03-Device Management
HomeSupportReference GuidesMIB CompanionH3C S5590-EI S5130S-G FS5500-EI FS5500V2-EI S6530X Switch Series MIB Reference-6W10103-Device Management
01-HH3C-INFOCENTER-MIB
01-HH3C-INFOCENTER-MIB 99.21 KB
HH3C-INFOCENTER-MIB
About this MIB
Use this MIB to configure information center settings, including enabling the information center or configuring log buffers and log hosts. You can access this MIB to obtain information about log entries in the log buffer.
MIB file name
hh3c-infocenter.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cInfoCenter(119)
Scalar objects
hh3cICMaxLogbufferSize
Object (OID)
Access
Value range
Implementation
hh3cICMaxLogbufferSize (1.3.6.1.4.1.25506.2.119.1.1.1)
read-only
Unsigned32
Standard MIB values.
Maximum number of log entries that can be buffered.
As per the MIB.
hh3cICLogbufferSize
Object (OID)
Access
Value range
Implementation
hh3cICLogbufferSize (1.3.6.1.4.1.25506.2.119.1.1.2)
read-write
Unsigned32
Current buffer size.
As per the MIB.
hh3cICLogbufferCurrentMessages
Object (OID)
Access
Value range
Implementation
hh3cICLogbufferCurrentMessages (1.3.6.1.4.1.25506.2.119.1.1.3)
read-only
Unsigned32
Number of messages stored in the log buffer.
As per the MIB.
hh3cICLogbufferOverwrittenMessages
Object (OID)
Access
Value range
Implementation
hh3cICLogbufferOverwrittenMessages (1.3.6.1.4.1.25506.2.119.1.1.4)
read-only
Counter32
Number of overwritten messages in the log buffer.
As per the MIB.
hh3cICLogbufferDroppedMessages
Object (OID)
Access
Value range
Implementation
hh3cICLogbufferDroppedMessages (1.3.6.1.4.1.25506.2.119.1.1.5)
read-only
Counter32
Number of dropped messages in the log buffer.
As per the MIB.
hh3cICMaxLoghost
Object (OID)
Access
Value range
Implementation
hh3cICMaxLoghost (1.3.6.1.4.1.25506.2.119.2.1.1)
read-only
Unsigned32
Maximum number of log hosts supported by the information center.
As per the MIB.
hh3cICLoghostSourceInterface
Object (OID)
Access
Value range
Implementation
hh3cICLoghostSourceInterface (1.3.6.1.4.1.25506.2.119.2.1.2)
read-write
InterfaceIndexOrZero
Source interface through which log messages are sent to log hosts.
As per the MIB.
hh3cICLoghostTimestampType
Object (OID)
Access
Value range
Implementation
hh3cICLoghostTimestampType (1.3.6.1.4.1.25506.2.119.2.1.3)
read-write
ICTimeStampType
date(0),
boot(1),
iso(2),
dateWithoutYear(3),
none(4),
isoWithTimezone(5),
dataWithMilliseconds(6),
isoWithMilliseconds(7),
isoWithMillisecondsAndTimezone(8)
Timestamp format for logs sent to log hosts.
Does not support boot(1).
hh3cICLogGlobalState
Object (OID)
Access
Value range
Implementation
hh3cICLogGlobalState (1.3.6.1.4.1.25506.2.119.5.1.1)
read-write
TruthValue
true(1),
false(2)
Selects whether to enable the information center globally.
As per the MIB.
hh3cICLogTimestampType
Object (OID)
Access
Value range
Implementation
hh3cICLogTimestampType (1.3.6.1.4.1.25506.2.119.5.1.2)
read-write
ICTimeStampType
date(0),
boot(1),
iso(2),
dateWithoutYear(3),
none(4),
isoWithTimezone(5)
Timestamp format for log messages.
Supports only boot, date, and none.
Tabular objects
hh3cICLogbufferContTable
About this table
This table contains log buffer information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cICLogbufferContIndex.
Object (OID)
Access
Value range
Implementation
hh3cICLogbufferContIndex (1.3.6.1.4.1.25506.2.119.1.2.1.1)
not-accessible
Integer32
Integer32 (1..2147483647)
Table index.
As per the MIB.
hh3cICLogbufferContDescription (1.3.6.1.4.1.25506.2.119.1.2.1.2)
read-only
DisplayString
OCTET STRING (0..1600)
Content of the log buffer.
As per the MIB.
hh3cICLoghostTable
About this table
This table specifies a log host and configures output parameters, including IP address of the log host, VPN instance, logging facility, port number of the log host, and log output destination. You can also access this table to obtain log host-related information.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cICLoghostIndex.
