.0.1   HU  t[1141140133]  InLoop0     invalid
For description about the above output, refer to Table 2-1.
2.1.3  display fib statistics
View
None
Use the display fib statistics command to display statistics about the FIB entries.
# View statistics about the FIB entries.
<Sysname> display fib statistics
Route Entry Count          : 2
Table 2-2 Description on the fields of the display fib statistics command
Route Entry Count
Number of FIB entries
2.1.4  display icmp statistics
View
None
Use the display icmp statistics command to display ICMP statistics.
Related commands: display ip interface, reset ip statistics.
# Display ICMP statistics.
<Sysname> display icmp statistics
  Input: bad formats   0                   bad checksum            0
         echo          5                   destination unreachable 0
         source quench 0                   redirects               0
         echo reply    10                  parameter problem       0
         timestamp     0                   information request     0
         mask requests 0                   mask replies            0
         time exceeded 0
  Output:echo          10                  destination unreachable 0
         echo reply    5                   parameter problem       0
         timestamp     0                   information reply       0
         time exceeded 0
Table 2-3 Description on the fields of the display icmp statistics command
bad formats
Number of input wrong format packets
bad checksum
Number of input wrong checksum packets
echo
Number of input/output echo packets
Number of input/output destination unreachable packets
source quench
Number of input/output source quench packets
redirects
Number of input/output redirection packets
echo reply
Number of input/output replies
parameter problem
Number of input/output parameter problem packets
timestamp
Number of input/output time stamp packets
information request
Number of input information request packets
mask requests
Number of input/output mask requests
mask replies
Number of input/output mask replies
information reply
Number of output information reply packets
time exceeded
Number of input/output expiration packets
2.1.5  display ip socket
display ip socket [ socktype sock-type ] [ task-id socket-id ]
View
socktype sock-type: Displays the socket information of this type. The sock type is in the range 1 to 3, corresponding to TCP, UDP and raw IP respectively.
task-id: Displays the socket information of this task. Task ID is in the range 1 to 100.
socket-id: Displays the information of the socket. Socket ID is in the range 0 to 3072.
Use the display ip socket command to display socket information.
# Display all socket information.
<Sysname> display ip socket
SOCK_STREAM:
Task = VTYD(60), socketid = 1, Proto = 6,
LA = 0.0.0.0:23, FA = 0.0.0.0:0,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 0, rb_cc = 0,
socket option = SO_ACCEPTCONN SO_KEEPALIVE SO_REUSEPORT SO_SENDVPNID(3073) SO_SETKEEPALIVE,
socket state = SS_PRIV SS_ASYNC
Task = HTTP(58), socketid = 1, Proto = 6,
LA = 0.0.0.0:80, FA = 0.0.0.0:0,
socket option = SO_ACCEPTCONN SO_REUSEPORT,
socket state = SS_PRIV SS_NBIO
Task = VTYD(60), socketid = 3, Proto = 6,
LA = 192.168.0.152:23, FA = 192.168.0.208:1099,
sndbuf = 8192, rcvbuf = 8192, sb_cc = 483, rb_cc = 0,
socket option = SO_KEEPALIVE SO_OOBINLINE SO_REUSEPORT SO_SENDVPNID(0) SO_SETKEEPALIVE,
socket state = SS_ISCONNECTED SS_PRIV SS_ASYNC
SOCK_DGRAM:
Task = AGNT(29), socketid = 1, Proto = 17,
