H3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
HomeSupportSwitchesH3C S5500 Switch SeriesReference GuidesCommand ReferencesH3C S5500-EI Series Switches Command Manual-Release 2102(V1.01)
13-IPv6 Routing Commands
13-IPv6 Routing Commands 442 KB
Table of Contents
Chapter 1 IPv6 Static Routing Configuration Commands. 1-1
1.1 IPv6 Static Routing Configuration Commands. 1-1
1.1.1 delete ipv6 static-routes all 1-1
1.1.2 ipv6 route-static. 1-2
Chapter 2 IPv6 RIPng Configuration Commands. 2-1
2.1 RIPng Configuration Commands. 2-1
2.1.1 checkzero. 2-1
2.1.2 default cost 2-2
2.1.3 display ripng. 2-2
2.1.4 display ripng database. 2-4
2.1.5 display ripng interface. 2-5
2.1.6 display ripng route. 2-6
2.1.7 filter-policy export 2-7
2.1.8 filter-policy import 2-8
2.1.9 import-route. 2-9
2.1.10 maximum load-balancing. 2-10
2.1.11 preference. 2-10
2.1.12 ripng. 2-11
2.1.13 ripng default-route. 2-12
2.1.14 ripng enable. 2-13
2.1.15 ripng metricin. 2-13
2.1.16 ripng metricout 2-14
2.1.17 ripng poison-reverse. 2-15
2.1.18 ripng split-horizon. 2-15
2.1.19 ripng summary-address. 2-16
2.1.20 timers. 2-17
Chapter 3 IPv6 OSPFv3 Configuration Commands. 3-1
3.1 OSPFv3 Configuration Commands. 3-1
3.1.1 abr-summary. 3-1
3.1.2 area. 3-2
3.1.3 default cost 3-2
3.1.4 default-cost 3-3
3.1.5 display ospfv3. 3-4
3.1.6 display ospfv3 interface. 3-6
3.1.7 display ospfv3 lsdb. 3-7
3.1.8 display ospfv3 lsdb statistic. 3-10
3.1.9 display ospfv3 next-hop. 3-11
3.1.10 display ospfv3 peer 3-12
3.1.11 display ospfv3 peer statistic. 3-14
3.1.12 display ospfv3 request-list 3-15
3.1.13 display ospfv3 retrans-list 3-17
3.1.14 display ospfv3 routing. 3-19
3.1.15 display ospfv3 statistic. 3-20
3.1.16 display ospfv3 topology. 3-21
3.1.17 display ospfv3 vlink. 3-22
3.1.18 filter-policy export 3-24
3.1.19 filter-policy import 3-25
3.1.20 import-route. 3-26
3.1.21 log-peer-change. 3-27
3.1.22 maximum load-balancing. 3-28
3.1.23 ospfv3. 3-29
3.1.24 ospfv3 area. 3-29
3.1.25 ospfv3 cost 3-30
3.1.26 ospfv3 dr-priority. 3-31
3.1.27 ospfv3 mtu-ignore. 3-31
3.1.28 ospfv3 timer dead. 3-32
3.1.29 ospfv3 timer hello. 3-33
3.1.30 ospfv3 timer retransmit 3-34
3.1.31 ospfv3 trans-delay. 3-34
3.1.32 preference. 3-35
3.1.33 router-id. 3-36
3.1.34 silent-interface. 3-37
3.1.35 spf timers. 3-37
3.1.36 stub. 3-38
3.1.37 vlink-peer 3-39
Chapter 4 IPv6 IS-IS Configuration Commands. 4-1
4.1 IPv6 IS-IS Configuration Commands. 4-1
4.1.1 display isis route ipv6. 4-1
4.1.2 ipv6 default-route-advertise. 4-3
4.1.3 ipv6 enable. 4-4
4.1.4 ipv6 filter-policy export 4-5
4.1.5 ipv6 filter-policy import 4-6
4.1.6 ipv6 import-route. 4-7
4.1.7 ipv6 import-route isisv6 level-2 into level-1. 4-8
4.1.8 ipv6 maximum load-balancing. 4-9
4.1.9 ipv6 preference. 4-10
4.1.10 ipv6 summary. 4-11
4.1.11 isis ipv6 enable. 4-12
Chapter 5 IPv6 BGP Configuration Commands. 5-1
5.1 IPv6 BGP Configuration Commands. 5-1
5.1.1 balance. 5-1
5.1.2 bestroute as-path-neglect 5-1
5.1.3 bestroute compare-med. 5-2
5.1.4 bestroute med-confederation. 5-3
5.1.5 compare-different-as-med. 5-4
5.1.6 dampening. 5-4
5.1.7 default local-preference. 5-5
5.1.8 default med. 5-6
5.1.9 default-route imported. 5-7
5.1.10 display bgp ipv6 group. 5-8
5.1.11 display bgp ipv6 network. 5-9
5.1.12 display bgp ipv6 paths. 5-10
5.1.13 display bgp ipv6 peer 5-11
5.1.14 display bgp ipv6 routing-table. 5-12
5.1.15 display bgp ipv6 routing-table as-path-acl 5-14
5.1.16 display bgp ipv6 routing-table community. 5-15
5.1.17 display bgp ipv6 routing-table community-list 5-16
5.1.18 display bgp ipv6 routing-table dampened. 5-17
5.1.19 display bgp ipv6 routing-table dampening parameter 5-18
5.1.20 display bgp ipv6 routing-table different-origin-as. 5-19
5.1.21 display bgp ipv6 routing-table flap-info. 5-19
5.1.22 display bgp ipv6 routing-table peer 5-21
5.1.23 display bgp ipv6 routing-table regular-expression. 5-22
5.1.24 display bgp ipv6 routing-table statistic. 5-22
5.1.25 filter-policy export 5-23
5.1.26 filter-policy import 5-24
5.1.27 group. 5-25
5.1.28 import-route. 5-25
5.1.29 ipv6-family. 5-26
5.1.30 network. 5-27
5.1.31 peer advertise-community. 5-28
5.1.32 peer advertise-ext-community. 5-28
5.1.33 peer allow-as-loop. 5-29
5.1.34 peer as-number 5-30
5.1.35 peer as-path-acl 5-30
5.1.36 peer capability-advertise route-refresh. 5-31
5.1.37 peer connect-interface. 5-32
5.1.38 peer default-route-advertise. 5-33
5.1.39 peer description. 5-34
5.1.40 peer ebgp-max-hop. 5-34
5.1.41 peer fake-as. 5-35
5.1.42 peer filter-policy. 5-36
5.1.43 peer group. 5-37
5.1.44 peer ignore. 5-37
5.1.45 peer ipv6-prefix. 5-38
5.1.46 peer keep-all-routes. 5-39
5.1.47 peer log-change. 5-40
5.1.48 peer next-hop-local 5-40
5.1.49 peer preferred-value. 5-41
5.1.50 peer public-as-only. 5-42
5.1.51 peer reflect-client 5-43
5.1.52 peer route-limit 5-43
5.1.53 peer route-policy. 5-44
5.1.54 peer route-update-interval 5-45
5.1.55 peer substitute-as. 5-46
5.1.56 peer timer 5-47
5.1.57 preference. 5-48
5.1.58 reflect between-clients. 5-48
5.1.59 reflector cluster-id. 5-49
5.1.60 refresh bgp ipv6. 5-50
5.1.61 reset bgp ipv6. 5-51
5.1.62 reset bgp ipv6 dampening. 5-51
5.1.63 reset bgp ipv6 flap-info. 5-52
5.1.64 router-id. 5-53
5.1.65 synchronization. 5-53
5.1.66 timer 5-54
Chapter 6 Routing Policy Configuration Commands. 6-1
6.1 Routing Policy Common Configuration Commands. 6-1
6.2 IPv6 Routing Policy Configuration Commands. 6-1
6.2.1 apply ipv6 next-hop. 6-1
6.2.2 display ip ipv6-prefix. 6-2
6.2.3 if-match ipv6. 6-3
6.2.4 ip ipv6-prefix. 6-3
6.2.5 reset ip ipv6-prefix. 6-5
&  Note:
Throughout this chapter, the term “router” refers to a Layer 3 switch running routing protocols.
View
None
Use the delete ipv6 static-routes all command to delete all static routes including the default route.
When using this command, you will be prompted whether to continue the deletion and only after you confirm the deletion will the static routes be deleted.
Related commands: display ipv6 routing-table, ipv6 route-static.
# Delete all IPv6 static routes.
[Sysname] delete ipv6 static-routes all
This will erase all ipv6 static routes and their configurations, you must reconfigure all static routes
Are you sure?[Y/N]Y
ipv6 route-static ipv6-address prefix-length [ interface-type interface-number ] nexthop-address [ preference preference-value ]
undo ipv6 route-static ipv6-address prefix-length [ interface-type interface-number ] [ nexthop-address ] [ preference preference-value ]
View
ipv6-address prefix-length: IPv6 address and prefix length.
interface-type interface-number: Interface type and interface number of the output interface.
nexthop-address: Next hop IPv6 address.
preference-value: Route preference value, in the range of 1 to 255. The default is 60.
Use the ipv6 route-static command to configure an IPv6 static route.
Use the undo ipv6 route-static command to remove an IPv6 static route.
An IPv6 static route that has the destination address configured as ::/0 (a prefix length of 0) is the default IPv6 route. If the destination address of an IPv6 packet does not match any entry in the routing table, this default route will be used to forward the packet.
Related commands: display ipv6 routing-table, delete ipv6 static-routes all.
# Configure a static IPv6 route, with the destination address being 1:1:2::/24 and next hop being 1:1:3::1.
[Sysname] ipv6 route-static 1:1:2:: 24 1:1:3::1
&  Note:
l      Throughout this chapter, the term “router” refers to a Layer 3 switch running routing protocols.
l      The S5500-EI series support only single RIPng process.
2.1.1  checkzero
checkzero
undo checkzero
View
RIPng view
None
Use the checkzero command to enable the zero field check on RIPng packets.
Use the undo checkzero command to disable the zero field check.
The zero field check is enabled by default.
Some fields in RIPng packet headers must be zero. These fields are called zero fields.  You can enable the zero field check on RIPng packet headers. If any such field contains a non-zero value, the RIPng packet will be discarded.
# Disable the zero field check on RIPng packet headers of RIPng 100.
[Sysname] ripng 100
[Sysname-ripng-100] undo checkzero
2.1.2  default cost
default cost cost
undo default cost
View
RIPng view
cost: Default metric of redistributed routes, in the range of 0 to 16.
Use the default cost command to specify the default metric of redistributed routes.
Use the undo default cost command to restore the default.
By default, the default metric of redistributed routes is 0.
The specified default metric applies to routes redistributed by the import-route command that has no metric specified.
Related commands: import-route.
# Set the default metric of redistributed routes to 2.
[Sysname] ripng 100
[Sysname-ripng-100] default cost 2
2.1.3  display ripng
display ripng [ process-id ]
View
process-id: RIPng process ID, in the range of 1 to 65535.
Use the display ripng command to display the running status and configuration information of a RIPng process. If process-id is not specified, information of all RIPng processes will be displayed.
# Display the running status and configuration information of all configured RIPng processes.
<Sysname> display ripng
    RIPng process : 1
       Preference : 100
       Checkzero : Enabled
       Default Cost : 0
       Maximum number of balanced paths : 3
       Update time   :   30 sec(s)  Timeout time           :  180 sec(s)
       Suppress time :  120 sec(s)  Garbage-Collect time :  240 sec(s)
       Number of periodic updates sent : 0
       Number of trigger updates sent : 0
Table 2-1 Description on the fields of the display ripng command
RIPng Process
RIPng process ID
Preference
RIPng route priority
Checkzero
Whether zero field check for RIPng packet headers is enabled
Default Cost
Maximum number of load balanced routes
Update time
RIPng updating interval, in seconds
Timeout time
RIPng timeout interval, in seconds
Suppress time
RIPng suppress interval, in seconds
RIPng garbage collection interval, in seconds
Number of triggered updates sent
display ripng process-id database
View
Use the display ripng database command to display all active routes in the RIPng advertising database, which are sent in normal RIPng update messages.
# Display the active routes in the database of RIPng process 100.
<Sysname> display ripng 100 database
   2001:7B::2:2A1:5DE/64,
        cost 4, Imported
   1:13::/120,
        cost 4, Imported
   1:32::/120,
        cost 4, Imported
   1:33::/120,
        cost 4, Imported
   100::/32,
       via FE80::200:5EFF:FE04:3302, cost 2
   3FFE:C00:C18:1::/64,
       via FE80::200:5EFF:FE04:B602, cost 2
       via FE80::200:5EFF:FE04:B601, cost 2
   3FFE:C00:C18:2::/64,
   3FFE:C00:C18:3::/64,
   4000:1::/64,
   4000:2::/64,
Table 2-2 Description on fields of the display ripng database command
IPv6 destination address/prefix length
via
cost
Route metric value
Imported
Routes learnt from other routing protocols
display ripng process-id interface [ interface-type interface-number ]
View
interface-type interface-number: Specified an interface.
Use the display ripng interface command to display the interface information of the RIPng process.
If no interface is specified, information about all interfaces of the RIPng process will be displayed.
# Display the interface information of RIPng process 1.
<Sysname> display ripng 1 interface
Interface-name: Vlan-interface100
         Link Local Address: FE80::200:5EFF:FE19:3E00
         Split-horizon: on            Poison-reverse: off
         MetricIn: 0                  MetricOut: 1
         Default route: off
Table 2-3 Description on the fields of the display ripng interface command
Interface-name
Name of an interface running RIPng.
Link Local Address
Link-local address of an interface running RIPng
Split-horizon
Indicates whether the split horizon function is enabled (on: Enabled off: Disabled).
Poison-reverse
Indicates whether the poison reverse function is enabled (on: Enabled off: Disabled).
MetricIn/MetricOut
Additional metric to incoming and outgoing routes
Default route
l      Only/Originate: Only means that the interface advertises only default route. Originate means that the default route and other RIPng routes are advertised.
l      Off, indicates that no default route is advertised or the garbage-collect time expires after the default route advertisement was disabled.
l      In garbage-collect status: With default route advertisement disabled, the interface advertises the default route with metric 16 during the garbage-collect time.
display ripng process-id route
View
Use the display ripng route command to display all RIPng routes and timers associated to each route of a RIPng process.
# Display the routing information of RIPng process 100.
<Sysname> display ripng 100 route
   Route Flags: A - Aging, S - Suppressed, G - Garbage-collect
 Peer FE80::20F:E2FF:FE00:220A  on Vlan-interface100
 Dest 4:3::/64,
     via FE80::20F:E2FF:FE00:220A, cost  1, tag 0, A, 34 Sec
Table 2-4 Description on the fields of the display ripng route command
Peer
Neighbor connected to the interface
Dest
via
cost
Routing metric value
tag
Route tag
Sec
Time that a route entry stays in a particular state
“A”
The route is in the aging state
“S”
The route is in the suppressed state
“G”
The route is in the Garbage-collect state
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ protocol [ process-id ] ]
View
RIPng view
acl6-number: Specifies the number of an ACL to filter advertised routing information, in the range of 2000 to 3999.
ipv6-prefix ipv6-prefix-name: Specifies the name of an IPv6 prefix list used to filter routing information, a string of 1 to 19 characters.
protocol: Filter routes redistributed from a routing protocol, currently including bgp4+, direct, isisv6, ospfv3, ripng, and static
process-id: Process number of the specified routing protocol, in the range of 1 to 65535. This argument is specified only when the routing protocol is ripng, ospfv3, or isisv6.
Use the filter-policy export command to define an outbound route filtering policy. Only routes passing the filter can be advertised in the update messages.
Use the undo filter-policy export command to restore the default.
By default, RIPng does not filter any outbound routing information.
With the protocol argument specified, only routing information redistributed from the specified routing protocol will be filtered. Otherwise, all outgoing routing information will be filtered.
# Use IPv6 prefix list Filter 2 to filter advertised RIPng updates.
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy ipv6-prefix Filter2 export
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } import
undo filter-policy import
View
RIPng view
acl6-number: Specifies the number of an ACL to filter incoming routing information, in the range of 2000 to 3999.
ipv6-prefix ipv6-prefix-name: Specifies the name of an IPv6 Prefix list to filter incoming routes, in the range 1 to 19 characters.
Use the filter-policy import command to define an inbound route filtering policy. Only routes which match the filtering policy can be received.
Use the undo filter-policy import command to disable inbound route filtering.
By default, RIPng does not filter incoming routing information.