Object (OID)
Access
Value range
Implementation
hh3cICLoghostIndex (1.3.6.1.4.1.25506.2.119.2.2.1.1)
not-accessible
Unsigned32
Unsigned32 (1..64)
Table index.
As per the MIB.
hh3cICLoghostIpaddressType (1.3.6.1.4.1.25506.2.119.2.2.1.2)
read-create
InetAddressType
unknown(0), ipv4(1), ipv6(2), ipv4z(3), ipv6z(4), dns(16)
Address type for the log host.
As per the MIB.
hh3cICLoghostIpaddress (1.3.6.1.4.1.25506.2.119.2.2.1.3)
read-create
InetAddress
OCTET STRING (0..255)
IP address of the log host.
As per the MIB.
hh3cICLoghostVPNName (1.3.6.1.4.1.25506.2.119.2.2.1.4)
read-create
DisplayString
Name of the VPN instance to which the log host belongs.
As per the MIB.
hh3cICLoghostFacility (1.3.6.1.4.1.25506.2.119.2.2.1.5)
read-create
ICFacilityType
kernel(0), userLevel(1), mailSystem(2), systemDaemons(3), securityAuthorization(4), internallyMessages(5), linePrinter(6), networkNews(7), uucp(8), clockDaemon(9), securityAuthorization2(10), ftpDaemon(11), ntp(12), logAudit(13), logAlert(14), clockDaemon2(15), local0(16), local1(17), local2(18), local3(19), local4(20), local5(21), local6(22), local7(23)
Logging facility for marking different logging sources, and querying and filtering log messages.
Supports only local0(0), local1(1), local2(2), local3(3), local4(4), local5(5), local6(6), and local7(7).
hh3cICLoghostOperateRowStatus (1.3.6.1.4.1.25506.2.119.2.2.1.6)
read-create
RowStatus
active(1), notInService(2), notReady(3), createAndGo(4), createAndWait(5), destroy(6)
Row status.
As per the MIB.
hh3cICLoghostIpaddressPort (1.3.6.1.4.1.25506.2.119.2.2.1.7)
read-create
Unsigned32
Unsigned32 (1..65535)
Port number of the log host.
As per the MIB.
hh3cICLoghostTAddress (1.3.6.1.4.1.25506.2.119.2.2.1.8)
read-create
TAddress
OCTET STRING (1..255)
Supports only IPv4 addresses.
hh3cICDirectionTable
About this table
This table contains information about syslog output directions and specifies the enablement status of output directions.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cICDirectionIndex.
Object (OID)
Access
Value range
Implementation
hh3cICDirectionIndex (1.3.6.1.4.1.25506.2.119.3.1.1.1)
not-accessible
Unsigned32
Table index.
As per the MIB.
hh3cICDirectionName (1.3.6.1.4.1.25506.2.119.3.1.1.2)
read-only
DisplayString
OCTET STRING (1..30)
Name of a log output destination.
As per the MIB.
hh3cICDirectionState
(1.3.6.1.4.1.25506.2.119.3.1.1.3)
read-write
TruthValue
true(1), false(2)
Status of the log output destination.
Specifies whether to enable log output to the log buffer, log file, security log file, or diagnostic log file.
Log output to other destinations than the above destinations are all enabled.
hh3cICModuleTable
About this table
This table contains available source modules.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cICModuleName.
Object (OID)
Access
Value range
Implementation
hh3cICModuleName (1.3.6.1.4.1.25506.2.119.4.1.1.1)
read-only
DisplayString
OCTET STRING (1..8)
Name of a source module.
As per the MIB.
hh3cICLogTable
About this table
This table specifies the log level of log messages generated by a specific module to a specific output destination, and contains the log buffer information.
Create
Edit/Modify
Delete
Read
The module name in a row cannot contain lowercase letters and cannot be default
A row with the source module named default cannot be deleted
Supported
Supported
Columns
The table indexes are hh3cICDirectionIndex and hh3cICModuleName.
Object (OID)
Access
Value range
Implementation
hh3cICLogLevel (1.3.6.1.4.1.25506.2.119.5.2.1.1)
read-create
ICMessageLevelType
emergency(0),
alert(1),
critical(2),
error(3),
warning(4),
notice(5),
informational(6),
debug(7),
invalid(8)
Severity level of a log message.
As per the MIB.
hh3cICLogRowStatus (1.3.6.1.4.1.25506.2.119.5.2.1.2)
read-create
RowStatus
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
As per the MIB.
