01-PFC命令
本章节下载: 01-PFC命令 (280.00 KB)
1.1.1 display priority-flow-control
1.1.2 priority-flow-control (Ethernet interface view)
1.1.3 priority-flow-control (System view)
1.1.4 priority-flow-control deadlock auto-recover action
1.1.5 priority-flow-control deadlock auto-recover cos
1.1.6 priority-flow-control deadlock cos
1.1.7 priority-flow-control deadlock enable
1.1.8 priority-flow-control deadlock precision
1.1.9 priority-flow-control deadlock recover
1.1.10 priority-flow-control deadlock recover-mode
1.1.11 priority-flow-control deadlock threshold
1.1.12 priority-flow-control deadlock threshold action
1.1.13 priority-flow-control dot1p headroom
1.1.14 priority-flow-control dot1p ingress-buffer dynamic
1.1.15 priority-flow-control dot1p ingress-buffer static
1.1.16 priority-flow-control dot1p ingress-threshold-offset
1.1.17 priority-flow-control dot1p reserved-buffer
1.1.18 priority-flow-control no-drop dot1p (Ethernet interface view)
1.1.19 priority-flow-control no-drop dot1p (System view)
1.1.20 priority-flow-control headroom
1.1.21 shutdown-interval priority-flow-control
display priority-flow-control命令用来显示接口的PFC(Priority-based Flow Control,基于优先级的流量控制)信息。
display priority-flow-control interface [ interface-type [ interface-number ] ]
interface-type:显示指定类型接口的PFC信息。interface-type表示接口类型。不指定该参数时,则显示设备上所有以太网接口的PFC信息。
interface-number:显示指定接口的PFC信息。interface-number表示接口编号。不指定该参数时,显示设备上指定类型的以太网接口的PFC信息。
# 显示所有接口的PFC信息。
<Sysname> display priority-flow-control interface
Conf -- Configured mode Ne -- Negotiated mode P -- Priority
Interface Conf Ne Dot1pList P Recv Sent
XGE1/0/1 Auto On 0,2-3,5-6 0 178 43
表1-1 display priority-flow-control interface命令显示信息描述表
Conf -- Configured mode |
本地配置的PFC功能的状态 |
Ne -- Negotiated mode |
PFC功能状态的协商结果 |
P -- Priority |
开启PFC功能的802.1p优先级 |
接口简名 |
Conf |
本地配置的PFC功能的状态: · Auto表示接口与对端自动协商是否开启PFC功能 · Off表示接口下未开启PFC功能 · On表示接口下已开启PFC功能 |
Ne |
PFC功能状态的协商结果: · Off表示接口PFC处于未开启状态 · On表示接口PFC处于开启状态 |
Dot1pList |
开启PFC功能的802.1p优先级队列,共8个(0~7)优先级队列 |
P |
开启PFC功能的802.1p优先级队列中,有数据帧收发的优先级队列,收发帧数据为0的队列不显示 |
Recv |
收到的PFC PAUSE帧数量 |
Sent |
发送的PFC PAUSE帧数量 |
· priority-flow-control
· priority-flow-control no-drop dot1p
priority-flow-control命令用来配置接口的PFC功能。
undo priority-flow-control命令用来关闭PFC功能。
priority-flow-control { auto | enable }
PFC功能处于关闭状态。
以太网接口视图
auto:表示与对端自动协商是否开启PFC功能。
enable:表示强制开启PFC功能。
如果本端和对端设备的PFC功能处于使能状态,并配置了priority-flow-control no-drop dot1p dot1p-list命令,则当本端收到的802.1p优先级在dot1p-list范围内的报文发生拥塞时,会通知对端设备暂时停止向本端发送对应优先级的报文;拥塞解除后,再通知对端继续发送对应优先级的报文。从而保证本设备在转发802.1p优先级在dot1p-list范围内的报文时不丢包。
