03-Device Management
HomeSupportReference GuidesMIB CompanionH3C S5590-EI S5130S-G FS5500-EI FS5500V2-EI S6530X Switch Series MIB Reference-6W10103-Device Management
13-HH3C-ENTITY-EXT-MIB
13-HH3C-ENTITY-EXT-MIB 261.55 KB
HH3C-ENTITY-EXT-MIB
About this MIB
Use this MIB to obtain entity extended information. Access this MIB to monitor specific entity data, which facilitates management and monitoring on the product through network management.
Products supporting this MIB must first support the ENTITY-MIB MIB.
The following tables show the relationship between the entity extended properties and device entities. Implementation varies by product.
Entity
hh3cEntityExtAdminStatus (R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
Yes
stack
No
other
No
unknown
No
Entity
hh3cEntityExtOperStatus (R)
chassis
No
backplane
No
container
No
power Supply
Yes
fan
Yes
sensor
No
module
Yes
port
Yes
stack
No
other
No
unknown
No
Entity
hh3cEntityExtStandbyStatus (R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
Yes
sensor
No
module
Yes
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtAlarmLight (R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtCpuUsage (R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
Yes(Only support the Module Level1)
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtCpuUsageThreshold (R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtMemUsage (R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtMemUsageThreshold(R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtMemSize (R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtUpTime (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtTemperature (R)
chassis
No
backplane
No
container
No
powerSupply
Yes
fan
Yes
sensor
Yes
module
Yes
port
No
stack
No
other
Yes
unknown
No
Entity
hh3cEntityExtTemperatureThreshold(R/W)
chassis
No
backplane
No
container
No
powerSupply
Yes
fan
Yes
sensor
Yes
module
Yes
port
No
stack
No
other
Yes
unknown
No
Entity
hh3cEntityExtVoltage(R)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtVoltageLowThreshold(R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtVoltageHighThreshold(R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtCriticalTemperatureThreshold(R/W)
chassis
No
backplane
No
container
No
powerSupply
No
fan
No
sensor
Yes
module
No
port
No
stack
No
other
No
unknown
No
Entity
hh3cEntityExtMacAddress (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
No
port
No
stack
Yes
other
No
unknown
No
Entity
hh3cEntityExtErrorStatus (R)
chassis
No
backplane
Yes
container
Yes
powerSupply
Yes
fan
Yes
sensor
Yes
module
No
port
Yes
stack
No
other
Yes
unknown
Yes
Entity
hh3cEntityExtManuSerialNum (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
Yes
port
No
cpu
No
Entity
hh3cEntityExtManuBuildInfo (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
Yes
port
No
cpu
No
Entity
hh3cEntityExtMacAddressCount (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
Yes
port
Yes
cpu
No
Entity
hh3cEntityExtManuBOM (R)
chassis
Yes
backplane
No
container
No
powerSupply
No
fan
No
sensor
No
module
Yes
port
No
cpu
No
Entity
(R/W: Read/Write)
POWERSUPPLY
FAN
CHASSIS
CONTAINER
MODULE
PORT
CPU
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
Yes
hh3cEntityExtTemperatureThreshold (R/W)
hh3cEntityExtVoltage (R)
hh3cEntityExtVoltageLowThreshold (R/W)
hh3cEntityExtVoltageHighThreshold (R/W)
Yes
·     Yes indicates that the extended property is supported.
·     If the read operation returns no such name/instance, the object is not supported in the current entity instance.
MIB file name
hh3c-entity-ext.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cEntityExtend(6)
Scalar objects
hh3cEntityExtTrapDescription
Object (OID)
Access
Value range
Implementation
hh3cEntityExtTrapDescription (1.3.6.1.4.1.25506.2.6.2.1.1)
accessible-for-notify
SnmpAdminString
OCTET STRING(0..255)
Detailed information of the trap.
As per the MIB.
hh3cEntityExtECCParityAlarmStatus
Object (OID)
Access
Value range
Implementation
hh3cEntityExtECCParityAlarmStatus (1.3.6.1.4.1.25506.2.6.2.1.2)
INTEGER
other(1),
l1cache(2),
l2cache(3),
sdram(4),
mac(5),
tcam(6),
ingressbuffer(7),
egressbuffer(8),
lpm(9),
controlmemory(10)
Resource type of the chip on which an ECC error or parity check error occurs.
As per the MIB.
hh3cEntityExtSFPInvalidInDays
Object (OID)
Access
Value range
Implementation
hh3cEntityExtSFPInvalidInDays (1.3.6.1.4.1.25506.2.6.2.1.3)
Integer32
Standard MIB values.
Remaining valid days of a transceiver module.
As per the MIB.
hh3cEntityExtFirstTrapTime
Object (OID)
Access
Value range
Implementation
hh3cEntityExtFirstTrapTime (1.3.6.1.4.1.25506.2.6.2.1.4)
TimeTicks
Time when a trap is sent for the first time.