# Reference IPv6 prefix list Filter1 to filter incoming RIPng updates.
[Sysname] ripng 100
[Sysname-ripng-100] filter-policy ipv6-prefix Filter1 import
2.1.9  import-route
import-route protocol [ process-id ] [ allow-ibgp ] [ cost cost | route-policy route-policy-name ] *
undo import-route protocol [ process-id ]
View
RIPng view
protocol: Specifies a routing protocol from which to redistribute routes. Currently, it can be bgp4+, direct, isisv6, ospfv3, or static.
process-id: Process number of the specified routing protocol, in the range of 1 to 65535, with the default as 1. This argument is available only when the routing protocol is isisv6, ospfv3.
cost: Routing metric of redistributed routes, in the range of 0 to 16. If cost value is not specified, the metric is the default metric specified by the default cost command.
route-policy route-policy-name: Specifies a routing policy by its name with 1 to 19 characters.
allow-ibgp: Optional keyword when the specified protocol is bgp4+. The import-route bgp4+ command redistributes only EBGP routes. The import-route bgp4+ allow-ibgp command redistributes additionally IBGP routes, thus be cautious when using it.
Use the import-route command to redistribute routes from another routing protocol.
Use the undo import-route command to disable redistributing routes from another routing protocol.
By default, RIPng does not redistribute routes from other routing protocols.
l           You can configure a routing policy to redistribute only needed routes.
l           You can specify a cost for redistributed routes using keyword cost.
Related commands: default cost.
# Redistribute IPv6-IS-IS routes (process 7) and specify the metric as 7.
[Sysname] ripng 100
[Sysname-ripng-100] import-route isisv6 7 cost 7
maximum load-balancing number
undo maximum load-balancing
View
RIPng view
number: Maximum number of equal-cost load-balanced routes. Its value is in the range 1 to 4.
Use the maximum load-balancing command to specify the maximum number of equal cost routes for load balancing.
Use the undo maximum load-balancing command to restore the default.
By default, the maximum number of equal cost routes for load balancing is 4.
&  Note:
Configure the maximum number according to the memory size.
# Set the maximum number of load balanced routes with equal cost to 2.
[Sysname] ripng 100
[Sysname-ripng-100] maximum load-balancing 2
# Restore the default.
[Sysname-ripng-100] undo maximum load-balancing
2.1.11  preference
preference [ route-policy route-policy-name ] preference
undo preference [ route-policy ]
View
RIPng view
route-policy-name: Name of a routing policy, in the range of 1 to 19 characters.
preference: RIPng route priority, in the range of 1 to 255.
Use the preference command to specify the RIPng route priority.
Use the undo preference command to restore the default.
By default, the priority of a RIPng route is 100.
Using the route-policy keyword can set a priority for routes filtered in by the routing policy:
l           If a priority is set in the routing policy, the priority applies to matched routes, and the priority set by the preference command applies to routes not matched.
l           If no priority is set in the routing policy, the one set by the preference command applies to all routes.
# Set the RIPng route priority to 120.
[Sysname] ripng 100
[Sysname-ripng-100] preference 120
# Restore the default RIPng route priority.
[Sysname-ripng-100] undo preference
2.1.12  ripng
undo ripng [ process-id ]
View
process-id: RIPng process ID, in the range of 1 to 65535. The default value is 1.
Use the ripng command to create a RIPng process and enter RIPng view.
Use the undo ripng command to disable a RIPng process.
By default, no RIPng process is enabled.
# Create RIPng process 100 and enter its view.
[Sysname] ripng 100
[Sysname-ripng-100]
# Disable RIPng process 100.
[Sysname] undo ripng 100
ripng default-route { only | originate } [ cost cost ]
undo ripng default-route
View
Interface view
only: Indicates that only the IPv6 default route (::/0) is advertised via the interface.
originate: Indicates that the IPv6 default route (::/0) is advertised without suppressing other routes.
cost: Metric of the advertised default route, in the range of 1 to 15, with a default value of 1.
Use the ripng default-route command to advertise a default route with the specified routing metric to a RIPng neighbor.
Use the undo ripng default-route command to stop advertising and forwarding the default route.
By default, a RIP process does not advertise any default route.
After you execute this command, the generated RIPng default route is advertised in a route update over the specified interface. This IPv6 default route is advertised without considering whether it already exists in local IPv6 routing table.
# Advertise only the default route via VLAN-interface 100.
[Sysname-Vlan-interface100] ripng default-route only
# Advertise the default route together with other routes via VLAN-interface 101.
[Sysname] interface vlan-interface 101
[Sysname-Vlan-interface101] ripng default-route originate
2.1.14  ripng enable
ripng process-id enable
undo ripng enable
View
Interface view
Use the ripng enable command to enable RIPng on the specified interface.
Use the undo ripng enable command to disable RIPng on the specified interface.
By default, RIPng is disabled on an interface.
# Enable RIPng100 on VLAN-interface 100.
[Sysname-Vlan-interface100] ripng 100 enable
ripng metricin value
undo ripng metricin
View
Interface view
value: Additional metric for received routes, in the range of 0 to 16.
Use the ripng metricin command to specify an additional metric for received RIPng routes.
Use the undo ripng metricin command to restore the default.
By default, the additional metric to received routes is 0.
Related commands: ripng metricout.
# Specify the additional routing metric as 12 for RIPng routes received by VLAN-interface 100.
[Sysname-Vlan-interface100] ripng metricin 12
ripng metricout value
undo ripng metricout
View
Interface view
value: Additional metric to advertised routes, in the range of 1 to 16.
Use the ripng metricout command to configure an additional metric for RIPng routes advertised by an interface.
Use the undo rip metricout command to restore the default.
The default additional routing metric is 1.
Related commands: ripng metricin.
# Set the additional metric to 12 for routes advertised by VLAN-interface 100.
[Sysname-Vlan-interface100] ripng metricout 12
undo ripng poison-reverse
View
Interface view
None
Use the rip poison-reverse command to enable the poison reverse function.
Use the undo rip poison-reverse command to disable the poison reverse function.
By default, the poison reverse function is disabled.
Enable the poison reverse function for RIPng update messages on VLAN-interface 100.
[Sysname-Vlan-interface100] ripng poison-reverse
ripng split-horizon
undo ripng split-horizon
View
Interface view
None
Use the rip split-horizon command to enable the split horizon function.
Use the undo rip split-horizon command to disable the split horizon function.
By default, the split horizon function is enabled.
Note that:
l           The split horizon function is necessary for preventing routing loops. Therefore, you are not recommended to disable it.
l           In special cases, make sure that it is necessary to disable the split horizon function before doing so.
&  Note:
If both the poison reverse and split horizon functions are enabled, only the poison reverse function takes effect.
Enable the split horizon function on Van-interface100.
[Sysname-Vlan-interface100] ripng split-horizon
ripng summary-address ipv6-address prefix-length
undo ripng summary-address ipv6-address prefix-length
View
Interface view
ipv6-address: Destination IPv6 address prefix of the summary route.
prefix-length: Destination IPv6 address prefix length of the summary route, in the range 0 to 128.
Use the ripng summary-address command to configure a summary advertised through the interface.
Use the undo ripng summary-address command to remove the summary.
If the prefix and the prefix length of a route match the IPv6 prefix, the IPv6 prefix will be advertised instead. Thus, one route can be advertised on behalf of many routes. After summarization, the summary route cost is the lowest cost among summarized routes.
# Assign an IPv6 address with the 64-bit prefix to VLAN-interface 100 and configure a summary with the 35-bit prefix length.
[Sysname-Vlan-interface100] ipv6 address 2001:200::3EFF:FE11:6770/64
[Sysname-Vlan-interface100] ripng summary-address 2001:200:: 35
2.1.20  timers
timers { garbage-collect garbage-collect-value | suppress suppress-value | timeout timeout-value | update update-value }*
undo timers { garbage-collect | suppress | timeout | update }*
View
RIPng view
garbage-collect-value: Interval of the garbage-collect timer in seconds, in the range of 1 to 86400.
suppress-value: Interval of the suppress timer in seconds, in the range of 0 to 86400.
timeout-value: Interval  of the timeout timer in seconds, in the range of 1 to 86400.
update-value: Interval of the update timer in seconds, in the range of 1 to 86400.
Use the timers command to configure RIPng timers.
Use the undo timers command to restore the default.
By default, the garbage-collect timer is 120 seconds, the suppress timer 120 seconds, the timeout timer 180 seconds, and the update timer 30 seconds.
RIPng is controlled by the above four timers.
l           The update timer defines the interval between update messages.
l           The timeout timer defines the route aging time. If no update message related to a route is received within the aging time, the metric of the route is set to 16 in the routing table.
l           The suppress timer defines how long a RIPng route stays in the suppressed state. When the metric of a route is 16, the route enters the suppressed state. In the suppressed state, only routes which come from the same neighbor and whose metric is less than 16 will be received by the router to replace unreachable routes.
l           The garbage-collect timer defines the interval from when the metric of a route becomes 16 to when it is deleted from the routing table. During the garbage-collect timer length, RIPng advertises the route with the routing metric set to 16. If no update message is announced for that route before the garbage-collect timer expires, the route will completely be deleted from the routing table.
Note that:
l           You are not recommended to change the default values of these timers under normal circumstances.
l           The lengths of these timers must be kept consistent on all routers and access servers in the network
# Configure the update, timeout, suppress, and garbage-collect timers as 5s, 15s, 15s and 30s.
[Sysname] ripng 100
[Sysname-ripng-100] timers update 5
[Sysname-ripng-100] timers timeout 15
[Sysname-ripng-100] timers suppress 15
[Sysname-ripng-100] timers garbage-collect 30
&  Note:
l      The S5500-EI series support only single OSPFv3 process.
3.1.1  abr-summary
abr-summary ipv6-address prefix-length [ not-advertise ]
undo abr-summary ipv6-address prefix-length
View
OSPFv3 area view
ipv6-address: Destination IPv6 address of the summary route.
prefix-length: Prefix length of the destination IPv6 address, in the range 0 to 128. This argument specifies the number of consecutive 1s of the prefix, which defines the network ID.
not-advertise: Specifies not to advertise the summary IPv6 route.
Use the abr-summary command to configure an IPv6 summary route on an area border router.
Use the undo abr-summary command to remove an IPv6 summary route. Then the summarized routes are advertised.
By default, no route summarization is available on an ABR.
You can use this command only on an ABR to configure a summary route for the area. The ABR advertises only the summary route to other areas. Multiple contiguous networks may be available in an area, where you can summarize them with one route for advertisement.
# Summarize networks 2000:1:1:1::/64 and 2000:1:1:2::/64 in Area 1 with 2000:1:1::/48.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 1
[Sysname-ospfv3-1-area-0.0.0.1] abr-summary 2000:1:1:: 48
3.1.2  area
area area-id
View
OSPFv3 view
area-id: ID of an area, a decimal integer (in the range of 0 to 4294967295 and changed to IPv4 address format by the system) or an IPv4 address.
Use the area command to enter OSPFv3 area view.
&  Note:
The undo form of the command is not available. An area is removed automatically if there is no configuration and no interface is up in the area.
# Enter OSPFv3 Area 0 view.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 0
[Sysname-ospfv3-1-area-0.0.0.0]
3.1.3  default cost
default cost value
undo default cost
View
OSPFv3 view
value: Specifies a default cost for redistributed routes, in the range of 1 to 16777214.
Use the default cost command to configure a default cost for redistributed routes.
By default, the default cost is 1.
You need to configure the default cost value for redistributed routes to advertise them throughout the whole AS.
If multiple OSPFv3 processes are available, use of this command takes effect for the current process only.
# Specify the default cost for redistributed routes as 10.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] default cost 10
3.1.4  default-cost
default-cost value
undo default-cost
View
OSPFv3 area view
value: Specifies a cost for the default route advertised to the stub area, in the range of 0 to 65535. The default is 1.
Use the default-cost command to specify the cost of the default route to be advertised to the stub area.
Use the undo-default-cost command to restore the default value.
Use of this command is only available on the ABR that is connected to a stub area.
You have two commands to configure a stub area: stub, defaulted-cost. You need to use the stub command on routers connected to a stub area to configure the area as stub.
If multiple OSPFv3 processes are running, use of this command takes effect only for the current process.
Related commands: stub.
# Configure Area1 as a stub area, and specify the cost of the default route advertised to the stub area as 60.
[Sysname] ospfv3
[Sysname-ospfv3-1-area-0.0.0.1] stub
[Sysname-ospfv3-1-area-0.0.0.1] default-cost 60
display ospfv3 [ process-id ]
View
process-id: Specifies the ID of an OSPFv3 process, ranging from 1 to 65535.
Use the display ospfv3 command to display the brief information of an OSPFv3 process. If no process ID is specified, OSPFv3 brief information about all processes will be displayed.
# Display brief information about all OSPFv3 processes.
<Sysname> display ospfv3
Routing Process "OSPFv3 (1)" with ID 0.0.0.0
 SPF schedule delay 5 secs, Hold time between SPFs 10 secs
 Minimum LSA interval 5 secs, Minimum LSA arrival 1 secs
 Number of external LSA 0. These external LSAs' checksum Sum 0x0000
 Number of AS-Scoped Unknown LSA 0
 Number of LSA originated 0
 Number of LSA received 0
 Number of areas in this router is 2
  Area BACKBONE(0)
       Number of interfaces in this area is 1
       SPF algorithm executed 1 times
       Number of LSA 0. These LSAs' checksum Sum 0x0000
       Number of Unknown LSA 0
  Area 0.0.0.1
       Number of interfaces in this area is 0
Table 3-1 Description on the fields of the display ospfv3 command
OSPFv3 process is 1, and router ID is 0.0.0.0.
SPF schedule delay
Delay interval of SPF calculation
Hold time between SPF calculations
Minimum interval for generating LSAs
Minimum LSA arrival
Minimum LSA repeat arrival interval
Number of ASE LSAs
These external LSAs’ checksum Sum
Sum of all the ASE LSAs’ checksum
Number of LSAs with unknown flooding scope
Number of LSAs originated
Number of LSAs received
Number of areas this router is attached to
Area
Area ID
Number of interfaces attached to this area
SPF algorithm is executed 1 time
Number of LSA
Number of LSAs
These LSAs’ checksum Sum
Sum of all LSAs’ checksum
Number of unknown LSAs
display ospfv3 interface [ interface-type interface-number | statistic ]
View
interface-type interface-number: Interface type and interface number.
statistic: Displays the interface statistics.
Use the display ospfv3 interface command to display OSPFv3 interface information.
# Display OSPFv3 interface information of VLAN-interface 200.
<Sysname >display ospfv3 interface Vlan-interface 200
Vlan-interface200 is up, line protocol is up
  Interface ID 11665607
  IPv6 Prefixes
    FE80::20F:E2FF:FE00:5 (Link-Local Address)
    2001:1::2
  OSPFv3 Process (1), Area 0.0.0.1, Instance ID 0
    Router ID: 1.1.1.1, Network Type: BROADCAST, Cost: 1
    Transmit Delay is 1 sec, State: DR, Priority: 1
    Designated Router (ID) 1.1.1.1
      Interface Address: FE80::20F:E2FF:FE00:5
    Backup Designated Router (ID): 2.2.2.2
      Interface Address: FE80::20F:E2FF:FE00:2205
    Timer interval configured, Hello: 10, Dead: 40, Wait: 40, Retransmit: 5
      Hello due in 00:00:08
    Neighbor Count is 1, Adjacent neighbor count is 1
Table 3-2 Description on the fields of the display ospfv3 interface command
Interface ID
Interface ID
IPv6 Prefixes
IPv6 Prefix
OSPFv3 Process
OSPFv3 Process
Area
Area ID
Instance ID
Instance ID
Router ID
Router ID
Network Type
Network type of the interface
Cost
Cost value of the interface
Transmit Delay
Transmission delay of the interface
Interface state
Priority
DR priority of the interface
ID of the designated router on this link
ID of the backup designated router on this link
Interface Address
Interface address
Time intervals in seconds configured on the interface, Hello: 10, Dead: 40, Wait: 40, Retransmit: 5
Hello packet will be sent in 8 seconds
Neighbor Count
Number of Neighbors on the interface
Number of Adjacencies on the interface
display ospfv3 [ process-id ] lsdb [ [ external | inter-prefix | inter-router | intra-prefix | link | network | router ] [ link-state-id ] [ originate-router router-id ] | total ]
View
process-id: Specifies ID of an OSPFv3 process, ranging from 1 to 65535.
external: Specifies to display information about AS-external LSAs.
inter-prefix: Specifies to display information about Inter-area-prefix LSAs.
inter-router: Specifies to display information about Inter-area-router LSAs.
intra-prefix: Specifies to display information about Intra-area-prefix LSAs.
link: Specifies to display information about Link-LSAs.
network: Specifies to display information about Network-LSAs.
router: Specifies to display information about Router-LSAs.
link-state-id: Link state ID, an IPv4 address.
originate-router router-id: The ID of the advertising router .
total: Displays the LSA statistics information in the LSDB.
Use the display ospfv3 lsdb command to display OSPFv3 LSDB information.