多次在系统视图和接口视图下执行本命令,最后一次执行的命令生效。
# 在以太网接口Ten-GigabitEthernet1/0/1上开启PFC功能。
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control enable
· display priority-flow-control
· priority-flow-control (System view)
priority-flow-control命令用来开启所有接口的PFC功能。
undo priority-flow-control命令用来关闭所有接口的PFC功能。
PFC功能处于关闭状态。
enable:表示强制开启PFC功能。
# 开启所有接口的PFC功能。
[Sysname] priority-flow-control enable
· priority-flow-control (Ethernet interface view)
priority-flow-control deadlock auto-recover action命令用来配置设备在自动恢复PFC死锁检测的延迟时间内对报文的处理动作。
undo priority-flow-control deadlock auto-recover action命令用来恢复缺省情况。
priority-flow-control deadlock auto-recover action { discard | forwarding }
设备在自动恢复PFC死锁的延迟时间内转发收到的数据报文。
discard:丢弃收到的数据报文。
forwarding:转发收到的数据报文。
当设备处于PFC死锁状态时,无法配置本命令。
# 配置当设备进入PFC死锁状态后对数据报文进行丢弃。
[Sysname] priority-flow-control deadlock auto-recover action discard
· priority-flow-control deadlock cos
· priority-flow-control deadlock enable
priority-flow-control deadlock auto-recover cos命令用来配置PFC死锁检测自动恢复的延迟周期。
undo priority-flow-control deadlock auto-recover cos命令用来删除PFC死锁检测自动恢复的延迟周期。
priority-flow-control deadlock auto-recover cos cos-value delay delay-interval
undo priority-flow-control deadlock auto-recover cos [ cos-value ]
未配置PFC死锁检测的恢复周期。
cos cos-value:报文CoS值,取值范围为0~7。不同的CoS值对应不同的802.1p优先级,可以通过display qos map-table dot1p-lp命令查看。
delay delay-time:PFC死锁检测自动恢复的延迟周期,取值范围为1~15。
PFC死锁检测功能可以按周期检测携带指定CoS值的报文是否发生死锁,在设备进入PFC死锁状态后,设备自动恢复时会在延迟时间结束后恢复PFC死锁检测功能。延迟时间 = 100ms + delay-interval * 100ms。
本命令仅在PFC死锁检测功能的恢复方式为自动恢复时生效。当设备处于PFC死锁状态时,无法配置本命令。
指定的CoS值必须在priority-flow-control no-drop dot1p命令配置的802.1p优先级内。
对于不同CoS值可以配置相同的延迟恢复周期。
对于同一CoS值,多次执行本命令,最后一次执行的命令生效。
# 配置CoS值为7的PFC死锁自动恢复的延迟周期为5。
[Sysname] priority-flow-control deadlock auto-recover cos 7 delay 5
· display qos map-table dot1p-lp(ACL和QoS/优先级映射)
· priority-flow-control deadlock precision
priority-flow-control deadlock cos命令用来配置PFC死锁检测的周期。
undo priority-flow-control deadlock cos命令用来删除PFC死锁检测的周期。
priority-flow-control deadlock cos cos-value interval interval
undo priority-flow-control deadlock cos [ cos-value ]
未配置PFC死锁检测的周期。
interval interval:PFC死锁检测周期,取值范围为1~15。
PFC死锁检测功能可以按周期检测携带指定CoS值的报文是否发生死锁。检测周期由interval interval和PFC死锁检测定时器的精度共同决定。
指定优先级报文死锁检测周期的具体时间等于priority-flow-control deadlock cos interval命令配置的interval值*priority-flow-control deadlock precision命令配置的时间精度值。例如配置priority-flow-control deadlock cos 5 interval 10表示Cos优先级为5的报文的死锁检测周期为10个精度单位,同时priority-flow-control deadlock precision命令配置精度为高精度(代表10毫秒),则Cos优先级为5的报文的死锁检测周期时间为10*10毫秒=100毫秒。