As per the MIB.
Tabular objects
hh3cEntityExtStateTable
About this table
This table contains information about entity extended properties, including administrative status, operation status, CPU usage, CPU usage threshold, memory usage, and memory usage threshold.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cEntityExtPhysicalIndex.
Object (OID)
Access
Value range
Implementation
hh3cEntityExtPhysicalIndex (1.3.6.1.4.1.25506.2.6.1.1.1.1.1)
Integer32
Integer32 (1..2147483647)
The index for this entry, which is the same with the value of entPhysicalIndex in ENTITY-MIB.
As per the MIB.
hh3cEntityExtAdminStatus (1.3.6.1.4.1.25506.2.6.1.1.1.1.2)
read-write
Hh3cAdminState
notSupported(1), locked(2), shuttingDown(3), unlocked(4)
Administrative status for this object.
Does not support notSupported(1) or shuttingDown(3).
·     locked—The resource is disabled.
·     shuttingDown—The resource is available only the current entity.
·     unlocked—The resource is not disabled.
hh3cEntityExtOperStatus (1.3.6.1.4.1.25506.2.6.1.1.1.1.3)
read-only
Hh3cOperState
notSupported(1), disabled(2), enabled(3), dangerous(4)
Operation status
·     disabled—The resource is not operable.
·     enabled—The resource or part of the resource is operable.
hh3cEntityExtStandbyStatus (1.3.6.1.4.1.25506.2.6.1.1.1.1.4)
read-only
Hh3cStandbyStatus
notSupported(1), hotStandby(2), coldStandby(3), providingService(4)
Standby status.
·     notStandby—The resource is not providing services, but it can provide services without being initialized. The resource in this status also contains information about the resources being backed up.
·     coldStandby—The resource is not providing services, but it can operate.
·     providingService—The resource is providing services.
hh3cEntityExtAlarmLight (1.3.6.1.4.1.25506.2.6.1.1.1.1.5)
read-only
Hh3cAlarmStatus
BITS { notSupported(0), underRepair(1), critical(2), major(3), minor(4), alarmOutstanding(5), warning(6), indeterminate(7) }
Alarm status for this entity.
Not supported.
An integer indicates an alarm status as follows:
¡ 0—notSupported. This indicates that none of the subsequent statuses is present.
¡ 1—underRepair. This indicates that the resource is being repaired.
¡ 2—critical. This indicates that one or multiple critical faults occurred on the resource.
¡ 3—major. This indicates that one or multiple major faults occurred on the resource.
¡ 4—minor. This indicates that one or multiple minor faults occurred on the resource.
¡ 5—alarmOutstanding. This indicates that one or multiple alarms occurred on the resource and might cause system interruption.
¡ 6—warning. This indicates that one or multiple warning faults occurred on the resource.
¡ 7—indeterminate. This indicates that one or multiple indeterminate faults occurred on the resource.
hh3cEntityExtCpuUsage (1.3.6.1.4.1.25506.2.6.1.1.1.1.6)
read-only
Integer32
Integer32 (0..100)
CPU usage for this entity.
The statistics interval for CPU usage is 5 seconds.
As per the MIB.
hh3cEntityExtCpuUsageThreshold (1.3.6.1.4.1.25506.2.6.1.1.1.1.7)
read-write
Integer32
Integer32 (0..100)
CPU usage alarm threshold in percentage.
Value range: 1 to 100.
As per the MIB.
hh3cEntityExtMemUsage (1.3.6.1.4.1.25506.2.6.1.1.1.1.8)
read-only
Integer32
Integer32 (0..100)
Memory usage for this entity in percentage.
As per the MIB.
hh3cEntityExtMemUsageThreshold (1.3.6.1.4.1.25506.2.6.1.1.1.1.9)
read-write
Integer32
Integer32 (0..100)
Memory usage alarm threshold in percentage.
As per the MIB.
hh3cEntityExtMemSize (1.3.6.1.4.1.25506.2.6.1.1.1.1.10)
read-only
Unsigned32
Unsigned32 (0..4294967295)
Memory size for this entity, in bytes. The memory is a 32-bit wide memory.
As per the MIB.
hh3cEntityExtUpTime (1.3.6.1.4.1.25506.2.6.1.1.1.1.11)
read-only
Integer32
Integer32 (-2147483648..2147483647)
Uptime for the entity., in seconds.
As per the MIB.
hh3cEntityExtTemperature (1.3.6.1.4.1.25506.2.6.1.1.1.1.12)
read-only
Integer32
Temperature of the entity.
