H3C Switch Software Upgrade Guide-6W101
HomeSupportInstall & UpgradeUpgrade GuidesH3C Switch Software Upgrade Guide-6W101
06-Upgrading the startup software
06-Upgrading the startup software 120.84 KB
You can upgrade the startup software by using the following methods:
·     Upgrading the startup software by using the boot loader method
·     Upgrading the startup software from the BootWare menu
·     Performing a compatible upgrade by using ISSU commands (distributed devices)
·     Performing a compatible upgrade by using ISSU commands (centralized devices)
·     Performing an incompatible upgrade by using ISSU commands (distributed devices)
·     Performing an incompatible upgrade by using ISSU commands (centralized devices)
Upgrade workflow
Table 1 Upgrade workflow
Upgrade procedure
Preparing for the upgrade
See "Preparing for the upgrade."
Downloading the upgrade file
Download the upgrade file from an PC to the switch. For more information, see "Appendix A Downloading the upgrade file."
·     You can specify an .ipe file or a boot image file and a system image file in the boot-loader file command. This section uses an .ipe file as an example.
·     Available commands vary by switch model. This section uses an S10500 switch as an example.
·     The upgrade procedure for single-MPU devices is the same as that for dual-MPU devices.
# Specify an .ipe file as the main startup software file.
<Sysname> boot-loader file flash:/all.ipe all main
Verifying the file flash:/all.ipe on slot 1..............Done.
H3C S10510 images in IPE:
  boot.bin
  system.bin
This command will set the main startup software images. Continue? [Y/N]:y
# Specify an .ipe file as the backup startup software file.
<Sysname> boot-loader file flash:/all2.ipe all backup
Verifying the file flash:/all2.ipe on slot 1..............Done.
  boot.bin
  system.bin
This command will set the backup startup software images. Continue? [Y/N]:y
Rebooting the switch
# Reboot the switch to complete the upgrade.
<Sysname> reboot
Start to check configuration with next startup configuration file, please wait.
........DONE!
Now rebooting, please wait...
Upgrade workflow
Table 2 Upgrade workflow
Upgrade procedure
# Return to the EXTENDED-BOOTWARE menu, and enter 0 in the EXTENDED-BOOTWARE menu to reboot the switch.
For a modular switch that has an active MPU and a standby MPU, you must access the BootWare menus of them through the console port to upgrade their startup software. You also need to connect to the management Ethernet ports on both MPUs.
·     Before performing an ISSU, you must use the display version comp-matrix command to identify the recommended ISSU methods.
·     In this section, the IRF fabric has two member devices, and each member device has two MPUs.
·     The command output varies by device model.
Upgrade workflow
Table 3 Upgrade workflow
Upgrade procedure
Identifying the recommended ISSU methods
# Display active software images.
<Sysname> display install active
Active packages on chassis 1 slot 6:
  flash:/boot-t0001015.bin
  flash:/system-t0001015.bin
  flash:/feature-t0001015.bin
Active packages on chassis 1 slot 7:
Active packages on chassis 2 slot 6:
Active packages on chassis 2 slot 7:
# Identify the recommended ISSU methods.
<Sysname> display version comp-matrix file boot flash:/boot-t0001016.bin system flash:/system-t0001016.bin feature flash:/feature-t0001016.bin
Verifying the file flash:/boot-t0001016.bin on chassis 1 slot 6..................................Done.
Verifying the file flash:/system-t0001016.bin on chassis 1 slot 6..................................Done.
Verifying the file flash:/feature-t0001016.bin on chassis 1 slot 6..................................Done.
Identifying the upgrade methods....Done.
  Chassis   Slot              Upgrade Way
  1         6                 Reboot
  1         7                 Reboot
  2         6                 Reboot
  2         7                 Reboot
The output shows that reboot upgrades are recommended.
# Disable automatic rollback.
[Sysname] issu rollback-timer 0
# Enable the IRF bridge MAC address to be permanent.
[Sysname] irf mac-address persistent always
# Save the running configuration.
<Sysname> save
# Upgrade the startup software on the subordinate member.
<Sysname> issu load file boot flash:/boot-t0001016.bin system flash:/system-t0001016.bin feature flash:/feature-t0001016.bin chassis 2
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:y
Copying file flash:/boot-t0001016.bin to chassis2#slot6#flash:/boot-t0001016.bin......Done.
Copying file flash:/system-t0001016.bin to chassis2#slot6#flash:/system-t0001016.bin........................Done.
Copying file flash:/feature-t0001016.bin to chassis2#slot6#flash:/feature-t0001016.bin......Done.
Verifying the file flash:/boot-t0001016.bin on chassis 2 slot 6...Done.
Verifying the file flash:/system-t0001016.bin on chassis 2 slot 6............Done.
Verifying the file flash:/feature-t0001016.bin on chassis 2 slot 6...Done.
