08-Configuration Examples
HomeSupportConfigure & DeployH3C Firewall Products Comware 7 Web Configuration Guide-6W40208-Configuration Examples
Table of Contents
Related Documents
07-OSPF configuration examples
07-OSPF configuration examples 355.97 KB
Introduction
The following information provides OSPF configuration examples.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The configuration examples were created and verified in a lab environment, and all the devices were started with the factory default configuration. When you are working on a live network, make sure you understand the potential impact of every command on your network
The following information is provided based on the assumption that you have basic knowledge of OSPF.
Example: Configuring OSPF
As shown in Figure 1, Device A and Device B are connected to R&D and finance departments, respectively. Device C is a router that acts as the gateway to the Internet.
Configure OSPF on the devices to enable the R&D and finance departments to learn routing information from each other. Configure a default route with the next hop being the gateway address 200.2.2.254 on Device C, and redistribute the default route to OSPF.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on F9345 of the F1060 device.
OSPF uses multicast addresses 224.0.0.5 and 224.0.0.6 to establish neighbor relationships. You must configure a security policy to permit the traffic between the local security zone and the security zones that contain the OSPF interfaces. For more information, see the configuration procedure.
Configuring Device A
1.     Assign IP addresses to interfaces and add the interfaces to security zones.
# On the top navigation bar, click Network.
# From the navigation pane, select Interface Configuration > Interfaces.
# Click the Edit icon for GE 1/0/1.
# In the dialog box that opens, configure the interface:
a.     Select the Untrust security zone.
b.     On the IPv4 Address tab, enter the IP address and mask of the interface. In this example, enter 10.0.0.1/24.
c.     Retain the default configuration for the rest of parameters.
d.     Click OK.
# Add GE 1/0/2 to the Trust security zone and set its IP address to 10.1.1.1/24 in the same way you configure GE 1/0/1.
2.     Create security policies.
# On the top navigation bar, click the Policies tab.
# From the navigation pane, select Security Policies > Security Policies.
# Select Create > Create a policy.
# Create security policy ospf-a:
¡     Enter policy name ospf-a.
¡     Select source zone Trust.
¡     Select destination zone Untrust.
¡     Select type IPv4.
¡     Select action Permit.
¡     Enter 10.1.1.0/24 as the source address.
¡     Retain the default configuration for the rest of parameters.
# Click OK.
# Create security policy ospf-b:
¡     Enter policy name ospf-b.
¡     Select source zone Local.
¡     Select destination zone Unrust.
¡     Select type IPv4.
¡     Select service object group ospf.
# Click OK.
# Create security policy ospf-c:
¡     Enter policy name ospf-c.
¡     Select source zone Unrust.
¡     Select destination zone Local.
¡     Select type IPv4.
# Click OK.
3.     Configure OSPF.
# From the navigation pane, select Routing > OSPF.
Figure 2 Configuring OSPF
# Click Create.
# In the dialog box that opens, configure an OSPF instance.
Figure 3 Creating an OSPF instance
# Click OK.
Figure 4 OSPF instance
# Click 0 in the Number of OSPF areas column for the created OSPF instance.
Figure 5 OSPF areas
# On the OSPF area configuration page that opens, click Create.
# In the dialog box that opens, configure Area 0.
Figure 6 Creating Area 0
# Click OK.
# On the OSPF area configuration page, click Create.
# In the dialog box that opens, configure Area 1.
Figure 7 Creating Area 1
Configuring Device B
b.     On the IPv4 Address tab, enter the IP address and mask of the interface. In this example, enter 10.0.0.2/24.
d.     Click OK.
# Add GE 1/0/2 to the Trust security zone and set its IP address to 10.2.2.1/24 in the same way you configure GE 1/0/1.
¡     Select type IPv4.
¡     Enter 10.2.2.0/24 as the source address.
# Click OK.
¡     Select type IPv4.
# Click OK.
¡     Select source zone Untrust.
¡     Select type IPv4.
# Click OK.
3.     Configure OSPF.
Figure 8 Configuring OSPF
# Click Create.
Figure 9 Creating an OSPF instance
# Click OK.
Figure 10 OSPF instance
Figure 11 OSPF areas
Figure 12 Creating Area 0
# Click OK.
# In the dialog box that opens, configure Area 2.
Figure 13 Creating Area 2
# Click OK.
Configuring Device C
1.     Assign IP addresses to interfaces. (Details not shown.)
2.     Configure OSPF.
# Enable OSPF process 1, and specify the router ID as 3.3.3.3.
<Device C> system-view
[Device C] ospf 1 router-id 3.3.3.3
# Create Area 0 and enter Area 0 view.
[Device C-ospf-1] area 0.0.0.0
# Advertise network 10.0.0.0/24.
[Device C-ospf-1-area-0.0.0.0] network 10.0.0.0 0.0.0.255
[Device C-ospf-1-area-0.0.0.0] quit
# Redistribute the default route into the OSPF routing table.
[Device C-ospf-1] default-route-advertise always
[Device C-ospf-1] quit
# Configure the default route to the ISP.
[Device C] ip route-static 0.0.0.0 0 200.2.2.254
1.     View information about the OSPF routing table of Device A.
# From the navigation pane, select Routing > Routing Table.
# On the IPv4 Routing Table tab, view the OSPF routing table information.
Figure 14 OSPF routing table of Device A
2.     View information about the OSPF routing table of Device B.
Figure 15 OSPF routing table of Device B
3.     Verify that Device A can ping the ISP.
<Device A> ping -a 10.1.1.1 200.2.2.254
Ping 200.2.2.254 (200.2.2.254) from 10.1.1.1: 56 data bytes, press CTRL_C to break
56 bytes from 200.2.2.254: icmp_seq=0 ttl=254 time=0.423 ms
56 bytes from 200.2.2.254: icmp_seq=1 ttl=254 time=0.222 ms
56 bytes from 200.2.2.254: icmp_seq=2 ttl=254 time=0.173 ms
56 bytes from 200.2.2.254: icmp_seq=3 ttl=254 time=0.170 ms
56 bytes from 200.2.2.254: icmp_seq=4 ttl=254 time=0.167 ms
--- Ping statistics for 200.2.2.254 ---
round-trip min/avg/max/std-dev = 0.167/0.231/0.423/0.098 ms
The output shows that the ISP can be pinged.
4.     Verify that Device B can ping the ISP.
<Device B> ping -a 10.0.0.2 200.2.2.254
Ping 200.2.2.254 (200.2.2.254) from 10.0.0.2: 56 data bytes, press CTRL_C to break
56 bytes from 200.2.2.254: icmp_seq=0 ttl=254 time=0.437 ms
56 bytes from 200.2.2.254: icmp_seq=1 ttl=254 time=0.209 ms
56 bytes from 200.2.2.254: icmp_seq=2 ttl=254 time=0.194 ms
56 bytes from 200.2.2.254: icmp_seq=3 ttl=254 time=0.174 ms
56 bytes from 200.2.2.254: icmp_seq=4 ttl=254 time=0.179 ms
round-trip min/avg/max/std-dev = 0.174/0.239/0.437/0.100 ms