The value 65535 indicates that the object is not supported.
hh3cEntityExtTemperatureThreshold (1.3.6.1.4.1.25506.2.6.1.1.1.1.13)
read-write
Integer32
hh3cEntityExtVoltage (1.3.6.1.4.1.25506.2.6.1.1.1.1.14)
read-only
Integer32
Voltage for the entity.
hh3cEntityExtVoltageLowThreshold (1.3.6.1.4.1.25506.2.6.1.1.1.1.15)
read-write
Integer32
Low-voltage threshold for the entity.
hh3cEntityExtVoltageHighThreshold (1.3.6.1.4.1.25506.2.6.1.1.1.1.16)
read-write
Integer32
High-voltage threshold for the entity.
hh3cEntityExtCriticalTemperatureThreshold (1.3.6.1.4.1.25506.2.6.1.1.1.1.17)
read-write
Integer32
Critical high-temperature threshold for the entity.
hh3cEntityExtMacAddress (1.3.6.1.4.1.25506.2.6.1.1.1.1.18)
read-only
MacAddress
OCTET STRING (6)
MAC address of the entity.
If the type of the entity is stack, the value of this object is bridge MAC address of the current device.
If this object is not supported in the current entity instance, the value of this object is fixed at 00.00.00.00.00.00.
hh3cEntityExtErrorStatus (1.3.6.1.4.1.25506.2.6.1.1.1.1.19)
read-only
INTEGER
notSupported(1),
normal(2),
postFailure(3),
entityAbsent(4),
poeError(11),
stackError(21),
stackPortBlocked(22),
stackPortFailed(23),
sfpRecvError(31),
sfpSendError(32),
sfpBothError(33),
fanError(41),
psuError(51),
rpsError(61),
moduleFaulty(71),
sensorError(81),
hardwareFaulty(91)
Alarm status for the entity, which is a supplement to hh3cEntityExtOperStatus.
·     notSupported(1)—The entity does not support this object.
·     normal(2)—The entity is normal. For ports, the object does not differentiate 10 Mbps, 100 Mbps, 1000 Mbps, duplex or half duplex ports. For fans, power supplies, cards, SFP ports, and stack ports, the object indicates they are normal.
·     postFailure(3)—The entity fails during POST.
·     entityAbsent(4)—The entity is absent.
·     poeError(11)—A power supply fault occurs on the PoE port.
·     stackError(21)—An issue occurs on the stack port during the stacking process.
·     stackPortBlocked(22)—The stack port is in standby status in the resilient daisy chain.
·     stackPortFailed(23)—The stacking process fails on a stack port after the stacking is enabled on the stack port.
·     sfpRecvError(31)—A fault occurs in the inbound direction of an SFP port.
·     sfpSendError(32)—A fault occurs in the outbound direction of an SFP port.
·     sfpBothError(33)—A fault occurs in both the inbound and outbound directions of an SFP port.
·     fanError(41)—A fan fault is present.
·     psuError(51)—A power supply fault is present.
·     rpsError(61)—An RPS fault is present.
·     moduleFaulty(71)— A card fault is present.
·     sensorError(81)—A sensor fault is present.
·     hardwareFaulty(91)—A hardware fault occurs on the entity.
hh3cEntityExtCpuMaxUsage (1.3.6.1.4.1.25506.2.6.1.1.1.1.20)
read-only
Integer32
Integer32 (0..100)
Peak CPU usage during the most recent 1-minute interval.
As per the MIB.
hh3cEntityExtLowerTemperatureThreshold (1.3.6.1.4.1.25506.2.6.1.1.1.1.21)
read-write
Integer32
Low-temperature threshold for the entity.
hh3cEntityExtShutdownTemperatureThreshold (1.3.6.1.4.1.25506.2.6.1.1.1.1.22)
read-write
Integer32
Shutdown temperature threshold.
Notifies and shuts down the device when the threshold is reached.
hh3cEntityExtPhyMemSize (1.3.6.1.4.1.25506.2.6.1.1.1.1.23)
read-only
Unsigned32
As per the MIB.
hh3cEntityExtPhyCpuFrequency (1.3.6.1.4.1.25506.2.6.1.1.1.1.24)
read-only
Integer32
CPU frequency of the entity, in MHz.
hh3cEntityExtFirstUsedDate (1.3.6.1.4.1.25506.2.6.1.1.1.1.25)
read-only
DateAndTime
OCTET STRING (8)
The date used for the first on the entity.
hh3cEntityExtCpuAvgUsage  (1.3.6.1.4.1.25506.2.6.1.1.1.1.26)
read-only
Integer32
Integer32 (0..100)
Average CPU usage for the entity during a time period.
As per the MIB.
hh3cEntityExtMemAvgUsage (1.3.6.1.4.1.25506.2.6.1.1.1.1.27)
read-only
Integer32
Integer32 (0..100)
Average memory usage for the entity during a time period.
