H3C Fixed Port Campus Switches Configuration Examples-B70D029-6W100
HomeSupportConfigure & DeployConfiguration ExamplesH3C Fixed Port Campus Switches Configuration Examples-B70D029-6W100
Table of Contents
Related Documents
09-VLAN Configuration Examples
09-VLAN Configuration Examples 148.69 KB
Introduction
This document provides examples of configuring the port-based VLAN, super VLAN and private VLAN.
This document assumes that you have basic knowledge of VLANs.
Example: Configuring port-based VLANs
As shown in Figure 1:
·     Host A and Host C belong to Department A. VLAN 100 is assigned to Department A.
·     Host B and Host D belong to Department B. VLAN 200 is assigned to Department B.
Configure port-based VLANs so that hosts only in the same department can communicate with each other.
Figure 1 Network diagram
Hardware
Software version
S6520X-HI switch series
S6520X-EI switch series
Supported in Release 1110P01
S6520X-SI switch series
S6520-SI switch series
S5000-EI switch series
MS4600 switch series
Procedures
1.     Configure Device A:
# Configure the ports Ten-GigabitEthernet 1/0/1 through Ten-GigabitEthernet 1/0/3 to operate in bridge mode.
[DeviceA] interface range ten-gigabitethernet 1/0/1 to ten-gigabitethernet 1/0/3
[DeviceA-if-range] port link-mode bridge
[DeviceA-if-range] quit
# Create VLAN 100, and assign Ten-GigabitEthernet 1/0/1 to VLAN 100.
[DeviceA] vlan 100
[DeviceA-vlan100] port ten-gigabitethernet 1/0/1
[DeviceA-vlan100] quit
# Create VLAN 200, and assign Ten-GigabitEthernet 1/0/2 to VLAN 200.
[DeviceA] vlan 200
[DeviceA-vlan200] port ten-gigabitethernet 1/0/2
[DeviceA-vlan200] quit
# Configure Ten-GigabitEthernet 1/0/3 as a trunk port, and assign it to VLANs 100 and 200.
[DeviceA] interface ten-gigabitethernet 1/0/3
[DeviceA-Ten-GigabitEthernet1/0/3] port link-type trunk
[DeviceA-Ten-GigabitEthernet1/0/3] port trunk permit vlan 100 200
2.     Configure Device B in the same way Device A is configured. (Details not shown.)
3.     Configure hosts:
a.     Configure Host A and Host C to be on the same IP subnet. For example, 192.168.100.0/24.
b.     Configure Host B and Host D to be on the same IP subnet. For example, 192.168.200.0/24.
# Verify that Host A and Host C can ping each other, but they both fail to ping Host B or Host D. (Details not shown.)
# Verify that Host B and Host D can ping each other, but they both fail to ping Host A or Host C. (Details not shown.)
# Display information about VLANs 100 and 200 on Device A.
[DeviceA-Ten-GigabitEthernet1/0/3] display vlan 100
 VLAN ID: 100
 VLAN type: Static
 Description: VLAN 0100
 Tagged ports:
 Untagged ports:
    Ten-GigabitEthernet1/0/1
[DeviceA-Ten-GigabitEthernet1/0/3] display vlan 200
 VLAN ID: 200
 VLAN type: Static
 Description: VLAN 0200
 Tagged ports:
 Untagged ports:
    Ten-GigabitEthernet1/0/2
The output shows that:
·     Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/1 permit packets from 100 to pass through.
·     Ten-GigabitEthernet 1/0/3 and Ten-GigabitEthernet 1/0/2 permit packets from 200 to pass through.
Configuration files
Configuration files on both Device B and Device A are the same. The following configuration files use Device A as an example.
vlan 100
vlan 200
 port access vlan 100
 port access vlan 200
 port trunk permit vlan 1 100 200
Example: Configuring the super VLAN
As shown in Figure 2:
·     Users in VLAN 2 access the network through Ten-GigabitEthernet 1/0/1 of Device A.
·     Users in VLAN 3 access the network through Ten-GigabitEthernet 1/0/2 of Device A.
·     Ten-GigabitEthernet 1/0/3 of Device A and Ten-GigabitEthernet 1/0/1 of Device B are in VLAN 20.
·     Users in VLAN 20 use the gateway address 192.168.2.1 and IP addresses on the IP network segment 192.168.2.0/24.
Configure a super VLAN to meet the following requirements:
·     Users in VLAN 2 and VLAN 3 use the gateway address 192.168.1.1 and IP addresses on the IP network segment 192.168.1.0/24.
·     Users in VLAN 2, VLAN 3, and VLAN 20 are isolated at Layer 2 but interoperable at Layer 3.
Figure 2 Network diagram
Hardware
Software version
A super VLAN does not have physical ports. A VLAN that has physical ports cannot be configured as a super VLAN.