LA = 0.0.0.0:161, FA = 0.0.0.0:0,
sndbuf = 9216, rcvbuf = 41600, sb_cc = 0, rb_cc = 0,
socket option = SO_UDPCHECKSUM SO_SENDVPNID(3073),
socket state = SS_PRIV SS_NBIO SS_ASYNC
Task = ROUT(86), socketid = 3, Proto = 17,
LA = 0.0.0.0:520, FA = 0.0.0.0:0,
sndbuf = 1024, rcvbuf = 256000, sb_cc = 0, rb_cc = 0,
socket option = SO_BROADCAST SO_REUSEPORT SO_UDPCHECKSUM SO_SETSRCADDR SO_SENDVPNID(0),
Task = RDSO(75), socketid = 1, Proto = 17,
LA = 0.0.0.0:1024, FA = 0.0.0.0:0,
socket option = SO_UDPCHECKSUM,
Task = TRAP(71), socketid = 1, Proto = 17,
LA = 0.0.0.0:1025, FA = 0.0.0.0:0,
sndbuf = 9216, rcvbuf = 0, sb_cc = 0, rb_cc = 0,
Task = RDSO(75), socketid = 2, Proto = 17,
LA = 0.0.0.0:1812, FA = 0.0.0.0:0,
SOCK_RAW:
Task = ROUT(86), socketid = 2, Proto = 65,
LA = 0.0.0.0, FA = 0.0.0.0,
sndbuf = 32767, rcvbuf = 256000, sb_cc = 0, rb_cc = 0,
socket option = 0,
Task = ROUT(86), socketid = 1, Proto = 2,
socket option = SO_SENDVPNID(0) SO_RCVVPNID(0),
Table 2-4 Description on the fields of the display ip socket command
SOCK_STREAM
TCP socket
SOCK_DGRAM
UDP socket
SOCK_RAW
raw IP socket
Task number
socketid
Socket ID
Proto
Protocol number of the socket
LA
Local address and local port number
FA
Remote address and remote port number
sndbuf
sending buffer size of the socket
rcvbuf
receiving buffer size of the socket
sb_cc
Current data size in the sending buffer (It is available only for TCP that can buffer data)
rb_cc
Data size currently in the receiving buffer
socket option
Socket option
socket state
Socket state
2.1.6  display ip statistics
View
None
Use the display ip statistics command to display statistics of IP packets.
# Display statistics of IP packets.
<Sysname> display ip statistics
  Input:   sum            7120             local             112
           bad protocol   0                bad format        0
           bad checksum   0                bad options       0
  Output:  forwarding     0                local             27
           dropped        0                no route          2
           compress fails 0
  Fragment:input          0                output            0
           dropped        0
           fragmented     0                couldn't fragment 0
  Reassembling:sum        0                timeouts          0
Table 2-5 Description on the fields of the display ip statistics command
Input:
sum
Total number of packets received
local
Total number of packets with destination being local
bad protocol
Total number of unknown protocol packets
bad format
Total number of packets with incorrect format
bad checksum
Total number of packets with incorrect checksum
bad options
Total number of packets with incorrect option
Output:
forwarding
Total number of packets forwarded
local
Total number of packets sent from the local
dropped
Total number of packets discarded
no route
Total number of packets for which no route is available
compress fails
Total number of packets failed to compress
Fragment:
input
Total number of fragments received
output
Total number of fragments sent
dropped
Total number of fragments dropped
fragmented
Total number of packets successfully fragmented
couldn't fragment
Total number of packets that failed to be fragmented
Reassembling
sum
Total number of packets reassembled
timeouts
Total number of reassembly timeout fragments
2.1.7  display tcp statistics
View
None
Use the display tcp statistics command to display statistics of TCP traffic.
Related commands: display tcp status, reset tcp statistics.