As per the MIB.
hh3cEntityExtMemType (1.3.6.1.4.1.25506.2.6.1.1.1.1.28)
read-only
OCTET STRING
OCTET STRING (0..64)
Memory type for the entity.
As per the MIB.
hh3cEntityExtCriticalLowerTemperatureThreshold(1.3.6.1.4.1.25506.2.6.1.1.1.1.29)
read-write
Integer32
hh3cEntityExtShutdownLowerTemperatureThreshold(1.3.6.1.4.1.25506.2.6.1.1.1.1.30)
read-write
Integer32
Low-temperature shutdown temperature threshold.
hh3cEntityExtCpuUsageRecoverThreshold(1.3.6.1.4.1.25506.2.6.1.1.1.1.31)
read-write
Integer32
Integer32 (0..100)
CPU usage recovery threshold for the entity.
Not supported
hh3cEntityExtMemSizeRev
(1.3.6.1.4.1.25506.2.6.1.1.1.1.32)
read-only
Counter64
Counter64 (0..18446744073709551615)
Memory size for this entity, in bytes. The memory is a 64-bit wide memory.
As per the MIB.
hh3cEntityExtCpuUsageIn1Minute(1.3.6.1.4.1.25506.2.6.1.1.1.1.33)
read-only
Integer32
Integer32 (0..100)
Average CPU usage for the entity during the most recent 1-minute interval.
As per the MIB.
hh3cEntityExtCpuUsageIn5Minutes(1.3.6.1.4.1.25506.2.6.1.1.1.1.34)
read-only
Integer32
Integer32 (0..100)
Average CPU usage for the entity during the most recent 5-minute interval.
As per the MIB.
hh3cEntityExtManuTable
About this table
This table contains manufacturing information about device entities.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cEntityExtManuPhysicalIndex.
Object (OID)
Access
Value range
Implementation
hh3cEntityExtManuPhysicalIndex (1.3.6.1.4.1.25506.2.6.1.2.1.1.1)
PhysicalIndex
Entity index.
As per the MIB.
hh3cEntityExtManuSerialNum (1.3.6.1.4.1.25506.2.6.1.2.1.1.2)
read-only
SnmpAdminString
OCTET STRING (0..255)
Serial number of the entity.
As per the MIB.
hh3cEntityExtManuBuildInfo (1.3.6.1.4.1.25506.2.6.1.2.1.1.3)
read-only
SnmpAdminString
Version of the entity.
As per the MIB.
hh3cEntityExtManuBOM (1.3.6.1.4.1.25506.2.6.1.2.1.1.4)
read-only
SnmpAdminString
BOM number of the entity.
As per the MIB.
hh3cEntityExtMacAddressCount (1.3.6.1.4.1.25506.2.6.1.2.1.1.5)
read-only
Unsigned32
MAC address count for the entity.
As per the MIB.
hh3cEntityExtPowerTable
About this table
This table contains power information about all entities on the device.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cEntityExtPowerPhysicalIndex.
Object (OID)
Access
Value range
Implementation
hh3cEntityExtPowerPhysicalIndex (1.3.6.1.4.1.25506.2.6.1.3.1.1.1)
PhysicalIndex
Entity index for the power supply.
As per the MIB.
hh3cEntityExtNominalPower (1.3.6.1.4.1.25506.2.6.1.3.1.1.2)
read-only
Gauge32
Gauge32 (0..4294967295)
Rated power for the entity, in milliwatts.
As per the MIB.
hh3cEntityExtCurrentPower (1.3.6.1.4.1.25506.2.6.1.3.1.1.3)
read-only
Gauge32
Current power for the entity, in milliwatts.
As per the MIB.
hh3cEntityExtAveragePower (1.3.6.1.4.1.25506.2.6.1.3.1.1.4)
read-write
Gauge32
Average power consumed by the entity, in milliwatts.
The value 0 is the only valid value, indicating that the system clears the existing records and restarts the power statistics. The other values for this object will not take effect.
As per the MIB.
hh3cEntityExtPeakPower (1.3.6.1.4.1.25506.2.6.1.3.1.1.5)
read-write
Integer32
Maximum power for the entity, in milliwatts.
As per the MIB.
hh3cProcessTable
About this table
This table contains process information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cProcessID.
Object (OID)
Access
Value range
Implementation
hh3cProcessID (1.3.6.1.4.1.25506.2.6.1.4.1.1.1)
read-only
Unsigned32
Process ID.
As per the MIB.
hh3cProcessName (1.3.6.1.4.1.25506.2.6.1.4.1.1.2)
read-only
DisplayString
OCTET STRING (1..32)
Process name.
As per the MIB.
hh3cProcessUtil5Min (1.3.6.1.4.1.25506.2.6.1.4.1.1.3)
read-only
Unsigned32
Unsigned32 (0..100)
CPU usage of the process during a 5-minute interval.