# Display OSPFv3 LSDB information.
<Sysname> display ospfv3 lsdb
            OSPFv3 Router with ID (5.5.5.5) (Process 1)
               Link-LSA (Interface Vlan-interface100)
Link State ID   Origin Router    Age   Seq#     CkSum  Prefix
0.15.0.9        5.5.5.5          0304  0x80000001 0x5b6a      1
0.15.0.9        6.6.6.6          0311  0x80000001 0x6956      1
               Router-LSA (Area 0.0.0.0)
Link State ID   Origin Router    Age   Seq#     CkSum    Link
0.0.0.0         5.5.5.5          0263  0x80000002 0x823f      1
0.0.0.0         6.6.6.6          0264  0x80000003 0x625a      1
Table 3-3 Description on the fields of the display ospfv3 lsdb command
Link-LSA
Type 8 LSA
Link State ID
Link State ID
Origin Router
Originating Router
Age
Age of LSAs
Seq#
LSA sequence number
CkSum
LSA Checksum
Prefix
Number of Prefixes
Router-LSA
Router-LSA
Link
Number of links
Network-LSA
Network-LSA
Intra-Area-Prefix-LSA
Type 9 LSA
Reference
Type of referenced LSA
# Display Link-local LSA information in the LSDB.
<Sysname> display ospfv3 lsdb link
            OSPFv3 Router with ID (4.4.4.4) (Process 1)
                Link-LSA (Interface Vlan-interface400)
  LS age            : 1536
  LS Type           : Link-LSA
  Link State ID     : 0.178.1.143
  Originating Router: 3.3.3.3
  LS Seq Number     : 0x80000003
  Checksum          : 0x22A7
  Length            : 56
  Priority          : 1
  Options           : 0x000011 (-|R|-|-|-|V6)
  Link-Local Address: FE80::2E0:FCFF:FE00:242A
  Number of Prefixes: 1
      Prefix        : 2001:2::/64
      Prefix Options: 0 (-|-|-|-)
  LS age            : 1558
  LS Type           : Link-LSA
  Originating Router: 4.4.4.4
  Checksum          : 0x4A6A
  Length            : 56
  Priority          : 1
  Link-Local Address: FE80::2E0:FCFF:FE00:550A
Table 3-4 Description on the fields of the display ospfv3 lsdb command
LS age
Age of LSA
LS Type
Type of LSA
Originating Router
Originating Router
LS Seq Number
LSA Sequence Number
Checksum
LSA Checksum
Length
LSA Length
Priority
Router Priority
Options
Options
Link-Local Address
Link-Local Address
Number of Prefixes
Number of Prefixes
Prefix
Address prefix
Prefix Options
Prefix options
View
None
Use the display ospfv3 lsdb statistic command to display LSA statistics in the OSPFv3 LSDB.
# Display OSPFv3 LSDB statistics.
<System> display ospfv3 lsdb statistic
            OSPFv3 Router with ID (1.1.1.1) (Process 1)
                           LSA Statistics
Area ID         Router   Network  InterPre InterRou IntraPre Link     ASE
0.0.0.0         2        1        1        0        1
0.0.0.1         1        0        1        0        1
Total           3        1        2        0        2                3        0
Table 3-5 Descriptions on the fields of the display ospfv3 lsdb statistic command
Area ID
Area ID
Router
Router-LSA number
Network
Network-LSA number
InterPre
Inter-Area-Prefix-LSA number
InterRou
Inter-Area-Router-LSA number
IntraPre
Intra-Area-Prefix-LSA number
Link
Link-LSA number
ASE
AS-external-LSA number
Total
Total LSA number
display ospfv3 [ process-id ] next-hop
View
Use the display ospfv3 next-hop command to display OSPFv3 next hop information.
If no process is specified, next hop information of all OSPFv3 processes is displayed.
# Display OSPFv3 next hop information.
<Sysname> display ospfv3 next-hop
            OSPFv3 Router with ID (2.2.2.2) (Process 1)
Neighbor-Id     Next-Hop                              Interface   RefCount
1.1.1.1         FE80::20F:E2FF:FE00:1                Vlan100     1
Table 3-6 Description on the fields of the display ospfv3 next-hop command
Neighbor-Id
Neighboring router ID
Next-hop
Next-hop address
Outbound interface
RefCount
Reference count
display ospfv3 [ process-id ] [ area area-id ] peer [ [ interface-type interface-number ] [ verbose ] | peer-router-id ]
View
area: Specifies to display neighbor information of the specified area.
area-id: The ID of an area, a decimal integer that is translated into IPv4 address format by the system (in the range of 0 to 4294967295) or an IPv4 address.
interface-type interface-number: interface type and number.
verbose: Display detailed neighbor information.
peer-router-id: Router-ID of the specified neighbor.
Use the display ospfv3 peer command to display OSPFv3 neighbor information.
l           If no area-id is specified, the neighbor information of all areas is displayed.
l           If no process-id is specified, the information of all processes is displayed.
l           If no interface or neighbor Router-ID is specified, the neighbor information of all interfaces is displayed.
# Display the neighbor information of OSPFv3 process 1 on an interface.
<Sysname> display ospfv3 1 peer Vlan-interface 400
                      OSPFv3 Process (1)
OSPFv3 Area (0.0.0.2)
Neighbor ID     Pri   State            Dead Time   Interface  Instance ID
3.3.3.3         1     Full/Backup      00:00:38    Vlan400        0
Table 3-7 Description on the fields of the display ospfv3 peer command
Neighbor ID
Neighbor ID
Pri
Priority of neighbor router
Neighbor state
Dead Time
Dead time remained
Interface connected to the neighbor
Instance ID
Instance ID
# Display detailed neighbor information of OSPFv3 process 1 of an interface.
<Sysname> display ospfv3 1 peer Vlan-interface 400 verbose
                      OSPFv3 Process (1)
 Neighbor: 3.3.3.3, interface address: FE80::2E0:FCFF:FE00:242A
    In the area 0.0.0.2 via interface Vlan-interface400
    DR is 4.4.4.4 BDR is 3.3.3.3
    Options is 0x000011 (-|R|-|-|-|V6)
    Dead timer due in 00:00:35
    Database Summary List 0
    Link State Request List 0
    Link State Retransmission List 0
Table 3-8 Description on the fields of the display ospfv3 peer verbose command
Neighbor
Neighbor ID
interface address
Interface address
In the area 0.0.0.2 via interface vlan-interface 400
Interface VLAN-interface 400 belongs to area 1.
DR is 4.4.4.4. BDR is 3.3.3.3
The option is 0x000011 (-|R|-|-|-|V6).
Dead timer due in 35 seconds
Number of LSAs sent in DD packet
Number of LSAs in the link state request list
Number of LSAs in the link state retransmission list
View
None
Use the display ospfv3 peer statistic command to display information about all OSPFv3 neighbors on the router, that is, numbers of neighbors in different states.
# Display information about all OSPFv3 neighbors.
<Sysname> display ospfv3 peer statistic
                           Neighbor Statistics
Area ID         Down     Init     2-way    ExStar   Exchange Loading  Full
0.0.0.0         0        0         0         0        0           0         1
Total           0        0         0         0        0            0         1
Table 3-9 Description on the fields of the display ospfv3 peer statistic command
Area ID
Area ID
Down
In this state, neighbor initial state, the router has not received any information from a neighboring router for a period of time.
Init
In this state, the device received a Hello packet from the neighbor but the packet contains no Router ID of the neighbor. Mutual communication is not setup.
2-Way
Indicates mutual communication between the router and its neighbor is available. DR/BDR election is finished under this state (or higher).
ExStar
In this state, the router decides on the initial DD sequence number and master/slave relationship of the two parties.
Exchange
In this state, the router exchanges DD packets with the neighbor.
Loading
In this state, the router sends LSRs to request the neighbor for needed LSAs.
Full
Indicates LSDB synchronization has been accomplished between neighbors.
Total
Total number of neighbors under the same state
display ospfv3 [ process-id ] request-list [ { external | inter-prefix | inter-router | intra-prefix | link | network | router } [ link-state-id ] [ originate-router ip-address ] | statistics ]
View
process-id: OSPFv3 process ID, in the range 1 to 65535.
external: Displays the AS-external LSA information of the OSPFv3 link state request list.
inter-prefix: Displays the Inter-area-prefix LSA information of the OSPFv3 link state request list.
inter-router: Displays the Inter-area-router LSA information of the OSPFv3 link state request list.
intra-prefix: Displays the Intra-area-prefix LSA information of the OSPFv3 link state request list.
link: Displays the Link LSA information of the OSPFv3 link state request list.
network: Displays the Network-LSA information of the OSPFv3 link state request list.
router: Displays the Router-LSA information of the OSPFv3 link state request list.
link-state-id: Link state ID, in the format of an IPv4 address.
originate-router ip-address: Specifies the router ID of an advertising router.
statistics: Displays the LSA statistics of the OSPFv3 link state request list.
Use the display ospfv3 request-list command to display OSPFv3 link state request list information.
If no process is specified, link state request list information of all OSPFv3 processes is displayed.
# Display the information of OSPFv3 link state request list.
<Sysname> display ospfv3 request-list
         OSPFv3 Router with ID (11.1.1.1) (Process 1)
             Interface Vlan100    Area-ID 0.0.0.0
                          Nbr-ID   12.1.1.1
LS-Type               LS-ID           AdvRouter       SeqNum       Age  CkSum
Router-LSA            0.0.0.0         12.1.1.1          0x80000014    774  0xe5b0
Table 3-10 Description on the fields of the display ospfv3 request-list command
Interface name
Area-ID
Area ID
Nbr-ID
Neighbor router ID
LS-Type
Type of LSA
LS-ID
Link state ID
AdvRouter
Advertising router
SeqNum
LSA sequence number
Age
Age of LSA
CkSum
Checksum
# Display the statistics of OSPFv3 link state request list.
<Sysname> display ospfv3 request-list statistics
Interface    Neighbor        LSA-Count
Vlan100      2.2.2.2         0
Table 3-11 Description on the fields of the display ospfv3 request-list statistics command
Interface name
Neighbor
Neighbor router ID
LSA-Count
Number of LSAs in the request list
display ospfv3 [ process-id ] retrans-list [ { external | inter-prefix | inter-router | intra-prefix | link | network | router } [ link-state-id ] [ originate-router ip-address ] | statistics ]
View
external: Displays the AS-external LSA information of the OSPFv3 link state retransmission list.
inter-prefix: Displays the Inter-area-prefix LSA information of the OSPFv3 link state retransmission list.
inter-router: Displays the Inter-area-router LSA information of the OSPFv3 link state retransmission list.
intra-prefix: Displays the Intra-area-prefix LSA information of the OSPFv3 link state retransmission list.
link: Displays the Link LSA information of the OSPFv3 link state retransmission list.
network: Displays the Network-LSA information of the OSPFv3 link state retransmission list.
router: Displays the Router-LSA information of the OSPFv3 link state retransmission list.
statistics: Displays the LSA statistics of the OSPFv3 link state retransmission list.
Use the display ospfv3 retrans-list command to display OSPFv3 link state retransmission list.
If no process is specified, link state retransmission list information of all OSPFv3 processes is displayed.
# Display the information of OSPFv3 link state retransmission list.
<Sysname> display ospfv3 retrans-list
                          Nbr-ID   12.1.1.1
Link-LSA              0.15.0.24       12.1.1.1          0x80000003    519  0x7823
Table 3-12 Description on the fields of the display ospfv3 retrans-list command
Interface name
Area-ID
Area ID
Nbr-ID
Neighbor router ID
LS-Type
Type of LSA
LS-ID
Link state ID
AdvRouter
Advertising Router
SeqNum
LSA sequence Number
Age
Age of LSA
CkSum
Checksum
# Display the statistics of OSPFv3 link state retransmission list.
<Sysname> display ospfv3 retrans-list statistics
            OSPFv3 Router with ID (3.3.3.3) (Process 1)
Vlan100     1.1.1.1           0
Table 3-13 Description on the fields of the display ospfv3 retrans-list statistics command
Interface name
Neighbor
Neighbor ID
LSA-Count
Number of LSAs in the retransmission request list
display ospfv3 [ process-id ] routing [ ipv6-address prefix-length | ipv6-address/prefix-length | abr-routes | asbr-routes | all | statistics ]
View
ipv6-address: IPv6 address prefix.
prefix-length: Prefix length, in the range 0 to 128.
abr-routes: Displays routes to ABR.
asbr-routes: Displays routes to ASBR.
all: Displays all routes.
statistics: Displays the OSPFv3 routing table statistics .
Use the display ospfv3 routing command to display OSPFv3 routing table information.
If no process is specified, routing table information of all OSPFv3 processes is displayed.
# Display OSPFv3 routing table information.
<Sysname> display ospfv3 routing
 E1 - Type 1 external route,    IA - Inter area route,    I  - Intra area route
 E2 - Type 2 external route,    *  - Seleted route
 *Destination: 2001::/64
  Type       : I                                        Cost     : 1
  NextHop    : directly-connected                   Interface: Vlan100
Table 3-14 Description on the fields of the display ospfv3 routing command
Destination
Destination network segment
Route type
Cost
Route cost value
Next-hop
Next hop address
Outbound interface
# Display the statistics of OSPFv3 routing table.
<Sysname> display ospfv3 routing statistics
                           OSPFv3 Routing Statistics
 Intra-area-routes   :   1
 Inter-area-routes   :   1
 External-routes     :   0
Table 3-15 Description on the fields of the display ospfv3 routing statistics command
Intra-area-routes
Number of Intra-area-routes
Inter-area-routes
Number of inter-area routes
External-routes
Number of external routes
View
None
Use the display ospfv3 statistic command to display outbound/inbound OSPFv3 packet statistics on associated interface(s).
# Display outbound/inbound OSPFv3 packet statistics on associated interfaces.
<Sysname> display ospfv3 statistic
                       OSPFv3 Statistics
Interface Vlan-interface100 Instance 0
 Type              Input       Output
 Hello             189         63
 DB Description    10          8
 Ls Req            2           1
 Ls Upd            16          6
 Ls Ack            10          6
Table 3-16 Description on the fields of the display ospfv3 statistics command
Interface name
Instance
Instance number
Type of packet
Input
Number of packets received by the interface
Output
Number of packets sent by the interface
Hello
Hello packet
DB Description
Database description packet
Ls Req
Link state request packet
Ls Upd
Link state update packet
Ls Ack
Link state acknowledgement packet
display ospfv3 [ process-id ] topology [ area area-id ]
View
process-id: Displays the topology information of an OSPFv3 process; The process ID ranges from 1 to 65535.
area: Displays the topology information of the specified area.
area-id: ID of an area, a decimal integer (in the range of 0 to 4294967295) that is translated into IPv4 address format by the system or an IPv4 address.
Use the display ospfv3 topology command to display OSPFv3 topology information. If no process is specified, topology information of all OSPFv3 processes is displayed.
# Display OSPFv3 area 1 topology information.
<Sysname> display ospfv3 topology area 1
                      OSPFv3 Process (1)
OSPFv3 Area (0.0.0.1) topology
Type  ID(If-Index)       Bits      Metric    Next-Hop        Interface
Rtr   1.1.1.1                        --
Rtr   2.2.2.2                        1         2.2.2.2         Vlan100
Table 3-17 Description on the fields of the display ospfv3 topology command
Type of node
ID(If-Index)
Router ID
Bits
Flag bit
Metric
Cost value
Next-Hop
Next hop
Outbound interface
display ospfv3 [ process-id ] vlink
View
Use the display ospfv3 vlink command to display OSPFv3 virtual link information. If no process is specified, virtual link information of all OSPFv3 processes is displayed.
# Display OSPFv3 virtual link information.
<Sysname> display ospfv3 vlink
     Virtual Link VLINK1 to router 1.1.1.1 is up
       Transit area :0.0.0.1 via interface Vlan-interface100, instance ID: 0
       Local address: 2000:1::1
       Remote address: 2001:1:1::1
       Transmit Delay is 1 sec, State: P-To-P,
       Timer intervals configured, Hello: 10, Dead: 40, Wait: 40, Retransmit: 5
         Hello due in 00:00:02
         Adjacency state :Full
Table 3-18 Description on the fields of the display ospfv3 vlink command
The virtual link VLINK1 to router 1.1.1.1 is up
Transit area 0.0.0.1 via interface Vlan-interface100
Interface VLAN-interface 100 in transit area 0.0.0.1.
instance ID
Instance ID
Local address
Local IPv6 address
Remote address
Remote IPv6 address
Transmit Delay
Transmit delay of sending LSAs
Interface state
Timer intervals in seconds, Hello: 10, Dead: 40, Wait: 40, Retransmit: 5
Send hello packets in 2 seconds.
