H3C Fixed Port Campus Switches Configuration Examples-B70D029-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-B70D029-6W100
Table of Contents
Related Documents
49-Static Multicast MAC Address Entry Configuration Examples
Introduction
This document provides configuration examples of static multicast MAC address entries.
This document assumes that you have basic knowledge of multicast MAC addresses.
Example: Configuring static multicast MAC address entries
As shown in Figure 1, Router A runs IGMP and acts as the IGMP querier. Switch A does not run a Layer 2 multicast protocol.
Configure a static multicast MAC address entry on Switch A so that only Host A and Host C can receive multicast data for multicast group 224.1.1.1.
Figure 1 Network diagram
Analysis
Multicast MAC address entries guide Layer 2 multicast forwarding. They can be dynamically created through Layer 2 multicast protocols or manually configured by binding multicast MAC addresses and ports.
In this example, Switch A does not run a Layer 2 multicast protocol. To control destination ports of Layer 2 multicast data, configure a static multicast MAC address entry on Switch A.
Hardware
Software version
S6520X-HI switch series
S6520X-EI switch series
Supported in Release 1110P01
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
When you configure multicast MAC address entries, follow these guidelines:
·     You must specify an unused multicast MAC address in a manually configured multicast MAC address entry.
·     By default, Ethernet interfaces, VLAN interfaces, and aggregate interfaces are shut down. You must first use the undo shutdown command to bring them up. This example assumes that all these interfaces are already up.
Procedures
# On Switch A, create VLAN 100.
[SwitchA] vlan 100
[SwitchA-vlan100] quit
# Configure Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/4 to operate in Layer 2 mode, and assign the ports to VLAN 100.
[SwitchA] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/4
[SwitchA-if-range] port access vlan 100
[SwitchA-if-range] quit
# Translate the multicast IP address 224.1.1.1 to a multicast MAC address (0100-5e01-0101). (Details not shown.)
# Create a static entry for the multicast MAC address 0100-5e01-0101 with Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/4 in VLAN 100 as outgoing ports.
[SwitchA] mac-address multicast 0100-5e01-0101 interface ten-gigabitethernet 1/0/2 ten-gigabitethernet 1/0/4 vlan 100
# Display static multicast MAC address entries for VLAN 100 on Switch A.
[SwitchA] display mac-address multicast vlan 100
MAC Address      VLAN ID    State            Port/NickName            Aging
0100-5e01-0101   100        Multicast        XGE1/0/2                 N
                                             XGE1/0/4
The output shows that Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/4 have become outgoing ports of the multicast MAC group 0100-5e01-0101.
Configuration files
vlan 100
 port link-mode bridge
interface Ten-GigabitEthernet1/0/4
mac-address multicast 0100-5e01-0101 interface Ten-GigabitEthernet1/0/2 Ten-GigabitEthernet1/0/4 vlan 100