As per the MIB.
hh3cEntityExtVoltageTable
About this table
This table contains information about voltage sensors.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cEntityExtCurrentVoltage (1.3.6.1.4.1.25506.2.6.1.5.1.1.1)
read-only
Integer32
Current voltage for the entity, in milliwatts.
hh3cEntityExtNominalVoltage (1.3.6.1.4.1.25506.2.6.1.5.1.1.2)
read-only
Integer32
Rated voltage for the entity, in milliwatts.
hh3cEntityExtVoltageState (1.3.6.1.4.1.25506.2.6.1.5.1.1.3)
read-only
INTEGER
normal(0),
low(1),
tooLow(2),
high(3),
tooHigh(4)
Voltage status of the entity.
hh3cEntityExtVoltageMajorLowThreshold
(1.3.6.1.4.1.25506.2.6.1.5.1.1.4)
read-only
Integer32
Low-temperature warning threshold.
hh3cEntityExtVoltageFatalLowThreshold
(1.3.6.1.4.1.25506.2.6.1.5.1.1.5)
read-only
Integer32
Low-temperature fatal threshold.
hh3cEntityExtVoltageMajorHighThreshold
(1.3.6.1.4.1.25506.2.6.1.5.1.1.6)
read-only
Integer32
High-temperature warning threshold.
hh3cEntityExtVoltageFatalHighThreshold
(1.3.6.1.4.1.25506.2.6.1.5.1.1.7)
read-only
Integer32
High-temperature fatal threshold.
Notifications
The following information describes the notifications included in the HH3C-ENTITY-EXT-MIB module.
hh3cEntityExtTemperatureThresholdNotification
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.6.2.0.1
Temperature of the entity higher than the threshold
Error notification
Major
ON
This notification is generated when the temperature of the entity exceeds the upper limit.
Status control
This alarm cannot be cleared.
Objects
OID (object)
Index
Value range
1.3.6.1.4.1.25506.2.6.1.1.1.1.1 (hh3cEntityExtPhysicalIndex)
Entity index.
Y
Integer32
1.3.6.1.4.1.25506.2.6.1.1.1.1.12 (hh3cEntityExtTemperature)
N
Integer32
1.3.6.1.4.1.25506.2.6.1.1.1.1.13 (hh3cEntityExtTemperatureThreshold)
Temperature threshold for the entity.
N
Integer32
1.3.6.1.4.1.25506.2.6.1.1.1.1.2 (hh3cEntityExtAdminStatus)
Administrative status of the entity.
N
Hh3cAdminState
notSupported(1)
locked(2)
shuttingDown(3)
unlocked(4)}
1.3.6.1.4.1.25506.2.6.1.1.1.1.5 (hh3cEntityExtAlarmLight)
Alarm status of the entity.
N
Hh3cAlarmStatus
BITS {
notSupported(0)
underRepair(1)
critical(2)
major(3)
minor(4)
alarmOutstanding(5)
warning(6)
indeterminate(7)
Recommended action
To resolve the issue:
1.     Verify that the temperature of the environment is normal. Execute the display environment command to obtain temperature information, including the current temperature and the temperature thresholds.
2.     Identify the reason why the temperature exceeded the upper limit.
3.     Verify that the temperature has dropped back to the normal.
4.     If the issue persists, contact H3C Support.
hh3cEntityExtCpuUsageThresholdNotfication
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.4
CPU usage of the entity higher than the threshold
Error notification
Major
1.3.6.1.4.1.25506.2.6.2.0.25(hh3cEntityExtCpuUsageThresholdRecover)
ON
This notification is generated when the CPU usage of the entity exceeds the threshold. The notification is sent every 60 seconds till the alarm is cleared.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
1.3.6.1.4.1.25506.2.6.1.1.1.1.6 (hh3cEntityExtCpuUsage)
CPU usage of the entity.
N
Integer32
0..100
1.3.6.1.4.1.25506.2.6.1.1.1.1.7 (hh3cEntityExtCpuUsageThreshold)
CPU usage threshold for the entity.
N
Integer32
0..100
N
Hh3cAdminState
notSupported(1)
locked(2)
shuttingDown(3)
unlocked(4)}
N
Hh3cAlarmStatus
BITS {
notSupported(0)
underRepair(1)
critical(2)
major(3)
minor(4)
alarmOutstanding(5)
warning(6)
indeterminate(7)
1.3.6.1.4.1.25506.2.6.1.1.1.1.31 (hh3cEntityExtCpuUsageRecoverThreshold)
N
Integer32
0..100
1.3.6.1.4.1.25506.2.6.2.1.4 (hh3cEntityExtFirstTrapTime)
Timestamp at which the notification is sent for the first time.