指定的CoS值必须在priority-flow-control no-drop dot1p命令配置的802.1p优先级内。不同的CoS值对应不同的802.1p优先级,可以通过display qos map-table dot1p-lp命令查看。
对于不同CoS值可以配置相同的检测周期。
# 配置CoS值为7的PFC死锁检测周期为5。
[Sysname] priority-flow-control deadlock cos 7 interval 5
· display qos map-table dot1p-lp(ACL和QoS命令参考/优先级映射)
priority-flow-control deadlock enable命令用来开启PFC死锁检测功能。
undo priority-flow-control deadlock enable命令用来关闭PFC死锁检测功能。
PFC死锁检测功能处于关闭状态。
以太网接口视图
开启指定802.1p优先级的PFC功能后(通过priority-flow-control和priority-flow-control no-drop dot1p命令配置),当指定优先级的报文形成环路时,会导致数据缓冲区内报文无法转发,此时设备进入PFC死锁状态。
通过配置本命令,可以定期检测设备是否处于PFC死锁状态,并解除PFC死锁状态。
# 在Ten-GigabitEthernet1/0/1下开启PFC死锁检测功能。
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control deadlock enable
priority-flow-control deadlock precision命令用来配置PFC死锁检测定时器的精度。
undo priority-flow-control deadlock precision命令用来恢复缺省情况。
priority-flow-control deadlock precision { high | low | normal }
PFC死锁检测定时器的精度为普通精度。
high:表示使用高精度的PFC死锁检测定时器。
low:表示使用低精度的PFC死锁检测定时器。
normal:表示使用普通精度的PFC死锁检测定时器。
slot slot-number:配置指定成员设备的PFC死锁检测定时器的精度,slot-number表示设备在IRF中的成员编号。
使用本命令可调整PFC死锁检测定时器的精度,从而控制PFC死锁检测时间。本系列设备PFC死锁检测定时器高精度所代表的时间为10 ms,普通精度所代表的时间为100 ms。
# 配置PFC死锁检测定时器精度为高精度。
[Sysname] priority-flow-control deadlock precision high
priority-flow-control deadlock recover命令用来手工恢复PFC死锁检测功能。
以太网接口视图
在配置本命令前,需执行priority-flow-control deadlock recover-mode命令配置PFC死锁检测功能的恢复方式。
当配置了手工恢复方式,设备能解除死锁状态,但同时死锁检测功能和PFC功能会暂时失效,需要手工执行本命令来恢复PFC死锁检测功能。恢复PFC死锁检测功能的同时可以让PFC功能继续生效。
# 在Ten-GigabitEthernet1/0/1下恢复PFC死锁检测功能。
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control deadlock recover
· priority-flow-control deadlock recover-mode
priority-flow-control deadlock recover-mode命令用来配置PFC死锁检测功能的恢复方式。
undo priority-flow-control deadlock recover-mode命令用来恢复缺省情况。
priority-flow-control deadlock recover-mode { auto | manual }
PFC死锁检测功能恢复方式为自动恢复方式。
以太网接口视图
auto:配置PFC死锁检测功能的恢复方式为自动恢复。
manual:配置PFC死锁检测功能的恢复方式为手工恢复。
当设备检测到PFC死锁状态后,设备自动恢复时会在延迟周期结束后解除PFC死锁状态,恢复PFC功能和PFC死锁检测功能。在PFC死锁检测自动恢复的延迟周期内,设备将关闭PFC功能和PFC死锁检测功能,以便报文能够正常转发。PFC死锁状态解除后,用户可采用自动或手工方式来恢复PFC死锁检测功能。恢复PFC死锁检测功能会让PFC功能继续生效。所以,通常情况下,使用自动恢复方式即可。当报文环路无法消除,设备频繁处于PFC死锁状态时,用户可以使用手工恢复方式,并尽快排除故障,再执行priority-flow-control deadlock recover命令,恢复PFC死锁检测功能和PFC功能。
# 在Ten-GigabitEthernet1/0/1下配置PFC死锁检测功能恢复方式为手工恢复。
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control deadlock recover-mode manual
priority-flow-control deadlock threshold命令用来配置在指定周期内发生PFC死锁的上限次数。
undo priority-flow-control deadlock threshold命令用来恢复缺省情况。
