H3C Fixed Port Campus Switches Configuration Examples-B70D029-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-B70D029-6W100
Table of Contents
Related Documents
31-Traffic Filtering Configuration Examples
31-Traffic Filtering Configuration Examples 77.91 KB
Introduction
This document provides traffic filtering configuration examples.
This document assumes that you have basic knowledge of traffic filtering.
Example: Configuring traffic filtering
As shown in Figure 1, a company has three branches, each of which has a Marketing department and a Finance department. All Marketing departments belong to VLAN 20. All Finance departments belong to VLAN 30.
Configure traffic filtering to meet the following requirements:
·     HTTP traffic from the Marketing department in each branch is denied.
·     In Branch B, only Host A and Host B can access the server.
·     The Marketing departments in three branches can access one another, and the Finance departments in three branches can access one another.
Figure 1 Network diagram
Analysis
To meet the network requirements, you must perform the following tasks:
·     To deny HTTP traffic from the Marketing departments, use one of the following methods:
¡     Filter outgoing traffic from the subnet 192.168.4.0/24 on the interfaces that connect Device B, Device C, and Device D to Device A.
This method has poor scalability, because new branches require the same configuration on their access switches.
¡     Filter outgoing traffic from the subnet 192.168.4.0/24 on interface Ten-GigabitEthernet 1/0/4 of Device A.
This method wastes processing capabilities of Device A, because Device A must internally forward all incoming traffic to interface Ten-GigabitEthernet 1/0/4.
¡     Configure a QoS policy to deny HTTP traffic from the Marketing departments.
This method can automatically adapt to changing network topologies and also saves hardware resources by denying traffic on the incoming interface. This example uses this method.
·     To allow only Host A and Host B to access the server in Branch B, perform the following tasks:
¡     Configure an ACL on Ten-GigabitEthernet 1/0/1 to allow packets from 192.168.4.10/24 and 192.168.4.15/24.
¡     Set the default packet filtering action to deny to deny packets that do not match the configured ACL.
·     To allow traffic from Marketing departments and Finance departments (except HTTP traffic) to the Internet and to allow access among Marketing departments and among Finance departments, perform the following tasks:
¡     Configure Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/4 as trunk ports.
¡     Assign these interfaces to VLAN 20 and VLAN 30.
Hardware
Software version
S6520X-HI switch series
S6520X-EI switch series
Supported in Release 1110P01
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
If a traffic behavior is configured with the filter deny action, all other actions in the behavior except traffic accounting do not take effect.
Procedures
Configuring Device A
# Create VLAN 20 and VLAN 30.
[DeviceA] vlan 20
[DeviceA-vlan20]quit
[DeviceA] vlan 30
[DeviceA-vlan30]quit
# Add Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/4 to interface range named myport.
[DeviceA] interface range name myport interface ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/4
# Configures interfaces Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/4 as trunk ports, assign them to VLAN 20 and VLAN 30, and remove them from VLAN 1.
[DeviceA-if-range-myport] port link-type trunk
[DeviceA-if-range-myport] port trunk permit vlan 20 30
[DeviceA-if-range-myport] undo port trunk permit vlan 1
[DeviceA-if-range-myport] quit
# Configure advanced IPv4 ACL 3000 to match HTTP traffic from subnet 192.168.4.0/24.
[DeviceA] acl advanced 3000
[DeviceA-acl-ipv4-adv-3000] rule deny tcp source 192.168.4.0 0.0.0.255 source-port eq 80
[DeviceA-acl-ipv4-adv-3000] quit
# Create a class named vlan20_http, and use ACL 3000 as the match criterion.
[DeviceA] traffic classifier vlan20_http
[DeviceA-classifier-vlan20_http] if-match acl 3000
[DeviceA-classifier-vlan20_http] quit
# Create a behavior named vlan20_http, and configure traffic filtering to deny traffic of the class vlan20_http.
[DeviceA] traffic behavior vlan20_http
[DeviceA-behavior-vlan20_http] filter deny
[DeviceA-behavior-vlan20_http] quit
# Create a QoS policy named vlan20_http, and associate the class vlan20_http with the behavior vlan20_http in the QoS policy.
[DeviceA] qos policy vlan20_http
[DeviceA-qospolicy-vlan20_http] classifier vlan20_http behavior vlan20_http
[DeviceA-qospolicy-vlan20_http] quit
# Apply the QoS policy vlan20_http to the inbound direction of VLAN 20 and VLAN 30.
[DeviceA] qos vlan-policy vlan20_http vlan 20 30 inbound
Configuring Device B
# Configure basic IPv4 ACL 2000 to permit traffic from Host A and Host B.
[DeviceB] acl basic 2000
[DeviceB-acl-ipv4-basic-2000] rule permit source 192.168.4.10 0
[DeviceB-acl-ipv4-basic-2000] rule permit source 192.168.4.15 0
[DeviceB-acl-ipv4-basic-2000] quit
# Set the packet filtering default action to deny.
[DeviceB] packet-filter default deny
# Apply ACL 2000 to interface Ten-GigabitEthernet 1/0/1 to filter outgoing traffic.
[DeviceB-Ten-GigabitEthernet1/0/1] packet-filter 2000 outbound
# Verify the QoS policy applied to the inbound direction of VLAN 20 and VLAN 30.
[DeviceA]display qos vlan-policy vlan inbound
  Direction: Inbound
  Policy: vlan20_http
   Classifier: vlan20_http
     Operator: AND
     Rule(s) :
      If-match acl 3000
     Behavior: vlan20_http
      Filter enable: Deny
Vlan 30
  Direction: Inbound
  Policy: vlan20_http
     Operator: AND
     Rule(s) :
      If-match acl 3000
      Filter enable: Deny
# Display application details of ACLs for incoming packet filtering on Ten-GigabitEthernet 1/0/1.
[DeviceB] display packet-filter verbose interface ten-gigabitethernet 1/0/1 outbound
 Outbound policy:
  IPv4 ACL 2000
   rule 0 permit source 192.168.4.10 0
  IPv4 default action: Deny
Configuration files
·     Device A:
vlan 20
vlan 30
interface range name myport interface Ten-GigabitEthernet1/0/1 to Ten-GigabitEthernet1/0/4
acl advanced 3000
 rule 0 deny tcp source 192.168.4.0 0.0.0.255 source-port eq www
traffic classifier vlan20_http operator and
 if-match acl 3000
 filter deny
 qos vlan-policy vlan20_http vlan 20 inbound
 qos vlan-policy vlan20_http vlan 30 inbound
 port link-mode bridge
interface Ten-GigabitEthernet1/0/4
·     Device B:
acl basic 2000