N
TimeTicks
Recommended action
1.     If the alarm is automatically cleared, no action is required.
2.     If the alarm cannot be automatically cleared, contact H3C Support.
hh3cEntityExtMemUsageThresholdNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.5
Memory usage of the entity higher than the threshold
Error notification
Major
1.3.6.1.4.1.25506.2.6.2.0.26(hh3cEntityExtMemUsageThresholdRecover)
ON
This notification is generated when the memory usage of the entity exceeds the threshold. The notification is sent every 60 seconds till the alarm is cleared.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
1.3.6.1.4.1.25506.2.6.1.1.1.1.8 (hh3cEntityExtMemUsage)
Memory usage of the entity.
N
Integer32
0..100
1.3.6.1.4.1.25506.2.6.1.1.1.1.9 (hh3cEntityExtMemUsageThreshold)
Memory usage threshold for the entity.
N
Integer32
0..100
1.3.6.1.4.1.25506.2.6.1.1.1.1.10 (hh3cEntityExtMemSize)
Memory size of the entity.
N
Unsigned32
N
Hh3cAdminState
notSupported(1)
locked(2)
shuttingDown(3)
unlocked(4)}
N
Hh3cAlarmStatus
BITS {
notSupported(0)
underRepair(1)
critical(2)
major(3)
minor(4)
alarmOutstanding(5)
warning(6)
indeterminate(7)
N
TimeTicks
Recommended action
hh3cEntityExtCriticalTemperatureThresholdNotification
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.8
Temperature of the entity higher than the critical high-temperature threshold
Error notification
Critical
ON
This notification is generated when the temperature of the entity exceeded the critical high-temperature threshold. The notification is sent every 80 seconds till the alarm is cleared.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
N
Integer32
1.3.6.1.4.1.25506.2.6.1.1.1.1.17 (hh3cEntityExtCriticalTemperatureThreshold)
N
Integer32
N
Hh3cAdminState
notSupported(1)
locked(2)
shuttingDown(3)
unlocked(4)}
N
Hh3cAlarmStatus
BITS {
notSupported(0)
underRepair(1)
critical(2)
major(3)
minor(4)
alarmOutstanding(5)
warning(6)
indeterminate(7)
Recommended action
2.     Identify the reason why the temperature exceeded the critical high-temperature threshold.
hh3cEntityInsert
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.12
Entity installation
ON
This notification is generated when the entity is installed to the device.
Status control
Objects
OID (object name)
Index
Value range
1.3.6.1.2.1.47.1.1.1.1.2 (entPhysicalDescr)
Description of the entity.
N
SnmpAdminString
OCTET STRING (SIZE (0..255))
N
Hh3cAdminState
notSupported(1)
locked(2)
shuttingDown(3)
unlocked(4)}
1.3.6.1.4.1.25506.2.6.1.1.1.1.3 (hh3cEntityExtOperStatus)
Operation status of the entity.
N
Hh3cOperState
notSupported(1)
disabled(2)
enabled(3)
dangerous(4)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required.
hh3cEntityRemove
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.13
Entity removal
Error notification
Minor
1.3.6.1.4.1.25506.2.6.2.0.12(hh3cEntityInsert)
ON
This notification is generated when the entity is removed from the device.
Status control
Objects
OID (object name)
Index
Value range
N
SnmpAdminString
N
Hh3cAdminState
notSupported(1)
locked(2)
shuttingDown(3)
unlocked(4)}
N
Hh3cOperState
notSupported(1)
disabled(2)
enabled(3)
dangerous(4)
Recommended action
1.     If the entity was removed from the device, no action is required.
2.     If the entity was not removed, verify that the entity is installed correctly.
3.     If the issue persists, contact H3C Support.
hh3cEntityExtFaultAlarmOn
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.16
Error occurrence on the entity
Error notification
Major
1.3.6.1.4.1.25506.2.6.2.0.16(hh3cEntityExtFaultAlarmOff)
ON
This notification is generate when an error occurs on the entity.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
1.3.6.1.2.1.47.1.1.1.1.7 (entPhysicalName)
Entity name.
N
SnmpAdminString
1.3.6.1.4.1.25506.2.6.1.1.1.1.19 (hh3cEntityExtErrorStatus)
Alarm status for the entity.
N
INTEGER
notSupported(1)
normal(2)
postFailure(3)
entityAbsent(4)
poeError(11)
stackError(21)
stackPortFailed(23)
sfpRecvError(31)
sfpSendError(32)
sfpBothError(33
 fanError(41)
psuError(51)
rpsError(61)
moduleFaulty(71)
sensorError(81)
hardwareFaulty(91)
N
Hh3cAdminState
notSupported(1)
locked(2)
shuttingDown(3)
unlocked(4)}
N
Hh3cAlarmStatus
BITS {
notSupported(0)
underRepair(1)
critical(2)
major(3)
minor(4)
alarmOutstanding(5)
warning(6)
indeterminate(7)
Recommended action
1.     Verify that the entity is installed correctly.
2.     If the issue persists, contact H3C Support.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.17
Error clearance
N/A
N/A
ON
This notification is generated when the entity recovers from the faulty state.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
Entity name.
