03-Device Management
HomeSupportReference GuidesMIB CompanionH3C S5590-EI S5130S-G FS5500-EI FS5500V2-EI S6530X Switch Series MIB Reference-6W10103-Device Management
14-HH3C-ENTRELATION-MIB
14-HH3C-ENTRELATION-MIB 36.40 KB
About this MIB
Use this MIB to obtain information about the relationship between two entities on combo interfaces or stack ports and describes the relationship between combo interfaces and stack ports.
MIB file name
hh3c-entrelation.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cEntityRelation(15)
Tabular objects
hh3cEntRelationTable
About this table
This table contains information about the relationship between combo interfaces and stack ports.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cEntRelationType, hh3cEntityIndex, and hh3cRelatedEntityIndex.
Object (OID)
Access
Value range
Implementation
hh3cEntRelationType (1.3.6.1.4.1.25506.2.15.1.1.1.1.1)
not-accessible
INTEGER
stackport(1),
                comboport(2)
Association type.
Supports only combo interfaces.
hh3cEntityIndex (1.3.6.1.4.1.25506.2.15.1.1.1.1.2)
not-accessible
PhysicalIndex
Integer32 (1..2147483647)
Entity index.
By default, the entity is a combo interface.
hh3cRelatedEntityIndex (1.3.6.1.4.1.25506.2.15.1.1.1.1.3)
read-only
PhysicalIndex
Index of the associated entity.
Implementation varies by product.
