08-Configuration Examples
HomeSupportConfigure & DeployH3C Firewall Products Comware 7 Web Configuration Guide-6W40208-Configuration Examples
Table of Contents
Related Documents
24-NAT configuration examples
24-NAT configuration examples 376.03 KB
The following information describes NAT configuration examples.
The following NAT translation methods are supported:
Static NAT
Static NAT creates a fixed mapping between a private address and a public address. It supports connections initiated from internal users to external network and from external users to the internal network. Static NAT applies to regular communications.
Dynamic NAT
Dynamic NAT uses an address pool to translate addresses. It applies to the scenario where a large number of internal users access the external network.
NAT Server
The NAT Server feature maps a public address and port number to the private IP address and port number of an internal server. This feature allows servers in the private network to provide services for external users.
NAT444 port block
NAT444 provides carrier-grade NAT by unifying the NAT444 gateway, AAA server, and log server. NAT444 introduces a second layer of NAT on the carrier side, with few changes on the customer side and the application server side. With port block assignment, NAT444 supports user tracking. It has become a preferred solution for carriers in transition to IPv6.
This document is not restricted to specific software or hardware versions. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of NAT.
Example: Configuring static NAT
As shown in Figure 1, configure static NAT to allow the host at 172.16.100.1/24 to access the server at 100.100.100.100/24 on the Internet by using public IP address 200.2.2.254/24.
Figure 1 Network diagram
Software versions used
This configuration example was created and verified on F9345 of the F1060 device.
1.     Assign IP addresses to interfaces and add the interfaces to security zones.
# On the top navigation bar, click Network.
# From the navigation pane, select Interface Configuration > Interfaces.
# Click the Edit icon for GE 1/0/1.
# In the dialog box that opens, configure the interface:
a.     Select the Untrust security zone.
b.     On the IPv4 Address tab, enter the IP address and mask of the interface. In this example, enter 200.2.2.254/24.
c.     Click OK.
# Add GE 1/0/2 to the Trust security zone and set its IP address to 172.16.100.254/24 in the same way you configure GE 1/0/1.
2.     Configure settings for routing.
This example configures a static route. If dynamic routes are required, configure a dynamic routing protocol.
# From the navigation pane, select Routing > Static Routing.
# On the IPv4 Static Routing tab, click Create.
# In the dialog box that opens, configure a static route to permit packets from the device to the server:
a.     Specify the IP address of the server as the destination IP. In this example, the address is 100.100.100.100.
b.     Enter the mask length. In this example, enter 24.
c.     Specify the next-hop address as 200.2.2.253.
d.     Click OK.
3.     Configure a security policy.
# On the top navigation bar, click Policies.
# From the navigation pane, select Security Policies > Security Policies.
# Click Create and click Create a policy.
# In the dialog box that opens, configure policy parameters as follows:
a.     Enter a policy name. In this example, the name is Secpolicy.
b.     Select the source zone. In this example, the source zone is Trust.
c.     Select the destination zone. In this example, the destination zone is Untrust.
d.     Select IPv4 as the type.
e.     Select Permit as the action.
f.     Specify the IP address of the host as the source IPv4 address. In this example, the address is 172.16.100.1.
g.     Specify the IP address of the server as the destination IPv4 address. In this example, the address is 100.100.100.100.
h.     Click OK.
4.     Create a static NAT mapping.
# From the navigation pane, select NAT > Static NAT > Policy Configuration.
# Click Create.
# Create a static NAT mapping, as shown in Figure 2.
Figure 2 Creating a static NAT mapping
# Click OK.
5.     Apply the static NAT mapping.
# From the navigation pane, select NAT > Static NAT > Apply Policy.
# Select GE 1/0/1 and click Enable. The mapping has been applied to the interface, as shown in Figure 3.
Figure 3 Applying the static NAT mapping
1.     Verify that the host can successfully ping the server on the external network.
C:\Users\abc>ping 100.100.100.100
Pinging host.com [100.100.100.100] with 32 bytes of data:
Reply from 100.100.100.100: bytes=32 time<1ms TTL=253
Ping statistics for 100.100.100.100:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
2.     Verify that a NAT session is generated when the host accesses the server.
# On the top navigation bar, click Monitor.
# From the navigation pane, select Sessions.
Figure 4 Session list
Example: Configuring NO-PAT for dynamic NAT
As shown in Figure 5, the company has public addresses 200.2.2.1/24 to 200.2.2.3/24. Configure NO-PAT translation to enable hosts in the internal network to access the server on the Internet.
Figure 5 Network diagram
c.     Click OK.
# In the dialog box that opens, configure a static route to permit packets from the internal hosts to the external server:
d.     Click OK.
f.     Specify the IP addresses of the hosts as the source IPv4 addresses. In this example, the address are 172.16.100.1, 172.16.100.2, 172.16.100.3.
g.     Specify the IP address of the server as the destination IPv4. In this example, the address is 100.100.100.100.
h.     Click OK.
