08-Configuration Examples
HomeSupportConfigure & DeployH3C Firewall Products Comware 7 Web Configuration Guide-6W40208-Configuration Examples
Table of Contents
Related Documents
32-Context Configuration Examples
32-Context Configuration Examples 245.28 KB
Context configuration examples
Introduction
The following information provides context configuration examples.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of the context feature.
When you assign VLANs to contexts, follow these restrictions and guidelines:
·     For contexts without the VLAN-unshared attribute, you can only assign VLANs to them and cannot use the vlan command to create VLANs for them. Before the assignment, you must create the VLANs on the default context.
·     You cannot assign the following VLANs to a context without the VLAN-unshared attribute:
¡     VLAN 1.
¡     Default VLANs of interfaces.
¡     VLANs for which you have created VLAN interfaces.
When you assign interfaces to contexts, follow these restrictions and guidelines:
·     Subinterfaces, VLAN interfaces, and aggregate interfaces can be assigned to a context only in shared mode.
·     After assigning a subinterface to a context, you cannot assign its primary interface to a context. After assigning a primary interface to a context, you cannot assign its subinterfaces to a context.
·     Do not assign member interfaces of an aggregate interface to a context in shared mode.
·     After assigning an interface to contexts in shared mode, you cannot assign the interface to contexts in exclusive mode before reclaiming the interface.
·     Do not assign IRF physical interfaces to a non-default context.
·     If a subinterface of a Layer 3 interface is a member interface of a Reth interface, do not assign the Layer 3 interface to a non-default context.
Example: Configuring contexts
As shown in Figure 1, configure contexts for the LANs as follows:
·     Configure context cnt1 for LAN 1. Assign 60% disk space and 60% memory space to the context and set the CPU weight to 8.
·     Configure context cnt2 for LAN 2. Leave the context to use the default amount of disk space and the default amount of memory space.
·     Configure context cnt3 for LAN 3. Set the CPU weight to 2.
·     Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/11 to context cnt1. Assign GigabitEthernet 1/0/2 and GigabitEthernet 1/0/12 to context cnt2. Assign GigabitEthernet 1/0/3 and GigabitEthernet 1/0/13 to context cnt3.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on F9345 of the F1060 device.
1.     Configure context cnt1:
# On the top navigation bar, click System.
# From the navigation pane, select Virtualization Advanced Settings > Contexts > Contexts.
# Click Create.
# Configure context cnt1 as shown in Figure 2.
# Click OK.
Figure 2 Creating a context
# Select context cnt1 from the context list and click Start.
Figure 3 Starting context cnt1
# From the navigation pane, select Virtualization Advanced Settings > Contexts > Resource Allocation.
# Click context cnt1 and edit the resource allocation scheme for the context as shown in Figure 4.
# Click OK.
Figure 4 Editing the resource allocation scheme
2.     Configure context cnt2 and cnt3 in the same way you configure context cnt1.
1.     On the top navigation bar, click System.
2.     From the navigation pane, select Virtualization Advanced Settings > Contexts > Contexts.
3.     Verify that the contexts are listed and their settings are as configured.
Figure 5 Viewing contexts
4.     From the navigation pane, select Virtualization Advanced Settings > Contexts > Resource Allocation to view the amounts of memory and disk resources allocated to contexts.
Figure 6 Viewing context resource allocation
5.     From the navigation pane, select Virtualization Advanced Settings > Contexts > Resource Usage to view the resource usage of contexts
Figure 7 Viewing resource usage of contexts
