- 17-High Availability Configuration Guide
- 01-Ethernet OAM configuration
- 02-CFD configuration
- 03-DLDP configuration
- 04-ERPS configuration
- 05-Smart Link configuration
- 06-Monitor Link configuration
- 07-S-Trunk configuration
- 08-Error code detection configuration
- 09-VRRP configuration
- 10-BFD configuration
- 11-Track configuration
- 12-Process placement configuration
- 13-Interface collaboration configuration
06-Monitor Link configuration | 139.54 KB |
Restrictions and guidelines: Monitor Link configuration
Monitor Link tasks at a glance
Enabling Monitor Link globally
Configuring monitor link group member interfaces
Configuring monitor link group member interfaces in monitor link group view
Configuring monitor link group member interfaces in interface view
Configuring a monitor link group to monitor a BGP instance
Configuring the uplink interface threshold for triggering monitor link group state switchover
Configuring the switchover delay for the downlink interfaces in a monitor link group
Verifying and maintaining Monitor Link
Configuring Monitor Link
About Monitor Link
Monitor Link is an H3C-proprietary solution that associates the state of downlink interfaces with the state of uplink interfaces in a monitor link group. When Monitor Link shuts down the downlink interfaces because of an uplink failure, the downstream device changes connectivity to another link.
Figure 1 Monitor Link application scenario
A monitor link group contains uplink and downlink interfaces. An interface can belong to only one monitor link group.
· Uplink interfaces are the monitored interfaces.
· Downlink interfaces are the monitoring interfaces.
As shown in Figure 1:
· Port B1 and Port B2 of Device B form a monitor link group. Port B1 is an uplink interface, and Port B2 is a downlink interface.
· Port D1 and Port D2 of Device D form another monitor link group. Port D1 is an uplink interface, and Port D2 is a downlink interface.
A monitor link group works independently of other monitor link groups. When a monitor link group does not contain any uplink interface or all its uplink interfaces are down, the monitor link group goes down. It forces all downlink interfaces down at the same time. When any uplink interface comes up, the monitor link group comes up and brings up all the downlink interfaces.
Follow these restrictions and guidelines when you configure Monitor Link:
· Do not manually shut down or bring up the downlink interfaces in a monitor link group.
· To avoid frequent state changes of downlink interfaces in the event that uplink interfaces in the monitor link group flap, you can configure a switchover delay. The switchover delay is the time that the downlink interfaces wait before they come up following an uplink interface.
To configure Monitor Link, perform the following tasks:
· Enabling Monitor Link globally
· Creating a monitor link group
· Configuring monitor link group member interfaces
· Configuring a monitor link group to monitor a BGP instance
· (Optional.) Configuring the uplink interface threshold for triggering monitor link group state switchover
· (Optional.) Configuring the switchover delay for the downlink interfaces in a monitor link group
All monitor link groups can operate only after you enable Monitor Link globally. When you disable Monitor Link globally, all monitor link groups cannot operate and the downlink interfaces brought down by the monitor link groups resume their original states.
1. Enter system view.
2. Enable Monitor Link globally.
undo monitor-link disable
By default, Monitor Link is enabled globally.
2. Create a monitor link group and enter monitor link group view.
monitor-link group group-id
· An interface can be assigned to only one monitor link group.
· To avoid undesired down/up state changes on the downlink interfaces, configure uplink interfaces before you configure downlink interfaces.
· If you have configured an interface as the downlink interface of a monitor link group, do not configure its subinterfaces as the uplink interfaces of any monitor link group. Otherwise, the Monitor Link operation might be interrupted.
· The state of subinterfaces is associated with the state of the interface. Do not add the interface and its subinterfaces to the same monitor link group. Otherwise, the monitor link group performance might be affected.
· If you have configured a Selected port of an aggregation group as the downlink interface of a monitor link group, do not configure an Unselected port of the aggregation group as the uplink interface of the monitor link group.
· Do not add an aggregate interface and its member ports to the same monitor link group.
· You can configure member interfaces for a monitor link group in monitor link group view or interface view. Configurations made in these views have the same effect. The configuration is supported by the following interfaces:
¡ Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces.
¡ Layer 3 Ethernet interfaces/subinterfaces and Layer 3 aggregate interfaces/subinterfaces.
¡ Loopback interfaces.
2. Enter monitor link group view.
3. Configure member interfaces for the monitor link group.
port interface-type { interface-number | interface-number.subnumber } { downlink | uplink }
By default, no member interfaces exist in a monitor link group.