Adjacency state
Adjacency state
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ isisv6 process-id | ospfv3 process-id | ripng process-id | bgp4+ | direct | static]
undo filter-policy export [ isisv6 process-id | ospfv3 process-id | ripng process-id | bgp4+ | direct | static ]
View
OSPFv3 view
acl6-number: Specifies the ACL6 number, ranging from 2000 to 3999.
ipv6-prefix ipv6-prefix-name: Specifies the name of an IPv6 prefix list, a string of up to 19 characters.
isisv6 process-id: Specifies to filter the routes of an IPv6-IS-IS process, which is in the range of 1 to 65535.
ospfv3 process-id: Specifies to filter the routes of an OSPFv3 process, which is in the range of 1 to 65535.
ripng process-id: Specifies to filter the routes of a RIPng process, which in the range of 1 to 65535.
bgp4+: Specifies to filter BGP4+ routes.
direct: Specifies to filter direct routes.
static: Specifies to filter static routes.
Use the filter-policy export command to filter redistributed routes.
Use the undo filter-policy export command to remove the configuration.
If no protocol is specified, all redistributed routes will be filtered.
By default, IPv6 OSPFv3 does not filter redistributed routes.
&  Note:
Using the filter-policy export command filters only routes redistributed by the import-route command. If the import-route command is not configured to redistribute routes from other protocols, use of the filter-policy export command does not take effect.
# Filter all redistributed routes using IPv6 ACL 2001.
[Sysname] acl ipv6 number 2001
[Sysname-acl6-basic-2001] rule permit source 2002:1:: 64
[Sysname-acl6-basic-2001] quit
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy 2001 export
View
OSPFv3 view
acl6-number: Specifies an ACL number, ranging from 2000 to 3999.
Use the filter-policy import command to filter received routes.
Use the undo filter-policy import command to remove the configuration.
No received routes are filtered by default.
&  Note:
Using the filter-policy import command only filters routes computed by OSPFv3. The routes that fail to pass are not added to the routing table.
# Filter received routes using the IPv6 prefix list abc.
[Sysname] ip ipv6-prefix abc permit 2002:1:: 64
[Sysname] ospfv3 1
[Sysname-ospfv3-1] filter-policy ipv6-prefix abc import
3.1.20  import-route
import-route { isisv6 process-id | ospfv3 process-id | ripng process-id | bgp4+ [ allow-ibgp ] | direct | static } [ cost value | type type | route-policy route-policy-name ]*
undo import-route  { isisv6 process-id | ospfv3 process-id | ripng process-id | bgp4+ | direct | static }
View
OSPFv3 view
isisv6 process-id: Redistributes IPv6 ISIS routes from an IPv6 IS-IS process. The process ID is in the range 1 to 65535.
ospfv3 process-id: Redistributes OSPFv3 routes from an OSPFv3 process. The process ID is in the range 1 to 65535.
ripng process-id: Redistributes RIPng routes from a RIPng process. The process ID is in the range 1 to 65535.
bgp4+: Redistributes BGP4+ routes.
allow-ibgp: Allows redistributing IBGP routes.
direct: Redistributes direct routes.
static: Redistributes static routes.
cost value: Cost for redistributed routes, ranging from 1 to 16777214. The default is 1.
type type: Specifies the type for redistributed routes, 1 or 2. It defaults to 2.
route-policy route-policy-name: Specifies to redistribute only the routes that match the specified route-policy. route-policy-name is a string of up to 19 characters.
  Caution:
Using the import-route bgp4+ command redistributes only EBGP routes, while using the import-route bgp4+ allow-ibgp command redistributes both EBGP and IBGP routes.
Use the import-route command to redistribute routes.
Use the undo import-route command to disable routes redistribution.
IPv6 OSPFv3 does not redistribute routes from other protocols by default.
# Configure to redistribute routes from RIPng and specify the type as type 2 and cost as 50.
[Sysname] ospfv3
[Sysname-ospfv3-1] import-route ripng 10 type 2 cost 50
# Configure OSPFv3 process 100 to redistribute the routes found by OSPFv3 process 160.
[Sysname] ospfv3 100
[Sysname-ospfv3-100] import-route ospfv3 160
log-peer-change
undo log-peer-change
View
OSPFv3 view
None
Use the log-peer-change command to enable the logging on neighbor state changes.
Use the undo maximum load-balancing command to disable the logging.
With this feature enabled, information about neighbor state changes of the current OSPFv3 process will display on the configuration terminal.
# Disable the logging on neighbor state changes of OSPFv3 process 100.
[Sysname-ospfv3-100] undo log-peer-change
maximum load-balancing maximum
View
OSPFv3 view
maximum: Maximum number of equal-cost routes for load-balancing. The argument being set to 1 means no load balancing is available. Its value is in the range 1 to 4.
Use the maximum load-balancing command to configure the maximum number of equal-cost routes for load-balancing.
By default, the maximum number of equal-cost routes for load-balancing in OSPFv3 is 4.
# Configure the maximum number of equal-cost routes for load-balancing as 2.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] maximum load-balancing 2
3.1.23  ospfv3
undo ospfv3 [ process-id ]
View
process-id: OSPFv3 process ID, ranging from 1 to 65535. The process ID defaults to 1.
Use the ospfv3 command to enable an OSPFv3 process and enter OSPFv3 view.
Use the undo ospfv3 command to disable an OSPFv3 process.
The system runs no OSPFv3 process by default.
Related commands: router-id.
&  Note:
An OSPFv3 process can run normally only when Router ID is configured in OSPFv3 view. Otherwise, you can find the process, but which cannot generate any LSA.
# Enable the OSPFv3 process with process ID as 120 and configure the Router ID as 1.1.1.1.
[Sysname] ospfv3 120
[Sysname-ospfv3-120] router-id 1.1.1.1
3.1.24  ospfv3 area
ospfv3 process-id area area-id [ instance instance-id ]
undo ospfv3 process-id area area-id [ instance instance-id ]
View
Interface view
area-id: Area ID, a decimal integer (in the range of 0 to 4294967295) that is translated into IPv4 address format by the system or an IPv4 address.
instance-id: Instance ID of an interface, in the range 0 to 255. The default is 0.
Use the ospfv3 area command to enable an OSPFv3 process on the interface and specify the area for the process.
Use the undo ospfv3 area command to disable an OSPFv3 process.
OSPFv3 is not enabled on an interface by default.
# Enable OSPFv3 process 1 on an interface that belongs to instance 1 and specify area 1 for the process.
[Sysname-Vlan-interface10] ospfv3 1 area 1 instance 1
3.1.25  ospfv3 cost
ospfv3 cost value [ instance instance-id ]
undo ospfv3 cost [ instance instance-id ]
View
Interface view
value: OSPFv3 cost of the interface, in the range 1 to 65535.
instance-id: Instance ID of an interface, in the range of 0 to 255, which defaults to 0.
Use the ospfv3 cost command to configure the OSPFv3 cost of the interface in an instance.
Use the undo ospfv3 cost command to restore the default OSPFv3 cost of the interface in an instance.
By default, the OSPFv3 cost of the interface in an instance is 1.
# Specifies the OSPFv3 cost of the interface in instance 1 as 33.
[Sysname-Vlan-interface10] ospfv3 cost 33 instance 1
ospfv3 dr-priority priority [ instance instance-id ]
undo ospfv3 dr-priority [ instance instance-id ]
View
Interface view
priority: DR priority, in the range 0 to 255.
instance-id: ID of the instance an interface belongs to, in the range 0 to 255, which defaults to 0.
Use the ospfv3 dr-priority command to set the DR priority for an interface in an instance.
Use the undo ospfv3 dr-priority command to restore the default value.
The DR priority on an interface defaults to 1.
An interface’s DR priority determines its privilege in DR/BDR selection, and the interface with the highest priority is preferred.
# Set the DR priority for an interface in instance 1 to 8 .
[Sysname-Vlan-interface10] ospfv3 dr-priority 8 instance 1
ospfv3 mtu-ignore [ instance instance-id ]
undo ospfv3 mtu-ignore [ instance instance-id ]
View
Interface view
instance-id: Instance ID, in the range 0 to 255, which defaults to 0.
Use the ospfv3 mtu-ignore command to configure an interface to ignore MTU check when sending DD packets.
Use the undo ospfv3 mtu-ignore command to restore the default.
MTU check is not ignored by default.
# Configure VLAN-interface 10 that belongs to instance 1 to ignore MTU check.
[Sysname-Vlan-interface10] ospfv3 mtu-ignore instance 1
ospfv3 timer dead seconds [ instance instance-id ]
undo ospfv3 timer dead [ instance instance-id ]
View
Interface view
seconds: Dead time in seconds, ranging from 1 to 65535.
Use the ospfv3 timer dead command to configure the OSPFv3 neighbor dead time for an interface that belongs to a specified instance.
Use the undo ospfv3 timer dead command to restore the default.
By default, the OSPFv3 neighbor dead time is 40 seconds.
OSPFv3 neighbor dead time: if an interface receives no hello packet from a neighbor after dead time elapses, the interface will consider the neighbor dead.
The dead seconds value is at least four times the Hello seconds value and must be identical on interfaces attached to the same network segment.
Related commands: ospfv3 timer hello.
# Configure the OSPFv3 neighbor dead time as 80 seconds for VLAN-interface 10 in instance 1.
[Sysname-Vlan-interface10] ospfv3 timer dead 80 instance 1
ospfv3 timer hello seconds [ instance instance-id ]
undo ospfv3 timer hello [ instance instance-id ]
View
Interface view
seconds: Interval between hello packets, ranging from 1 to 65535.
Use the ospfv3 timer hello command to configure the hello interval for an interface that belongs to an instance.
Use the undo ospfv3 timer hello command to restore the default .
By default, the hello interval is 10 seconds.
Related commands: ospfv3 timer dead.
# Configure the hello interval as 20 seconds for VLAN-interface 10 in instance 1.
[Sysname-Vlan-interface10] ospfv3 timer hello 20 instance 1
ospfv3 timer retransmit interval [ instance instance-id ]
undo ospfv3 timer retransmit [ instance instance-id ]
View
Interface view
interval: LSA retransmission interval in seconds, ranging from 1 to 65535.
Use the ospfv3 timer retransmit command to configure the LSA retransmission interval for an interface in an instance.
Use the undo ospfv3 timer retransmit command to restore the default.
The interval defaults to 5 seconds.
After sending a LSA to its neighbor, the device waits for an acknowledgement. If receiving no acknowledgement after the LSA retransmission interval elapses, it will retransmit the LSA.
The LSA retransmission interval should not be too small for avoidance of unnecessary retransmissions.
# Configure the LSA retransmission interval on VLAN-interface 10 in instance 1 as 12 seconds.
[Sysname-Vlan-interface10] ospfv3 timer retransmit 12 instance 1
3.1.31  ospfv3 trans-delay
ospfv3 trans-delay seconds [ instance instance-id ]
undo ospfv3 trans-delay [ instance instance-id ]
View
Interface view
seconds: Transmission delay in seconds, ranging from 1 to 3600.
instance-id: Instance ID of an interface, in the range of 0 to 255, with the default as 0.
Use the ospfv3 trans-delay command to configure the transmission delay for an interface with an instance ID.
Use the undo ospfv3 trans-delay command to restore the default.
The transmission delay defaults to 1s.
As LSAs are aged in the LSDB (incremented by 1 every second) but not aged on transmission, it is necessary to add a delay time to the age time before sending a LSA. This configuration is important for low-speed networks.
# Configure the transmission delay as 3 seconds for VLAN-interface 10 in instance 1.
[Sysname-Vlan-interface10] ospfv3 trans-delay 3 instance 1
3.1.32  preference
preference [ ase ] [ route-policy route-policy-name ] preference
undo preference [ ase ]
View
OSPFv3 view
ase: Applies the preference to OSPFv3 external routes. If the keyword is not specified, the preference applies to OSPFv3 internal routes.
route-policy route-policy-name: References a routing policy to set preference for specific routes. The name is a string of 1 to 19 characters.
Preference: Preference of OSPFv3, in the range 1 to 255.
Use the preference command to specify a preference for OSPFv3 routes.
By default, the preference for OSPFv3 internal routes is 10, and that for OSPFv3 external routes is 150.
The smaller the value is, the higher the preference is.
A router may run multiple routing protocols. Each protocol has a preference. When several routing protocols find multiple routes to the same destination, the route found by the protocol with the highest preference is selected.
# Set a preference of 150 for OSPFv3 routes.
[Sysname] OSPFv3
[Sysname-OSPFv3-1] preference 150
3.1.33  router-id
router-id router-id
undo router-id
View
OSPFv3 view
router-id: 32-bit router ID, in IPv4 address format.
Use the router-id command to configure the OSPFv3 router ID.
Use the undo router-id command to remove a configured router ID.
Router ID is the unique identifier of a device running an OSPFv3 process in the autonomous system. The OSPFv3 process cannot run without a Router ID.
Make sure that different processes have different Router IDs.
Related commands: ospfv3.
# Configure the Router ID as 10.1.1.3 for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] router-id 10.1.1.3
3.1.34  silent-interface
View
OSPFv3 view
interface-type interface-number: Interface type and number
all: Specifies all interfaces.
Use the silent-interface command to disable the specified interface from sending OSPFv3 packets.
Use the undo silent-interface command to restore the default.
An interface is able to send OSPFv3 packets by default.
Multiple processes can disable the same interface from sending OSPFv3 packets, but use of the silent-interface command takes effect only on interfaces enabled with the current process.
# Disable VLAN-interface 10 from sending OSPFv3 packets in OSPFv3 processes 100 and 200.
[Sysname-ospfv3-100] router-id 10.110.1.9
[Sysname-ospfv3-100] silent-interface vlan-interface 10
[Sysname-ospfv3-100] quit
[Sysname] ospfv3 200
[Sysname-ospfv3-200] router-id 20.18.0.7
[Sysname-ospfv3-200] silent-interface vlan-interface 10
3.1.35  spf timers
spf timers delay-interval hold-interval
undo spf timers
View
OSPFv3 view
delay-interval: Interval in seconds between when OSPFv3 receives a topology change and when it starts SPF calculation. in the range 1 to 65535.
hold-interval: Hold interval in seconds between two consecutive SPF calculations, in the range 1 to 65535.
Use the spf timers command to configure the delay interval and hold interval for OSPFv3 SPF calculation.
Use the undo spf timers command to restore the default.
The delay interval and hold interval default to 5s and 10s.
An OSPFv3 router works out a shortest path tree with itself as root based on the LSDB, and decides on the next hop to a destination network according the tree. Adjusting the SPF calculation interval can restrain bandwidth and router resource from over consumption due to frequent network changes.
# Configure the delay interval and hold interval as 6 seconds for SPF calculation.
[Sysname]ospfv3 1
[Sysname-ospfv3-1] spf timers 6 6
3.1.36  stub
stub [ no-summary ]
undo stub
View
OSPFv3 area view
no-summary: This argument is only applicable to the ABR of a stub area. With it configured, the ABR advertises only a default route in a Summary-LSA to the stub area (such an area is called a totally stub area).
Use the stub command to configure an area as a stub area.
Use the undo stub command to remove the configuration.
By default, an area is not configured as a stub area.
When an area is configured as a stub area, all the routers attached to the area must be configured with the stub command.
Related commands: default-cost.
# Configure OSPFv3 area 1 as a stub area.
[Sysname] ospfv3 1
3.1.37  vlink-peer
vlink-peer router-id [ hello seconds | retransmit seconds | trans-delay seconds | dead seconds | instance instance-id ] *
undo vlink-peer router-id [ hello | retransmit | trans-delay | dead ]*
View
OSPFv3 area view
router-id: Router ID for a virtual link neighbor.
hello seconds: Specifies the interval in seconds for sending Hello packets, ranging from 1 to 8192, with the default as 10. This value must be equal to the hello seconds configured on the virtual link peer.
retransmit seconds: Specifies the interval in seconds for retransmitting LSA packets, ranging from 1 to 3600, with the default as 5.
trans-delay seconds: Specifies the delay interval in seconds for sending LSA packets, ranging from 1 to 3600, with the default as 1.
dead seconds: Specifies the neighbor dead time in seconds, ranging from 1 to 32768, with the default as 40. This value must be equal to the dead seconds configured on the virtual link peer, and at least four times the value of hello seconds.
instance Instance-id: Instance ID of an virtual link, in the range of 0 to 255, with the default as 0.
Use the vlink-peer command to create and configure a virtual link.
Use the undo vlink-peer command to remove a virtual link.
For a non-backbone area without a direct connection to the backbone area or for a backbone area that cannot maintain connectivity, you can use the vlink-peer command to create logical links. A virtual link can be considered as an interface with OSPFv3 enabled, because parameters such as hello, dead, retransmit and trans-delay are configured in the similar way.
Both ends of a virtual link are ABRs that are configured with the vlink-peer command.
