- H3C Switch Software Upgrade Guide-6W101
- 01-About software upgrade
- 02-Upgrade restrictions and guidelines
- 03-Upgrade workflow
- 04-Preparing for the upgrade
- 05-Upgrading the BootWare
- 06-Upgrading the startup software
- 07-Installing patches and features
- 08-Verifying the upgrade
- 09-Rolling back the running software images
- 10-Troubleshooting
- 11-Appendix A Downloading the upgrade file
09-Rolling back the running software images | 39.68 KB |
This chapter includes the following sections:
Application scenarios
The following are application scenarios for version rollback:
· You need to roll back the running software version to the old version due to business requirements.
· You need to roll back the running software version to the old version if the device cannot work correctly after a software upgrade.
Rollback workflow
The version rollback workflow is the same as the version upgrade workflow. For more information, see "Upgrade workflow."
Rollback procedure
The version rollback procedure is the same as the version upgrade procedure. For more information, see "Upgrading the startup software."
Verifying the rollback
Verifying the rollback is the same as verifying the upgrade. For more information, see "Verifying the upgrade."