Procedures
Configuring Device A
# Create VLAN 10 and configure it as a super VLAN.
[DeviceA] vlan 10
[DeviceA-vlan10] supervlan
[DeviceA-vlan10] quit
# Create VLAN 2, and assign Ten-GigabitEthernet 1/0/1 to VLAN 2.
[DeviceA] vlan 2
[DeviceA-vlan2] port ten-gigabitethernet 1/0/1
[DeviceA-vlan2] quit
# Create VLAN 3, and assign Ten-GigabitEthernet 1/0/2 to VLAN 3.
[DeviceA] vlan 3
[DeviceA-vlan3] port ten-gigabitethernet 1/0/2
[DeviceA-vlan3] quit
# Associate super VLAN 10 with VLANs 2 and 3.
[DeviceA] vlan 10
[DeviceA-vlan10] subvlan 2 3
# Create VLAN-interface 10, and assign IP address 192.168.1.1 to it.
[DeviceA-Vlan-interface10] ip address 192.168.1.1 24
# Enable local proxy ARP on VLAN-interface 10.
[DeviceA-Vlan-interface10] local-proxy-arp enable
# Create VLAN 20.
[DeviceA] vlan 20
[DeviceA-vlan20] quit
# Configure Ten-GigabitEthernet 1/0/3 as a trunk port, and remove the port from VLAN 1.
[DeviceA-Ten-GigabitEthernet1/0/3] undo port trunk permit vlan 1
# Assign Ten-GigabitEthernet 1/0/3 to VLAN 20.
[DeviceA-Ten-GigabitEthernet1/0/3] port trunk permit vlan 20
# Create VLAN-interface 20, and assign IP address 192.168.2.1 to it.
[DeviceA] interface Vlan-interface 20
[DeviceA-Vlan-interface20] ip address 192.168.2.1 24
[DeviceA-Vlan-interface20] quit
Configuring Device B
# Create VLAN 20.
[DeviceB] vlan 20
[DeviceB-vlan20] quit
# Configure Ten-GigabitEthernet 1/0/1 as a trunk port, and remove the port from VLAN 1.
[DeviceB-Ten-GigabitEthernet1/0/1] port link-type trunk
[DeviceB-Ten-GigabitEthernet1/0/1] undo port trunk permit vlan 1
# Assign Ten-GigabitEthernet 1/0/1 to VLAN 20.
[DeviceB-Ten-GigabitEthernet1/0/1] port trunk permit vlan 20
# Assign Ten-GigabitEthernet 1/0/2 to VLAN 20.
[DeviceB] vlan 20
[DeviceB-vlan20] port ten-gigabitethernet 1/0/2
# Verify the super VLAN configuration.
[DeviceA] display supervlan
 Super VLAN ID: 10
 Sub-VLAN ID: 2-3
 VLAN ID: 10
 VLAN type: Static
 It is a super VLAN.
 Route interface: Configured
 IPv4 address: 192.168.1.1
 IPv4 subnet mask: 255.255.255.0
 Description: VLAN 0010
 Tagged ports: none
 Untagged ports: none
 VLAN ID: 2
 VLAN type: Static
 It is a sub-VLAN.
 Description: VLAN 0002
 Tagged ports: none
 Untagged ports:
 VLAN ID: 3
 VLAN type: Static
 It is a sub-VLAN.
 Description: VLAN 0003
 Tagged ports: none
 Untagged ports:
# Verify that Host A and Host B can ping each other. In the ARP table of Host A, the IP address of Host B corresponds to the MAC address of VLAN-interface 10. In the ARP table of Host B, the IP address of Host A corresponds to the MAC address of VLAN-interface 10. (Details not shown.)
# Verify that Host A and Host C can ping each other. In the ARP table of Host A, no entry about Host C exists. In the ARP table of Host C, no entry about Host A exists. (Details not shown.)
# Verify that Host B and Host C can ping each other. In the ARP table of Host B, no entry about Host C exists. In the ARP table of Host C, no entry about Host B exists. (Details not shown.)
Configuration files
·     Device A:
vlan 2
vlan 3
vlan 10
 supervlan
 subvlan 2 3
vlan 20
interface Vlan-interface10
interface Vlan-interface20
 ip address 192.168.2.1 255.255.255.0
 port access vlan 2
 port access vlan 3
·     Device B:
vlan 20
 port access vlan 20
Example: Configuring the private VLAN
As shown in Figure 3:
·     The aggregation-layer device Device A assigns VLAN 10 to Device B. Hosts access the network through VLAN-interface 10.
·     Users connected to Device B are on the same subnet 10.0.0.0/24.
·     Host A and Host B are in the Marketing department. Host C and Host D are in the Finance department.
Configure the private VLAN feature to meet the following requirements:
·     Device A is only aware of the primary VLAN 10.
·     Hosts in the same secondary VLAN are interoperable at Layer 2.
·     Hosts in different secondary VLANs are isolated at Layer 2.