# Create a virtual link to 10.110.0.3.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 10.0.0.0
[Sysname-ospfv3-1-area-10.0.0.0] vlink-peer 10.110.0.3
Chapter 4  IPv6 IS-IS Configuration Commands
4.1  IPv6 IS-IS Configuration Commands
&  Note:
4.1.1  display isis route ipv6
display isis route ipv6 [ [ level-1 | level-2 ] | verbose ]* [ process-id ]
View
verbose: Displays detailed IPv6 IS-IS routing information.
process-id: IS-IS process ID, in the range 1 to 65535.
level-1: Display Level-1 IPv6 IS-IS routes only.
level-2: Displays Level-2 IPv6 IS-IS routes only.
&  Note:
If no level is specified, both Level-1 and Level-2 (namely Level-1-2) routing information will be displayed.
Use the display isis route ipv6 command to display IPv6 IS-IS routing information.
# Display IPv6 IS-IS routing information.
<Sysname> display isis route ipv6
                         Route information for ISIS(1)
                     ISIS(1) IPv6 Level-1 Forwarding Table
 Destination: 2001::                              PrefixLen: 64
 Flag       : R/L/-                               Cost     : 10
 Next Hop   : Direct                              Interface: Vlan100
 Destination: 2002::                              PrefixLen: 64
 Flag       : R/L/-                               Cost     : 20
 Next Hop   : FE80::20F:E2FF:FE1D:A65B            Interface: Vlan100
      Flags: R-Added to RM, L-Advertised in LSPs, U-Up/Down Bit Set
Table 4-1 Description on the fields of the display isis route ipv6 command
Destination
IPv6 destination address prefix
PrefixLen
Length of the prefix
Flag/Flags
Flag of routing information status
D: This is a direct route.
R: The route has been added into the routing table.
L: The route has been advertised in an LSP.
U: Route leaking flag, indicating the Level-1 route is from Level-2. “UP” means the route will not be returned to Level-2.
Cost
Value of cost
Next Hop
Next hop
Outbound interface
# Display detailed IPv6 IS-IS routing information.
<Sysname> display isis route ipv6 verbose
 IPV6 Dest  : 2001:1::/64                    Cost : 10       Flag : R/L/-
 Preference : 15                        Admin Tag : -
 Interface  : Vlan100                    Next Hop : Direct
 IPV6 Dest  : 2001:2::/64                 Cost : 20      Flag : R/-/-
 Interface  : Vlan100                    Next Hop : FE80::2E0:FCFF:FE00:242A
 IPV6 Dest  : 2001:3::/64                    Cost : 20            Flag : R/-/-
 IPV6 Dest  : ::/0                           Cost : 10            Flag : R/-/-
Table 4-2 Description on the fields of the display isis route ipv6 verbose command
IPV6 Dest
IPv6 destination
Cost
Value of cost
Flag/Flags
Admin Tag
Administrative tag
Src Count
Number of advertisement sources
Next Hop
Next hop
Outbound interface
4.1.2  ipv6 default-route-advertise
ipv6 default-route-advertise [ [ level-1 | level-2 | level-1-2 ] | route-policy route-policy-name ]*
undo ipv6 default-route-advertise [ route-policy route-policy-name ]
View
IS-IS view
route-policy-name: Specifies the name of a routing policy with a string of 1 to 19 characters.
level-1: Specifies the default route as Level-1.
level-2: Specifies the default route as Level-2.
level-1-2: Specifies the default route as Level-1-2.
&  Note:
If no level is specified, the default route belongs to Level-2.
Use the ipv6 default-route-advertise command to generate a Level-1 or Level-2 IPv6 IS-IS default route.
Use the undo ipv6 default-route-advertise command to disable generating a default route.
No IPv6 IS-IS default route is generated by default.
With a routing policy, you can configure IPv6 IS-IS to generate the default route that must match the routing policy. You can use the apply isis level-1 command in routing policy view to generate a default route in L1 LSPs, or use the apply isis level-2 command in routing policy view to generate a default route in L2 LSPs, and use the apply isis level-1-2 in routing policy view to generate a default route in L1 and L2 LSPs respectively.
# Configure the router to generate a default route in Level-2 LSPs.
[Sysname] isis
[Sysname-isis-1] ipv6 default-route-advertise
4.1.3  ipv6 enable
ipv6 enable
undo ipv6 enable
View
IS-IS view
None
Use the ipv6 enable command to enable IPv6 for the IPv6 IS-IS process.
Use the undo ipv6 enable command to disable IPv6.
IPv6 is disabled by default.
# Create IS-IS routing process 1, and enable IPv6 for the process.
[Sysname] ipv6
[Sysname] isis 1
[Sysname-isis-1] network-entity 10.0001.1010.1020.1030.00
[Sysname-isis-1] ipv6 enable
4.1.4  ipv6 filter-policy export
ipv6 filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } export [ protocol process-id ]
undo ipv6 filter-policy export [ protocol [ process-id ] ]
View
IS-IS view
acl6-number: Number of a basic or advanced IPv6 ACL used to filter redistributed routes before advertisement, ranging from 2000 to 3999.
ipv6-prefix-name: Name of an IPv6 prefix list used to filter the redistributed routes before advertisement, a string of 1 to 19 characters.
route-policy-name: Name of a routing policy used to filter the redistributed routes before advertisement, a string of 1 to 19 characters.
protocol: Filter routes redistributed from the specified routing protocol before advertisement. The routing protocol can be bgp4+, direct, isisv6, ospfv3, ripng or static at present. If no protocol is specified, routes redistributed from all protocols are filtered before advertisement.
process-id: Process ID of the routing protocol, ranging from 1 to 65535. This argument is available when the protocol is isisv6, ospfv3 or ripng.
Use the ipv6 filter-policy export command to configure IPv6 IS-IS to filter redistributed routes before advertisement.
Use the undo ipv6 filter-policy export command to disable the filtering.
The filtering is disabled by default.
In some cases, only routes satisfying certain conditions will be advertised. You can configure the filtering conditions using the ipv6 filter-policy command.
You can use the ipv6 filter-policy export command, which filters redistributed routes only when they are advertised to other routers, in combination with the ipv6 import-route command.
l           If no protocol is specified, routes redistributed from all protocols are filtered before advertisement.
l           If a protocol is specified, only routes redistributed from the protocol are filtered before advertisement.
Related commands: ipv6 filter-policy import.
# Reference the ACL6 2006 to filter all the redistributed routes before advertisement.
[Sysname] isis
[Sysname-isis-1] ipv6 filter-policy 2006 export
4.1.5  ipv6 filter-policy import
ipv6 filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } import
undo ipv6 filter-policy import
View
IS-IS view
acl6-number: Number of a basic or advanced IPv6 ACL used to filter incoming routes, ranging from 2000 to 3999.
ipv6-prefix-name: Name of an IPv6 prefix list used to filter incoming routes, a string of 1 to 19 characters.
route-policy-name: Name of a routing policy used to filter incoming routes, a string of 1 to 19 characters.
Use the ipv6 filter-policy import command to configure IPv6 IS-IS to filter the received routes.
Use the undo ipv6 filter-policy import command to disable the filtering.
In some cases, only the routing information satisfying certain conditions will be received. You can configure the filtering conditions using the ipv6 filter-policy command.
Related commands: ipv6 filter-policy export.
# Reference the IPv6 ACL 2003 to filter the received routes.
[Sysname] isis
[Sysname-isis-1] ipv6 filter-policy 2003 import
4.1.6  ipv6 import-route
ipv6 import-route protocol [ process-id ] [ allow-ibgp ] [ cost cost | [ level-1 | level-2 | level-1-2 ] | route-policy route-policy-name | tag tag ] *
undo ipv6 import-route protocol [ process-id ]
View
IS-IS view
protocol: Redistributes routes from a specified routing protocol, which can be direct, static, ripng, isisv6, bgp4+ or ospfv3.
process-id: Process ID of the routing protocol of ripng, isisv6 or ospfv3, in the range of 1 to 65535. The default is 1.
cost: Cost for redistributed routes, ranging from 0 to 4261412864.
level-1: Redistributes routes into Level-1 routing table.
level-2: Redistributes routes into Level-2 routing table.
level-1-2: Redistributes routes into Level-1 and Level-2 routing tables.
route-policy-name: Name of a routing policy used to filter routes when they are being redistributed, a string of 1 to 19 characters.
tag: Specifies a administrative tag number for the redistributed routes, in the range of 1 to 4294967295.
allow-ibgp: Allows the redistribution of IBGP routes. This keyword is optional when the protocol is bgp4+.
Use the ipv6 import-route command to enable IPv6 IS-IS to redistribute routes from another routing protocol.
Use the undo ipv6 import-route command to disable route redistribution.
Route redistribution is disabled by default.
If no level is specified, the routes are imported to Level-2 routing table by default.
IPv6 IS-IS considers redistributed routes as routes to destinations outside the local routing domain.
You can specify a cost and a level for redistributed routes.
  Caution:
Using the import-route bgp4+ allow-ibgp command will redistribute both EBGP and IBGP routes. The redistributed IBGP routes may cause routing loops. Therefore, be cautious with this command.
# Configure IPv6–IS-IS to redistribute static routes and sets the cost 15 for them.
[Sysname] isis
[Sysname-isis-1]ipv6 import-route static cost 15
4.1.7  ipv6 import-route isisv6 level-2 into level-1
ipv6 import-route isisv6 level-2 into level-1 [ filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name | route-policy route-policy-name } | tag tag ]*
undo ipv6 import-route isisv6 level-2 into level-1
View
IS-IS view
acl6-number: Number of a basic or advanced ACL6 used to filter routes when they are leaking from Level-2 to Level-1, ranging from 2000 to 3999.
ipv6-prefix-name: Name of an IPv6 prefix list used to filter routes when they are leaking from Level-2 to Level-1, a string of 1 to 19 characters.
route-policy-name: Name of a routing policy used to filter routes when they are leaking from Level-2 to Level-1, a string of 1 to 19 characters.
tag: Specifies a administrative tag number for the leaked routes, in the range of 1 to 4294967295.
Use the ipv6 import-route isisv6 level-2 into level-1 to enable IPv6 IS-IS route leaking from Level-2 to Level-1.
Use the undo ipv6 import-route isisv6 level-2 into level-1 command to disable the leaking.
The leaking is disabled by default.
The route leaking feature enables a Level-1-2 router to advertise routes destined to the Level-2 area and other Level-1 areas to the Level-1 and Level-1-2 routers in the local area.
# Enable IPv6 IS-IS route leaking from Level-2 to Level-1.
[Sysname] isis 1
[Sysname-isis-1] ipv6 import-route isisv6 level-2 into level-1
4.1.8  ipv6 maximum load-balancing
ipv6 maximum load-balancing number
undo ipv6 maximum load-balancing
View
IS-IS view
number: Maximum number of equal-cost routes for load balancing. Its value is in the range 1 to 4 and defaults to 4.
Use the ipv6 maximum load-balancing command to configure the maximum number of equal-cost routes for load balancing.
Use the undo ipv6 maximum load-balancing command to restore the default.
The maximum number range and default vary by device.
&  Note:
Configure the maximum number of equivalent load-balanced routes according to the memory capacity.
# Configure the maximum number of equivalent load-balanced routing as 2.
[Sysname] isis 100
[Sysname-isis-100] ipv6 maximum load-balancing 2
4.1.9  ipv6 preference
ipv6 preference { route-policy route-policy-name | preference } *
undo ipv6 preference
View
IS-IS view
preference: Preference for IPv6 IS-IS, ranging from 1 to 255.
route-policy-name: Name of a routing policy, a string of 1 to 19 characters.
Use the ipv6 preference command to configure the preference for IPv6 IS-IS protocol.
Use the undo ipv6 preference command to configure the default preference for IPv6 IS-IS protocol.
The default preference is 15.
When a router runs multiple dynamic routing protocols at the same time, the system will assign a preference to each routing protocol. If several protocols find routes to the same destination, the route found by the protocol with the highest preference is selected.
# Configure the preference of IPv6 IS-IS protocol as 20.
[Sysname] isis
[Sysname-isis-1] ipv6 preference 20
4.1.10  ipv6 summary
ipv6 summary ipv6-prefix prefix-length [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
undo ipv6 summary ipv6-prefix prefix-length [ level-1 | level-1-2 | level-2 ]
View
IS-IS view
ipv6-prefix: IPv6 prefix of the summary route.
prefix-length: Length of the IPv6 prefix, in the range of 0 to 128.
avoid-feedback: Specifies to avoid learning summary routes via routing calculation.
generate_null0_route: Generates the NULL 0 route to avoid routing loops.
level-1: Specifies to summarize only the routes redistributed to Level-1 area.
level-1-2: Specifies to summarize all the routes redistributed to Level-1 and Level-2 areas.
level-2: Specifies to summarize only the routes redistributed to Level-2 area.
tag: Value of a administrative tag, in the range of 1 to 4294967295.
&  Note:
If no level is specified in the command, the default is level-2.
Use the ipv6 summary command to configure an IPv6 IS-IS summary route.
Use the undo ipv6 summary command to remove the summary route.
Route summarization is disabled by default.
Configuring summary routes can reduce the size of the route table, LSPs and LSDB. Routes to be summarized can be IS-IS routes or redistributed routes. The cost of a summary route is the smallest cost among all summarized routes.
# Configure a summary route of 2002::/32.
[Sysname] isis
[Sysname-isis-1] ipv6 summary 2002:: 32
4.1.11  isis ipv6 enable
isis ipv6 enable [ process-id ]
undo isis ipv6 enable
View
Interface view
process-id: IS-IS process ID, ranging from 1 to 65535. The default is 1.
Use the isis ipv6 enable command to enable IPv6 for the specified IS-IS process on the interface.
Use the undo isis ipv6 enable command to disable the configuration.
IPv6 is disabled on the interface by default.
# Enable global IPv6, create IS-IS routing process 1, enable IPv6 for the process, and enable IPv6 for the process on VLAN-interface100.
[Sysname] ipv6
[Sysname] isis 1
[Sysname-isis-1] quit
[Sysname] interface Vlan-interface 100
[Sysname--Vlan-interface100] ipv6 address 2002::1/64
[Sysname--Vlan-interface100] isis ipv6 enable 1
Chapter 5  IPv6 BGP Configuration Commands
5.1  IPv6 BGP Configuration Commands
5.1.1  balance
balance number
undo balance
View
IPv6 address family view
number: Number of BGP4+ routes participating in load balancing. Its value is in the range 1 to 4. When it is set to 1, load balancing is disabled.
Use the balance command to configure the number of routes participating in IPv6 BGP load balancing.
Use the undo balance command to restore the default.
The feature is not available by default.
Unlike IGP, BGP has no explicit metric for making load balancing decision. Instead, it implements load balancing by defining its routing rule.
# Set the number of routes participating in IPv6 BGP load balancing to 2.
[Sysname] bgp 100
[Sysname-bgp] ipv6-family
[Sysname-bgp-af-ipv6] balance 2
5.1.2  bestroute as-path-neglect
undo bestroute as-path-neglect
View
None
Use the bestroute as-path-neglect command to configure the IPv6 BGP router to not evaluate the AS_PATH during best route selection.
Use the undo bestroute as-path-neglect command to configure the IPv6 BGP router to use the AS_PATH during best route selection.
By default, the router takes AS_PATH as a factor when selecting the best route.
# Ignore AS_PATH in route selection.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] bestroute as-path-neglect
5.1.3  bestroute compare-med
undo bestroute compare-med
View
None
Use the bestroute compare-med command to enable the comparison of the MED for paths from each AS.
Use the undo bestroute compare-med command to disable this comparison.
This comparison is not enabled by default.
  Caution:
After the bestroute compare-med command is executed, the balance command does not take effect.
# Compare the MED for paths from an AS for selecting the best route.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] bestroute compare-med
5.1.4  bestroute med-confederation
undo bestroute med-confederation
View
None
Use the bestroute med-confederation command to enable the comparison of the MED for paths from confederation peers for best route selection.
Use the undo bestroute med-confederation command to disable the comparison.
By default, this comparison is not enabled.
With this feature enabled, the system can only compare the MED for paths from peers within the confederation. Paths from external ASs are advertised throughout the confederation without MED comparison.
# Compare the MED for paths from peers within the confederation.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] bestroute med-confederation
5.1.5  compare-different-as-med
undo compare-different-as-med
View
None
Use the compare-different-as-med command to enable the comparison of the MED for paths from peers in different ASs.
Use the undo compare-different-as-med command to disable the comparison.
The comparison is disabled by default.
If there are several paths available for one destination, the path with the smallest MED value is selected.
Do not use this command unless associated ASs adopt the same IGP protocol and routing selection method.