priority-flow-control deadlock threshold cos cos-value period period count count [ down-auto-recovery | error-down ]
undo priority-flow-control deadlock threshold cos [ cos-value ]
未配置指定周期内发生PFC死锁的上限次数。
period period:发生PFC死锁次数的检测周期,取值范围为1~60,单位为秒。
count count:指定周期内发生PFC死锁的上限次数,取值范围为1~500,单位为次数。
down-auto-recovery:在指定周期内端口发生PFC死锁的次数达到配置值时,端口将被关闭。在到达shutdown-interval priority-flow-control命令配置的端口状态自动恢复时间之后,端口将恢复到真实的物理状态,同时恢复端口的PFC功能。如果未指定本参数,则在检测周期内端口发生PFC死锁的次数达到上限后,将关闭端口以及端口对应802.1p优先级的PFC功能。
error-down:在检测周期内端口发生PFC死锁的次数达到上限,端口将被关闭。如果未指定本参数,则在检测周期内端口发生PFC死锁的次数达到上限,将关闭端口对应802.1p优先级的PFC功能。
当配置该命令后,在指定周期内端口发生PFC死锁的次数达到配置值时,设备将关闭对应端口对应优先级的PFC功能,此时用户需要排除故障手工执行undo priority-flow-control deadlock threshold命令恢复对应端口的PFC功能。
本命令配置的发生PFC死锁次数的检测周期需要大于priority-flow-control deadlock cos命令配置的PFC死锁检测周期,以便确认设备是否频繁处于PFC死锁状态。
# 配置5秒周期内发生PFC死锁的上限次数为100。
[Sysname] priority-flow-control deadlock threshold cos 7 period 5 count 100
· priority-flow-control deadlock threshold action
· shutdown-interval priority-flow-control
priority-flow-control deadlock threshold action命令用来配置在指定周期内端口发生PFC死锁的次数达到配置值时端口的动作。
undo priority-flow-control deadlock threshold action命令用来恢复缺省配置。
priority-flow-control deadlock threshold action { down-auto-recovery | error-down | turn-off }
在指定周期内端口发生PFC死锁的次数达到配置值时端口的动作以系统视图下priority-flow-control deadlock threshold命令为准。
以太网接口视图
down-auto-recovery:在指定周期内端口发生PFC死锁的次数达到配置值时,端口将被关闭。在到达shutdown-interval priority-flow-control命令配置的端口状态检测定时器超时时间之后,端口将恢复到真实的物理状态,同时恢复端口的PFC功能。
error-down:在指定周期内端口发生PFC死锁的次数达到配置值时,端口将被关闭,该端口不再转发流量。
turn-off:在指定周期内端口发生PFC死锁的次数达到配置值时,设备将关闭对应端口对应802.1p优先级的PFC功能。
端口发生PFC死锁的阈值及采样周期通过系统视图下priority-flow-control deadlock threshold命令配置。如果端口下没有配置本命令,则以系统视图下priority-flow-control deadlock threshold命令为准。如果端口下配置了本命令,则以端口的配置为准。
如果没有在系统视图下配置priority-flow-control deadlock threshold命令,则本命令不生效。
如果端口配置的action为turn-off,在指定周期内端口发生PFC死锁的次数达到配置值时,设备将关闭对应端口对应优先级的PFC功能,此时用户需要排除故障,手工先执行undo priority-flow-control enable命令,再执行priority-flow-control enable命令恢复对应端口的PFC功能。执行undo priority-flow-control deadlock threshold命令也可以恢复接口的PFC功能,但是可能影响多个接口的PFC状态,请根据实际情况使用。
如果端口配置的action为error-down,在指定周期内端口发生PFC死锁的次数达到配置值时,端口将被关闭,此时用户需要手工执行 undo shutdown 命令来恢复接口状态以及对应端口的PFC功能。
如果端口配置的action为down-auto-recovery,在指定周期内端口发生PFC死锁的次数达到配置值时,端口将被关闭,在到达shutdown-interval priority-flow-control命令配置的端口状态检测定时器超时时间之后,端口将恢复到真实的物理状态,同时恢复端口的PFC功能。
# 配置在指定周期内端口发生PFC死锁的次数达到配置值时,端口被关闭。
[Sysname-GigabitEthernet1/0/1] priority-flow-control deadlock threshold action error-down
priority-flow-control dot1p headroom命令用来配置Headroom缓存门限。