4.     Configure a NAT address group.
# From the navigation pane, select NAT > NAT Advanced Settings > NAT Address Groups.
# Click Create.
# Create a NAT address group, as shown in Figure 6.
Figure 6 Creating a NAT address group
# Click OK.
5.     Configure an outbound dynamic NAT rule.
# From the navigation pane, select NAT > Dynamic NAT.
# On the Outbound Dynamic NAT (Object Group-Based) tab, click Create.
# Create an outbound dynamic NAT rule, as shown in Figure 7.
Figure 7 Creating an outbound dynamic NAT rule
# Click OK.
Figure 8 Session list
Example: Configuring PAT for dynamic NAT
As shown in Figure 9, a company has only one public IP addresses 200.2.2.1/24. Configure PAT for outbound dynamic NAT to allow only internal hosts to access the Internet by using this public IP address.
Figure 9 Network diagram
c.     Click OK.
# In the dialog box that opens, configure a static route to permit packets from the hosts to the server:
d.     Click OK.
f.     Specify the IP addresses of the hosts as the source IPv4 addresses. In this example, the address are 172.16.100.1, 172.16.100.2, and 172.16.100.3.
h.     Click OK.
# Click Create.
# Create a NAT address group, as shown in Figure 10.
Figure 10 Creating a NAT address group
# Click OK.
# Create an outbound dynamic NAT rule, as shown in Figure 11.
Figure 11 Creating an outbound dynamic NAT rule
# Click OK.
Figure 12 Session list
Example: Configuring the NAT Server
As shown in Figure 13, the server in the internal network to provide Web services for external users.
Configure the NAT Server feature to allow the external user to use public address 200.2.2.1/24 to access the internal server.
Figure 13 Network diagram
c.     Click OK.
2.     Configure a security policy.
b.     Select the source zone. In this example, the source zone is Untrust.
c.     Select the destination zone. In this example, the destination zone is Trust.
f.     Specify the IP address of the host as the source IPv4 address. In this example, the address is 100.100.100.100.
g.     Specify the IP address of the server as the destination IPv4 address. In this example, the address is 172.16.100.1.
h.     Click OK.
3.     Configure a NAT server rule.
# From the navigation pane, select NAT > NAT Servers > Policy Configuration.
# Click Create.
# Create a NAT server rule, as shown in Figure 14.
Figure 14 Creating a NAT server rule
# Click OK.
1.     Verify that the host can successfully ping the public address.
C:\Users\abc>ping 200.2.2.1
Pinging host.com [200.2.2.1] with 32 bytes of data:
Reply from 200.2.2.1: bytes=32 time<1ms TTL=253
Ping statistics for 200.2.2.1:
2.     Verify that a NAT session is generated when the host accesses the internal server.
Figure 15 Session list
Example: Configuring static NAT444
As shown in Figure 16, a company has one public IP address 200.2.2.1/24. Configure static NAT444 port block mapping to allow internal network users to use this public IP address to access the Internet. Configure the port range as 10001 to 15000, and set the port block size to 500.
Figure 16 Network diagram
c.     Click OK.
a.     Specify the IP address of the server as the destination IP address. In this example, the address is 100.100.100.100.
c.     Specify the public address as the next-hop address as 200.2.2.253.
d.     Click OK.
h.     Click OK.
4.     Configure a port block group.
# From the navigation pane, select NAT > Static NAT444 > Port Blocks.
# Click Create.
# Create a port block group, as shown in Figure 17.
Figure 17 Creating a port block group
# Click OK.
5.     Configure a static NAT444 rule.
# From the navigation pane, select NAT > Static NAT444 > Policy Configuration.
# Click Create.
# Create a static NAT444 rule, as shown in Figure 18.
Figure 18 Creating a static NAT444 rule
# Click OK.
Figure 19 Session list
Example: Configuring dynamic NAT444
As shown in Figure 20, a company has public IP addresses 200.2.2.1/24 to 200.2.2.3/24. Configure NAT444 dynamic port block mapping to meet the following requirements:
·     The internal network users can use public IP addresses to access the Internet.
·     The port range for the public IP addresses is 1024 to 65535.
·     The port block size is 500.
·     If the ports in the assigned port block are all used, extend another port block for users.
Figure 20 Network diagram
c.     Click OK.
d.     Click OK.
a.     Specify the policy name. In this example, the name is Secpolicy.
f.     Specify the IP addresses of the host as the source IPv4 addresses. In this example, the address is 172.16.100.1, 172.16.100.2, and 172.16.100.3.
h.     Click OK.
4.     Configure a security policy.
# Click Create.
# Create a security policy to allow packets to pass through.
5.     Configure a NAT address group.
# Click Create.
# Create a NAT address group, as shown in Figure 21.
Figure 21 Creating a NAT address group
# Click OK.
6.     Configure an outbound dynamic NAT444 rule.
# From the navigation pane, select NAT > Dynamic NAT444.
# On the Outbound Dynamic NAT444 (Object Group-Based) tab, click Create.
# Create an outbound dynamic NAT444 rule, as shown in Figure 22.
Figure 22  Configuring a dynamic NAT444 rule
# Click OK.
Figure 23 Session list