2. Enter interface view or subinterface view.
3. Configure the interface as a member of a monitor link group.
port monitor-link group group-id { downlink | uplink }
By default, the interface is not a monitor link group member.
A monitor link can monitor BGP instances and BGP sessions as its uplink interfaces:
· The monitor link group takes a BGP process as an uplink interface. When a BGP instance goes down (the corresponding BGP process exits), the monitor link group takes it as an uplink interface down event. When the BGP instance comes up, the monitor link group takes it as an uplink interface up event.
· The monitor link group takes a BGP session as an uplink interface. When a BGP instance goes down (the corresponding BGP process exits), the monitor link group takes it as an uplink interface down event. When the BGP instance comes up, the monitor link group takes it as an uplink interface up event. For more information about the monitoring of BGP sessions, see advanced BGP configuration in Layer 3—IP Routing Command Reference.
When the number of uplink interfaces in up state in a monitor link group is lower than the uplink interface threshold configured by the uplink up-port-threshold command, the monitor link group goes down and forces all downlink interfaces to go down. When the number of uplink interfaces in up state in the monitor link group is larger than or equal to the uplink interface threshold, the monitor link group comes up and brings up all its downlink interfaces.
If a monitored BGP session is established in a monitored BGP instance, the monitor link group calculates the number of uplink interfaces in up state as follows:
· If a minimum of one BGP session in the BGP instance is in up state, the monitor link group calculates only the number of BGP sessions in up state.
· If no BGP session in the BGP instance is in up state, the monitor link group calculates only the BGP instance coming up as an uplink interface up event.
3. Configure a monitor link group to monitor a BGP instance.
monitor bgp instance-name
3. Configure the uplink interface threshold for triggering monitor link group state switchover.
uplink up-port-threshold number-of-port
By default, the uplink interface threshold for triggering monitor link group state switchover is 1.
3. Configure the switchover delay for the downlink interfaces in the monitor link group.
downlink up-delay delay
By default, the switchover delay is 0 seconds. The downlink interfaces come up as soon as an uplink interface comes up.
To display Monitor Link group information, execute the following command in any view:
display monitor-link [ bgp ] group { group-id | all }
Monitor Link configuration examples
Example: Configuring Monitor Link
As shown in Figure 2:
· Device C is a Smart Link device, and Device A, Device B, and Device D are associated devices. Traffic of VLANs 1 through 30 on Device C is dual-uplinked to Device A through a smart link group.
· Implement dual uplink backup on Device C. When the link between Device A and Device B (or Device D) fails, Device C can detect the link fault. It then performs uplink switchover in the smart link group.
For more information about Smart Link, see "Configuring Smart Link."