# Enable to compare the MED for paths from peers in different ASs.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] compare-different-as-med
5.1.6  dampening
undo dampening
View
half-life-reachable: Half-life for reachable routes, in the range 1 to 45 minutes. By default, the value is 15 minutes.
half-life-unreachable: Half-life for unreachable routes, in the range 1 to 45 minutes. By default, the value is 15 minutes.
reuse: Reuse threshold value for suppressed routes, in the range 1 to 20000. Penalty value of a suppressed route decreasing under the value is reused. By default, its value is 750.
suppress: Suppression threshold from 1 to 20000, which should be bigger than the reuse value. Routes with a penalty value bigger than the threshold are suppressed. By default, it is 2000.
ceiling: Ceiling penalty value from 1001 to 20000. The value must be bigger than the suppress value. By default, the value is 16000.
route-policy-name: Routing policy name, a string of 1 to 19 characters.
half-life-reachable, half-life-unreachable, reuse, suppress and ceiling are mutually dependent. Once any one is configured, all the others should also be specified accordingly.
Use the dampening command to enable IPv6 BGP route dampening or/and configure dampening parameters.
Use the undo dampening command to disable route dampening.
By default, no route dampening is configured.
Related commands: reset bgp ipv6 dampening, reset bgp ipv6 flap-info, display bgp ipv6 routing-table dampened, display bgp ipv6 routing-table dampening parameter, display bgp ipv6 routing-table flap-info.
# Enable IPv6 BGP route dampening and configure route dampening parameters.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] dampening 10 10 1000 2000 3000
5.1.7  default local-preference
undo default local-preference
View
value: Default local preference, in the range 0 to 4294967295. The larger the value is, the higher the preference is.
Use the default local-preference command to configure the default local preference.
Use the undo default local-preference command to restore the default value.
By default, the default local preference is 100.
Use this command to affect IPv6 BGP route selection.
# Two devices A and B in the same AS are connected to another AS. Change the local preference of B from default value 100 to 180, making the route passing B preferred.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] default local-preference 180
5.1.8  default med
default med med-value
undo default med
View
med-value: MED value, in the range 0 to 4294967295.
Use the default med command to specify the default MED value.
Use the undo default med command to restore the default.
By default, the default med-value is 0.
The multi-exit discriminator (MED) is an external metric of a route. Different from local preference, MED is exchanged between ASs and will stay in the AS once it enters the AS. The route with a lower MED is preferred. When a router running BGP obtains several routes with the identical destination and different next-hops from various external peers, it will select the best route depending on the MED value. In the case that all other conditions are the same, the system first selects the route with the smaller MED value as the best route for the autonomous system.
# Devices A and B belong to AS100 and device C belongs to AS200. C is the peer of A and B. Configure the MED of A as 25 to make C select the path from B.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] default med 25
5.1.9  default-route imported
undo default-route imported
View
None
Use the default-route imported command to enable the redistribution of default route into the IPv6 BGP routing table.
Use the undo default-route imported command to disable the redistribution.
By default, the redistribution is not enabled.
# Enable the redistribution of default route from OSPFv3 into IPv6 BGP.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] default-route imported
[Sysname-bgp-af-ipv6] import-route ospfv3 1
5.1.10  display bgp ipv6 group
display bgp ipv6 group [ ipv6-group-name ]
View
ipv6-group-name: Peer group name, a string of 1 to 47 characters.
Use the display bgp ipv6 group command to display IPv6 peer group information.
If no ipv6-group-name is specified, information about all peer groups is displayed.
# Display the information of the IPv6 peer group aaa.
<Sysname> display bgp ipv6 group aaa
 BGP peer-group is aaa
 remote AS number not specified
 Type : external
 Threshold: 75%
 Configured hold timer value: 180
 Keepalive timer value: 60
 Minimum time between advertisement runs is 30 seconds
 Peer Preferred Value: 0
  Members:
  Peer        V    AS  MsgRcvd  MsgSent  OutQ PrefRcv Up/Down  State
  20:20::20:1  4   200       170       141      0        2 02:13:35 Established
Table 5-1 Description on the fields of the display bgp ipv6 group command
BGP peer-group
Name of the peer group
remote AS
AS number of the peer group
Type of the  peer group
Threshold
Threshold  value
hold timer value
Holdtime
Keepalive interval
Minimum interval between advertisements
Preferred value of the routes from the peer
No routing policy is configured for the peer
Members
Group members
Peer
IPv6 address of the peer
V
Peer BGP version
AS
AS number
MsgRcvd
Number of messages received
MsgSent
Number of messages sent
OutQ
Number of messages to be sent
PrefRcv
Number of prefixes received
Up/Down
The lasting time of a session/the lasting time of present state (when no session is established)
State machine of peer
5.1.11  display bgp ipv6 network
View
None
Use the display bgp ipv6 network command to display IPv6 routes advertised with the network command.
# Display IPv6 routes advertised with the network command.
<Sysname> display bgp ipv6 network
  BGP Local Router ID is 1.1.1.2.
  Local AS Number is 200.
  Network          Mask            Route-policy        Short-cut
  2002::           64
  2001::           64                                  Short-cut
Table 5-2 Description on the fields of the display bgp ipv6 network command
BGP Local Router ID
BGP Local Router ID
Local AS Number
Local AS Number
Network
Network address
Prefix
Prefix length
Route-policy
Routing policy
Short-cut
Shortcut route
5.1.12  display bgp ipv6 paths
display bgp ipv6 paths [ as-regular-expression ]
View
as-regular-expression: AS path regular expression.
Use the display bgp ipv6 paths command to display IPv6 BGP path information.
If no parameter is specified, all path information will be displayed.
# Display IPv6 BGP path information.
<Sysname> display bgp ipv6 paths
    Address       Hash    Refcount  MED         Path/Origin
    0x5917098     1       1          0            i
    0x59171D0     9       2          0            100i
Table 5-3 Description on the fields of the display bgp ipv6 paths command
Address
Route destination address in local database, in dotted hexadecimal notation
Hash
Hash index
Refcount
Count of routes that used the path
MED
MED of the path
Path
AS_PATH attribute of the path, recording the ASs it has passed, for avoiding routing loops
Origin
Origin attribute of the route, which can take on one of the following values:
i
Indicates the route is interior to the AS.
Summary routes and routes defined using the network command are considered IGP routes.
e
Indicates that a route is learned from the exterior gateway protocol (EGP).
Short for INCOMPLETE. It indicates that the origin of a route is unknown and the route is learned by other means. BGP sets Origin attribute of routes learned from other IGP protocols to INCOMPLETE.
5.1.13  display bgp ipv6 peer
display bgp ipv6 peer [ ipv6-group-name log-info | ipv6-address { log-info | verbose } ]
View
ipv6-group-name: Name of an IPv6 peer group, a string of 1 to 47 characters.
ipv6-address: Specifies the IPv6 address of a peer to be displayed.
log-info: Displays log information of the specified peer.
verbose: Displays the detailed information of the peer.
Use the display bgp ipv6 peer command to display peer/peer group information.
If no parameter specified, information about all peers and peer groups is displayed.
# Display all IPv6 peer information.
<Sysname> display bgp ipv6 peer
 BGP Local router ID : 20.0.0.1
 local AS number : 100
Total number of peers : 1                 Peers in established state : 1
20::21    4   200  17       19       0          3  00:09:59   Established
Table 5-4 Description on the fields of the display bgp ipv6 peer command
Peer
V
Peer BGP version
AS
AS number
MsgRcvd
Messages received
MsgSent
Messages sent
OutQ
Messages to be sent
PrefRcv
Up/Down
Peer state
5.1.14  display bgp ipv6 routing-table
display bgp ipv6 routing-table [ ipv6-address prefix-length ]
View
ipv6-address: Destination IPv6 address.
prefix-length: Prefix length of the IPv6 address, in the range 0 to 128.
Use the display bgp ipv6 routing-table command to display IPv6 BGP routing table information.
# Display the IPv6 BGP routing table.
<Sysname> display bgp ipv6 routing-table
 Total Number of Routes: 2
 BGP Local router ID is 30.30.30.1
 Status codes: * - valid, > - best, d - damped,
               h - history,  i - internal, s - suppressed, S - Stale
               Origin : i - IGP, e - EGP, ? - incomplete
 *>  Network : 30:30::                                  PrefixLen : 64
     NextHop : 30:30::30:1                              LocPrf    :
     PrefVal : 0                                        Label     : NULL
     MED      : 0
     Path/Ogn: i
 *>  Network : 40:40::                                  PrefixLen : 64
     NextHop : 40:40::40:1                              LocPrf    :
     MED     : 0
     Path/Ogn: i
Table 5-5 Description on the fields of the display bgp ipv6 routing-table command
Local router ID
Local router ID
Status codes
Status codes:
* – valid
> – best
d – damped
h – history
i – internal (IGP)
s – summary suppressed (suppressed)
S – Stale
Origin
i – IGP (originated in the AS)
e – EGP (learned through EGP)
? – incomplete (learned by other means)
Network
Destination network address
PrefixLen
Prefix length
NextHop
Next Hop
MED
MULTI_EXIT_DISC attribute
LocPrf
Local preference value
Path
AS_PATH attribute, recording the ASs the packet has passed to avoid routing loops
PrefVal
Preferred value
Label
Label
Ogn
i
Indicates that a route is interior to the AS.
Summary routes and the routes configured using the network command are considered IGP routes.
e
5.1.15  display bgp ipv6 routing-table as-path-acl
display bgp ipv6 routing-table as-path-acl as-path-acl-number
View
as-path-acl-number: Number of an AS path ACL permitted by which to display routing information, ranging from 1 to 256.
Use the display bgp ipv6 routing-table as-path-acl command to display routes filtered through the specified AS path ACL.
# Display routes filtered through the AS path ACL 20.
<Sysname> display bgp ipv6 routing-table as-path-acl 20
     MED     : 0
     Path/Ogn: i
Refer to Table 5-5 for description on the fields above.
5.1.16  display bgp ipv6 routing-table community
display bgp ipv6 routing-table community [ aa:nn&<1-13> ] [ no-advertise | no-export | no-export-subconfed ] * [ whole-match ]
View
aa:nn: Specifies a community number; both aa and nn are in the range 0 to 65535.
&<1-13>: Indicates the argument before it can be entered up to 13 times.
no-advertise: Displays routes not advertised to any peer.
no-export: Displays routes advertised outside the AS; if there is a confederation, it displays routes not advertised outside the confederation, but to other sub ASs in the confederation.
no-export-subconfed: Displays routes neither advertised outside the AS nor to other sub ASs if the confederation is configured.
whole-match: Displays the exactly matched routes.
Use the display bgp ipv6 routing-table community command to display the routing information of the specified community.
# Display the routing information of the community no-export.
<Sysname> display bgp ipv6 routing-table community no-export
     MED      : 0
     Path/Ogn: i
5.1.17  display bgp ipv6 routing-table community-list
display bgp ipv6 routing-table community-list { basic-community-list-number [ whole-match ] | adv-community-list-number }&<1-16>
View
basic-community-list-number: Specifies a basic community-list number, in the range 1 to 99.
adv-community-list-number: Specifies an advanced community-list number, in the range 100 to 199.
whole-match: Displays routes exactly matching the specified basic-community-list-number.
&<1-16>: Specifies to allow entering the argument before it up to 16 times.
Use the display bgp ipv6 routing-table community-list command to view the routing information matching the specified IPv6 BGP community list.
# Display the routing information matching the specified IPv6 BGP community list.
<Sysname> display bgp ipv6 routing-table community-list 99
     MED      : 0
     Path/Ogn: i
5.1.18  display bgp ipv6 routing-table dampened
View
None
Use the display bgp ipv6 routing-table dampened command to display the IPv6 BGP dampened routes.
# Display IPv6 BGP dampened routes.
<Sysname> display bgp ipv6 routing-table dampened
 *d  Network : 111::                                  PrefixLen : 64
     From    : 122::1                                    Reuse     : 00:29:34
     Path/Ogn: 200?
Table 5-6 Description on the fields of the display bgp ipv6 routing-table dampened command
From
Source IP address of a route
Reuse
Time for reuse
5.1.19  display bgp ipv6 routing-table dampening parameter
View
None
Use the display bgp ipv6 routing-table dampening parameter command to display IPv6 BGP routing dampening parameters.
Related commands: dampening.
# Display IPv6 BGP routing dampening parameters.
<Sysname> display bgp ipv6 routing-table dampening parameter
 Maximum Suppress Time(in second)     : 3069
 Ceiling Value                        : 16000
 Reuse Value                          : 750
 HalfLife Time(in  second)            : 900
 Suppress-Limit                       : 2000
Table 5-7 Description on the above fields
Ceiling Value
Upper limit of penalty value
Reuse Value
Reuse Value
HalfLife Time
Half life Time
Suppress-Limit
Suppress value
5.1.20  display bgp ipv6 routing-table different-origin-as
View
None
Use the display bgp ipv6 routing-table different-origin-as command to display IPv6 BGP routes originating from different autonomous systems.
# Display routes from different ASs.
<Sysname> display bgp ipv6 routing-table different-origin-as
BGP Local router ID is 2.2.2.2
 *>  Network : 222::                                    PrefixLen : 64
     NextHop : 122::2                                   LocPrf    :
     MED      : 0
     Path/Ogn: 100 ?
5.1.21  display bgp ipv6 routing-table flap-info
display bgp ipv6 routing-table flap-info [ regular-expression as-regular-expression | as-path-acl as-path-acl-number | ipv6-address [ prefix-length [ longer-match ] ] ]
View
as-regular-expression: AS path regular expression to be matched.
as-path-acl-number: Number of the specified AS path ACL to be matched, ranging from 1 to 256.
ipv6-address: IPv6 address of a route to be displayed.
longer-match: Matches the longest prefix.
Use the display bgp ipv6 routing-table flap-info command to display IPv6 BGP route flap statistics.
# Display IPv6 BGP route flap statistics.
<Sysname> display bgp ipv6 routing-table flap-info
     From     : 122::1                                Flaps     : 3
     Duration : 00:13:47                              Reuse     : 00:16:36
     Path/Ogn : 200?
Table 5-8 Description on the fields of the display bgp ipv6 routing-table flap-info command
Flaps
Number of flaps
Duration
Flap duration
Reuse
Reuse time of the route
5.1.22  display bgp ipv6 routing-table peer
display bgp ipv6 routing-table peer ipv6-address { advertised-routes | received-routes } [ network-address prefix-length | statistic ]
View
ipv6-address: Specifies the IPv6 peer to be displayed.
advertised-routes: Routing information advertised to the specified peer.
received-routes: Routing information received from the specified peer.
network-address prefix-length: IPv6 address and prefix length. The prefix length ranges from 0 to 128.
statistic: Displays route statistics.
Use the display bgp ipv6 routing-table peer command to display the routing information advertised to or received from the specified IPv6 BGP peer.
# Display the routing information advertised to the specified BGP peer.
<Sysname> display bgp ipv6 routing-table peer 10:10::10:1 advertised-routes
 BGP Local router ID is 20.20.20.1
 *>  Network : 20:20::                                  PrefixLen : 64
     NextHop : 20:20::20:1                              LocPrf    :
     MED     : 0
     Path/Ogn: i
     MED     : 0
     Path/Ogn: 300 i
5.1.23  display bgp ipv6 routing-table regular-expression
display bgp ipv6 routing-table regular-expression as-regular-expression
View
as-regular-expression: AS regular expression.
Use the display bgp ipv6 routing-table regular-expression command to display the routes permitted by the specified AS regular expression.
# Display routing information matching the specified AS regular expression.
<Sysname> display bgp ipv6 routing-table regular-expression ^100
 *>  Network : 50:50::                                  PrefixLen : 64
     NextHop : 10:10::10:1                              LocPrf    :
     MED     : 0
     Path/Ogn: 100 i
5.1.24  display bgp ipv6 routing-table statistic
View
None
Use the display bgp ipv6 routing-table statistic command to display IPv6 BGP routing statistics.
# Display IPv6 BGP routing statistics.
<Sysname> display bgp ipv6 routing-table statistic
 Total Number of Routes: 1
5.1.25  filter-policy export
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } export [ protocol  process-id ]
undo filter-policy export [ protocol process-id ]
View
acl6-number: Specifies the number of an ACL6 used to match against the destination of routing information. The number is in the range 2000 to 3999.
ipv6-prefix-name: Specifies the name of an IPv6 prefix list used to match against the destination address field of routing information. The name is a string of 1 to 19 characters.
protocol: Filters routes redistributed from the routing protocol. It can be direct, isisv6, ospfv3, ripng, and static at present. If no protocol is specified, all routes will be filtered when advertised.
process-id: Process ID of the routing protocol, in the range 1 to 65535. It is available only when the protocol is isisv6, ospfv3 or ripng.
Use the filter-policy export command to filter outbound routes using a specified filter.
Use the undo filter-policy export command to cancel filtering outbound routes.
By default, no outbound routing information is filtered.
If a protocol is specified, only routes redistributed from the specified protocol are filtered. If no protocol is specified, all redistributed routes will be filtered.