undo priority-flow-control dot1p headroom命令用来恢复缺省情况。
priority-flow-control dot1p dot1p headroom headroom-number
undo priority-flow-control dot1p dot1p headroom
40GE接口Headroom缓存门限为4000,10GE接口缓存门限为1000。
以太网接口视图
dot1p:802.1p优先级,取值范围为0~7。
headroom-number:Headroom缓存门限,取值范围为1~4095。
在配置本命令时,需执行priority-flow-control no-drop dot1p命令开启指定802.1p优先级的PFC功能。
多次执行本命令,同一802.1p优先级的Headroom缓存门限配置,最后一次执行的命令生效。
在报文转发过程中配置Headroom缓存门限值时,会导致流量中断,短暂丢包。
# 配置Headroom缓存门限为1000。
<sysname> system-view
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control dot1p 1 headroom 1000
priority-flow-control dot1p ingress-buffer dynamic命令用来配置动态反压帧触发门限。
undo priority-flow-control dot1p ingress-buffer dynamic命令用来恢复缺省情况。
priority-flow-control dot1p dot1p ingress-buffer dynamic ratio
undo priority-flow-control dot1p dot1p ingress-buffer
未配置动态反压帧触发门限。
以太网接口视图
ratio:动态反压帧触发门限,即可用空间的百分比,取值范围为1~100。
多次执行本命令,同一802.1p优先级的动态反压帧触发门限配置,最后一次执行的命令生效。
在报文转发过程中配置Headroom动态反压帧触发门限时,会导致流量中断,短暂丢包。
# 配置动态反压帧触发门限为30。
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control dot1p 1 ingress-buffer dynamic 30
priority-flow-control dot1p ingress-buffer static命令用来配置静态反压帧触发门限。
undo priority-flow-control dot1p ingress-buffer static命令用来恢复缺省情况。
priority-flow-control dot1p dot1p ingress-buffer static threshold
40G口静态反压帧触发门限为1000,10G口静态反压帧触发门限为250。
以太网接口视图
threshold:静态反压帧触发门限,取值范围为1~79872。
在报文转发过程中配置Headroom静态反压帧触发门限时,会导致流量中断,短暂丢包。
多次执行本命令,同一802.1p优先级的静态反压帧触发门限配置,最后一次执行的命令生效。
# 配置静态反压帧触发门限为1000。
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control dot1p 1 ingress-buffer static 1000
priority-flow-control dot1p ingress-threshold-offset命令用来配置反压帧停止门限与触发门限间的偏移量。
undo priority-flow-control dot1p ingress-threshold-offset命令用来恢复缺省情况。
priority-flow-control dot1p dot1p ingress-threshold-offset offset-number
undo priority-flow-control dot1p dot1p ingress-threshold-offset
40GE接口反压帧停止门限与触发门限间的偏移量为204,10GE接口反压帧停止门限与触发门限间的偏移量为51。
以太网接口视图
offset-number:反压帧停止门限与触发门限间的偏移量,取值范围为1~79872。
在报文转发过程中配置反压帧停止门限与触发门限间的偏移量时,会导致流量中断,短暂丢包。
# 配置反压帧停止门限与触发门限间的偏移量为1000。
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control dot1p 1 ingress-threshold-offset 1000
priority-flow-control dot1p reserved-buffer命令用来配置PFC预留门限。
undo priority-flow-control dot1p reserved-buffer命令用来恢复缺省情况。
priority-flow-control dot1p dot1p reserved-buffer reserved-number
undo priority-flow-control dot1p dot1p reserved-buffer
PFC预留门限为15。
以太网接口视图
reserved-number:PFC预留门限,取值范围为1~79872。
多次执行本命令,同一802.1p优先级的PFC预留门限配置,最后一次执行的命令生效。
在报文转发过程中配置PFC预留门限时,会导致流量中断,短暂丢包。