Figure 3 Network diagram
Requirements analysis
The private VLAN configuration is required only on Device B.
Hardware
Software version
The system default VLAN (VLAN 1) does not support the private VLAN configuration.
Procedures
# Create VLAN 10 and configure it as a primary VLAN.
[DeviceB] vlan 10
[DeviceB-vlan10] private-vlan primary
[DeviceB-vlan10] quit
# Create VLANs 201 and 202.
[DeviceB] vlan 201 to 202
# Associate primary VLAN 10 with secondary VLANs 201 and 202.
[DeviceB] vlan 10
[DeviceB-vlan10] private-vlan secondary 201 to 202
# Configure the uplink port Ten-GigabitEthernet 1/0/1 as a promiscuous port of VLAN 10.
[DeviceB-Ten-GigabitEthernet1/0/1] port private-vlan 10 promiscuous
# Assign the downlink ports Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3 to VLAN 201 as host ports.
[DeviceB] interface range ten-gigabitethernet 1/0/2 to ten-gigabitethernet 1/0/3
[DeviceB-if-range] port link-mode bridge
[DeviceB-if-range] port access vlan 201
[DeviceB-if-range] port private-vlan host
[DeviceB-if-range] quit
# Assign the downlink ports Ten-GigabitEthernet 1/0/4 and Ten-GigabitEthernet 1/0/5 to VLAN 202 as host ports.
[DeviceB] interface range ten-gigabitethernet 1/0/4 to ten-gigabitethernet 1/0/5
[DeviceB-if-range] port access vlan 202
# Create VLAN 10.
[DeviceA] vlan 10
[DeviceA] quit
# Assign Ten-GigabitEthernet 1/0/1 to VLAN 10.
[DeviceA-Ten-GigabitEthernet1/0/1] port link-mode bridge
[DeviceA-Ten-GigabitEthernet1/0/1] port access vlan 10
# Create VLAN-interface 10, and assign IP address 10.0.0.1 to it.
[DeviceA-Vlan-interface10] ip address 10.0.0.1 24
# Verify that Device A can ping Host A, Host B, Host C, and Host D successfully. (Details not shown.)
# Display the ARP table of Device A.
[DeviceA] display arp
  Type: S-Static   D-Dynamic   O-Openflow   R-Rule   M-Multiport  I-Invalid
IP address      MAC address    VLAN/VSI    Interface/Link ID       Aging Type
10.0.0.2        d485-64a1-7e4a 10          XGE1/0/1                19    D
10.0.0.3        7446-a0aa-7774 10          XGE1/0/1                19    D
10.0.0.4        6805-ca05-39ae 10          XGE1/0/1                20    D
10.0.0.5        6805-ca05-414e 10          XGE1/0/1                20    D
# Display the private VLAN configuration on Device B.
[DeviceB] display private-vlan
 Primary VLAN ID: 10
 Secondary VLAN ID: 201-202
 VLAN ID: 10
 VLAN type: Static
 Private VLAN type: Primary
 Tagged ports:   None
 Untagged ports:
    Ten-GigabitEthernet1/0/1          Ten-GigabitEthernet1/0/2
    Ten-GigabitEthernet1/0/3          Ten-GigabitEthernet1/0/4
    Ten-GigabitEthernet1/0/5
 VLAN ID: 201
 VLAN type: Static
 Private VLAN type: Secondary
 Description: VLAN 0201
 Tagged ports:   None
 Untagged ports:
 VLAN ID: 202
 VLAN type: Static
 Description: VLAN 0202
 Tagged ports:   None
 Untagged ports:
    Ten-GigabitEthernet1/0/1          Ten-GigabitEthernet1/0/4
·     The promiscuous port Ten-GigabitEthernet1/0/1 is an untagged member of primary VLAN 10 and secondary VLANs 201 and 202.
·     The host ports Ten-GigabitEthernet 1/0/2 and Ten-GigabitEthernet 1/0/3 are untagged members of secondary VLANs 201.
·     The host ports Ten-GigabitEthernet 1/0/4 and Ten-GigabitEthernet 1/0/5 are untagged members of secondary VLANs 202.
# Verify that Hosts in the same secondary VLAN can ping each other, but they fail to ping hosts in the other secondary VLAN. (Details not shown.)
Configuration files
·     Device B:
vlan 1
vlan 10
vlan 201 to 202
 port link-type hybrid
 undo port hybrid vlan 1
 port hybrid vlan 10 201 to 202 untagged
 port hybrid pvid vlan 10
 port hybrid vlan 10 201 untagged
 port hybrid pvid vlan 201
interface Ten-GigabitEthernet1/0/4
 port hybrid vlan 10 202 untagged
 port hybrid pvid vlan 202
interface Ten-GigabitEthernet1/0/5
·     Device A:
vlan 1
vlan 10
 ip address 10.0.0.1 255.255.255.0
 port access vlan 10