Copying file flash:/boot-t0001016.bin to chassis2#slot7#flash:/boot-t0001016.bin......Done.
Copying file flash:/system-t0001016.bin to chassis2#slot7#flash:/system-t0001016.bin........................Done.
Copying file flash:/feature-t0001016.bin to chassis2#slot7#flash:/feature-t0001016.bin......Done.
Verifying the file flash:/boot-t0001016.bin on chassis 2 slot 7...Done.
Verifying the file flash:/system-t0001016.bin on chassis 2 slot 7............Done.
Verifying the file flash:/feature-t0001016.bin on chassis 2 slot 7...Done.
Identifying the upgrade methods….Done.
  Running Version             New Version
  Test 0001015                Test 0001016
  2         6                 Reboot
  2         7                 Reboot
This operation might take several minutes, please wait...Done.
# Verify that the ISSU is in a stable state.
<Sysname> display issu state
ISSU state: Loaded
Compatibility: Compatible
Work state: Normal
Upgrade method: Chassis by chassis
Upgraded chassis:
  chassis 2
Current upgrading chassis: None
Previous version list:
  boot: 7.1.070, Test 0001015
  system: 7.1.070, Test 0001015
  feature: 7.1.070, Test 0001015
Previous software images:
Upgrade version list:
  boot: 7.1.070, Test 0001016
  system: 7.1.070, Test 0001016
  feature: 7.1.070, Test 0001016
Upgrade software images:
The Loaded state is a stable state, which indicates that the system is waiting for a master/subordinate switchover. Chassis 2 has completed the upgrade, and chassis 1 has not.
# Perform a master/subordinate switchover.
<Sysname> issu run switchover
  Chassis   Slot              Switchover Way
  1         6                 Master subordinate switchover
This operation might take several minutes, please wait.........
ISSU state: Switchover
Work state: Normal
Upgraded chassis:
  chassis 2
The Switchover state is a stable state, which indicates that the system has completed the master/subordinate switchover and is waiting for a commit operation to upgrade chassis 1.
# Upgrade the startup software on the original master.
<Sysname> issu commit chassis 1
Copying file flash:/boot-t0001016.bin to chassis1#slot7#flash:/boot-t0001016.bin......Done.
Copying file flash:/system-t0001016.bin to chassis1#slot7#flash:/system-t0001016.bin........................Done.
Copying file flash:/feature-t0001016.bin to chassis1#slot7#flash:/feature-t0001016.bin......Done.
Verifying the file flash:/boot-t0001016.bin on chassis 1 slot 7...Done.
Verifying the file flash:/system-t0001016.bin on chassis 1 slot 7...Done.
Verifying the file flash:/feature-t0001016.bin on chassis 1 slot 7...Done.
  1         6                 Reboot
  1         7                 Reboot
Verifying the upgrade
# Verify that the ISSU is finished.
ISSU state: Init
Compatibility: Unknown
Upgraded chassis: None
Current version list:
Current software images:
The ISSU state field displays Init, which indicates that the ISSU is finished.
# Verify that both members are running the new software images.
·     In this section, the IRF fabric has two member devices.
Upgrade workflow
Table 4 Upgrade workflow
Upgrade procedure
Download the upgrade file from an PC to the switch. For more information, "Appendix A Downloading the upgrade file."
Active packages on slot 1:
Active packages on slot 2:
Verifying the file flash:/boot-t0001016.bin on slot 1.......................Done.
Verifying the file flash:/system-t0001016.bin on slot 1................. .................Done.
Verifying the file flash:/feature-t0001016.bin on slot 1.................Done.
  Slot                        Upgrade Way
  1                           Reboot
  2                           Reboot
<Sysname> save
<Sysname> issu load file boot flash:/boot-t0001016.bin system flash:/system-t0001016.bin feature flash:/feature-t0001016.bin slot 2
Copying file flash:/boot-t0001016.bin to slot2#flash:/boot-t0001016.bin......Done.
Copying file flash:/system-t0001016.bin to slot2#flash:/system-t0001016.bin........................Done.
Copying file flash:/feature-t0001016.bin to slot2#flash:/feature-t0001016.bin......Done.
Verifying the file flash:/boot-t0001016.bin on slot 2...Done.
Verifying the file flash:/system-t0001016.bin on slot 2............Done.
Verifying the file flash:/feature-t0001016.bin on slot 2...Done.
  Slot                        Upgrade Way
  2                           Reboot
ISSU state: Loaded
Work state: Normal
Upgrade method: Card by card
Upgraded slot:
  slot 2
Current upgrading slot: None
The Loaded state is a stable state, which indicates that the system is waiting for a master/subordinate switchover. Slot 2 has completed the upgrade, and slot 1 has not.
  Slot                        Switchover Way
  1                           Master subordinate switchover
Work state: Normal
Upgraded slot:
  slot 2
The Switchover state is a stable state, which indicates that the system has completed the master/subordinate switchover and is waiting for a commit operation to upgrade slot 1.