N
SnmpAdminString
N
INTEGER
notSupported(1)
normal(2)
postFailure(3)
entityAbsent(4)
poeError(11)
stackError(21)
stackPortFailed(23)
sfpRecvError(31)
sfpSendError(32)
sfpBothError(33
 fanError(41)
psuError(51)
rpsError(61)
moduleFaulty(71)
sensorError(81)
hardwareFaulty(91)
N
Hh3cAdminState
notSupported(1)
locked(2)
shuttingDown(3)
unlocked(4)}
N
Hh3cAlarmStatus
BITS {
notSupported(0)
underRepair(1)
critical(2)
major(3)
minor(4)
alarmOutstanding(5)
warning(6)
indeterminate(7)
Recommended action
hh3cEntityExtTemperatureLower
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.20
Temperature of the entity lower than the low-temperature threshold
Error notification
Major
1.3.6.1.4.1.25506.2.6.2.0.22(hh3cEntityExtTemperatureNormal)
ON
This notification is generated when the temperature of the entity decreases below the low-temperature threshold.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
Entity name.
N
SnmpAdminString
N
Integer32
1.3.6.1.4.1.25506.2.6.1.1.1.1.21 (hh3cEntityExtLowerTemperatureThreshold)
N
Integer32
N
Hh3cAdminState
notSupported(1)
locked(2)
shuttingDown(3)
unlocked(4)}
Recommended action
2.     Identify the reason why the temperature dropped below the lower limit.
3.     Verify that the temperature has increased to the normal.
hh3cEntityExtTemperatureTooUp
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.21
Temperature of the entity higher than the shutdown temperature threshold
Error notification
Critical
ON
This notification is generated when the temperature of the entity exceeds the shutdown temperature threshold. The notification is sent every 80 seconds till the alarm is cleared.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
Entity name.
N
SnmpAdminString
N
Integer32
1.3.6.1.4.1.25506.2.6.1.1.1.1.22 (hh3cEntityExtShutdownTemperatureThreshold)
Shutdown temperature threshold for the entity.
N
Integer32
N
Hh3cAdminState
notSupported(1)
locked(2)
shuttingDown(3)
unlocked(4)}
Recommended action
2.     Identify the reason why the temperature exceeded the shutdown temperature threshold.
Basic information
OID
Event
Severity
Default status
Temperature of the entity back to normal
ON
This notification is generated when the temperature of the entity recovers from the abnormal status.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
Entity name.
N
SnmpAdminString
N
Integer32
N
Integer32
N
Integer32
N
Hh3cAdminState
notSupported(1)
locked(2)
shuttingDown(3)
unlocked(4)}
Recommended action
hh3cEntityExternalAlarmOccur
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.23
Error on a peripheral of the entity
Error notification
Major
1.3.6.1.4.1.25506.2.6.2.0.24(hh3cEntityExternalAlarmRecover)
ON
This notification is generated when an error occurs on the peripheral of the entity.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
Entity name.
N
SnmpAdminString
Recommended action
Basic information
OID
Event
Severity
Default status
A peripheral of the entity back to normal
ON
This notification is generated when the peripheral of the entity recovers from the faulty state.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
Entity name.
N
SnmpAdminString
Recommended action
Basic information
OID
Event
Severity
Default status
Recovery of the CPU usage  from an alarm threshold
ON
This notification is generated when the CPU usage of the entity recovers from the abnormal state.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
N
Integer32
0..100
N
Integer32
0..100
N
Hh3cAdminState
notSupported(1)
locked(2)
shuttingDown(3)
unlocked(4)}
N
Hh3cAlarmStatus
BITS {
notSupported(0)
underRepair(1)
critical(2)
major(3)
minor(4)
alarmOutstanding(5)
warning(6)
indeterminate(7)
N
Integer32
0..100
N
TimeTicks
Recommended action
Basic information
OID
Event
Severity
Default status
Recovery of the memory usage  from an alarm threshold
ON
This notification is generated when the memory usage of the entity recovers from the abnormal state.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
N
Integer32
0..100
N
Integer32
0..100
N
Unsigned32
N
Hh3cAdminState
notSupported(1)
locked(2)
shuttingDown(3)
unlocked(4)}
N
Hh3cAlarmStatus
BITS {
notSupported(0)
underRepair(1)
critical(2)
major(3)
minor(4)
alarmOutstanding(5)
warning(6)
indeterminate(7)
N
TimeTicks
Recommended action
hh3cEntityExtMemAllocatedFailed
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.27
Memory allocation request failure
Informational
Major
ON
This notification is generated when memory allocation for the entity failed.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
1.3.6.1.4.1.25506.2.6.2.1.1 (hh3cEntityExtTrapDescription)
Description of the notification.