# Display statistics of TCP traffic.
<Sysname> display tcp statistics
Received packets:
     Total: 753
     packets in sequence: 412 (11032 bytes)
     window probe packets: 0, window update packets: 0
     checksum error: 0, offset error: 0, short error: 0
     duplicate packets: 4 (88 bytes), partially duplicate packets: 5 (7 bytes)
     out-of-order packets: 0 (0 bytes)
     packets of data after window: 0 (0 bytes)
     packets received after close: 0
     ACK packets: 481 (8776 bytes)
     duplicate ACK packets: 7, too much ACK packets: 0
Sent packets:
     Total: 665
     urgent packets: 0
     control packets: 5 (including 1 RST)
     window probe packets: 0, window update packets: 2
     data packets: 618 (8770 bytes) data packets retransmitted: 0 (0 bytes)
ACK-only packets: 40 (28 delayed)
Retransmitted timeout: 0, connections dropped in retransmitted timeout: 0
Keepalive timeout: 0, keepalive probe: 0, Keepalive timeout, so connections disconnected : 0
Initiated connections: 0, accepted connections: 0, established connections:0
Closed connections: 0 (dropped: 0, initiated dropped: 0)
Packets dropped with MD5 authentication: 0
Packets permitted with MD5 authentication: 0
Table 2-6 Description on the fields of the display tcp statistics command
Received packets:
Total
packets in sequence
Number of packets arriving in sequence
Number of window probe packets received
Number of window update packets received
checksum error
Number of checksum error packets received
offset error
Number of offset error packets received
short error
Number of received packets with length being too small
duplicate packets
Number of completely duplicate packets received
Number of partially duplicate packets received
Number of out-of-order packets received
Number of packets outside the receiving window
Number of packets that arrived after connection is closed
ACK packets
Number of ACK packets received
Number of duplicate ACK packets received
Number of ACK packets for data unsent
Sent packets:
Total
urgent packets
Number of urgent packets sent
control packets
Number of control packets sent
Number of window probe packets sent; in the brackets are resent packets
Number of window update packets sent
data packets
Number of data packets sent
Number of data packets retransmitted
ACK-only packets
Number of ACK packets sent; in brackets are delayed ACK packets
Number of retransmission timer timeouts
Number of connections broken due to retransmission timeouts
Keepalive timeout
Number of keepalive timer timeouts
keepalive probe
Number of keepalive probe packets sent
Number of connections broken due to timeout of keepalive timer
Number of connections initiated
Number of connections accepted
Number of connections established
Closed connections
Number of connections closed; in brackets are connections closed accidentally (before receiving SYN from the peer) and connections closed initiatively (after receiving SYN from the peer)
Number of packets dropped with MD5 authentication
Number of packets permitted with MD5 authentication
2.1.8  display tcp status
display tcp status
View
None
Use the display tcp status command to display status of all TCP connection for monitoring TCP connections.
# Display status of all TCP connections
<Sysname> display tcp status
*: TCP MD5 Connection
TCPCB            Local Add:port      Foreign Add:port        State
03e37dc4     0.0.0.0:4001            0.0.0.0:0           Listening
04217174     100.0.0.204:23      100.0.0.253:65508   Established
Table 2-7 Description on the fields of the display tcp status command
If the status information of a TCP connection contains *, the TCP adopts the MD5 algorithm for authentication.
TCPCB
TCP control block
Local Add:port
Local IP address and port number
Foreign Add:port
Remote IP address and port number
State of the TCP connection
2.1.9  display udp statistics
View
None
Use the display udp statistics command to display statistics of UDP packets.
Related commands: reset udp statistics.
# Display statistics of UDP packets.
<Sysname> display udp statistics
Received packets:
     Total: 0
     checksum error: 0
     shorter than header: 0, data length larger than packet: 0
     unicast(no socket on port): 0
     broadcast/multicast(no socket on port): 0
     not delivered, input socket full: 0
     input packets missing pcb cache: 0
Sent packets:
     Total: 0
Table 2-8 Description on the fields of the display udp statistics command
Received packets:
Total
Total number of UDP packets received
checksum error
shorter than header
Number of packets with data shorter than head
Number of packets with data longer than packet
Number of unicast packets with no socket on port
Number of broadcast/multicast packets without socket on port
Number of packets not delivered to upper layer due to socket buffer being full
Number of packets without matching PCB cache
Sent packets:
Total
Total number of UDP packets sent
2.1.10  ip forward-broadcast (interface view)
ip forward-broadcast [ acl acl-number ]
undo ip forward-broadcast
View
Interface view
acl acl-number: Number of an ACL from 2000 to 3999. From 2000 to 2999 are numbers for basic ACLs, and from 3000 to 3999 are numbers for advanced ACLs. Only directed broadcasts permitted by the ACL can be forwarded.
Use the ip forward-broadcast command to enable the interface to forward directed broadcasts.
Use the undo ip forward-broadcast command to disable an interface from forwarding directed broadcasts.
By default, an interface is disabled from forwarding directed broadcasts.
