- H3C Switch Software Upgrade Guide-6W101
- 01-About software upgrade
- 02-Upgrade restrictions and guidelines
- 03-Upgrade workflow
- 04-Preparing for the upgrade
- 05-Upgrading the BootWare
- 06-Upgrading the startup software
- 07-Installing patches and features
- 08-Verifying the upgrade
- 09-Rolling back the running software images
- 10-Troubleshooting
- 11-Appendix A Downloading the upgrade file
01-About software upgrade | 41.09 KB |
Software types
Software types include the BootWare image and startup software images. They are required for the device to start and run and provide support, management, and other services.
BootWare image
This image contains a basic segment and an extended segment. The basic segment is the minimum code that bootstraps the system. The extended segment enables hardware initialization and provides system management menus. When the device cannot start up correctly, you can use the menus to load software and the startup configuration file or manage files.
NOTE: Typically, you do not need to upgrade the BootWare, and use the built-in BootWare of the switch. |
Startup software images
Startup software image subcategories
Startup software images include the following image subcategories:
· Boot image—A .bin file that contains the Linux operating system kernel. It provides process management, memory management, file system management, and the emergency shell.
· System image—A .bin file that contains the Comware kernel and standard features, including device management, interface management, configuration management, and routing.
· Feature image—A .bin file that contains advanced or customized software features.
· Patch image—A .bin file that is released for fixing bugs without rebooting the device. A patch image does not add or remove features.
The boot image and system image are required for the device to operate and cannot be uninstalled. A feature or patch image can be uninstalled.
Software release forms
All startup software images except patch images are released as a whole in one .ipe package file. The images in an .ipe package file are compatible. The system decompresses the file automatically, loads the .bin images and sets them as startup software images.
Main and backup startup software images
To upgrade software, you must specify the upgrade files as the startup software images for the device to load at next startup. You can specify two lists of software images: one main and one backup. The device first loads the main startup software images. If the main startup software images are not available, the device loads the backup startup software images.
Software upgrade types
Software upgrade types include BootWare upgrade, startup software upgrade, and feature and patch installation.