# 配置PFC预留门限为1000。
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control dot1p 1 reserved-buffer 1000
priority-flow-control no-drop dot1p命令用来开启指定802.1p优先级的PFC功能。
undo priority-flow-control no-drop dot1p命令用来关闭指定802.1p优先级的PFC功能。
所有802.1p优先级的PFC功能都处于关闭状态。
以太网接口视图
dot1p-list:802.1p优先级(dot1p优先级)列表,例如:1,3-5(表示数值区间时使用连字符“-”,数值之间用英文格式的逗号“,”分隔,最多可配置16个字符)。
如果本端和对端设备的PFC功能处于使能状态,并配置了本命令,则当本端收到的802.1p优先级在dot1p-list范围内的报文发生拥塞时,会通知对端设备暂时停止向本端发送对应优先级的报文;拥塞解除后,再通知对端继续发送对应优先级的报文。从而保证本设备在转发802.1p优先级在dot1p-list范围内的报文时不丢包。有关802.1p优先级的介绍,请参见“ACL和QoS配置指导”中的“QoS”。
本命令和flow-control、flow-control receive enable互斥。
在报文转发过程中开启或关闭指定802.1p优先级的PFC功能时,会导致流量中断,短暂丢包。
# 在以太网接口Ten-GigabitEthernet1/0/1上配置PFC功能的开启模式为自动协商模式,并开启802.1p优先级5的PFC功能。
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control auto
[Sysname-Ten-GigabitEthernet1/0/1] priority-flow-control no-drop dot1p 5
· flow-control(接口管理命令参考/以太网接口)
· flow-control receive enable(接口管理命令参考/以太网接口)
· priority-flow-control no-drop dot1p (System view)
priority-flow-control no-drop dot1p命令用来开启所有接口下指定802.1p优先级的PFC功能。
undo priority-flow-control no-drop dot1p命令用来关闭所有接口下指定802.1p优先级的PFC功能。
所有接口下802.1p优先级的PFC功能都处于关闭状态。
dot1p-list:802.1p优先级(dot1p优先级)列表,例如:1,3-5。(表示数值区间时使用连字符“-”,数值之间用英文格式的逗号“,”分隔,最多可配置16个字符)
# 开启所有接口802.1p优先级5的PFC功能。
[Sysname] priority-flow-control no-drop dot1p 5
· priority-flow-control no-drop dot1p (Ethernet interface view)
priority-flow-control headroom命令用来配置Headroom最大可用的cell资源。
undo priority-flow-control headroom命令用来恢复缺省情况。
priority-flow-control headroom headroom-number
Headroom最大可用的cell资源为12288。
headroom-number:最大可用的cell资源,取值范围为1~26624。
# 配置Headroom 1的最大可用的cell资源为1000。
[Sysname] priority-flow-control headroom 1000
shutdown-interval priority-flow-control命令用来配置指定周期内发生PFC死锁的次数达到上限导致端口被关闭,端口状态自动恢复的时长。
undo shutdown-interval priority-flow-control命令用来恢复缺省情况。
shutdown-interval [ priority-flow-control ] interval
undo shutdown-interval [ priority-flow-control ]
端口状态自动恢复的时长为30秒。
priority-flow-control:表示PFC功能。如果未配置本参数,则表示本命令配置的是全局端口状态自动恢复的时长。
interval:端口状态自动恢复的时长,取值范围为0~300,单位为秒。取值为0时,表示系统不自动恢复端口状态,需要用户执行undo shutdown命令手动恢复端口状态。
某些协议模块在特定情况下会自动关闭某个端口,比如当开启了BPDU保护功能的端口收到配置消息时,MSTP协议模块将自动关闭该端口。在协议自动关闭端口的同时,系统会启动一个自动恢复端口状态的定时器。如果直到定时器超时(即经过time秒之后),该端口仍处于关闭状态,系统自动将端口恢复到真实的物理状态。
如果用户在端口定时检测过程中将检测时间间隔修改为T1,修改时刻距协议关闭端口时间间隔为T。
· 若T<T1,则被关闭的端口会再经过T1-T时间后被恢复。
· 若T>=T1,则被关闭的端口会立即恢复。
例如当前time配置为30,当端口被协议模块关闭2秒(T=2)后,修改time为10(T1=10),则该接口会再经过8秒后被恢复;如果当前time为30,端口被协议模块关闭10秒后,修改time为2,则该端口会立即恢复。
# 配置指定周期内发生PFC死锁的次数达到上限导致端口被关闭,端口状态自动恢复的时长为100秒。
[Sysname] shutdown-interval priority-flow-control 100