# Allow VLAN-interface 2 to forward directed broadcasts permitted by ACL 2001.
[Sysname-Vlan-interface2] ip forward-broadcast acl 2001
2.1.11  ip forward-broadcast (system view)
View
None
Use the ip forward-broadcast command to enable the device to receive directed broadcasts.
Use the undo ip forward-broadcast command to disable the device from receiving directed broadcasts.
By default, the feature is disabled from receiving directed broadcasts.
# Enable the device to receive directed broadcasts.
[Sysname] ip forward-broadcast
2.1.12  ip redirects enable
ip redirects enable
undo ip redirects
View
None
Use the ip redirects enable command to enable sending ICMP redirection packets.
Use the undo ip redirects command to disable sending ICMP redirection packets.
This feature is enabled by default.
# Disable sending ICMP redirection packets.
[Sysname] undo ip redirects
 The function is disabled!
2.1.13  ip ttl-expires enable
undo ip ttl-expires
View
None
Use the ip ttl-expires enable command to enable the sending of ICMP timeout packets.
Use the undo ip ttl-expires command to disable sending ICMP timeout packets.
Sending ICMP timeout packets is enabled by default.
If the feature is disabled, the device will not send TTL timeout ICMP packets, but still send “reassembly timeout” ICMP packets.
# Disable sending ICMP timeout packets.
[Sysname] undo ip ttl-expires
2.1.14  ip unreachables enable
undo ip unreachables
View
None
Use the ip unreachables enable command to enable the sending of ICMP destination unreachable packets.
Use the undo ip unreachables command to disable sending ICMP destination unreachable packets.
Sending ICMP destination unreachable packets is enabled by default.
If the feature is disabled, the device will not send network unreachable and source route failure ICMP packets, but still send other destination unreachable ICMP packets.
# Disable sending ICMP destination unreachable packets.
[Sysname] undo ip unreachables
2.1.15  reset ip statistics
reset ip statistics
View
None
Use the reset ip statistics command to clear statistics of IP packets.
Related commands: display ip interface, display ip statistics.
# Clear statistics of IP packets.
<Sysname> reset ip statistics
2.1.16  reset tcp statistics
View
None
Use the reset tcp statistics command to clear statistics of TCP traffic.
Related commands: display tcp statistics.
<Sysname> reset tcp statistics
2.1.17  reset udp statistics
View
None
Use the reset udp statistics command to clear statistics of UDP traffic.
# Display statistics of UDP traffic.
<Sysname> reset udp statistics
2.1.18  tcp timer fin-timeout
undo tcp timer fin-timeout
View
time-value: Length of the TCP finwait timer in seconds, ranging from 76 to 3,600.
Use the tcp timer fin-timeout command to configure the length of the TCP finwait timer.
Use the undo tcp timer fin-timeout command to restore the default.
By default, the length of the TCP finwait timer is 675 seconds.
Note that the actual length of the finwait timer is determined by the following formula:
Actual length of the finwait timer = (Configured length of the finwait timer – 75) + configured length of the synwait timer
Related commands: tcp timer syn-timeout, tcp window.
# Set the length of the TCP finwait timer to 800 seconds.
[Sysname] tcp timer fin-timeout 800
2.1.19  tcp timer syn-timeout
undo tcp timer syn-timeout
View
time-value: Length of the TCP finwait timer in seconds, ranging from 2 to 600.
Use the tcp timer syn-timeout command to configure the length of the TCP synwait timer.
Use the undo tcp timer syn-timeout command to restore the default.
By default, the length of the TCP synwait timer is 75 seconds.
Related commands: tcp timer fin-timeout, tcp window.
# Set the length of the TCP synwait timer to 80 seconds.
[Sysname] tcp timer syn-timeout 80
2.1.20  tcp window
tcp window window-size
undo tcp window
View
window-size: Receiving/sending buffer size of TCP connection in KB, ranging from 1 to 32.
Use the tcp window command to configure the receiving/sending buffer size of TCP connection.
Use the undo tcp window command to restore the default.
The TCP receiving/sending buffer is 8 KB by default.
Related commands: tcp timer fin-timeout, tcp timer syn-timeout.
# Configure the receiving/sending buffer of TCP connection as 3 KB.
[Sysname] tcp window 3