# Reference ACL6 2001 to filter all outbound IPv6 BGP routes.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] filter-policy 2001 export
5.1.26  filter-policy import
filter-policy { acl6-number | ipv6-prefix ipv6-prefix-name } import
View
acl6-number: Number of an IPv6 ACL used to match against the destination address field of routing information, ranging from 2000 to 3999.
ipv6-prefix-name: Name of an IPv6 prefix list used to match against the destination address field of routing information, a string of 1 to 19 characters.
Use the filter-policy import command to filter inbound routing information using a specified filter.
Use the undo filter-policy import command to cancel filtering inbound routing information.
By default, no inbound routing information is filtered.
# Reference ACL6 2001 to filter all inbound routes.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] filter-policy 2001 import
5.1.27  group
group ipv6-group-name [ internal | external ]
undo group ipv6-group-name
View
internal: Creates an IBGP peer group.
external: Creates an EBGP peer group, which can be a group of another sub AS in the confederation.
Use the group command to create a peer group.
Use the undo group command to delete a peer group.
An IBGP peer group will be created if neither internal nor external is selected.
# Create an IBGP peer group named test.
[Sysname] bgp 100
[Sysname] ipv6-family
[Sysname-bgp-af-ipv6] group test
5.1.28  import-route
import-route protocol [ process-id [ med med-value | route-policy route-policy-name ] * ]
undo import-route protocol [ process-id ]
View
protocol: Redistributes routes from the specified routing protocol, which can be direct, isisv6, ospfv3, ripng, or static at present.
process-id: Routing protocol process ID, in the range 1 to 65535 and with the default as 1 . It is available only when the protocol is isisv6, ospfv3, or ripng.
med-value: Applies the MED value to redistributed routes. The value is in the range 0 to 4294967295. If not specified, the cost of the redistributed route is used as its MED in the IPv6 BGP routing domain.
route-policy-name: Name of a routing policy used to filter redistributed routes, a string of 1 to 19 characters.
Use the import-route command to redistribute routes from another routing protocol.
Use the undo import-route command to remove the configuration.
By default, IPv6 BGP does not redistribute routes from any routing protocol.
The routes redistributed using the import-route command has the incomplete origin attribute.
# Redistribute routes from RIPng 1.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] import-route ripng 1
5.1.29  ipv6-family
ipv6-family
undo ipv6-family
View
BGP view
None
Use the ipv6-family command to enter IPv6 address family view.
Use the undo ipv6-family command to remove all configurations from the view.
IPv4 BGP unicast view is the default.
# Enter IPv6 address family view.
[Sysname] bgp 100
5.1.30  network
network ipv6-address prefix-length [ short-cut | route-policy route-policy-name ]
undo network ipv6-address prefix-length [ short-cut ]
View
ipv6-address: IPv6 address.
prefix-length: Prefix length of the address, in the range 0 to 128.
short-cut: If the keyword is specified for an EBGP route, the route will use the local routing management value rather than that of EBGP routes, so the preference of the route is reduced.
Use the network command to advertise a network to the IPv6 BGP routing table.
Use the undo network command to remove an entry from the IPv6 BGP routing table.
By default, no route is advertised.
Note that:
l           The route to be advertised must exist in the local IP routing table, and using a routing policy makes route management more flexible.
l           The route advertised to the BGP routing table using the network command has the IGP origin attribute.
# Advertise the network 2002::/16 into the IPv6 BGP routing table.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] network 2002:: 16
5.1.31  peer advertise-community
peer { ipv6-group-name | ipv6-address } advertise-community
undo peer { ipv6-group-name | ipv6-address } advertise-community
View
ipv6-address: IPv6 address of a peer.
Use the peer advertise-community command to advertise the community attribute to a peer/peer group.
Use the undo peer advertise-community command to remove the configuration.
By default, no community attribute is advertised to any peer group/peer.
# Advertise the community attribute to the peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 advertise-community
5.1.32  peer advertise-ext-community
peer { ipv6-group-name | ipv6-address } advertise-ext-community
undo peer { ipv6-group-name | ipv6-address } advertise-ext-community
View
Use the peer advertise-ext-community command to advertise the extended community attribute to a peer/peer group.
Use the undo peer advertise-ext-community command to remove the configuration.
By default, no extended community attribute is advertised to a peer/peer group.
# Advertise the extended community attribute to the peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 advertise-ext-community
5.1.33  peer allow-as-loop
peer { ipv6-group-name | ipv6-address } allow-as-loop [ number ]
undo peer { ipv6-group-name | ipv6-address } allow-as-loop
View
number: Specifies the repeating times of the local AS number, in the range 1 to 10. The default number is 1.
Use the peer allow-as-loop command to configure IPv6 BGP to allow the local AS number to exist in the AS_PATH attribute of routes from a peer/peer group, and to configure the repeating times of the local AS number.
Use the undo peer allow-as-loop command to disable the function.
The local AS number is not allowed to exist in the AS PATH attribute of routes by default.
# Configure the repeating times of the local AS number allowed in the AS PATH of routes from peer 1::1 as 2.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1::1 allow-as-loop 2
5.1.34  peer as-number
peer { ipv6-group-name | ipv6-address } as-number as-number
undo peer ipv6-group-name as-number
undo peer ipv6-address
View
ipv6-group-name: Name of a peer group, a string of 1 to 47 characters.
as-number: AS number of the peer/peer group, in the range 1 to 65535.
Use the peer as-number command to specify an AS number for a peer/peer group.
Use the undo peer as-number command to delete the AS number of a peer group.
Use the undo peer command to delete a peer.
By default, no AS number is configured for a peer/peer group.
# Specify the AS number of the peer group test as 200.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] group test external
[Sysname-bgp-af-ipv6] peer test as-number 200
5.1.35  peer as-path-acl
peer { ipv6-group-name | ipv6-address } as-path-acl as-path-acl-number { import | export }
undo peer { ipv6-group-name | ipv6-address } as-path-acl as-path-acl-number { import | export }
View
as-path-acl-number: Number of an AS path ACL, in the range 1 to 256.
import: Filters incoming routes.
export: Filters outgoing routes.
Use the peer as-path-acl command to specify an AS path ACL to filter routes incoming from or outgoing to a peer/peer group.
Use the undo peer as-path-acl command to remove the configuration.
By default, no AS path list is specified for filtering.
# Specify the AS path ACL 3 to filter routes outgoing to the peer 1:2::3:4.
[Sysname] ip as-path-acl 3 permit ^200
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 as-path-acl 3 export
5.1.36  peer capability-advertise route-refresh
peer { ipv6-group-name | ipv6-address } capability-advertise route-refresh
undo peer { ipv6-group-name | ipv6-address } capability-advertise route-refresh
View
Use the peer capability-advertise route-refresh command to enable IPv6 BGP route-refresh.
Use the undo peer capability-advertise route-refresh command to disable the function.
By default, route-refresh is enabled.
# Disable route-refresh of peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 as-number 100
[Sysname-bgp-af-ipv6] undo peer 1:2::3:4 capability-advertise route-refresh
5.1.37  peer connect-interface
peer { ipv6-group-name | ipv6-address } connect-interface interface-type interface-number
undo peer { ipv6-group-name | ipv6-address } connect-interface
View
interface-type interface-number: Specifies the type and name of the interface.
Use the peer connect-interface command to specify the source interface for establishing TCP connections to an IPv6 BGP peer or peer group.
Use the undo peer connect-interface command to restore the default.
By default, BGP uses the outbound interface of the best route to the IPv6 BGP peer/peer group as the source interface for establishing a TCP connection.
Note that:
To establish multiple BGP connections to a BGP router, you need to specify on the local router the respective source interfaces for establishing TCP connections to the peers on the peering BGP router; otherwise, the local BGP router may fail to establish TCP connections to the peers when using the outbound interfaces of the best routes as the source interfaces.
# Specify loopback 0 as the source interface for routing updates to peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 connect-interface loopback 0
5.1.38  peer default-route-advertise
peer { ipv6-group-name | ipv6-address } default-route-advertise [ route-policy route-policy-name ]
undo peer { ipv6-group-name | ipv6-address } default-route-advertise
View
route-policy-name: Route-policy name, a string of 1 to 19 characters.
Use the peer default-route-advertise command to advertise a default route to a peer/peer group.
Use the undo peer default-route-advertise command to disable advertising a default route.
By default, no default route is advertised to a peer/peer group.
Using this command does not require the default route available in the routing table. With this command used, the router sends the default route unconditionally to the peer/peer group with the next hop being itself.
# Advertise a default route to peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 default-route-advertise
5.1.39  peer description
peer { ipv6-group-name | ipv6-address } description description-text
undo peer { ipv6-group-name | ipv6-address } description
View
description-text: Description information for the peer/peer group, a string of 1 to 79 characters.
Use the peer description command to configure the description information for a peer/peer group.
Use the undo peer description command to remove the description information of a peer/peer group.
By default, no description information is configured for a peer (group).
You need create a peer/peer group before configuring a description for it.
# Configure the description for the peer group test as ISP1.
<Sysname] system-view
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer test description ISP1
5.1.40  peer ebgp-max-hop
peer { ipv6-group-name | ipv6-address } ebgp-max-hop [ hop-count ]
undo peer { ipv6-group-name | ipv6-address } ebgp-max-hop
View
hop-count: Maximum hop count, in the range 1 to 255. By default, the value is 64.
Use the peer ebgp-max-hop command to allow establishing the EBGP connection to a peer/peer group indirectly connected.
Use the undo peer ebgp-max-hop command to remove the configuration.
You can use the argument hop-count to specify the maximum router hops of the EBGP connection.
# Allow establishing the EBGP connection with the peer group test on an indirectly connected network.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer test ebgp-max-hop
5.1.41  peer fake-as
peer { ipv6-group-name | ipv6-address } fake-as as-number
undo peer { ipv6-group-name | ipv6-address } fake-as
View
as-number: Local autonomous system number, in the range 1 to 65535.
Use the peer fake-as command to configure a fake local AS number for a peer or peer group.
Use the undo peer fake-as command to remove the configuration.
By default, no fake local AS number is configured for a peer or peer group.
# Configure a fake AS number of 200 for the peer group test.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer test fake-as 200
5.1.42  peer filter-policy
peer { ipv6-group-name | ipv6-address } filter-policy acl6-number { import | export }
undo peer { ipv6-group-name | ipv6-address } filter-policy [ acl6-number ] { import | export }
View
acl6-number: IPv6 ACL number, in the range 2000 to 3999.
import: Applies the filter-policy to routes received from the peer/peer group.
export: Applies the filter-policy to routes advertised to the peer/peer group.
Use the peer filter-policy command to configure an ACL-based filter policy for a peer or peer group.
Use the undo peer filter-policy command to remove the configuration.
By default, no ACL-based filter policy is configured for a peer or peer group.
# Apply the ACL6 2000 to filter routes advertised to the peer 1:2::3:4.
[Sysname] acl ipv6 number 2000
[Sysname-acl6-basic-2000] rule permit source 2001:1:: 64
[Sysname-acl6-basic-2000] quit
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 filter-policy 2000 export
5.1.43  peer group
peer ipv6-address group ipv6-group-name [ as-number as-number ]
undo peer ipv6-address group ipv6-group-name
View
as-number: Specifies the AS number of the peer/peer group, in the range 1 to 65535.
Use the peer group command to add a peer to a configured peer group.
Use the undo peer group command to delete a specified peer from a peer group.
By default, the peer does not belong to any peer group.
# Create a peer group named test and add the peer 1:2::3:4 to the peer group.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 as-number 200
[Sysname-bgp-af-ipv6] peer 1:2::3:4 group test
5.1.44  peer ignore
peer { ipv6-group-name | ipv6-address } ignore
undo peer { ipv6-group-name | ipv6-address } ignore
View
Use the peer ignore command to terminate the session to a peer or peer group.
Use the undo peer ignore command to remove the configuration.
By default, a router can establish sessions with a peer or peer group.
After the peer ignore command is executed, the system terminates the active session(s) with the specified peer or peer group and clears all the related routing information. For a peer group, this means all the sessions with the peer group will be tore down.
# Terminate the session with peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 ignore
5.1.45  peer ipv6-prefix
peer { ipv6-group-name | ipv6-address } ipv6-prefix ipv6-prefix-name { import | export }
undo peer { ipv6-group-name | ipv6-address } ipv6-prefix { import | export }
View
ipv6-prefix-name: IPv6 prefix list name, a string of 1 to 19 characters.
import: Applies the filtering policy to routes received from the specified peer/peer group.
export: Applies the filtering policy to routes advertised to the specified peer/peer group.
Use the peer ipv6-prefix command to specify an IPv6 prefix list to filter routes incoming from or outgoing to a peer or peer group.
Use the undo peer ipv6-prefix command to remove the configuration.
By default, no IPv6 prefix list is specified for filtering.
# Reference the IPv6 prefix list list 1 to filter routes outgoing to peer 1:2::3:4.
[Sysname] ip ipv6-prefix list1 permit 2002:: 64
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 ipv6-prefix list1 export
5.1.46  peer keep-all-routes
peer { ipv6-group-name | ipv6-address } keep-all-routes
undo peer { ipv6-group-name | ipv6-address } keep-all-routes
View
Use the peer keep-all-routes command to save the original routing information from a peer or peer group, including even routes that failed to pass the inbound policy.
Use the undo peer keep-all-routes command to disable this function.
By default, the function is not enabled.
# Save routing information from peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 keep-all-routes
5.1.47  peer log-change
peer { ipv6-group-name | ipv6-address } log-change
undo peer { ipv6-group-name | ipv6-address } log-change
View
Use the peer log-change command to enable the logging of session state and event information of a specified peer or peer group.
Use the undo peer log-change command to remove the configuration.
The logging is enabled by default.
# Enable the logging of session state and event information of peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 log-change
5.1.48  peer next-hop-local
peer { ipv6-group-name | ipv6-address } next-hop-local
undo peer { ipv6-group-name | ipv6-address } next-hop-local
View
Use the peer next-hop-local command to configure the next hop of routes advertised to a peer/peer group as the local router.
Use the undo peer next-hop-local command to restore the default.
By default, the system sets the next hop of routes advertised to an EBGP peer/peer group to the local router, but does not set for routes outgoing to an IBGP peer/peer group.
# Set the next hop of routes advertised to EBGP peer group test to the router itself.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer test next-hop-local
5.1.49  peer preferred-value
peer { ipv6-group-name | ipv6-address } preferred-value value
undo peer { ipv6-group-name | ipv6-address } preferred-value
View
value: Preferred value, in the range 0 to 65535.
Use the peer preferred-value command to assign a preferred value to routes received from a peer or peer group.
Use the undo peer preferred-value command to restore the default.
By default, routes received from a peer or peer group have a preferred value of 0.
Routes learned from peers each have an initial preferred value. Among multiple routes to the same destination, the route with the biggest value is selected.
Note that:
If you both reference a routing policy and use the command peer { ipv6-group-name | ipv6-address } preferred-value value to set a preferred value for routes from a peer, the routing policy sets a non-zero preferred value for routes matching it. Other routes not matching the routing policy uses the value set with the command. If the preferred value in the routing policy is zero, the routes matching it will also use the value set with the command. For information about using a routing policy to set a preferred value, refer to the peer { ipv6-group-name | ipv6-address } route-policy route-policy-name { import | export } command and the apply preferred-value preferred-value command.
# Configure the preferred value as 50 for routes from peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 preferred-value 50
5.1.50  peer public-as-only
peer { ipv6-group-name | ipv6-address } public-as-only
undo peer { ipv6-group-name | ipv6-address } public-as-only
View
Use the peer public-as-only command to configure IPv6 BGP updates to a peer/peer group to not carry private AS numbers.
Use the undo peer public-as-only command to allow IPv6 BGP updates to a peer/peer group to carry private AS numbers.
By default, BGP updates carry the private AS number.
The command does not take effect if the BGP update has both the public AS number and private AS number. The range of private AS number is from 64512 to 65535.
# Carry no private AS number in BGP updates sent to the peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 public-as-only
5.1.51  peer reflect-client
peer { ipv6-group-name | ipv6-address } reflect-client
undo peer { ipv6-group-name | ipv6-address } reflect-client
View
Use the peer reflect-client command to configure the router as a route reflector and specify a peer/peer group as a client.
Use the undo peer reflect-client command to remove the configuration.
By default, neither route reflector nor client is configured.
Related commands: reflect between-clients, reflector cluster-id.
# Configure the local device as a route reflector and specify the peer group test as a client.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer test reflect-client
5.1.52  peer route-limit
peer { ipv6-group-name | ipv6-address } route-limit limit [ percentage ]
undo peer { ipv6-group-name | ipv6-address } route-limit
View
limit: Specifies the upper limit of address prefixes that can be received from the peer or peer group. The limit is in the range 1 to 6144.
percentage: Specifies the percentage of routes to generate alarm information, ranging from 1 to 100, with the default as 75.
Use the peer route-limit command to set the maximum number of prefixes that can be received from a peer/peer group.
Use the undo peer route-limit command to restore the default.
By default, the router has no limit on prefixes from a peer/peer group.