<Sysname> issu commit slot 1
  Slot                        Upgrade Way
  1                           Reboot
ISSU state: Init
Work state: Normal
Upgraded slot: None
Upgrade workflow
Table 5 Upgrade workflow
Upgrade procedure
<Sysname> display version comp-matrix file boot flash:/boot-t0001017.bin system flash:/system-t0001017.bin feature flash:/feature-t0001017.bin
Verifying the file flash:/boot-t0001017.bin on chassis 1 slot 6..................................Done.
Verifying the file flash:/system-t0001017.bin on chassis 1 slot 6..................................Done.
Verifying the file flash:/feature-t0001017.bin on chassis 1 slot 6..................................Done.
Incompatible upgrade
The output shows that an incompatible upgrade is recommended.
<Sysname> save
<Sysname> issu load file boot flash:/boot-t0001017.bin system flash:/system-t0001017.bin feature flash:/feature-t0001017.bin chassis 2
Copying file flash:/boot-t0001017.bin to chassis2#slot6#flash:/boot-t0001017.bin......Done.
Copying file flash:/system-t0001017.bin to chassis2#slot6#flash:/system-t0001017.bin........................Done.
Copying file flash:/feature-t0001017.bin to chassis2#slot6#flash:/feature-t0001017.bin......Done.
Verifying the file flash:/boot-t0001017.bin on chassis 2 slot 6...Done.
Verifying the file flash:/system-t0001017.bin on chassis 2 slot 6............Done.
Verifying the file flash:/feature-t0001017.bin on chassis 2 slot 6...Done.
Copying file flash:/boot-t0001017.bin to chassis2#slot7#flash:/boot-t0001017.bin......Done.
Copying file flash:/system-t0001017.bin to chassis2#slot7#flash:/system-t0001017.bin........................Done.
Copying file flash:/feature-t0001017.bin to chassis2#slot7#flash:/feature-t0001017.bin......Done.
Verifying the file flash:/boot-t0001017.bin on chassis 2 slot 7...Done.
Verifying the file flash:/system-t0001017.bin on chassis 2 slot 7............Done.
Verifying the file flash:/feature-t0001017.bin on chassis 2 slot 7...Done.
  Test 0001015                Test 0001017
  2         6                 Reboot
  2         7                 Reboot
Upgrading software images to incompatible versions. Continue? [Y/N]:y
ISSU state: Loaded
Compatibility: Incompatible
Work state: Normal
Upgraded chassis:
  chassis 2
  boot: 7.1.070, Test 0001017
  system: 7.1.070, Test 0001017
  feature: 7.1.070, Test 0001017
Copying file flash:/boot-t0001017.bin to chassis1#slot7#flash:/boot-t0001017.bin......Done.
Copying file flash:/system-t0001017.bin to chassis1#slot7#flash:/system-t0001017.bin........................Done.
Copying file flash:/feature-t0001017.bin to chassis1#slot7#flash:/feature-t0001017.bin......Done.
Verifying the file flash:/boot-t0001017.bin on chassis 1 slot 7...Done.
Verifying the file flash:/system-t0001017.bin on chassis 1 slot 7............Done.
Verifying the file flash:/feature-t0001017.bin on chassis 1 slot 7...Done.
  1         6                 Reboot
  1         7                 Reboot
ISSU state: Init
Work state: Normal
Upgrade workflow
Table 6 Upgrade workflow
Upgrade procedure
Verifying the file flash:/boot-t0001017.bin on slot 1.......................Done.
Verifying the file flash:/system-t0001017.bin on slot 1................. .................Done.
Verifying the file flash:/feature-t0001017.bin on slot 1.................Done.
Incompatible upgrade.
# Enable link-aggregation traffic redirection.
[Sysname] link-aggregation lacp traffic-redirect-notification enable
<Sysname> save
<Sysname> issu load file boot flash:/boot-t0001017.bin system flash:/system-t0001017.bin feature flash:/feature-t0001017.bin slot 2
Copying file flash:/boot-t0001017.bin to slot2#flash:/boot-t0001017.bin......Done.
Copying file flash:/system-t0001017.bin to slot2#flash:/system-t0001017.bin........................Done.
Copying file flash:/feature-t0001017.bin to slot2#flash:/feature-t0001017.bin......Done.
Verifying the file flash:/boot-t0001017.bin on slot 2...Done.
Verifying the file flash:/system-t0001017.bin on slot 2............Done.
Verifying the file flash:/feature-t0001017.bin on slot 2...Done.
  Slot                        Upgrade Way
  2                           Reboot
ISSU state: Loaded
Work state: Normal
Upgraded slot:
  slot 2
  Slot                        Switchover Way
ISSU state: Init
Work state: Normal
Upgraded slot: None