N
SnmpAdminString
Recommended action
To resolve the issue, contact H3C Support.
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.28
ECC parity check error
Informational
Major
ON
This notification is generated when an ECC parity check error occurs on the entity.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
1.3.6.1.4.1.25506.2.6.2.1.2 (hh3cEntityExtECCParityAlarmStatus)
Status of ECC parity check for the entity
N
INTEGER
other(1)
l1cache(2)
l2cache(3)
sdram(4)
mac(5)
tcam(6)
ingressbuffer(7)
egressbuffer(8)
lpm(9)
controlmemory(10)
N
SnmpAdminString
Recommended action
hh3cEntityExtMemUsageThresholdOverTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.35
Continuous notifications of memory usage exceeding the threshold
Error notification
Major
1.3.6.1.4.1.25506.2.6.2.0.36(hh3cEntityExtMemUsageThresholdRecoverTrap)
ON
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
N
Integer32
0..100
N
Integer32
0..100
1.3.6.1.4.1.25506.2.6.1.1.1.1.32 (hh3cEntityExtMemSizeRev)
N
Counter64
N
Hh3cAdminState
notSupported(1)
locked(2)
shuttingDown(3)
unlocked(4)}
N
Hh3cAlarmStatus
BITS {
notSupported(0)
underRepair(1)
critical(2)
major(3)
minor(4)
alarmOutstanding(5)
warning(6)
indeterminate(7)
Recommended action
Basic information
OID
Event
Severity
Default status
ON
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
N
Integer32
0..100
N
Integer32
0..100
N
Counter64
N
Hh3cAdminState
notSupported(1)
locked(2)
shuttingDown(3)
unlocked(4)}
N
Hh3cAlarmStatus
BITS {
notSupported(0)
underRepair(1)
critical(2)
major(3)
minor(4)
alarmOutstanding(5)
warning(6)
indeterminate(7)
Recommended action
hh3cEntityExtVoltageNormal
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.37
Recovery of the voltage from an alarm threshold
ON
This notification is generated when the voltage of the entity recovers from the abnormal state.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
1.3.6.1.4.1.25506.2.6.1.5.1.1.1 (hh3cEntityExtCurrentVoltage)
Voltage of the entity.
N
Integer32
1.3.6.1.4.1.25506.2.6.1.5.1.1.2 (hh3cEntityExtNominalVoltage)
Rated voltage of the entity.
N
Integer32
1.3.6.1.4.1.25506.2.6.1.5.1.1.4 (hh3cEntityExtVoltageMajorLowThreshold)
N
Integer32
1.3.6.1.4.1.25506.2.6.1.5.1.1.6 (hh3cEntityExtVoltageMajorHighThreshold)
N
Integer32
Recommended action
hh3cEntityExtVoltageLower
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.38
Voltage of the entity lower than the low-voltage threshold
Error notification
Major
1.3.6.1.4.1.25506.2.6.2.0.37(hh3cEntityExtVoltageNormal)
ON
This notification is generated when the voltage of the entity drops below the low-voltage threshold.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
N
Integer32
N
Integer32
N
Integer32
Recommended action
1.     Verify that the power system of the device is normal.
hh3cEntityExtVoltageTooLow
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.39
Voltage of the threshold lower than critical low-voltage threshold
Error notification
Critical
ON
This notification is generated when the voltage of the entity drops below the critical low-voltage threshold. The notification is sent every 80 seconds till the alarm is cleared.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
N
Integer32
N
Integer32
1.3.6.1.4.1.25506.2.6.1.5.1.1.5 (hh3cEntityExtVoltageFatalLowThreshold)
Critical low-voltage threshold for the entity.
N
Integer32
Recommended action
hh3cEntityExtVoltageHigher
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.40
Voltage of the entity higher than the high-voltage threshold
Error notification
Major
ON
This notification is generated when the voltage of the entity increases above the high-voltage threshold.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
N
Integer32
N
Integer32
N
Integer32
Recommended action
hh3cEntityExtVoltageTooHigh
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.6.2.0.41
Voltage of the entity higher than the critical high-voltage threshold
Error notification
Critical
ON
This notification is generated when the voltage of the entity increases over the critical high-voltage threshold. The notification is sent every 80 seconds till the alarm is cleared.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Y
Integer32
N
Integer32
N
Integer32
1.3.6.1.4.1.25506.2.6.1.5.1.1.7 (hh3cEntityExtVoltageFatalHighThreshold)
Critical high-voltage threshold for the entity.
N
Integer32
Recommended action