The router will end the peer relation when the number of address prefixes received for the peer exceeds the limit.
# Set the number of prefixes allowed to receive from the peer 1:2::3:4 to 1000.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 route-limit 1000
5.1.53  peer route-policy
undo peer { ipv6-group-name | ipv6-address } route-policy route-policy-name { import | export }
View
route-policy-name: Specifies route-policy name, a string of 1 to 19 characters.
import: Applies the routing policy to routes from the peer (group).
export: Applies the routing policy to routes to the peer (group).
Use the peer route-policy command to apply a routing policy to routes incoming from or outgoing to a peer or peer group.
Use the undo peer route-policy command to remove the configuration.
By default, no routing policy is specified for the peer (group).
Use of the peer route-policy command does not apply the if-match interface clause defined in the routing policy. Refer to Routing Policy Commands in the part discussing IPv4 routing for related information.
# Apply the routing policy test-policy to routes received from the peer group test.
[Sysname] route-policy test-policy permit node 10
[Sysname-route-policy] if-match cost 10
[Sysname-route-policy] apply cost 65535
[Sysname-route-policy] quit
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer test route-policy test-policy import
5.1.54  peer route-update-interval
peer { ipv6-group-name | ipv6-address } route-update-interval seconds
undo peer { ipv6-group-name | ipv6-address } route-update-interval
View
seconds: Specifies the minimum interval for sending the same update to a peer (group) from 5 to 600 seconds.
Use the peer route-update-interval command to specify the interval for sending the same update to a peer/peer group.
Use the undo peer route-update-interval command to restore the default.
By default, the interval is 15 seconds for the IBGP peer, and 30 seconds for the EBGP peer.
# Specify the interval for sending the same update to the peer 1:2::3:4 as 10 seconds.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 route-update-interval 10
5.1.55  peer substitute-as
peer { ipv6-group-name | ipv6-address } substitute-as
undo peer { ipv6-group-name | ipv6-address } substitute-as
View
Use the peer substitute-as command to substitute the local AS number for the AS number of a peer/peer group in the AS_PATH attribute.
Use the undo peer substitute-as command to remove the configuration.
The substitution is not configured by default.
# Substitute the local AS number for the AS number of peer 1:2::3:4.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer 1:2::3:4 substitute-as
5.1.56  peer timer
peer { ipv6-group-name | ipv6-address } timer keepalive keepalive hold holdtime
undo peer { ipv6-group-name | ipv6-address } timer
View
keepalive: Specifies the keepalive interval in seconds, ranging from 1 to 21845.
holdtime: Specifies the holdtime in seconds, ranging from 3 to 65535.
Use the peer timer command to configure keepalive interval and holdtime interval for a peer or peer group.
Use the undo peer timer command to restore the default.
keepalive interval defaults to 60 seconds, and holdtime interval defaults to 180 seconds
Note that:
l           The timer configured with this command is preferred to the timer configured with the timer command.
l           The holdtime interval must be at least three times the keepalive interval.
Related commands: timer.
# Configure the keepalive interval and holdtime interval for the peer group test as 60 seconds and 180 seconds.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] peer test timer keepalive 60 hold 180
5.1.57  preference
undo preference
View
external-preference: Preference of EBGP route learned from an EBGP peer, in the range 1 to 255.
internal-preference: Preference of IBGP route learned from an IBGP peer, in the range 1 to 255.
local-preference: Preference of IPv6 BGP local route, in the range 1 to 255.
route-policy-name: Routing policy name, a string of 1 to 19 characters. The routing policy can set a preference for routes passing it. The default value applies to the routes filtered out.
Use the preference command to configure preferences for EBGP, IBGP, and local routes.
Use the undo preference command to restore the default.
The bigger the preference value is, the lower the preference is. The default values of external-preference, internal-preference and local-preference are 255, 255 and 130 respectively.
# Configure preferences for EBGP, IBGP, and local routes as 20, 20 and 200.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] preference 20 20 200
5.1.58  reflect between-clients
undo reflect between-clients
View
None
Use the reflect between-clients command to enable route reflection between clients.
Use the undo reflect between-clients command to disable this function.
By default, route reflection between clients is enabled.
After a route reflector is configured, it reflects routes between clients. If the clients are fully meshed, it is recommended to disable route reflection on the route reflector to reduce costs.
Related commands: reflector cluster-id, peer reflect-client.
# Enable route reflection between clients.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] reflect between-clients
5.1.59  reflector cluster-id
reflector cluster-id cluster-id
undo reflector cluster-id
View
cluster-id: Specifies the cluster ID of the route reflector, an integer from 1 to 4294967295 (the system translates it into an IPv4 address) or an IPv4 address.
Use the reflector cluster-id command to configure the cluster ID of the route reflector.
Use the undo reflector cluster-id command to remove the configured cluster ID.
By default, a route reflector uses its router ID as the cluster ID.
Usually, there is only one route reflector in a cluster, so the router ID of the route reflector identifies the cluster. If multiple route reflectors are configured to improve the stability of the network, you should use this command to configure the identical cluster ID for all the reflectors to avoid routing loops.
Related commands: reflect between-clients, peer reflect-client.
# Set 50 as the cluster ID for the route reflector, which is one of multiple route reflectors in the cluster.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] reflector cluster-id 50
5.1.60  refresh bgp ipv6
refresh bgp ipv6 { ipv6-address | all | external | group ipv6-group-name | internal } { export | import }
View
ipv6-address: Soft-resets the connection with an IPv6 BGP peer.
all: Soft-resets all IPv6 BGP connections.
external: Soft-resets EBGP connections.
group ipv6-group-name: Soft-resets connections with a peer group. The name of the peer group is a string of 1 to 47 characters.
internal: Soft-resets IBGP connections.
export: Performs soft reset in outbound direction.
import: Performs soft reset in inbound direction.
Use the refresh bgp ipv6 command to soft reset specified IPv6 BGP connections. With this feature, you can refresh the IPv6 BGP routing table and apply a new available policy without tearing down BGP connections.
To perform IPv6 BGP soft reset, all routers in the network should support route-refresh. If a router not supporting route refresh exists in the network, you need to use the peer keep-all-routes command on the local router to save all route updates before performing soft reset.
# Soft reset inbound IPv6 BGP connections.
<Sysname> refresh bgp ipv6 all import
5.1.61  reset bgp ipv6
reset bgp ipv6 { as-number | ipv6-address [ flap-info ] | all | group ipv6-group-name | external | internal }
View
as-number: Resets the IPv6 BGP connections to peers in the specified AS.
ipv6-address: Resets the connection to the specified IPv6 BGP peer.
flap-info: Clears the history information of routing flaps.
all: Resets all IPv6 BGP connections.
group ipv6-group-name: Resets the connections to the specified IPv6 BGP peer group.
external: Resets all the EBGP connections.
internal: Resets all the IBGP connections.
Use the reset bgp ipv6 command to reset specified IPv6 BGP connections.
# Reset all the IPv6 BGP connections.
<Sysname> reset bgp ipv6 all
5.1.62  reset bgp ipv6 dampening
reset bgp ipv6 dampening [ ipv6-address prefix-length ]
View
Use the reset bgp ipv6 dampening command to clear dampened IPv6 BGP route information and release suppressed routes.
If no ipv6-address prefix-length is specified, all dampened IPv6 BGP route information will be cleared.
# Clear the dampened information of routes to 2345::/64 and release suppressed routes.
<Sysname> reset bgp ipv6 dampening 2345:: 64
5.1.63  reset bgp ipv6 flap-info
reset bgp ipv6 flap-info [ ipv6-address/prefix-length | regexp as-path-regexp | as-path-acl as-path-acl-number ]
View
ipv6-address: Clears the flap statistics for the specified IPv6 address.
prefix-length: Prefix length of the address, in the range 1 to 128.
as-path-regexp: Clears the flap statistics for routes matching the AS path regular expression.
as-path-acl-number: Clears the flap statistics for routes matching the AS path ACL. The number is in the range 1 to 256.
Use the reset bgp ipv6 flap-info command to clear IPv6 routing flap statistics.
If no parameters are specified, the flap statistics of all the routes will be cleared
# Clear the flap statistics of the routes matching AS path ACL 10.
[Sysname] ip as-path 10 permit ^100.*200$
[Sysname] quit
<Sysname> reset bgp ipv6 flap-info as-path-acl 10
5.1.64  router-id
router-id router-id
undo router-id
View
BGP view
router-id: Router ID in IP address format.
Use the router-id command to specify a router ID for the router.
Use the undo router-id command to remove a router ID.
To run IPv6 BGP protocol, a router must have a router ID, an unsigned 32-bit integer and the unique ID of the router in the AS.
A router ID can be configured manually. If not, the system will select a router ID automatically from the current interfaces’ IPv4 addresses. The selection sequence is the highest IPv4 address of Loopback interfaces’ addresses, then the highest IPv4 address of physical interfaces’ addresses if no Loopback interfaces are configured.
Only when the interface with the router ID is removed or the manually configured router ID is removed, will the system select another Router ID. To improve network reliability, it is recommended to configure the IPv4 address of a loopback interface as the router ID.
# Specify the router ID of the router as 10.18.4.221.
[Sysname] bgp 100
[Sysname-bgp] router-id 10.18.4.221
5.1.65  synchronization
synchronization
undo synchronization
View
None
Use the synchronization command to enable the synchronization between IPv6 BGP and IGP.
Use the undo synchronization command to disable the synchronization.
The feature is disabled by default.
With this feature enabled and when a non-BGP router is responsible for forwarding packets in an AS, IPv6 BGP speakers in the AS cannot advertise routing information to other ASs unless all routers in the AS know the latest routing information.
By default, upon receiving an IPv6 IBGP route, the BGP router only checks whether the next hop is reachable before advertisement. If synchronization is enabled, the IBGP route can be advertised to EBGP peers only when the route is also advertised by the IGP.
# Enable the route synchronization between IPv6 BGP and IGP.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] synchronization
5.1.66  timer
undo timer
View
keepalive: Keepalive interval in seconds, ranging from 1 to 21845.
holdtime: Holdtime interval in seconds, ranging from 3 to 65535.
Use the timer command to specify IPv6 BGP keepalive interval and holdtime interval.
Use the undo timer command to restore the default.
By default, the keepalive and holdtime intervals are 60s and 180s respectively.
Note that:
l           Timer configured using the peer timer command is preferred to the timer configured using the timer command.
l           The configured timer applies to all the IPv6 BGP peers. It becomes valid only after the corresponding IPv6 BGP connections are reset.
Related commands: peer timer.
# Configure keepalive interval and holdtime interval as 60 and 180 seconds.
[Sysname] bgp 100
[Sysname-bgp-af-ipv6] timer keepalive 60 hold 180
Chapter 6  Routing Policy Configuration Commands
6.1  Routing Policy Common Configuration Commands
Refer to IPv4 routing commands for routing policy common configuration commands.
6.2  IPv6 Routing Policy Configuration Commands
6.2.1  apply ipv6 next-hop
undo apply ipv6 next-hop
View
Routing policy view
ipv6-address: Next hop IPv6 address.
Use the apply ipv6 next-hop command to apply a next hop to IPv6 routes.
Use the undo apply ipv6 next-hop command to remove the clause configuration.
No next hop address is set for IPv6 routing information by default.
Using the apply ipv6 next-hop command to set a next hop when redistributing routes does not take effect.
# Create routing policy policy1 with node 10, matching mode permit. If a route matches AS path list 1, set next hop 3ff3:506::1 for it.
[Sysname-route-policy] if-match as-path 1
[Sysname-route-policy] apply ipv6 next-hop 3ffe:506::1
6.2.2  display ip ipv6-prefix
display ip ipv6-prefix [ ipv6-prefix-name ]
View
Use the display ip ipv6-prefix command to display the statistics of the specified IPv6 prefix list. If no IPv6 prefix list is specified, the statistics of all the IPv6 prefix lists will be displayed.
# Display the statistics of all the IPv6 prefix lists.
<Sysname> display ip ipv6-prefix
Prefix-list6 abc
Permitted 0
Denied 0
         index:   10            permit  ::/0
         index:   20             permit  ::/1                 ge  1   le  128
Table 6-1 Description on the fields of the display ip ipv6-prefix command
Prefix-list6
Name of the IPv6 prefix list
Permitted
Number of routes satisfying the match criterion
Denied
Number of routes not satisfying the match criterion
Index
Internal serial number of address prefix list
Permit
Matching mode: permit, deny
::/1
IPv6 address and its prefix length for matching
ge
greater-equal, the lower limit prefix length
Le
less-equal, the upper limit prefix length
6.2.3  if-match ipv6
if-match ipv6 { address | next-hop | route-source } { acl acl6-number | prefix-list ipv6-prefix-name }
undo if-match ipv6 { address | next-hop | route-source } [ acl | prefix-list ]
View
Routing policy view
address: Matches the destination address of IPv6 routing information.
next-hop: Matches the next hop of IPv6 routing information.
route-source: Matches the source address of IPv6 routing information.
acl acl6-number: Specifies the number of an IPv6 ACL for filtering, in the range 2000 to 3999 for address, and 2000 to 2999 for next-hop and route-source.
prefix-list ipv6-prefix-name: Specifies the name of a IPv6 prefix list for filtering, a string of 1 to 19 characters.
Use the if-match ipv6 command to configure a destination, next hop or source address based match criterion for IPv6 routes.
Use the undo if-match ipv6 command to remove the match criterion.
The match criterion is not configured by default.
# Create a routing policy named policy1 with node 10, matching mode as permit. Define an if-match clause to permit the routing information whose next hop address matches IPv6 prefix list p1.
[Sysname-route-policy] if-match ipv6 next-hop prefix-list p1
6.2.4  ip ipv6-prefix
ip ipv6-prefix ipv6-prefix-name [ index index-number ] { deny | permit } ipv6-address prefix-length [ greater-equal min-prefix-length ] [ less-equal max-prefix-length ]
undo ip ipv6-prefix ipv6-prefix-name [ index index-number ]
View
ipv6-prefix-name: IPv6 prefix list name, a string of 1 to 19 characters, for uniquely specifying an IPv6 prefix list.
index-number: Index number, in the range 1 to 65535, for uniquely specifying an IPv6 prefix list item. The item with a smaller index-number will be tested first.
permit: Specifies the matching mode for the IPv6 prefix list as permit, that is, if a route matches the IPv6 prefix list, it passes the IPv6 prefix list without needing to enter the next item for test. If not, it will enter the next item test.
deny: Specifies the matching mode for the IPv6 prefix list as deny, that is, if a route  matches the IPv6 prefix list, the route neither passes the filter nor enters the next node for test; if not, the route will enter the next item test.
ipv6-address prefix-length: Specifies an IPv6 prefix and prefix length, with prefix-length being in the range 0 to 128. When specified as :: 0, it matches the default route.
greater-equal min-prefix-length: Greater than or equal to the minimum prefix length.
less-equal max-prefix-length: Less than or equal to the maximum prefix length.
The length relation is mask-length <= min-mask-length <= max-mask-length <= 128. If only min-prefix-length is specified, the prefix length range is [ min-prefix-length, 128 ]. If only max-prefix-length is specified, the prefix length range is [ prefix-length, max-prefix-length ]. If both min-prefix-length and max-prefix-length are specified, the prefix length range is [ min-prefix-length, max-prefix-length ].
Use the ip ipv6-prefix command to configure an IPv6 prefix list item.
Use the undo ip ipv6-prefix command to remove an IPv6 prefix list or an item.
No IPv6 prefix list is configured by default.
The IPv6 address prefix list is used to filter IPv6 addresses. It may have multiple items, and each of them specifies a range of IPv6 prefix. The filtering relation among items is logic OR, namely, a route passing an item will pass the prefix list.
The IPv6 prefix range is determined by prefix-length and [ min-prefix-length, max-prefix-length ]. If both mask-length and [ min-mask-length, max-mask-length ] are specified, then the IPv6 addresses must satisfy both of them.
If ipv6-address prefix-length is specified as :: 0, then only the default route matches.
If you want it to match all the routes, configure it as :: 0 less-equal 128.
# Permit the IPv6 addresses with mask length between 32 bits and 64 bits.
[Sysname] ip ipv6-prefix abc permit :: 0 greater-equal 32 less-equal 64
# Deny the IPv6 addresses with prefix as 3FFE:D00::/32, prefix length greater than or equal to 32 bits.
[Sysname] ip ipv6-prefix abc deny 3FEE:D00:: 32 less-equal 128
6.2.5  reset ip ipv6-prefix
reset ip ipv6-prefix [ ipv6-prefix-name ]
View
Use the reset ip ipv6-prefix command to clear the statistics of the specified IPv6 prefix list. If no name is specified, the statistics of all IPv6 prefix lists will be cleared.
# Clear the statistics of IPv6 prefix list abc.
<Sysname> reset ip ipv6-prefix abc