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
1. Configure Device C:
# Create VLANs 1 through 30.
<DeviceC> system-view
[DeviceC] vlan 1 to 30
# Map these VLANs to MSTI 1.
[DeviceC-mst-region] instance 1 vlan 1 to 30
# Activate MST region configuration.
[DeviceC-mst-region] quit
# Shut down HundredGigE 1/0/1.
[DeviceC] interface hundredgige 1/0/1
[DeviceC-HundredGigE1/0/1] shutdown
# Disable the spanning tree feature on the interface.
[DeviceC-HundredGigE1/0/1] undo stp enable
# Configure the interface as a trunk port.
[DeviceC-HundredGigE1/0/1] port link-type trunk
# Assign the interface to VLANs 1 through 30.
[DeviceC-HundredGigE1/0/1] port trunk permit vlan 1 to 30
[DeviceC-HundredGigE1/0/1] quit
# Configure HundredGigE 1/0/2 in the same way HundredGigE 1/0/1 is configured.
[DeviceC] interface hundredgige 1/0/2
[DeviceC-HundredGigE1/0/2] shutdown
[DeviceC-HundredGigE1/0/2] undo stp enable
[DeviceC-HundredGigE1/0/2] port link-type trunk
[DeviceC-HundredGigE1/0/2] port trunk permit vlan 1 to 30
[DeviceC-HundredGigE1/0/2] quit
# Create smart link group 1, and configure all the VLANs mapped to MSTI 1 as the protected VLANs for smart link group 1.
[DeviceC] smart-link group 1
[DeviceC-smlk-group1] protected-vlan reference-instance 1
# Configure HundredGigE 1/0/1 as the primary port and HundredGigE 1/0/2 as the secondary port for smart link group 1.
[DeviceC-smlk-group1] port hundredgige 1/0/1 primary
[DeviceC-smlk-group1] port hundredgige 1/0/2 secondary
# Enable the smart link group to transmit flush messages.
[DeviceC-smlk-group1] flush enable
[DeviceC-smlk-group1] quit
# Bring up HundredGigE 1/0/1 and HundredGigE 1/0/2.
[DeviceC-HundredGigE1/0/1] undo shutdown
[DeviceC-HundredGigE1/0/2] undo shutdown
2. Configure Device A:
[DeviceA] vlan 1 to 30
# Configure HundredGigE 1/0/1 as a trunk port.
[DeviceA] interface hundredgige 1/0/1
[DeviceA-HundredGigE1/0/1] port link-type trunk
[DeviceA-HundredGigE1/0/1] port trunk permit vlan 1 to 30
# Enable flush message receiving on the interface.
[DeviceA-HundredGigE1/0/1] smart-link flush enable
[DeviceA-HundredGigE1/0/1] quit
[DeviceA] interface hundredgige 1/0/2
[DeviceA-HundredGigE1/0/2] port link-type trunk
[DeviceA-HundredGigE1/0/2] port trunk permit vlan 1 to 30
[DeviceA-HundredGigE1/0/2] smart-link flush enable
[DeviceA-HundredGigE1/0/2] quit
3. Configure Device B:
[DeviceB] vlan 1 to 30
[DeviceB] interface hundredgige 1/0/1
[DeviceB-HundredGigE1/0/1] port link-type trunk
[DeviceB-HundredGigE1/0/1] port trunk permit vlan 1 to 30
[DeviceB-HundredGigE1/0/1] smart-link flush enable
[DeviceB-HundredGigE1/0/1] quit
# Disable the spanning tree feature on HundredGigE 1/0/2.
[DeviceB] interface hundredgige 1/0/2
[DeviceB-HundredGigE1/0/2] undo stp enable
[DeviceB-HundredGigE1/0/2] port link-type trunk
[DeviceB-HundredGigE1/0/2] port trunk permit vlan 1 to 30
[DeviceB-HundredGigE1/0/2] smart-link flush enable
[DeviceB-HundredGigE1/0/2] quit
# Create monitor link group 1.
[DeviceB] monitor-link group 1
# Configure HundredGigE 1/0/1 as an uplink interface for monitor link group 1.
[DeviceB-mtlk-group1] port hundredgige 1/0/1 uplink
# Configure HundredGigE 1/0/2 as a downlink interface for monitor link group 1.
[DeviceB-mtlk-group1] port hundredgige 1/0/2 downlink
[DeviceB-mtlk-group1] quit
4. Configure Device D:
<DeviceD> system-view
[DeviceD] vlan 1 to 30
[DeviceD] interface hundredgige 1/0/1
[DeviceD-HundredGigE1/0/1] port link-type trunk
[DeviceD-HundredGigE1/0/1] port trunk permit vlan 1 to 30
[DeviceD-HundredGigE1/0/1] smart-link flush enable
[DeviceD-HundredGigE1/0/1] quit
[DeviceD] interface hundredgige 1/0/2
[DeviceD-HundredGigE1/0/2] undo stp enable
[DeviceD-HundredGigE1/0/2] port link-type trunk
[DeviceD-HundredGigE1/0/2] port trunk permit vlan 1 to 30
[DeviceD-HundredGigE1/0/2] smart-link flush enable
[DeviceD-HundredGigE1/0/2] quit
[DeviceD] monitor-link group 1
[DeviceD-mtlk-group1] port hundredgige 1/0/1 uplink
[DeviceD-mtlk-group1] port hundredgige 1/0/2 downlink
[DeviceD-mtlk-group1] quit
# When HundredGigE 1/0/2 on Device A goes down because of a link fault, verify information about monitor link group 1 on Device B.
[DeviceB] display monitor-link group 1
Monitor link group 1 information:
Group status : UP
Downlink up delay: 0(s)
Last up time : 16:38:26 2019/4/21
Last down time : 16:37:20 2019/4/21
Up port threshold: 1
Member Role Status
HGE1/0/1 UPLINK UP
HGE1/0/2 DOWNLINK UP
# Verify information about monitor link group 1 on Device D.
[DeviceD] display monitor-link group 1
Group status : DOWN
Last up time : 16:37:20 2019/4/21
Last down time : 16:38:26 2019/4/21
Member Role Status
HGE1/0/1 UPLINK DOWN
HGE1/0/2 DOWNLINK DOWN (Monitor Link)
